2011-11-26Linux 3.1.3v3.1.3Greg Kroah-Hartman
2011-11-26vmscan: fix shrinker callback bug in fs/super.cMikulas Patocka
commit 09f363c7363eb10cfb4b82094bd7064e5608258b upstream. The callback must not return -1 when nr_to_scan is zero. Fix the bug in fs/super.c and add this requirement to the callback specification. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26batman-adv: unify hash_entry field position in tt_local/global_entryAntonio Quartulli
commit 93840ac40bb0d0f177ef8af74e64671be67e8c37 upstream. Function tt_response_fill_table() actually uses a tt_local_entry pointer to iterate either over the local or the global table entries (it depends on the what hash table is passed as argument). To iterate over such entries the hlist_for_each_entry_rcu() macro has to access their "hash_entry" field which MUST be at the same position in both the tt_global/local_entry structures. Reported-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26batman-adv: add sanity check when removing global ttsSimon Wunderlich
commit 6e8014947d6469df1566e9e253805557c5c0e4e0 upstream. After removing the batman-adv module, the hash may be already gone when tt_global_del_orig() tries to clean the hash. This patch adds a sanity check to avoid this. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Tested-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26batman-adv: remove references for global tt entriesSimon Wunderlich
commit 531027fcddbcf81c9937dd04f08a7e8f11fd47d2 upstream. struct tt_global_entry holds a reference to an orig_node which must be decremented before deallocating the structure. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Tested-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26batman-adv: correctly set the data field in the TT_REPONSE packetAntonio Quartulli
commit 9d8523931f7f5eb8900077f0da0fbe6b8ad0010b upstream. In the TT_RESPONSE packet, the number of carried entries is not correctly set. This leads to a wrong interpretation of the packet payload on the receiver side causing random entries to be added to the global translation table. Therefore the latter gets always corrupted, triggering a table recovery all the time. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26batman-adv: fix tt_local_reset_flags() functionAntonio Quartulli
commit 31901264511cf20c5ed33b8649a3ca9ce28df60b upstream. Currently the counter of tt_local_entry structures (tt_local_num) is incremented each time the tt_local_reset_flags() is invoked causing the node to send wrong TT_REPONSE packets containing a copy of non-initialised memory thus corrupting other nodes global translation table and making higher level communication impossible. Reported-by: Junkeun Song <jun361@gmail.com> Signed-off-by: Antonio Quartulli <ordex@autistici.org> Acked-by: Junkeun Song <jun361@gmail.com> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26drm/i915: always set FDI composite sync bitJesse Barnes
commit c4f9c4c2b3f1831e932e04db992cf6fe92c2a95a upstream. It's needed for 3 pipe support as well as just regular functionality (e.g. DisplayPort). Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Adam Jackson <ajax@redhat.com> Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Robert Hooker <robert.hooker@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26drm/i915: fix IVB cursor supportJesse Barnes
commit 65a21cd65316145f9302594be8e69074369e1050 upstream. The cursor regs have moved around, add the offsets and new macros for getting at them. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-By: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-By: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Robert Hooker <robert.hooker@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: quirks: adding more quirky webcams to avoid squeaky audiosordna
commit 0d145d7d4a241c321c832a810bb6edad18e2217b upstream. The following patch contains additional affected webcam models, on top of the patches commited to linux-next 2394d67e446bf616a0885167d5f0d397bdacfdfc and 5b253d88cc6c65a23cefc457a5a4ef139913c5fc Signed-off-by: sordna <sordna@gmail.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: add quirk for Logitech C600 web camJosh Boyer
commit 60c71ca972a2dd3fd9d0165b405361c8ad48349b upstream. We've had another report of the "chipmunk" sound on a Logitech C600 webcam. This patch resolves the issue. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: EHCI: fix HUB TT scheduling issue with iso transferThomas Poussevin
commit 811c926c538f7e8d3c08b630dd5844efd7e000f6 upstream. The current TT scheduling doesn't allow to play and then record on a full-speed device connected to a high speed hub. The IN iso stream can only start on the first uframe (0-2 for a 165 us) because of CSPLIT transactions. For the OUT iso stream there no such restriction. uframe 0-5 are possible. The idea of this patch is that the first uframe are precious (for IN TT iso stream) and we should allocate the last uframes first if possible. For that we reverse the order of uframe allocation (last uframe first). Here an example : hid interrupt stream ---------------------------------------------------------------------- uframe | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | ---------------------------------------------------------------------- max_tt_usecs | 125 | 125 | 125 | 125 | 125 | 125 | 30 | 0 | ---------------------------------------------------------------------- used usecs on a frame | 13 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | ---------------------------------------------------------------------- iso OUT stream ---------------------------------------------------------------------- uframe | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | ---------------------------------------------------------------------- max_tt_usecs | 125 | 125 | 125 | 125 | 125 | 125 | 30 | 0 | ---------------------------------------------------------------------- used usecs on a frame | 13 | 125 | 39 | 0 | 0 | 0 | 0 | 0 | ---------------------------------------------------------------------- There no place for iso IN stream (uframe 0-2 are used) and we got "cannot submit datapipe for urb 0, error -28: not enough bandwidth" error. With the patch this become. iso OUT stream ---------------------------------------------------------------------- uframe | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | ---------------------------------------------------------------------- max_tt_usecs | 125 | 125 | 125 | 125 | 125 | 125 | 30 | 0 | ---------------------------------------------------------------------- used usecs on a frame | 13 | 0 | 0 | 0 | 125 | 39 | 0 | 0 | ---------------------------------------------------------------------- iso IN stream ---------------------------------------------------------------------- uframe | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | ---------------------------------------------------------------------- max_tt_usecs | 125 | 125 | 125 | 125 | 125 | 125 | 30 | 0 | ---------------------------------------------------------------------- used usecs on a frame | 13 | 0 | 125 | 40 | 125 | 39 | 0 | 0 | ---------------------------------------------------------------------- Signed-off-by: Matthieu Castet <matthieu.castet@parrot.com> Signed-off-by: Thomas Poussevin <thomas.poussevin@parrot.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26usb-storage: Accept 8020i-protocol commands longer than 12 bytesAlan Stern
commit 2f640bf4c94324aeaa1b6385c10aab8c5ad1e1cf upstream. The 8020i protocol (also 8070i and QIC-157) uses 12-byte commands; shorter commands must be padded. Simon Detheridge reports that his 3-TB USB disk drive claims to use the 8020i protocol (which is normally meant for ATAPI devices like CD drives), and because of its large size, the disk drive requires the use of 16-byte commands. However the usb_stor_pad12_command() routine in usb-storage always sets the command length to 12, making the drive impossible to use. Since the SFF-8020i specification allows for 16-byte commands in future extensions, we may as well accept them. This patch (as1490) changes usb_stor_pad12_command() to leave commands larger than 12 bytes alone rather than truncating them. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Simon Detheridge <simon@widgit.com> CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: Fix Corruption issue in USB ftdi driver ftdi_sio.cAndrew Worsley
commit b1ffb4c851f185e9051ba837c16d9b84ef688d26 upstream. Fix for ftdi_set_termios() glitching output ftdi_set_termios() is constantly setting the baud rate, data bits and parity unnecessarily on every call, . When called while characters are being transmitted can cause the FTDI chip to corrupt the serial port bit stream output by stalling the output half a bit during the output of a character. Simple fix by skipping this setting if the baud rate/data bits/parity are unchanged. Signed-off-by: Andrew Worsley <amworsley@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: ark3116 initialisation fixBart Hartgers
commit 583182ba5f02c8c9be82ea550f2051eaec15b975 upstream. This patch for the usb serial ark3116 driver fixes an initialisation ordering bug that gets triggered on hotplug when using at least recent debian/ubuntu userspace. Without it, ark3116 serial cables don't work. Signed-off-by: Bart Hartgers <bart.hartgers@gmail.com> Tested-by: law_ence.dev@ntlworld.com Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: workaround for bug in old version of GCCAlan Stern
commit 97ff22ee3b4cb3a334f7385e269773141aed702f upstream. This patch (as1491) works around a bug in GCC-3.4.6, which is still supposed to be supported. The number of microseconds in the udelay() call in quirk_usb_disable_ehci() is fixed at 100, but the compiler doesn't understand this and generates a link-time error. So we replace the otherwise unused variable "delta" with a simple constant 100. This same pattern is already used in other delay loops in that source file. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Konrad Rzepecki <krzepecki@dentonet.pl> Tested-by: Konrad Rzepecki <krzepecki@dentonet.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: cdc-acm: Fix disconnect() vs close() raceHavard Skinnemoen
commit 5dc2470c602da8851907ec18942cd876c3b4ecc1 upstream. There's a race between the USB disconnect handler and the TTY close handler which may cause the acm object to be freed while it's still being used. This may lead to things like http://article.gmane.org/gmane.linux.usb.general/54250 and https://lkml.org/lkml/2011/5/29/64 This is the simplest fix I could come up with. Holding on to open_mutex while closing the TTY device prevents acm_disconnect() from freeing the acm object between acm->port.count drops to 0 and the TTY side of the cleanups are finalized. Signed-off-by: Havard Skinnemoen <hskinnemoen@google.com> Cc: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: pch_udc: Support new device LAPIS Semiconductor ML7831 IOHTomoya MORINAGA
commit 731ad81e2dd97e3f222361f7b3ff4b35639e46af upstream. ML7831 is companion chip for Intel Atom E6xx series. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: serial: pl2303: rm duplicate idwangyanqing
commit 0c16595539b612fe948559433dda08ff96a8bdc7 upstream. I get report from customer that his usb-serial converter doesn't work well,it sometimes work, but sometimes it doesn't. The usb-serial converter's id: vendor_id product_id 0x4348 0x5523 Then I search the usb-serial codes, and there are two drivers announce support this device, pl2303 and ch341, commit 026dfaf1 cause it. Through many times to test, ch341 works well with this device, and pl2303 doesn't work quite often(it just work quite little). ch341 works well with this device, so we doesn't need pl2303 to support.I try to revert 026dfaf1 first, but it failed. So I prepare this patch by hand to revert it. Signed-off-by: Wang YanQing <Udknight@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: option: add PID of Huawei E173s 3G modemFerenc Wagner
commit 4aa3648c719265bac9c2742c9ebb043e6dbdd790 upstream. Signed-off-by: Ferenc Wagner <wferi@niif.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: option: release new PID for ZTE 3G modemzheng.zhijian@zte.com.cn
commit 46b5a277ed90317a4d17e936c16037e76011b219 upstream. This patch adds new PIDs for ZTE 3G modem, after we confirm it and tested. Thanks for Dan's work at kernel option devier. Signed-off-by: Alvin.Zheng <zheng.zhijian@zte.com.cn> Signed-off-by: wsalvin <wsalvin@yahoo.com.cn> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26USB: XHCI: resume root hubs when the controller resumesAlan Stern
commit f69e3120df82391a0ee8118e0a156239a06b2afb upstream. This patch (as1494) fixes a problem in xhci-hcd's resume routine. When the controller is runtime-resumed, this can only mean that one of the two root hubs has made a wakeup request and therefore needs to be resumed as well. Rather than try to determine which root hub requires attention (which might be difficult in the case where a new non-SuperSpeed device has been plugged in), the patch simply resumes both root hubs. Without this change, there is a race: The controller might be put back to sleep before it can activate its IRQ line, and the wakeup condition might never get handled. The patch also simplifies the logic in xhci_resume a little, combining some repeated flag settings into a single pair of statements. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Sarah Sharp <sarah.a.sharp@linux.intel.com> Tested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26usb, xhci: fix lockdep warning on endpoint timeoutDon Zickus
commit f43d623164022dcbf6750ef220b7a1133a1183eb upstream. While debugging a usb3 problem, I stumbled upon this lockdep warning. Oct 18 21:41:17 dhcp47-74 kernel: ================================= Oct 18 21:41:17 dhcp47-74 kernel: [ INFO: inconsistent lock state ] Oct 18 21:41:17 dhcp47-74 kernel: 3.1.0-rc4nmi+ #456 Oct 18 21:41:17 dhcp47-74 kernel: --------------------------------- Oct 18 21:41:17 dhcp47-74 kernel: inconsistent {IN-HARDIRQ-W} -> {HARDIRQ-ON-W} usage. Oct 18 21:41:17 dhcp47-74 kernel: swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes: Oct 18 21:41:17 dhcp47-74 kernel: (&(&xhci->lock)->rlock){?.-...}, at: [<ffffffffa0228990>] xhci_stop_endpoint_command_watchdog+0x30/0x340 [xhci_hcd] Oct 18 21:41:17 dhcp47-74 kernel: {IN-HARDIRQ-W} state was registered at: Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8109a941>] __lock_acquire+0x781/0x1660 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8109bed7>] lock_acquire+0x97/0x170 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81501b46>] _raw_spin_lock+0x46/0x80 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffffa02299fa>] xhci_irq+0x3a/0x1960 [xhci_hcd] Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffffa022b351>] xhci_msi_irq+0x31/0x40 [xhci_hcd] Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff810d2305>] handle_irq_event_percpu+0x85/0x320 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff810d25e8>] handle_irq_event+0x48/0x70 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff810d537d>] handle_edge_irq+0x6d/0x130 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff810048c9>] handle_irq+0x49/0xa0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8150d56d>] do_IRQ+0x5d/0xe0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff815029b0>] ret_from_intr+0x0/0x13 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81388aca>] usb_set_device_state+0x8a/0x180 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8138f038>] usb_add_hcd+0x2b8/0x730 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffffa022ed7e>] xhci_pci_probe+0x9e/0xd4 [xhci_hcd] Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8127915f>] local_pci_probe+0x5f/0xd0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8127a569>] pci_device_probe+0x119/0x120 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81334473>] driver_probe_device+0xa3/0x2c0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8133473b>] __driver_attach+0xab/0xb0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8133373c>] bus_for_each_dev+0x6c/0xa0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff813341fe>] driver_attach+0x1e/0x20 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81333b88>] bus_add_driver+0x1f8/0x2b0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81334df6>] driver_register+0x76/0x140 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8127a7c6>] __pci_register_driver+0x66/0xe0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffffa013c04a>] snd_timer_find+0x4a/0x70 [snd_timer] Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffffa013c00e>] snd_timer_find+0xe/0x70 [snd_timer] Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff810001d3>] do_one_initcall+0x43/0x180 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff810a9ed2>] sys_init_module+0x92/0x1f0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8150ab6b>] system_call_fastpath+0x16/0x1b Oct 18 21:41:17 dhcp47-74 kernel: irq event stamp: 631984 Oct 18 21:41:17 dhcp47-74 kernel: hardirqs last enabled at (631984): [<ffffffff81502720>] _raw_spin_unlock_irq+0x30/0x50 Oct 18 21:41:17 dhcp47-74 kernel: hardirqs last disabled at (631983): [<ffffffff81501c49>] _raw_spin_lock_irq+0x19/0x90 Oct 18 21:41:17 dhcp47-74 kernel: softirqs last enabled at (631980): [<ffffffff8105ff63>] _local_bh_enable+0x13/0x20 Oct 18 21:41:17 dhcp47-74 kernel: softirqs last disabled at (631981): [<ffffffff8150ce6c>] call_softirq+0x1c/0x30 Oct 18 21:41:17 dhcp47-74 kernel: Oct 18 21:41:17 dhcp47-74 kernel: other info that might help us debug this: Oct 18 21:41:17 dhcp47-74 kernel: Possible unsafe locking scenario: Oct 18 21:41:17 dhcp47-74 kernel: Oct 18 21:41:17 dhcp47-74 kernel: CPU0 Oct 18 21:41:17 dhcp47-74 kernel: ---- Oct 18 21:41:17 dhcp47-74 kernel: lock(&(&xhci->lock)->rlock); Oct 18 21:41:17 dhcp47-74 kernel: <Interrupt> Oct 18 21:41:17 dhcp47-74 kernel: lock(&(&xhci->lock)->rlock); Oct 18 21:41:17 dhcp47-74 kernel: Oct 18 21:41:17 dhcp47-74 kernel: *** DEADLOCK *** Oct 18 21:41:17 dhcp47-74 kernel: Oct 18 21:41:17 dhcp47-74 kernel: 1 lock held by swapper/0: Oct 18 21:41:17 dhcp47-74 kernel: #0: (&ep->stop_cmd_timer){+.-...}, at: [<ffffffff8106abf2>] run_timer_softirq+0x162/0x570 Oct 18 21:41:17 dhcp47-74 kernel: Oct 18 21:41:17 dhcp47-74 kernel: stack backtrace: Oct 18 21:41:17 dhcp47-74 kernel: Pid: 0, comm: swapper Tainted: G W 3.1.0-rc4nmi+ #456 Oct 18 21:41:17 dhcp47-74 kernel: Call Trace: Oct 18 21:41:17 dhcp47-74 kernel: <IRQ> [<ffffffff81098ed7>] print_usage_bug+0x227/0x270 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff810999c6>] mark_lock+0x346/0x410 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8109a7de>] __lock_acquire+0x61e/0x1660 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81099893>] ? mark_lock+0x213/0x410 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8109bed7>] lock_acquire+0x97/0x170 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffffa0228990>] ? xhci_stop_endpoint_command_watchdog+0x30/0x340 [xhci_hcd] Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81501b46>] _raw_spin_lock+0x46/0x80 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffffa0228990>] ? xhci_stop_endpoint_command_watchdog+0x30/0x340 [xhci_hcd] Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffffa0228990>] xhci_stop_endpoint_command_watchdog+0x30/0x340 [xhci_hcd] Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8106abf2>] ? run_timer_softirq+0x162/0x570 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8106ac9d>] run_timer_softirq+0x20d/0x570 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8106abf2>] ? run_timer_softirq+0x162/0x570 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffffa0228960>] ? xhci_queue_isoc_tx_prepare+0x8e0/0x8e0 [xhci_hcd] Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff810604d2>] __do_softirq+0xf2/0x3f0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81020edd>] ? lapic_next_event+0x1d/0x30 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81090d4e>] ? clockevents_program_event+0x5e/0x90 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8150ce6c>] call_softirq+0x1c/0x30 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8100484d>] do_softirq+0x8d/0xc0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8105ff35>] irq_exit+0xe5/0x100 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8150d65e>] smp_apic_timer_interrupt+0x6e/0x99 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff8150b6f0>] apic_timer_interrupt+0x70/0x80 Oct 18 21:41:17 dhcp47-74 kernel: <EOI> [<ffffffff81095d8d>] ? trace_hardirqs_off+0xd/0x10 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff812ddb76>] ? acpi_idle_enter_bm+0x227/0x25b Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff812ddb71>] ? acpi_idle_enter_bm+0x222/0x25b Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff813eda63>] cpuidle_idle_call+0x103/0x290 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81002155>] cpu_idle+0xe5/0x160 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff814e7f50>] rest_init+0xe0/0xf0 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff814e7e70>] ? csum_partial_copy_generic+0x170/0x170 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81df8e23>] start_kernel+0x3fc/0x407 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81df8321>] x86_64_start_reservations+0x131/0x135 Oct 18 21:41:17 dhcp47-74 kernel: [<ffffffff81df8412>] x86_64_start_kernel+0xed/0xf4 Oct 18 21:41:17 dhcp47-74 kernel: xhci_hcd 0000:00:14.0: xHCI host not responding to stop endpoint command. Oct 18 21:41:17 dhcp47-74 kernel: xhci_hcd 0000:00:14.0: Assuming host is dying, halting host. Oct 18 21:41:17 dhcp47-74 kernel: xhci_hcd 0000:00:14.0: HC died; cleaning up Oct 18 21:41:17 dhcp47-74 kernel: usb 3-4: device descriptor read/8, error -110 Oct 18 21:41:17 dhcp47-74 kernel: usb 3-4: device descriptor read/8, error -22 Oct 18 21:41:17 dhcp47-74 kernel: hub 3-0:1.0: cannot disable port 4 (err = -19) Basically what is happening is in xhci_stop_endpoint_command_watchdog() the xhci->lock is grabbed with just spin_lock. What lockdep deduces is that if an interrupt occurred while in this function it would deadlock with xhci_irq because that function also grabs the xhci->lock. Fixing it is trivial by using spin_lock_irqsave instead. This should be queued to stable kernels as far back as 2.6.33. Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26usb, xhci: Clear warm reset change event during initDon Zickus
commit 79c3dd8150fd5236d95766a9e662e3e932b462c9 upstream. I noticed on my Panther Point system that I wasn't getting hotplug events for my usb3.0 disk on a usb3 port. I tracked it down to the fact that the system had the warm reset change bit still set. This seemed to block future events from being received, including a hotplug event. Clearing this bit during initialization allowed the hotplug event to be received and the disk to be recognized correctly. This patch should be backported to kernels as old as 2.6.39. Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26xhci: Set slot and ep0 flags for address command.Sarah Sharp
commit d31c285b3a71cf9056e6a060de41f37780b0af86 upstream. Matt's AsMedia xHCI host controller was responding with a Context Error to an address device command after a configured device reset. Some sequence of events leads both the slot and endpoint zero add flags cleared to zero, which the AsMedia host doesn't like: [ 223.701839] xhci_hcd 0000:03:00.0: Slot ID 1 Input Context: [ 223.701841] xhci_hcd 0000:03:00.0: @ffff880137b25000 (virt) @ffffc000 (dma) 0x000000 - drop flags [ 223.701843] xhci_hcd 0000:03:00.0: @ffff880137b25004 (virt) @ffffc004 (dma) 0x000000 - add flags [ 223.701846] xhci_hcd 0000:03:00.0: @ffff880137b25008 (virt) @ffffc008 (dma) 0x000000 - rsvd2[0] [ 223.701848] xhci_hcd 0000:03:00.0: @ffff880137b2500c (virt) @ffffc00c (dma) 0x000000 - rsvd2[1] [ 223.701850] xhci_hcd 0000:03:00.0: @ffff880137b25010 (virt) @ffffc010 (dma) 0x000000 - rsvd2[2] [ 223.701852] xhci_hcd 0000:03:00.0: @ffff880137b25014 (virt) @ffffc014 (dma) 0x000000 - rsvd2[3] [ 223.701854] xhci_hcd 0000:03:00.0: @ffff880137b25018 (virt) @ffffc018 (dma) 0x000000 - rsvd2[4] [ 223.701857] xhci_hcd 0000:03:00.0: @ffff880137b2501c (virt) @ffffc01c (dma) 0x000000 - rsvd2[5] [ 223.701858] xhci_hcd 0000:03:00.0: Slot Context: [ 223.701860] xhci_hcd 0000:03:00.0: @ffff880137b25020 (virt) @ffffc020 (dma) 0x8400000 - dev_info [ 223.701862] xhci_hcd 0000:03:00.0: @ffff880137b25024 (virt) @ffffc024 (dma) 0x010000 - dev_info2 [ 223.701864] xhci_hcd 0000:03:00.0: @ffff880137b25028 (virt) @ffffc028 (dma) 0x000000 - tt_info [ 223.701866] xhci_hcd 0000:03:00.0: @ffff880137b2502c (virt) @ffffc02c (dma) 0x000000 - dev_state [ 223.701869] xhci_hcd 0000:03:00.0: @ffff880137b25030 (virt) @ffffc030 (dma) 0x000000 - rsvd[0] [ 223.701871] xhci_hcd 0000:03:00.0: @ffff880137b25034 (virt) @ffffc034 (dma) 0x000000 - rsvd[1] [ 223.701873] xhci_hcd 0000:03:00.0: @ffff880137b25038 (virt) @ffffc038 (dma) 0x000000 - rsvd[2] [ 223.701875] xhci_hcd 0000:03:00.0: @ffff880137b2503c (virt) @ffffc03c (dma) 0x000000 - rsvd[3] [ 223.701877] xhci_hcd 0000:03:00.0: Endpoint 00 Context: [ 223.701879] xhci_hcd 0000:03:00.0: @ffff880137b25040 (virt) @ffffc040 (dma) 0x000000 - ep_info [ 223.701881] xhci_hcd 0000:03:00.0: @ffff880137b25044 (virt) @ffffc044 (dma) 0x2000026 - ep_info2 [ 223.701883] xhci_hcd 0000:03:00.0: @ffff880137b25048 (virt) @ffffc048 (dma) 0xffffe8e0 - deq [ 223.701885] xhci_hcd 0000:03:00.0: @ffff880137b25050 (virt) @ffffc050 (dma) 0x000000 - tx_info [ 223.701887] xhci_hcd 0000:03:00.0: @ffff880137b25054 (virt) @ffffc054 (dma) 0x000000 - rsvd[0] [ 223.701889] xhci_hcd 0000:03:00.0: @ffff880137b25058 (virt) @ffffc058 (dma) 0x000000 - rsvd[1] [ 223.701892] xhci_hcd 0000:03:00.0: @ffff880137b2505c (virt) @ffffc05c (dma) 0x000000 - rsvd[2] ... [ 223.701927] xhci_hcd 0000:03:00.0: // Ding dong! [ 223.701992] xhci_hcd 0000:03:00.0: Setup ERROR: address device command for slot 1. The xHCI spec says that both flags must be set to one for the Address Device command. When the device is first enumerated, xhci_setup_addressable_virt_dev() does set those flags. However, when the device is addressed after it has been reset in the configured state, xhci_setup_addressable_virt_dev() is not called, and xhci_copy_ep0_dequeue_into_input_ctx() is called instead. That function relies on the flags being set up by previous commands, which apparently isn't a good assumption. Move the setting of the flags into the common parent function. This should be queued for stable kernels as old as 2.6.35, since that was the first introduction of xhci_copy_ep0_dequeue_into_input_ctx. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Tested-by: Matt <mdm@iinet.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26drivers/base/node.c: fix compilation error with older versions of gccClaudio Scordino
commit 91a13c281d7d4648c0b32dede11a0144c4e7984c upstream. Patch to fix the error message "directives may not be used inside a macro argument" which appears when the kernel is compiled for the cris architecture. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26pcie-gadget-spear: Add "platform:" prefix for platform modaliasAxel Lin
commit 161f14191dc166c4e3f37f68af1bc199c6868b7d upstream. Since 43cc71eed1250755986da4c0f9898f9a635cb3bf (platform: prefix MODALIAS with "platform:"), the platform modalias is prefixed with "platform:". Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Pratyush Anand <pratyush.anand@st.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26ALSA: hda - fix ELD memory leakWu Fengguang
Backported from commit b95d68b8179764e29558b75cec35ef4a6a98925b. memset(eld) clears eld->proc_entry which will leak the struct snd_info_entry when unloading module. Fix it by - memset only the fields before eld->eld_buffer - set eld->eld_valid to true _after_ all eld fields have been filled Cc: Pierre-louis Bossart <pierre-louis.bossart@intel.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26nfs: when attempting to open a directory, fall back on normal lookup (try #5)Jeff Layton
commit 1788ea6e3b2a58cf4fb00206e362d9caff8d86a7 upstream. commit d953126 changed how nfs_atomic_lookup handles an -EISDIR return from an OPEN call. Prior to that patch, that caused the client to fall back to doing a normal lookup. When that patch went in, the code began returning that error to userspace. The d_revalidate codepath however never had the corresponding change, so it was still possible to end up with a NULL ctx->state pointer after that. That patch caused a regression. When we attempt to open a directory that does not have a cached dentry, that open now errors out with EISDIR. If you attempt the same open with a cached dentry, it will succeed. Fix this by reverting the change in nfs_atomic_lookup and allowing attempts to open directories to fall back to a normal lookup Also, add a NFSv4-specific f_ops->open routine that just returns -ENOTDIR. This should never be called if things are working properly, but if it ever is, then the dprintk may help in debugging. To facilitate this, a new file_operations field is also added to the nfs_rpc_ops struct. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26TTY: ldisc, wait for ldisc infinitely in hangupJiri Slaby
commit 0c73c08ec73dbe080b9ec56696ee21d32754d918 upstream. For /dev/console case, we do not kill all ldisc users. It's due to redirected_tty_write test in __tty_hangup. In that case there still might be a process waiting e.g. in n_tty_read for input. We wait for such processes to disappear. The problem is that we use a timeout. After this timeout, we continue closing the ldisc and start freeing tty resources. It obviously leads to crashes when the other process is woken. So to fix this, we wait infinitely before reiniting the ldisc. (The tiocsetd remains untouched -- times out after 5s.) This is nicely reproducible with this run from shell: exec 0<>/dev/console 1<>/dev/console 2<>/dev/console and stopping a getty like: systemctl stop serial-getty@ttyS0.service The crash proper may be produced only under load or with constified timing the same as for 92f6fa09b. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Dmitriy Matrosov <sgf.dma@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26TTY: ldisc, move wait idle to callerJiri Slaby
commit 300420722e0734a4254f3b634e0f82664495d210 upstream. It is the only place where reinit is called from. And we really need to wait for the old ldisc to go once. Actually this is the place where the waiting originally was (before removed and re-added later). This will make the fix in the following patch easier to implement. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Dmitriy Matrosov <sgf.dma@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26TTY: ldisc, allow waiting for ldisc arbitrarily longJiri Slaby
commit df92d0561de364de53c42abc5d43e04ab6f326a5 upstream. To fix a nasty bug in ldisc hup vs. reinit we need to wait infinitely long for ldisc to be gone. So here we add a parameter to tty_ldisc_wait_idle to allow that. This is only a preparation for the real fix which is done in the following patches. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Dmitriy Matrosov <sgf.dma@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26tty: hvc_dcc: Fix duplicate character inputsStephen Boyd
commit c2a3e84f950e7ddba1f3914b005861d46ae60359 upstream. Reading from the DCC grabs a character from the buffer and clears the status bit. Since this is a context-changing operation, instructions following the character read that rely on the status bit being accurate need to be synchronized with an ISB. In this case, the status bit check needs to execute after the character read otherwise we run the risk of reading the character and checking the status bit before the read can clear the status bit in the first place. When this happens, the user will see the same character they typed twice, instead of once. Add an ISB after the read and the write, so that the status check is synchronized with the read/write operations. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26pch_uart: Support new device LAPIS Semiconductor ML7831 IOHTomoya MORINAGA
commit 8249f743f732ccbc3056428945ab1d9bd36d46bf upstream. ML7831 is companion chip for Intel Atom E6xx series. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26pch_uart: Fix DMA resource leak issueTomoya MORINAGA
commit 90f04c2926cfb5bf74533b0a7766bc896f6a0c0e upstream. Changing UART mode PIO->DMA->PIO->DMA like below, pch_uart driver can't get DMA channel resource. setserial /dev/ttyPCH0 ^low_latency setserial /dev/ttyPCH0 low_latency CAUSE: Changing mode using setserial command, ".startup" function which gets DMA channel is called before ".verify_port" function which sets dma-flag(use_dma/use_dma_flag) as 1. PIO->DMA .startup: Since dma-flag is 0, DMA channel is not requested. .verify_port: dma-flag is set as 1. .shutdown: N/A DMA->PIO .startup: Since dma-flag is 1, DMA channel is requested. .verify_port: dma-flag is set as 0. .shutdown: Since dma-flag is 0, DMA channel is not released. This means DMA channel resource leak occurs. Next time, this driver can't get DMA channel resource forever. MODIFICATION: Currently, when release DMA channel resource, this driver checks dma-flag. However, this specification occurs the above issue. This driver must check whether dma_request_channel is executed or not. The values are saved in private data variable "chan_tx/chan_tx". These variables mean if the value is NULL, DMA channel is not requested, if not NULL, DMA channel is requested. This patch fixes the issue. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26pch_uart: Fix hw-flow control issueTomoya MORINAGA
commit a1d7cfe29f13cf45f8094929864b9c66bf0cd91b upstream. Using hardware flow control, currently, register of the control-bit(AFE) is not set. This patch fixes the issue. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26pch_phub: Fix MAC address writing issue for LAPIS ML7831Tomoya MORINAGA
commit 2a9887919457c6e1bd482e8448223be59d19010a upstream. ISSUE: Using ML7831, MAC address writing doesn't work well. CAUSE: ML7831 and EG20T have the same register map for MAC address access. However, this driver processes the writing the same as ML7223. This is not true. This driver must process the writing the same as EG20T. This patch fixes the issue. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Cc: Masayuki Ohtak <masa-korg@dsn.okisemi.com> Cc: Alexander Stein <alexander.stein@systec-electronic.com> Cc: Denis Turischev <denis@compulab.co.il> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26pch_phub: Support new device LAPIS Semiconductor ML7831 IOHTomoya MORINAGA
commit 584ad00ce4bfe594e4c4a89944b3c635187a1ca1 upstream. ML7831 is companion chip for Intel Atom E6xx series. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26PM / driver core: disable device's runtime PM during shutdownPeter Chen
commit af8db1508f2c9f3b6e633e2d2d906c6557c617f9 upstream. There may be an issue when the user issue "reboot/shutdown" command, then the device has shut down its hardware, after that, this runtime-pm featured device's driver will probably be scheduled to do its suspend routine, and at its suspend routine, it may access hardware, but the device has already shutdown physically, then the system hang may be occurred. I ran out this issue using an auto-suspend supported USB devices, like 3G modem, keyboard. The usb runtime suspend routine may be scheduled after the usb controller has been shut down, and the usb runtime suspend routine will try to suspend its roothub(controller), it will access register, then the system hang occurs as the controller is shutdown. Signed-off-by: Peter Chen <peter.chen@freescale.com> Acked-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26ip6_tunnel: copy parms.name after register_netdeviceJosh Boyer
commit 731abb9cb27aef6013ce60808a04e04a545f3f4e upstream. Commit 1c5cae815d removed an explicit call to dev_alloc_name in ip6_tnl_create because register_netdevice will now create a valid name. This works for the net_device itself. However the tunnel keeps a copy of the name in the parms structure for the ip6_tnl associated with the tunnel. parms.name is set by copying the net_device name in ip6_tnl_dev_init_gen. That function is called from ip6_tnl_dev_init in ip6_tnl_create, but it is done before register_netdevice is called so the name is set to a bogus value in the parms.name structure. This shows up if you do a simple tunnel add, followed by a tunnel show: [root@localhost ~]# ip -6 tunnel add remote fec0::100 local fec0::200 [root@localhost ~]# ip -6 tunnel show ip6tnl0: ipv6/ipv6 remote :: local :: encaplimit 0 hoplimit 0 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000) ip6tnl%d: ipv6/ipv6 remote fec0::100 local fec0::200 encaplimit 4 hoplimit 64 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000) [root@localhost ~]# Fix this by moving the strcpy out of ip6_tnl_dev_init_gen, and calling it after register_netdevice has successfully returned. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26cfg80211: fix bug on regulatory core exit on access to last_requestLuis R. Rodriguez
commit 58ebacc66bd11be2327edcefc79de94bd6f5bb4a upstream. Commit 4d9d88d1 by Scott James Remnant <keybuk@google.com> added the .uevent() callback for the regulatory device used during the platform device registration. The change was done to account for queuing up udev change requests through udevadm triggers. The change also meant that upon regulatory core exit we will now send a uevent() but the uevent() callback, reg_device_uevent(), also accessed last_request. Right before commiting device suicide we free'd last_request but never set it to NULL so platform_device_unregister() would lead to bogus kernel paging request. Fix this and also simply supress uevents right before we commit suicide as they are pointless. This fix is required for kernels >= v2.6.39 $ git describe --contains 4d9d88d1 v2.6.39-rc1~468^2~25^2^2~21 The impact of not having this present is that a bogus paging access may occur (only read) upon cfg80211 unload time. You may also get this BUG complaint below. Although Johannes could not reproduce the issue this fix is theoretically correct. mac80211_hwsim: unregister radios mac80211_hwsim: closing netlink BUG: unable to handle kernel paging request at ffff88001a06b5ab IP: [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211] PGD 1836063 PUD 183a063 PMD 1ffcb067 PTE 1a06b160 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU 0 Modules linked in: cfg80211(-) [last unloaded: mac80211] Pid: 2279, comm: rmmod Tainted: G W 3.1.0-wl+ #663 Bochs Bochs RIP: 0010:[<ffffffffa030df9a>] [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211] RSP: 0000:ffff88001c5f9d58 EFLAGS: 00010286 RAX: 0000000000000000 RBX: ffff88001d2eda88 RCX: ffff88001c7468fc RDX: ffff88001a06b5a0 RSI: ffff88001c7467b0 RDI: ffff88001c7467b0 RBP: ffff88001c5f9d58 R08: 000000000000ffff R09: 000000000000ffff R10: 0000000000000000 R11: 0000000000000001 R12: ffff88001c7467b0 R13: ffff88001d2eda78 R14: ffffffff8164a840 R15: 0000000000000001 FS: 00007f8a91d8a6e0(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88001a06b5ab CR3: 000000001c62e000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rmmod (pid: 2279, threadinfo ffff88001c5f8000, task ffff88000023c780) Stack: ffff88001c5f9d98 ffffffff812ff7e5 ffffffff8176ab3d ffff88001c7468c2 000000000000ffff ffff88001d2eda88 ffff88001c7467b0 ffff880000114820 ffff88001c5f9e38 ffffffff81241dc7 ffff88001c5f9db8 ffffffff81040189 Call Trace: [<ffffffff812ff7e5>] dev_uevent+0xc5/0x170 [<ffffffff81241dc7>] kobject_uevent_env+0x1f7/0x490 [<ffffffff81040189>] ? sub_preempt_count+0x29/0x60 [<ffffffff814cab1a>] ? _raw_spin_unlock_irqrestore+0x4a/0x90 [<ffffffff81305307>] ? devres_release_all+0x27/0x60 [<ffffffff8124206b>] kobject_uevent+0xb/0x10 [<ffffffff812fee27>] device_del+0x157/0x1b0 [<ffffffff8130377d>] platform_device_del+0x1d/0x90 [<ffffffff81303b76>] platform_device_unregister+0x16/0x30 [<ffffffffa030fffd>] regulatory_exit+0x5d/0x180 [cfg80211] [<ffffffffa032bec3>] cfg80211_exit+0x2b/0x45 [cfg80211] [<ffffffff8109a84c>] sys_delete_module+0x16c/0x220 [<ffffffff8108a23e>] ? trace_hardirqs_on_caller+0x7e/0x120 [<ffffffff814cba02>] system_call_fastpath+0x16/0x1b Code: <all your base are belong to me> RIP [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211] RSP <ffff88001c5f9d58> CR2: ffff88001a06b5ab ---[ end trace 147c5099a411e8c0 ]--- Reported-by: Johannes Berg <johannes@sipsolutions.net> Cc: Scott James Remnant <keybuk@google.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26nl80211: fix HT capability attribute validationJohannes Berg
commit 6c7394197af90f6a332180e33f5d025d3037d883 upstream. Since the NL80211_ATTR_HT_CAPABILITY attribute is used as a struct, it needs a minimum, not maximum length. Enforce that properly. Not doing so could potentially lead to reading after the buffer. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26mac80211: fix bug in ieee80211_build_probe_reqJohannes Berg
commit 5b2bbf75a24d6b06afff6de0eb4819413fd81971 upstream. ieee80211_probereq_get() can return NULL in which case we should clean up & return NULL in ieee80211_build_probe_req() as well. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26mac80211: fix NULL dereference in radiotap codeJohannes Berg
commit f8d1ccf15568268c76f913b45ecdd33134387f1a upstream. When receiving failed PLCP frames is enabled, there won't be a rate pointer when we add the radiotap header and thus the kernel will crash. Fix this by not assuming the rate pointer is always valid. It's still always valid for frames that have good PLCP though, and that is checked & enforced. This was broken by my commit fc88518916793af8ad6a02e05ff254d95c36d875 Author: Johannes Berg <johannes.berg@intel.com> Date: Fri Jul 30 13:23:12 2010 +0200 mac80211: don't check rates on PLCP error frames where I removed the check in this case but didn't take into account that the rate info would be used. Reported-by: Xiaokang Qin <xiaokang.qin@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26rt2x00: Fix sleep-while-atomic bug in powersaving code.Gertjan van Wingerde
commit ed66ba472a742cd8df37d7072804b2111cdb1014 upstream. The generic powersaving code that determines after reception of a frame whether the device should go back to sleep or whether is could stay awake was calling rt2x00lib_config directly from RX tasklet context. On a number of the devices this call can actually sleep, due to having to confirm that the sleeping commands have been executed successfully. Fix this by moving the call to rt2x00lib_config to a workqueue call. This fixes bug https://bugzilla.redhat.com/show_bug.cgi?id=731672 Tested-by: Tomas Trnka <tomastrnka@gmx.com> Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26Net, libertas: Resolve memory leak in if_spi_host_to_card()Jesper Juhl
commit fe09b32a4361bea44169b2063e8c867cabb6a8ba upstream. If we hit the default case in the switch in if_spi_host_to_card() we'll leak the memory we allocated for 'packet'. This patch resolves the leak by freeing the allocated memory in that case. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26ARM: 7150/1: Allow kernel unaligned accesses on ARMv6+ processorsCatalin Marinas
commit 8428e84d42179c2a00f5f6450866e70d802d1d05 upstream. Recent gcc versions generate unaligned accesses by default on ARMv6 and later processors. This patch ensures that the SCTLR.A bit is always cleared on such processors to avoid kernel traping before alignment_init() is called. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: John Linn <John.Linn@xilinx.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26KVM: s390: Fix RUNNING flag misinterpretationCornelia Huck
commit 9e6dabeffd1d0ec2aa19aa076c4886067238d442 upstream. CPUSTAT_RUNNING was implemented signifying that a vcpu is not stopped. This is not, however, what the architecture says: RUNNING should be set when the host is acting on the behalf of the guest operating system. CPUSTAT_RUNNING has been changed to be set in kvm_arch_vcpu_load() and to be unset in kvm_arch_vcpu_put(). For signifying stopped state of a vcpu, a host-controlled bit has been used and is set/unset basically on the reverse as the old CPUSTAT_RUNNING bit (including pushing it down into stop handling proper in handle_stop()). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26saa7164: Add support for another HVR2200 hardware revisionTony Jago
commit 62dd28d0c659db29bdb89cfe9f0aefe42f0adfe9 upstream. Hauppauge have released a new model rev, sub id 8940, this adds support. [stoth@kernellabs.com: I modified Tony's patch slightly in relation to the card numbering in saa7164.h, appending rather than inserting the new card - normal practise] Signed-off-by: Tony Jago <tony@hammertelecom.com.au> Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26aacraid: controller hangs if kernel uses non-default ASPM policyVasily Averin
commit cf16123c9c8e346ed1dd171295a678d77648d7f8 upstream. Aacraid controller can hang on some nodes if kernel uses non-default (powersave) ASPM policy. Controller hangs shortly after successful load and hardware detection. Scsi error handler detects this hang and tries to restart hardware but it does not help. Initially it was noticed on RHEL6-based openVZ kernel after backporting aacraid driver from mainline (RHEL6 kernel with original driver works well) http://bugzilla.openvz.org/show_bug.cgi?id=2043 This issue happens because default ASPM policy was changed in Red Hat kernels. Therefore guys from Red Hat have noticed this problem long time ago: on Fedora 12 https://bugzilla.redhat.com/show_bug.cgi?id=540478 on Fedora 14 https://bugzilla.redhat.com/show_bug.cgi?id=679385 In RHEL6 kernel this issue was fixed, ASPM was disabled in aacraid driver. In kernel changelog I've found that seems it was done by Matthew Garrett: - [scsi] aacraid: Disable ASPM by default (Matthew Garrett) [599735] However seems this patch was not submitted to mainline. I've reproduced this issue on vanilla 3.1.0 kernel booted with "pcie_aspm.policy=powersave" option, So I believe it makes sense to do it now. Signed-off-by: Vasily Averin <vvs@sw.ru> [mjg: Checking the Windows drivers indicates that they disable ASPM under all circumstances, so:] Acked-by: Matthew Garrett <mjg@redhat.com> Acked-by: Achim Leubner <Achim_Leubner@pmc-sierra.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
