2012-09-08Linux 3.6-rc5v3.6-rc5Linus Torvalds
2012-09-08Merge branch 'fixes-for-3.6' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA-mapping fixes from Marek Szyprowski: "Another set of fixes for ARM dma-mapping subsystem. Commit e9da6e9905e6 replaced custom consistent buffer remapping code with generic vmalloc areas. It however introduced some regressions caused by limited support for allocations in atomic context. This series contains fixes for those regressions. For some subplatforms the default, pre-allocated pool for atomic allocations turned out to be too small, so a function for setting its size has been added. Another set of patches adds support for atomic allocations to IOMMU-aware DMA-mapping implementation. The last part of this pull request contains two fixes for Contiguous Memory Allocator, which relax too strict requirements." * 'fixes-for-3.6' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: ARM: dma-mapping: IOMMU allocates pages from atomic_pool with GFP_ATOMIC ARM: dma-mapping: Introduce __atomic_get_pages() for __iommu_get_pages() ARM: dma-mapping: Refactor out to introduce __in_atomic_pool ARM: dma-mapping: atomic_pool with struct page **pages ARM: Kirkwood: increase atomic coherent pool size ARM: DMA-Mapping: print warning when atomic coherent allocation fails ARM: DMA-Mapping: add function for setting coherent pool size from platform code ARM: relax conditions required for enabling Contiguous Memory Allocator mm: cma: fix alignment requirements for contiguous regions
2012-09-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: wacom - add support for EMR on Cintiq 24HD touch Input: i8042 - add Gigabyte T1005 series netbooks to noloop table Input: imx_keypad - reset the hardware before enabling Input: edt-ft5x06 - fix build error when compiling wthout CONFIG_DEBUG_FS
2012-09-07Merge branch 'upstream-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: "It contains a fix for Eaton Ellipse MAX UPS from Alan Stern, performance improvement (not processing debug data if noone is interested), by Henrik Rydberg, and allowing tpkbd-driven devices to work even with generic driver in a crippled mode, by Andres Freund." * 'upstream-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: tpkbd: work even if the new Lenovo Keyboard driver is not configured HID: Only dump input if someone is listening HID: add NOGET quirk for Eaton Ellipse MAX UPS
2012-09-07HID: tpkbd: work even if the new Lenovo Keyboard driver is not configuredAndres Freund
c1dcad2d32d0252e8a3023d20311b52a187ecda3 added a new driver configured by HID_LENOVO_TPKBD but made the hid_have_special_driver entry non-optional which lead to a recognized but non-working device if the new driver wasn't configured (which is the correct default). Signed-off-by: Andres Freund <andres@anarazel.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-09-06Merge tag 'stable/for-linus-3.6-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen bug-fixes from Konrad Rzeszutek Wilk: * Fix for TLB flushing introduced in v3.6 * Fix Xen-SWIOTLB not using proper DMA mask - device had 64bit but in a 32-bit kernel we need to allocate for coherent pages from a 32-bit pool. * When trying to re-use P2M nodes we had a one-off error and triggered a BUG_ON check with specific CONFIG_ option. * When doing FLR in Xen-PCI-backend we would first do FLR then save the PCI configuration space. We needed to do it the other way around. * tag 'stable/for-linus-3.6-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pciback: Fix proper FLR steps. xen: Use correct masking in xen_swiotlb_alloc_coherent. xen: fix logical error in tlb flushing xen/p2m: Fix one-off error in checking the P2M tree directory.
2012-09-06Merge tag '3.6-pci-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "Power management - PCI/PM: Enable D3/D3cold by default for most devices - PCI/PM: Keep parent bridge active when probing device - PCI/PM: Fix config reg access for D3cold and bridge suspending - PCI/PM: Add ABI document for sysfs file d3cold_allowed Core - PCI: Don't print anything while decoding is disabled" * tag '3.6-pci-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Don't print anything while decoding is disabled PCI/PM: Add ABI document for sysfs file d3cold_allowed PCI/PM: Fix config reg access for D3cold and bridge suspending PCI/PM: Keep parent bridge active when probing device PCI/PM: Enable D3/D3cold by default for most devices
2012-09-06Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC bug fixes from Olof Johansson: "Mostly Renesas and Atmel bugfixes this time, targeting boot and build problems. A couple of patches for gemini and kirkwood as well. On a whole nothing very controversial." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: gemini: fix the gemini build ARM: shmobile: armadillo800eva: enable rw rootfs mount ARM: Kirkwood: Fix 'SZ_1M' undeclared here for db88f6281-bp-setup.c ARM: shmobile: mackerel: fixup usb module order ARM: shmobile: armadillo800eva: fixup: sound card detection order ARM: shmobile: marzen: fixup smsc911x id for regulator ARM: at91/feature-removal-schedule: delay at91_mci removal ARM: mach-shmobile: armadillo800eva: Enable power button as wakeup source ARM: mach-shmobile: armadillo800eva: Fix GPIO buttons descriptions ARM: at91/dts: remove partial parameter in at91sam9g25ek.dts ARM: at91/clock: fix PLLA overclock warning ARM: at91: fix rtc-at91sam9 irq issue due to sparse irq support ARM: at91: fix system timer irq issue due to sparse irq support ARM: shmobile: sh73a0: fixup RELOC_BASE of intca_irq_pins_desc
2012-09-06Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull a hwmon fix from Guenter Roeck: "One patch, fixing DIV_ROUND_CLOSEST to support negative dividends. While the changes are not in the drivers/hwmon directory, the problem primarily affects hwmon drivers, and it makes sense to push the patch through the hwmon tree." * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: linux/kernel.h: Fix DIV_ROUND_CLOSEST to support negative dividends
2012-09-06Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fixes from Michal Marek: "These are two fixes that should go into 3.6. The link-vmlinux.sh one is obvious. The other one fixes make firmware_install with certain configurations, where a file in the toplevel firmware tree gets installed first, and $(INSTALL_FW_PATH)/$$(dir <file>) results in /lib/firmware/./, which confuses make 3.82 for some reason." * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: firmware: fix directory creation rule matching with make 3.82 link-vmlinux.sh: Fix stray "echo" in error message
2012-09-06Remove user-triggerable BUG from mpol_to_strDave Jones
Trivially triggerable, found by trinity: kernel BUG at mm/mempolicy.c:2546! Process trinity-child2 (pid: 23988, threadinfo ffff88010197e000, task ffff88007821a670) Call Trace: show_numa_map+0xd5/0x450 show_pid_numa_map+0x13/0x20 traverse+0xf2/0x230 seq_read+0x34b/0x3e0 vfs_read+0xac/0x180 sys_pread64+0xa2/0xc0 system_call_fastpath+0x1a/0x1f RIP: mpol_to_str+0x156/0x360 Cc: stable@vger.kernel.org Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-06xen/pciback: Fix proper FLR steps.Konrad Rzeszutek Wilk
When we do FLR and save PCI config we did it in the wrong order. The end result was that if a PCI device was unbind from its driver, then binded to xen-pciback, and then back to its driver we would get: > lspci -s 04:00.0 04:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection 13:42:12 # 4 :~/ > echo "0000:04:00.0" > /sys/bus/pci/drivers/pciback/unbind > modprobe e1000e e1000e: Intel(R) PRO/1000 Network Driver - 2.0.0-k e1000e: Copyright(c) 1999 - 2012 Intel Corporation. e1000e 0000:04:00.0: Disabling ASPM L0s L1 e1000e 0000:04:00.0: enabling device (0000 -> 0002) xen: registering gsi 48 triggering 0 polarity 1 Already setup the GSI :48 e1000e 0000:04:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode e1000e: probe of 0000:04:00.0 failed with error -2 This fixes it by first saving the PCI configuration space, then doing the FLR. Reported-by: Ren, Yongjie <yongjie.ren@intel.com> Reported-and-Tested-by: Tobias Geiger <tobias.geiger@vido.info> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> CC: stable@vger.kernel.org
2012-09-05Merge tag 'mmc-fixes-for-3.6-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC fixes from Chris Ball: - a firmware bug on several Samsung MoviNAND eMMC models causes permanent corruption on the device when secure erase and secure trim requests are made, so we disable those requests on these eMMC devices. - atmel-mci: fix a hang with some SD cards by waiting for not-busy flag. - dw_mmc: low-power mode breaks SDIO interrupts; fix PIO error handling; fix handling of error interrupts. - mxs-mmc: fix deadlocks; fix compile error due to dma.h arch change. - omap: fix broken PIO mode causing memory corruption. - sdhci-esdhc: fix card detection. * tag 'mmc-fixes-for-3.6-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: omap: fix broken PIO mode mmc: card: Skip secure erase on MoviNAND; causes unrecoverable corruption. mmc: dw_mmc: Disable low power mode if SDIO interrupts are used mmc: dw_mmc: fix error handling in PIO mode mmc: dw_mmc: correct mishandling error interrupt mmc: dw_mmc: amend using error interrupt status mmc: atmel-mci: not busy flag has also to be used for read operations mmc: sdhci-esdhc: break out early if clock is 0 mmc: mxs-mmc: fix deadlock caused by recursion loop mmc: mxs-mmc: fix deadlock in SDIO IRQ case mmc: bfin_sdh: fix dma_desc_array build error
2012-09-05uml: fix compile error in deliver_alarm()Miklos Szeredi
Fix the following compile error on UML. arch/um/os-Linux/time.c: In function 'deliver_alarm': arch/um/os-Linux/time.c:117:3: error: too few arguments to function 'alarm_handler' arch/um/os-Linux/internal.h:1:6: note: declared here The error was introduced by commit d3c1cfcd ("um: pass siginfo to guest process") in 3.6-rc1. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Martin Pärtel <martin.partel@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-05dj: memory scribble in logi_djAlan Cox
Allocate a structure not a pointer to it ! Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-05Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fixes from Benjamin Herrenschmidt: "Here are a few fixes for 3.6 that were piling up while I was away or busy (I was mostly MIA a week or two before San Diego). Some fixes from Anton fixing up issues with our relatively new DSCR control feature, and a few other fixes that are either regressions or bugs nasty enough to warrant not waiting." * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Don't use __put_user() in patch_instruction powerpc: Make sure IPI handlers see data written by IPI senders powerpc: Restore correct DSCR in context switch powerpc: Fix DSCR inheritance in copy_thread() powerpc: Keep thread.dscr and thread.dscr_inherit in sync powerpc: Update DSCR on all CPUs when writing sysfs dscr_default powerpc/powernv: Always go into nap mode when CPU is offline powerpc: Give hypervisor decrementer interrupts their own handler powerpc/vphn: Fix arch_update_cpu_topology() return value
2012-09-05Merge tag 'gpio-fixes-for-v3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO fixes from Linus Walleij: "These are some GPIO regression fixes for v3.6: - Erroneous debug message from of_get_named_gpio_flags() - Make sure the MC9S08DZ60 GPIO driver depend on I2C being compiled in (not module) or allmodconfig breaks. - Check return value from irq_alloc_descs() in the Emma Mobile GPIO driver. - Assign the owner field for the rdc321x driver so the module won't be removed if it has active GPIOs." * tag 'gpio-fixes-for-v3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio: rdc321x: Prevent removal of modules exporting active GPIOs gpio: em: Fix checking return value of irq_alloc_descs gpio: mc9s08dz60: Fix build error if I2C=m gpio: Fix debug message in of_get_named_gpio_flags()
2012-09-05Merge tag 'sound-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "There are nothing scaring, contains only small fixes for HD-audio and USB-audio: - EPSS regression fix and GPIO fix for HD-audio IDT codecs - A series of USB-audio regression fixes that are found since 3.5 kernel" * tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: snd-usb: fix cross-interface streaming devices ALSA: snd-usb: fix calls to next_packet_size ALSA: snd-usb: restore delay information ALSA: snd-usb: use list_for_each_safe for endpoint resources ALSA: snd-usb: Fix URB cancellation at stream start ALSA: hda - Don't trust codec EPSS bit for IDT 92HD83xx & co ALSA: hda - Avoid unnecessary parameter read for EPSS ALSA: hda - Do not set GPIOs for speakers on IDT if there are no speakers
2012-09-05Merge tag 'fbdev-fixes-for-3.6-1' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev fixes from Florian Tobias Schandinat: - a fix by Paul Cercueil to prevent a possible buffer overflow - a fix by Bruno Prémont to prevent a rare sleep in invalid context - a fix by Julia Lawall for a double free in auo_k190x - a fix by Dan Carpenter to prevent a division by zero in mb862xxfb - a regression fix by Tomi Valkeinen for the SDI output in OMAP - a fix by Grazvydas Ignotas to fix the console colors in OMAP * tag 'fbdev-fixes-for-3.6-1' of git://github.com/schandinat/linux-2.6: OMAPFB: fix framebuffer console colors OMAPDSS: Fix SDI PLL locking video: mb862xxfb: prevent divide by zero bug drivers/video/auo_k190x.c: drop kfree of devm_kzalloc's data fbcon: Fix bit_putcs() call to kmalloc(s, GFP_KERNEL) fbcon: prevent possible buffer overflow.
2012-09-05Merge tag 'upstream-3.6-rc5' of git://git.infradead.org/linux-ubiLinus Torvalds
Pull ubi fix from Artem Bityutskiy: "A single small fix for memory deallocation: we allocated memory using 'kmem_cache_alloc()' but were freeing it using 'kfree()' in some cases. Now we fix this by using 'kmem_cache_free()' instead." * tag 'upstream-3.6-rc5' of git://git.infradead.org/linux-ubi: UBI: fix a horrible memory deallocation bug
2012-09-05Fix order of arguments to compat_put_time[spec|val]Mikulas Patocka
Commit 644595f89620 ("compat: Handle COMPAT_USE_64BIT_TIME in net/socket.c") introduced a bug where the helper functions to take either a 64-bit or compat time[spec|val] got the arguments in the wrong order, passing the kernel stack pointer off as a user pointer (and vice versa). Because of the user address range check, that in turn then causes an EFAULT due to the user pointer range checking failing for the kernel address. Incorrectly resuling in a failed system call for 32-bit processes with a 64-bit kernel. On odder architectures like HP-PA (with separate user/kernel address spaces), it can be used read kernel memory. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-05xen: Use correct masking in xen_swiotlb_alloc_coherent.Ronny Hegewald
When running 32-bit pvops-dom0 and a driver tries to allocate a coherent DMA-memory the xen swiotlb-implementation returned memory beyond 4GB. The underlaying reason is that if the supplied driver passes in a DMA_BIT_MASK(64) ( hwdev->coherent_dma_mask is set to 0xffffffffffffffff) our dma_mask will be u64 set to 0xffffffffffffffff even if we set it to DMA_BIT_MASK(32) previously. Meaning we do not reset the upper bits. By using the dma_alloc_coherent_mask function - it does the proper casting and we get 0xfffffffff. This caused not working sound on a system with 4 GB and a 64-bit compatible sound-card with sets the DMA-mask to 64bit. On bare-metal and the forward-ported xen-dom0 patches from OpenSuse a coherent DMA-memory is always allocated inside the 32-bit address-range by calling dma_alloc_coherent_mask. This patch adds the same functionality to xen swiotlb and is a rebase of the original patch from Ronny Hegewald which never got upstream b/c the underlaying reason was not understood until now. The original email with the original patch is in: http://old-list-archives.xen.org/archives/html/xen-devel/2010-02/msg00038.html the original thread from where the discussion started is in: http://old-list-archives.xen.org/archives/html/xen-devel/2010-01/msg00928.html Signed-off-by: Ronny Hegewald <ronny.hegewald@online.de> Signed-off-by: Stefano Panella <stefano.panella@citrix.com> Acked-By: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> CC: stable@vger.kernel.org
2012-09-05xen: fix logical error in tlb flushingAlex Shi
While TLB_FLUSH_ALL gets passed as 'end' argument to flush_tlb_others(), the Xen code was made to check its 'start' parameter. That may give a incorrect op.cmd to MMUEXT_INVLPG_MULTI instead of MMUEXT_TLB_FLUSH_MULTI. Then it causes some page can not be flushed from TLB. This patch fixed this issue. Reported-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Alex Shi <alex.shi@intel.com> Acked-by: Jan Beulich <jbeulich@suse.com> Tested-by: Yongjie Ren <yongjie.ren@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-05Merge commit '4cb38750d49010ae72e718d46605ac9ba5a851b4' into ↵Konrad Rzeszutek Wilk
stable/for-linus-3.6 * commit '4cb38750d49010ae72e718d46605ac9ba5a851b4': (6849 commits) bcma: fix invalid PMU chip control masks [libata] pata_cmd64x: whitespace cleanup libata-acpi: fix up for acpi_pm_device_sleep_state API sata_dwc_460ex: device tree may specify dma_channel ahci, trivial: fixed coding style issues related to braces ahci_platform: add hibernation callbacks libata-eh.c: local functions should not be exposed globally libata-transport.c: local functions should not be exposed globally sata_dwc_460ex: support hardreset ata: use module_pci_driver drivers/ata/pata_pcmcia.c: adjust suspicious bit operation pata_imx: Convert to clk_prepare_enable/clk_disable_unprepare ahci: Enable SB600 64bit DMA on MSI K9AGM2 (MS-7327) v2 [libata] Prevent interface errors with Seagate FreeAgent GoFlex drivers/acpi/glue: revert accidental license-related 6b66d95895c bits libata-acpi: add missing inlines in libata.h i2c-omap: Add support for I2C_M_STOP message flag i2c: Fall back to emulated SMBus if the operation isn't supported natively i2c: Add SCCB support i2c-tiny-usb: Add support for the Robofuzz OSIF USB/I2C converter ...
2012-09-05xen/p2m: Fix one-off error in checking the P2M tree directory.Konrad Rzeszutek Wilk
We would traverse the full P2M top directory (from 0->MAX_DOMAIN_PAGES inclusive) when trying to figure out whether we can re-use some of the P2M middle leafs. Which meant that if the kernel was compiled with MAX_DOMAIN_PAGES=512 we would try to use the 512th entry. Fortunately for us the p2m_top_index has a check for this: BUG_ON(pfn >= MAX_P2M_PFN); which we hit and saw this: (XEN) domain_crash_sync called from entry.S (XEN) Domain 0 (vcpu#0) crashed on cpu#0: (XEN) ----[ Xen-4.1.2-OVM x86_64 debug=n Tainted: C ]---- (XEN) CPU: 0 (XEN) RIP: e033:[<ffffffff819cadeb>] (XEN) RFLAGS: 0000000000000212 EM: 1 CONTEXT: pv guest (XEN) rax: ffffffff81db5000 rbx: ffffffff81db4000 rcx: 0000000000000000 (XEN) rdx: 0000000000480211 rsi: 0000000000000000 rdi: ffffffff81db4000 (XEN) rbp: ffffffff81793db8 rsp: ffffffff81793d38 r8: 0000000008000000 (XEN) r9: 4000000000000000 r10: 0000000000000000 r11: ffffffff81db7000 (XEN) r12: 0000000000000ff8 r13: ffffffff81df1ff8 r14: ffffffff81db6000 (XEN) r15: 0000000000000ff8 cr0: 000000008005003b cr4: 00000000000026f0 (XEN) cr3: 0000000661795000 cr2: 0000000000000000 Fixes-Oracle-Bug: 14570662 CC: stable@vger.kernel.org # only for v3.5 Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-05powerpc: Don't use __put_user() in patch_instructionBenjamin Herrenschmidt
patch_instruction() can be called very early on ppc32, when the kernel isn't yet running at it's linked address. That can cause the ! is_kernel_addr() test in __put_user() to trip and call might_sleep() which is very bad at that point during boot. Use a lower level function instead for now, at least until we get to rework ppc32 boot process to do the code patching later, like ppc64 does. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc: Make sure IPI handlers see data written by IPI sendersPaul Mackerras
We have been observing hangs, both of KVM guest vcpu tasks and more generally, where a process that is woken doesn't properly wake up and continue to run, but instead sticks in TASK_WAKING state. This happens because the update of rq->wake_list in ttwu_queue_remote() is not ordered with the update of ipi_message in smp_muxed_ipi_message_pass(), and the reading of rq->wake_list in scheduler_ipi() is not ordered with the reading of ipi_message in smp_ipi_demux(). Thus it is possible for the IPI receiver not to see the updated rq->wake_list and therefore conclude that there is nothing for it to do. In order to make sure that anything done before smp_send_reschedule() is ordered before anything done in the resulting call to scheduler_ipi(), this adds barriers in smp_muxed_message_pass() and smp_ipi_demux(). The barrier in smp_muxed_message_pass() is a full barrier to ensure that there is a full ordering between the smp_send_reschedule() caller and scheduler_ipi(). In smp_ipi_demux(), we use xchg() rather than xchg_local() because xchg() includes release and acquire barriers. Using xchg() rather than xchg_local() makes sense given that ipi_message is not just accessed locally. This moves the barrier between setting the message and calling the cause_ipi() function into the individual cause_ipi implementations. Most of them -- those that used outb, out_8 or similar -- already had a full barrier because out_8 etc. include a sync before the MMIO store. This adds an explicit barrier in the two remaining cases. These changes made no measurable difference to the speed of IPIs as measured using a simple ping-pong latency test across two CPUs on different cores of a POWER7 machine. The analysis of the reason why processes were not waking up properly is due to Milton Miller. Cc: stable@vger.kernel.org # v3.0+ Reported-by: Milton Miller <miltonm@bga.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc: Restore correct DSCR in context switchAnton Blanchard
During a context switch we always restore the per thread DSCR value. If we aren't doing explicit DSCR management (ie thread.dscr_inherit == 0) and the default DSCR changed while the process has been sleeping we end up with the wrong value. Check thread.dscr_inherit and select the default DSCR or per thread DSCR as required. This was found with the following test case, when running with more threads than CPUs (ie forcing context switching): http://ozlabs.org/~anton/junkcode/dscr_default_test.c With the four patches applied I can run a combination of all test cases successfully at the same time: http://ozlabs.org/~anton/junkcode/dscr_default_test.c http://ozlabs.org/~anton/junkcode/dscr_explicit_test.c http://ozlabs.org/~anton/junkcode/dscr_inherit_test.c Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> # 3.0+ Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc: Fix DSCR inheritance in copy_thread()Anton Blanchard
If the default DSCR is non zero we set thread.dscr_inherit in copy_thread() meaning the new thread and all its children will ignore future updates to the default DSCR. This is not intended and is a change in behaviour that a number of our users have hit. We just need to inherit thread.dscr and thread.dscr_inherit from the parent which ends up being much simpler. This was found with the following test case: http://ozlabs.org/~anton/junkcode/dscr_default_test.c Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> # 3.0+ Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc: Keep thread.dscr and thread.dscr_inherit in syncAnton Blanchard
When we update the DSCR either via emulation of mtspr(DSCR) or via a change to dscr_default in sysfs we don't update thread.dscr. We will eventually update it at context switch time but there is a period where thread.dscr is incorrect. If we fork at this point we will copy the old value of thread.dscr into the child. To avoid this, always keep thread.dscr in sync with reality. This issue was found with the following testcase: http://ozlabs.org/~anton/junkcode/dscr_inherit_test.c Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> # 3.0+ Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc: Update DSCR on all CPUs when writing sysfs dscr_defaultAnton Blanchard
Writing to dscr_default in sysfs doesn't actually change the DSCR - we rely on a context switch on each CPU to do the work. There is no guarantee we will get a context switch in a reasonable amount of time so fire off an IPI to force an immediate change. This issue was found with the following test case: http://ozlabs.org/~anton/junkcode/dscr_explicit_test.c Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> # 3.0+ Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc/powernv: Always go into nap mode when CPU is offlinePaul Mackerras
The CPU hotplug code for the powernv platform currently only puts offline CPUs into nap mode if the powersave_nap variable is set. However, HV-style KVM on this platform requires secondary CPU threads to be offline and in nap mode. Since we know nap mode works just fine on all POWER7 machines, and the only machines that support the powernv platform are POWER7 machines, this changes the code to always put offline CPUs into nap mode, regardless of powersave_nap. Powersave_nap still controls whether or not CPUs go into nap mode when idle, as before. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc: Give hypervisor decrementer interrupts their own handlerPaul Mackerras
At the moment the handler for hypervisor decrementer interrupts is the same as for decrementer interrupts, i.e. timer_interrupt(). This is bogus; if we ever do get a hypervisor decrementer interrupt it won't have anything to do with the next timer event. In fact the only time we get hypervisor decrementer interrupts is when one is left pending on exit from a KVM guest. When we get a hypervisor decrementer interrupt we don't need to do anything special to clear it, since they are edge-triggered on the transition of HDEC from 0 to -1. Thus this adds an empty handler function for them. We don't need to have them masked when interrupts are soft-disabled, so we use STD_EXCEPTION_HV instead of MASKABLE_EXCEPTION_HV. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc/vphn: Fix arch_update_cpu_topology() return valueJesse Larrew
arch_update_cpu_topology() should only return 1 when the topology has actually changed, and should return 0 otherwise. This patch fixes a potential bug where rebuild_sched_domains() would reinitialize the sched domains even when the topology hasn't changed. Signed-off-by: Jesse Larrew <jlarrew@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-04ARM: gemini: fix the gemini buildLinus Walleij
Test-compiling obscure machines I notice that the gemini (which by the way lacks a defconfig) is broken since some time back. Adding a simple missing include makes it build again. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-04Merge branch 'fixes' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes Two regression fixes and one boot-loader compatibility fix from Simon Horman. * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: armadillo800eva: enable rw rootfs mount ARM: shmobile: mackerel: fixup usb module order ARM: shmobile: armadillo800eva: fixup: sound card detection order
2012-09-04mmc: omap: fix broken PIO modePaul Walmsley
After commit 26b88520b80695a6fa5fd95b5d97c03f4daf87e0 ("mmc: omap_hsmmc: remove private DMA API implementation"), the Nokia N800 here stopped booting: [ 2.086181] Waiting for root device /dev/mmcblk0p1... [ 2.324066] Unhandled fault: imprecise external abort (0x406) at 0x00000000 [ 2.331451] Internal error: : 406 [#1] ARM [ 2.335784] Modules linked in: [ 2.339050] CPU: 0 Not tainted (3.6.0-rc3 #60) [ 2.344146] PC is at default_idle+0x28/0x30 [ 2.348602] LR is at trace_hardirqs_on_caller+0x15c/0x1b0 ... This turned out to be due to memory corruption caused by long-broken PIO code in drivers/mmc/host/omap.c. (Previously, this driver had been using DMA; but the above commit caused the MMC driver to fall back to PIO mode with an unmodified Kconfig.) The PIO code, added with the rest of the driver in commit 730c9b7e6630f786fcec026fb11d2e6f2c90fdcb ("[MMC] Add OMAP MMC host driver"), confused bytes with 16-bit words. This bug caused memory located after the PIO transfer buffer to be corrupted with transfers larger than 32 bytes. The driver also did not increment the buffer pointer after the transfer occurred. This bug resulted in data corruption during any transfer larger than 64 bytes. Signed-off-by: Paul Walmsley <paul@pwsan.com> Reviewed-by: Felipe Balbi <balbi@ti.com> Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: card: Skip secure erase on MoviNAND; causes unrecoverable corruption.Ian Chen
For several MoviNAND eMMC parts, there are known issues with secure erase and secure trim. For these specific MoviNAND devices, we skip these operations. Specifically, there is a bug in the eMMC firmware that causes unrecoverable corruption when the MMC is erased with MMC_CAP_ERASE enabled. References: http://forum.xda-developers.com/showthread.php?t=1644364 https://plus.google.com/111398485184813224730/posts/21pTYfTsCkB#111398485184813224730/posts/21pTYfTsCkB Signed-off-by: Ian Chen <ian.cy.chen@samsung.com> Reviewed-by: Namjae Jeon <linkinjeon@gmail.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Cc: stable <stable@vger.kernel.org> [3.0+] Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: dw_mmc: Disable low power mode if SDIO interrupts are usedDoug Anderson
The documentation for the dw_mmc part says that the low power mode should normally only be set for MMC and SD memory and should be turned off for SDIO cards that need interrupts detected. The best place I could find to do this is when the SDIO interrupt was first enabled. I rely on the fact that dw_mci_setup_bus() will be called when it's time to reenable. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Seungwon Jeon <tgih.jun@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: dw_mmc: fix error handling in PIO modeSeungwon Jeon
Data transfer will be continued until all the bytes are transmitted, even if data crc error occurs during a multiple-block data transfer. This means RXDR/TXDR interrupts will occurs until data transfer is terminated. Early setting of host->sg to NULL prevents going into xxx_data_pio functions, hence permanent unhandled RXDR/TXDR interrupts occurs. And checking error interrupt status in the xxx_data_pio functions is no need because dw_mci_interrupt does do the same. This patch also removes it. Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: dw_mmc: correct mishandling error interruptSeungwon Jeon
Datasheet of SYNOPSYS mentions that DTO(Data Transfer Over) interrupt will be raised even if some error interrupts, however it is actually found that DTO does not occur. SYNOPSYS has confirmed this issue. Current implementation defers the call of tasklet_schedule until DTO when the error interrupts is happened. This patch fixes error handling. Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: dw_mmc: amend using error interrupt statusSeungwon Jeon
RINTSTS status includes masked interrupts as well as unmasked. data_status and cmd_status are set by value of RINTSTS in interrupt handler and tasklet finally uses it to decide whether error is happened or not. In addition, MINTSTS status is used for setting data_status in PIO. Masked error interrupt will not be handled and that status can be considered non-error case. Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com> Reviewed By: Girish K S <girish.shivananjappa@linaro.org> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: atmel-mci: not busy flag has also to be used for read operationsLudovic Desroches
Even if the datasheet says that the not busy flag has to be used only for write operations, it's false except for version lesser than v2xx. Not waiting on the not busy flag for read operations can cause the controller to hang-up during the initialization of some SD cards with DMA after the first CMD6 -- the next command is sent too early. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: stable <stable@vger.kernel.org> [3.5, 3.6] Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: sdhci-esdhc: break out early if clock is 0Shawn Guo
Since commit 30832ab56 ("mmc: sdhci: Always pass clock request value zero to set_clock host op") was merged, esdhc_set_clock starts hitting "if (clock == 0)" where ESDHC_SYSTEM_CONTROL has been operated. This causes SDHCI card-detection function being broken. Fix the regression by moving "if (clock == 0)" above ESDHC_SYSTEM_CONTROL operation. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: <stable@vger.kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: mxs-mmc: fix deadlock caused by recursion loopLauri Hintsala
Release the lock before mmc_signal_sdio_irq is called by mxs_mmc_enable_sdio_irq. Backtrace: [ 65.470000] ============================================= [ 65.470000] [ INFO: possible recursive locking detected ] [ 65.470000] 3.5.0-rc5 #2 Not tainted [ 65.470000] --------------------------------------------- [ 65.470000] ksdioirqd/mmc0/73 is trying to acquire lock: [ 65.470000] (&(&host->lock)->rlock#2){-.-...}, at: [<bf054120>] mxs_mmc_enable_sdio_irq+0x18/0xdc [mxs_mmc] [ 65.470000] [ 65.470000] but task is already holding lock: [ 65.470000] (&(&host->lock)->rlock#2){-.-...}, at: [<bf054120>] mxs_mmc_enable_sdio_irq+0x18/0xdc [mxs_mmc] [ 65.470000] [ 65.470000] other info that might help us debug this: [ 65.470000] Possible unsafe locking scenario: [ 65.470000] [ 65.470000] CPU0 [ 65.470000] ---- [ 65.470000] lock(&(&host->lock)->rlock#2); [ 65.470000] lock(&(&host->lock)->rlock#2); [ 65.470000] [ 65.470000] *** DEADLOCK *** [ 65.470000] [ 65.470000] May be due to missing lock nesting notation [ 65.470000] [ 65.470000] 1 lock held by ksdioirqd/mmc0/73: [ 65.470000] #0: (&(&host->lock)->rlock#2){-.-...}, at: [<bf054120>] mxs_mmc_enable_sdio_irq+0x18/0xdc [mxs_mmc] [ 65.470000] [ 65.470000] stack backtrace: [ 65.470000] [<c0014990>] (unwind_backtrace+0x0/0xf4) from [<c005ccb8>] (__lock_acquire+0x14f8/0x1b98) [ 65.470000] [<c005ccb8>] (__lock_acquire+0x14f8/0x1b98) from [<c005d3f8>] (lock_acquire+0xa0/0x108) [ 65.470000] [<c005d3f8>] (lock_acquire+0xa0/0x108) from [<c02f671c>] (_raw_spin_lock_irqsave+0x48/0x5c) [ 65.470000] [<c02f671c>] (_raw_spin_lock_irqsave+0x48/0x5c) from [<bf054120>] (mxs_mmc_enable_sdio_irq+0x18/0xdc [mxs_mmc]) [ 65.470000] [<bf054120>] (mxs_mmc_enable_sdio_irq+0x18/0xdc [mxs_mmc]) from [<bf0541d0>] (mxs_mmc_enable_sdio_irq+0xc8/0xdc [mxs_mmc]) [ 65.470000] [<bf0541d0>] (mxs_mmc_enable_sdio_irq+0xc8/0xdc [mxs_mmc]) from [<c0219b38>] (sdio_irq_thread+0x1bc/0x274) [ 65.470000] [<c0219b38>] (sdio_irq_thread+0x1bc/0x274) from [<c003c324>] (kthread+0x8c/0x98) [ 65.470000] [<c003c324>] (kthread+0x8c/0x98) from [<c00101ac>] (kernel_thread_exit+0x0/0x8) [ 65.470000] BUG: spinlock lockup suspected on CPU#0, ksdioirqd/mmc0/73 [ 65.470000] lock: 0xc3358724, .magic: dead4ead, .owner: ksdioirqd/mmc0/73, .owner_cpu: 0 [ 65.470000] [<c0014990>] (unwind_backtrace+0x0/0xf4) from [<c01b46b0>] (do_raw_spin_lock+0x100/0x144) [ 65.470000] [<c01b46b0>] (do_raw_spin_lock+0x100/0x144) from [<c02f6724>] (_raw_spin_lock_irqsave+0x50/0x5c) [ 65.470000] [<c02f6724>] (_raw_spin_lock_irqsave+0x50/0x5c) from [<bf054120>] (mxs_mmc_enable_sdio_irq+0x18/0xdc [mxs_mmc]) [ 65.470000] [<bf054120>] (mxs_mmc_enable_sdio_irq+0x18/0xdc [mxs_mmc]) from [<bf0541d0>] (mxs_mmc_enable_sdio_irq+0xc8/0xdc [mxs_mmc]) [ 65.470000] [<bf0541d0>] (mxs_mmc_enable_sdio_irq+0xc8/0xdc [mxs_mmc]) from [<c0219b38>] (sdio_irq_thread+0x1bc/0x274) [ 65.470000] [<c0219b38>] (sdio_irq_thread+0x1bc/0x274) from [<c003c324>] (kthread+0x8c/0x98) [ 65.470000] [<c003c324>] (kthread+0x8c/0x98) from [<c00101ac>] (kernel_thread_exit+0x0/0x8) Reported-by: Attila Kinali <attila@kinali.ch> Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: mxs-mmc: fix deadlock in SDIO IRQ caseLauri Hintsala
Release the lock before mmc_signal_sdio_irq is called by mxs_mmc_irq_handler. Backtrace: [ 79.660000] ============================================= [ 79.660000] [ INFO: possible recursive locking detected ] [ 79.660000] 3.4.0-00009-g3e96082-dirty #11 Not tainted [ 79.660000] --------------------------------------------- [ 79.660000] swapper/0 is trying to acquire lock: [ 79.660000] (&(&host->lock)->rlock#2){-.....}, at: [<c026ea3c>] mxs_mmc_enable_sdio_irq+0x18/0xd4 [ 79.660000] [ 79.660000] but task is already holding lock: [ 79.660000] (&(&host->lock)->rlock#2){-.....}, at: [<c026f744>] mxs_mmc_irq_handler+0x1c/0xe8 [ 79.660000] [ 79.660000] other info that might help us debug this: [ 79.660000] Possible unsafe locking scenario: [ 79.660000] [ 79.660000] CPU0 [ 79.660000] ---- [ 79.660000] lock(&(&host->lock)->rlock#2); [ 79.660000] lock(&(&host->lock)->rlock#2); [ 79.660000] [ 79.660000] *** DEADLOCK *** [ 79.660000] [ 79.660000] May be due to missing lock nesting notation [ 79.660000] [ 79.660000] 1 lock held by swapper/0: [ 79.660000] #0: (&(&host->lock)->rlock#2){-.....}, at: [<c026f744>] mxs_mmc_irq_handler+0x1c/0xe8 [ 79.660000] [ 79.660000] stack backtrace: [ 79.660000] [<c0014bd0>] (unwind_backtrace+0x0/0xf4) from [<c005f9c0>] (__lock_acquire+0x1948/0x1d48) [ 79.660000] [<c005f9c0>] (__lock_acquire+0x1948/0x1d48) from [<c005fea0>] (lock_acquire+0xe0/0xf8) [ 79.660000] [<c005fea0>] (lock_acquire+0xe0/0xf8) from [<c03a8460>] (_raw_spin_lock_irqsave+0x44/0x58) [ 79.660000] [<c03a8460>] (_raw_spin_lock_irqsave+0x44/0x58) from [<c026ea3c>] (mxs_mmc_enable_sdio_irq+0x18/0xd4) [ 79.660000] [<c026ea3c>] (mxs_mmc_enable_sdio_irq+0x18/0xd4) from [<c026f7fc>] (mxs_mmc_irq_handler+0xd4/0xe8) [ 79.660000] [<c026f7fc>] (mxs_mmc_irq_handler+0xd4/0xe8) from [<c006bdd8>] (handle_irq_event_percpu+0x70/0x254) [ 79.660000] [<c006bdd8>] (handle_irq_event_percpu+0x70/0x254) from [<c006bff8>] (handle_irq_event+0x3c/0x5c) [ 79.660000] [<c006bff8>] (handle_irq_event+0x3c/0x5c) from [<c006e6d0>] (handle_level_irq+0x90/0x110) [ 79.660000] [<c006e6d0>] (handle_level_irq+0x90/0x110) from [<c006b930>] (generic_handle_irq+0x38/0x50) [ 79.660000] [<c006b930>] (generic_handle_irq+0x38/0x50) from [<c00102fc>] (handle_IRQ+0x30/0x84) [ 79.660000] [<c00102fc>] (handle_IRQ+0x30/0x84) from [<c000f058>] (__irq_svc+0x38/0x60) [ 79.660000] [<c000f058>] (__irq_svc+0x38/0x60) from [<c0010520>] (default_idle+0x2c/0x40) [ 79.660000] [<c0010520>] (default_idle+0x2c/0x40) from [<c0010a90>] (cpu_idle+0x64/0xcc) [ 79.660000] [<c0010a90>] (cpu_idle+0x64/0xcc) from [<c04ff858>] (start_kernel+0x244/0x2c8) [ 79.660000] BUG: spinlock lockup on CPU#0, swapper/0 [ 79.660000] lock: c398cb2c, .magic: dead4ead, .owner: swapper/0, .owner_cpu: 0 [ 79.660000] [<c0014bd0>] (unwind_backtrace+0x0/0xf4) from [<c01ddb1c>] (do_raw_spin_lock+0xf0/0x144) [ 79.660000] [<c01ddb1c>] (do_raw_spin_lock+0xf0/0x144) from [<c03a8468>] (_raw_spin_lock_irqsave+0x4c/0x58) [ 79.660000] [<c03a8468>] (_raw_spin_lock_irqsave+0x4c/0x58) from [<c026ea3c>] (mxs_mmc_enable_sdio_irq+0x18/0xd4) [ 79.660000] [<c026ea3c>] (mxs_mmc_enable_sdio_irq+0x18/0xd4) from [<c026f7fc>] (mxs_mmc_irq_handler+0xd4/0xe8) [ 79.660000] [<c026f7fc>] (mxs_mmc_irq_handler+0xd4/0xe8) from [<c006bdd8>] (handle_irq_event_percpu+0x70/0x254) [ 79.660000] [<c006bdd8>] (handle_irq_event_percpu+0x70/0x254) from [<c006bff8>] (handle_irq_event+0x3c/0x5c) [ 79.660000] [<c006bff8>] (handle_irq_event+0x3c/0x5c) from [<c006e6d0>] (handle_level_irq+0x90/0x110) [ 79.660000] [<c006e6d0>] (handle_level_irq+0x90/0x110) from [<c006b930>] (generic_handle_irq+0x38/0x50) [ 79.660000] [<c006b930>] (generic_handle_irq+0x38/0x50) from [<c00102fc>] (handle_IRQ+0x30/0x84) [ 79.660000] [<c00102fc>] (handle_IRQ+0x30/0x84) from [<c000f058>] (__irq_svc+0x38/0x60) [ 79.660000] [<c000f058>] (__irq_svc+0x38/0x60) from [<c0010520>] (default_idle+0x2c/0x40) [ 79.660000] [<c0010520>] (default_idle+0x2c/0x40) from [<c0010a90>] (cpu_idle+0x64/0xcc) [ 79.660000] [<c0010a90>] (cpu_idle+0x64/0xcc) from [<c04ff858>] (start_kernel+0x244/0x2c8) Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: bfin_sdh: fix dma_desc_array build errorSonic Zhang
Descriptor array structure has been moved into blackfin dma.h head file. This patch fix below error: drivers/mmc/host/bfin_sdh.c:52:8: error: redefinition of 'struct dma_desc_array' make[4]: *** [drivers/mmc/host/bfin_sdh.o] Error 1 Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04UBI: fix a horrible memory deallocation bugArtem Bityutskiy
UBI was mistakingly using 'kfree()' instead of 'kmem_cache_free()' when freeing "attach eraseblock" structures in vtbl.c. Thankfully, this happened only when we were doing auto-format, so many systems were unaffected. However, there are still many users affected. It is strange, but the system did not crash and nothing bad happened when the SLUB memory allocator was used. However, in case of SLOB we observed an crash right away. This problem was introduced in 2.6.39 by commit "6c1e875 UBI: add slab cache for ubi_scan_leb objects" A note for stable trees: Because variable were renamed, this won't cleanly apply to older kernels. Changing names like this should help: 1. ai -> si 2. aeb_slab_cache -> seb_slab_cache 3. new_aeb -> new_seb Reported-by: Richard Genoud <richard.genoud@gmail.com> Tested-by: Richard Genoud <richard.genoud@gmail.com> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: stable@vger.kernel.org [v2.6.39+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-09-03ARM: shmobile: armadillo800eva: enable rw rootfs mountKuninori Morimoto
armadillo800eva default boot loader is "hermit", and it's tag->u.core.flags has flag when kernel boots. Because of this, ${LINUX}/arch/arm/kernel/setup.c :: parse_tag_core() didn't remove MS_RDONLY flag from root_mountflags. Thus, the rootfs is mounted as "readonly". This patch adds "rw" kernel parameter, and enable read/write mounts for rootfs Cc: Masahiro Nakai <nakai@atmark-techno.com> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Simon Horman <horms@verge.net.au>
2012-09-02Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French. * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: CIFS: Fix cifs_do_create error hadnling cifs: print error code if smb signature verification fails CIFS: Fix log messages in packet checking for SMB2 CIFS: Protect i_nlink from being negative
