commit f9865f06f7f18c6661c88d0511f05c48612319cc upstream.
Commit f363e45fd118 ("net/ceph: make ceph_msgr_wq non-reentrant")
effectively removed WQ_MEM_RECLAIM flag from ceph_msgr_wq. This is
wrong - libceph is very much a memory reclaim path, so restore it.
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
Tested-by: Micha Krause <micha@krausam.de>
Reviewed-by: Sage Weil <sage@redhat.com>
commit 6e5aafb27419f32575b27ef9d6a31e5d54661aca upstream.
If we hit any errors in btrfs_lookup_csums_range, we'll loop through all
the csums we allocate and free them. But the code was using list_entry
incorrectly, and ended up trying to free the on-stack list_head instead.
This bug came from commit 0678b6185
btrfs: Don't BUG_ON kzalloc error in btrfs_lookup_csums_range()
Signed-off-by: Chris Mason <clm@fb.com>
Reported-by: Erik Berg <btrfs@slipsprogrammoer.no>
commit a87fa1d81a9fb5e9adca9820e16008c40ad09f33 upstream.
The string property read helpers will run off the end of the buffer if
it is handed a malformed string property. Rework the parsers to make
sure that doesn't happen. At the same time add new test cases to make
sure the functions behave themselves.
The original implementations of of_property_read_string_index() and
of_property_count_strings() both open-coded the same block of parsing
code, each with it's own subtly different bugs. The fix here merges
functions into a single helper and makes the original functions static
inline wrappers around the helper.
One non-bugfix aspect of this patch is the addition of a new wrapper,
of_property_read_string_array(). The new wrapper is needed by the
device_properties feature that Rafael is working on and planning to
merge for v3.19. The implementation is identical both with and without
the new static inline wrapper, so it just got left in to reduce the
churn on the header file.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Darren Hart <darren.hart@intel.com>
commit e4a60d139060975eb956717e4f63ae348d4d8cc5 upstream.
There is a race condition when removing glue directory.
It can be reproduced in following test:
path 1: Add first child device
device_add()
get_device_parent()
/*find parent from glue_dirs.list*/
list_for_each_entry(k, &dev->class->p->glue_dirs.list, entry)
if (k->parent == parent_kobj) {
kobj = kobject_get(k);
break;
class_dir_create_and_add()
path2: Remove last child device under glue dir
device_del()
cleanup_device_parent()
cleanup_glue_dir()
kobject_put(glue_dir);
If path2 has been called cleanup_glue_dir(), but not
call kobject_put(glue_dir), the glue dir is still
in parent's kset list. Meanwhile, path1 find the glue
dir from the glue_dirs.list. Path2 may release glue dir
before path1 call kobject_get(). So kernel will report
the warning and bug_on.
This is a "classic" problem we have of a kref in a list
that can be found while the last instance could be removed
at the same time.
This patch reuse gdp_mutex to fix this race condition.
The following calltrace is captured in kernel 3.4, but
the latest kernel still has this bug.
<4>[ 3965.441471] WARNING: at ...include/linux/kref.h:41 kobject_get+0x33/0x40()
<4>[ 3965.441474] Hardware name: Romley
<4>[ 3965.441475] Modules linked in: isd_iop(O) isd_xda(O)...
<4>[ 3965.441605] Call Trace:
<4>[ 3965.441611] [<ffffffff8103717a>] warn_slowpath_common+0x7a/0xb0
<4>[ 3965.441615] [<ffffffff810371c5>] warn_slowpath_null+0x15/0x20
<4>[ 3965.441618] [<ffffffff81215963>] kobject_get+0x33/0x40
<4>[ 3965.441624] [<ffffffff812d1e45>] get_device_parent.isra.11+0x135/0x1f0
<4>[ 3965.441627] [<ffffffff812d22d4>] device_add+0xd4/0x6d0
<4>[ 3965.441631] [<ffffffff812d0dbc>] ? dev_set_name+0x3c/0x40
<2>[ 3965.441912] kernel BUG at ..../fs/sysfs/group.c:65!
<4>[ 3965.441915] invalid opcode: 0000 [#1] SMP
<4>[ 3965.686743] [<ffffffff811a677e>] sysfs_create_group+0xe/0x10
<4>[ 3965.686748] [<ffffffff810cfb04>] blk_trace_init_sysfs+0x14/0x20
<4>[ 3965.686753] [<ffffffff811fcabb>] blk_register_queue+0x3b/0x120
<4>[ 3965.686756] [<ffffffff812030bc>] add_disk+0x1cc/0x490
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Signed-off-by: Weng Meiling <wengmeiling.weng@huawei.com>
commit 11cfbfb098b22d3e57f1f2be217cad20e2d48463 upstream.
iowait is for blkio [1]. I2C shouldn't use it.
[1] https://lkml.org/lkml/2014/11/3/317
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
commit 183fd8fcd7f8afb7ac5ec68f83194872f9fecc84 upstream.
The acpi-video backlight interface on the Acer KAV80 is broken, and worse
it causes the entire machine to slow down significantly after a suspend/resume.
Blacklist it, and use the acer-wmi backlight interface instead. Note that
the KAV80 is somewhat unique in that it is the only Acer model where we
fall back to acer-wmi after blacklisting, rather then using the native
(e.g. intel) backlight driver. This is done because there is no native
backlight interface on this model.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1128309
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
commit a8d4205623ae965e36c68629db306ca0695a2771 upstream.
When we fail to allocate page vector in rbd_obj_read_sync() we just
basically ignore the problem and continue which will result in an oops
later. Fix the problem by returning proper error.
CC: Yehuda Sadeh <yehuda@inktank.com>
CC: Sage Weil <sage@inktank.com>
CC: ceph-devel@vger.kernel.org
Coverity-id: 1226882
commit 8c3e434769b1707fd2d24de5a2eb25fedc634c4a upstream.
0x4c6e is a secondary device id so should not be used
by the driver.
Noticed-by: Mark Kettenis <mark.kettenis@xs4all.nl>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit bfa6b18c680450c17512c741ed1d818695747621 ]
Currently, there's no guarantee that udc->driver
will be valid when using soft_connect sysfs
interface. In fact, we can very easily trigger
a NULL pointer dereference by trying to disconnect
when a gadget driver isn't loaded.
Fix this bug:
~# echo disconnect > soft_connect
[ 33.685743] Unable to handle kernel NULL pointer dereference at virtual address 00000014
[ 33.694221] pgd = ed0cc000
[ 33.697174] [00000014] *pgd=ae351831, *pte=00000000, *ppte=00000000
[ 33.703766] Internal error: Oops: 17 [#1] SMP ARM
[ 33.708697] Modules linked in: xhci_plat_hcd xhci_hcd snd_soc_davinci_mcasp snd_soc_tlv320aic3x snd_soc_edma snd_soc_omap snd_soc_evm snd_soc_core dwc3 snd_compress snd_pcm_dmaengine snd_pcm snd_timer snd lis3lv02d_i2c matrix_keypad lis3lv02d dwc3_omap input_polldev soundcore
[ 33.734372] CPU: 0 PID: 1457 Comm: bash Not tainted 3.17.0-09740-ga93416e-dirty #345
[ 33.742457] task: ee71ce00 ti: ee68a000 task.ti: ee68a000
[ 33.748116] PC is at usb_udc_softconn_store+0xa4/0xec
[ 33.753416] LR is at mark_held_locks+0x78/0x90
[ 33.758057] pc : [<c04df128>] lr : [<c00896a4>] psr: 20000013
[ 33.758057] sp : ee68bec8 ip : c0c00008 fp : ee68bee4
[ 33.770050] r10: ee6b394c r9 : ee68bf80 r8 : ee6062c0
[ 33.775508] r7 : 00000000 r6 : ee6062c0 r5 : 0000000b r4 : ee739408
[ 33.782346] r3 : 00000000 r2 : 00000000 r1 : ee71d390 r0 : ee664170
[ 33.789168] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 33.796636] Control: 10c5387d Table: ad0cc059 DAC: 00000015
[ 33.802638] Process bash (pid: 1457, stack limit = 0xee68a248)
[ 33.808740] Stack: (0xee68bec8 to 0xee68c000)
[ 33.813299] bec0: 0000000b c0411284 ee6062c0 00000000 ee68bef4 ee68bee8
[ 33.821862] bee0: c04112ac c04df090 ee68bf14 ee68bef8 c01c2868 c0411290 0000000b ee6b3940
[ 33.830419] bf00: 00000000 00000000 ee68bf4c ee68bf18 c01c1a24 c01c2818 00000000 00000000
[ 33.838990] bf20: ee61b940 ee2f47c0 0000000b 000ce408 ee68bf80 c000f304 ee68a000 00000000
[ 33.847544] bf40: ee68bf7c ee68bf50 c0152dd8 c01c1960 ee68bf7c c0170af8 ee68bf7c ee2f47c0
[ 33.856099] bf60: ee2f47c0 000ce408 0000000b c000f304 ee68bfa4 ee68bf80 c0153330 c0152d34
[ 33.864653] bf80: 00000000 00000000 0000000b 000ce408 b6e7fb50 00000004 00000000 ee68bfa8
[ 33.873204] bfa0: c000f080 c01532e8 0000000b 000ce408 00000001 000ce408 0000000b 00000000
[ 33.881763] bfc0: 0000000b 000ce408 b6e7fb50 00000004 0000000b 00000000 000c5758 00000000
[ 33.890319] bfe0: 00000000 bec2c924 b6de422d b6e1d226 40000030 00000001 75716d2f 00657565
[ 33.898890] [<c04df128>] (usb_udc_softconn_store) from [<c04112ac>] (dev_attr_store+0x28/0x34)
[ 33.907920] [<c04112ac>] (dev_attr_store) from [<c01c2868>] (sysfs_kf_write+0x5c/0x60)
[ 33.916200] [<c01c2868>] (sysfs_kf_write) from [<c01c1a24>] (kernfs_fop_write+0xd0/0x194)
[ 33.924773] [<c01c1a24>] (kernfs_fop_write) from [<c0152dd8>] (vfs_write+0xb0/0x1bc)
[ 33.932874] [<c0152dd8>] (vfs_write) from [<c0153330>] (SyS_write+0x54/0xb0)
[ 33.940247] [<c0153330>] (SyS_write) from [<c000f080>] (ret_fast_syscall+0x0/0x48)
[ 33.948160] Code: e1a01007 e12fff33 e5140004 e5143008 (e5933014)
[ 33.954625] ---[ end trace f849bead94eab7ea ]---
Fixes: 2ccea03 (usb: gadget: introduce UDC Class)
Signed-off-by: Felipe Balbi <balbi@ti.com>
[ Upstream commit 52ec49a5e56a27c5b6f8217708783eff39f24c16 ]
During Halt Endpoint Test, our interrupt endpoint
will be disabled, which will clear out ep->desc
to NULL. Unless we call config_ep_by_speed() again,
we will not be able to enable this endpoint which
will make us fail that test.
Fixes: f9c56cd (usb: gadget: Clear usb_endpoint_descriptor
inside the struct usb_ep on disable)
[ Upstream commit 7a60855972f0d3c014093046cb6f013a1ee5bb19 ]
According to our Gadget Framework API documentation,
->set_halt() *must* return -EAGAIN if we have pending
transfers (on either direction) or FIFO isn't empty (on
TX endpoints).
Fix this bug so that the mass storage gadget can be used
without stall=0 parameter.
This patch should be backported to all kernels since v3.2.
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
commit e2cffb5f493a8b431dc87124388ea59b79f0bccb upstream.
On archs with PAGE_SIZE >= 64 KiB the function skcipher_alloc_sgl()
fails with -ENOMEM no matter what user space actually requested.
This is caused by the fact sock_kmalloc call inside the function tried
to allocate more memory than allowed by the default kernel socket buffer
size (kernel param net.core.optmem_max).
Signed-off-by: Ondrej Kozina <okozina@redhat.com>
commit f55fefd1a5a339b1bd08c120b93312d6eb64a9fb upstream.
The WARN_ON checking whether i_mutex is held in
pagecache_isize_extended() was wrong because some filesystems (e.g.
XFS) use different locks for serialization of truncates / writes. So
just remove the check.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit b47dcbdc5161d3d5756f430191e2840d9b855492 upstream.
If the TSC is unusable or disabled, then this patch fixes:
- Confusion while trying to clear old APIC interrupts.
- Division by zero and incorrect programming of the TSC deadline
timer.
This fixes boot if the CPU has a TSC deadline timer but a missing or
broken TSC. The failure to boot can be observed with qemu using
-cpu qemu64,-tsc,+tsc-deadline
This also happens to me in nested KVM for unknown reasons.
With this patch, I can boot cleanly (although without a TSC).
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Bandan Das <bsd@redhat.com>
Link: http://lkml.kernel.org/r/e2fa274e498c33988efac0ba8b7e3120f7f92d78.1413393027.git.luto@amacapital.net
commit 6891c4509c792209c44ced55a60f13954cb50ef4 upstream.
If userland creates a timer without specifying a sigevent info, we'll
create one ourself, using a stack local variable. Particularly will we
use the timer ID as sival_int. But as sigev_value is a union containing
a pointer and an int, that assignment will only partially initialize
sigev_value on systems where the size of a pointer is bigger than the
size of an int. On such systems we'll copy the uninitialized stack bytes
from the timer_create() call to userland when the timer actually fires
and we're going to deliver the signal.
Initialize sigev_value with 0 to plug the stack info leak.
Found in the PaX patch, written by the PaX Team.
Fixes: 5a9fa7307285 ("posix-timers: kill ->it_sigev_signo and...")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Brad Spengler <spender@grsecurity.net>
Cc: PaX Team <pageexec@freemail.hu>
Link: http://lkml.kernel.org/r/1412456799-32339-1-git-send-email-minipli@googlemail.com
commit c7abf25af0f41be4b50d44c5b185d52eea360cb8 upstream.
It affects non-(V)HT rates and can lead to selecting an rts_cts rate
that is not a basic rate or way superior to the reference rate (ATM
rates[0] used for the 1st attempt of the protected frame data).
E.g, assuming drivers register growing (bitrate) sorted tables of
ieee80211_rate-s, having :
- rates[0].idx == d'2 and basic_rates == b'10100
will select rts_cts idx b'10011 & ~d'(BIT(2)-1), i.e. 1, likewise
- rates[0].idx == d'2 and basic_rates == b'10001
will select rts_cts idx b'10000
The first is not a basic rate and the second is > rates[0].
Also, wrt severity of the addressed misbehavior, ATM we only have one
rts_cts_rate_idx rather than one per rate table entry, so this idx might
still point to bitrates > rates[1..MAX_RATES].
Fixes: 5253ffb8c9e1 ("mac80211: always pick a basic rate to tx RTS/CTS for pre-HT rates")
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
commit 94fb823fcb4892614f57e59601bb9d4920f24711 upstream.
If a device's dev_pm_ops::freeze callback fails during the QUIESCE
phase, we don't rollback things correctly calling the thaw and complete
callbacks. This could leave some devices in a suspended state in case of
an error during resuming from hibernation.
Signed-off-by: Imre Deak <imre.deak@intel.com>
commit 37b164578826406a173ca7c20d9ba7430134d23e upstream.
Kernel oops can cause the tty to be unreleaseable (for example, if
n_tty_read() crashes while on the read_wait queue). This will cause
tty_release() to endlessly loop without sleeping.
Use a killable sleep timeout which grows by 2n+1 jiffies over the interval
[0, 120 secs.) and then jumps to forever (but still killable).
NB: killable just allows for the task to be rewoken manually, not
to be terminated.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
commit 474d2605d119479e5aa050f738632e63589d4bb5 upstream.
Due to a switched left and right side of an assignment,
dquot_writeback_dquots() never returned error. This could result in
errors during quota writeback to not be reported to userspace properly.
Fix it.
Coverity-id: 1226884
commit 7938db449bbc55bbeb164bec7af406212e7e98f1 upstream.
The check whether quota format is set even though there are no
quota files with journalled quota is pointless and it actually
makes it impossible to turn off journalled quotas (as there's
no way to unset journalled quota format). Just remove the check.
commit 51904b08072a8bf2b9ed74d1bd7a5300a614471d upstream.
Unknown operation numbers are caught in nfsd4_decode_compound() which
sets op->opnum to OP_ILLEGAL and op->status to nfserr_op_illegal. The
error causes the main loop in nfsd4_proc_compound() to skip most
processing. But nfsd4_proc_compound also peeks ahead at the next
operation in one case and doesn't take similar precautions there.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit fa19ac4b92bc2b5024af3e868f41f81fa738567a upstream.
Fix UE event being reported as HW_EVENT_ERR_CORRECTED.
Signed-off-by: Jason Baron <jbaron@akamai.com>
Link: http://lkml.kernel.org/r/8beb13803500076fef827eab33d523e355d83759.1413405053.git.jbaron@akamai.com
commit 8030122a9ccf939186f8db96c318dbb99b5463f6 upstream.
Fix CE event being reported as HW_EVENT_ERR_UNCORRECTED.
Link: http://lkml.kernel.org/r/e6dd616f2cd51583a7e77af6f639b86313c74144.1413405053.git.jbaron@akamai.com
commit 8a3f075d6c9b3612b4a5fb2af8db82b38b20caf0 upstream.
Link: http://lkml.kernel.org/r/d02465b4f30314b390c12c061502eda5e9d29c52.1413405053.git.jbaron@akamai.com
commit ab0543de6ff0877474f57a5aafbb51a61e88676f upstream.
Link: http://lkml.kernel.org/r/7aee8e244a32ff86b399a8f966c4aae70296aae0.1413405053.git.jbaron@akamai.com
commit 84ce0f0e94ac97217398b3b69c21c7a62ebeed05 upstream.
When sg_scsi_ioctl() fails to prepare request to submit in
blk_rq_map_kern() we jump to a label where we just end up copying
(luckily zeroed-out) kernel buffer to userspace instead of reporting
error. Fix the problem by jumping to the right label.
CC: Jens Axboe <axboe@kernel.dk>
CC: linux-scsi@vger.kernel.org
Coverity-id: 1226871
Fixed up the, now unused, out label.
Signed-off-by: Jens Axboe <axboe@fb.com>
commit ea5d05b34aca25c066e0699512d0ffbd8ee6ac3e upstream.
If __bitmap_shift_left() or __bitmap_shift_right() are asked to shift by
a multiple of BITS_PER_LONG, they will try to shift a long value by
BITS_PER_LONG bits which is undefined. Change the functions to avoid
the undefined shift.
Coverity id: 1192175
Coverity id: 1192174
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
commit 401507d67d5c2854f5a88b3f93f64fc6f267bca5 upstream.
Commit ff7ee93f4715 ("cgroup/kmemleak: Annotate alloc_page() for cgroup
allocations") introduces kmemleak_alloc() for alloc_page_cgroup(), but
corresponding kmemleak_free() is missing, which makes kmemleak be
wrongly disabled after memory offlining. Log is pasted at the end of
this commit message.
This patch add kmemleak_free() into free_page_cgroup(). During page
offlining, this patch removes corresponding entries in kmemleak rbtree.
After that, the freed memory can be allocated again by other subsystems
without killing kmemleak.
bash # for x in 1 2 3 4; do echo offline > /sys/devices/system/memory/memory$x/state ; sleep 1; done ; dmesg | grep leak
Offlined Pages 32768
kmemleak: Cannot insert 0xffff880016969000 into the object search tree (overlaps existing)
CPU: 0 PID: 412 Comm: sleep Not tainted 3.17.0-rc5+ #86
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x46/0x58
create_object+0x266/0x2c0
kmemleak_alloc+0x26/0x50
kmem_cache_alloc+0xd3/0x160
__sigqueue_alloc+0x49/0xd0
__send_signal+0xcb/0x410
send_signal+0x45/0x90
__group_send_sig_info+0x13/0x20
do_notify_parent+0x1bb/0x260
do_exit+0x767/0xa40
do_group_exit+0x44/0xa0
SyS_exit_group+0x17/0x20
system_call_fastpath+0x16/0x1b
kmemleak: Kernel memory leak detector disabled
kmemleak: Object 0xffff880016900000 (size 524288):
kmemleak: comm "swapper/0", pid 0, jiffies 4294667296
kmemleak: min_count = 0
kmemleak: count = 0
kmemleak: flags = 0x1
kmemleak: checksum = 0
kmemleak: backtrace:
log_early+0x63/0x77
kmemleak_alloc+0x4b/0x50
init_section_page_cgroup+0x7f/0xf5
page_cgroup_init+0xc5/0xd0
start_kernel+0x333/0x408
x86_64_start_reservations+0x2a/0x2c
x86_64_start_kernel+0xf5/0xfc
Fixes: ff7ee93f4715 (cgroup/kmemleak: Annotate alloc_page() for cgroup allocations)
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
commit 90a646c770c50cc206ceba0d7b50453c46c13c36 upstream.
This commit fixes the following oops:
[10238.622067] scsi host3: uas_eh_bus_reset_handler start
[10240.766164] usb 3-4: reset SuperSpeed USB device number 3 using xhci_hcd
[10245.779365] usb 3-4: device descriptor read/8, error -110
[10245.883331] usb 3-4: reset SuperSpeed USB device number 3 using xhci_hcd
[10250.897603] usb 3-4: device descriptor read/8, error -110
[10251.058200] BUG: unable to handle kernel NULL pointer dereference at 0000000000000040
[10251.058244] IP: [<ffffffff815ac6e1>] xhci_check_streams_endpoint+0x91/0x140
<snip>
[10251.059473] Call Trace:
[10251.059487] [<ffffffff815aca6c>] xhci_calculate_streams_and_bitmask+0xbc/0x130
[10251.059520] [<ffffffff815aeb5f>] xhci_alloc_streams+0x10f/0x5a0
[10251.059548] [<ffffffff810a4685>] ? check_preempt_curr+0x75/0xa0
[10251.059575] [<ffffffff810a46dc>] ? ttwu_do_wakeup+0x2c/0x100
[10251.059601] [<ffffffff810a49e6>] ? ttwu_do_activate.constprop.111+0x66/0x70
[10251.059635] [<ffffffff815779ab>] usb_alloc_streams+0xab/0xf0
[10251.059662] [<ffffffffc0616b48>] uas_configure_endpoints+0x128/0x150 [uas]
[10251.059694] [<ffffffffc0616bac>] uas_post_reset+0x3c/0xb0 [uas]
[10251.059722] [<ffffffff815727d9>] usb_reset_device+0x1b9/0x2a0
[10251.059749] [<ffffffffc0616f42>] uas_eh_bus_reset_handler+0xb2/0x190 [uas]
[10251.059781] [<ffffffff81514293>] scsi_try_bus_reset+0x53/0x110
[10251.059808] [<ffffffff815163b7>] scsi_eh_bus_reset+0xf7/0x270
<snip>
The problem is the following call sequence (simplified):
1) usb_reset_device
2) usb_reset_and_verify_device
2) hub_port_init
3) hub_port_finish_reset
3) xhci_discover_or_reset_device
This frees xhci->devs[slot_id]->eps[ep_index].ring for all eps but 0
4) usb_get_device_descriptor
This fails
5) hub_port_init fails
6) usb_reset_and_verify_device fails, does not restore device config
7) uas_post_reset
8) xhci_alloc_streams
NULL deref on the free-ed ring
This commit fixes this by not allowing usb_alloc_streams to continue if
the device is not configured.
Note that we do allow usb_free_streams to continue after a (logical)
disconnect, as it is necessary to explicitly free the streams at the xhci
controller level.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit e681286de221af78fc85db9222b6a203148c005a upstream.
Write may be called from interrupt context so make sure to use
GFP_ATOMIC for all allocations in write.
Fixes: 0d930e51cfe6 ("USB: opticon: Add Opticon OPN2001 write support")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 93c9bf4d1838d5851a18ca398b0ad66397f05056 upstream.
Sometimes mass-storage devices using the Bulk-only transport will
mistakenly skip the data phase of a command. Rather than sending the
data expected by the host or sending a zero-length packet, they go
directly to the status phase and send the CSW.
This causes problems for usb-storage, for obvious reasons. The driver
will interpret the CSW as a short data transfer and will wait to
receive a CSW. The device won't have anything left to send, so the
command eventually times out.
The SCSI layer doesn't retry commands after they time out (this is a
relatively recent change). Therefore we should do our best to detect
a skipped data phase and handle it promptly.
This patch adds code to do that. If usb-storage receives a short
13-byte data transfer from the device, and if the first four bytes of
the data match the CSW signature, the driver will set the residue to
the full transfer length and interpret the data as a CSW.
This fixes Bugzilla #86611.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Tested-by: Paul Osmialowski <newchief@king.net.pl>
commit 2b9375b91bef65b837bed61a05fb387159b38ddf upstream.
If PM_RUNTIME is enabled, it is easy to trigger the following backtrace
on pxa2xx hosts:
WARNING: CPU: 0 PID: 1 at /home/lumag/linux/arch/arm/mach-pxa/clock.c:35 clk_disable+0xa0/0xa8()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 3.17.0-00007-g1b3d2ee-dirty #104
[<c000de68>] (unwind_backtrace) from [<c000c078>] (show_stack+0x10/0x14)
[<c000c078>] (show_stack) from [<c001d75c>] (warn_slowpath_common+0x6c/0x8c)
[<c001d75c>] (warn_slowpath_common) from [<c001d818>] (warn_slowpath_null+0x1c/0x24)
[<c001d818>] (warn_slowpath_null) from [<c0015e80>] (clk_disable+0xa0/0xa8)
[<c0015e80>] (clk_disable) from [<c02507f8>] (pxa2xx_spi_suspend+0x2c/0x34)
[<c02507f8>] (pxa2xx_spi_suspend) from [<c0200360>] (platform_pm_suspend+0x2c/0x54)
[<c0200360>] (platform_pm_suspend) from [<c0207fec>] (dpm_run_callback.isra.14+0x2c/0x74)
[<c0207fec>] (dpm_run_callback.isra.14) from [<c0209254>] (__device_suspend+0x120/0x2f8)
[<c0209254>] (__device_suspend) from [<c0209a94>] (dpm_suspend+0x50/0x208)
[<c0209a94>] (dpm_suspend) from [<c00455ac>] (suspend_devices_and_enter+0x8c/0x3a0)
[<c00455ac>] (suspend_devices_and_enter) from [<c0045ad4>] (pm_suspend+0x214/0x2a8)
[<c0045ad4>] (pm_suspend) from [<c04b5c34>] (test_suspend+0x14c/0x1dc)
[<c04b5c34>] (test_suspend) from [<c000880c>] (do_one_initcall+0x8c/0x1fc)
[<c000880c>] (do_one_initcall) from [<c04aecfc>] (kernel_init_freeable+0xf4/0x1b4)
[<c04aecfc>] (kernel_init_freeable) from [<c0378078>] (kernel_init+0x8/0xec)
[<c0378078>] (kernel_init) from [<c0009590>] (ret_from_fork+0x14/0x24)
---[ end trace 46524156d8faa4f6 ]---
This happens because suspend function tries to disable a clock that is
already disabled by runtime_suspend callback. Add if
(!pm_runtime_suspended()) checks to suspend/resume path.
Fixes: 7d94a505858 (spi/pxa2xx: add support for runtime PM)
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Reported-by: Andrea Adami <andrea.adami@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 3ffa6158f002e096d28ede71be4e0ee8ab20baa2 upstream.
When mapped RX DMA entries are unmapped in an error condition when DMA
is firstly configured in the driver, the number of TX DMA entries was
passed in, which is incorrect
Signed-off-by: Ray Jui <rjui@broadcom.com>
commit 1200a82a59b6aa65758ccc92c3447b98c53cd7a2 upstream.
On ISOC endpoints the last trb_pool entry used as a
LINK TRB is not getting zeroed out correctly due to
memset being called incorrectly and in the wrong place.
If pool allocated from DMA was not zero-initialized
to begin with this will result in the size and ctrl
values being random garbage. Call memset correctly after
assignment of the trb_link pointer.
Fixes: f6bafc6a1c ("usb: dwc3: convert TRBs into bitshifts")
Signed-off-by: Jack Pham <jackp@codeaurora.org>
commit 664d6a792785cc677c2091038ce10322c8d04ae1 upstream.
0x1b75 0xa200 AirLive WN-200USB wireless 11b/g/n dongle
References: https://bugs.debian.org/766802
Reported-by: Martin Mokrejs <mmokrejs@fold.natur.cuni.cz>
Signed-off-by: Cyril Brulebois <kibi@debian.org>
Acked-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 012eee1522318b5ccd64d277d50ac32f7e9974fe upstream.
Port layout:
0: QCDM/DIAG
1: NMEA
2: AT
3: AT/PPP
Signed-off-by: Dan Williams <dcbw@redhat.com>
commit 2d0eb862dd477c3c4f32b201254ca0b40e6f465c upstream.
Add VID/PID for Telit LE910 modem. Interfaces description is almost the
same than LE920, except that the qmi interface is number 2 (instead than
5).
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
commit 4473d054ceb572557954f9536731d39b20937b0c upstream.
Make sure to only raise DTR on transitions from B0 in set_termios.
Also allow set_termios to be called from open with a termios_old of
NULL. Note that DTR will not be raised prematurely in this case.
commit cf84a691a61606a2e7269907d3727e2d9fa148ee upstream.
Add device-id entry for GW Instek AFG-2225, which has a byte swapped
bInterfaceSubClass (0x20).
Reported-by: Karl Palsson <karlp@tweak.net.au>
commit 7f2719f0003da1ad13124ef00f48d7514c79e30d upstream.
An official recent Windows driver from FTDI detects counterfeit devices
and reprograms the internal EEPROM containing the USB PID to 0, effectively
bricking the device.
Add support for this VID/PID pair to correctly bind the driver on these
devices.
See:
http://hackaday.com/2014/10/22/watch-that-windows-update-ftdi-drivers-are-killing-fake-chips/
Signed-off-by: Perry Hung <iperry@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit edd74ffab1f6909eee400c7de8ce621870aacac9 upstream.
Add new IDs for the Xsens Awinda Station and Awinda Dongle.
While at it, order the definitions by PID and add a logical separation
between devices using Xsens' VID and those using FTDI's VID.
Signed-off-by: Frans Klaver <frans.klaver@xsens.com>
commit 35cc83eab097e5720a9cc0ec12bdc3a726f58381 upstream.
Enable Silicon Labs Ember VID chips to enumerate with the cp210x usb serial
driver. EM358x devices operating with the Ember Z-Net 5.1.2 stack may now
connect to host PCs over a USB serial link.
Signed-off-by: Nathaniel Ting <nathaniel.ting@silabs.com>
commit 547039ec502076e60034eeb79611df3433a99b7d upstream.
uart_get_baud_rate() will return baud == 0 if the max rate is set
to the "magic" 38400 rate and the SPD_* flags are also specified.
On the first iteration, if the current baud rate is higher than the
max, the baud rate is clamped at the max (which in the degenerate
case is 38400). On the second iteration, the now-"magic" 38400 baud
rate selects the possibly higher alternate baud rate indicated by
the SPD_* flag. Since only two loop iterations are performed, the
loop is exited, a kernel WARNING is generated and a baud rate of
0 is returned.
Reproducible with:
setserial /dev/ttyS0 spd_hi base_baud 38400
Only perform the "magic" 38400 -> SPD_* baud transform on the first
loop iteration, which prevents the degenerate case from recognizing
the clamped baud rate as the "magic" 38400 value.
Reported-by: Robert Święcki <robert@swiecki.net>
commit b598aacc29331e7e638cd509108600e916c6331b upstream.
"raw" is a property of a channel, but should not be part of the name of
channel.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 79fa64eb2ee8ccb4bcad7f54caa2699730b10b22 upstream.
We should check if a channel is enabled, not if no channels are enabled.
Fixes: 550268ca1111 ("staging:iio: scrap scan_count and ensure all drivers use active_scan_mask")
commit e10554738cab4224e097c2f9d975ea781a4fcde4 upstream.
In older versions of the IIO framework it was possible to pass a completely
different set of channels to iio_buffer_register() as the one that is
assigned to the IIO device. Commit 959d2952d124 ("staging:iio: make
iio_sw_buffer_preenable much more general.") introduced a restriction that
requires that the set of channels that is passed to iio_buffer_register() is
a subset of the channels assigned to the IIO device as the IIO core will use
the list of channels that is assigned to the device to lookup a channel by
scan index in iio_compute_scan_bytes(). If it can not find the channel the
function will crash. This patch fixes the issue by making sure that the same
set of channels is assigned to the IIO device and passed to
iio_buffer_register().
Note that we need to remove the IIO_CHAN_INFO_RAW and IIO_CHAN_INFO_SCALE
info attributes from the channels since we don't actually want those to be
registered.
Fixes the following crash:
Unable to handle kernel NULL pointer dereference at virtual address 00000016
pgd = d2094000
[00000016] *pgd=16e39831, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 1 PID: 1695 Comm: bash Not tainted 3.17.0-06329-g29461ee #9686
task: d7768040 ti: d5bd4000 task.ti: d5bd4000
PC is at iio_compute_scan_bytes+0x38/0xc0
LR is at iio_compute_scan_bytes+0x34/0xc0
pc : [<c0316de8>] lr : [<c0316de4>] psr: 60070013
sp : d5bd5ec0 ip : 00000000 fp : 00000000
r10: d769f934 r9 : 00000000 r8 : 00000001
r7 : 00000000 r6 : c8fc6240 r5 : d769f800 r4 : 00000000
r3 : d769f800 r2 : 00000000 r1 : ffffffff r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 18c5387d Table: 1209404a DAC: 00000015
Process bash (pid: 1695, stack limit = 0xd5bd4240)
Stack: (0xd5bd5ec0 to 0xd5bd6000)
5ec0: d769f800 d7435640 c8fc6240 d769f984 00000000 c03175a4 d7435690 d7435640
5ee0: d769f990 00000002 00000000 d769f800 d5bd4000 00000000 000b43a8 c03177f4
5f00: d769f810 0162b8c8 00000002 c8fc7e00 d77f1d08 d77f1da8 c8fc7e00 c01faf1c
5f20: 00000002 c010694c c010690c d5bd5f88 00000002 c8fc6840 c8fc684c c0105e08
5f40: 00000000 00000000 d20d1580 00000002 000af408 d5bd5f88 c000de84 c00b76d4
5f60: d20d1580 000af408 00000002 d20d1580 d20d1580 00000002 000af408 c000de84
5f80: 00000000 c00b7a44 00000000 00000000 00000002 b6ebea78 00000002 000af408
5fa0: 00000004 c000dd00 b6ebea78 00000002 00000001 000af408 00000002 00000000
5fc0: b6ebea78 00000002 000af408 00000004 bee96a4c 000a6094 00000000 000b43a8
5fe0: 00000000 bee969cc b6e2eb77 b6e6525c 40070010 00000001 00000000 00000000
[<c0316de8>] (iio_compute_scan_bytes) from [<c03175a4>] (__iio_update_buffers+0x248/0x438)
[<c03175a4>] (__iio_update_buffers) from [<c03177f4>] (iio_buffer_store_enable+0x60/0x7c)
[<c03177f4>] (iio_buffer_store_enable) from [<c01faf1c>] (dev_attr_store+0x18/0x24)
[<c01faf1c>] (dev_attr_store) from [<c010694c>] (sysfs_kf_write+0x40/0x4c)
[<c010694c>] (sysfs_kf_write) from [<c0105e08>] (kernfs_fop_write+0x110/0x154)
[<c0105e08>] (kernfs_fop_write) from [<c00b76d4>] (vfs_write+0xbc/0x170)
[<c00b76d4>] (vfs_write) from [<c00b7a44>] (SyS_write+0x40/0x78)
[<c00b7a44>] (SyS_write) from [<c000dd00>] (ret_fast_syscall+0x0/0x30)
Fixes: 959d2952d124 ("staging:iio: make iio_sw_buffer_preenable much more general.")
commit 6822ee34ad57b29a3b44df2c2829910f03c34fa4 upstream.
"raw" is the name of a channel property, but should not be part of the
channel name itself.
commit 824269c5868d2a7a26417e5ef3841a27d42c6139 upstream.
completely different set of channels to iio_buffer_register() as the one
that is assigned to the IIO device. Commit 959d2952d124 ("staging:iio: make
Fixes the follow NULL pointer derefernce kernel crash:
pgd = d53d0000
[00000016] *pgd=1534e831, *pte=00000000, *ppte=00000000
Modules linked in:
CPU: 1 PID: 1626 Comm: bash Not tainted 3.15.0-19969-g2a180eb-dirty #9545
task: d6c124c0 ti: d539a000 task.ti: d539a000
PC is at iio_compute_scan_bytes+0x34/0xa8
LR is at iio_compute_scan_bytes+0x34/0xa8
pc : [<c03052e4>] lr : [<c03052e4>] psr: 60070013
sp : d539beb8 ip : 00000001 fp : 00000000
r10: 00000002 r9 : 00000000 r8 : 00000001
r7 : 00000000 r6 : d6dc8800 r5 : d7571000 r4 : 00000002
r3 : d7571000 r2 : 00000044 r1 : 00000001 r0 : 00000000
Control: 18c5387d Table: 153d004a DAC: 00000015
Process bash (pid: 1626, stack limit = 0xd539a240)
Stack: (0xd539beb8 to 0xd539c000)
bea0: c02fc0e4 d7571000
bec0: d76c1640 d6dc8800 d757117c 00000000 d757112c c0305b04 d76c1690 d76c1640
bee0: d7571188 00000002 00000000 d7571000 d539a000 00000000 000dd1c8 c0305d54
bf00: d7571010 0160b868 00000002 c69d3900 d7573278 d7573308 c69d3900 c01ece90
bf20: 00000002 c0103fac c0103f6c d539bf88 00000002 c69d3b00 c69d3b0c c0103468
bf40: 00000000 00000000 d7694a00 00000002 000af408 d539bf88 c000dd84 c00b2f94
bf60: d7694a00 000af408 00000002 d7694a00 d7694a00 00000002 000af408 c000dd84
bf80: 00000000 c00b32d0 00000000 00000000 00000002 b6f1aa78 00000002 000af408
bfa0: 00000004 c000dc00 b6f1aa78 00000002 00000001 000af408 00000002 00000000
bfc0: b6f1aa78 00000002 000af408 00000004 be806a4c 000a6094 00000000 000dd1c8
bfe0: 00000000 be8069cc b6e8ab77 b6ec125c 40070010 00000001 22940489 154a5007
[<c03052e4>] (iio_compute_scan_bytes) from [<c0305b04>] (__iio_update_buffers+0x248/0x438)
[<c0305b04>] (__iio_update_buffers) from [<c0305d54>] (iio_buffer_store_enable+0x60/0x7c)
[<c0305d54>] (iio_buffer_store_enable) from [<c01ece90>] (dev_attr_store+0x18/0x24)
[<c01ece90>] (dev_attr_store) from [<c0103fac>] (sysfs_kf_write+0x40/0x4c)
[<c0103fac>] (sysfs_kf_write) from [<c0103468>] (kernfs_fop_write+0x110/0x154)
[<c0103468>] (kernfs_fop_write) from [<c00b2f94>] (vfs_write+0xd0/0x160)
[<c00b2f94>] (vfs_write) from [<c00b32d0>] (SyS_write+0x40/0x78)
[<c00b32d0>] (SyS_write) from [<c000dc00>] (ret_fast_syscall+0x0/0x30)
Code: ea00000e e1a01008 e1a00005 ebfff6fc (e5d0a016)
commit 5695be142e203167e3cb515ef86a88424f3524eb upstream.
PM freezer relies on having all tasks frozen by the time devices are
getting frozen so that no task will touch them while they are getting
frozen. But OOM killer is allowed to kill an already frozen task in
order to handle OOM situtation. In order to protect from late wake ups
OOM killer is disabled after all tasks are frozen. This, however, still
keeps a window open when a killed task didn't manage to die by the time
freeze_processes finishes.
Reduce the race window by checking all tasks after OOM killer has been
disabled. This is still not race free completely unfortunately because
oom_killer_disable cannot stop an already ongoing OOM killer so a task
might still wake up from the fridge and get killed without
freeze_processes noticing. Full synchronization of OOM and freezer is,
however, too heavy weight for this highly unlikely case.
Introduce and check oom_kills counter which gets incremented early when
the allocator enters __alloc_pages_may_oom path and only check all the
tasks if the counter changes during the freezing attempt. The counter
is updated so early to reduce the race window since allocator checked
oom_killer_disabled which is set by PM-freezing code. A false positive
will push the PM-freezer into a slow path but that is not a big deal.
Changes since v1
- push the re-check loop out of freeze_processes into
check_frozen_processes and invert the condition to make the code more
readable as per Rafael
Fixes: f660daac474c6f (oom: thaw threads if oom killed thread is frozen before deferring)
