2013-09-07Linux 3.4.61v3.4.61Greg Kroah-Hartman
2013-09-07SCSI: sg: Fix user memory corruption when SG_IO is interrupted by a signalRoland Dreier
commit 35dc248383bbab0a7203fca4d722875bc81ef091 upstream. There is a nasty bug in the SCSI SG_IO ioctl that in some circumstances leads to one process writing data into the address space of some other random unrelated process if the ioctl is interrupted by a signal. What happens is the following: - A process issues an SG_IO ioctl with direction DXFER_FROM_DEV (ie the underlying SCSI command will transfer data from the SCSI device to the buffer provided in the ioctl) - Before the command finishes, a signal is sent to the process waiting in the ioctl. This will end up waking up the sg_ioctl() code: result = wait_event_interruptible(sfp->read_wait, (srp_done(sfp, srp) || sdp->detached)); but neither srp_done() nor sdp->detached is true, so we end up just setting srp->orphan and returning to userspace: srp->orphan = 1; write_unlock_irq(&sfp->rq_list_lock); return result; /* -ERESTARTSYS because signal hit process */ At this point the original process is done with the ioctl and blithely goes ahead handling the signal, reissuing the ioctl, etc. - Eventually, the SCSI command issued by the first ioctl finishes and ends up in sg_rq_end_io(). At the end of that function, we run through: write_lock_irqsave(&sfp->rq_list_lock, iflags); if (unlikely(srp->orphan)) { if (sfp->keep_orphan) srp->sg_io_owned = 0; else done = 0; } srp->done = done; write_unlock_irqrestore(&sfp->rq_list_lock, iflags); if (likely(done)) { /* Now wake up any sg_read() that is waiting for this * packet. */ wake_up_interruptible(&sfp->read_wait); kill_fasync(&sfp->async_qp, SIGPOLL, POLL_IN); kref_put(&sfp->f_ref, sg_remove_sfp); } else { INIT_WORK(&srp->ew.work, sg_rq_end_io_usercontext); schedule_work(&srp->ew.work); } Since srp->orphan *is* set, we set done to 0 (assuming the userspace app has not set keep_orphan via an SG_SET_KEEP_ORPHAN ioctl), and therefore we end up scheduling sg_rq_end_io_usercontext() to run in a workqueue. - In workqueue context we go through sg_rq_end_io_usercontext() -> sg_finish_rem_req() -> blk_rq_unmap_user() -> ... -> bio_uncopy_user() -> __bio_copy_iov() -> copy_to_user(). The key point here is that we are doing copy_to_user() on a workqueue -- that is, we're on a kernel thread with current->mm equal to whatever random previous user process was scheduled before this kernel thread. So we end up copying whatever data the SCSI command returned to the virtual address of the buffer passed into the original ioctl, but it's quite likely we do this copying into a different address space! As suggested by James Bottomley <James.Bottomley@hansenpartnership.com>, add a check for current->mm (which is NULL if we're on a kernel thread without a real userspace address space) in bio_uncopy_user(), and skip the copy if we're on a kernel thread. There's no reason that I can think of for any caller of bio_uncopy_user() to want to do copying on a kernel thread with a random active userspace address space. Huge thanks to Costa Sapuntzakis <costa@purestorage.com> for the original pointer to this bug in the sg code. Signed-off-by: Roland Dreier <roland@purestorage.com> Tested-by: David Milburn <dmilburn@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Bottomley <JBottomley@Parallels.com> [lizf: backported to 3.4: - Use __bio_for_each_segment() instead of bio_for_each_segment_all()] Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07target: Fix trailing ASCII space usage in INQUIRY vendor+modelNicholas Bellinger
commit ee60bddba5a5f23e39598195d944aa0eb2d455e5 upstream. This patch fixes spc_emulate_inquiry_std() to add trailing ASCII spaces for INQUIRY vendor + model fields following SPC-4 text: "ASCII data fields described as being left-aligned shall have any unused bytes at the end of the field (i.e., highest offset) and the unused bytes shall be filled with ASCII space characters (20h)." This addresses a problem with Falconstor NSS multipathing. Reported-by: Tomas Molota <tomas.molota@lightstorm.sk> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07ACPI / EC: Add ASUSTEK L4R to quirk list in order to validate ECDTLan Tianyu
commit 524f42fab787a9510be826ce3d736b56d454ac6d upstream. The ECDT of ASUSTEK L4R doesn't provide correct command and data I/O ports. The DSDT provides the correct information instead. For this reason, add this machine to quirk list for ECDT validation and use the EC information from the DSDT. [rjw: Changelog] References: https://bugzilla.kernel.org/show_bug.cgi?id=60765 Reported-and-tested-by: Daniele Esposti <expo@expobrain.net> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07iwl4965: fix rfkill set state regressionStanislaw Gruszka
commit b2fcc0aee58a3435566dd6d8501a0b355552f28b upstream. My current 3.11 fix: commit 788f7a56fce1bcb2067b62b851a086fca48a0056 Author: Stanislaw Gruszka <sgruszka@redhat.com> Date: Thu Aug 1 12:07:55 2013 +0200 iwl4965: reset firmware after rfkill off broke rfkill notification to user-space . I missed that bug, because I compiled without CONFIG_RFKILL, sorry about that. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07ath9k_htc: Restore skb headroom when returning skb to mac80211Helmut Schaa
commit d2e9fc141e2aa21f4b35ee27072d84e9aa6e2ba0 upstream. ath9k_htc adds padding between the 802.11 header and the payload during TX by moving the header. When handing the frame back to mac80211 for TX status handling the header is not moved back into its original position. This can result in a too small skb headroom when entering ath9k_htc again (due to a soft retransmission for example) causing an skb_under_panic oops. Fix this by moving the 802.11 header back into its original position before returning the frame to mac80211 as other drivers like rt2x00 or ath5k do. Reported-by: Marc Kleine-Budde <mkl@blackshift.org> Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Tested-by: Marc Kleine-Budde <mkl@blackshift.org> Signed-off-by: Marc Kleine-Budde <mkl@blackshift.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07SUNRPC: Fix memory corruption issue on 32-bit highmem systemsTrond Myklebust
commit 347e2233b7667e336d9f671f1a52dfa3f0416e2c upstream. Some architectures, such as ARM-32 do not return the same base address when you call kmap_atomic() twice on the same page. This causes problems for the memmove() call in the XDR helper routine "_shift_data_right_pages()", since it defeats the detection of overlapping memory ranges, and has been seen to corrupt memory. The fix is to distinguish between the case where we're doing an inter-page copy or not. In the former case of we know that the memory ranges cannot possibly overlap, so we can additionally micro-optimise by replacing memmove() with memcpy(). Reported-by: Mark Young <MYoung@nvidia.com> Reported-by: Matt Craighead <mcraighead@nvidia.com> Cc: Bruce Fields <bfields@fieldses.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Matt Craighead <mcraighead@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07drm/i915: ivb: fix edp voltage swing reg valImre Deak
commit 77fa4cbd5fa389e28419bbe8ac491b5fdd54840d upstream. Fix the typo introduced in commit 1a2eb4604b85c5efb343da8a4dcf41288fcfca85 Author: Keith Packard <keithp@keithp.com> Date: Wed Nov 16 16:26:07 2011 -0800 drm/i915: Hook up Ivybridge eDP This fixes eDP link-training failures and cases where all voltage swing /pre-emphasis levels were tried and failed during clock recovery and - as a fallback - we go on to do channel equalization with the last voltage swing/pre-emphasis level which will succeed. Both issues can lead to a blank screen. v2: - improve commit message Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=64880 Tested-by: Jeremy Moles <cubicool@gmail.com> Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07drm/vmwgfx: Split GMR2_REMAP commands if they are to largeJakob Bornecrantz
commit 6e4dcff3adbf25acb87e74500a58e3c07bdec40f upstream. This fixes the piglit test texturing/max-texture-size causing the VM to die due to a too large SVGA command. Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Reviewed-by: Biran Paul <brianp@vmware.com> Reviewed-by: Zack Rusin <zackr@vmware.com> Signed-off-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07drivers/base/memory.c: fix show_mem_removable() to handle missing sectionsRuss Anderson
commit 21ea9f5ace3a7317cc3ba1fbc749758021a83136 upstream. "cat /sys/devices/system/memory/memory*/removable" crashed the system. The problem is that show_mem_removable() is passing a bad pfn to is_mem_section_removable(), which causes if (!node_online(page_to_nid(page))) to blow up. Why is it passing in a bad pfn? The reason is that show_mem_removable() will loop sections_per_block times. sections_per_block is 16, but mem->section_count is 8, indicating holes in this memory block. Checking that the memory section is present before checking to see if the memory section is removable fixes the problem. harp5-sys:~ # cat /sys/devices/system/memory/memory*/removable 0 1 1 1 1 1 1 1 1 1 1 1 1 1 BUG: unable to handle kernel paging request at ffffea00c3200000 IP: [<ffffffff81117ed1>] is_pageblock_removable_nolock+0x1/0x90 PGD 83ffd4067 PUD 37bdfce067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: autofs4 binfmt_misc rdma_ucm rdma_cm iw_cm ib_addr ib_srp scsi_transport_srp scsi_tgt ib_ipoib ib_cm ib_uverbs ib_umad iw_cxgb3 cxgb3 mdio mlx4_en mlx4_ib ib_sa mlx4_core ib_mthca ib_mad ib_core fuse nls_iso8859_1 nls_cp437 vfat fat joydev loop hid_generic usbhid hid hwperf(O) numatools(O) dm_mod iTCO_wdt ipv6 iTCO_vendor_support igb i2c_i801 ioatdma i2c_algo_bit ehci_pci pcspkr lpc_ich i2c_core ehci_hcd ptp sg mfd_core dca rtc_cmos pps_core mperf button xhci_hcd sd_mod crc_t10dif usbcore usb_common scsi_dh_emc scsi_dh_hp_sw scsi_dh_alua scsi_dh_rdac scsi_dh gru(O) xvma(O) xfs crc32c libcrc32c thermal sata_nv processor piix mptsas mptscsih scsi_transport_sas mptbase megaraid_sas fan thermal_sys hwmon ext3 jbd ata_piix ahci libahci libata scsi_mod CPU: 4 PID: 5991 Comm: cat Tainted: G O 3.11.0-rc5-rja-uv+ #10 Hardware name: SGI UV2000/ROMLEY, BIOS SGI UV 2000/3000 series BIOS 01/15/2013 task: ffff88081f034580 ti: ffff880820022000 task.ti: ffff880820022000 RIP: 0010:[<ffffffff81117ed1>] [<ffffffff81117ed1>] is_pageblock_removable_nolock+0x1/0x90 RSP: 0018:ffff880820023df8 EFLAGS: 00010287 RAX: 0000000000040000 RBX: ffffea00c3200000 RCX: 0000000000000004 RDX: ffffea00c30b0000 RSI: 00000000001c0000 RDI: ffffea00c3200000 RBP: ffff880820023e38 R08: 0000000000000000 R09: 0000000000000001 R10: 0000000000000000 R11: 0000000000000001 R12: ffffea00c33c0000 R13: 0000160000000000 R14: 6db6db6db6db6db7 R15: 0000000000000001 FS: 00007ffff7fb2700(0000) GS:ffff88083fc80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffffea00c3200000 CR3: 000000081b954000 CR4: 00000000000407e0 Call Trace: show_mem_removable+0x41/0x70 dev_attr_show+0x2a/0x60 sysfs_read_file+0xf7/0x1c0 vfs_read+0xc8/0x130 SyS_read+0x5d/0xa0 system_call_fastpath+0x16/0x1b Signed-off-by: Russ Anderson <rja@sgi.com> Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com> Cc: Yinghai Lu <yinghai@kernel.org> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07regmap: silence GCC warningPaul Bolle
commit a8f28cfad8cd44d7c34b166d0e5ace1125dbee1f upstream. Building regmap.o triggers this GCC warning: drivers/base/regmap/regmap.c: In function ‘regmap_raw_read’: drivers/base/regmap/regmap.c:1172:6: warning: ‘ret’ may be used uninitialized in this function [-Wmaybe-uninitialized] Long story short: Jakub Jelinek pointed out that there is a type mismatch between 'num' in regmap_volatile_range() and 'val_count' in regmap_raw_read(). And indeed, converting 'num' to the type of 'val_count' (ie, size_t) makes this warning go away. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07powerpc/hvsi: Increase handshake timeout from 200ms to 400ms.Eugene Surovegin
commit d220980b701d838560a70de691b53be007e99e78 upstream. This solves a problem observed in kexec'ed kernel where 200ms timeout is too short and bootconsole fails to initialize. Console did eventually become workable but much later into the boot process. Observed timeout was around 260ms, but I decided to make it a little bigger for more reliability. This has been tested on Power7 machine with Petitboot as a primary bootloader and PowerNV firmware. Signed-off-by: Eugene Surovegin <surovegin@google.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07powerpc: Work around gcc miscompilation of __pa() on 64-bitPaul Mackerras
commit bdbc29c19b2633b1d9c52638fb732bcde7a2031a upstream. On 64-bit, __pa(&static_var) gets miscompiled by recent versions of gcc as something like: addis 3,2,.LANCHOR1+4611686018427387904@toc@ha addi 3,3,.LANCHOR1+4611686018427387904@toc@l This ends up effectively ignoring the offset, since its bottom 32 bits are zero, and means that the result of __pa() still has 0xC in the top nibble. This happens with gcc 4.8.1, at least. To work around this, for 64-bit we make __pa() use an AND operator, and for symmetry, we make __va() use an OR operator. Using an AND operator rather than a subtraction ends up with slightly shorter code since it can be done with a single clrldi instruction, whereas it takes three instructions to form the constant (-PAGE_OFFSET) and add it on. (Note that MEMORY_START is always 0 on 64-bit.) Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07ALSA: opti9xx: Fix conflicting driver object nameTakashi Iwai
commit fb615499f0ad28ed74201c1cdfddf9e64e205424 upstream. The recent commit to delay the release of kobject triggered NULL dereferences of opti9xx drivers. The cause is that all snd-opti92x-ad1848, snd-opti92x-cs4231 and snd-opti93x drivers register the PnP card driver with the very same name, and also snd-opti92x-ad1848 and -cs4231 drivers register the ISA driver with the same name, too. When these drivers are built in, quick "register-release-and-re-register" actions occur, and this results in Oops because of the same name is assigned to the kobject. The fix is simply to assign individual names. As a bonus, by using KBUILD_MODNAME, the patch reduces more lines than it adds. The fix is based on the suggestion by Russell King. Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07jfs: fix readdir cookie incompatibility with NFSv4Dave Kleikamp
commit 44512449c0ab368889dd13ae0031fba74ee7e1d2 upstream. NFSv4 reserves readdir cookie values 0-2 for special entries (. and ..), but jfs allows a value of 2 for a non-special entry. This incompatibility can result in the nfs client reporting a readdir loop. This patch doesn't change the value stored internally, but adds one to the value exposed to the iterate method. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> [bwh: Backported to 3.2: - Adjust context - s/ctx->pos/filp->f_pos/] Tested-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29Linux 3.4.60v3.4.60Greg Kroah-Hartman
2013-08-29x86/xen: do not identity map UNUSABLE regions in the machine E820David Vrabel
commit 3bc38cbceb85881a8eb789ee1aa56678038b1909 upstream. If there are UNUSABLE regions in the machine memory map, dom0 will attempt to map them 1:1 which is not permitted by Xen and the kernel will crash. There isn't anything interesting in the UNUSABLE region that the dom0 kernel needs access to so we can avoid making the 1:1 mapping and treat it as RAM. We only do this for dom0, as that is where tboot case shows up. A PV domU could have an UNUSABLE region in its pseudo-physical map and would need to be handled in another patch. This fixes a boot failure on hosts with tboot. tboot marks a region in the e820 map as unusable and the dom0 kernel would attempt to map this region and Xen does not permit unusable regions to be mapped by guests. (XEN) 0000000000000000 - 0000000000060000 (usable) (XEN) 0000000000060000 - 0000000000068000 (reserved) (XEN) 0000000000068000 - 000000000009e000 (usable) (XEN) 0000000000100000 - 0000000000800000 (usable) (XEN) 0000000000800000 - 0000000000972000 (unusable) tboot marked this region as unusable. (XEN) 0000000000972000 - 00000000cf200000 (usable) (XEN) 00000000cf200000 - 00000000cf38f000 (reserved) (XEN) 00000000cf38f000 - 00000000cf3ce000 (ACPI data) (XEN) 00000000cf3ce000 - 00000000d0000000 (reserved) (XEN) 00000000e0000000 - 00000000f0000000 (reserved) (XEN) 00000000fe000000 - 0000000100000000 (reserved) (XEN) 0000000100000000 - 0000000630000000 (usable) Signed-off-by: David Vrabel <david.vrabel@citrix.com> [v1: Altered the patch and description with domU's with UNUSABLE regions] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29SCSI: zfcp: fix schedule-inside-lock in scsi_device list loopsMartin Peschke
commit 924dd584b198a58aa7cb3efefd8a03326550ce8f upstream. BUG: sleeping function called from invalid context at kernel/workqueue.c:2752 in_atomic(): 1, irqs_disabled(): 1, pid: 360, name: zfcperp0.0.1700 CPU: 1 Not tainted 3.9.3+ #69 Process zfcperp0.0.1700 (pid: 360, task: 0000000075b7e080, ksp: 000000007476bc30) <snip> Call Trace: ([<00000000001165de>] show_trace+0x106/0x154) [<00000000001166a0>] show_stack+0x74/0xf4 [<00000000006ff646>] dump_stack+0xc6/0xd4 [<000000000017f3a0>] __might_sleep+0x128/0x148 [<000000000015ece8>] flush_work+0x54/0x1f8 [<00000000001630de>] __cancel_work_timer+0xc6/0x128 [<00000000005067ac>] scsi_device_dev_release_usercontext+0x164/0x23c [<0000000000161816>] execute_in_process_context+0x96/0xa8 [<00000000004d33d8>] device_release+0x60/0xc0 [<000000000048af48>] kobject_release+0xa8/0x1c4 [<00000000004f4bf2>] __scsi_iterate_devices+0xfa/0x130 [<000003ff801b307a>] zfcp_erp_strategy+0x4da/0x1014 [zfcp] [<000003ff801b3caa>] zfcp_erp_thread+0xf6/0x2b0 [zfcp] [<000000000016b75a>] kthread+0xf2/0xfc [<000000000070c9de>] kernel_thread_starter+0x6/0xc [<000000000070c9d8>] kernel_thread_starter+0x0/0xc Apparently, the ref_count for some scsi_device drops down to zero, triggering device removal through execute_in_process_context(), while the lldd error recovery thread iterates through a scsi device list. Unfortunately, execute_in_process_context() decides to immediately execute that device removal function, instead of scheduling asynchronous execution, since it detects process context and thinks it is safe to do so. But almost all calls to shost_for_each_device() in our lldd are inside spin_lock_irq, even in thread context. Obviously, schedule() inside spin_lock_irq sections is a bad idea. Change the lldd to use the proper iterator function, __shost_for_each_device(), in combination with required locking. Occurences that need to be changed include all calls in zfcp_erp.c, since those might be executed in zfcp error recovery thread context with a lock held. Other occurences of shost_for_each_device() in zfcp_fsf.c do not need to be changed (no process context, no surrounding locking). The problem was introduced in Linux 2.6.37 by commit b62a8d9b45b971a67a0f8413338c230e3117dff5 "[SCSI] zfcp: Use SCSI device data zfcp_scsi_dev instead of zfcp_unit". Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29SCSI: zfcp: fix lock imbalance by reworking request queue lockingMartin Peschke
commit d79ff142624e1be080ad8d09101f7004d79c36e1 upstream. This patch adds wait_event_interruptible_lock_irq_timeout(), which is a straight-forward descendant of wait_event_interruptible_timeout() and wait_event_interruptible_lock_irq(). The zfcp driver used to call wait_event_interruptible_timeout() in combination with some intricate and error-prone locking. Using wait_event_interruptible_lock_irq_timeout() as a replacement nicely cleans up that locking. This rework removes a situation that resulted in a locking imbalance in zfcp_qdio_sbal_get(): BUG: workqueue leaked lock or atomic: events/1/0xffffff00/10 last function: zfcp_fc_wka_port_offline+0x0/0xa0 [zfcp] It was introduced by commit c2af7545aaff3495d9bf9a7608c52f0af86fb194 "[SCSI] zfcp: Do not wait for SBALs on stopped queue", which had a new code path related to ZFCP_STATUS_ADAPTER_QDIOUP that took an early exit without a required lock being held. The problem occured when a special, non-SCSI I/O request was being submitted in process context, when the adapter's queues had been torn down. In this case the bug surfaced when the Fibre Channel port connection for a well-known address was closed during a concurrent adapter shut-down procedure, which is a rare constellation. This patch also fixes these warnings from the sparse tool (make C=1): drivers/s390/scsi/zfcp_qdio.c:224:12: warning: context imbalance in 'zfcp_qdio_sbal_check' - wrong count at exit drivers/s390/scsi/zfcp_qdio.c:244:5: warning: context imbalance in 'zfcp_qdio_sbal_get' - unexpected unlock Last but not least, we get rid of that crappy lock-unlock-lock sequence at the beginning of the critical section. It is okay to call zfcp_erp_adapter_reopen() with req_q_lock held. Reported-by: Mikulas Patocka <mpatocka@redhat.com> Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29libata: apply behavioral quirks to sil3826 PMPTerry Suereth
commit 8ffff94d20b7eb446e848e0046107d51b17a20a8 upstream. Fixing support for the Silicon Image 3826 port multiplier, by applying to it the same quirks applied to the Silicon Image 3726. Specifically fixes the repeated timeout/reset process which previously afflicted the 3726, as described from line 290. Slightly based on notes from: https://bugzilla.redhat.com/show_bug.cgi?id=890237 Signed-off-by: Terry Suereth <terry.suereth@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29Hostap: copying wrong data prism2_ioctl_giwaplist()Dan Carpenter
commit 909bd5926d474e275599094acad986af79671ac9 upstream. We want the data stored in "addr" and "qual", but the extra ampersands mean we are copying stack data instead. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29nilfs2: fix issue with counting number of bio requests for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error detection commit 4bf93b50fd04118ac7f33a3c2b8a0a1f9fa80bc9 upstream. Fix the issue with improper counting number of flying bio requests for BIO_EOPNOTSUPP error detection case. The sb_nbio must be incremented exactly the same number of times as complete() function was called (or will be called) because nilfs_segbuf_wait() will call wail_for_completion() for the number of times set to sb_nbio: do { wait_for_completion(&segbuf->sb_bio_event); } while (--segbuf->sb_nbio > 0); Two functions complete() and wait_for_completion() must be called the same number of times for the same sb_bio_event. Otherwise, wait_for_completion() will hang or leak. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29nilfs2: remove double bio_put() in nilfs_end_bio_write() for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error commit 2df37a19c686c2d7c4e9b4ce1505b5141e3e5552 upstream. Remove double call of bio_put() in nilfs_end_bio_write() for the case of BIO_EOPNOTSUPP error detection. The issue was found by Dan Carpenter and he suggests first version of the fix too. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29of: fdt: fix memory initialization for expanded DTWladislav Wiebe
commit 9e40127526e857fa3f29d51e83277204fbdfc6ba upstream. Already existing property flags are filled wrong for properties created from initial FDT. This could cause problems if this DYNAMIC device-tree functions are used later, i.e. properties are attached/detached/replaced. Simply dumping flags from the running system show, that some initial static (not allocated via kzmalloc()) nodes are marked as dynamic. I putted some debug extensions to property_proc_show(..) : .. + if (OF_IS_DYNAMIC(pp)) + pr_err("DEBUG: xxx : OF_IS_DYNAMIC\n"); + if (OF_IS_DETACHED(pp)) + pr_err("DEBUG: xxx : OF_IS_DETACHED\n"); when you operate on the nodes (e.g.: ~$ cat /proc/device-tree/*some_node*) you will see that those flags are filled wrong, basically in most cases it will dump a DYNAMIC or DETACHED status, which is in not true. (BTW. this OF_IS_DETACHED is a own define for debug purposes which which just make a test_bit(OF_DETACHED, &x->_flags) If nodes are dynamic kernel is allowed to kfree() them. But it will crash attempting to do so on the nodes from FDT -- they are not allocated via kzmalloc(). Signed-off-by: Wladislav Wiebe <wladislav.kw@gmail.com> Acked-by: Alexander Sverdlin <alexander.sverdlin@nsn.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29drm/i915: Invalidate TLBs for the rings after a resetChris Wilson
commit 884020bf3d2a3787a1cc6df902e98e0eec60330b upstream. After any "soft gfx reset" we must manually invalidate the TLBs associated with each ring. Empirically, it seems that a suspend/resume or D3-D0 cycle count as a "soft reset". The symptom is that the hardware would fail to note the new address for its status page, and so it would continue to write the shadow registers and breadcrumbs into the old physical address (now used by something completely different, scary). Whereas the driver would read the new status page and never see any progress, it would appear that the GPU hung immediately upon resume. Based on a patch by naresh kumar kachhi <naresh.kumar.kacchi@intel.com> Reported-by: Thiago Macieira <thiago@kde.org> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=64725 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Thiago Macieira <thiago@kde.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29xen/events: initialize local per-cpu mask for all possible eventsDavid Vrabel
commit 84ca7a8e45dafb49cd5ca90a343ba033e2885c17 upstream. The sizeof() argument in init_evtchn_cpu_bindings() is incorrect resulting in only the first 64 (or 32 in 32-bit guests) ports having their bindings being initialized to VCPU 0. In most cases this does not cause a problem as request_irq() will set the irq affinity which will set the correct local per-cpu mask. However, if the request_irq() is called on a VCPU other than 0, there is a window between the unmasking of the event and the affinity being set were an event may be lost because it is not locally unmasked on any VCPU. If request_irq() is called on VCPU 0 then local irqs are disabled during the window and the race does not occur. Fix this by initializing all NR_EVENT_CHANNEL bits in the local per-cpu masks. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29zd1201: do not use stack as URB transfer_bufferJussi Kivilinna
commit 1206ff4ff9d2ef7468a355328bc58ac6ebf5be44 upstream. Patch fixes zd1201 not to use stack as URB transfer_buffer. URB buffers need to be DMA-able, which stack is not. Patch is only compile tested. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29workqueue: consider work function when searching for busy work itemsTejun Heo
commit a2c1c57be8d9fd5b716113c8991d3d702eeacf77 upstream. To avoid executing the same work item concurrenlty, workqueue hashes currently busy workers according to their current work items and looks up the the table when it wants to execute a new work item. If there already is a worker which is executing the new work item, the new item is queued to the found worker so that it gets executed only after the current execution finishes. Unfortunately, a work item may be freed while being executed and thus recycled for different purposes. If it gets recycled for a different work item and queued while the previous execution is still in progress, workqueue may make the new work item wait for the old one although the two aren't really related in any way. In extreme cases, this false dependency may lead to deadlock although it's extremely unlikely given that there aren't too many self-freeing work item users and they usually don't wait for other work items. To alleviate the problem, record the current work function in each busy worker and match it together with the work item address in find_worker_executing_work(). While this isn't complete, it ensures that unrelated work items don't interact with each other and in the very unlikely case where a twisted wq user triggers it, it's always onto itself making the culprit easy to spot. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Andrey Isakov <andy51@gmx.ru> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51701 [lizf: Backported to 3.4: - Adjust context - Incorporate earlier logging cleanup in process_one_work() from 044c782ce3a9 ('workqueue: fix checkpatch issues')] Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29workqueue: fix possible stall on try_to_grab_pending() of a delayed work itemLai Jiangshan
commit 3aa62497594430ea522050b75c033f71f2c60ee6 upstream. Currently, when try_to_grab_pending() grabs a delayed work item, it leaves its linked work items alone on the delayed_works. The linked work items are always NO_COLOR and will cause future cwq_activate_first_delayed() increase cwq->nr_active incorrectly, and may cause the whole cwq to stall. For example, state: cwq->max_active = 1, cwq->nr_active = 1 one work in cwq->pool, many in cwq->delayed_works. step1: try_to_grab_pending() removes a work item from delayed_works but leaves its NO_COLOR linked work items on it. step2: Later on, cwq_activate_first_delayed() activates the linked work item increasing ->nr_active. step3: cwq->nr_active = 1, but all activated work items of the cwq are NO_COLOR. When they finish, cwq->nr_active will not be decreased due to NO_COLOR, and no further work items will be activated from cwq->delayed_works. the cwq stalls. Fix it by ensuring the target work item is activated before stealing PENDING in try_to_grab_pending(). This ensures that all the linked work items are activated without incorrectly bumping cwq->nr_active. tj: Updated comment and description. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org> [lizf: backported to 3.4: adjust context] Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20Linux 3.4.59v3.4.59Greg Kroah-Hartman
2013-08-20jbd2: Fix use after free after error in jbd2_journal_dirty_metadata()Jan Kara
commit 91aa11fae1cf8c2fd67be0609692ea9741cdcc43 upstream. When jbd2_journal_dirty_metadata() returns error, __ext4_handle_dirty_metadata() stops the handle. However callers of this function do not count with that fact and still happily used now freed handle. This use after free can result in various issues but very likely we oops soon. The motivation of adding __ext4_journal_stop() into __ext4_handle_dirty_metadata() in commit 9ea7a0df seems to be only to improve error reporting. So replace __ext4_journal_stop() with ext4_journal_abort_handle() which was there before that commit and add WARN_ON_ONCE() to dump stack to provide useful information. Reported-by: Sage Weil <sage@inktank.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20m68k/atari: ARAnyM - Fix NatFeat module supportGeert Uytterhoeven
commit e8184e10f89736a23ea6eea8e24cd524c5c513d2 upstream. As pointed out by Andreas Schwab, pointers passed to ARAnyM NatFeat calls should be physical addresses, not virtual addresses. Fortunately on Atari, physical and virtual kernel addresses are the same, as long as normal kernel memory is concerned, so this usually worked fine without conversion. But for modules, pointers to literal strings are located in vmalloc()ed memory. Depending on the version of ARAnyM, this causes the nf_get_id() call to just fail, or worse, crash ARAnyM itself with e.g. Gotcha! Illegal memory access. Atari PC = $968c This is a big issue for distro kernels, who want to have all drivers as loadable modules in an initrd. Add a wrapper for nf_get_id() that copies the literal to the stack to work around this issue. Reported-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20m68k: Truncate base in do_div()Andreas Schwab
commit ea077b1b96e073eac5c3c5590529e964767fc5f7 upstream. Explicitly truncate the second operand of do_div() to 32 bits to guard against bogus code calling it with a 64-bit divisor. [Thorsten] After upgrading from 3.2 to 3.10, mounting a btrfs volume fails with: btrfs: setting nodatacow, compression disabled btrfs: enabling auto recovery btrfs: disk space caching is enabled *** ZERO DIVIDE *** FORMAT=2 Current process id is 722 BAD KERNEL TRAP: 00000000 Modules linked in: evdev mac_hid ext4 crc16 jbd2 mbcache btrfs xor lzo_compress zlib_deflate raid6_pq crc32c libcrc32c PC: [<319535b2>] __btrfs_map_block+0x11c/0x119a [btrfs] SR: 2000 SP: 30c1fab4 a2: 30f0faf0 d0: 00000000 d1: 00001000 d2: 00000000 d3: 00000000 d4: 00010000 d5: 00000000 a0: 3085c72c a1: 3085c72c Process mount (pid: 722, task=30f0faf0) Frame format=2 instr addr=319535ae Stack from 30c1faec: 00000000 00000020 00000000 00001000 00000000 01401000 30253928 300ffc00 00a843ac 3026f640 00000000 00010000 0009e250 00d106c0 00011220 00000000 00001000 301c6830 0009e32a 000000ff 00000009 3085c72c 00000000 00000000 30c1fd14 00000000 00000020 00000000 30c1fd14 0009e26c 00000020 00000003 00000000 0009dd8a 300b0b6c 30253928 00a843ac 00001000 00000000 00000000 0000a008 3194e76a 30253928 00a843ac 00001000 00000000 00000000 00000002 Call Trace: [<00001000>] kernel_pg_dir+0x0/0x1000 [...] Code: 222e ff74 2a2e ff5c 2c2e ff60 4c45 1402 <2d40> ff64 2d41 ff68 2205 4c2e 1800 ff68 4c04 0800 2041 d1c0 2206 4c2e 1400 ff68 [Geert] As diagnosed by Andreas, fs/btrfs/volumes.c:__btrfs_map_block() calls do_div(stripe_nr, stripe_len); with stripe_len u64, while do_div() assumes the divisor is a 32-bit number. Due to the lack of truncation in the m68k-specific implementation of do_div(), the division is performed using the upper 32-bit word of stripe_len, which is zero. This was introduced by commit 53b381b3abeb86f12787a6c40fee9b2f71edc23b ("Btrfs: RAID5 and RAID6"), which changed the divisor from map->stripe_len (struct map_lookup.stripe_len is int) to a 64-bit temporary. Reported-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Tested-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20ARM: 7809/1: perf: fix event validation for software group leadersWill Deacon
commit c95eb3184ea1a3a2551df57190c81da695e2144b upstream. It is possible to construct an event group with a software event as a group leader and then subsequently add a hardware event to the group. This results in the event group being validated by adding all members of the group to a fake PMU and attempting to allocate each event on their respective PMU. Unfortunately, for software events wthout a corresponding arm_pmu, this results in a kernel crash attempting to dereference the ->get_event_idx function pointer. This patch fixes the problem by checking explicitly for software events and ignoring those in event validation (since they can always be scheduled). We will probably want to revisit this for 3.12, since the validation checks don't appear to work correctly when dealing with multiple hardware PMUs anyway. Reported-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20xtensa: replace xtensa-specific _f{data,text} by _s{data,text}Geert Uytterhoeven
commit 5e7b6ed8e9bf3c8e3bb579fd0aec64f6526f8c81 upstream. commit a2d063ac216c161 ("extable, core_kernel_data(): Make sure all archs define _sdata") missed xtensa. Xtensa does have a start of data marker, but calls it _fdata, causing kernel/built-in.o:(.text+0x964): undefined reference to `_sdata' _stext was already defined, but it was duplicated by _fdata. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20xtensa: fix linker script transformation for .text.unlikelyMax Filippov
commit f6a03a12ecdbe0dd80a55f6df3b7206c5a403a49 upstream. Now that binutils generate *.unlikely sections which don't follow documented (info as) literal section naming rules, section name transformation script doesn't work well resulting in the following errors at vmlinux link time: main.c:(.text.unlikely+0x3): dangerous relocation: l32r: literal placed after use: .literal.unlikely Fix section name transformation script by adding specific rule for .text.unlikely sections. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20USB: mos7720: fix broken control requestsJohan Hovold
commit ef6c8c1d733e244f0499035be0dabe1f4ed98c6f upstream. The parallel-port code of the drivers used a stack allocated control-request buffer for asynchronous (and possibly deferred) control requests. This not only violates the no-DMA-from-stack requirement but could also lead to corrupt control requests being submitted. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20usb: add two quirky touchscreenOliver Neukum
commit 304ab4ab079a8ed03ce39f1d274964a532db036b upstream. These devices tend to become unresponsive after S3 Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20can: pcan_usb: fix wrong memcpy() bytes lengthStephane Grosjean
commit 3c322a56b01695df15c70bfdc2d02e0ccd80654e upstream. Fix possibly wrong memcpy() bytes length since some CAN records received from PCAN-USB could define a DLC field in range [9..15]. In that case, the real DLC value MUST be used to move forward the record pointer but, only 8 bytes max. MUST be copied into the data field of the struct can_frame object of the skb given to the network core. Signed-off-by: Stephane Grosjean <s.grosjean@peak-system.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20iwl4965: reset firmware after rfkill offStanislaw Gruszka
commit 788f7a56fce1bcb2067b62b851a086fca48a0056 upstream. Using rfkill switch can make firmware unstable, what cause various Microcode errors and kernel warnings. Reseting firmware just after rfkill off (radio on) helped with that. Resolve: https://bugzilla.redhat.com/show_bug.cgi?id=977053 Reported-and-tested-by: Justin Pearce <whitefox@guardianfox.net> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20iwl4965: set power mode earlyStanislaw Gruszka
commit eca396d7a5bdcc1fd67b1b12f737c213ac78a6f4 upstream. If device was put into a sleep and system was restarted or module reloaded, we have to wake device up before sending other commands. Otherwise it will fail to start with Microcode error. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20af_key: initialize satype in key_notify_policy_flush()Nicolas Dichtel
commit 85dfb745ee40232876663ae206cba35f24ab2a40 upstream. This field was left uninitialized. Some user daemons perform check against this field. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Cc: Luis Henriques <luis.henriques@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20MIPS: Rewrite pfn_valid to work in modules, too.Ralf Baechle
Upstream commit 8b9232141bf40788cce31f893c13f344ec31ee66. This fixes: MODPOST 393 modules ERROR: "min_low_pfn" [arch/mips/kvm/kvm.ko] undefined! make[3]: *** [__modpost] Error 1 It would have been possible to just export min_low_pfn but in the end pfn_valid should return 1 for any pfn argument for which a struct page exists so using min_low_pfn was wrong anyway. [Backport to 3.4 kernel. Applies cleanly on top of current 3.4 patch queue, and fixes "make ARCH=mips allmodconfig; make ARCH=mips" build problem. - Guenter] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20sparc32: Add ucmpdi2.o to obj-y instead of lib-y.David S. Miller
commit 74c7b28953d4eaa6a479c187aeafcfc0280da5e8 upstream. Otherwise if no references exist in the static kernel image, we won't export the symbol properly to modules. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20sparc32: add ucmpdi2Sam Ravnborg
commit de36e66d5fa52bc6e2dacd95c701a1762b5308a7 upstream. Based on copy from microblaze add ucmpdi2 implementation. This fixes build of niu driver which failed with: drivers/built-in.o: In function `niu_get_nfc': niu.c:(.text+0x91494): undefined reference to `__ucmpdi2' This driver will never be used on a sparc32 system, but patch added to fix build breakage with all*config builds. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20md/raid1,raid10: use freeze_array in place of raise_barrier in various places.NeilBrown
commit e2d59925221cd562e07fee38ec8839f7209ae603 upstream. Various places in raid1 and raid10 are calling raise_barrier when they really should call freeze_array. The former is only intended to be called from "make_request". The later has extra checks for 'nr_queued' and makes a call to flush_pending_writes(), so it is safe to call it from within the management thread. Using raise_barrier will sometimes deadlock. Using freeze_array should not. As 'freeze_array' currently expects one request to be pending (in handle_read_error - the only previous caller), we need to pass it the number of pending requests (extra) to ignore. The deadlock was made particularly noticeable by commits 050b66152f87c7 (raid10) and 6b740b8d79252f13 (raid1) which appeared in 3.4, so the fix is appropriate for any -stable kernel since then. This patch probably won't apply directly to some early kernels and will need to be applied by hand. Cc: stable@vger.kernel.org Reported-by: Alexander Lyakas <alex.bolshoy@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de> [adjust context to make it can be apply on top of 3.4 ] Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20alpha: makefile: don't enforce small data model for kernel buildsWill Deacon
commit cd8d2331756751b6aeb855a3c9cb0a92fbd9c725 upstream. Due to all of the goodness being packed into today's kernels, the resulting image isn't as slim as it once was. In light of this, don't pass -msmall-data to gcc, which otherwise results in link failures due to impossible relocations when compiling anything but the most trivial configurations. Reviewed-by: Matt Turner <mattst88@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Tested-by: Thorsten Kranzkowski <dl8bcu@dl8bcu.de> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20powerpc/numa: Avoid stupid uninitialized warning from gccBenjamin Herrenschmidt
commit aa709f3bc92c6daaf177cd7e3446da2ef64426c6 upstream. Newer gcc are being a bit blind here (it's pretty obvious we don't reach the code path using the array if we haven't initialized the pointer) but none of that is performance critical so let's just silence it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20frv: Use core allocator for task_structThomas Gleixner
commit c6ae063aaf3786b9db7f19a90bf4ed8aaebb7f90 upstream. There is no point having a copy of the core allocator. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/20120503085033.967140188@linutronix.de Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20frv: Use correct size for task_struct allocationThomas Gleixner
commit cce4517f33384c3794c759e206cc8e1bb6df146b upstream. alloc_task_struct_node() allocates THREAD_SIZE and maintains some weird refcount in the allocated memory. This never blew up as task_struct size on 32bit machines was always less than THREAD_SIZE Allocate just sizeof(struct task_struct) and get rid of the magic refcounting. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/20120503085033.898475542@linutronix.de Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
