2013-06-13Linux 3.4.49v3.4.49Greg Kroah-Hartman
2013-06-13ftrace: Move ftrace_filter_lseek out of CONFIG_DYNAMIC_FTRACE sectionSteven Rostedt
commit 7f49ef69db6bbf756c0abca7e9b65b32e999eec8 upstream. As ftrace_filter_lseek is now used with ftrace_pid_fops, it needs to be moved out of the #ifdef CONFIG_DYNAMIC_FTRACE section as the ftrace_pid_fops is defined when DYNAMIC_FTRACE is not. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Namhyung Kim <namhyung@kernel.org> [ lizf: adjust context ] Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13tracing: Fix possible NULL pointer dereferencesNamhyung Kim
commit 6a76f8c0ab19f215af2a3442870eeb5f0e81998d upstream. Currently set_ftrace_pid and set_graph_function files use seq_lseek for their fops. However seq_open() is called only for FMODE_READ in the fops->open() so that if an user tries to seek one of those file when she open it for writing, it sees NULL seq_file and then panic. It can be easily reproduced with following command: $ cd /sys/kernel/debug/tracing $ echo 1234 | sudo tee -a set_ftrace_pid In this example, GNU coreutils' tee opens the file with fopen(, "a") and then the fopen() internally calls lseek(). Link: http://lkml.kernel.org/r/1365663302-2170-1-git-send-email-namhyung@kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> [ lizf: adjust context ] Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13drm/gma500: Increase max resolution for mode settingPatrik Jakobsson
commit cbbd379aa43890f36da934f5af619d2fb8ec3d87 upstream. By having a higher max resolution we can now set up a virtual framebuffer that spans several monitors. 4096 should be ok since we're gen 3 or higher and should be enough for most dual head setups. Bugzilla: https://bugs.launchpad.net/ubuntu/+source/xserver-xorg-video-modesetting/+bug/1169147 Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: ftdi_sio: Quiet sparse noise about using plain integer was NULL pointerYing Xue
commit a816e3113b63753c330ca4751ea1d208e93e3015 upstream. Pointers should not be compared to plain integers. Quiets the sparse warning: warning: Using plain integer as NULL pointer Signed-off-by: Ying Xue <ying.xue@windriver.com> Cc: Lotfi Manseur <lotfi.manseur@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13xen-pciback: rate limit error messages from xen_pcibk_enable_msi{,x}()Jan Beulich
commit 51ac8893a7a51b196501164e645583bf78138699 upstream. ... as being guest triggerable (e.g. by invoking XEN_PCI_OP_enable_msi{,x} on a device not being MSI/MSI-X capable). This is CVE-2013-0231 / XSA-43. Also make the two messages uniform in both their wording and severity. Signed-off-by: Jan Beulich <jbeulich@suse.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [stable tree: Added two extra #include files] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13drm/i915: no lvds quirk for hp t5740Ben Mesman
commit 45a211d75137b1ac869a8a758a6667f15827a115 upstream. Last year, a patch was made for the "HP t5740e Thin Client" (see http://lists.freedesktop.org/archives/dri-devel/2012-May/023245.html). This device reports an lvds panel, but does not really have one. The predecessor of this device is the "hp t5740", which also does not have an lvds panel. This patch will add the same quirk for this device. Signed-off-by: Ben Mesman <ben@bnc.nl> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13drm/i915/sdvo: Use &intel_sdvo->ddc instead of intel_sdvo->i2c for DDC.Egbert Eich
commit 53d3b4d7778daf15900867336c85d3f8dd70600c upstream. In intel_sdvo_get_lvds_modes() the wrong i2c adapter record is used for DDC. Thus the code will always have to rely on a LVDS panel mode supplied by VBT. In most cases this succeeds, so this didn't get detected for quite a while. This regression seems to have been introduced in commit f899fc64cda8569d0529452aafc0da31c042df2e Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Tue Jul 20 15:44:45 2010 -0700 drm/i915: use GMBUS to manage i2c links Signed-off-by: Egbert Eich <eich@suse.de> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> [danvet: Add note about which commit likely introduced this issue.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13drm: fix a use-after-free when GPU acceleration disabledHuacai Chen
commit b7ea85a4fed37835eec78a7be3039c8dc22b8178 upstream. When GPU acceleration is disabled, drm_vblank_cleanup() will free the vblank-related data, such as vblank_refcount, vblank_inmodeset, etc. But we found that drm_vblank_post_modeset() may be called after the cleanup, which use vblank_refcount and vblank_inmodeset. And this will cause a kernel panic. Fix this by return immediately if dev->num_crtcs is zero. This is the same thing that drm_vblank_pre_modeset() does. Call trace of a drm_vblank_post_modeset() after drm_vblank_cleanup(): [ 62.628906] [<ffffffff804868d0>] drm_vblank_post_modeset+0x34/0xb4 [ 62.628906] [<ffffffff804c7008>] atombios_crtc_dpms+0xb4/0x174 [ 62.628906] [<ffffffff804c70e0>] atombios_crtc_commit+0x18/0x38 [ 62.628906] [<ffffffff8047f038>] drm_crtc_helper_set_mode+0x304/0x3cc [ 62.628906] [<ffffffff8047f92c>] drm_crtc_helper_set_config+0x6d8/0x988 [ 62.628906] [<ffffffff8047dd40>] drm_fb_helper_set_par+0x94/0x104 [ 62.628906] [<ffffffff80439d14>] fbcon_init+0x424/0x57c [ 62.628906] [<ffffffff8046a638>] visual_init+0xb8/0x118 [ 62.628906] [<ffffffff8046b9f8>] take_over_console+0x238/0x384 [ 62.628906] [<ffffffff80436df8>] fbcon_takeover+0x7c/0xdc [ 62.628906] [<ffffffff8024fa20>] notifier_call_chain+0x44/0x94 [ 62.628906] [<ffffffff8024fcbc>] __blocking_notifier_call_chain+0x48/0x68 [ 62.628906] [<ffffffff8042d990>] register_framebuffer+0x228/0x260 [ 62.628906] [<ffffffff8047e010>] drm_fb_helper_single_fb_probe+0x260/0x314 [ 62.628906] [<ffffffff8047e2c4>] drm_fb_helper_initial_config+0x200/0x234 [ 62.628906] [<ffffffff804e5560>] radeon_fbdev_init+0xd4/0xf4 [ 62.628906] [<ffffffff804e0e08>] radeon_modeset_init+0x9bc/0xa18 [ 62.628906] [<ffffffff804bfc14>] radeon_driver_load_kms+0xdc/0x12c [ 62.628906] [<ffffffff8048b548>] drm_get_pci_dev+0x148/0x238 [ 62.628906] [<ffffffff80423564>] local_pci_probe+0x5c/0xd0 [ 62.628906] [<ffffffff80241ac4>] work_for_cpu_fn+0x1c/0x30 [ 62.628906] [<ffffffff802427c8>] process_one_work+0x274/0x3bc [ 62.628906] [<ffffffff80242934>] process_scheduled_works+0x24/0x44 [ 62.628906] [<ffffffff8024515c>] worker_thread+0x31c/0x3f4 [ 62.628906] [<ffffffff802497a8>] kthread+0x88/0x90 [ 62.628906] [<ffffffff80206794>] kernel_thread_helper+0x10/0x18 Signed-off-by: Huacai Chen <chenhc@lemote.com> Signed-off-by: Binbin Zhou <zhoubb@lemote.com> Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Acked-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13hwmon: (adm1021) Strengthen chip detection for ADM1021, LM84 and MAX1617Guenter Roeck
commit 591bfcfc334a003ba31c0deff03b22e73349939b upstream. On a system with both MAX1617 and JC42 sensors, JC42 sensors can be misdetected as LM84. Strengthen detection sufficiently enough to avoid this misdetection. Also improve detection for ADM1021. Modeled after chip detection code in sensors-detect command. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13drm/radeon: don't allow audio on DCE6Alex Deucher
commit 1cbcca302a318499f20a512847c5d6a510c08c35 upstream. It's not supported yet. Fixes display issues when users force it on. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13radeon: Fix system hang issue when using KMS with older cardsAdis Hamzić
commit e49f3959a96dc279860af7e86e6dbcfda50580a5 upstream. The current radeon driver initialization routines, when using KMS, are written so that the IRQ installation routine is called before initializing the WB buffer and the CP rings. With some ASICs, though, the IRQ routine tries to access the GFX_INDEX ring causing a call to RREG32 with the value of -1 in radeon_fence_read. This, in turn causes the system to completely hang with some cards, requiring a hard reset. A call stack that can cause such a hang looks like this (using rv515 ASIC for the example here): * rv515_init (rv515.c) * radeon_irq_kms_init (radeon_irq_kms.c) * drm_irq_install (drm_irq.c) * radeon_driver_irq_preinstall_kms (radeon_irq_kms.c) * rs600_irq_process (rs600.c) * radeon_fence_process - due to SW interrupt (radeon_fence.c) * radeon_fence_read (radeon_fence.c) * hang due to RREG32(-1) The patch moves the IRQ installation to the card startup routine, after the ring has been initialized, but before the IRQ has been set. This fixes the issue, but requires a check to see if the IRQ is already installed, as is the case in the system resume codepath. I have tested the patch on three machines using the rv515, the rv770 and the evergreen ASIC. They worked without issues. This seems to be a known issue and has been reported on several bug tracking sites by various distributions (see links below). Most of reports recommend booting the system with KMS disabled and then enabling KMS by reloading the radeon module. For some reason, this was indeed a usable workaround, however, UMS is now deprecated and disabled by default. Bug reports: https://bugzilla.redhat.com/show_bug.cgi?id=845745 https://bugs.launchpad.net/ubuntu/+source/linux/+bug/561789 https://bbs.archlinux.org/viewtopic.php?id=156964 Signed-off-by: Adis Hamzić <adis@hamzadis.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-06-13powerpc/eeh: Don't check RTAS token to get PE addrGavin Shan
commit b8b3de224f194005ad87ede6fd022fcc2bef3b1a upstream. RTAS token "ibm,get-config-addr-info" or ibm,get-config-addr-info2" are used to retrieve the PE address according to PCI address, which made up of domain/bus/slot/function. If we don't have those 2 tokens, the domain/bus/slot/function would be used as the address for EEH RTAS operations. Some older f/w might not have those 2 tokens and that blocks the EEH functionality to be initialized. It was introduced by commit e2af155c ("powerpc/eeh: pseries platform EEH initialization"). The patch skips the check on those 2 tokens so we can bring up EEH functionality successfully. And domain/bus/slot/function will be used as address for EEH RTAS operations. Reported-by: Robert Knight <knight@princeton.edu> Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Tested-by: Robert Knight <knight@princeton.edu> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13ACPI / video: ignore BIOS initial backlight value for HP Pavilion g6Ash Willis
commit 780a6ec640a3fed671fc2c40e4dd30c03eca3ac3 upstream. This patch addresses kernel bug 56661. BIOS reports an incorrect backlight value, causing the driver to switch off the backlight completely during startup. This patch ignores the incorrect value from BIOS. References: https://bugzilla.kernel.org/show_bug.cgi?id=56661 Signed-off-by: Ash Willis <ashwillis@programmer.net> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13ACPI / video: ignore BIOS initial backlight value for HP m4Alex Hung
commit fedbe9bc6fd3e14b1ffbb3dac407777ac4a3650c upstream. On HP m4 lapops, BIOS reports minimum backlight on boot and causes backlight to dim completely. This ignores the initial backlight values and set to max brightness. References: https://bugs.launchpad.net/bugs/1184501 Signed-off-by: Alex Hung <alex.hung@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: mos7720: fix hardware flow controlJohan Hovold
commit a26f009a070e840fadacb91013b2391ba7ab6cc2 upstream. The register access to enable hardware flow control depends on the device port number and not the port minor number. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: mos7720: fix message timeoutsJohan Hovold
commit 849513a7809175420d353625b6f651d961e99d49 upstream. The control and bulk-message timeouts are specified in milliseconds and should not depend on HZ. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: mos7720: fix DMA to stackJohan Hovold
commit 72ea18a558ed7a63a50bb121ba60d73b5b38ae30 upstream. The read_mos_reg function is called with stack-allocated buffers, which must not be used for control messages. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: revert periodic scheduling bugfixAlan Stern
commit fdc03438f53a00294ed9939eb3a1f6db6f3d8963 upstream. This patch reverts commit 3e619d04159be54b3daa0b7036b0ce9e067f4b5d (USB: EHCI: fix bug in scheduling periodic split transfers). The commit was valid -- it fixed a real bug -- but the periodic scheduler in ehci-hcd is in such bad shape (especially the part that handles split transactions) that fixing one bug is very likely to cause another to surface. That's what happened in this case; the result was choppy and noisy playback on certain 24-bit audio devices. The only real fix will be to rewrite this entire section of code. My next project... This fixes https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1136110. Thanks to Tim Richardson for extra testing and feedback, and to Joseph Salisbury and Tyson Tan for tracking down the original source of the problem. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Joseph Salisbury <joseph.salisbury@canonical.com> CC: Tim Richardson <tim@tim-richardson.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: serial: fix Treo/Kyocera interrrupt-in urb contextJohan Hovold
commit 5f8e2c07d75967ee49a5da1d21ddf5f50d48cda0 upstream. The first and second interrupt-in urbs are swapped for some Treo/Kyocera devices, but the urb context was never updated with the new port. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: whiteheat: fix broken port configurationJohan Hovold
commit 9eecf22d2b375b9064a20421c6c307b760b03d46 upstream. When configuring the port (e.g. set_termios) the port minor number rather than the port number was used in the request (and they only coincide for minor number 0). Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: Serial: cypress_M8: Enable FRWD Dongle hidcom deviceRobert Butora
commit 6529591e3eef65f0f528a81ac169f6e294b947a7 upstream. The patch adds a new HIDCOM device and does not affect other devices driven by the cypress_M8 module. Changes are: - add VendorID ProductID to device tables - skip unstable speed check because FRWD uses 115200bps - skip reset at probe which is an issue workaround for this particular device. Signed-off-by: Robert Butora <robert.butora.fi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: visor: fix initialisation of Treo/Kyocera devicesJohan Hovold
commit 420021a395ce38b7ab2cceb52dee4038be7d8fa3 upstream. Fix regression introduced by commit 214916f2e ("USB: visor: reimplement using generic framework") which broke initialisation of Treo/Kyocera devices that re-mapped bulk-in endpoints. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: ark3116: fix control-message timeoutJohan Hovold
commit 634371911730a462626071065b64cd6e1fe213e0 upstream. The control-message timeout is specified in milliseconds and should not depend on HZ. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: keyspan: fix bogus array indexJohan Hovold
commit a07088098a650267b2eda689538133a324b9523f upstream. The outcont_endpoints array was indexed using the port minor number (which can be greater than the array size) rather than the device port number. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: iuu_phoenix: fix bulk-message timeoutJohan Hovold
commit 6c13ff68a7ce01da7a51b44241a7aad8eaaedde7 upstream. The bulk-message timeout is specified in milliseconds and should not depend on HZ. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13ALSA: usb-audio - Fix invalid volume resolution on Logitech HD webcam c270Takashi Iwai
commit 11e7064f35bb87da8f427d1aa4bbd8b7473a3993 upstream. USB audio driver spews an error message when probing Logitech HD webcam c270: ALSA mixer.c:1300 usb_audio: Warning! Unlikely big volume range (=6144), cval->res is probably wrong. ALSA mixer.c:1304 usb_audio: [5] FU [Mic Capture Volume] ch = 1, val = 1536/7680/1 Obviously the device needs a fixed volume resolution (cval->res = 384) like other Logitech devices. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=821735 Reported-and-tested-by: Cristian Rodríguez <crrodriguez@opensuse.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13ALSA: usb-audio - Apply Logitech QuickCam Pro 9000 quirk only to audio ifaceTakashi Iwai
commit 8eafc0a161123d90617c9ca2eddfe87b382b1b89 upstream. ... instead of applying to all interfaces. Reference: http://forums.gentoo.org/viewtopic-p-6886404.html Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13ALSA: usb-audio: fix Roland/Cakewalk UM-3G supportClemens Ladisch
commit a0c6d309c6df14655f9962f666d1da96318b0b7c upstream. Commit 927c9423dd5f2d1c0b93d5e694ab84b4a5559713 (ALSA: usb-audio: add Edirol UM-3G support) used a wrong quirk type, which would make the driver refuse to attach with the error message "MIDIStreaming interface descriptor not found". Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13xhci: fix list access before initVladimir Murzin
commit 88696ae432ce7321540ac53d9caab3de9118b094 upstream. If for whatever reason we fall into fail path in xhci_mem_init() before bw table gets initialized we may access the uninitialized lists in xhci_mem_cleanup(). Check for bw table before traversing lists in cleanup routine. This patch should be backported to kernels as old as 3.2, that contain the commit 839c817ce67178ca3c7c7ad534c571bba1e69ebe "xhci: Store information about roothubs and TTs." Reported-by: Sergey Dyasly <dserrg@gmail.com> Tested-by: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Vladimir Murzin <murzin.v@gmail.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13xhci-mem: init list heads at the beginning of initSergio Aguirre
commit 331de00a64e5027365145bdf51da27b9ce15dfd5 upstream. It is possible that we fail on xhci_mem_init, just before doing the INIT_LIST_HEAD, and calling xhci_mem_cleanup. Problem is that, the list_for_each_entry_safe macro, assumes list heads are initialized (not NULL), and dereferences their 'next' pointer, causing a kernel panic if this is not yet initialized. Let's protect from that by moving inits to the beginning. This patch should be backported to kernels as old as 3.2, that contain the commit 9574323c39d1f8359a04843075d89c9f32d8b7e6 "xHCI: test USB2 software LPM". Signed-off-by: Sergio Aguirre <sergio.a.aguirre.rodriguez@intel.com> Acked-by: David Cohen <david.a.cohen@intel.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13xhci - correct comp_mode_recovery_timer on return from hibernateTony Camuso
commit 77df9e0b799b03e1d5d9c68062709af5f637e834 upstream. Commit 71c731a2 (usb: host: xhci: Fix Compliance Mode on SN65LVPE502CP Hardware) was a workaround for systems using the SN65LVPE502CP, controller, but it introduced a bug in resume from hibernate. The fix created a timer, comp_mode_recovery_timer, which is deleted from a timer list when xhci_suspend() is called. However, the hibernate image, including the timer list containing the comp_mode_recovery_timer, had already been saved before the timer was deleted. Upon resume from hibernate, the list containing the comp_mode_recovery_timer is restored from the image saved to disk, and xhci_resume(), assuming that the timer had been deleted by xhci_suspend(), makes a call to compliance_mode_recoery_timer_init(), which creates a new instance of the comp_mode_recovery_timer and attempts to place it into the same list in which it is already active, thus corrupting the list during the list_add() call. At this point, a call trace is emitted indicating the list corruption. Soon afterward, the system locks up, the watchdog times out, and the ensuing NMI crashes the system. The problem did not occur when resuming from suspend. In suspend, the image in RAM remains exactly as it was when xhci_suspend() deleted the comp_mode_recovery_timer, so there is no problem when xhci_resume() creates a new instance of this timer and places it in the still empty list. This patch avoids the problem by deleting the timer in xhci_resume() when resuming from hibernate. Now xhci_resume() can safely make the call to create a new instance of this timer, whether returning from suspend or hibernate. Thanks to Alan Stern for his help with understanding the problem. [Sarah reworked this patch to cover the case where the xHCI restore register operation fails, and (temp & STS_SRE) is true (and we re-init the host, including re-init for the compliance mode), but hibernate is false. The original patch would have caused list corruption in this case.] This patch should be backported to kernels as old as 3.2, that contain the commit 71c731a296f1b08a3724bd1b514b64f1bda87a23 "usb: host: xhci: Fix Compliance Mode on SN65LVPE502CP Hardware" Signed-off-by: Tony Camuso <tcamuso@redhat.com> Tested-by: Tony Camuso <tcamuso@redhat.com> Acked-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13USB: option: blacklist network interface on Huawei E1820Bjørn Mork
commit b8a24e6281d37243c06b9497dcbfaa98c1e2ad35 upstream. The mode used by Windows for the Huawei E1820 will use the same ff/ff/ff class codes for both serial and network functions. Reported-by: Graham Inggs <graham.inggs@uct.ac.za> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07Linux 3.4.48v3.4.48Greg Kroah-Hartman
2013-06-07thinkpad-acpi: recognize latest V-Series using DMI_BIOS_VENDORManoj Iyer
commit a4f46bb9fa84642e356898ee44b670989622f8bb upstream. In the latest V-series bios DMI_PRODUCT_VERSION does not contain the string Lenovo or Thinkpad, but is set to the model number, this causes the thinkpad_acpi module to fail to load. Recognize laptop as Lenovo using DMI_BIOS_VENDOR instead, which is set to Lenovo. Test on V490u ============= == After the patch == [ 1350.295757] thinkpad_acpi: ThinkPad ACPI Extras v0.24 [ 1350.295760] thinkpad_acpi: http://ibm-acpi.sf.net/ [ 1350.295761] thinkpad_acpi: ThinkPad BIOS H7ET21WW (1.00 ), EC unknown [ 1350.295763] thinkpad_acpi: Lenovo LENOVO, model LV5DXXX [ 1350.296086] thinkpad_acpi: detected a 8-level brightness capable ThinkPad [ 1350.296694] thinkpad_acpi: radio switch found; radios are enabled [ 1350.296703] thinkpad_acpi: possible tablet mode switch found; ThinkPad in laptop mode [ 1350.306466] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked [ 1350.307082] Registered led device: tpacpi::thinklight [ 1350.307215] Registered led device: tpacpi::power [ 1350.307255] Registered led device: tpacpi::standby [ 1350.307294] Registered led device: tpacpi::thinkvantage [ 1350.308160] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one [ 1350.308333] thinkpad_acpi: Console audio control enabled, mode: monitor (read only) [ 1350.312287] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input14 == Before the patch == sudo modprobe thinkpad_acpi FATAL: Error inserting thinkpad_acpi (/lib/modules/3.2.0-27-generic/kernel/drivers/platform/x86/thinkpad_acpi.ko): No such device Test on B485 ============= This patch was also test in a B485 where the thinkpad_acpi module does not have any issues loading. But, I tested it to make sure this patch does not break on already functioning models of Lenovo products. [13486.746359] thinkpad_acpi: ThinkPad ACPI Extras v0.24 [13486.746364] thinkpad_acpi: http://ibm-acpi.sf.net/ [13486.746368] thinkpad_acpi: ThinkPad BIOS HJET15WW(1.01), EC unknown [13486.746373] thinkpad_acpi: Lenovo Lenovo LB485, model 814TR01 [13486.747300] thinkpad_acpi: detected a 8-level brightness capable ThinkPad [13486.752435] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked [13486.752883] Registered led device: tpacpi::thinklight [13486.752915] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one [13486.753216] thinkpad_acpi: Console audio control enabled, mode: monitor (read only) [13486.757147] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input15 Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Shuduo Sang <shuduo.sang@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07mac80211: close AP_VLAN interfaces before unregistering allJohannes Berg
commit c8aa22db0112f640ac6631347f850879c621840b upstream. Since Eric's commit efe117ab8 ("Speedup ieee80211_remove_interfaces") there's a bug in mac80211 when it unregisters with AP_VLAN interfaces up. If the AP_VLAN interface was registered after the AP it belongs to (which is the typical case) and then we get into this code path, unregister_netdevice_many() will crash because it isn't prepared to deal with interfaces being closed in the middle of it. Exactly this happens though, because we iterate the list, find the AP master this AP_VLAN belongs to and dev_close() the dependent VLANs. After this, unregister_netdevice_many() won't pick up the fact that the AP_VLAN is already down and will do it again, causing a crash. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07x86, um: Correct syscall table type attributes breaking gcc 4.8Martin Pelikan
commit 9271b0b4b2044c6db06051fe60bc58cdd4f17c7c upstream. The latest GCC 4.8 does some more checking on type attributes that break the build for ARCH=um -> fill them in. Specifically, the "asmlinkage" attributes is now tested for consistency. Signed-off-by: Martin Pelikan <pelikan@storkhole.cz> Link: http://lkml.kernel.org/r/1339269731-10772-1-git-send-email-pelikan@storkhole.cz Acked-by: Richard Weinberger <richard@nod.at> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Bernhard M. Wiedemann <bwiedemann@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07iommu/amd: Workaround for ERBT1312Joerg Roedel
commit d3263bc29706e42f74d8800807c2dedf320d77f1 upstream. Work around an IOMMU hardware bug where clearing the EVT_INT or PPR_INT bit in the status register may race with the hardware trying to set it again. When not handled the bit might not be cleared and we lose all future event or ppr interrupts. Reported-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07iommu/amd: Re-enable IOMMU event log interrupt after handling.Suravee Suthikulpanit
commit 925fe08bce38d1ff052fe2209b9e2b8d5fbb7f98 upstream. Current driver does not clear the IOMMU event log interrupt bit in the IOMMU status register after processing an interrupt. This causes the IOMMU hardware to generate event log interrupt only once. This has been observed in both IOMMU v1 and V2 hardware. This patch clears the bit by writing 1 to bit 1 of the IOMMU status register (MMIO Offset 2020h) Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07xen-netback: remove skb in xen_netbk_alloc_pageWei Liu
commit 27f852282ab9a028f57da96d05c26f38c424a315 upstream. This variable is never used. Signed-off-by: Wei Liu <wei.liu2@citrix.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07jfs: fix a couple racesDave Kleikamp
commit 73aaa22d5ffb2630456bac2f9a4ed9b81d0d7271 upstream. This patch fixes races uncovered by xfstests testcase 068. One race is the result of jfs_sync() trying to write a sync point to the journal after it has been frozen (or possibly in the process). Since freezing sync's the journal, there is no need to write a sync point so we simply want to return. The second involves jfs_write_inode() being called on a deleted inode. It calls jfs_flush_journal which is held up by the jfs_commit thread doing the final iput on the same deleted inode, which itself is waiting for the I_SYNC flag to be cleared. jfs_write_inode need not do anything when i_nlink is zero, which is the easy fix. Reported-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07xen/events: Handle VIRQ_TIMER before any other hardirq in event loop.Keir Fraser
commit bee980d9e9642e96351fa3ca9077b853ecf62f57 upstream. This avoids any other hardirq handler seeing a very stale jiffies value immediately after wakeup from a long idle period. The one observable symptom of this was a USB keyboard, with software keyboard repeat, which would always repeat a key immediately that it was pressed. This is due to the key press waking the guest, the key handler immediately runs, sees an old jiffies value, and then that jiffies value significantly updated, before the key is unpressed. Reviewed-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Keir Fraser <keir.fraser@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07m68k/mac: Fix unexpected interrupt with CONFIG_EARLY_PRINTKFinn Thain
commit df66834a43c461de2565c45d815288ba1c0def37 upstream. The present code does not wait for the SCC to finish resetting itself before trying to initialise the device. The result is that the SCC interrupt sources become enabled (if they weren't already). This leads to an early boot crash (unexpected interrupt) given CONFIG_EARLY_PRINTK. Fix this by adding a delay. A successful reset disables the interrupt sources. Also, after the reset for channel A setup, the SCC then gets a second reset for channel B setup which leaves channel A uninitialised again. Fix this by performing the reset only once. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07libata: make ata_exec_internal_sg honor DMADIRVincent Pelletier
commit e771451c0a831d96a7c14b0ca8a8ec671d98567b upstream. libata honors DMADIR for regular commands, but not for internal commands used (among other) during device initialisation. This makes SATA-host-to-PATA-device bridges based on Silicon Image SiL3611 (such as "Abit Serillel 2") end up disabled when used with an ATAPI device after a few tries. Log output of the bridge being hot-plugged with an ATAPI drive: [ 9631.212901] ata1: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen [ 9631.212913] ata1: irq_stat 0x00000040, connection status changed [ 9631.212923] ata1: SError: { CommWake 10B8B DevExch } [ 9631.212939] ata1: hard resetting link [ 9632.104962] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 9632.106393] ata1.00: ATAPI: PIONEER DVD-RW DVR-115, 1.06, max UDMA/33 [ 9632.106407] ata1.00: applying bridge limits [ 9632.108151] ata1.00: configured for UDMA/33 [ 9637.105303] ata1.00: qc timeout (cmd 0xa0) [ 9637.105324] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5) [ 9637.105335] ata1: hard resetting link [ 9638.044599] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 9638.047878] ata1.00: configured for UDMA/33 [ 9643.044933] ata1.00: qc timeout (cmd 0xa0) [ 9643.044953] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5) [ 9643.044963] ata1: limiting SATA link speed to 1.5 Gbps [ 9643.044971] ata1.00: limiting speed to UDMA/33:PIO3 [ 9643.044979] ata1: hard resetting link [ 9643.984225] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310) [ 9643.987471] ata1.00: configured for UDMA/33 [ 9648.984591] ata1.00: qc timeout (cmd 0xa0) [ 9648.984612] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5) [ 9648.984619] ata1.00: disabled [ 9649.000593] ata1: hard resetting link [ 9649.939902] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310) [ 9649.955864] ata1: EH complete With this patch, the drive enumerates correctly when libata is loaded with atapi_dmadir=1: [ 9891.810863] ata1: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen [ 9891.810874] ata1: irq_stat 0x00000040, connection status changed [ 9891.810884] ata1: SError: { CommWake 10B8B DevExch } [ 9891.810900] ata1: hard resetting link [ 9892.762105] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 9892.763544] ata1.00: ATAPI: PIONEER DVD-RW DVR-115, 1.06, max UDMA/33, DMADIR [ 9892.763558] ata1.00: applying bridge limits [ 9892.765393] ata1.00: configured for UDMA/33 [ 9892.786063] ata1: EH complete [ 9892.792062] scsi 0:0:0:0: CD-ROM PIONEER DVD-RW DVR-115 1.06 PQ: 0 ANSI: 5 [ 9892.798455] sr2: scsi3-mmc drive: 12x/12x writer dvd-ram cd/rw xa/form2 cdda tray [ 9892.798837] sr 0:0:0:0: Attached scsi CD-ROM sr2 [ 9892.799109] sr 0:0:0:0: Attached scsi generic sg6 type 5 Based on a patch by Csaba Halász <csaba.halasz@gmail.com> on linux-ide: http://marc.info/?l=linux-ide&m=136121147832295&w=2 tj: minor formatting changes. Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07ata_piix: add PCI IDs for Intel BayTailChew, Chiau Ee
commit fca8c90d519dedd4f4b19901d005c243f7f0bf2e upstream. Adds IDE-mode SATA Device IDs for the Intel BayTrail platform. Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07USB: io_ti: Fix NULL dereference in chase_port()Wolfgang Frisch
commit 1ee0a224bc9aad1de496c795f96bc6ba2c394811 upstream. The tty is NULL when the port is hanging up. chase_port() needs to check for this. This patch is intended for stable series. The behavior was observed and tested in Linux 3.2 and 3.7.1. Johan Hovold submitted a more elaborate patch for the mainline kernel. [ 56.277883] usb 1-1: edge_bulk_in_callback - nonzero read bulk status received: -84 [ 56.278811] usb 1-1: USB disconnect, device number 3 [ 56.278856] usb 1-1: edge_bulk_in_callback - stopping read! [ 56.279562] BUG: unable to handle kernel NULL pointer dereference at 00000000000001c8 [ 56.280536] IP: [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35 [ 56.281212] PGD 1dc1b067 PUD 1e0f7067 PMD 0 [ 56.282085] Oops: 0002 [#1] SMP [ 56.282744] Modules linked in: [ 56.283512] CPU 1 [ 56.283512] Pid: 25, comm: khubd Not tainted 3.7.1 #1 innotek GmbH VirtualBox/VirtualBox [ 56.283512] RIP: 0010:[<ffffffff8144e62a>] [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35 [ 56.283512] RSP: 0018:ffff88001fa99ab0 EFLAGS: 00010046 [ 56.283512] RAX: 0000000000000046 RBX: 00000000000001c8 RCX: 0000000000640064 [ 56.283512] RDX: 0000000000010000 RSI: ffff88001fa99b20 RDI: 00000000000001c8 [ 56.283512] RBP: ffff88001fa99b20 R08: 0000000000000000 R09: 0000000000000000 [ 56.283512] R10: 0000000000000000 R11: ffffffff812fcb4c R12: ffff88001ddf53c0 [ 56.283512] R13: 0000000000000000 R14: 00000000000001c8 R15: ffff88001e19b9f4 [ 56.283512] FS: 0000000000000000(0000) GS:ffff88001fd00000(0000) knlGS:0000000000000000 [ 56.283512] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 56.283512] CR2: 00000000000001c8 CR3: 000000001dc51000 CR4: 00000000000006e0 [ 56.283512] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 56.283512] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 56.283512] Process khubd (pid: 25, threadinfo ffff88001fa98000, task ffff88001fa94f80) [ 56.283512] Stack: [ 56.283512] 0000000000000046 00000000000001c8 ffffffff810578ec ffffffff812fcb4c [ 56.283512] ffff88001e19b980 0000000000002710 ffffffff812ffe81 0000000000000001 [ 56.283512] ffff88001fa94f80 0000000000000202 ffffffff00000001 0000000000000296 [ 56.283512] Call Trace: [ 56.283512] [<ffffffff810578ec>] ? add_wait_queue+0x12/0x3c [ 56.283512] [<ffffffff812fcb4c>] ? usb_serial_port_work+0x28/0x28 [ 56.283512] [<ffffffff812ffe81>] ? chase_port+0x84/0x2d6 [ 56.283512] [<ffffffff81063f27>] ? try_to_wake_up+0x199/0x199 [ 56.283512] [<ffffffff81263a5c>] ? tty_ldisc_hangup+0x222/0x298 [ 56.283512] [<ffffffff81300171>] ? edge_close+0x64/0x129 [ 56.283512] [<ffffffff810612f7>] ? __wake_up+0x35/0x46 [ 56.283512] [<ffffffff8106135b>] ? should_resched+0x5/0x23 [ 56.283512] [<ffffffff81264916>] ? tty_port_shutdown+0x39/0x44 [ 56.283512] [<ffffffff812fcb4c>] ? usb_serial_port_work+0x28/0x28 [ 56.283512] [<ffffffff8125d38c>] ? __tty_hangup+0x307/0x351 [ 56.283512] [<ffffffff812e6ddc>] ? usb_hcd_flush_endpoint+0xde/0xed [ 56.283512] [<ffffffff8144e625>] ? _raw_spin_lock_irqsave+0x14/0x35 [ 56.283512] [<ffffffff812fd361>] ? usb_serial_disconnect+0x57/0xc2 [ 56.283512] [<ffffffff812ea99b>] ? usb_unbind_interface+0x5c/0x131 [ 56.283512] [<ffffffff8128d738>] ? __device_release_driver+0x7f/0xd5 [ 56.283512] [<ffffffff8128d9cd>] ? device_release_driver+0x1a/0x25 [ 56.283512] [<ffffffff8128d393>] ? bus_remove_device+0xd2/0xe7 [ 56.283512] [<ffffffff8128b7a3>] ? device_del+0x119/0x167 [ 56.283512] [<ffffffff812e8d9d>] ? usb_disable_device+0x6a/0x180 [ 56.283512] [<ffffffff812e2ae0>] ? usb_disconnect+0x81/0xe6 [ 56.283512] [<ffffffff812e4435>] ? hub_thread+0x577/0xe82 [ 56.283512] [<ffffffff8144daa7>] ? __schedule+0x490/0x4be [ 56.283512] [<ffffffff8105798f>] ? abort_exclusive_wait+0x79/0x79 [ 56.283512] [<ffffffff812e3ebe>] ? usb_remote_wakeup+0x2f/0x2f [ 56.283512] [<ffffffff812e3ebe>] ? usb_remote_wakeup+0x2f/0x2f [ 56.283512] [<ffffffff810570b4>] ? kthread+0x81/0x89 [ 56.283512] [<ffffffff81057033>] ? __kthread_parkme+0x5c/0x5c [ 56.283512] [<ffffffff8145387c>] ? ret_from_fork+0x7c/0xb0 [ 56.283512] [<ffffffff81057033>] ? __kthread_parkme+0x5c/0x5c [ 56.283512] Code: 8b 7c 24 08 e8 17 0b c3 ff 48 8b 04 24 48 83 c4 10 c3 53 48 89 fb 41 50 e8 e0 0a c3 ff 48 89 04 24 e8 e7 0a c3 ff ba 00 00 01 00 <f0> 0f c1 13 48 8b 04 24 89 d1 c1 ea 10 66 39 d1 74 07 f3 90 66 [ 56.283512] RIP [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35 [ 56.283512] RSP <ffff88001fa99ab0> [ 56.283512] CR2: 00000000000001c8 [ 56.283512] ---[ end trace 49714df27e1679ce ]--- Signed-off-by: Wolfgang Frisch <wfpub@roembden.net> Cc: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07cifs: fix potential buffer overrun when composing a new options stringJeff Layton
commit 166faf21bd14bc5c5295a44874bf7f3930c30b20 upstream. Consider the case where we have a very short ip= string in the original mount options, and when we chase a referral we end up with a very long IPv6 address. Be sure to allow for that possibility when estimating the size of the string to allocate. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07drm/radeon: fix card_posted check for newer asicsAlex Deucher
commit 09fb8bd1a63b0f9f15e655c4fe8d047e5d2bf67a upstream. Newer asics have variable numbers of crtcs. Use that rather than the asic family to determine which crtcs to check. This avoids checking non-existent crtcs or missing crtcs on certain asics. Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07xfs: kill suid/sgid through the truncate path.Dave Chinner
commit 2962f5a5dcc56f69cbf62121a7be67cc15d6940b upstream. XFS has failed to kill suid/sgid bits correctly when truncating files of non-zero size since commit c4ed4243 ("xfs: split xfs_setattr") introduced in the 3.1 kernel. Fix it. Fix it. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07NFSv4: Fix a thinko in nfs4_try_open_cachedTrond Myklebust
commit f448badd34700ae728a32ba024249626d49c10e1 upstream. We need to pass the full open mode flags to nfs_may_open() when doing a delegated open. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
