[ Upstream commit c0795bf64cba4d1b796fdc5b74b33772841ed1bb ]
Otherwise, if we fail to allocate new PIO buffers, our TXQs will try to
use the old ones, which aren't there any more.
Fixes: 183233bec810 "sfc: Allocate and link PIO buffers; map them with write-combining"
Signed-off-by: Edward Cree <ecree@solarflare.com>
[ Upstream commit addf8fc4acb1cf79492ac64966f07178793cb3d7 ]
We used to check dev->reg_state against NETREG_REGISTERED after each
time we are woke up. But after commit 9e641bdcfa4e ("net-tun:
restructure tun_do_read for better sleep/wakeup efficiency"), it uses
skb_recv_datagram() which does not check dev->reg_state. This will
result if we delete a tun/tap device after a process is blocked in the
reading. The device will wait for the reference count which was held
by that process for ever.
Fixes this by using RCV_SHUTDOWN which will be checked during
sk_recv_datagram() before trying to wake up the process during uninit.
Fixes: 9e641bdcfa4e ("net-tun: restructure tun_do_read for better
Cc: Eric Dumazet <edumazet@google.com>
Cc: Xi Wang <xii@google.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 03aaaa9b941e136757b55c4cf775aab6068dfd94 ]
The publication field of the old netlink API should contain the
publication key and not the publication reference.
Fixes: 44a8ae94fd55 (tipc: convert legacy nl name table dump to nl compat)
Signed-off-by: Richard Alpe <richard.alpe@ericsson.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit 92964c79b357efd980812c4de5c1fd2ec8bb5520 ]
When we free cb->skb after a dump, we do it after releasing the
lock. This means that a new dump could have started in the time
being and we'll end up freeing their skb instead of ours.
This patch saves the skb and module before we unlock so we free
the right memory.
Fixes: 16b304f3404f ("netlink: Eliminate kmalloc in netlink dump operation.")
Reported-by: Baozeng Ding <sploving1@gmail.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 45e093ae2830cd1264677d47ff9a95a71f5d9f9c ]
Make sure the socket for which the user is listing publication exists
before parsing the socket netlink attributes.
Prior to this patch a call without any socket caused a NULL pointer
dereference in tipc_nl_publ_dump().
Tested-and-reported-by: Baozeng Ding <sploving1@gmail.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.cm>
[ Upstream commit 233135b763db7c64d07b728a9c66745fb0376275 ]
This adds a name to each buf_ops structure, so that if
a verifier fails we can print the type of verifier that
failed it. Should be a slight debugging aid, I hope.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
[ Upstream commit 759c01142a5d0f364a462346168a56de28a80f52 ]
On no-so-small systems, it is possible for a single process to cause an
OOM condition by filling large pipes with data that are never read. A
typical process filling 4000 pipes with 1 MB of data will use 4 GB of
memory. On small systems it may be tricky to set the pipe max size to
prevent this from happening.
This patch makes it possible to enforce a per-user soft limit above
which new pipes will be limited to a single page, effectively limiting
them to 4 kB each, as well as a hard limit above which no new pipes may
be created for this user. This has the effect of protecting the system
against memory abuse without hurting other users, and still allowing
pipes to work correctly though with less data at once.
The limit are controlled by two new sysctls : pipe-user-pages-soft, and
pipe-user-pages-hard. Both may be disabled by setting them to zero. The
default soft limit allows the default number of FDs per process (1024)
to create pipes of the default size (64kB), thus reaching a limit of 64MB
before starting to create only smaller pipes. With 256 processes limited
to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB =
1084 MB of memory allocated for a user. The hard limit is disabled by
default to avoid breaking existing applications that make intensive use
of pipes (eg: for splicing).
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
[ Upstream commit a95d069204e178f18476f5499abab0d0d9cbc32c ]
After commit 92923ca3aacef63c92d ("mm: meminit: only set page reserved
in the memblock region"), the MIPS hibernation is broken. Because pages
in nosave data section should be "reserved", but currently they aren't
set to "reserved" at initialization. This patch makes hibernation work
again.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: Aurelien Jarno <aurelien@aurel32.net>
Cc: Steven J . Hill <sjhill@realitydiluted.com>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Cc: linux-mips@linux-mips.org
Cc: stable@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/12888/
s3c24xx_serial_set_termios()
[ Upstream commit b8995f527aac143e83d3900ff39357651ea4e0f6 ]
This patch fixes the broken serial log when changing the clock source
of uart device. Before disabling the original clock source, this patch
enables the new clock source to protect the clock off state for a split second.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com>
[ Upstream commit 6798df4c5fe0a7e6d2065cf79649a794e5ba7114 ]
When csw->con_startup() fails in do_register_con_driver, we return no
error (i.e. 0). This was changed back in 2006 by commit 3e795de763.
Before that we used to return -ENODEV.
So fix the return value to be -ENODEV in that case again.
Fixes: 3e795de763 ("VT binding: Add binding/unbinding support for the VT console")
Reported-by: "Dan Carpenter" <dan.carpenter@oracle.com>
[ Upstream commit 316314cae15fb0e3869b76b468f59a0c83ac3d4e ]
This ensures that the guest doesn't see XSAVE extensions
(e.g. xgetbv1 or xsavec) that the host lacks.
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit 332a5b446b7916d272c2a659a3b20909ce34d2c1 ]
In the current implementation functionfs generates a EFAULT for async read
operations if the read buffer size is larger than the URB data size. Since
a application does not necessarily know how much data the host side is
going to send it typically supplies a buffer larger than the actual data,
which will then result in a EFAULT error.
This behaviour was introduced while refactoring the code to use iov_iter
interface in commit c993c39b8639 ("gadget/function/f_fs.c: use put iov_iter
into io_data"). The original code took the minimum over the URB size and
the user buffer size and then attempted to copy that many bytes using
copy_to_user(). If copy_to_user() could not copy all data a EFAULT error
was generated. Restore the original behaviour by only generating a EFAULT
error when the number of bytes copied is not the size of the URB and the
target buffer has not been fully filled.
Commit 342f39a6c8d3 ("usb: gadget: f_fs: fix check in read operation")
already fixed the same problem for the synchronous read path.
Fixes: c993c39b8639 ("gadget/function/f_fs.c: use put iov_iter into io_data")
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit 2a0974aa1a0b40a92387ea03dbfeacfbc9ba182c ]
This patch adds the CLK_SET_RATE_PARENT flag for the crypto core and
ahb blocks. Without this flag, clk_set_rate can fail for certain
frequency requests.
Signed-off-by: Andy Gross <andy.gross@linaro.org>
Fixes: 3966fab8b6ab ("clk: qcom: Add MSM8916 Global Clock Controller support")
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[ Upstream commit c79b4713304f812d3d6c95826fc3e5fc2c0b0c14 ]
The fd we pass in may not be on a btrfs file system, so don't try to do
BTRFS_I() on it. Thanks,
Signed-off-by: Josef Bacik <jbacik@fb.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
[ Upstream commit e3c00d87845ab375f90fa6e10a5e72a3a5778cd3 ]
On DCE6.1 PPLL2 is exclusively available to UNIPHYA, so it should not
be taken into consideration when looking for an already enabled PLL
to be shared with other outputs.
This fixes the broken VGA port (TRAVIS DP->VGA bridge) on my Richland
based laptop, where the internal display is connected to UNIPHYA through
a TRAVIS DP->LVDS bridge.
Bug:
https://bugs.freedesktop.org/show_bug.cgi?id=78987
v2: agd: add check in radeon_get_shared_nondp_ppll as well, drop
extra parameter.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 723cacbd9dc79582e562c123a0bacf8bfc69e72a ]
There is a race with multi-threaded applications between context switch and
pagetable upgrade. In switch_mm() a new user_asce is built from mm->pgd and
mm->context.asce_bits, w/o holding any locks. A concurrent mmap with a
pagetable upgrade on another thread in crst_table_upgrade() could already
have set new asce_bits, but not yet the new mm->pgd. This would result in a
corrupt user_asce in switch_mm(), and eventually in a kernel panic from a
translation exception.
Fix this by storing the complete asce instead of just the asce_bits, which
can then be read atomically from switch_mm(), so that it either sees the
old value or the new value, but no mixture. Both cases are OK. Having the
old value would result in a page fault on access to the higher level memory,
but the fault handler would see the new mm->pgd, if it was a valid access
after the mmap on the other thread has completed. So as worst-case scenario
we would have a page fault loop for the racing thread until the next time
slice.
Also remove dead code and simplify the upgrade/downgrade path, there are no
upgrades from 2 levels, and only downgrades from 3 levels for compat tasks.
There are also no concurrent upgrades, because the mmap_sem is held with
down_write() in do_mmap, so the flush and table checks during upgrade can
be removed.
Reported-by: Michael Munday <munday@ca.ibm.com>
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
[ Upstream commit 10a81980fc47e64ffac26a073139813d3f697b64 ]
In the very unlikely case __tcp_retransmit_skb() can not use the cloning
done in tcp_transmit_skb(), we need to refresh skb_mstamp before doing
the copy and transmit, otherwise TCP TS val will be an exact copy of
original transmit.
Fixes: 7faee5c0d514 ("tcp: remove TCP_SKB_CB(skb)->when")
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 79e48650320e6fba48369fccf13fd045315b19b8 ]
Stack object "dte_facilities" is allocated in x25_rx_call_request(),
which is supposed to be initialized in x25_negotiate_facilities.
However, 5 fields (8 bytes in total) are not initialized. This
object is then copied to userland via copy_to_user, thus infoleak
occurs.
Signed-off-by: Kangjie Lu <kjlu@gatech.edu>
[ Upstream commit 31ca0458a61a502adb7ed192bf9716c6d05791a5 ]
get_bridge_ifindices() is used from the old "deviceless" bridge ioctl
calls which aren't called with rtnl held. The comment above says that it is
called with rtnl but that is not really the case.
Here's a sample output from a test ASSERT_RTNL() which I put in
get_bridge_ifindices and executed "brctl show":
[ 957.422726] RTNL: assertion failed at net/bridge//br_ioctl.c (30)
[ 957.422925] CPU: 0 PID: 1862 Comm: brctl Tainted: G W O
4.6.0-rc4+ #157
[ 957.423009] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996),
BIOS 1.8.1-20150318_183358- 04/01/2014
[ 957.423009] 0000000000000000 ffff880058adfdf0 ffffffff8138dec5
0000000000000400
[ 957.423009] ffffffff81ce8380 ffff880058adfe58 ffffffffa05ead32
0000000000000001
[ 957.423009] 00007ffec1a444b0 0000000000000400 ffff880053c19130
0000000000008940
[ 957.423009] Call Trace:
[ 957.423009] [<ffffffff8138dec5>] dump_stack+0x85/0xc0
[ 957.423009] [<ffffffffa05ead32>]
br_ioctl_deviceless_stub+0x212/0x2e0 [bridge]
[ 957.423009] [<ffffffff81515beb>] sock_ioctl+0x22b/0x290
[ 957.423009] [<ffffffff8126ba75>] do_vfs_ioctl+0x95/0x700
[ 957.423009] [<ffffffff8126c159>] SyS_ioctl+0x79/0x90
[ 957.423009] [<ffffffff8163a4c0>] entry_SYSCALL_64_fastpath+0x23/0xc1
Since it only reads bridge ifindices, we can use rcu to safely walk the net
device list. Also remove the wrong rtnl comment above.
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit dedc58e067d8c379a15a8a183c5db318201295bb ]
The peer may be expecting a reply having sent a request and then done a
shutdown(SHUT_WR), so tearing down the whole socket at this point seems
wrong and breaks for me with a client which does a SHUT_WR.
Looking at other socket family's stream_recvmsg callbacks doing a shutdown
here does not seem to be the norm and removing it does not seem to have
had any adverse effects that I can see.
I'm using Stefan's RFC virtio transport patches, I'm unsure of the impact
on the vmci transport.
Signed-off-by: Ian Campbell <ian.campbell@docker.com>
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com>
Cc: Andy King <acking@vmware.com>
Cc: Dmitry Torokhov <dtor@vmware.com>
Cc: Jorgen Hansen <jhansen@vmware.com>
Cc: Adit Ranadive <aditr@vmware.com>
Cc: netdev@vger.kernel.org
[ Upstream commit 82d69203df634b4dfa765c94f60ce9482bcc44d6 ]
Use htons instead of unconditionally byte swapping nexthdr. On a little
endian systems shifting the byte is correct behavior, but it results in
incorrect csums on big endian architectures.
Fixes: f8c6455bb04b ('net/mlx4_en: Extend checksum offloading by CHECKSUM COMPLETE')
Signed-off-by: Daniel Jurgens <danielj@mellanox.com>
Reviewed-by: Carol Soto <clsoto@us.ibm.com>
Tested-by: Carol Soto <clsoto@us.ibm.com>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
[ Upstream commit 5f8e44741f9f216e33736ea4ec65ca9ac03036e6 ]
The stack object “map” has a total size of 32 bytes. Its last 4
bytes are padding generated by compiler. These padding bytes are
not initialized and sent out via “nla_put”.
[ Upstream commit b8670c09f37bdf2847cc44f36511a53afc6161fd ]
The stack object “info” has a total size of 12 bytes. Its last byte
is padding which is not initialized and leaked via “put_cmsg”.
[ Upstream commit 1c021bb717a70aaeaa4b25c91f43c2aeddd922de ]
In the receive path a queue's work bit was cleared unconditionally even
if fec_enet_rx_queue only read out a part of the available packets from
the hardware. This resulted in not reading any packets in the next napi
turn and so packets were delayed or lost.
The obvious fix is to only clear a queue's bit when the queue was
emptied.
Fixes: 4d494cdc92b3 ("net: fec: change data structure to support multiqueue")
Reviewed-by: Lucas Stach <l.stach@pengutronix.de>
Tested-by: Fugang Duan <fugang.duan@nxp.com>
Acked-by: Fugang Duan <fugang.duan@nxp.com>
[ Upstream commit 6071bd1aa13ed9e41824bafad845b7b7f4df5cfd ]
This was recently reported to me, and reproduced on the latest net kernel,
when attempting to run netperf from a host that had a netem qdisc attached
to the egress interface:
[ 788.073771] ---------------------[ cut here ]---------------------------
[ 788.096716] WARNING: at net/core/dev.c:2253 skb_warn_bad_offload+0xcd/0xda()
[ 788.129521] bnx2: caps=(0x00000001801949b3, 0x0000000000000000) len=2962
data_len=0 gso_size=1448 gso_type=1 ip_summed=3
[ 788.182150] Modules linked in: sch_netem kvm_amd kvm crc32_pclmul ipmi_ssif
ghash_clmulni_intel sp5100_tco amd64_edac_mod aesni_intel lrw gf128mul
glue_helper ablk_helper edac_mce_amd cryptd pcspkr sg edac_core hpilo ipmi_si
i2c_piix4 k10temp fam15h_power hpwdt ipmi_msghandler shpchp acpi_power_meter
pcc_cpufreq nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c
sd_mod crc_t10dif crct10dif_generic mgag200 syscopyarea sysfillrect sysimgblt
i2c_algo_bit drm_kms_helper ahci ata_generic pata_acpi ttm libahci
crct10dif_pclmul pata_atiixp tg3 libata crct10dif_common drm crc32c_intel ptp
serio_raw bnx2 r8169 hpsa pps_core i2c_core mii dm_mirror dm_region_hash dm_log
dm_mod
[ 788.465294] CPU: 16 PID: 0 Comm: swapper/16 Tainted: G W
------------ 3.10.0-327.el7.x86_64 #1
[ 788.511521] Hardware name: HP ProLiant DL385p Gen8, BIOS A28 12/17/2012
[ 788.542260] ffff880437c036b8 f7afc56532a53db9 ffff880437c03670
ffffffff816351f1
[ 788.576332] ffff880437c036a8 ffffffff8107b200 ffff880633e74200
ffff880231674000
[ 788.611943] 0000000000000001 0000000000000003 0000000000000000
ffff880437c03710
[ 788.647241] Call Trace:
[ 788.658817] <IRQ> [<ffffffff816351f1>] dump_stack+0x19/0x1b
[ 788.686193] [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0
[ 788.713803] [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80
[ 788.741314] [<ffffffff812f92f3>] ? ___ratelimit+0x93/0x100
[ 788.767018] [<ffffffff81637f49>] skb_warn_bad_offload+0xcd/0xda
[ 788.796117] [<ffffffff8152950c>] skb_checksum_help+0x17c/0x190
[ 788.823392] [<ffffffffa01463a1>] netem_enqueue+0x741/0x7c0 [sch_netem]
[ 788.854487] [<ffffffff8152cb58>] dev_queue_xmit+0x2a8/0x570
[ 788.880870] [<ffffffff8156ae1d>] ip_finish_output+0x53d/0x7d0
The problem occurs because netem is not prepared to handle GSO packets (as it
uses skb_checksum_help in its enqueue path, which cannot manipulate these
frames).
The solution I think is to simply segment the skb in a simmilar fashion to the
way we do in __dev_queue_xmit (via validate_xmit_skb), with some minor changes.
When we decide to corrupt an skb, if the frame is GSO, we segment it, corrupt
the first segment, and enqueue the remaining ones.
tested successfully by myself on the latest net kernel, to which this applies
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Jamal Hadi Salim <jhs@mojatatu.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: netem@lists.linux-foundation.org
CC: eric.dumazet@gmail.com
CC: stephen@networkplumber.org
[ Upstream commit bdf17661f63a79c3cb4209b970b1cc39e34f7543 ]
Similarly, we need to update backlog too when we update qlen.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit 431e3a8e36a05a37126f34b41aa3a5a6456af04e ]
We saw qlen!=0 but backlog==0 on our production machine:
qdisc htb 1: dev eth0 root refcnt 2 r2q 10 default 1 direct_packets_stat 0 ver 3.17
Sent 172680457356 bytes 222469449 pkt (dropped 0, overlimits 123575834 requeues 0)
backlog 0b 72p requeues 0
The problem is we only count qlen for HTB qdisc but not backlog.
We need to update backlog too when we update qlen, so that we
can at least know the average packet length.
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit 2ccccf5fb43ff62b2b96cc58d95fc0b3596516e4 ]
When the bottom qdisc decides to, for example, drop some packet,
it calls qdisc_tree_decrease_qlen() to update the queue length
for all its ancestors, we need to update the backlog too to
keep the stats on root qdisc accurate.
[ Upstream commit 86a7996cc8a078793670d82ed97d5a99bb4e8496 ]
Remove nearly duplicated code and prepare for the following patch.
[ Upstream commit 8358b02bf67d3a5d8a825070e1aa73f25fb2e4c7 ]
When bpf(BPF_PROG_LOAD, ...) was invoked with a BPF program whose bytecode
references a non-map file descriptor as a map file descriptor, the error
handling code called fdput() twice instead of once (in __bpf_map_get() and
in replace_map_fd_with_map_ptr()). If the file descriptor table of the
current task is shared, this causes f_count to be decremented too much,
allowing the struct file to be freed while it is still in use
(use-after-free). This can be exploited to gain root privileges by an
unprivileged user.
This bug was introduced in
commit 0246e64d9a5f ("bpf: handle pseudo BPF_LD_IMM64 insn"), but is only
exploitable since
commit 1be7f75d1668 ("bpf: enable non-root eBPF programs") because
previously, CAP_SYS_ADMIN was required to reach the vulnerable code.
(posted publicly according to request by maintainer)
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit fc96256c906362e845d848d0f6a6354450059e81 ]
When multiple skb are TX-completed in a row, we might incorrectly keep
a timestamp of a prior skb and cause extra work.
Fixes: ec693d47010e8 ("net/mlx4_en: Add HW timestamping (TS) support")
Cc: Willem de Bruijn <willemb@google.com>
Reviewed-by: Eran Ben Elisha <eranbe@mellanox.com>
[ Upstream commit 391a20333b8393ef2e13014e6e59d192c5594471 ]
After commit fbd40ea0180a ("ipv4: Don't do expensive useless work
during inetdev destroy.") when deleting an interface,
fib_del_ifaddr() can be executed without any primary address
present on the dead interface.
The above is safe, but triggers some "bug: prim == NULL" warnings.
This commit avoids warning if the in_dev is dead
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit b4f70527f052b0c00be4d7cac562baa75b212df5 ]
When using masked actions the ipv6_proto field of an action
to set IPv6 fields may be zero rather than the prevailing protocol
which will result in skipping checksum recalculation.
This patch resolves the problem by relying on the protocol
in the flow key rather than that in the set field action.
Fixes: 83d2b9ba1abc ("net: openvswitch: Support masked set actions.")
Cc: Jarno Rajahalme <jrajahalme@nicira.com>
Signed-off-by: Simon Horman <simon.horman@netronome.com>
[ Upstream commit f43bfaeddc79effbf3d0fcb53ca477cca66f3db8 ]
atl2 includes NETIF_F_SG in hw_features even though it has no support
for non-linear skbs. This bug was originally harmless since the
driver does not claim to implement checksum offload and that used to
be a requirement for SG.
Now that SG and checksum offload are independent features, if you
explicitly enable SG *and* use one of the rare protocols that can use
SG without checkusm offload, this potentially leaks sensitive
information (before you notice that it just isn't working). Therefore
this obscure bug has been designated CVE-2016-2117.
Reported-by: Justin Yackoski <jyackoski@crypto-nite.com>
Fixes: ec5f06156423 ("net: Kill link between CSUM and SG features.")
[ Upstream commit d82bccc69041a51f7b7b9b4a36db0772f4cdba21 ]
verifier must check for reserved size bits in instruction opcode and
reject BPF_LD | BPF_ABS | BPF_DW and BPF_LD | BPF_IND | BPF_DW instructions,
otherwise interpreter will WARN_RATELIMIT on them during execution.
Fixes: ddd872bc3098 ("bpf: verifier: add checks for BPF_ABS | BPF_IND instructions")
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 3dcd493fbebfd631913df6e2773cc295d3bf7d22 ]
A failure in validate_xmit_skb_list() triggered an unconditional call
to dev_requeue_skb with skb=NULL. This slowly grows the queue
discipline's qlen count until all traffic through the queue stops.
We take the optimistic approach and continue running the queue after a
failure since it is unknown if later packets also will fail in the
validate path.
Fixes: 55a93b3ea780 ("qdisc: validate skb without holding lock")
Signed-off-by: Lars Persson <larper@axis.com>
[ Upstream commit 309cf37fe2a781279b7675d4bb7173198e532867 ]
Because we miss to wipe the remainder of i->addr[] in packet_mc_add(),
pdiag_put_mclist() leaks uninitialized heap bytes via the
PACKET_DIAG_MCLIST netlink attribute.
Fix this by explicitly memset(0)ing the remaining bytes in i->addr[].
Fixes: eea68e2f1a00 ("packet: Report socket mclist info via diag module")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Acked-by: Pavel Emelyanov <xemul@virtuozzo.com>
[ Upstream commit d6d5e999e5df67f8ec20b6be45e2229455ee3699 ]
For local routes that require a particular output interface we do not want
to cache the result. Caching the result causes incorrect behaviour when
there are multiple source addresses on the interface. The end result
being that if the intended recipient is waiting on that interface for the
packet he won't receive it because it will be delivered on the loopback
interface and the IP_PKTINFO ipi_ifindex will be set to the loopback
interface as well.
This can be tested by running a program such as "dhcp_release" which
attempts to inject a packet on a particular interface so that it is
received by another program on the same board. The receiving process
should see an IP_PKTINFO ipi_ifndex value of the source interface
(e.g., eth1) instead of the loopback interface (e.g., lo). The packet
will still appear on the loopback interface in tcpdump but the important
aspect is that the CMSG info is correct.
Sample dhcp_release command line:
dhcp_release eth1 192.168.204.222 02:11:33:22:44:66
Signed-off-by: Allain Legacy <allain.legacy@windriver.com>
Signed off-by: Chris Friesen <chris.friesen@windriver.com>
Reviewed-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit a36a0d4008488fa545c74445d69eaf56377d5d4e ]
In particular, make sure we check for decnet private presence
for loopback devices.
[ Upstream commit a21211672c9a1d730a39aa65d4a5b3414700adfb ]
There are several reports of freeze on enabling HWP (Hardware PStates)
feature on Skylake-based systems by the Intel P-states driver. The root
cause is identified as the HWP interrupts causing BIOS code to freeze.
HWP interrupts use the thermal LVT which can be handled by Linux
natively, but on the affected Skylake-based systems SMM will respond
to it by default. This is a problem for several reasons:
- On the affected systems the SMM thermal LVT handler is broken (it
will crash when invoked) and a BIOS update is necessary to fix it.
- With thermal interrupt handled in SMM we lose all of the reporting
features of the arch/x86/kernel/cpu/mcheck/therm_throt driver.
- Some thermal drivers like x86-package-temp depend on the thermal
threshold interrupts signaled via the thermal LVT.
- The HWP interrupts are useful for debugging and tuning
performance (if the kernel can handle them).
The native handling of thermal interrupts needs to be enabled
because of that.
This requires some way to tell SMM that the OS can handle thermal
interrupts. That can be done by using _OSC/_PDC in processor
scope very early during ACPI initialization.
The meaning of _OSC/_PDC bit 12 in processor scope is whether or
not the OS supports native handling of interrupts for Collaborative
Processor Performance Control (CPPC) notifications. Since on
HWP-capable systems CPPC is a firmware interface to HWP, setting
this bit effectively tells the firmware that the OS will handle
thermal interrupts natively going forward.
For details on _OSC/_PDC refer to:
http://www.intel.com/content/www/us/en/standards/processor-vendor-specific-acpi-specification.html
To implement the _OSC/_PDC handshake as described, introduce a new
function, acpi_early_processor_osc(), that walks the ACPI
namespace looking for ACPI processor objects and invokes _OSC for
them with bit 12 in the capabilities buffer set and terminates the
namespace walk on the first success.
Also modify intel_thermal_interrupt() to clear HWP status bits in
the HWP_STATUS MSR to acknowledge HWP interrupts (which prevents
them from firing continuously).
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
[ rjw: Subject & changelog, function rename ]
[ Upstream commit 05be8d4101d960bad271d32b4f6096af1ccb1534 ]
If i2c_device_id *id is NULL and acpi_match_device returns NULL too,
then chipset may be unitialized when accessing &ak_def_array[chipset] in
ak8975_probe. Therefore initialize chipset to AK_MAX_TYPE, which will
return an error when not changed.
This patch fixes the following maybe-uninitialized warning:
drivers/iio/magnetometer/ak8975.c: In function ‘ak8975_probe’:
drivers/iio/magnetometer/ak8975.c:788:14: warning: ‘chipset’ may be used
uninitialized in this function [-Wmaybe-uninitialized]
data->def = &ak_def_array[chipset];
Signed-off-by: Richard Leitner <dev@g0hl1n.net>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
[ Upstream commit d1a65f1741bfd9c69f9e4e2ad447a89b6810427d ]
_batadv_update_route rcu_derefences orig_ifinfo->router outside of a
spinlock protected region to print some information messages to the debug
log. But this pointer is not checked again when the new pointer is assigned
in the spinlock protected region. Thus is can happen that the value of
orig_ifinfo->router changed in the meantime and thus the reference counter
of the wrong router gets reduced after the spinlock protected region.
Just rcu_dereferencing the value of orig_ifinfo->router inside the spinlock
protected region (which also set the new pointer) is enough to get the
correct old router object.
Fixes: e1a5382f978b ("batman-adv: Make orig_node->router an rcu protected pointer")
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Antonio Quartulli <a@unstable.cc>
[ Upstream commit c4fdb6cff2aa0ae740c5f19b6f745cbbe786d42f ]
When removing a single interface while a broadcast or ogm packet is
still pending then we will free the forward packet without releasing the
queue slots again.
This patch is supposed to fix this issue.
Fixes: 6d5808d4ae1b ("batman-adv: Add missing hardif_free_ref in forw_packet_free")
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
[sven@narfation.org: fix conflicts with current version]
[ Upstream commit c78296665c3d81f040117432ab9e1cb125521b0c ]
The encapsulated ethernet and VLAN header may be outside the received
ethernet frame. Thus the skb buffer size has to be checked before it can be
parsed to find out if it encapsulates another batman-adv packet.
Fixes: 420193573f11 ("batman-adv: softif bridge loop avoidance")
[ Upstream commit bc22af74f271ef76b2e6f72f3941f91f0da3f5f8 ]
Khugepaged attempts to raise min_free_kbytes if its set too low.
However, on boot khugepaged sets min_free_kbytes first from
subsys_initcall(), and then the mm 'core' over-rides min_free_kbytes
after from init_per_zone_wmark_min(), via a module_init() call.
Khugepaged used to use a late_initcall() to set min_free_kbytes (such
that it occurred after the core initialization), however this was
removed when the initialization of min_free_kbytes was integrated into
the starting of the khugepaged thread.
The fix here is simply to invoke the core initialization using a
core_initcall() instead of module_init(), such that the previous
initialization ordering is restored. I didn't restore the
late_initcall() since start_stop_khugepaged() already sets
min_free_kbytes via set_recommended_min_free_kbytes().
This was noticed when we had a number of page allocation failures when
moving a workload to a kernel with this new initialization ordering. On
an 8GB system this restores min_free_kbytes back to 67584 from 11365
when CONFIG_TRANSPARENT_HUGEPAGE=y is set and either
CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y or
CONFIG_TRANSPARENT_HUGEPAGE_MADVISE=y.
Fixes: 79553da293d3 ("thp: cleanup khugepaged startup")
Signed-off-by: Jason Baron <jbaron@akamai.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Acked-by: David Rientjes <rientjes@google.com>
[ Upstream commit 8148a73c9901a8794a50f950083c00ccf97d43b3 ]
If /proc/<PID>/environ gets read before the envp[] array is fully set up
in create_{aout,elf,elf_fdpic,flat}_tables(), we might end up trying to
read more bytes than are actually written, as env_start will already be
set but env_end will still be zero, making the range calculation
underflow, allowing to read beyond the end of what has been written.
Fix this as it is done for /proc/<PID>/cmdline by testing env_end for
zero. It is, apparently, intentionally set last in create_*_tables().
This bug was found by the PaX size_overflow plugin that detected the
arithmetic underflow of 'this_len = env_end - (env_start + src)' when
env_end is still zero.
The expected consequence is that userland trying to access
/proc/<PID>/environ of a not yet fully set up process may get
inconsistent data as we're in the middle of copying in the environment
variables.
Fixes: https://forums.grsecurity.net/viewtopic.php?f=3&t=4363
Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=116461
Cc: Emese Revfy <re.emese@gmail.com>
Cc: Pax Team <pageexec@freemail.hu>
Cc: Mateusz Guzik <mguzik@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Jarod Wilson <jarod@redhat.com>
[ Upstream commit 6984ab1ab35f422292b7781c65284038bcc0f6a6 ]
A wrong decoding of the touch coordinate message causes a wrong touch
ID. Touch ID for dual touch must be 0 or 1.
According to the actual Neonode nine byte touch coordinate coding,
the state is transported in the lower nibble and the touch ID in
the higher nibble of payload byte five.
Signed-off-by: Knut Wohlrab <Knut.Wohlrab@de.bosch.com>
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
[ Upstream commit aeb6641f8ebdd61939f462a8255b316f9bfab707 ]
gcc-6 complains about the indentation of the lpfc_destroy_vport_work_array()
call in lpfc_online(), which clearly doesn't look right:
drivers/scsi/lpfc/lpfc_init.c: In function 'lpfc_online':
drivers/scsi/lpfc/lpfc_init.c:2880:3: warning: statement is indented as if it were guarded by... [-Wmisleading-indentation]
lpfc_destroy_vport_work_array(phba, vports);
drivers/scsi/lpfc/lpfc_init.c:2863:2: note: ...this 'if' clause, but it is not
if (vports != NULL)
Looking at the patch that introduced this code, it's clear that the
behavior is correct and the indentation is wrong.
This fixes the indentation and adds curly braces around the previous
if() block for clarity, as that is most likely what caused the code
to be misindented in the first place.
Fixes: 549e55cd2a1b ("[SCSI] lpfc 8.2.2 : Fix locking around HBA's port_list")
Reviewed-by: Sebastian Herbszt <herbszt@gmx.de>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
[ Upstream commit 0f75e1a370fd843c9e508fc1ccf0662833034827 ]
The offset seems to have been copied from the sata clk. Fix it so
that enabling the crypto engine source clk works.
Tested-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Tested-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Fixes: 5f775498bdc4 ("clk: qcom: Fully support apq8064 global clock control")
[ Upstream commit ec7957a6aa0aaf981fb8356dc47a2cdd01cde03c ]
Despite care take to allocate clocks state containers the
SP810 driver actually just supports creating one instance:
all clocks registered for every instance will end up with the
exact same name and __clk_init() will fail.
Rename the timclken<0> .. timclken<n> to sp810_<instance>_<n>
so every clock on every instance gets a unique name.
This is necessary for the RealView PBA8 which has two SP810
blocks: the second block will not register its clocks unless
every clock on every instance is unique and results in boot
logs like this:
WARNING: CPU: 0 PID: 0 at ../drivers/clk/versatile/clk-sp810.c:137
clk_sp810_of_setup+0x110/0x154()
Modules linked in:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted
4.5.0-rc2-00030-g352718fc39f6-dirty #225
Hardware name: ARM RealView Machine (Device Tree Support)
[<c00167f8>] (unwind_backtrace) from [<c0013204>]
(show_stack+0x10/0x14)
[<c0013204>] (show_stack) from [<c01a049c>]
(dump_stack+0x84/0x9c)
[<c01a049c>] (dump_stack) from [<c0024990>]
(warn_slowpath_common+0x74/0xb0)
[<c0024990>] (warn_slowpath_common) from [<c0024a68>]
(warn_slowpath_null+0x1c/0x24)
[<c0024a68>] (warn_slowpath_null) from [<c051eb44>]
(clk_sp810_of_setup+0x110/0x154)
[<c051eb44>] (clk_sp810_of_setup) from [<c051e3a4>]
(of_clk_init+0x12c/0x1c8)
[<c051e3a4>] (of_clk_init) from [<c0504714>]
(time_init+0x20/0x2c)
[<c0504714>] (time_init) from [<c0501b18>]
(start_kernel+0x244/0x3c4)
[<c0501b18>] (start_kernel) from [<7000807c>] (0x7000807c)
---[ end trace cb88537fdc8fa200 ]---
Cc: Michael Turquette <mturquette@baylibre.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Fixes: 6e973d2c4385 "clk: vexpress: Add separate SP810 driver"
