commit 8b01fc86b9f425899f8a3a8fc1c47d73c2c20543 upstream.
This prevents a race between chown() and execve(), where chowning a
setuid-user binary to root would momentarily make the binary setuid
root.
This patch was mostly written by Linus Torvalds.
Signed-off-by: Jann Horn <jann@thejh.net>
[ Upstream commit 213dd74aee765d4e5f3f4b9607fef0cf97faa2af ]
On Wed, Apr 15, 2015 at 05:41:26PM +0200, Nicolas Dichtel wrote:
> Le 15/04/2015 15:57, Herbert Xu a écrit :
> >On Wed, Apr 15, 2015 at 06:22:29PM +0800, Herbert Xu wrote:
> [snip]
> >Subject: skbuff: Do not scrub skb mark within the same name space
> >The commit ea23192e8e577dfc51e0f4fc5ca113af334edff9 ("tunnels:
> Maybe add a Fixes tag?
> Fixes: ea23192e8e57 ("tunnels: harmonize cleanup done on skb on rx path")
> >harmonize cleanup done on skb on rx path") broke anyone trying to
> >use netfilter marking across IPv4 tunnels. While most of the
> >fields that are cleared by skb_scrub_packet don't matter, the
> >netfilter mark must be preserved.
> >This patch rearranges skb_scurb_packet to preserve the mark field.
> nit: s/scurb/scrub
> Else it's fine for me.
Sure.
PS I used the wrong email for James the first time around. So
let me repeat the question here. Should secmark be preserved
or cleared across tunnels within the same name space? In fact,
do our security models even support name spaces?
---8<---
This patch rearranges skb_scrub_packet to preserve the mark field.
Acked-by: Thomas Graf <tgraf@suug.ch>
[ Upstream commit 4c0ee414e877b899f7fc80aafb98d9425c02797f ]
This patch reverts commit b8fb4e0648a2ab3734140342002f68fb0c7d1602
because the secmark must be preserved even when a packet crosses
namespace boundaries. The reason is that security labels apply to
the system as a whole and is not per-namespace.
[ Upstream commit c3de6317d748e23b9e46ba36e10483728d00d144 ]
Due to missing bounds check the DAG pass of the BPF verifier can corrupt
the memory which can cause random crashes during program loading:
[8.449451] BUG: unable to handle kernel paging request at ffffffffffffffff
[8.451293] IP: [<ffffffff811de33d>] kmem_cache_alloc_trace+0x8d/0x2f0
[8.452329] Oops: 0000 [#1] SMP
[8.452329] Call Trace:
[8.452329] [<ffffffff8116cc82>] bpf_check+0x852/0x2000
[8.452329] [<ffffffff8116b7e4>] bpf_prog_load+0x1e4/0x310
[8.452329] [<ffffffff811b190f>] ? might_fault+0x5f/0xb0
[8.452329] [<ffffffff8116c206>] SyS_bpf+0x806/0xa30
Fixes: f1bca824dabb ("bpf: add search pruning optimization to verifier")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 074975d0374333f656c48487aa046a21a9b9d7a1 ]
Commit 9a2620c877454 ("bnx2x: prevent WARN during driver unload")
switched the napi/busy_lock locking mechanism from spin_lock() into
spin_lock_bh(), breaking inter-operability with netconsole, as netpoll
disables interrupts prior to calling our napi mechanism.
This switches the driver into using atomic assignments instead of the
spinlock mechanisms previously employed.
Based on initial patch from Yuval Mintz & Ariel Elior
I basically added softirq starvation avoidance, and mixture
of atomic operations, plain writes and barriers.
Note this slightly reduces the overhead for this driver when no
busy_poll sockets are in use.
Fixes: 9a2620c877454 ("bnx2x: prevent WARN during driver unload")
[ Upstream commit b50edd7812852d989f2ef09dcfc729690f54a42d ]
I noticed tcpdump was giving funky timestamps for locally
generated SYNACK messages on loopback interface.
11:42:46.938990 IP 127.0.0.1.48245 > 127.0.0.2.23850: S
945476042:945476042(0) win 43690 <mss 65495,nop,nop,sackOK,nop,wscale 7>
20:28:58.502209 IP 127.0.0.2.23850 > 127.0.0.1.48245: S
3160535375:3160535375(0) ack 945476043 win 43690 <mss
This is because we need to clear skb->tstamp before
entering lower stack, otherwise net_timestamp_check()
does not set skb->tstamp.
Fixes: 7faee5c0d514 ("tcp: remove TCP_SKB_CB(skb)->when")
[ Upstream commit b736a623bd099cdf5521ca9bd03559f3bc7fa31c ]
handle_offloads() calls skb_reset_inner_headers() to store
the layer pointers to the encapsulated packet. However, we
currently push the vlag tag (if there is one) onto the packet
afterwards. This changes the MAC header for the encapsulated
packet but it is not reflected in skb->inner_mac_header, which
breaks GSO and drivers which attempt to use this for encapsulation
offloads.
Fixes: 1eaa8178 ("vxlan: Add tx-vlan offload support.")
Signed-off-by: Jesse Gross <jesse@nicira.com>
Pull vfs and fs fixes from Al Viro:
"Several AIO and OCFS2 fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ocfs2: _really_ sync the right range
ocfs2_file_write_iter: keep return value and current position update in sync
[regression] ocfs2: do *not* increment ->ki_pos twice
ioctx_alloc(): fix vma (and file) leak on failure
fix mremap() vs. ioctx_kill() race
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal
Pull last minute thermal-SoC management fixes from Eduardo Valentin:
"Specifics:
- Minor fixes on ST and RCAR thermal drivers.
- Avoid flooding kernel log when driver returns -EAGAIN.
Note: I am sending this pull on Rui's behalf while he fixes issues in
his Linux box"
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal:
drivers: thermal: st: remove several sparse warnings
thermal: constify of_device_id array
thermal: Do not log an error if thermal_zone_get_temp returns -EAGAIN
thermal: rcar: Fix typo in r8a73a4 SoC name
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound
Pull last-minute ASoC fix from Mark Brown:
"This patch backs out a change that came in during the merge window
which selects a configuration for GPIO4 on pcm512x CODECs that may not
be suitable for all systems using the device. Changes for v4.1 will
make this properly configurable but for now it's safest to revert to
the v3.19 behaviour and leave the pin configuration alone.
Sorry for sending this direct at the last minute but due to the GPIO
misuse it'd be really good to get it in the release and I'd not
realised it hadn't been sent yet - between some travel, a job change
and other non-urgent fixes coming in I'd lost track of the urgency.
It's been in -next for several weeks now, is isolated to the driver
and fairly clear to inspection"
* tag 'asoc-fix-v4.0-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound:
ASoC: pcm512x: Remove hardcoding of pll-lock to GPIO4
Currently GPIO4 is hardcoded to output the pll-lock signal.
Unfortunately this is after the pll-out GPIO is configured which
is selectable in the device tree. Therefore it is not possible to
use GPIO4 for pll-out. Therefore this patch removes the
configuration of GPIO4.
Signed-off-by: Howard Mitchell <hm@hmbedded.co.uk>
Signed-off-by: Mark Brown <broonie@kernel.org>
caps retrieval"
This reverts commit ecc19d17868be9c9f8f00ed928791533c420f3e0.
It added a new warning to try to encourage driver writers to set the
device capabities properly, but drivers haven't been updated and in the
meantime it just generaters a scary message that users cannot actually
do anything about.
Warnings like these are appropriate if you actually expect to fix the
code that causes them. They are not appropriate for releases.
Requested-by: Peter Hurley <peter@hurleysoftware.com>
Jan Engelhardt reports a strange oops with an invalid ->sense_buffer
pointer in scsi_init_cmd_errh() with the blk-mq code.
The sense_buffer pointer should have been initialized by the call to
scsi_init_request() from blk_mq_init_rq_map(), but there seems to be
some non-repeatable memory corruptor.
This patch makes sure we initialize the whole struct request allocation
(and the associated 'struct scsi_cmnd' for the SCSI case) to zero, by
using __GFP_ZERO in the allocation. The old code initialized a couple
of individual fields, leaving the rest undefined (although many of them
are then initialized in later phases, like blk_mq_rq_ctx_init() etc.
It's not entirely clear why this matters, but it's the rigth thing to do
regardless, and with 4.0 imminent this is the defensive "let's just make
sure everything is initialized properly" patch.
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Jens Axboe <axboe@kernel.dk>
Pull dmaengine fix from Vinod Koul:
"I have one more fix to fix the boot warning on cppi driver due to
missing capabilities"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: cppi41: add missing bitfields
Pull late ipmi fixes from Corey Minyard:
"Some annoying issues in the IPMI driver that would be good to have
fixed before 4.0 is released.
These got reported or discovered late, but they will avoid some
situations that would cause lots of log spam and in one case a
deadlock"
* tag 'for-linus-4.0-1' of git://git.code.sf.net/p/openipmi/linux-ipmi:
ipmi_ssif: Use interruptible completion for waiting in the thread
ipmi/powernv: Fix minor locking bug
ipmi: Handle BMCs that don't allow clearing the rcv irq bit
Add missing directions, residue_granularity,
srd_addr_widths and dst_addr_widths bitfields.
Without those we will see a kernel WARN()
when loading musb on am335x devices.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
The code was using an normal completion, but that caused stuck
task errors after a while. Use an interruptible one to avoid that.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
If ipmi_powernv_recv(...) is called without a current message it
prints a warning and returns. However it fails to release the message
lock causing the system to dead lock during any subsequent IPMI
operations.
This error path should never normally be taken unless there are bugs
elsewhere in the system.
Signed-off-by: Alistair Popple <alistair@popple.id.au>
Some BMCs don't let you clear the receive irq bit in the global
enables. This is kind of silly, but they give an error if you
try to clear it. Compensate for this by detecting the situation
and working around it.
Tested-by: Thomas D <whissi@whissi.de>
Reviewed-by: Thomas D <whissi@whissi.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is our remaining set of three fixes for 4.0: two oops fixes(one
for cable pulls triggering oopses and the other be2iscsi specific) and
one warn on in sysfs on multipath devices using enclosures"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
Defer processing of REQ_PREEMPT requests for blocked devices
be2iscsi: Fix kernel panic when device initialization fails
enclosure: fix WARN_ON removing an adapter in multi-path devices
Pull SCSI target fixes from Nicholas Bellinger:
"Just a few small fixes:
Two from Andy, the first addresses a v4.0 target specific regression
to a user visible configfs attribute, and the second adds a set of
missing brackets around IPv6 discovery portal information within
iscsi-target.
And one from Mike that fixes an OOPs regression in traditional
iscsi-target when an iovec allocation fails, that has been present
since v3.10.y code. (CC'd to stable)"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iscsi target: fix oops when adding reject pdu
iscsi-target: TargetAddress in SendTargets should bracket ipv6 addresses
target: Allow userspace to write 1 to attrib/emulate_fua_write
This fixes a oops due to a double list add when adding a reject PDU for
iscsit_allocate_iovecs allocation failures. The cmd has already been
added to the conn_cmd_list in iscsit_setup_scsi_cmd, so this has us call
iscsit_reject_cmd.
Note that for ERL0 the reject PDU is not actually sent, so this patch
is not completely tested. Just verified we do not oops. The problem is the
add reject functions return -1 which is returned all the way up to
iscsi_target_rx_thread which for ERL0 will drop the connection.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Cc: <stable@vger.kernel.org> # v3.10+
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Here are fixes gathered for 4.0-final; one FireFire endian fix, two
USB-audio quirks, and three HD-audio quirks.
All relatively small and device-specific fixes, should be pretty safe
to apply"
* tag 'sound-4.0' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: usb - Creative USB X-Fi Pro SB1095 volume knob support
ALSA: hda - Fix headphone pin config for Lifebook T731
ALSA: bebob: fix to processing in big-endian machine for sending cue
ALSA: hda/realtek - Make more stable to get pin sense for ALC283
ALSA: usb-audio: don't try to get Benchmark DAC1 sample rate
ALSA: hda/realtek - Support Dell headset mode for ALC256
git://git.rocketboards.org/linux-socfpga-next
Pull arch/nios2 fixes from Ley Foon Tan:
"There are 3 arch/nios2 fixes for 4.0 final:
- fix cache coherency issue when debugging with gdb
- move restart_block to struct task_struct (aligned with other
architectures)
- fix for missing registers defines for ptrace"
* tag 'nios2-fixes-v4.0-final' of git://git.rocketboards.org/linux-socfpga-next:
nios2: fix cache coherency issue when debug with gdb
nios2: add missing ptrace registers defines
nios2: signal: Move restart_block to struct task_struct
Remove the end address checking for flushda function. We need to flush
each address line for flushda instruction, from start to end address.
This is because flushda instruction only flush the cache if tag and line
fields are matched.
Change to use ldwio instruction (bypass cache) to load the instruction
that causing trap. Our interest is the actual instruction that executed
by the processor, this should be uncached.
Note, EA address might be an userspace cached address.
Signed-off-by: Ley Foon Tan <lftan@altera.com>
Pull power management and ACPI fixes from Rafael Wysocki:
"These are stable-candidate fixes of some recently reported issues in
the cpufreq core, cpuidle core, the ACPI cpuidle driver and the
hibernate core.
Specifics:
- Revert a 3.17 hibernate commit that was supposed to fix an issue
related to e820 reserved regions, but broke resume from hibernation
on Lenovo x230 (Rafael J Wysocki).
- Prevent the ACPI cpuidle driver from overwriting the name and
description of the C0 state set by the core when the list of
C-states changes (Thomas Schlichter).
- Remove the no longer needed state_count field from struct
cpuidle_device which prevents the list of C-states shown by the
sysfs interface from becoming incorrect when the current number of
them is different from the number of C-states on boot (Bartlomiej
Zolnierkiewicz).
- The cpufreq core updates the policy object of the only online CPU
during system resume to make it reflect the current hardware state,
but it always assumes that CPU to be CPU0 which need not be the
case, so fix the code to avoid that assumption (Viresh Kumar)"
* tag 'pm+acpi-4.0-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
Revert "PM / hibernate: avoid unsafe pages in e820 reserved regions"
cpuidle: ACPI: do not overwrite name and description of C0
cpuidle: remove state_count field from struct cpuidle_device
cpufreq: Schedule work for the first-online CPU on resume
* pm-sleep:
* pm-cpufreq:
* pm-cpuidle:
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"Here are some fixes for v4.0. I apologize for how late they are. We
were hoping for some better fixes, but couldn't get them polished in
time. These fix:
- a Xen domU oops with PCI passthrough devices
- a sparc T5 boot failure
- a STM SPEAr13xx crash (use after initdata freed)
- a cpcihp hotplug driver thinko
- an AER thinko that printed stack junk
Details:
Enumeration
- Don't look for ACPI hotplug parameters if ACPI is disabled (Bjorn Helgaas)
Resource management
- Revert "sparc/PCI: Clip bridge windows to fit in upstream windows" (Bjorn Helgaas)
AER
- Avoid info leak in __print_tlp_header() (Rasmus Villemoes)
PCI device hotplug
- Add missing curly braces in cpci_configure_slot() (Dan Carpenter)
ST Microelectronics SPEAr13xx host bridge driver
- Drop __initdata from spear13xx_pcie_driver (Matwey V. Kornilov)
* tag 'pci-v4.0-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Don't look for ACPI hotplug parameters if ACPI is disabled
PCI: cpcihp: Add missing curly braces in cpci_configure_slot()
PCI/AER: Avoid info leak in __print_tlp_header()
PCI: spear: Drop __initdata from spear13xx_pcie_driver
Adds an entry for Creative USB X-Fi to the rc_config array in
mixer_quirks.c to allow use of volume knob on the device.
Adds support for newer X-Fi Pro card, known as "Model No. SB1095"
with USB ID "041e:3237"
Signed-off-by: Dmitry M. Fedin <dmitry.fedin@gmail.com>
"ocfs2 syncs the wrong range" had been broken; prior to it the
code was doing the wrong thing in case of O_APPEND, all right,
but _after_ it we were syncing the wrong range in 100% cases.
*ppos, aka iocb->ki_pos is incremented prior to that point,
so we are always doing sync on the area _after_ the one we'd
written to.
Spotted by Joseph Qi <joseph.qi@huawei.com> back in January;
unfortunately, I'd missed his mail back then ;-/
Cc: stable@vger.kernel.org
These are all register available in nios2.
Pull drm fixes from Dave Airlie:
"Final drm fixes: one core locking imbalance regression, and a bunch of
i915 baytrail s/r fixes"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm: fix drm_mode_getconnector() locking imbalance regression
drm/i915/vlv: remove wait for previous GFX clk disable request
drm/i915/chv: Remove Wait for a previous gfx force-off
drm/i915/vlv: save/restore the power context base reg
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull ceph revert from Sage Weil:
"This corrects a recent misadventure with __GFP_MEMALLOC and
PF_MEMALLOC; it turns out it's not a good fit for RBD and we're better
off relying on dirty page throttling"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
Revert "libceph: use memalloc flags for net IO"
Merge misc fixes from Andrew Morton:
"Three fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm: numa: disable change protection for vma(VM_HUGETLB)
include/linux/dmapool.h: declare struct device
mm: move zone lock to a different cache line than order-0 free page lists
Unlike most (all?) other copies from user space, kernel module loading
is almost unlimited in size. So we do a potentially huge
"copy_from_user()" when we copy the module data from user space to the
kernel buffer, which can be a latency concern when preemption is
disabled (or voluntary).
Also, because 'copy_from_user()' clears the tail of the kernel buffer on
failures, even a *failed* copy can end up wasting a lot of time.
Normally neither of these are concerns in real life, but they do trigger
when doing stress-testing with trinity. Running in a VM seems to add
its own overheadm causing trinity module load testing to even trigger
the watchdog.
The simple fix is to just chunk up the module loading, so that it never
tries to copy insanely big areas in one go. That bounds the latency,
and also the amount of (unnecessarily, in this case) cleared memory for
the failure case.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
The rule for 'copy_from_user()' is that it zeroes the remaining kernel
buffer even when the copy fails halfway, just to make sure that we don't
leave uninitialized kernel memory around. Because even if we check for
errors, some kernel buffers stay around after thge copy (think page
cache).
However, the x86-64 logic for user copies uses a copy_user_generic()
function for all the cases, that set the "zerorest" flag for any fault
on the source buffer. Which meant that it didn't just try to clear the
kernel buffer after a failure in copy_from_user(), it also tried to
clear the destination user buffer for the "copy_in_user()" case.
Not only is that pointless, it also means that the clearing code has to
worry about the tail clearing taking page faults for the user buffer
case. Which is just stupid, since that case shouldn't happen in the
first place.
Get rid of the whole "zerorest" thing entirely, and instead just check
if the destination is in kernel space or not. And then just use
memset() to clear the tail of the kernel buffer if necessary.
git://anongit.freedesktop.org/drm-intel into drm-fixes
three commits, all cc: stable, to address Baytrail
suspend/resume issues.
* tag 'drm-intel-fixes-2015-04-08' of git://anongit.freedesktop.org/drm-intel:
generic_file_direct_write() already does that. Broken by
"ocfs2: do not fallback to buffer I/O write if appending"
Some BIOS version of Fujitsu Lifebook T731 seems to set up the
headphone pin (0x21) without the assoc number 0x0f while it's set only
to the output on the docking port (0x1a). With the recent commit
[03ad6a8c93b6: ALSA: hda - Fix "PCM" name being used on one DAC when
there are two DACs], this resulted in the weird mixer element
mapping where the headphone on the laptop is assigned as a shared
volume with the speaker and the docking port is assigned as an
individual headphone.
This patch improves the situation by correcting the headphone pin
config to the more appropriate value.
Reported-and-tested-by: Taylor Smock <smocktaylor@gmail.com>
SCSI transport drivers and SCSI LLDs block a SCSI device if the
transport layer is not operational. This means that in this state
no requests should be processed, even if the REQ_PREEMPT flag has
been set. This patch avoids that a rescan shortly after a cable
pull sporadically triggers the following kernel oops:
BUG: unable to handle kernel paging request at ffffc9001a6bc084
IP: [<ffffffffa04e08f2>] mlx4_ib_post_send+0xd2/0xb30 [mlx4_ib]
Process rescan-scsi-bus (pid: 9241, threadinfo ffff88053484a000, task ffff880534aae100)
Call Trace:
[<ffffffffa0718135>] srp_post_send+0x65/0x70 [ib_srp]
[<ffffffffa071b9df>] srp_queuecommand+0x1cf/0x3e0 [ib_srp]
[<ffffffffa0001ff1>] scsi_dispatch_cmd+0x101/0x280 [scsi_mod]
[<ffffffffa0009ad1>] scsi_request_fn+0x411/0x4d0 [scsi_mod]
[<ffffffff81223b37>] __blk_run_queue+0x27/0x30
[<ffffffff8122a8d2>] blk_execute_rq_nowait+0x82/0x110
[<ffffffff8122a9c2>] blk_execute_rq+0x62/0xf0
[<ffffffffa000b0e8>] scsi_execute+0xe8/0x190 [scsi_mod]
[<ffffffffa000b2f3>] scsi_execute_req+0xa3/0x130 [scsi_mod]
[<ffffffffa000c1aa>] scsi_probe_lun+0x17a/0x450 [scsi_mod]
[<ffffffffa000ce86>] scsi_probe_and_add_lun+0x156/0x480 [scsi_mod]
[<ffffffffa000dc2f>] __scsi_scan_target+0xdf/0x1f0 [scsi_mod]
[<ffffffffa000dfa3>] scsi_scan_host_selected+0x183/0x1c0 [scsi_mod]
[<ffffffffa000edfb>] scsi_scan+0xdb/0xe0 [scsi_mod]
[<ffffffffa000ee13>] store_scan+0x13/0x20 [scsi_mod]
[<ffffffff811c8d9b>] sysfs_write_file+0xcb/0x160
[<ffffffff811589de>] vfs_write+0xce/0x140
[<ffffffff81158b53>] sys_write+0x53/0xa0
[<ffffffff81464592>] system_call_fastpath+0x16/0x1b
[<00007f611c9d9300>] 0x7f611c9d92ff
Reported-by: Max Gurtuvoy <maxg@mellanox.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Kernel panic was happening as iscsi_host_remove() was called on
a host which was not yet added.
Signed-off-by: John Soni Jose <sony.john-n@emulex.com>
Some M-Audio devices require to receive bootup command just after
powering on, while codes in BeBoB driver doesn't work properly in
big-endian machine because the command should be aligned by
little-endian.
This commit fixes this bug. This fix should go to stable kernel.
Cc: Takayuki Shiroma <t.shiroma.oki@gmail.com>
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
This reverts commit d63e2e1f3df904bf6bd150bdafb42ddbb3257ea8.
David Ahern reported that d63e2e1f3df9 breaks booting on an 8-socket T5
sparc system. He also verified that the system boots with d63e2e1f3df9
reverted. Yinghai has some fixes, but they need a little more polishing
than we can do before v4.0.
Link: http://lkml.kernel.org/r/5514391F.2030300@oracle.com # report
Link: http://lkml.kernel.org/r/1427857069-6789-1-git-send-email-yinghai@kernel.org # patches
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: stable@vger.kernel.org # v3.19+
Booting a v3.18 or newer Xen domU kernel with PCI devices passed through
results in an oops (this is a 32-bit 3.13.11 dom0 with a 64-bit 4.4.0
hypervisor and 32-bit domU):
BUG: unable to handle kernel paging request at 0030303e
IP: [<c06ed0e6>] acpi_ns_validate_handle+0x12/0x1a
Call Trace:
[<c06eda4d>] ? acpi_evaluate_object+0x31/0x1fc
[<c06b78e1>] ? pci_get_hp_params+0x111/0x4e0
[<c0407bc7>] ? xen_force_evtchn_callback+0x17/0x30
[<c04085fb>] ? xen_restore_fl_direct_reloc+0x4/0x4
[<c0699d34>] ? pci_device_add+0x24/0x450
Don't look for ACPI configuration information if ACPI has been disabled.
I don't think this is the best fix, because we can boot plain Linux (no
Xen) with "acpi=off", and we don't need this check in pci_get_hp_params().
There should be a better fix that would make Xen domU work the same way.
The domU kernel has ACPI support but it has no AML. There should be a way
to initialize the ACPI data structures so things fail gracefully rather
than oopsing. This is an interim fix to address the regression.
Fixes: 6cd33649fa83 ("PCI: Add pci_configure_device() during enumeration")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=96301
Reported-by: Michael D Labriola <mlabriol@gdeb.com>
Tested-by: Michael D Labriola <mlabriol@gdeb.com>
CC: stable@vger.kernel.org # v3.18+
Pin sense will active when power pin is wake up.
Power pin will not wake up immediately during resume state.
Add some delay to wait for power pin activated.
Signed-off-by: Kailang Yang <kailang@realtek.com>
See https://lkml.org/lkml/2014/10/29/643 and commit f56141e3e2d9
("all arches, signal: move restart_block to struct task_struct")
Regression in commit 2caa80e72b57c6216aec6f6a11fcfb4fec46daa0
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Sun Feb 22 11:38:36 2015 +0100
drm: Fix deadlock due to getconnector locking changes
If the drm_connector_find() call returns NULL, we should no longer
call drm_modeset_unlock() to avoid locking imbalance.
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
