commit a4f46bb9fa84642e356898ee44b670989622f8bb upstream.
In the latest V-series bios DMI_PRODUCT_VERSION does not contain
the string Lenovo or Thinkpad, but is set to the model number, this
causes the thinkpad_acpi module to fail to load. Recognize laptop
as Lenovo using DMI_BIOS_VENDOR instead, which is set to Lenovo.
Test on V490u
== After the patch ==
[ 1350.295757] thinkpad_acpi: ThinkPad ACPI Extras v0.24
[ 1350.295760] thinkpad_acpi: http://ibm-acpi.sf.net/
[ 1350.295761] thinkpad_acpi: ThinkPad BIOS H7ET21WW (1.00 ), EC unknown
[ 1350.295763] thinkpad_acpi: Lenovo LENOVO, model LV5DXXX
[ 1350.296086] thinkpad_acpi: detected a 8-level brightness capable ThinkPad
[ 1350.296694] thinkpad_acpi: radio switch found; radios are enabled
[ 1350.296703] thinkpad_acpi: possible tablet mode switch found; ThinkPad in laptop mode
[ 1350.306466] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[ 1350.307082] Registered led device: tpacpi::thinklight
[ 1350.307215] Registered led device: tpacpi::power
[ 1350.307255] Registered led device: tpacpi::standby
[ 1350.307294] Registered led device: tpacpi::thinkvantage
[ 1350.308160] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one
[ 1350.308333] thinkpad_acpi: Console audio control enabled, mode: monitor (read only)
[ 1350.312287] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input14
== Before the patch ==
sudo modprobe thinkpad_acpi
FATAL: Error inserting thinkpad_acpi (/lib/modules/3.2.0-27-generic/kernel/drivers/platform/x86/thinkpad_acpi.ko): No such device
Test on B485
This patch was also test in a B485 where the thinkpad_acpi module does not
have any issues loading. But, I tested it to make sure this patch does not
break on already functioning models of Lenovo products.
[13486.746359] thinkpad_acpi: ThinkPad ACPI Extras v0.24
[13486.746364] thinkpad_acpi: http://ibm-acpi.sf.net/
[13486.746368] thinkpad_acpi: ThinkPad BIOS HJET15WW(1.01), EC unknown
[13486.746373] thinkpad_acpi: Lenovo Lenovo LB485, model 814TR01
[13486.747300] thinkpad_acpi: detected a 8-level brightness capable ThinkPad
[13486.752435] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[13486.752883] Registered led device: tpacpi::thinklight
[13486.752915] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one
[13486.753216] thinkpad_acpi: Console audio control enabled, mode: monitor (read only)
[13486.757147] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input15
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
Cc: Shuduo Sang <shuduo.sang@canonical.com>
commit c8aa22db0112f640ac6631347f850879c621840b upstream.
Since Eric's commit efe117ab8 ("Speedup ieee80211_remove_interfaces")
there's a bug in mac80211 when it unregisters with AP_VLAN interfaces
up. If the AP_VLAN interface was registered after the AP it belongs
to (which is the typical case) and then we get into this code path,
unregister_netdevice_many() will crash because it isn't prepared to
deal with interfaces being closed in the middle of it. Exactly this
happens though, because we iterate the list, find the AP master this
AP_VLAN belongs to and dev_close() the dependent VLANs. After this,
unregister_netdevice_many() won't pick up the fact that the AP_VLAN
is already down and will do it again, causing a crash.
commit 9271b0b4b2044c6db06051fe60bc58cdd4f17c7c upstream.
The latest GCC 4.8 does some more checking on type attributes that
break the build for ARCH=um -> fill them in. Specifically, the
"asmlinkage" attributes is now tested for consistency.
Signed-off-by: Martin Pelikan <pelikan@storkhole.cz>
Link: http://lkml.kernel.org/r/1339269731-10772-1-git-send-email-pelikan@storkhole.cz
Acked-by: Richard Weinberger <richard@nod.at>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Bernhard M. Wiedemann <bwiedemann@suse.de>
commit d3263bc29706e42f74d8800807c2dedf320d77f1 upstream.
Work around an IOMMU hardware bug where clearing the
EVT_INT or PPR_INT bit in the status register may race with
the hardware trying to set it again. When not handled the
bit might not be cleared and we lose all future event or ppr
interrupts.
Reported-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
commit 925fe08bce38d1ff052fe2209b9e2b8d5fbb7f98 upstream.
Current driver does not clear the IOMMU event log interrupt bit
in the IOMMU status register after processing an interrupt.
This causes the IOMMU hardware to generate event log interrupt only once.
This has been observed in both IOMMU v1 and V2 hardware.
This patch clears the bit by writing 1 to bit 1 of the IOMMU
status register (MMIO Offset 2020h)
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
commit 27f852282ab9a028f57da96d05c26f38c424a315 upstream.
This variable is never used.
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
commit 73aaa22d5ffb2630456bac2f9a4ed9b81d0d7271 upstream.
This patch fixes races uncovered by xfstests testcase 068.
One race is the result of jfs_sync() trying to write a sync point to the
journal after it has been frozen (or possibly in the process). Since
freezing sync's the journal, there is no need to write a sync point so
we simply want to return.
The second involves jfs_write_inode() being called on a deleted inode.
It calls jfs_flush_journal which is held up by the jfs_commit thread
doing the final iput on the same deleted inode, which itself is
waiting for the I_SYNC flag to be cleared. jfs_write_inode need not
do anything when i_nlink is zero, which is the easy fix.
Reported-by: Michael L. Semon <mlsemon35@gmail.com>
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
commit bee980d9e9642e96351fa3ca9077b853ecf62f57 upstream.
This avoids any other hardirq handler seeing a very stale jiffies
value immediately after wakeup from a long idle period. The one
observable symptom of this was a USB keyboard, with software keyboard
repeat, which would always repeat a key immediately that it was
pressed. This is due to the key press waking the guest, the key
handler immediately runs, sees an old jiffies value, and then that
jiffies value significantly updated, before the key is unpressed.
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Keir Fraser <keir.fraser@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit df66834a43c461de2565c45d815288ba1c0def37 upstream.
The present code does not wait for the SCC to finish resetting itself
before trying to initialise the device. The result is that the SCC
interrupt sources become enabled (if they weren't already). This leads to
an early boot crash (unexpected interrupt) given CONFIG_EARLY_PRINTK. Fix
this by adding a delay. A successful reset disables the interrupt sources.
Also, after the reset for channel A setup, the SCC then gets a second
reset for channel B setup which leaves channel A uninitialised again. Fix
this by performing the reset only once.
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
commit e771451c0a831d96a7c14b0ca8a8ec671d98567b upstream.
libata honors DMADIR for regular commands, but not for internal commands
used (among other) during device initialisation.
This makes SATA-host-to-PATA-device bridges based on Silicon Image SiL3611
(such as "Abit Serillel 2") end up disabled when used with an ATAPI device
after a few tries.
Log output of the bridge being hot-plugged with an ATAPI drive:
[ 9631.212901] ata1: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen
[ 9631.212913] ata1: irq_stat 0x00000040, connection status changed
[ 9631.212923] ata1: SError: { CommWake 10B8B DevExch }
[ 9631.212939] ata1: hard resetting link
[ 9632.104962] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 9632.106393] ata1.00: ATAPI: PIONEER DVD-RW DVR-115, 1.06, max UDMA/33
[ 9632.106407] ata1.00: applying bridge limits
[ 9632.108151] ata1.00: configured for UDMA/33
[ 9637.105303] ata1.00: qc timeout (cmd 0xa0)
[ 9637.105324] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5)
[ 9637.105335] ata1: hard resetting link
[ 9638.044599] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 9638.047878] ata1.00: configured for UDMA/33
[ 9643.044933] ata1.00: qc timeout (cmd 0xa0)
[ 9643.044953] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5)
[ 9643.044963] ata1: limiting SATA link speed to 1.5 Gbps
[ 9643.044971] ata1.00: limiting speed to UDMA/33:PIO3
[ 9643.044979] ata1: hard resetting link
[ 9643.984225] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 9643.987471] ata1.00: configured for UDMA/33
[ 9648.984591] ata1.00: qc timeout (cmd 0xa0)
[ 9648.984612] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5)
[ 9648.984619] ata1.00: disabled
[ 9649.000593] ata1: hard resetting link
[ 9649.939902] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 9649.955864] ata1: EH complete
With this patch, the drive enumerates correctly when libata is loaded with
atapi_dmadir=1:
[ 9891.810863] ata1: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen
[ 9891.810874] ata1: irq_stat 0x00000040, connection status changed
[ 9891.810884] ata1: SError: { CommWake 10B8B DevExch }
[ 9891.810900] ata1: hard resetting link
[ 9892.762105] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 9892.763544] ata1.00: ATAPI: PIONEER DVD-RW DVR-115, 1.06, max UDMA/33, DMADIR
[ 9892.763558] ata1.00: applying bridge limits
[ 9892.765393] ata1.00: configured for UDMA/33
[ 9892.786063] ata1: EH complete
[ 9892.792062] scsi 0:0:0:0: CD-ROM PIONEER DVD-RW DVR-115 1.06 PQ: 0 ANSI: 5
[ 9892.798455] sr2: scsi3-mmc drive: 12x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 9892.798837] sr 0:0:0:0: Attached scsi CD-ROM sr2
[ 9892.799109] sr 0:0:0:0: Attached scsi generic sg6 type 5
Based on a patch by Csaba Halász <csaba.halasz@gmail.com> on linux-ide:
http://marc.info/?l=linux-ide&m=136121147832295&w=2
tj: minor formatting changes.
Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com>
commit fca8c90d519dedd4f4b19901d005c243f7f0bf2e upstream.
Adds IDE-mode SATA Device IDs for the Intel BayTrail platform.
Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 1ee0a224bc9aad1de496c795f96bc6ba2c394811 upstream.
The tty is NULL when the port is hanging up.
chase_port() needs to check for this.
This patch is intended for stable series.
The behavior was observed and tested in Linux 3.2 and 3.7.1.
Johan Hovold submitted a more elaborate patch for the mainline kernel.
[ 56.277883] usb 1-1: edge_bulk_in_callback - nonzero read bulk status received: -84
[ 56.278811] usb 1-1: USB disconnect, device number 3
[ 56.278856] usb 1-1: edge_bulk_in_callback - stopping read!
[ 56.279562] BUG: unable to handle kernel NULL pointer dereference at 00000000000001c8
[ 56.280536] IP: [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35
[ 56.281212] PGD 1dc1b067 PUD 1e0f7067 PMD 0
[ 56.282085] Oops: 0002 [#1] SMP
[ 56.282744] Modules linked in:
[ 56.283512] CPU 1
[ 56.283512] Pid: 25, comm: khubd Not tainted 3.7.1 #1 innotek GmbH VirtualBox/VirtualBox
[ 56.283512] RIP: 0010:[<ffffffff8144e62a>] [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35
[ 56.283512] RSP: 0018:ffff88001fa99ab0 EFLAGS: 00010046
[ 56.283512] RAX: 0000000000000046 RBX: 00000000000001c8 RCX: 0000000000640064
[ 56.283512] RDX: 0000000000010000 RSI: ffff88001fa99b20 RDI: 00000000000001c8
[ 56.283512] RBP: ffff88001fa99b20 R08: 0000000000000000 R09: 0000000000000000
[ 56.283512] R10: 0000000000000000 R11: ffffffff812fcb4c R12: ffff88001ddf53c0
[ 56.283512] R13: 0000000000000000 R14: 00000000000001c8 R15: ffff88001e19b9f4
[ 56.283512] FS: 0000000000000000(0000) GS:ffff88001fd00000(0000) knlGS:0000000000000000
[ 56.283512] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 56.283512] CR2: 00000000000001c8 CR3: 000000001dc51000 CR4: 00000000000006e0
[ 56.283512] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 56.283512] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 56.283512] Process khubd (pid: 25, threadinfo ffff88001fa98000, task ffff88001fa94f80)
[ 56.283512] Stack:
[ 56.283512] 0000000000000046 00000000000001c8 ffffffff810578ec ffffffff812fcb4c
[ 56.283512] ffff88001e19b980 0000000000002710 ffffffff812ffe81 0000000000000001
[ 56.283512] ffff88001fa94f80 0000000000000202 ffffffff00000001 0000000000000296
[ 56.283512] Call Trace:
[ 56.283512] [<ffffffff810578ec>] ? add_wait_queue+0x12/0x3c
[ 56.283512] [<ffffffff812fcb4c>] ? usb_serial_port_work+0x28/0x28
[ 56.283512] [<ffffffff812ffe81>] ? chase_port+0x84/0x2d6
[ 56.283512] [<ffffffff81063f27>] ? try_to_wake_up+0x199/0x199
[ 56.283512] [<ffffffff81263a5c>] ? tty_ldisc_hangup+0x222/0x298
[ 56.283512] [<ffffffff81300171>] ? edge_close+0x64/0x129
[ 56.283512] [<ffffffff810612f7>] ? __wake_up+0x35/0x46
[ 56.283512] [<ffffffff8106135b>] ? should_resched+0x5/0x23
[ 56.283512] [<ffffffff81264916>] ? tty_port_shutdown+0x39/0x44
[ 56.283512] [<ffffffff8125d38c>] ? __tty_hangup+0x307/0x351
[ 56.283512] [<ffffffff812e6ddc>] ? usb_hcd_flush_endpoint+0xde/0xed
[ 56.283512] [<ffffffff8144e625>] ? _raw_spin_lock_irqsave+0x14/0x35
[ 56.283512] [<ffffffff812fd361>] ? usb_serial_disconnect+0x57/0xc2
[ 56.283512] [<ffffffff812ea99b>] ? usb_unbind_interface+0x5c/0x131
[ 56.283512] [<ffffffff8128d738>] ? __device_release_driver+0x7f/0xd5
[ 56.283512] [<ffffffff8128d9cd>] ? device_release_driver+0x1a/0x25
[ 56.283512] [<ffffffff8128d393>] ? bus_remove_device+0xd2/0xe7
[ 56.283512] [<ffffffff8128b7a3>] ? device_del+0x119/0x167
[ 56.283512] [<ffffffff812e8d9d>] ? usb_disable_device+0x6a/0x180
[ 56.283512] [<ffffffff812e2ae0>] ? usb_disconnect+0x81/0xe6
[ 56.283512] [<ffffffff812e4435>] ? hub_thread+0x577/0xe82
[ 56.283512] [<ffffffff8144daa7>] ? __schedule+0x490/0x4be
[ 56.283512] [<ffffffff8105798f>] ? abort_exclusive_wait+0x79/0x79
[ 56.283512] [<ffffffff812e3ebe>] ? usb_remote_wakeup+0x2f/0x2f
[ 56.283512] [<ffffffff810570b4>] ? kthread+0x81/0x89
[ 56.283512] [<ffffffff81057033>] ? __kthread_parkme+0x5c/0x5c
[ 56.283512] [<ffffffff8145387c>] ? ret_from_fork+0x7c/0xb0
[ 56.283512] Code: 8b 7c 24 08 e8 17 0b c3 ff 48 8b 04 24 48 83 c4 10 c3 53 48 89 fb 41 50 e8 e0 0a c3 ff 48 89 04 24 e8 e7 0a c3 ff ba 00 00 01 00
<f0> 0f c1 13 48 8b 04 24 89 d1 c1 ea 10 66 39 d1 74 07 f3 90 66
[ 56.283512] RIP [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35
[ 56.283512] RSP <ffff88001fa99ab0>
[ 56.283512] ---[ end trace 49714df27e1679ce ]---
Signed-off-by: Wolfgang Frisch <wfpub@roembden.net>
Cc: Johan Hovold <jhovold@gmail.com>
commit 166faf21bd14bc5c5295a44874bf7f3930c30b20 upstream.
Consider the case where we have a very short ip= string in the original
mount options, and when we chase a referral we end up with a very long
IPv6 address. Be sure to allow for that possibility when estimating the
size of the string to allocate.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 09fb8bd1a63b0f9f15e655c4fe8d047e5d2bf67a upstream.
Newer asics have variable numbers of crtcs. Use that
rather than the asic family to determine which crtcs
to check. This avoids checking non-existent crtcs or
missing crtcs on certain asics.
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 2962f5a5dcc56f69cbf62121a7be67cc15d6940b upstream.
XFS has failed to kill suid/sgid bits correctly when truncating
files of non-zero size since commit c4ed4243 ("xfs: split
xfs_setattr") introduced in the 3.1 kernel. Fix it.
Fix it.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit f448badd34700ae728a32ba024249626d49c10e1 upstream.
We need to pass the full open mode flags to nfs_may_open() when doing
a delegated open.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit cea4dcfdad926a27a18e188720efe0f2c9403456 upstream.
If a key was larger than 64 bytes, as checked by iscsi_check_key(), the
error response packet, generated by iscsi_add_notunderstood_response(),
would still attempt to copy the entire key into the packet, overflowing
the structure on the heap.
Remote preauthentication kernel memory corruption was possible if a
target was configured and listening on the network.
CVE-2013-2850
commit 7c3425123ddfdc5f48e7913ff59d908789712b18 upstream.
We should not use set_pmd_at to update pmd_t with pgtable_t pointer.
set_pmd_at is used to set pmd with huge pte entries and architectures
like ppc64, clear few flags from the pte when saving a new entry.
Without this change we observe bad pte errors like below on ppc64 with
THP enabled.
BUG: Bad page map in process ld mm=0xc000001ee39f4780 pte:7fc3f37848000001 pmd:c000001ec0000000
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
commit a9ff785e4437c83d2179161e012f5bdfbd6381f0 upstream.
A panic can be caused by simply cat'ing /proc/<pid>/smaps while an
application has a VM_PFNMAP range. It happened in-house when a
benchmarker was trying to decipher the memory layout of his program.
/proc/<pid>/smaps and similar walks through a user page table should not
be looking at VM_PFNMAP areas.
Certain tests in walk_page_range() (specifically split_huge_page_pmd())
assume that all the mapped PFN's are backed with page structures. And
this is not usually true for VM_PFNMAP areas. This can result in panics
on kernel page faults when attempting to address those page structures.
There are a half dozen callers of walk_page_range() that walk through a
task's entire page table (as N. Horiguchi pointed out). So rather than
change all of them, this patch changes just walk_page_range() to ignore
VM_PFNMAP areas.
The logic of hugetlb_vma() is moved back into walk_page_range(), as we
want to test any vma in the range.
VM_PFNMAP areas are used by:
- graphics memory manager gpu/drm/drm_gem.c
- global reference unit sgi-gru/grufile.c
- sgi special memory char/mspec.c
- and probably several out-of-tree modules
[akpm@linux-foundation.org: remove now-unused hugetlb_vma() stub]
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: David Sterba <dsterba@suse.cz>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
commit dfd20b2b174d3a9b258ea3b7a35ead33576587b1 upstream.
The index on the page must be set before it is inserted in the radix
tree. Otherwise there is a small race which can occur during lookup
where the page can be found with the incorrect index. This will trigger
the BUG_ON() in brd_lookup_page().
Signed-off-by: Brian Behlendorf <behlendorf1@llnl.gov>
Reported-by: Chris Wedgwood <cw@f00f.org>
commit d34883d4e35c0a994e91dd847a82b4c9e0c31d83 upstream.
Commit 751efd8610d3 ("mmu_notifier_unregister NULL Pointer deref and
multiple ->release()") breaks the fix 3ad3d901bbcf ("mm: mmu_notifier:
fix freed page still mapped in secondary MMU").
Since hlist_for_each_entry_rcu() is changed now, we can not revert that
patch directly, so this patch reverts the commit and simply fix the bug
spotted by that patch
This bug spotted by commit 751efd8610d3 is:
There is a race condition between mmu_notifier_unregister() and
__mmu_notifier_release().
Assume two tasks, one calling mmu_notifier_unregister() as a result
of a filp_close() ->flush() callout (task A), and the other calling
mmu_notifier_release() from an mmput() (task B).
A B
t1 srcu_read_lock()
t2 if (!hlist_unhashed())
t3 srcu_read_unlock()
t4 srcu_read_lock()
t5 hlist_del_init_rcu()
t6 synchronize_srcu()
t7 srcu_read_unlock()
t8 hlist_del_rcu() <--- NULL pointer deref.
This can be fixed by using hlist_del_init_rcu instead of hlist_del_rcu.
The another issue spotted in the commit is "multiple ->release()
callouts", we needn't care it too much because it is really rare (e.g,
can not happen on kvm since mmu-notify is unregistered after
exit_mmap()) and the later call of multiple ->release should be fast
since all the pages have already been released by the first call.
Anyway, this issue should be fixed in a separate patch.
-stable suggestions: Any version that has commit 751efd8610d3 need to be
backported. I find the oldest version has this commit is 3.0-stable.
[akpm@linux-foundation.org: tweak comments]
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Tested-by: Robin Holt <holt@sgi.com>
commit 136e8770cd5d1fe38b3c613100dd6dc4db6d4fa6 upstream.
nilfs2: fix issue of nilfs_set_page_dirty for page at EOF boundary
DESCRIPTION:
There are use-cases when NILFS2 file system (formatted with block size
lesser than 4 KB) can be remounted in RO mode because of encountering of
"broken bmap" issue.
The issue was reported by Anthony Doggett <Anthony2486@interfaces.org.uk>:
"The machine I've been trialling nilfs on is running Debian Testing,
Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc
version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.35-2), but I've
also reproduced it (identically) with Debian Unstable amd64 and Debian
Experimental (using the 3.8-trunk kernel). The problematic partitions
were formatted with "mkfs.nilfs2 -b 1024 -B 8192"."
SYMPTOMS:
(1) System log contains error messages likewise:
[63102.496756] nilfs_direct_assign: invalid pointer: 0
[63102.496786] NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28)
[63102.496798]
[63102.524403] Remounting filesystem read-only
(2) The NILFS2 file system is remounted in RO mode.
REPRODUSING PATH:
(1) Create volume group with name "unencrypted" by means of vgcreate utility.
(2) Run script (prepared by Anthony Doggett <Anthony2486@interfaces.org.uk>):
----------------[BEGIN SCRIPT]--------------------
VG=unencrypted
lvcreate --size 2G --name ntest $VG
mkfs.nilfs2 -b 1024 -B 8192 /dev/mapper/$VG-ntest
mkdir /var/tmp/n
mkdir /var/tmp/n/ntest
mount /dev/mapper/$VG-ntest /var/tmp/n/ntest
mkdir /var/tmp/n/ntest/thedir
cd /var/tmp/n/ntest/thedir
sleep 2
date
darcs init
sleep 2
dmesg|tail -n 5
date
darcs whatsnew || true
date
sleep 2
dmesg|tail -n 5
----------------[END SCRIPT]--------------------
REPRODUCIBILITY: 100%
INVESTIGATION:
As it was discovered, the issue takes place during segment
construction after executing such sequence of user-space operations:
open("_darcs/index", O_RDWR|O_CREAT|O_NOCTTY, 0666) = 7
fstat(7, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
ftruncate(7, 60)
The error message "NILFS error (device dm-17): nilfs_bmap_assign: broken
bmap (inode number=28)" takes place because of trying to get block
number for third block of the file with logical offset #3072 bytes. As
it is possible to see from above output, the file has 60 bytes of the
whole size. So, it is enough one block (1 KB in size) allocation for
the whole file. Trying to operate with several blocks instead of one
takes place because of discovering several dirty buffers for this file
in nilfs_segctor_scan_file() method.
The root cause of this issue is in nilfs_set_page_dirty function which
is called just before writing to an mmapped page.
When nilfs_page_mkwrite function handles a page at EOF boundary, it
fills hole blocks only inside EOF through __block_page_mkwrite().
The __block_page_mkwrite() function calls set_page_dirty() after filling
hole blocks, thus nilfs_set_page_dirty function (=
a_ops->set_page_dirty) is called. However, the current implementation
of nilfs_set_page_dirty() wrongly marks all buffers dirty even for page
at EOF boundary.
As a result, buffers outside EOF are inconsistently marked dirty and
queued for write even though they are not mapped with nilfs_get_block
function.
FIX:
This modifies nilfs_set_page_dirty() not to mark hole blocks dirty.
Thanks to Vyacheslav Dubeyko for his effort on analysis and proposals
for this issue.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Reported-by: Anthony Doggett <Anthony2486@interfaces.org.uk>
Reported-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Vyacheslav Dubeyko <slava@dubeyko.com>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 4c663cfc523a88d97a8309b04a089c27dc57fd7e upstream.
Many callers of the wait_event_timeout() and
wait_event_interruptible_timeout() expect that the return value will be
positive if the specified condition becomes true before the timeout
elapses. However, at the moment this isn't guaranteed. If the wake-up
handler is delayed enough, the time remaining until timeout will be
calculated as 0 - and passed back as a return value - even if the
condition became true before the timeout has passed.
Fix this by returning at least 1 if the condition becomes true. This
semantic is in line with what wait_for_condition_timeout() does; see
commit bb10ed09 ("sched: fix wait_for_completion_timeout() spurious
failure under heavy load").
Daniel said "We have 3 instances of this bug in drm/i915. One case even
where we switch between the interruptible and not interruptible
wait_event_timeout variants, foolishly presuming they have the same
semantics. I very much like this."
One such bug is reported at
https://bugs.freedesktop.org/show_bug.cgi?id=64133
Signed-off-by: Imre Deak <imre.deak@intel.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Jens Axboe <axboe@kernel.dk>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Lukas Czerner <lczerner@redhat.com>
commit ac5a2962b02f57dea76d314ef2521a2170b28ab6 upstream.
There is a race between klist_remove and klist_release. klist_remove
uses a local var waiter saved on stack. When klist_release calls
wake_up_process(waiter->process) to wake up the waiter, waiter might run
immediately and reuse the stack. Then, klist_release calls
list_del(&waiter->list) to change previous
wait data and cause prior waiter thread corrupt.
The patch fixes it against kernel 3.9.
Signed-off-by: wang, biao <biao.wang@intel.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit c2cc499c5bcf9040a738f49e8051b42078205748 upstream.
Page 'new' during MIGRATION can't be flushed with flush_cache_page().
Using flush_cache_page(vma, addr, pfn) is justified only if the page is
already placed in process page table, and that is done right after
flush_cache_page(). But without it the arch function has no knowledge
of process PTE and does nothing.
Besides that, flush_cache_page() flushes an application cache page, but
the kernel has a different page virtual address and dirtied it.
Replace it with flush_dcache_page(new) which is the proper usage.
The old page is flushed in try_to_unmap_one() before migration.
This bug takes place in Sead3 board with M14Kc MIPS CPU without cache
aliasing (but Harvard arch - separate I and D cache) in tight memory
environment (128MB) each 1-3days on SOAK test. It fails in cc1 during
kernel build (SIGILL, SIGBUS, SIGSEG) if CONFIG_COMPACTION is switched
ON.
Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Cc: Leonid Yegoshin <yegoshin@mips.com>
commit 4b949b8af12e24b8a48fa5bb775a13b558d9f4da upstream.
During the development of this driver an in-house register documentation
was used. The last week some integration tests were done and this
problem was found. It turned out that the released register
documentation is wrong.
The fix is very simple: shift all masks by one.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Bryan Wu <cooloney@gmail.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 99e11334dcb846f9b76fb808196c7f47aa83abb3 upstream.
Enable KW_PCIE1 on QNAP TS-11x/TS-21x devices as newer revisions
(rev 1.3) have a USB 3.0 chip from Etron on PCIe port 1. Thanks
to Marek Vasut for identifying this issue!
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
Tested-by: Marek Vasut <marex@denx.de>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit b4ca2b4b577c3530e34dcfaafccb2cc680ce95d1 upstream.
Last time we found there is lock/unlock bug in ocfs2_file_aio_write, and
then we did a thorough search for all lock resources in
ocfs2_inode_info, including rw, inode and open lockres and found this
bug. My kernel version is 3.0.13, and it is also in the lastest version
3.9. In ocfs2_fiemap, once ocfs2_get_clusters_nocache failed, it should
goto out_unlock instead of out, because we need release buffer head, up
read alloc sem and unlock inode.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Reviewed-by: Jie Liu <jeff.liu@oracle.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Acked-by: Sunil Mushran <sunil.mushran@gmail.com>
commit 5a1e99dd2028e00998d42029be86835d8ef4a46e upstream.
The comparison between traced and symbol addresses is backwards: if
the traced address doesn't exactly match a symbol (which we don't
expect it to), we'll show the next symbol and the offset to it,
whereas we should show the previous symbol and the offset from it.
commit 140c3c6a2bcd2c31e2f7f5a8d59689724776c8e5 upstream.
This works much better if we don't treat protocol numbers as addresses.
commit 7b92d03c3239f43e5b86c9cc9630f026d36ee995 upstream.
Intermediate value of fat_clusters can be overflowed on 32bits arch.
Reported-by: Krzysztof Strasburger <strasbur@chkw386.ch.pwr.wroc.pl>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
commit c2b93e0699723700f886ce17bb65ffd771195a6d upstream.
It's generally not safe to reset the inode ops once they've been set. In
the case where the inode was originally thought to be a directory and
then later found to be a DFS referral, this can lead to an oops when we
try to trigger an inode op on it after changing the ops to the blank
referral operations.
Reported-and-Tested-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 997ff893603c6455da4c5e26ba1d0f81adfecdfc upstream.
HP's virtual UHCI host controller takes a long time to suspend
(several hundred microseconds), even when no devices are attached.
This provokes a warning message from uhci-hcd in the auto-stop case.
To prevent this from happening, this patch adds a test to avoid
performing an auto-stop when the wait_for_hp quirk flag is set. The
controller will still suspend through the normal runtime PM mechanism.
And since that pathway includes a 1-ms delay, the slowness of the
virtual hardware won't matter.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: ZhenHua <zhen-hual@hp.com>
commit e4f47e3675e6f1f40906b785b934ce963e9f2eb3 upstream.
This patch shortens the logic in xhci_endpoint_init() by moving common
calculations involving max_packet and max_burst outside the switch
statement, rather than repeating the same code in multiple
case-specific statements. It also replaces two usages of max_packet
which were clearly intended to be max_burst all along.
More importantly, it compensates for a common bug in high-speed bulk
endpoint descriptors. In many devices there is a bulk endpoint having
a wMaxPacketSize value smaller than 512, which is forbidden by the USB
spec. Some xHCI controllers can't handle this and refuse to accept
the endpoint. This patch changes the max_packet value to 512, which
allows the controller to use the endpoint properly.
In practice the bogus maxpacket size doesn't matter, because none of
the transfers sent via these endpoints are longer than the maxpacket
value anyway.
Reported-and-tested-by: "Aurélien Leblond" <blablack@gmail.com>
commit bac6b03275184c912ad0818c9a0a736847804dca upstream.
Werner Fink has reported problems with this hub.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
commit 8ff10bdb14a52e3f25d4ce09e0582a8684c1a6db upstream.
/drivers/usb/serial/option.c: Blacklisted Cinterion's PLxx WWAN
Interface (USB Interface 4), because it will be handled by QMI WWAN
driver. Product IDs renamed.
Signed-off-by: Hans-Christoph Schemmel <hans-christoph.schemmel@gemalto.com>
commit dab73b4eb9ef924a2b90dab84e539076d82b256f upstream.
I meet emacs hang in start if I do the operation below:
1: echo 3 > /proc/sys/vm/drop_caches
2: emacs BigFile
3: Press CTRL-S follow 2 immediately
Then emacs hang on, CTRL-Q can't resume, the terminal
hang on, you can do nothing with this terminal except
close it.
The reason is before emacs takeover control the tty,
we use CTRL-S to XOFF it. Then when emacs takeover the
control, it may don't use the flow-control, so emacs hang.
This patch fix it.
This patch will fix a kind of strange tty relation hang problem,
I believe I meet it with vim in ssh, and also see below bug report:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=465823
Signed-off-by: Wang YanQing <udknight@gmail.com>
commit 2a0ebf80aa95cc758d4725f74a7016e992606a39 upstream.
The value of "offd" comes off the instance->rcv_buf[] and we used it as
the offset into an array. The problem is that we check the upper bound
but not for negative values.
commit 7138143972b7c293267c783fc99a194f0ceff7f2 upstream.
Here are two more devices that use FTDI USB-to-serial chips with new product ID's.
The devices are the Newport Conex-AGP and Conex-CC motor controllers.
(http://www.newport.com/CONEX-AGP-Integrated-Piezo-Motor-Rotation-Stages-/987623/1033/info.aspx)
(http://www.newport.com/CONEX-CC-DC-Servo-Controller-Actuators/934114/1033/info.aspx)
usb-devices command yields:
P: Vendor=104d ProdID=3002 Rev=06.00
S: Manufacturer=Newport
S: Product=CONEX-CC
as well as
P: Vendor=104d ProdID=3006 Rev=06.00
S: Product=CONEX-AGP
Signed-off-by: Andrew Gomella <andrew.gomella@nih.gov>
commit 49c6e370dd6400b84897c4100095089b5c13a061 upstream.
A rebranded Novatel E371 for AT&T's LTE bands.
Signed-off-by: Dan Williams <dcbw@redhat.com>
commit 73c042df6e1bc50544842a04b777b36bbe3630e6 upstream.
Information from driver description files:
diag: VID_19D2&PID_0412&MI_00
nmea: VID_19D2&PID_0412&MI_01
at: VID_19D2&PID_0412&MI_02
modem: VID_19D2&PID_0412&MI_03
net: VID_19D2&PID_0412&MI_04
Signed-off-by: Teppo Kotilainen <qubit303@gmail.com>
commit 0a438d5b381e2bdfd5e02d653bf46fcc878356e3 upstream.
use free_netdev() instead of kfree(pDevice->apdev)
Signed-off-by: Hema Prathaban <hemaklnce@gmail.com>
commit 2b8b2797142c7951e635c6eec5d1705ee9bc45c5 upstream.
When platform data were moved from arch/arm/mach-mv78xx0/common.c to
arch/arm/plat-orion/common.c with the commit "7e3819d ARM: orion:
Consolidate ethernet platform data", there were few typo made on
gigabit Ethernet interface ge10 and ge11. This commit writes back
their initial value, which allows to use this interfaces again.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit e68c636d88db3fda74e664ecb1a213ae0d50a7d8 upstream.
Caught by static code analysis by David.
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
commit e1d45ae10aea8e8a403e5d96bf5902ee670007ff upstream.
If we set mantis->fe to NULL on an error its not a good idea to then try
passing NULL to the unregister paths and oopsing really.
Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=16473
Signed-off-by: Alan Cox <alan@linux.intel.com>
Cc: Bjørn Mork <bjorn@mork.no>
commit fc986034540102cd090237bf3f70262e1ae80d9c upstream.
Add ULL prefix to avoid overflow.
Signed-off-by: Niels Ole Salscheider <niels_ole@salscheider-online.de>
commit 2a2d95e9d6d29e726cc294b65391917ed2e32bf4 upstream.
If the I2C bus is put to a low power state by an ACPI method it might pull
the SDA line low (as its power is removed). Once the bus is put to full
power state again, the SDA line is pulled back to high. This transition
looks like a STOP condition from the controller point-of-view which sets
STOP detected bit in its status register causing the driver to fail
subsequent transfers.
Fix this by always clearing all interrupts before we start a transfer.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit ecacb0b17c08fae89f65468727f0e4b8e91da4e1 upstream.
Fix to return a negative error code from the error handling
case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
