2010-01-12Linux 2.6.33-rc4v2.6.33-rc4Linus Torvalds
2010-01-12Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: pmu_battery: Fix battery full reporting
2010-01-12[SCSI] megaraid_sas: remove sysfs poll_mode_io world writeable permissionsBryn M. Reeves
/sys/bus/pci/drivers/megaraid_sas/poll_mode_io defaults to being world-writable, which seems bad (letting any user affect kernel driver behavior). This turns off group and user write permissions, so that on typical production systems only root can write to it. Signed-off-by: Bryn M. Reeves <bmr@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-12Merge branch 'for-linus' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux: OMAP: DSS2: OMAPFB: fix crash when panel driver was not loaded OMAP: DSS2: Reject scaling settings when they cannot be supported OMAP: DSS2: Make check-delay-loops consistent OMAP: DSS2: OMAPFB: fix omapfb_free_fbmem() video/omap: add __init/__exit macros to drivers/video/omap/lcd_htcherald.c OMAP: DSS2: Fix compile warning MAINTAINERS: Combine DSS2 and OMAPFB2 into one entry MAINTAINERS: change omapfb maintainer OMAP: OMAPFB: add dummy release function for omapdss OMAP: OMAPFB: fix clk_get for RFBI OMAP: DSS2: RFBI: convert to new kfifo API OMAP: DSS2: Fix crash when panel doesn't define enable_te() OMAP: DSS2: Collect interrupt statistics OMAP: DSS2: DSI: print debug DCS cmd in hex OMAP: DSS2: DSI: fix VC channels in send_short and send_null
2010-01-12lib: Introduce generic list_sort functionDave Chinner
There are two copies of list_sort() in the tree already, one in the DRM code, another in ubifs. Now XFS needs this as well. Create a generic list_sort() function from the ubifs version and convert existing users to it so we don't end up with yet another copy in the tree. Signed-off-by: Dave Chinner <david@fromorbit.com> Acked-by: Dave Airlie <airlied@redhat.com> Acked-by: Artem Bityutskiy <dedekind@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-12remove my email address from checkpatch.Dave Jones
Maybe this will stop people emailing me about it. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-12Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata: retry link resume if necessary ata_piix: enable 32bit PIO on SATA piix sata_promise: don't classify overruns as HSM errors
2010-01-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: Ensure ARMv6/7 mm files are built using appropriate assembler options ARM: Fix wrong dmb ARM: 5874/1: serial21285: fix disable_irq-from-interrupt-handler deadlock ARM: 5873/1: ARM: Fix the reset logic for ARM RealView boards ARM: 5872/1: ARM: include needed linux/cpu.h in asm/cpu.h ARM: 5871/1: arch/arm: Fix build failure for lpd7a404_defconfig caused by missing includes ARM: 5870/1: arch/arm: Fix build failure for defconfigs without CONFIG_ISA_DMA_API set ARM: 5868/1: ARM: fix "BUG: using smp_processor_id() in preemptible code" ARM: 5867/1: Update U300 defconfig ARM: 5866/1: arm ptrace: use unsigned types for kernel pt_regs [ARM] pxa: fix strange characters in zaurus gpio .desc ARM: add missing recvmmsg syscall number [ARM] pxa: fix compiler warnings of unused variable 'id' in cpu_is_pxa9*() [ARM] pxa: update pwm_backlight->notify() to include missed 'struct device *' [ARM] pxa: enable L2 if present in XSC3 [ARM] pxa: do not enable L2 after MMU is enabled
2010-01-12Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (22 commits) MIPS: Ignore vmlinux.* MIPS: Move vmlinux.ecoff to arch/mips/boot MIPS: cpumask_of_node() should handle -1 as a node MIPS: Octeon: Use non-overflowing arithmetic in sched_clock MIPS: Malta, PowerTV: Remove unnecessary "Linux started" MIPS: BCM63xx: Remove duplicate CONFIG_CMDLINE. MIPS: AR7: Remove unused prom_getchar() MIPS: PowerTV: Remove extra r4k_clockevent_init() call MIPS: Cobalt use strlcat() for the command line arguments MIPS: Octeon: Add sched_clock() to csrc-octeon.c MIPS: TXx9: Cleanup builtin-cmdline processing MIPS: PowerTV: simplify prom_init_cmdline() and merge into prom_init() MIPS: PowerTV: Remove unused platform_die() MIPS: PowerTV: Remove mips_machine_halt() MIPS: PowerTV: Remove unused ptv_memsize MIPS: PowerTV: Remove unused prom_getcmdline() MIPS: AR7: Remove kgdb_enabled MIPS: Alchemy: Correct code taking the size of a pointer MIPS: BCM63xx: Fix whitespace damaged board_bcm963xx.c MIPS: VR41xx: Use strlcat() for the command line arguments ...
2010-01-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Fix ALC861-VD capture source mixer ALSA: ac97: add AC97 STMicroelectronics' codecs ALSA: ac97: Add Dell Dimension 2400 to Headphone/Line Jack Sense blacklist ASoC: Fix WM8350 DSP mode B configuration sbawe: fix memory detection part 2 sound: oss: off by one bug ALSA: usb-audio - Avoid Oops after disconnect ALSA: test off by one in setsamplerate() ALSA: atiixp: Specify codec for Foxconn RC4107MA-RS2
2010-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits) sky2: Fix oops in sky2_xmit_frame() after TX timeout Documentation/3c509: document ethtool support af_packet: Don't use skb after dev_queue_xmit() vxge: use pci_dma_mapping_error to test return value netfilter: ebtables: enforce CAP_NET_ADMIN e1000e: fix and commonize code for setting the receive address registers e1000e: e1000e_enable_tx_pkt_filtering() returns wrong value e1000e: perform 10/100 adaptive IFS only on parts that support it e1000e: don't accumulate PHY statistics on PHY read failure e1000e: call pci_save_state() after pci_restore_state() netxen: update version to 4.0.72 netxen: fix set mac addr netxen: fix smatch warning netxen: fix tx ring memory leak tcp: update the netstamp_needed counter when cloning sockets TI DaVinci EMAC: Handle emac module clock correctly. dmfe/tulip: Let dmfe handle DM910x except for SPARC on-board chips ixgbe: Fix compiler warning about variable being used uninitialized netfilter: nf_ct_ftp: fix out of bounds read in update_nl_seq() mv643xx_eth: don't include cache padding in rx desc buffer size ... Fix trivial conflict in drivers/scsi/cxgb3i/cxgb3i_offload.c
2010-01-12m68knommu: fix definitions of __pa() and __va()Greg Ungerer
Fix compilation breakage of all m68knommu targets: CC arch/m68knommu/kernel/asm-offsets.s In file included from include/linux/sched.h:77, from arch/m68knommu/kernel/asm-offsets.c:12: include/linux/percpu.h: In function 'per_cpu_ptr_to_phys': include/linux/percpu.h:161: error: implicit declaration of function 'virt_to_phy This is broken in linux-2.6.33-rc3. Change the definitions of __pa() and __va() to not use virt_to_phys() and phys_to_virt(). Trivial 1:1 conversion required for the non-MMU case. A side effect if this is that the m68knommu can now use asm/virtconvert.h for the definition of virt_to_phys() and phys_to_virt(). Also cleaned up the definition of page_to_phys() when moving into virtconvert.h. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-12libata: retry link resume if necessaryTejun Heo
Interestingly, when SIDPR is used in ata_piix, writes to DET in SControl sometimes get ignored leading to detection failure. Update sata_link_resume() such that it reads back SControl after clearing DET and retry if it's not clear. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: fengxiangjun <fengxiangjun@neusoft.com> Reported-by: Jim Faulkner <jfaulkne@ccs.neu.edu> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-01-12ata_piix: enable 32bit PIO on SATA piixTejun Heo
Commit 871af1210f13966ab911ed2166e4ab2ce775b99d enabled 32bit PIO for PATA piix but didn't for SATA. There's no reason not to use 32bit PIO on SATA piix. Enable it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-01-12sata_promise: don't classify overruns as HSM errorsMikael Pettersson
When sata_promise encounters an overrun or underrun error it translates that to a libata AC_ERR_HSM, causing a hard reset. Since over/under-runs were thought to be rare and transient, this action seemed reasonable. Unfortunately it turns out that the controller throws overrun errors when e.g. hal polls a CD or DVD writer containing blank media, causing long sequences of hard resets and retries before EH finally gives up. This patch updates sata_promise to classify over/under-runs as AC_ERR_OTHER instead. This allows libata EH and upper layers to retry or fail the operation as they see fit without the disruption caused by repeated hard resets. This fixes a problem using a DVD-RAM drive with sata_promise, reported by Thomas Schorpp. I also tested it on a DVD-RW drive. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: thomas schorpp <thomas.schorpp@googlemail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-01-12ARM: Ensure ARMv6/7 mm files are built using appropriate assembler optionsRussell King
A kernel with both ARMv6 and ARMv7 selected results in build errors. Fix this by specifying the proper architectures for these assembly files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-12ARM: Fix wrong dmbRussell King
The __kuser_cmpxchg code uses an ARMv6 dmb instruction, rather than one based upon the architecture being built for. Switch to using the macro provided for this purpose, which also eliminates the need for an ifdef. Acked-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-12MIPS: Ignore vmlinux.*Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/795/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: Move vmlinux.ecoff to arch/mips/bootYoichi Yuasa
It moves to the same directory as the boot files in other formats. Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/796/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: cpumask_of_node() should handle -1 as a nodeAnton Blanchard
pcibus_to_node can return -1 if we cannot determine which node a pci bus is on. If passed -1, cpumask_of_node will negatively index the lookup array and pull in random data: # cat /sys/devices/pci0000:00/0000:00:01.0/local_cpus 00000000,00000003,00000000,00000000 # cat /sys/devices/pci0000:00/0000:00:01.0/local_cpulist 64-65 Change cpumask_of_node to check for -1 and return cpu_all_mask in this case: # cat /sys/devices/pci0000:00/0000:00:01.0/local_cpus ffffffff,ffffffff,ffffffff,ffffffff # cat /sys/devices/pci0000:00/0000:00:01.0/local_cpulist 0-127 Signed-off-by: Anton Blanchard <anton@samba.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andrew Morton <akpm@linux-foundation.org> Patchwork: http://patchwork.linux-mips.org/patch/831/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: Octeon: Use non-overflowing arithmetic in sched_clockDavid Daney
With typical mult and shift values, the calculation for Octeon's sched_clock overflows when using 64-bit arithmetic. Use 128-bit calculations instead. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/849/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: Malta, PowerTV: Remove unnecessary "Linux started"Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/813/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: BCM63xx: Remove duplicate CONFIG_CMDLINE.Yoichi Yuasa
Builtin cmdline is copied by arch_mem_init(). Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/812/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: AR7: Remove unused prom_getchar()Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/811/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: PowerTV: Remove extra r4k_clockevent_init() callDavid VomLehn
A call to r4k_clocksource_init() was added to plat_time_init(), but when init_mips_clock_source() calls the same function, boot fails in clockevents_register_device(). This patch removes the extraneous call. Signed-off-by: David VomLehn <dvomlehn@cisco.com> Patchwork: http://patchwork.linux-mips.org/patch/803/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: Cobalt use strlcat() for the command line argumentsYoichi Yuasa
Tested with CoLo v1.22 Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/807/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: Octeon: Add sched_clock() to csrc-octeon.cDavid Daney
With the advent of function graph tracing on MIPS, Octeon needs a high precision sched_clock() implementation. Without it, most timing numbers are reported as 0.000. This new sched_clock just uses the 64-bit cycle counter appropriately scaled. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/805/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: TXx9: Cleanup builtin-cmdline processingAtsushi Nemoto
Since commit 898d357b5262f9e26bc2418e01f8676e80d9867e (lmo) / 6acc7d485c24c00e111c61b2e6dff9180faebcae (kernel.org) ("Fix and enhance built-in kernel command line") arcs_cmdline[] does not contain built-in command line. The commit introduce CONFIG_CMDLINE_BOOL and CONFIG_CMDLINE_OVERRIDE to control built-in command line, and now we can use them instead of platform-specific built-in command line processing. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Patchwork: http://patchwork.linux-mips.org/patch/802/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: PowerTV: simplify prom_init_cmdline() and merge into prom_init()Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/801/ Reviewed-by: David VomLehn <dvomlehn@cisco.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: PowerTV: Remove unused platform_die()Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/800/ Reviewed-by: David VomLehn <dvomlehn@cisco.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: PowerTV: Remove mips_machine_halt()Yoichi Yuasa
mips_machine_halt() is same as mips_machine_restart(). Also delete the registration of _machine_halt and pm_power_off because mips_machine_halt() is the restart function. Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/798/ Reviewed-by: David VomLehn <dvomlehn@cisco.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: PowerTV: Remove unused ptv_memsizeYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/799/ Reviewed-by: David VomLehn <dvomlehn@cisco.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: PowerTV: Remove unused prom_getcmdline()Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/797/ Reviewed-by: David VomLehn <dvomlehn@cisco.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: AR7: Remove kgdb_enabledYoichi Yuasa
An unused leftover from the old KGDB implementation. Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/794/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: Alchemy: Correct code taking the size of a pointerJulia Lawall
sizeof(dp) is just the size of the pointer. Change it to the size of the referenced structure. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression *x; expression f; type T; @@ *f(...,(T)x,...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Patchwork: http://patchwork.linux-mips.org/patch/789/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: BCM63xx: Fix whitespace damaged board_bcm963xx.cFlorian Fainelli
Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: VR41xx: Use strlcat() for the command line argumentsYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/784/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: Cleanup and Fixup of compressed kernel supportWu Zhangjin
o Remove the .initrd section. The initrd section was already handled when vmlinux was linked. o Discard .MIPS.options, .options, .pdr, .reginfo, .comment and .note sections. If .MIPS.options is not removed, kernels compiled with gcc 3.4.6 will not boot. o Clean up the file format. o Remove several other unneeded sections. Tested with GCC 3.4.6 and 4.4.1 with and without initrd. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/785/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: Cleanup forgotten label_module_alloc in tlbex.cDavid Daney
commit c8af165342e83a4eb078c9607d29a7c399d30a53 (lmo) rsp. e0cc87f59490d7d62a8ab2a76498dc8a2b64927a (kernel.org) left label_module_alloc unused. Remove it now. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/752/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-01-12Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-01-12ALSA: hda - Fix ALC861-VD capture source mixerTakashi Iwai
The capture source or input source mixer element wasn't created properly for ALC861-VD codec due to the wrong NID passed to alc_auto_create_input_ctls(). References: Novell bnc#568305 http://bugzilla.novell.com/show_bug.cgi?id=568305 Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: <stable@kernel.org>
2010-01-12sky2: Fix oops in sky2_xmit_frame() after TX timeoutJarek Poplawski
During TX timeout procedure dev could be awoken too early, e.g. by sky2_complete_tx() called from sky2_down(). Then sky2_xmit_frame() can run while buffers are freed causing an oops. This patch fixes it by adding netif_device_present() test in sky2_tx_complete(). Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14925 With debugging by: Mike McCormack <mikem@ring3k.org> Reported-by: Berck E. Nash <flyboy@gmail.com> Tested-by: Berck E. Nash <flyboy@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-12OMAP: DSS2: OMAPFB: fix crash when panel driver was not loadedTomi Valkeinen
If the panel's probe had failed, omapfb would still go on, eventually crashing. A better fix would be to handle each display properly, and leaving just the failed display out. But that is a bigger change. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2010-01-12OMAP: DSS2: Reject scaling settings when they cannot be supportedVille Syrjälä
If the scaling ratio is below 0.5 video output width can't be identical to the display width. Reject such settings. Signed-off-by: Ville Syrjälä <ville.syrjala@nokia.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2010-01-12Merge remote branch 'alsa/fixes' into fix/miscTakashi Iwai
2010-01-11Revert "x86, apic: Use logical flat on intel with <= 8 logical cpus"Ananth N Mavinakayanahalli
Revert commit 2fbd07a5f5d1295fa9b0c0564ec27da7c276a75a, as this commit breaks an IBM platform with quad-core Xeon cpu's. According to Suresh, this might be an IBM platform issue, as on other Intel platforms with <= 8 logical cpu's, logical flat mode works fine irespective of physical apic id values (inline with the xapic architecture). Revert this for now because of the IBM platform breakage. Another version will be re-submitted after the complete analysis. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11Documentation/3c509: document ethtool supportBen Hutchings
3c509 was changed to support ethtool in 2002, making the 'xcvr' module parameter obsolete in most cases. More recently 3c509 was converted to the modern driver model and this parameter was removed. Fix the documentation to refer to ethtool rather than the module parameter. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-11af_packet: Don't use skb after dev_queue_xmit()Jarek Poplawski
tpacket_snd() can change and kfree an skb after dev_queue_xmit(), which is illegal. With debugging by: Stephen Hemminger <shemminger@vyatta.com> Reported-by: Michael Breuer <mbreuer@majjas.com> With help from: David S. Miller <davem@davemloft.net> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Tested-by: Michael Breuer<mbreuer@majjas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-11Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: Ensure we force all busy extents in range to disk xfs: Don't flush stale inodes xfs: fix timestamp handling in xfs_setattr xfs: use DECLARE_EVENT_CLASS
