2013-05-24Linux 3.4.47v3.4.47Greg Kroah-Hartman
2013-05-24media: mantis: fix silly crash caseAlan Cox
commit e1d45ae10aea8e8a403e5d96bf5902ee670007ff upstream. If we set mantis->fe to NULL on an error its not a good idea to then try passing NULL to the unregister paths and oopsing really. Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=16473 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24drm/radeon: Fix VRAM size calculation for VRAM >= 4GBNiels Ole Salscheider
commit fc986034540102cd090237bf3f70262e1ae80d9c upstream. Add ULL prefix to avoid overflow. Signed-off-by: Niels Ole Salscheider <niels_ole@salscheider-online.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24i2c: designware: always clear interrupts before enabling themMika Westerberg
commit 2a2d95e9d6d29e726cc294b65391917ed2e32bf4 upstream. If the I2C bus is put to a low power state by an ACPI method it might pull the SDA line low (as its power is removed). Once the bus is put to full power state again, the SDA line is pulled back to high. This transition looks like a STOP condition from the controller point-of-view which sets STOP detected bit in its status register causing the driver to fail subsequent transfers. Fix this by always clearing all interrupts before we start a transfer. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24hwmon: fix error return code in abituguru_probe()Wei Yongjun
commit ecacb0b17c08fae89f65468727f0e4b8e91da4e1 upstream. Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24btrfs: don't stop searching after encountering the wrong itemGabriel de Perthuis
commit 03b71c6ca6286625d8f1ed44aabab9b5bf5dac10 upstream. The search ioctl skips items that are too large for a result buffer, but inline items of a certain size occuring before any search result is found would trigger an overflow and stop the search entirely. Bug: https://bugzilla.kernel.org/show_bug.cgi?id=57641 Signed-off-by: Gabriel de Perthuis <g2p.code+btrfs@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19Linux 3.4.46v3.4.46Greg Kroah-Hartman
2013-05-19usermodehelper: check subprocess_info->path != NULLOleg Nesterov
commit 264b83c07a84223f0efd0d1db9ccc66d6f88288f upstream. argv_split(empty_or_all_spaces) happily succeeds, it simply returns argc == 0 and argv[0] == NULL. Change call_usermodehelper_exec() to check sub_info->path != NULL to avoid the crash. This is the minimal fix, todo: - perhaps we should change argv_split() to return NULL or change the callers. - kill or justify ->path[0] check - narrow the scope of helper_lock() Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-By: Lucas De Marchi <lucas.demarchi@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drm/radeon: check incoming cliprects pointerKees Cook
commit fefaedcfb82d2e57c2320acf60604ab03b750cc0 upstream. The "boxes" parameter points into userspace memory. It should be verified like any other operation against user memory. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ipmi: ipmi_devintf: compat_ioctl method fails to take ipmi_mutexBenjamin LaHaise
commit 6368087e851e697679af059b4247aca33a69cef3 upstream. When a 32 bit version of ipmitool is used on a 64 bit kernel, the ipmi_devintf code fails to correctly acquire ipmi_mutex. This results in incomplete data being retrieved in some cases, or other possible failures. Add a wrapper around compat_ipmi_ioctl() to take ipmi_mutex to fix this. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drivers/char/ipmi: memcpy, need additional 2 bytes to avoid memory overflowChen Gang
commit a5f2b3d6a738e7d4180012fe7b541172f8c8dcea upstream. When calling memcpy, read_data and write_data need additional 2 bytes. write_data: for checking: "if (size > IPMI_MAX_MSG_LENGTH)" for operating: "memcpy(bt->write_data + 3, data + 1, size - 1)" read_data: for checking: "if (msg_len < 3 || msg_len > IPMI_MAX_MSG_LENGTH)" for operating: "memcpy(data + 2, bt->read_data + 4, msg_len - 2)" Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ACPI / EC: Restart transaction even when the IBF flag setLan Tianyu
commit 28fe5c825f8e15744d04c7c1b8df197950923ecd upstream. The EC driver works abnormally with IBF flag always set. IBF means "The host has written a byte of data to the command or data port, but the embedded controller has not yet read it". If IBF is set in the EC status and not cleared, this will cause all subsequent EC requests to fail with a timeout error. Change the EC driver so that it doesn't refuse to restart a transaction if IBF is set in the status. Also increase the number of transaction restarts to 5, as it turns out that 2 is not sufficient in some cases. This bug happens on several different machines (Asus V1S, Dell Latitude E6530, Samsung R719, Acer Aspire 5930G, Sony Vaio SR19VN and others). [rjw: Changelog] References: https://bugzilla.kernel.org/show_bug.cgi?id=14733 References: https://bugzilla.kernel.org/show_bug.cgi?id=15560 References: https://bugzilla.kernel.org/show_bug.cgi?id=15946 References: https://bugzilla.kernel.org/show_bug.cgi?id=42945 References: https://bugzilla.kernel.org/show_bug.cgi?id=48221 Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19iscsi-target: Fix processing of OOO commandsShlomo Pongratz
commit 3eccfdb01da58fbd0f789ae6ca61cee3769e26de upstream. Fix two issues in OOO commands processing done at iscsit_attach_ooo_cmdsn. Handle command serial numbers wrap around by using iscsi_sna_lt and not regular comparisson. The routine iterates until it finds an entry whose serial number is greater than the serial number of the new one, thus the new entry should be inserted before that entry and not after. Signed-off-by: Shlomo Pongratz <shlomop@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drivers/rtc/rtc-pcf2123.c: fix error return code in pcf2123_probe()Wei Yongjun
commit 35623715818dfa720cccf99cd280dcbb4b78da23 upstream. Fix to return -ENODEV in the chip not found error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drbd: fix for deadlock when using automatic split-brain-recoveryPhilipp Reisner
commit 7c689e63a847316c1b2500f86891b0a574ce7e69 upstream. With an automatic after split-brain recovery policy of "after-sb-1pri call-pri-lost-after-sb", when trying to drbd_set_role() to R_SECONDARY, we run into a deadlock. This was first recognized and supposedly fixed by 2009-06-10 "Fixed a deadlock when using automatic split brain recovery when both nodes are" replacing drbd_set_role() with drbd_change_state() in that code-path, but the first hunk of that patch forgets to remove the drbd_set_role(). We apparently only ever tested the "two primaries" case. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19r8169: fix vlan tag read ordering.Francois Romieu
commit ce11ff5e5963e441feb591e76278528f876c332d upstream. Control of receive descriptor must not be returned to ethernet chipset before vlan tag processing is done. VLAN tag receive word is now reset both in normal and error path. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Spotted-by: Timo Teras <timo.teras@iki.fi> Cc: Hayes Wang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19hugetlbfs: fix mmap failure in unaligned size requestNaoya Horiguchi
commit af73e4d9506d3b797509f3c030e7dcd554f7d9c4 upstream. The current kernel returns -EINVAL unless a given mmap length is "almost" hugepage aligned. This is because in sys_mmap_pgoff() the given length is passed to vm_mmap_pgoff() as it is without being aligned with hugepage boundary. This is a regression introduced in commit 40716e29243d ("hugetlbfs: fix alignment of huge page requests"), where alignment code is pushed into hugetlb_file_setup() and the variable len in caller side is not changed. To fix this, this patch partially reverts that commit, and adds alignment code in caller side. And it also introduces hstate_sizelog() in order to get proper hstate to specified hugepage size. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=56881 [akpm@linux-foundation.org: fix warning when CONFIG_HUGETLB_PAGE=n] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: <iceman_dvd@yahoo.com> Cc: Steven Truelove <steven.truelove@utoronto.ca> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19pch_dma: Use GFP_ATOMIC because called from interrupt contextTomoya MORINAGA
commit 5c1ef59168c485318e40ba485c1eba57d81d0faa upstream. pdc_desc_get() is called from pd_prep_slave_sg, and the function is called from interrupt context(e.g. Uart driver "pch_uart.c"). In fact, I saw kernel error message. So, GFP_ATOMIC must be used not GFP_NOIO. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19dm thin: do not set discard_zeroes_dataMike Snitzer
commit 307615a26e95406c42c95916a66ba50434567e0f upstream. The dm thin pool target claims to support the zeroing of discarded data areas. This turns out to be incorrect when processing discards that do not exactly cover a complete number of blocks, so the target must always set discard_zeroes_data_unsupported. The thin pool target will zero blocks when they are allocated if the skip_block_zeroing feature is not specified. The block layer may send a discard that only partly covers a block. If a thin pool block is partially discarded then there is no guarantee that the discarded data will get zeroed before it is accessed again. Due to this, thin devices cannot claim discards will always zero data. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Libo Chen <libo.chen@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19xfrm6: release dev before returning errorCong Wang
[ Upstream commit 84c4a9dfbf430861e7588d95ae3ff61535dca351 ] We forget to call dev_put() on error path in xfrm6_fill_dst(), its caller doesn't handle this. Signed-off-by: Cong Wang <amwang@redhat.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ipv6: do not clear pinet6 fieldEric Dumazet
[ Upstream commit f77d602124d865c38705df7fa25c03de9c284ad2 ] We have seen multiple NULL dereferences in __inet6_lookup_established() After analysis, I found that inet6_sk() could be NULL while the check for sk_family == AF_INET6 was true. Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP and TCP stacks. Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash table, we no longer can clear pinet6 field. This patch extends logic used in commit fcbdf09d9652c891 ("net: fix nulls list corruptions in sk_prot_alloc") TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method to make sure we do not clear pinet6 field. At socket clone phase, we do not really care, as cloning the parent (non NULL) pinet6 is not adding a fatal race. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19macvlan: fix passthru mode race between dev removal and rx pathJiri Pirko
[ Upstream commit 233c7df0821c4190e2d3f4be0f2ca0ab40a5ed8c, note that I had to add list_first_or_null_rcu to rculist.h in order to accomodate this fix. ] Currently, if macvlan in passthru mode is created and data are rxed and you remove this device, following panic happens: NULL pointer dereference at 0000000000000198 IP: [<ffffffffa0196058>] macvlan_handle_frame+0x153/0x1f7 [macvlan] I'm using following script to trigger this: <script> while [ 1 ] do ip link add link e1 name macvtap0 type macvtap mode passthru ip link set e1 up ip link set macvtap0 up IFINDEX=`ip link |grep macvtap0 | cut -f 1 -d ':'` cat /dev/tap$IFINDEX >/dev/null & ip link del dev macvtap0 done </script> I run this script while "ping -f" is running on another machine to send packets to e1 rx. Reason of the panic is that list_first_entry() is blindly called in macvlan_handle_frame() even if the list was empty. vlan is set to incorrect pointer which leads to the crash. I'm fixing this by protecting port->vlans list by rcu and by preventing from getting incorrect pointer in case the list is empty. Introduced by: commit eb06acdc85585f2 "macvlan: Introduce 'passthru' mode to takeover the underlying device" Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19if_cablemodem.h: Add parenthesis around ioctl macrosJosh Boyer
[ Upstream commit 4f924b2aa4d3cb30f07e57d6b608838edcbc0d88 ] Protect the SIOCGCM* ioctl macros with parenthesis. Reported-by: Paul Wouters <pwouters@redhat.com> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-193c59x: fix PCI resource managementSergei Shtylyov
[ Upstream commit 4b264a1676e70dc656ba53a8cac690f2d4b65f4e ] The driver wrongly claimed I/O ports at an address returned by pci_iomap() -- even if it was passed an MMIO address. Fix this by claiming/releasing all PCI resources in the PCI driver's probe()/remove() methods instead and get rid of 'must_free_region' flag weirdness (why would Cardbus claim anything for us?). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-193c59x: fix freeing nonexistent resource on driver unloadSergei Shtylyov
[ Upstream commit c81400be716aa4c76f6ebf339ba94358dbbf6da6 ] When unloading the driver that drives an EISA board, a message similar to the following one is displayed: Trying to free nonexistent resource <0000000000013000-000000000001301f> Then an user is unable to reload the driver because the resource it requested in the previous load hasn't been freed. This happens most probably due to a typo in vortex_eisa_remove() which calls release_region() with 'dev->base_addr' instead of 'edev->base_addr'... Reported-by: Matthew Whitehead <tedheadster@gmail.com> Tested-by: Matthew Whitehead <tedheadster@gmail.com> Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19packet: tpacket_v3: do not trigger bug() on wrong header statusDaniel Borkmann
[ Upstream commit 8da3056c04bfc5f69f840ab038a38389e2de8189 ] Jakub reported that it is fairly easy to trigger the BUG() macro from user space with TPACKET_V3's RX_RING by just giving a wrong header status flag. We already had a similar situation in commit 7f5c3e3a80e6654 (``af_packet: remove BUG statement in tpacket_destruct_skb'') where this was the case in the TX_RING side that could be triggered from user space. So really, don't use BUG() or BUG_ON() unless there's really no way out, and i.e. don't use it for consistency checking when there's user space involved, no excuses, especially not if you're slapping the user with WARN + dump_stack + BUG all at once. The two functions are of concern: prb_retire_current_block() [when block status != TP_STATUS_KERNEL] prb_open_block() [when block_status != TP_STATUS_KERNEL] Calls to prb_open_block() are guarded by ealier checks if block_status is really TP_STATUS_KERNEL (racy!), but the first one BUG() is easily triggable from user space. System behaves still stable after they are removed. Also remove that yoda condition entirely, since it's already guarded. Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19bridge: fix race with topology change timerstephen hemminger
[ Upstream commit 83401eb4990ff6af55aeed8f49681558544192e6 ] A bridge should only send topology change notice if it is not the root bridge. It is possible for message age timer to elect itself as a new root bridge, and still have a topology change timer running but waiting for bridge lock on other CPU. Solve the race by checking if we are root bridge before continuing. This was the root cause of the cases where br_send_tcn_bpdu would OOPS. Reported-by: JerryKang <jerry.kang@samsung.com> Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19net: vlan,ethtool: netdev_features_t is more than 32 bitBjørn Mork
[ Upstream commit b29d3145183da4e07d4b570fa8acdd3ac4a5c572 ] Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19net: use netdev_features_t in skb_needs_linearize()Patrick McHardy
[ Upstream commit 6708c9e5cc9bfc7c9a00ce9c0fdd0b1d4952b3d1 ] Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19net_sched: act_ipt forward compat with xtablesJamal Hadi Salim
[ Upstream commit 0dcffd09641f3abb21ac5cabc61542ab289d1a3c ] Deal with changes in newer xtables while maintaining backward compatibility. Thanks to Jan Engelhardt for suggestions. Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-193c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)Matthew Whitehead
[ Upstream commit 3b54912f9cd167641b91d4a697bd742f70e534fe ] The venerable 3c509 driver only sets its device parent in one case, the ISAPnP one. It does this with the SET_NETDEV_DEV function. It should register with the device hierarchy in two additional cases: standard (non-PnP) ISA and EISA. - Currently they appear here: /sys/devices/virtual/net/eth0 (standard ISA) /sys/devices/virtual/net/eth1 (EISA) - Rather, they should instead be here: /sys/devices/isa/3c509.0/net/eth0 (standard ISA) /sys/devices/pci0000:00/0000:00:07.0/00:04/net/eth1 (EISA) Tested on ISA and EISA boards. Signed-off-by: Matthew Whitehead <tedheadster@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19sfc: Fix naming of MTD partitions for FPGA bitfilesBen Hutchings
[ Upstream commit 89cc80a44b7c320e08599cb86f6aef0ead8986a1 ] efx_mcdi_get_board_cfg() uses a buffer for the firmware response that is only large enough to hold subtypes for the originally defined set of NVRAM partitions. Longer responses are truncated, and we may read off the end of the buffer when copying out subtypes for additional partitions. In particular, this can result in the MTD partition for an FPGA bitfile being named e.g. 'eth5 sfc_fpga:00' when it should be 'eth5 sfc_fpga:01'. This means the firmware update tool (sfupdate) can't tell which bitfile should be written to the partition. Correct the response buffer size. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19tcp: force a dst refcount when prequeue packetEric Dumazet
[ Upstream commit 093162553c33e9479283e107b4431378271c735d ] Before escaping RCU protected section and adding packet into prequeue, make sure the dst is refcounted. Reported-by: Mike Galbraith <bitbucket@online.de> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19net: qmi_wwan: prevent duplicate mac address on link (firmware bug workaround)Bjørn Mork
[ Upstream commit cc6ba5fdaabea7a7b28de3ba1e0fe54d92232fe5 ] We normally trust and use the CDC functional descriptors provided by a number of devices. But some of these will erroneously list the address reserved for the device end of the link. Attempting to use this on both the device and host side will naturally not work. Work around this bug by ignoring the functional descriptor and assign a random address instead in this case. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19net: qmi_wwan: fixup destination address (firmware bug workaround)Bjørn Mork
[ Upstream commit 6483bdc9d76fb98174797516a19d289eb837909e ] Received packets are sometimes addressed to 00:a0:c6:00:00:00 instead of the address the device firmware should have learned from the host: 321.224126 77.16.85.204 -> 148.122.171.134 ICMP 98 Echo (ping) request id=0x4025, seq=64/16384, ttl=64 0000 82 c0 82 c9 f1 67 82 c0 82 c9 f1 67 08 00 45 00 .....g.....g..E. 0010 00 54 00 00 40 00 40 01 57 cc 4d 10 55 cc 94 7a .T..@.@.W.M.U..z 0020 ab 86 08 00 62 fc 40 25 00 40 b2 bc 6e 51 00 00 ....b.@%.@..nQ.. 0030 00 00 6b bd 09 00 00 00 00 00 10 11 12 13 14 15 ..k............. 0040 16 17 18 19 1a 1b 1c 1d 1e 1f 20 21 22 23 24 25 .......... !"#$% 0050 26 27 28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35 &'()*+,-./012345 0060 36 37 67 321.240607 148.122.171.134 -> 77.16.85.204 ICMP 98 Echo (ping) reply id=0x4025, seq=64/16384, ttl=55 0000 00 a0 c6 00 00 00 02 50 f3 00 00 00 08 00 45 00 .......P......E. 0010 00 54 00 56 00 00 37 01 a0 76 94 7a ab 86 4d 10 .T.V..7..v.z..M. 0020 55 cc 00 00 6a fc 40 25 00 40 b2 bc 6e 51 00 00 U...j.@%.@..nQ.. 0030 00 00 6b bd 09 00 00 00 00 00 10 11 12 13 14 15 ..k............. 0040 16 17 18 19 1a 1b 1c 1d 1e 1f 20 21 22 23 24 25 .......... !"#$% 0050 26 27 28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35 &'()*+,-./012345 0060 36 37 67 The bogus address is always the same, and matches the address suggested by many devices as a default address. It is likely a hardcoded firmware default. The circumstances where this bug has been observed indicates that the trigger is related to timing or some other factor the host cannot control. Repeating the exact same configuration sequence that caused it to trigger once, will not necessarily cause it to trigger the next time. Reproducing the bug is therefore difficult. This opens up a possibility that the bug is more common than we can confirm, because affected devices often will work properly again after a reset. A procedure most users are likely to try out before reporting a bug. Unconditionally rewriting the destination address if the first digit of the received packet is 0, is considered an acceptable compromise since we already have to inspect this digit. The simplification will cause unnecessary rewrites if the real address starts with 0, but this is still better than adding additional tests for this particular case. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19net: qmi_wwan: fixup missing ethernet header (firmware bug workaround)Bjørn Mork
[ Upstream commit 6ff509af3869ccac69dcf8905fc75b9a76951594 ] A number of LTE devices from different vendors all suffer from the same firmware bug: Most of the packets received from the device while it is attached to a LTE network will not have an ethernet header. The devices work as expected when attached to 2G or 3G networks, sending an ethernet header with all packets. This driver is not aware of which network the modem attached to, and even if it were there are still some packet types which are always received with the header intact. All devices supported by this driver have severely limited networking capabilities: - can only transmit IPv4, IPv6 and possibly ARP - can only support a single host hardware address at any time - will only do point-to-point communcation with the host Because of this, we are able to reliably identify any bogus raw IP packets by simply looking at the 4 IP version bits. All we need to do is to avoid 4 or 6 in the first digit of the mac address. This workaround ensures this, and fix up the received packets as necessary. Given the distribution of the bug, it is believed that the source is the chipset vendor. The devices which are verified to be affected are: Huawei E392u-12 (Qualcomm MDM9200) Pantech UML290 (Qualcomm MDM9600) Novatel USB551L (Qualcomm MDM9600) Novatel E362 (Qualcomm MDM9600) It is believed that the bug depend on firmware revision, which means that possibly all devices based on the above mentioned chipset may be affected if we consider all available firmware revisions. The information about affected devices and versions is likely incomplete. As the additional overhead for packets not needing this fixup is very small, it is considered acceptable to apply the workaround to all devices handled by this driver. Reported-by: Dan Williams <dcbw@redhat.com> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drm/mm: fix dump table BUGDaniel Vetter
commit 3a359f0b21ab218c1bf7a6a1b638b6fd143d0b99 upstream. In commit 9e8944ab564f2e3dde90a518cd32048c58918608 Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Thu Nov 15 11:32:17 2012 +0000 drm: Introduce an iterator over holes in the drm_mm range manager helpers and iterators for hole handling have been introduced with some debug BUG_ONs sprinkled over. Unfortunately this broke the mm dumper which unconditionally tried to compute the size of the very first hole. While at it unify the code a bit with the hole dumping in the loop. v2: Extract a hole dump helper. Reported-by: Christopher Harvey <charvey@matrox.com> Cc: Christopher Harvey <charvey@matrox.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Acked-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19B43: Handle DMA RX descriptor underrunThommy Jakobsson
commit 73b82bf0bfbf58e6ff328d3726934370585f6e78 upstream. Add handling of rx descriptor underflow. This fixes a fault that could happen on slow machines, where data is received faster than the CPU can handle. In such a case the device will use up all rx descriptors and refuse to send any more data before confirming that it is ok. This patch enables necessary interrupt to discover such a situation and will handle them by dropping everything in the ring buffer. Reviewed-by: Michael Buesch <m@bues.ch> Signed-off-by: Thommy Jakobsson <thommyj@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19mwifiex: fix setting of multicast filterDaniel Drake
commit ccd384b10420ac81ba3fb9b0a7d18272c7173552 upstream. A small bug in this code was causing the ALLMULTI filter to be set when in fact we were just wanting to program a selective multicast list to the hardware. Fix that bug and remove a redundant if condition in the code that follows. This fixes wakeup behaviour when multicast WOL is enabled. Previously, all multicast packets would wake up the system. Now, only those that the host intended to receive trigger wakeups. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19mwifiex: clear is_suspended flag when interrupt is received earlyBing Zhao
commit 48795424acff7215d5eac0b52793a2c1eb3a6283 upstream. When the XO-4 with 8787 wireless is woken up due to wake-on-WLAN mwifiex is often flooded with "not allowed while suspended" messages and the interface is unusable. [ 202.171609] int: sdio_ireg = 0x1 [ 202.180700] info: mwifiex_process_hs_config: auto cancelling host sleep since there is interrupt from the firmware [ 202.201880] event: wakeup device... [ 202.211452] event: hs_deactivated [ 202.514638] info: --- Rx: Data packet --- [ 202.514753] data: 4294957544 BSS(0-0): Data <= kernel [ 202.514825] PREP_CMD: device in suspended state [ 202.514839] data: dequeuing the packet ec7248c0 ec4869c0 [ 202.514886] mwifiex_write_data_sync: not allowed while suspended [ 202.514886] host_to_card, write iomem (1) failed: -1 [ 202.514917] mwifiex_write_data_sync: not allowed while suspended [ 202.514936] host_to_card, write iomem (2) failed: -1 [ 202.514949] mwifiex_write_data_sync: not allowed while suspended [ 202.514965] host_to_card, write iomem (3) failed: -1 [ 202.514976] mwifiex_write_data_async failed: 0xFFFFFFFF This can be readily reproduced when putting the XO-4 in a loop where it goes to sleep due to inactivity, but then wakes up due to an incoming ping. The error is hit within an hour or two. This issue happens when an interrupt comes in early while host sleep is still activated. Driver handles this case by auto cancelling host sleep. However is_suspended flag is still set which prevents any cmd or data from being sent to firmware. Fix it by clearing is_suspended flag in this path. Reported-by: Daniel Drake <dsd@laptop.org> Tested-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ath9k: fix key allocation error handling for powersave keysFelix Fietkau
commit 4ef69d0394cba8caa9f75d3f2e53429bfb8b3045 upstream. If no keycache slots are available, ath_key_config can return -ENOSPC. If the key index is not checked for errors, it can lead to logspam that looks like this: "ath: wiphy0: keyreset: keycache entry 228 out of range" This can cause follow-up errors if the invalid keycache index gets used for tx. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19powerpc: Bring all threads online prior to migration/hibernationRobert Jennings
commit 120496ac2d2d60aee68d3123a68169502a85f4b5 upstream. This patch brings online all threads which are present but not online prior to migration/hibernation. After migration/hibernation those threads are taken back offline. During migration/hibernation all online CPUs must call H_JOIN, this is required by the hypervisor. Without this patch, threads that are offline (H_CEDE'd) will not be woken to make the H_JOIN call and the OS will be deadlocked (all threads either JOIN'd or CEDE'd). Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ext4: limit group search loop for non-extent filesLachlan McIlroy
commit e6155736ad76b2070652745f9e54cdea3f0d8567 upstream. In the case where we are allocating for a non-extent file, we must limit the groups we allocate from to those below 2^32 blocks, and ext4_mb_regular_allocator() attempts to do this initially by putting a cap on ngroups for the subsequent search loop. However, the initial target group comes in from the allocation context (ac), and it may already be beyond the artificially limited ngroups. In this case, the limit if (group == ngroups) group = 0; at the top of the loop is never true, and the loop will run away. Catch this case inside the loop and reset the search to start at group 0. [sandeen@redhat.com: add commit msg & comments] Signed-off-by: Lachlan McIlroy <lmcilroy@redhat.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19tracing: Fix leaks of filter predsSteven Rostedt (Red Hat)
commit 60705c89460fdc7227f2d153b68b3f34814738a4 upstream. Special preds are created when folding a series of preds that can be done in serial. These are allocated in an ops field of the pred structure. But they were never freed, causing memory leaks. This was discovered using the kmemleak checker: unreferenced object 0xffff8800797fd5e0 (size 32): comm "swapper/0", pid 1, jiffies 4294690605 (age 104.608s) hex dump (first 32 bytes): 00 00 01 00 03 00 05 00 07 00 09 00 0b 00 0d 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff814b52af>] kmemleak_alloc+0x73/0x98 [<ffffffff8111ff84>] kmemleak_alloc_recursive.constprop.42+0x16/0x18 [<ffffffff81120e68>] __kmalloc+0xd7/0x125 [<ffffffff810d47eb>] kcalloc.constprop.24+0x2d/0x2f [<ffffffff810d4896>] fold_pred_tree_cb+0xa9/0xf4 [<ffffffff810d3781>] walk_pred_tree+0x47/0xcc [<ffffffff810d5030>] replace_preds.isra.20+0x6f8/0x72f [<ffffffff810d50b5>] create_filter+0x4e/0x8b [<ffffffff81b1c30d>] ftrace_test_event_filter+0x5a/0x155 [<ffffffff8100028d>] do_one_initcall+0xa0/0x137 [<ffffffff81afbedf>] kernel_init_freeable+0x14d/0x1dc [<ffffffff814b24b7>] kernel_init+0xe/0xdb [<ffffffff814d539c>] ret_from_fork+0x7c/0xb0 [<ffffffffffffffff>] 0xffffffffffffffff Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19tick: Cleanup NOHZ per cpu data on cpu downThomas Gleixner
commit 4b0c0f294f60abcdd20994a8341a95c8ac5eeb96 upstream. Prarit reported a crash on CPU offline/online. The reason is that on CPU down the NOHZ related per cpu data of the dead cpu is not cleaned up. If at cpu online an interrupt happens before the per cpu tick device is registered the irq_enter() check potentially sees stale data and dereferences a NULL pointer. Cleanup the data after the cpu is dead. Reported-by: Prarit Bhargava <prarit@redhat.com> Cc: Mike Galbraith <bitbucket@online.de> Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1305031451561.2886@ionos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19timer: Don't reinitialize the cpu base lock during CPU_UP_PREPARETirupathi Reddy
commit 42a5cf46cd56f46267d2a9fcf2655f4078cd3042 upstream. An inactive timer's base can refer to a offline cpu's base. In the current code, cpu_base's lock is blindly reinitialized each time a CPU is brought up. If a CPU is brought online during the period that another thread is trying to modify an inactive timer on that CPU with holding its timer base lock, then the lock will be reinitialized under its feet. This leads to following SPIN_BUG(). <0> BUG: spinlock already unlocked on CPU#3, kworker/u:3/1466 <0> lock: 0xe3ebe000, .magic: dead4ead, .owner: kworker/u:3/1466, .owner_cpu: 1 <4> [<c0013dc4>] (unwind_backtrace+0x0/0x11c) from [<c026e794>] (do_raw_spin_unlock+0x40/0xcc) <4> [<c026e794>] (do_raw_spin_unlock+0x40/0xcc) from [<c076c160>] (_raw_spin_unlock+0x8/0x30) <4> [<c076c160>] (_raw_spin_unlock+0x8/0x30) from [<c009b858>] (mod_timer+0x294/0x310) <4> [<c009b858>] (mod_timer+0x294/0x310) from [<c00a5e04>] (queue_delayed_work_on+0x104/0x120) <4> [<c00a5e04>] (queue_delayed_work_on+0x104/0x120) from [<c04eae00>] (sdhci_msm_bus_voting+0x88/0x9c) <4> [<c04eae00>] (sdhci_msm_bus_voting+0x88/0x9c) from [<c04d8780>] (sdhci_disable+0x40/0x48) <4> [<c04d8780>] (sdhci_disable+0x40/0x48) from [<c04bf300>] (mmc_release_host+0x4c/0xb0) <4> [<c04bf300>] (mmc_release_host+0x4c/0xb0) from [<c04c7aac>] (mmc_sd_detect+0x90/0xfc) <4> [<c04c7aac>] (mmc_sd_detect+0x90/0xfc) from [<c04c2504>] (mmc_rescan+0x7c/0x2c4) <4> [<c04c2504>] (mmc_rescan+0x7c/0x2c4) from [<c00a6a7c>] (process_one_work+0x27c/0x484) <4> [<c00a6a7c>] (process_one_work+0x27c/0x484) from [<c00a6e94>] (worker_thread+0x210/0x3b0) <4> [<c00a6e94>] (worker_thread+0x210/0x3b0) from [<c00aad9c>] (kthread+0x80/0x8c) <4> [<c00aad9c>] (kthread+0x80/0x8c) from [<c000ea80>] (kernel_thread_exit+0x0/0x8) As an example, this particular crash occurred when CPU #3 is executing mod_timer() on an inactive timer whose base is refered to offlined CPU #2. The code locked the timer_base corresponding to CPU #2. Before it could proceed, CPU #2 came online and reinitialized the spinlock corresponding to its base. Thus now CPU #3 held a lock which was reinitialized. When CPU #3 finally ended up unlocking the old cpu_base corresponding to CPU #2, we hit the above SPIN_BUG(). CPU #0 CPU #3 CPU #2 ------ ------- ------- ..... ...... <Offline> mod_timer() lock_timer_base spin_lock_irqsave(&base->lock) cpu_up(2) ..... ...... init_timers_cpu() .... ..... spin_lock_init(&base->lock) ..... spin_unlock_irqrestore(&base->lock) ...... <spin_bug> Allocation of per_cpu timer vector bases is done only once under "tvec_base_done[]" check. In the current code, spinlock_initialization of base->lock isn't under this check. When a CPU is up each time the base lock is reinitialized. Move base spinlock initialization under the check. Signed-off-by: Tirupathi Reddy <tirupath@codeaurora.org> Link: http://lkml.kernel.org/r/1368520142-4136-1-git-send-email-tirupath@codeaurora.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19audit: Syscall rules are not applied to existing processes on non-x86Anton Blanchard
commit cdee3904b4ce7c03d1013ed6dd704b43ae7fc2e9 upstream. Commit b05d8447e782 (audit: inline audit_syscall_entry to reduce burden on archs) changed audit_syscall_entry to check for a dummy context before calling __audit_syscall_entry. Unfortunately the dummy context state is maintained in __audit_syscall_entry so once set it never gets cleared, even if the audit rules change. As a result, if there are no auditing rules when a process starts then it will never be subject to any rules added later. x86 doesn't see this because it has an assembly fast path that calls directly into __audit_syscall_entry. I noticed this issue when working on audit performance optimisations. I wrote a set of simple test cases available at: http://ozlabs.org/~anton/junkcode/audit_tests.tar.gz 02_new_rule.py fails without the patch and passes with it. The test case clears all rules, starts a process, adds a rule then verifies the process produces a syscall audit record. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19SCSI: sd: fix array cache flushing bug causing performance problemsJames Bottomley
commit 39c60a0948cc06139e2fbfe084f83cb7e7deae3b upstream. Some arrays synchronize their full non volatile cache when the sd driver sends a SYNCHRONIZE CACHE command. Unfortunately, they can have Terrabytes of this and we send a SYNCHRONIZE CACHE for every barrier if an array reports it has a writeback cache. This leads to massive slowdowns on journalled filesystems. The fix is to allow userspace to turn off the writeback cache setting as a temporary measure (i.e. without doing the MODE SELECT to write it back to the device), so even though the device reported it has a writeback cache, the user, knowing that the cache is non volatile and all they care about is filesystem correctness, can turn that bit off in the kernel and avoid the performance ruinous (and safety irrelevant) SYNCHRONIZE CACHE commands. The way you do this is add a 'temporary' prefix when performing the usual cache setting operations, so echo temporary write through > /sys/class/scsi_disk/<disk>/cache_type Reported-by: Ric Wheeler <rwheeler@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19xen/vcpu/pvhvm: Fix vcpu hotplugging hanging.Konrad Rzeszutek Wilk
commit 7f1fc268c47491fd5e63548f6415fc8604e13003 upstream. If a user did: echo 0 > /sys/devices/system/cpu/cpu1/online echo 1 > /sys/devices/system/cpu/cpu1/online we would (this a build with DEBUG enabled) get to: smpboot: ++++++++++++++++++++=_---CPU UP 1 .. snip.. smpboot: Stack at about ffff880074c0ff44 smpboot: CPU1: has booted. and hang. The RCU mechanism would kick in an try to IPI the CPU1 but the IPIs (and all other interrupts) would never arrive at the CPU1. At first glance at least. A bit digging in the hypervisor trace shows that (using xenanalyze): [vla] d4v1 vec 243 injecting 0.043163027 --|x d4v1 intr_window vec 243 src 5(vector) intr f3 ] 0.043163639 --|x d4v1 vmentry cycles 1468 ] 0.043164913 --|x d4v1 vmexit exit_reason PENDING_INTERRUPT eip ffffffff81673254 0.043164913 --|x d4v1 inj_virq vec 243 real [vla] d4v1 vec 243 injecting 0.043164913 --|x d4v1 intr_window vec 243 src 5(vector) intr f3 ] 0.043165526 --|x d4v1 vmentry cycles 1472 ] 0.043166800 --|x d4v1 vmexit exit_reason PENDING_INTERRUPT eip ffffffff81673254 0.043166800 --|x d4v1 inj_virq vec 243 real [vla] d4v1 vec 243 injecting there is a pending event (subsequent debugging shows it is the IPI from the VCPU0 when smpboot.c on VCPU1 has done "set_cpu_online(smp_processor_id(), true)") and the guest VCPU1 is interrupted with the callback IPI (0xf3 aka 243) which ends up calling __xen_evtchn_do_upcall. The __xen_evtchn_do_upcall seems to do *something* but not acknowledge the pending events. And the moment the guest does a 'cli' (that is the ffffffff81673254 in the log above) the hypervisor is invoked again to inject the IPI (0xf3) to tell the guest it has pending interrupts. This repeats itself forever. The culprit was the per_cpu(xen_vcpu, cpu) pointer. At the bootup we set each per_cpu(xen_vcpu, cpu) to point to the shared_info->vcpu_info[vcpu] but later on use the VCPUOP_register_vcpu_info to register per-CPU structures (xen_vcpu_setup). This is used to allow events for more than 32 VCPUs and for performance optimizations reasons. When the user performs the VCPU hotplug we end up calling the the xen_vcpu_setup once more. We make the hypercall which returns -EINVAL as it does not allow multiple registration calls (and already has re-assigned where the events are being set). We pick the fallback case and set per_cpu(xen_vcpu, cpu) to point to the shared_info->vcpu_info[vcpu] (which is a good fallback during bootup). However the hypervisor is still setting events in the register per-cpu structure (per_cpu(xen_vcpu_info, cpu)). As such when the events are set by the hypervisor (such as timer one), and when we iterate in __xen_evtchn_do_upcall we end up reading stale events from the shared_info->vcpu_info[vcpu] instead of the per_cpu(xen_vcpu_info, cpu) structures. Hence we never acknowledge the events that the hypervisor has set and the hypervisor keeps on reminding us to ack the events which we never do. The fix is simple. Don't on the second time when xen_vcpu_setup is called over-write the per_cpu(xen_vcpu, cpu) if it points to per_cpu(xen_vcpu_info). Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19hp_accel: Ignore the error from lis3lv02d_poweron() at resumeShuah Khan
commit 7783819920ca52fc582a2782f654fe6ed373f465 upstream. The error in lis3lv02_poweron() is harmless in the resume path, so we should ignore it. It is inline with the other usages of lis3lv02_poweron() and matches the 3.0 code for this routine. This patch is in suse git and might have missed making it into the mainline. opensuse - commit id: 66ccdac87c322cf7af12bddba8c805af640b1cff Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
