commit 108e02b12921078a59dcacd048079ece48a4a983 upstream.
Fix regression introduced by commit b1ffb4c851f1 ("USB: Fix Corruption
issue in USB ftdi driver ftdi_sio.c") which caused the termios settings
to no longer be initialised at open. Consequently it was no longer
possible to set the port to the default speed of 9600 baud without first
changing to another baud rate and back again.
Reported-by: Roland Ramthun <mail@roland-ramthun.de>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Tested-by: Roland Ramthun <mail@roland-ramthun.de>
commit be125d9c8d59560e7cc2d6e2b65c8fd233498ab7 upstream.
We do not implement B0 hangup yet so map low baudrates to 300bps.
Cc: Preston Fick <preston.fick@silabs.com>
commit 791b7d7cf69de11275e4dccec2f538eec02cbff6 upstream.
This device is a Oscilloscope/Logic Analizer/Pattern Generator/TDR,
using a Silabs CP2103 USB to UART Bridge.
Signed-off-by: Renato Caldas <rmsc@fe.up.pt>
commit 6edf3c30af01854c416f8654d3d5d2652470afd4 upstream.
When no platform data was supplied, returned error code was 0.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 86b2bbfdbd1fcc4a3aa62ccd3f245c40c5ad5b85 upstream.
Properly clamp temperature limits set by the user. Without this fix,
attempts to write temperature limits above the maximum supported by
the chip (255 degrees Celsius) would arbitrarily and unexpectedly
result in the limit being set to 0 degree Celsius.
commit 1097ccebe630170080c41df0edcf88e0626e9c75 upstream.
This changes the max length for the usb seven segment delcom device to 8
from 6. Delcom has both 6 and 8 variants and having 8 works fine with
devices which are only 6.
Signed-off-by: Harrison Metzger <harrisonmetz@gmail.com>
Signed-off-by: Stuart Pook <stuart@acm.org>
commit 6d443d8499e4e59ffb949759cdded32730f8d2f6 upstream.
Calling edge_remove_sysfs_attrs from edge_disconnect is too late
as the device has already been removed from sysfs.
Do the simple and obvious thing and make edge_remove_sysfs_attrs
the port_remove method.
Reported-by: Wolfgang Frisch <wfpub@roembden.net>
commit c428b70c1e115c5649707a602742e34130d19428 upstream.
wdm_in_callback() will also touch this field, so we cannot change it without locking
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Acked-by: Oliver Neukum <oneukum@suse.de>
commit 2353f806c97020d4c7709f15eebb49b591f7306d upstream.
0x04d8, 0x000a: Hornby Elite
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit fc216ec363f4d174932df90bbf35c77d0540e561 upstream.
I tested this against 2.6.39 in the Ubuntu kernel, however I see the IDs
are not in latest 3.2 git.
This adds IDs for the FTDI controller in the Rainforest Automation
Zigbee dongle.
Signed-off-by: Peter Naulls <peter@chocky.org>
commit 55f13aeae0346f0c89bfface91ad9a97653dc433 upstream.
Port A for JTAG, port B for serial.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
commit eb833a9e0972f60beb4ab8104ad7ef6bf30f02fc upstream.
Return EINVAL if new baud_base does not match the current one.
The baud_base is device specific and can not be changed. This restores
the old (pre-2005) behaviour which was changed due to a
misunderstanding regarding this fact (see
https://lkml.org/lkml/2005/1/20/84).
Reported-by: Torbjörn Lofterud <torbjorn@pi.nxs.se>
commit ec8013beddd717d1740cfefb1a9b900deef85462 upstream.
A logical volume can map to just part of underlying physical volume.
In this case, it must be treated like a partition.
Based on a patch from Alasdair G Kergon.
Cc: Alasdair G Kergon <agk@redhat.com>
Cc: dm-devel@redhat.com
[bwh: Backport to 2.6.32 - drop change to drivers/md/dm-flakey.c]
commit 0bfc96cb77224736dfa35c3c555d37b3646ef35e upstream.
[ Changes with respect to 3.3: return -ENOTTY from scsi_verify_blk_ioctl
and -ENOIOCTLCMD from sd_compat_ioctl. ]
Linux allows executing the SG_IO ioctl on a partition or LVM volume, and
will pass the command to the underlying block device. This is
well-known, but it is also a large security problem when (via Unix
permissions, ACLs, SELinux or a combination thereof) a program or user
needs to be granted access only to part of the disk.
This patch lets partitions forward a small set of harmless ioctls;
others are logged with printk so that we can see which ioctls are
actually sent. In my tests only CDROM_GET_CAPABILITY actually occurred.
Of course it was being sent to a (partition on a) hard disk, so it would
have failed with ENOTTY and the patch isn't changing anything in
practice. Still, I'm treating it specially to avoid spamming the logs.
In principle, this restriction should include programs running with
CAP_SYS_RAWIO. If for example I let a program access /dev/sda2 and
/dev/sdb, it still should not be able to read/write outside the
boundaries of /dev/sda2 independent of the capabilities. However, for
now programs with CAP_SYS_RAWIO will still be allowed to send the
ioctls. Their actions will still be logged.
This patch does not affect the non-libata IDE driver. That driver
however already tests for bd != bd->bd_contains before issuing some
ioctl; it could be restricted further to forbid these ioctls even for
programs running with CAP_SYS_ADMIN/CAP_SYS_RAWIO.
Cc: linux-scsi@vger.kernel.org
Cc: James Bottomley <JBottomley@parallels.com>
[ Make it also print the command name when warning - Linus ]
[bwh: Backport to 2.6.32 - ENOIOCTLCMD does not get converted to
ENOTTY, so we must return ENOTTY directly]
This reverts commit c8cdf3f97d34d906e0519d5cbc2ab3f81269d0b4, applied on
linux 2.6.32.53 stable release, as it can introduce the following build
error while building 2.6.32.y on armel:
linux-2.6.32/drivers/mmc/host/mmci.c: In function 'mmci_cmd_irq':
linux-2.6.32/drivers/mmc/host/mmci.c:237: error: implicit declaration of function 'dma_inprogress'
linux-2.6.32/drivers/mmc/host/mmci.c:238: error: implicit declaration of function 'mmci_dma_data_error'
Aparently the commit was wrongly pushed into 2.6.32, since it depends on
commit c8ebae37 ("ARM: mmci: add dmaengine-based DMA support"), not
present on 2.6.32.
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
commit 51fc6dc8f948047364f7d42a4ed89b416c6cc0a3 upstream.
For rounds 16--79, W[i] only depends on W[i - 2], W[i - 7], W[i - 15] and W[i - 16].
Consequently, keeping all W[80] array on stack is unnecessary,
only 16 values are really needed.
Using W[16] instead of W[80] greatly reduces stack usage
(~750 bytes to ~340 bytes on x86_64).
Line by line explanation:
* BLEND_OP
array is "circular" now, all indexes have to be modulo 16.
Round number is positive, so remainder operation should be
without surprises.
* initial full message scheduling is trimmed to first 16 values which
come from data block, the rest is calculated before it's needed.
* original loop body is unrolled version of new SHA512_0_15 and
SHA512_16_79 macros, unrolling was done to not do explicit variable
renaming. Otherwise it's the very same code after preprocessing.
See sha1_transform() code which does the same trick.
Patch survives in-tree crypto test and original bugreport test
(ping flood with hmac(sha512).
See FIPS 180-2 for SHA-512 definition
http://csrc.nist.gov/publications/fips/fips180-2/fips180-2withchangenotice.pdf
commit 84e31fdb7c797a7303e0cc295cb9bc8b73fb872d upstream.
commit f9e2bca6c22d75a289a349f869701214d63b5060
aka "crypto: sha512 - Move message schedule W[80] to static percpu area"
created global message schedule area.
If sha512_update will ever be entered twice, hash will be silently
calculated incorrectly.
Probably the easiest way to notice incorrect hashes being calculated is
to run 2 ping floods over AH with hmac(sha512):
#!/usr/sbin/setkey -f
flush;
spdflush;
add IP1 IP2 ah 25 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000025;
add IP2 IP1 ah 52 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000052;
spdadd IP1 IP2 any -P out ipsec ah/transport//require;
spdadd IP2 IP1 any -P in ipsec ah/transport//require;
XfrmInStateProtoError will start ticking with -EBADMSG being returned
from ah_input(). This never happens with, say, hmac(sha1).
With patch applied (on BOTH sides), XfrmInStateProtoError does not tick
with multiple bidirectional ping flood streams like it doesn't tick
with SHA-1.
After this patch sha512_transform() will start using ~750 bytes of stack on x86_64.
This is OK for simple loads, for something more heavy, stack reduction will be done
separatedly.
commit 598781d71119827b454fd75d46f84755bca6f0c6 upstream.
If the master tries to authenticate a client using drm_authmagic and
that client has already closed its drm file descriptor,
either wilfully or because it was terminated, the
call to drm_authmagic will dereference a stale pointer into kmalloc'ed memory
and corrupt it.
Typically this results in a hard system hang.
This patch fixes that problem by removing any authentication tokens
(struct drm_magic_entry) open for a file descriptor when that file
descriptor is closed.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 5e6f0d769017cc49207ef56996e42363ec26c1f0 upstream.
ecryptfs_write() handles the truncation of eCryptfs inodes. It grabs a
page, zeroes out the appropriate portions, and then encrypts the page
before writing it to the lower filesystem. It was unkillable and due to
the lack of sparse file support could result in tying up a large portion
of system resources, while encrypting pages of zeros, with no way for
the truncate operation to be stopped from userspace.
This patch adds the ability for ecryptfs_write() to detect a pending
fatal signal and return as gracefully as possible. The intent is to
leave the lower file in a useable state, while still allowing a user to
break out of the encryption loop. If a pending fatal signal is detected,
the eCryptfs inode size is updated to reflect the modified inode size
and then -EINTR is returned.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
commit 30373dc0c87ffef68d5628e77d56ffb1fa22e1ee upstream.
Print inode on metadata read failure. The only real
way of dealing with metadata read failures is to delete
the underlying file system file. Having the inode
allows one to 'find . -inum INODE`.
[tyhicks@canonical.com: Removed some minor not-for-stable parts]
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit db10e556518eb9d21ee92ff944530d84349684f4 upstream.
A malicious count value specified when writing to /dev/ecryptfs may
result in a a very large kernel memory allocation.
This patch peeks at the specified packet payload size, adds that to the
size of the packet headers and compares the result with the write count
value. The resulting maximum memory allocation size is approximately 532
bytes.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
commit d496aab567e7e52b3e974c9192a5de6e77dce32c upstream.
Commit ef53d9c5e ("kprobes: improve kretprobe scalability with hashed
locking") introduced a bug where we can potentially leak
kretprobe_instances since we initialize a hlist head after having used
it.
Initialize the hlist head before using it.
Reported by: Jim Keniston <jkenisto@us.ibm.com>
Acked-by: Jim Keniston <jkenisto@us.ibm.com>
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Srinivasa D S <srinivasa@in.ibm.com>
commit c25a785d6647984505fa165b5cd84cfc9a95970b upstream.
If the provided system call number is equal to __NR_syscalls, the
current check will pass and a function pointer just after the system
call table may be called, since sys_call_table is an array with total
size __NR_syscalls.
Whether or not this is a security bug depends on what the compiler puts
immediately after the system call table. It's likely that this won't do
anything bad because there is an additional NULL check on the syscall
entry, but if there happens to be a non-NULL value immediately after the
system call table, this may result in local privilege escalation.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Eugene Teo <eugeneteo@kernel.sg>
commit cced5041ed5a2d1352186510944b0ddfbdbe4c0b upstream.
sym53c8xx_slave_destroy unconditionally assumes that sym53c8xx_slave_alloc has
succesesfully allocated a sym_lcb. This can lead to a NULL pointer dereference
(exposed by commit 4e6c82b).
Signed-off-by: Stratos Psomadakis <psomas@gentoo.org>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit ffe535edb9a9c5b4d5fe03dfa3d89a1495580f1b upstream.
More than one user reports that changing the model from "both" to
"dmic" makes their Internal Mic work.
Tested-by: Martin Ling <martin-launchpad@earth.li>
BugLink: https://bugs.launchpad.net/bugs/795823
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 8a64f336bc1d4aa203b138d29d5a9c414a9fbb47 upstream.
Add a printk_ratelimited statement expression macro that uses a per-call
ratelimit_state so that multiple subsystems output messages are not
suppressed by a global __ratelimit state.
[akpm@linux-foundation.org: s/_rl/_ratelimited/g]
Cc: Naohiro Ooiwa <nooiwa@miraclelinux.com>
Cc: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
commit 577ebb374c78314ac4617242f509e2f5e7156649 upstream.
Introduce a wrapper around scsi_cmd_ioctl that takes a block device.
The function will then be enhanced to detect partition block devices
and, in that case, subject the ioctls to whitelisting.
[bwh: Backport to 2.6.32 - adjust context]
commit 878b753e32ca765cd346a5d3038d630178ec78ff upstream.
[ changed s/usb_free_coherent/usb_buffer_free/ for 2.6.32.x]
In the WDM class driver a disconnect event leads to calls to
usb_free_coherent to put back two USB DMA buffers allocated earlier.
The call to usb_free_coherent uses a different size parameter
(desc->wMaxCommand) than the corresponding call to usb_alloc_coherent
(desc->bMaxPacketSize0).
When a disconnect event occurs, this leads to 'bad dma' complaints
from usb core because the USB DMA buffer is being pushed back to the
'buffer-2048' pool from which it has not been allocated.
This patch against the most recent linux-2.6 kernel ensures that the
parameters used by usb_alloc_coherent & usb_free_coherent calls in
cdc-wdm.c match.
Signed-off-by: Robert Lukassen <robert.lukassen@tomtom.com>
commit c3e0ef9a298e028a82ada28101ccd5cf64d209ee upstream.
For 32-bit architectures using standard jiffies the idletime calculation
in uptime_proc_show will quickly overflow. It takes (2^32 / HZ) seconds
of idle-time, or e.g. 12.45 days with no load on a quad-core with HZ=1000.
Switch to 64-bit calculations.
Cc: Michael Abbott <michael.abbott@diamond.ac.uk>
commit 0cdfb819b6a97e79c7a0aa0c471cd7000367103b upstream.
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Oliver Neukum <oliver@neukum.org>
CC: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: David Sterba <dsterba@suse.cz>
commit b2ea70afade7080360ac55c4e64ff7a5fafdb67b upstream.
expkey_parse() oopses when handling a 0 length export. This is easily
triggerable from usermode by writing 0 bytes into
'/proc/[proc id]/net/rpc/nfsd.fh/channel'.
Below is the log:
[ 1402.286893] BUG: unable to handle kernel paging request at ffff880077c49fff
[ 1402.287632] IP: [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1
[ 1402.287632] PGD 2206063 PUD 1fdfd067 PMD 1ffbc067 PTE 8000000077c49160
[ 1402.287632] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
[ 1402.287632] CPU 1
[ 1402.287632] Pid: 20198, comm: trinity Not tainted 3.2.0-rc2-sasha-00058-gc65cd37 #6
[ 1402.287632] RIP: 0010:[<ffffffff812b4b99>] [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1
[ 1402.287632] RSP: 0018:ffff880077f0fd68 EFLAGS: 00010292
[ 1402.287632] RAX: ffff880077c49fff RBX: 00000000ffffffea RCX: 0000000001043400
[ 1402.287632] RDX: 0000000000000000 RSI: ffff880077c4a000 RDI: ffffffff82283de0
[ 1402.287632] RBP: ffff880077f0fe18 R08: 0000000000000001 R09: ffff880000000000
[ 1402.287632] R10: 0000000000000000 R11: 0000000000000001 R12: ffff880077c4a000
[ 1402.287632] R13: ffffffff82283de0 R14: 0000000001043400 R15: ffffffff82283de0
[ 1402.287632] FS: 00007f25fec3f700(0000) GS:ffff88007d400000(0000) knlGS:0000000000000000
[ 1402.287632] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1402.287632] CR2: ffff880077c49fff CR3: 0000000077e1d000 CR4: 00000000000406e0
[ 1402.287632] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 1402.287632] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 1402.287632] Process trinity (pid: 20198, threadinfo ffff880077f0e000, task ffff880077db17b0)
[ 1402.287632] Stack:
[ 1402.287632] ffff880077db17b0 ffff880077c4a000 ffff880077f0fdb8 ffffffff810b411e
[ 1402.287632] ffff880000000000 ffff880077db17b0 ffff880077c4a000 ffffffff82283de0
[ 1402.287632] 0000000001043400 ffffffff82283de0 ffff880077f0fde8 ffffffff81111f63
[ 1402.287632] Call Trace:
[ 1402.287632] [<ffffffff810b411e>] ? lock_release+0x1af/0x1bc
[ 1402.287632] [<ffffffff81111f63>] ? might_fault+0x97/0x9e
[ 1402.287632] [<ffffffff81111f1a>] ? might_fault+0x4e/0x9e
[ 1402.287632] [<ffffffff81a8bcf2>] cache_do_downcall+0x3e/0x4f
[ 1402.287632] [<ffffffff81a8c950>] cache_write.clone.16+0xbb/0x130
[ 1402.287632] [<ffffffff81a8c9df>] ? cache_write_pipefs+0x1a/0x1a
[ 1402.287632] [<ffffffff81a8c9f8>] cache_write_procfs+0x19/0x1b
[ 1402.287632] [<ffffffff8118dc54>] proc_reg_write+0x8e/0xad
[ 1402.287632] [<ffffffff8113fe81>] vfs_write+0xaa/0xfd
[ 1402.287632] [<ffffffff8114142d>] ? fget_light+0x35/0x9e
[ 1402.287632] [<ffffffff8113ff8b>] sys_write+0x48/0x6f
[ 1402.287632] [<ffffffff81bbdb92>] system_call_fastpath+0x16/0x1b
[ 1402.287632] Code: c0 c9 c3 55 48 63 d2 48 89 e5 48 8d 44 32 ff 41 57 41 56 41 55 41 54 53 bb ea ff ff ff 48 81 ec 88 00 00 00 48 89 b5 58 ff ff ff
[ 1402.287632] 38 0a 0f 85 89 02 00 00 c6 00 00 48 8b 3d 44 4a e5 01 48 85
[ 1402.287632] RIP [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1
[ 1402.287632] RSP <ffff880077f0fd68>
[ 1402.287632] ---[ end trace 368ef53ff773a5e3 ]---
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
Cc: linux-nfs@vger.kernel.org
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 2fefb8a09e7ed251ae8996e0c69066e74c5aa560 upstream.
There's no reason I can see that we need to call sv_shutdown between
closing the two lists of sockets.
commit 61c8504c428edcebf23b97775a129c5b393a302b upstream.
The pool_to and to_pool fields of the global svc_pool_map are freed on
shutdown, but are initialized in nfsd startup only in the
SVC_POOL_PERCPU and SVC_POOL_PERNODE cases.
They *are* initialized to zero on kernel startup. So as long as you use
only SVC_POOL_GLOBAL (the default), this will never be a problem.
You're also OK if you only ever use SVC_POOL_PERCPU or SVC_POOL_PERNODE.
However, the following sequence events leads to a double-free:
1. set SVC_POOL_PERCPU or SVC_POOL_PERNODE
2. start nfsd: both fields are initialized.
3. shutdown nfsd: both fields are freed.
4. set SVC_POOL_GLOBAL
5. start nfsd: the fields are left untouched.
6. shutdown nfsd: now we try to free them again.
Step 4 is actually unnecessary, since (for some bizarre reason), nfsd
automatically resets the pool mode to SVC_POOL_GLOBAL on shutdown.
commit 6c06108be53ca5e94d8b0e93883d534dd9079646 upstream.
If ctrls->count is too high the multiplication could overflow and
array_size would be lower than expected. Mauro and Hans Verkuil
suggested that we cap it at 1024. That comes from the maximum
number of controls with lots of room for expantion.
$ grep V4L2_CID include/linux/videodev2.h | wc -l
211
commit 7c1f59c9d5caf3a84f35549b5d58f3c055a68da5 upstream.
When adding checks for ACPI resource conflicts to many bus drivers,
not enough attention was paid to the error paths, and for several
drivers this causes 0 to be returned on error in some cases. Fix this
by properly returning a non-zero value on every error.
commit 4a59c797a18917a5cf3ff7ade296b46134d91e6a upstream.
Currently it's possible to create a volume without a name. E.g:
ubimkvol -n 32 -s 2MiB -t static /dev/ubi0 -N ""
After that vtbl_check() will always fail because it does not permit
empty strings.
Signed-off-by: Richard Weinberger <richard@nod.at>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
commit 9af0c7a6fa860698d080481f24a342ba74b68982 upstream.
On x86_32 casting the unsigned int result of get_random_int() to
long may result in a negative value. On x86_32 the range of
mmap_rnd() therefore was -255 to 255. The 32bit mode on x86_64
used 0 to 255 as intended.
The bug was introduced by 675a081 ("x86: unify mmap_{32|64}.c")
in January 2008.
Signed-off-by: Ludwig Nussel <ludwig.nussel@suse.de>
Cc: harvey.harrison@gmail.com
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Link: http://lkml.kernel.org/r/201111152246.pAFMklOB028527@wpaz5.hot.corp.google.com
commit eb31aae8cb5eb54e234ed2d857ddac868195d911 upstream.
Some Dell BIOSes have MCFG tables that don't report the entire
MMCONFIG area claimed by the chipset. If we move PCI devices into
that claimed-but-unreported area, they don't work.
This quirk reads the AMD MMCONFIG MSRs and adds PNP0C01 resources as
needed to cover the entire area.
Example problem scenario:
BIOS-e820: 00000000cfec5400 - 00000000d4000000 (reserved)
Fam 10h mmconf [d0000000, dfffffff]
PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xd0000000-0xd3ffffff] (base 0xd0000000)
pnp 00:0c: [mem 0xd0000000-0xd3ffffff]
pci 0000:00:12.0: reg 10: [mem 0xffb00000-0xffb00fff]
pci 0000:00:12.0: no compatible bridge window for [mem 0xffb00000-0xffb00fff]
pci 0000:00:12.0: BAR 0: assigned [mem 0xd4000000-0xd40000ff]
Reported-by: Lisa Salimbas <lisa.salimbas@canonical.com>
Reported-by: <thuban@singularity.fr>
Tested-by: dann frazier <dann.frazier@canonical.com>
References: https://bugzilla.kernel.org/show_bug.cgi?id=31602
References: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/647043
References: https://bugzilla.redhat.com/show_bug.cgi?id=770308
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 45fae7493970d7c45626ccd96d4a74f5f1eea5a9 upstream.
Info about new measurements are cached in the iint for performance. When
the inode is flushed from cache, the associated iint is flushed as well.
Subsequent access to the inode will cause the inode to be re-measured and
will attempt to add a duplicate entry to the measurement list.
This patch frees the duplicate measurement memory, fixing a memory leak.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
commit 9e7860cee18241633eddb36a4c34c7b61d8cecbc upstream.
Haogang Chen found out that:
There is a potential integer overflow in process_msg() that could result
in cross-domain attack.
body = kmalloc(msg->hdr.len + 1, GFP_NOIO | __GFP_HIGH);
When a malicious guest passes 0xffffffff in msg->hdr.len, the subsequent
call to xb_read() would write to a zero-length buffer.
The other end of this connection is always the xenstore backend daemon
so there is no guest (malicious or otherwise) which can do this. The
xenstore daemon is a trusted component in the system.
However this seem like a reasonable robustness improvement so we should
have it.
And Ian when read the API docs found that:
The payload length (len field of the header) is limited to 4096
(XENSTORE_PAYLOAD_MAX) in both directions. If a client exceeds the
limit, its xenstored connection will be immediately killed by
xenstored, which is usually catastrophic from the client's point of
view. Clients (particularly domains, which cannot just reconnect)
should avoid this.
so this patch checks against that instead.
This also avoids a potential integer overflow pointed out by Haogang Chen.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Haogang Chen <haogangchen@gmail.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit a776c491ca5e38c26d9f66923ff574d041e747f4 upstream.
I traced a nasty kexec on panic boot failure to the fact that we had
screaming msi interrupts and we were not disabling the msi messages at
kernel startup. The booting kernel had not enabled those interupts so
was not prepared to handle them.
I can see no reason why we would ever want to leave the msi interrupts
enabled at boot if something else has enabled those interrupts. The pci
spec specifies that msi interrupts should be off by default. Drivers
are expected to enable the msi interrupts if they want to use them. Our
interrupt handling code reprograms the interrupt handlers at boot and
will not be be able to do anything useful with an unexpected interrupt.
This patch applies cleanly all of the way back to 2.6.32 where I noticed
the problem.
commit 1830ea91c20b06608f7cdb2455ce05ba834b3214 upstream.
Spec shows this as 1010b = 0xa
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
commit e57e0d8e818512047fe379157c3f77f1b9fabffb upstream.
When we fail to erase a PEB, we free the corresponding erase entry object,
but then re-schedule this object if the error code was something like -EAGAIN.
Obviously, it is a bug to use the object after we have freed it.
Reported-by: Emese Revfy <re.emese@gmail.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit e46e927b9b7e8d95526e69322855243882b7e1a3 upstream.
This allows the latest N-Trig devices to function properly.
BugLink: https://bugs.launchpad.net/bugs/724831
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
commit 3a90274de3548ebb2aabfbf488cea8e275a73dc6 upstream.
When an invalid NID is given, get_wcaps() returns zero as the error,
but get_wcaps_type() takes it as the normal value and returns a bogus
AC_WID_AUD_OUT value. This confuses the parser.
With this patch, get_wcaps_type() returns -1 when value 0 is given,
i.e. an invalid NID is passed to get_wcaps().
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=740118
commit e7848163aa2a649d9065f230fadff80dc3519775 upstream.
Cards with identical PCI ids but no AC97 config in EEPROM do not have
the ac97 field initialized. We must check for this case to avoid kernel oops.
Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com>
commit d0f3a2eb9062560bebca8b923424f3ca02a331ba upstream.
They are not needed here.
Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de>
commit d50f2ab6f050311dbf7b8f5501b25f0bf64a439b upstream.
Commit 503358ae01b70ce6909d19dd01287093f6b6271c ("ext4: avoid divide by
zero when trying to mount a corrupted file system") fixes CVE-2009-4307
by performing a sanity check on s_log_groups_per_flex, since it can be
set to a bogus value by an attacker.
sbi->s_log_groups_per_flex = sbi->s_es->s_log_groups_per_flex;
groups_per_flex = 1 << sbi->s_log_groups_per_flex;
if (groups_per_flex < 2) { ... }
This patch fixes two potential issues in the previous commit.
1) The sanity check might only work on architectures like PowerPC.
On x86, 5 bits are used for the shifting amount. That means, given a
large s_log_groups_per_flex value like 36, groups_per_flex = 1 << 36
is essentially 1 << 4 = 16, rather than 0. This will bypass the check,
leaving s_log_groups_per_flex and groups_per_flex inconsistent.
2) The sanity check relies on undefined behavior, i.e., oversized shift.
A standard-confirming C compiler could rewrite the check in unexpected
ways. Consider the following equivalent form, assuming groups_per_flex
is unsigned for simplicity.
if (groups_per_flex == 0 || groups_per_flex == 1) {
We compile the code snippet using Clang 3.0 and GCC 4.6. Clang will
completely optimize away the check groups_per_flex == 0, leaving the
patched code as vulnerable as the original. GCC keeps the check, but
there is no guarantee that future versions will do the same.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
