2016-11-13Linux 4.9-rc5v4.9-rc5Linus Torvalds
2016-11-13Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "ARM fixes. There are a couple pending x86 patches but they'll have to wait for next week" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: arm/arm64: vgic: Kick VCPUs when queueing already pending IRQs KVM: arm/arm64: vgic: Prevent access to invalid SPIs arm/arm64: KVM: Perform local TLB invalidation when multiplexing vcpus on a single CPU
2016-11-13Merge branch 'media-fixes' (patches from Mauro)Linus Torvalds
Merge media fixes from Mauro Carvalho Chehab: "This contains two patches fixing problems with my patch series meant to make USB drivers to work again after the DMA on stack changes. The last patch on this series is actually not related to DMA on stack. It solves a longstanding bug affecting module unload, causing module_put() to be called twice. It was reported by the user who reported and tested the issues with the gp8psk driver with the DMA fixup patches. As we're late at -rc cycle, maybe you prefer to not apply it right now. If this is the case, I'll add to the pile of patches for 4.10. Exceptionally this time, I'm sending the patches via e-mail, because I'm on another trip, and won't be able to use the usual procedure until Monday. Also, it is only three patches, and you followed already the discussions about the first one" * emailed patches from Mauro Carvalho Chehab <mchehab@osg.samsung.com>: gp8psk: Fix DVB frontend attach gp8psk: fix gp8psk_usb_in_op() logic dvb-usb: move data_mutex to struct dvb_usb_device
2016-11-13Merge tag 'char-misc-4.9-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc fixes from Greg KH: "Here are three small driver fixes for some reported issues for 4.9-rc5. One for the hyper-v subsystem, fixing up a naming issue that showed up in 4.9-rc1, one mei driver fix, and one fix for parallel ports, resolving a reported regression. All have been in linux-next with no reported issues" * tag 'char-misc-4.9-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: ppdev: fix double-free of pp->pdev->name vmbus: make sysfs names consistent with PCI mei: bus: fix received data size check in NFC fixup
2016-11-13Merge tag 'driver-core-4.9-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fixes from Greg KH: "Here are two driver core fixes for 4.9-rc5. The first resolves an issue with some drivers not liking to be unbound and bound again (if CONFIG_DEBUG_TEST_DRIVER_REMOVE is enabled), which solves some reported problems with graphics and storage drivers. The other resolves a smatch error with the 4.9-rc1 driver core changes around this feature. Both have been in linux-next with no reported issues" * tag 'driver-core-4.9-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: driver core: fix smatch warning on dev->bus check driver core: skip removal test for non-removable drivers
2016-11-13Merge tag 'staging-4.9-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging/IIO fixes from Grek KH: "Here are a few small staging and iio driver fixes for reported issues. The last one was cherry-picked from my -next branch to resolve a build warning that Arnd fixed, in his quest to be able to turn -Wmaybe-uninitialized back on again. That patch, and all of the others, have been in linux-next for a while with no reported issues" * tag 'staging-4.9-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: iio: maxim_thermocouple: detect invalid storage size in read() staging: nvec: remove managed resource from PS2 driver Revert "staging: nvec: ps2: change serio type to passthrough" drivers: staging: nvec: remove bogus reset command for PS/2 interface staging: greybus: arche-platform: fix device reference leak staging: comedi: ni_tio: fix buggy ni_tio_clock_period_ps() return value staging: sm750fb: Fix bugs introduced by early commits iio: hid-sensors: Increase the precision of scale to fix wrong reading interpretation. iio: orientation: hid-sensor-rotation: Add PM function (fix non working driver) iio: st_sensors: fix scale configuration for h3lis331dl staging: iio: ad5933: avoid uninitialized variable in error case
2016-11-13Merge tag 'usb-4.9-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB / PHY fixes from Greg KH: "Here are a number of small USB and PHY driver fixes for 4.9-rc5 Nothing major, just small fixes for reported issues, all of these have been in linux-next for a while with no reported issues" * tag 'usb-4.9-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: USB: cdc-acm: fix TIOCMIWAIT cdc-acm: fix uninitialized variable drivers/usb: Skip auto handoff for TI and RENESAS usb controllers usb: musb: remove duplicated actions usb: musb: da8xx: Don't print phy error on -EPROBE_DEFER phy: sun4i: check PMU presence when poking unknown bit of pmu phy-rockchip-pcie: remove deassert of phy_rst from exit callback phy: da8xx-usb: rename the ohci device to ohci-da8xx phy: Add reset callback for not generic phy uwb: fix device reference leaks usb: gadget: u_ether: remove interrupt throttling usb: dwc3: st: add missing <linux/pinctrl/consumer.h> include usb: dwc3: Fix error handling for core init
2016-11-13Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull more block fixes from Jens Axboe: "Since I mistakenly left out the lightnvm regression fix yesterday and the aoeblk seems adequately tested at this point, might as well send out another pull to make -rc5" * 'for-linus' of git://git.kernel.dk/linux-block: aoe: fix crash in page count manipulation lightnvm: invalid offset calculation for lba_shift
2016-11-13Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "The megaraid_sas patch in here fixes a major regression in the last fix set that made all megaraid_sas cards unusable. It turns out no-one had actually tested such an "obvious" fix, sigh. The fix for the fix has been tested ... The next most serious is the vmw_pvscsi abort problem which basically means that aborts don't work on the vmware paravirt devices and error handling always escalates to reset. The rest are an assortment of missed reference counting in certain paths and corner case bugs that show up on some architectures" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: scsi: megaraid_sas: fix macro MEGASAS_IS_LOGICAL to avoid regression scsi: qla2xxx: fix invalid DMA access after command aborts in PCI device remove scsi: qla2xxx: do not queue commands when unloading scsi: libcxgbi: fix incorrect DDP resource cleanup scsi: qla2xxx: Fix scsi scan hang triggered if adapter fails during init scsi: scsi_dh_alua: Fix a reference counting bug scsi: vmw_pvscsi: return SUCCESS for successful command aborts scsi: mpt3sas: Fix for block device of raid exists even after deleting raid disk scsi: scsi_dh_alua: fix missing kref_put() in alua_rtpg_work()
2016-11-13Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clk fixes from Stephen Boyd: "The typical collection of minor bug fixes in clk drivers. We don't have anything in the core framework here, just driver fixes. There's a boot fix for Samsung devices and a safety measure for qoriq to prevent CPUs from running too fast. There's also a fix for i.MX6Q to properly handle audio clock rates. We also have some "that's obviously wrong" fixes like bad NULL pointer checks in the MPP driver and a poor usage of __pa in the xgene clk driver that are fixed here" * tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: clk: mmp: pxa910: fix return value check in pxa910_clk_init() clk: mmp: pxa168: fix return value check in pxa168_clk_init() clk: mmp: mmp2: fix return value check in mmp2_clk_init() clk: qoriq: Don't allow CPU clocks higher than starting value clk: imx: fix integer overflow in AV PLL round rate clk: xgene: Don't call __pa on ioremaped address clk/samsung: Use CLK_OF_DECLARE_DRIVER initialization method for CLKOUT clk: rockchip: don't return NULL when failing to register ddrclk branch
2016-11-13gp8psk: Fix DVB frontend attachMauro Carvalho Chehab
The DVB binding schema at the DVB core assumes that the frontend is a separate driver. Faling to do that causes OOPS when the module is removed, as it tries to do a symbol_put_addr on an internal symbol, causing craches like: WARNING: CPU: 1 PID: 28102 at kernel/module.c:1108 module_put+0x57/0x70 Modules linked in: dvb_usb_gp8psk(-) dvb_usb dvb_core nvidia_drm(PO) nvidia_modeset(PO) snd_hda_codec_hdmi snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd soundcore nvidia(PO) [last unloaded: rc_core] CPU: 1 PID: 28102 Comm: rmmod Tainted: P WC O 4.8.4-build.1 #1 Hardware name: MSI MS-7309/MS-7309, BIOS V1.12 02/23/2009 Call Trace: dump_stack+0x44/0x64 __warn+0xfa/0x120 module_put+0x57/0x70 module_put+0x57/0x70 warn_slowpath_null+0x23/0x30 module_put+0x57/0x70 gp8psk_fe_set_frontend+0x460/0x460 [dvb_usb_gp8psk] symbol_put_addr+0x27/0x50 dvb_usb_adapter_frontend_exit+0x3a/0x70 [dvb_usb] From Derek's tests: "Attach bug is fixed, tuning works, module unloads without crashing. Everything seems ok!" Reported-by: Derek <user.vdr@gmail.com> Tested-by: Derek <user.vdr@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-13gp8psk: fix gp8psk_usb_in_op() logicMauro Carvalho Chehab
Commit bc29131ecb10 ("[media] gp8psk: don't do DMA on stack") fixed the usage of DMA on stack, but the memcpy was wrong for gp8psk_usb_in_op(). Fix it. From Derek's email: "Fix confirmed using 2 different Skywalker models with HD mpeg4, SD mpeg2." Suggested-by: Johannes Stezenbach <js@linuxtv.org> Fixes: bc29131ecb10 ("[media] gp8psk: don't do DMA on stack") Tested-by: Derek <user.vdr@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-13dvb-usb: move data_mutex to struct dvb_usb_deviceMauro Carvalho Chehab
The data_mutex is initialized too late, as it is needed for each device driver's power control, causing an OOPS: dvb-usb: found a 'TerraTec/qanu USB2.0 Highspeed DVB-T Receiver' in warm state. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff846617af>] __mutex_lock_slowpath+0x6f/0x100 PGD 0 Oops: 0002 [#1] SMP Modules linked in: dvb_usb_cinergyT2(+) dvb_usb CPU: 0 PID: 2029 Comm: modprobe Not tainted 4.9.0-rc4-dvbmod #24 Hardware name: FUJITSU LIFEBOOK A544/FJNBB35 , BIOS Version 1.17 05/09/2014 task: ffff88020e943840 task.stack: ffff8801f36ec000 RIP: 0010:[<ffffffff846617af>] [<ffffffff846617af>] __mutex_lock_slowpath+0x6f/0x100 RSP: 0018:ffff8801f36efb10 EFLAGS: 00010282 RAX: 0000000000000000 RBX: ffff88021509bdc8 RCX: 00000000c0000100 RDX: 0000000000000001 RSI: 0000000000000000 RDI: ffff88021509bdcc RBP: ffff8801f36efb58 R08: ffff88021f216320 R09: 0000000000100000 R10: ffff88021f216320 R11: 00000023fee6c5a1 R12: ffff88020e943840 R13: ffff88021509bdcc R14: 00000000ffffffff R15: ffff88021509bdd0 FS: 00007f21adb86740(0000) GS:ffff88021f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 0000000215bce000 CR4: 00000000001406f0 Call Trace: mutex_lock+0x16/0x25 cinergyt2_power_ctrl+0x1f/0x60 [dvb_usb_cinergyT2] dvb_usb_device_init+0x21e/0x5d0 [dvb_usb] cinergyt2_usb_probe+0x21/0x50 [dvb_usb_cinergyT2] usb_probe_interface+0xf3/0x2a0 driver_probe_device+0x208/0x2b0 __driver_attach+0x87/0x90 driver_probe_device+0x2b0/0x2b0 bus_for_each_dev+0x52/0x80 bus_add_driver+0x1a3/0x220 driver_register+0x56/0xd0 usb_register_driver+0x77/0x130 do_one_initcall+0x46/0x180 free_vmap_area_noflush+0x38/0x70 kmem_cache_alloc+0x84/0xc0 do_init_module+0x50/0x1be load_module+0x1d8b/0x2100 find_symbol_in_section+0xa0/0xa0 SyS_finit_module+0x89/0x90 entry_SYSCALL_64_fastpath+0x13/0x94 Code: e8 a7 1d 00 00 8b 03 83 f8 01 0f 84 97 00 00 00 48 8b 43 10 4c 8d 7b 08 48 89 63 10 4c 89 3c 24 41 be ff ff ff ff 48 89 44 24 08 <48> 89 20 4c 89 64 24 10 eb 1a 49 c7 44 24 08 02 00 00 00 c6 43 RIP [<ffffffff846617af>] __mutex_lock_slowpath+0x6f/0x100 RSP <ffff8801f36efb10> CR2: 0000000000000000 So, move it to the struct dvb_usb_device and initialize it before calling the driver's callbacks. Reported-by: Jörg Otte <jrg.otte@gmail.com> Tested-by: Jörg Otte <jrg.otte@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-13iio: maxim_thermocouple: detect invalid storage size in read()Arnd Bergmann
As found by gcc -Wmaybe-uninitialized, having a storage_bytes value other than 2 or 4 will result in undefined behavior: drivers/iio/temperature/maxim_thermocouple.c: In function 'maxim_thermocouple_read': drivers/iio/temperature/maxim_thermocouple.c:141:5: error: 'ret' may be used uninitialized in this function [-Werror=maybe-uninitialized] This probably cannot happen, but returning -EINVAL here is appropriate and makes gcc happy and the code more robust. Fixes: 231147ee77f3 ("iio: maxim_thermocouple: Align 16 bit big endian value of raw reads") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org> (cherry picked from commit 32cb7d27e65df9daa7cee8f1fdf7b259f214bee2) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-12aoe: fix crash in page count manipulationJens Axboe
aoeblk contains some mysterious code, that wants to elevate the bio vec page counts while it's under IO. That is not needed, it's fragile, and it's causing kernel oopses for some. Reported-by: Tested-by: Don Koch <kochd@us.ibm.com> Tested-by: Tested-by: Don Koch <kochd@us.ibm.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-11lightnvm: invalid offset calculation for lba_shiftMatias Bjørling
The ns->lba_shift assumes its value to be the logarithmic of the LA size. A previous patch duplicated the lba_shift calculation into lightnvm. It prematurely also subtracted a 512byte shift, which commonly is applied per-command. The 512byte shift being subtracted twice led to data loss when restoring the logical to physical mapping table from device and when issuing I/O commands using rrpc. Fix offset by removing the 512byte shift subtraction when calculating lba_shift. Fixes: b0b4e09c1ae7 "lightnvm: control life of nvm_dev in driver" Reported-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-11Merge tag 'acpi-4.9-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI fix from Rafael Wysocki: "Fix a recent regression in the 8250_dw serial driver introduced by adding a quirk for the APM X-Gene SoC to it which uncovered an issue related to the handling of built-in device properties in the core ACPI device enumeration code (Heikki Krogerus)" * tag 'acpi-4.9-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / platform: Add support for build-in properties
2016-11-11Merge tag 'pm-4.9-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management fixes from Rafael Wysocki: "These fix two bugs in error code paths in the PM core (system-wide suspend of devices), a device reference leak in the boot-time suspend test code and a cpupower utility regression from the 4.7 cycle. Specifics: - Prevent the PM core from attempting to suspend parent devices if any of their children, whose suspend callbacks were invoked asynchronously, have failed to suspend during the "late" and "noirq" phases of system-wide suspend of devices (Brian Norris). - Prevent the boot-time system suspend test code from leaking a reference to the RTC device used by it (Johan Hovold). - Fix cpupower to use the return value of one of its library functions correctly and restore the correct behavior of it when used for setting cpufreq tunables broken during the 4.7 development cycle (Laura Abbott)" * tag 'pm-4.9-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / sleep: don't suspend parent when async child suspend_{noirq, late} fails PM / sleep: fix device reference leak in test_suspend cpupower: Correct return type of cpu_power_is_cpu_online() in cpufreq-set
2016-11-11Merge tag 'arc-4.9-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fixes from Vineet Gupta: - mmap handler for dma ops as generic handler no longer works for us [Alexey] - Fixes for EZChip platform [Noam] - Fix RTC clocksource driver build issue - ARC IRQ handling fixes [Yuriy] - Revert a recent makefile change which doesn't go well with oldish tools out in the wild * tag 'arc-4.9-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARCv2: MCIP: Use IDU_M_DISTRI_DEST mode if there is only 1 destination core ARC: IRQ: Do not use hwirq as virq and vice versa ARC: [plat-eznps] set default baud for early console ARC: [plat-eznps] remove IPI clear from SMP operations Revert "ARC: build: retire old toggles" ARC: timer: rtc: implement read loop in "C" vs. inline asm ARC: change return value of userspace cmpxchg assist syscall arc: Implement arch-specific dma_map_ops.mmap ARC: [SMP] avoid overriding present cpumask ARC: Enable PERF_EVENTS in nSIM driven platforms
2016-11-11Merge tag 'platform-drivers-x86-v4.9-3' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform driver fixes from Darren Hart: "Minor doc fix, a DMI match for ideapad and a fix to toshiba-wmi to avoid loading on non-toshiba systems. Documentation/ABI: - ibm_rtl: The "What:" fields are incomplete toshiba-wmi: - Fix loading the driver on non Toshiba laptops ideapad-laptop: - Add another DMI entry for Yoga 900" * tag 'platform-drivers-x86-v4.9-3' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: Documentation/ABI: ibm_rtl: The "What:" fields are incomplete toshiba-wmi: Fix loading the driver on non Toshiba laptops ideapad-laptop: Add another DMI entry for Yoga 900
2016-11-11Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "Two small (really, one liners both of them!) fixes that should go into this series: - Request allocation error handling fix for nbd, from Christophe, fixing a regression in this series. - An oops fix for drbd. Not a regression in this series, but stable material. From Richard" * 'for-linus' of git://git.kernel.dk/linux-block: drbd: Fix kernel_sendmsg() usage - potential NULL deref nbd: Fix error handling
2016-11-11Merge tag 'pci-v4.9-fixes-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: - Update MAINTAINERS for Intel VMD driver filename - Update Rockchip rk3399 host bridge driver DTS and resets - Fix ROM shadow problem that made some video device initialization fail * tag 'pci-v4.9-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: VMD: Update filename to reflect move arm64: dts: rockchip: add three new resets for rk3399 PCIe controller PCI: rockchip: Add three new resets as required properties PCI: Don't attempt to claim shadow copies of ROM
2016-11-11Merge tag 'drm-fixes-for-v4.9-rc5' of ↵Linus Torvalds
git://people.freedesktop.org/~airlied/linux Pull drm fixes from Dave Airlie: "AMD, radeon, i915, imx, msm and udl fixes: - amdgpu/radeon have a number of power management regressions and fixes along with some better error checking - imx has a single regression fix - udl has a single kmalloc instead of stack for usb control msg fix - msm has some fixes for modesetting bugs and regressions - i915 has a one fix for a Sandybridge regression along with some others for DP audio. They all seem pretty okay at this stage, we've got one MST fix I know going through process for i915, but I expect it'll be next week" * tag 'drm-fixes-for-v4.9-rc5' of git://people.freedesktop.org/~airlied/linux: (30 commits) drm/udl: make control msg static const. (v2) drm/amd/powerplay: implement get_clock_by_type for iceland. drm/amd/powerplay/smu7: fix checks in smu7_get_evv_voltages (v2) drm/amd/powerplay: update phm_get_voltage_evv_on_sclk for iceland drm/amd/powerplay: propagate errors in phm_get_voltage_evv_on_sclk drm/imx: disable planes before DC drm/amd/powerplay: return false instead of -EINVAL drm/amdgpu/powerplay/smu7: fix unintialized data usage drm/amdgpu: fix crash in acp_hw_fini drm/i915: Limit Valleyview and earlier to only using mappable scanout drm/i915: Round tile chunks up for constructing partial VMAs drm/i915/dp: Extend BDW DP audio workaround to GEN9 platforms drm/i915/dp: BDW cdclk fix for DP audio drm/i915/vlv: Prevent enabling hpd polling in late suspend drm/i915: Respect alternate_ddc_pin for all DDI ports drm/msm: Fix error handling crashes seen when VRAM allocation fails drm/msm/mdp5: 8x16 actually has 8 mixer stages drm/msm/mdp5: no scaling support on RGBn pipes for 8x16 drm/msm/mdp5: handle non-fullscreen base plane case drm/msm: Set CLK_IGNORE_UNUSED flag for PLL clocks ...
2016-11-11Merge tag 'mmc-v4.9-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc Pull MMC fixes from Ulf Hansson: "MMC core: - Fix mmc card initialization for hosts not supporting HW busy detection - Fix mmc_test for sending commands during non-blocking write MMC host: - mxs: Avoid using an uninitialized - sdhci: Restore enhanced strobe setting during runtime resume - sdhci: Fix a couple of reset related issues - dw_mmc: Fix a reset controller issue" * tag 'mmc-v4.9-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc: mmc: mxs: Initialize the spinlock prior to using it mmc: mmc: Use 500ms as the default generic CMD6 timeout mmc: mmc_test: Fix "Commands during non-blocking write" tests mmc: sdhci: Fix missing enhanced strobe setting during runtime resume mmc: sdhci: Reset cmd and data circuits after tuning failure mmc: sdhci: Fix unexpected data interrupt handling mmc: sdhci: Fix CMD line reset interfering with ongoing data transfer mmc: dw_mmc: add the "reset" as name of reset controller Documentation: synopsys-dw-mshc: add binding for reset-names
2016-11-11Merge tag 'pinctrl-v4.9-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control fixes from Linus Walleij: "All is about drivers, no core business going on. - Fix a host of runtime problems with the Intel Cherryview driver: suspend/resume needs to be marshalled properly, and strange effects from BIOS interaction during suspend/resume need to be dealt with. - A single bit was being set wrong in the Aspeed driver. - Fix an iProc probe ordering fallout resulting from v4.9 refactorings for bus population. - Do not specify a default trigger in the ST Micro cascaded GPIO IRQ controller: the kernel will moan. - Make IRQs optional altogether on the STM32 driver, it turns out not all systems have them or want them. - Fix a re-probe bug in the i.MX driver, it will eventually crash if probed repeatedly, not good" * tag 'pinctrl-v4.9-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl-aspeed-g5: Never set SCU90[6] pinctrl: cherryview: Prevent possible interrupt storm on resume pinctrl: cherryview: Serialize register access in suspend/resume pinctrl: imx: reset group index on probe pinctrl: stm32: move gpio irqs binding to optional pinctrl: stm32: remove dependency with interrupt controller pinctrl: st: don't specify default interrupt trigger pinctrl: iproc: Fix iProc and NSP GPIO support
2016-11-11Merge branches 'pm-tools-fixes' and 'pm-sleep-fixes'Rafael J. Wysocki
* pm-tools-fixes: cpupower: Correct return type of cpu_power_is_cpu_online() in cpufreq-set * pm-sleep-fixes: PM / sleep: don't suspend parent when async child suspend_{noirq, late} fails PM / sleep: fix device reference leak in test_suspend
2016-11-11Merge branch 'device-properties'Rafael J. Wysocki
* device-properties: ACPI / platform: Add support for build-in properties
2016-11-11Merge branch 'maybe-uninitialized' (patches from Arnd)Linus Torvalds
Merge fixes for -Wmaybe-uninitialized from Arnd Bergmann: "It took a while for some patches to make it into mainline through maintainer trees, but the 28-patch series is now reduced to 10, with one tiny patch added at the end. Aside from patches that are no longer required, I did these changes compared to version 1: - Dropped "iio: maxim_thermocouple: detect invalid storage size in read()", which is currently in linux-next as commit 32cb7d27e65d. This is the only remaining warning I see for a couple of corner cases (kbuild bot reports it on blackfin, kernelci bot and arm-soc bot both report it on arm64) - Dropped "brcmfmac: avoid maybe-uninitialized warning in brcmf_cfg80211_start_ap", which is currently in net/master merge pending. - Dropped two x86 patches, "x86: math-emu: possible uninitialized variable use" and "x86: mark target address as output in 'insb' asm" as they do not seem to trigger for a default build, and I got no feedback on them. Both of these are ancient issues and seem harmless, I will send them again to the x86 maintainers once the rest is merged. - Dropped "rbd: false-postive gcc-4.9 -Wmaybe-uninitialized" based on feedback from Ilya Dryomov, who already has a different fix queued up for v4.10. The kbuild bot reports this as a warning for xtensa. - Replaced "crypto: aesni: avoid -Wmaybe-uninitialized warning" with a simpler patch, this one always triggers but my first solution would not be safe for linux-4.9 any more at this point. I'll follow up with the larger patch as a cleanup for 4.10. - Replaced "dib0700: fix nec repeat handling" with a better one, contributed by Sean Young" * -Wmaybe-uninitialized fixes: Kbuild: enable -Wmaybe-uninitialized warnings by default pcmcia: fix return value of soc_pcmcia_regulator_set infiniband: shut up a maybe-uninitialized warning crypto: aesni: shut up -Wmaybe-uninitialized warning rc: print correct variable for z8f0811 dib0700: fix nec repeat handling s390: pci: don't print uninitialized data for debugging nios2: fix timer initcall return value x86: apm: avoid uninitialized data NFSv4.1: work around -Wmaybe-uninitialized warning Kbuild: enable -Wmaybe-uninitialized warning for "make W=1"
2016-11-11Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "15 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: lib/stackdepot: export save/fetch stack for drivers mm: kmemleak: scan .data.ro_after_init memcg: prevent memcg caches to be both OFF_SLAB & OBJFREELIST_SLAB coredump: fix unfreezable coredumping task mm/filemap: don't allow partially uptodate page for pipes mm/hugetlb: fix huge page reservation leak in private mapping error paths ocfs2: fix not enough credit panic Revert "console: don't prefer first registered if DT specifies stdout-path" mm: hwpoison: fix thp split handling in memory_failure() swapfile: fix memory corruption via malformed swapfile mm/cma.c: check the max limit for cma allocation scripts/bloat-o-meter: fix SIGPIPE shmem: fix pageflags after swapping DMA32 object mm, frontswap: make sure allocated frontswap map is assigned mm: remove extra newline from allocation stall warning
2016-11-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS fixes from Al Viro: "Christoph's and Jan's aio fixes, fixup for generic_file_splice_read (removal of pointless detritus that actually breaks it when used for gfs2 ->splice_read()) and fixup for generic_file_read_iter() interaction with ITER_PIPE destinations." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: splice: remove detritus from generic_file_splice_read() mm/filemap: don't allow partially uptodate page for pipes aio: fix freeze protection of aio writes fs: remove aio_run_iocb fs: remove the never implemented aio_fsync file operation aio: hold an extra file reference over AIO read/write operations
2016-11-11Merge tag 'ceph-for-4.9-rc5' of git://github.com/ceph/ceph-clientLinus Torvalds
Pull Ceph fixes from Ilya Dryomov: "Ceph's ->read_iter() implementation is incompatible with the new generic_file_splice_read() code that went into -rc1. Switch to the less efficient default_file_splice_read() for now; the proper fix is being held for 4.10. We also have a fix for a 4.8 regression and a trival libceph fixup" * tag 'ceph-for-4.9-rc5' of git://github.com/ceph/ceph-client: libceph: initialize last_linger_id with a large integer libceph: fix legacy layout decode with pool 0 ceph: use default file splice read callback
2016-11-11Merge tag 'nfs-for-4.9-3' of git://git.linux-nfs.org/projects/anna/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Anna Schumaker: "Most of these fix regressions in 4.9, and none are going to stable this time around. Bugfixes: - Trim extra slashes in v4 nfs_paths to fix tools that use this - Fix a -Wmaybe-uninitialized warnings - Fix suspicious RCU usages - Fix Oops when mounting multiple servers at once - Suppress a false-positive pNFS error - Fix a DMAR failure in NFS over RDMA" * tag 'nfs-for-4.9-3' of git://git.linux-nfs.org/projects/anna/linux-nfs: xprtrdma: Fix DMAR failure in frwr_op_map() after reconnect fs/nfs: Fix used uninitialized warn in nfs4_slot_seqid_in_use() NFS: Don't print a pNFS error if we aren't using pNFS NFS: Ignore connections that have cl_rpcclient uninitialized SUNRPC: Fix suspicious RCU usage NFSv4.1: work around -Wmaybe-uninitialized warning NFS: Trim extra slash in v4 nfs_path
2016-11-11Merge tag 'xfs-fixes-for-linus-4.9-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs Pull xfs fix from Dave Chinner: "This is a fix for an unmount hang (regression) when the filesystem is shutdown. It was supposed to go to you for -rc3, but I accidentally tagged the commit prior to it in that pullreq. Summary: - fix for aborting deferred transactions on filesystem shutdown" * tag 'xfs-fixes-for-linus-4.9-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: xfs: defer should abort intent items if the trans roll fails
2016-11-11Kbuild: enable -Wmaybe-uninitialized warnings by defaultArnd Bergmann
Previously the warnings were added back at the W=1 level and above, this now turns them on again by default, assuming that we have addressed all warnings and again have a clean build for v4.10. I found a number of new warnings in linux-next already and submitted bugfixes for those. Hopefully they are caught by the 0day builder in the future as soon as this patch is merged. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11pcmcia: fix return value of soc_pcmcia_regulator_setArnd Bergmann
The newly introduced soc_pcmcia_regulator_set() function sometimes returns without setting its return code, as shown by this warning: drivers/pcmcia/soc_common.c: In function 'soc_pcmcia_regulator_set': drivers/pcmcia/soc_common.c:112:5: error: 'ret' may be used uninitialized in this function [-Werror=maybe-uninitialized] This changes it to propagate the regulator_disable() result instead. Fixes: ac61b6001a63 ("pcmcia: soc_common: add support for Vcc and Vpp regulators") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11infiniband: shut up a maybe-uninitialized warningArnd Bergmann
Some configurations produce this harmless warning when built with gcc -Wmaybe-uninitialized: infiniband/core/cma.c: In function 'cma_get_net_dev': infiniband/core/cma.c:1242:12: warning: 'src_addr_storage.sin_addr.s_addr' may be used uninitialized in this function [-Wmaybe-uninitialized] I previously reported this for the powerpc64 defconfig, but have now reproduced the same thing for x86 as well, using gcc-5 or higher. The code looks correct to me, and this change just rearranges it by making sure we alway initialize the entire address structure to make the warning disappear. My first approach added an initialization at the time of the declaration, which Doug commented may be too costly, so I hope this version doesn't add overhead. Link: http://arm-soc.lixom.net/buildlogs/mainline/v4.7-rc6/buildall.powerpc.ppc64_defconfig.log.passed Link: https://patchwork.kernel.org/patch/9212825/ Acked-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11crypto: aesni: shut up -Wmaybe-uninitialized warningArnd Bergmann
The rfc4106 encrypy/decrypt helper functions cause an annoying false-positive warning in allmodconfig if we turn on -Wmaybe-uninitialized warnings again: arch/x86/crypto/aesni-intel_glue.c: In function ‘helper_rfc4106_decrypt’: include/linux/scatterlist.h:67:31: warning: ‘dst_sg_walk.sg’ may be used uninitialized in this function [-Wmaybe-uninitialized] The problem seems to be that the compiler doesn't track the state of the 'one_entry_in_sg' variable across the kernel_fpu_begin/kernel_fpu_end section. This takes the easy way out by adding a bogus initialization, which should be harmless enough to get the patch into v4.9 so we can turn on this warning again by default without producing useless output. A follow-up patch for v4.10 rearranges the code to make the warning go away. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11rc: print correct variable for z8f0811Arnd Bergmann
A recent rework accidentally left a debugging printk untouched while changing the meaning of the variables, leading to an uninitialized variable being printed: drivers/media/i2c/ir-kbd-i2c.c: In function 'get_key_haup_common': drivers/media/i2c/ir-kbd-i2c.c:62:2: error: 'toggle' may be used uninitialized in this function [-Werror=maybe-uninitialized] This prints the correct one instead, as we did before the patch. Fixes: 00bb820755ed ("[media] rc: Hauppauge z8f0811 can decode RC6") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11dib0700: fix nec repeat handlingSean Young
When receiving a nec repeat, ensure the correct scancode is repeated rather than a random value from the stack. This removes the need for the bogus uninitialized_var() and also fixes the warnings: drivers/media/usb/dvb-usb/dib0700_core.c: In function ‘dib0700_rc_urb_completion’: drivers/media/usb/dvb-usb/dib0700_core.c:679: warning: ‘protocol’ may be used uninitialized in this function [sean addon: So after writing the patch and submitting it, I've bought the hardware on ebay. Without this patch you get random scancodes on nec repeats, which the patch indeed fixes.] Signed-off-by: Sean Young <sean@mess.org> Tested-by: Sean Young <sean@mess.org> Cc: stable@vger.kernel.org Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11s390: pci: don't print uninitialized data for debuggingArnd Bergmann
gcc correctly warns about an incorrect use of the 'pa' variable in case we pass an empty scatterlist to __s390_dma_map_sg: arch/s390/pci/pci_dma.c: In function '__s390_dma_map_sg': arch/s390/pci/pci_dma.c:309:13: warning: 'pa' may be used uninitialized in this function [-Wmaybe-uninitialized] This adds a bogus initialization to the function to sanitize the debug output. I would have preferred a solution without the initialization, but I only got the report from the kbuild bot after turning on the warning again, and didn't manage to reproduce it myself. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11nios2: fix timer initcall return valueArnd Bergmann
When called more than twice, the nios2_time_init() function return an uninitialized value, as detected by gcc -Wmaybe-uninitialized arch/nios2/kernel/time.c: warning: 'ret' may be used uninitialized in this function This makes it return '0' here, matching the comment above the function. Acked-by: Ley Foon Tan <lftan@altera.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11x86: apm: avoid uninitialized dataArnd Bergmann
apm_bios_call() can fail, and return a status in its argument structure. If that status however is zero during a call from apm_get_power_status(), we end up using data that may have never been set, as reported by "gcc -Wmaybe-uninitialized": arch/x86/kernel/apm_32.c: In function ‘apm’: arch/x86/kernel/apm_32.c:1729:17: error: ‘bx’ may be used uninitialized in this function [-Werror=maybe-uninitialized] arch/x86/kernel/apm_32.c:1835:5: error: ‘cx’ may be used uninitialized in this function [-Werror=maybe-uninitialized] arch/x86/kernel/apm_32.c:1730:17: note: ‘cx’ was declared here arch/x86/kernel/apm_32.c:1842:27: error: ‘dx’ may be used uninitialized in this function [-Werror=maybe-uninitialized] arch/x86/kernel/apm_32.c:1731:17: note: ‘dx’ was declared here This changes the function to return "APM_NO_ERROR" here, which makes the code more robust to broken BIOS versions, and avoids the warning. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Jiri Kosina <jkosina@suse.cz> Reviewed-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11NFSv4.1: work around -Wmaybe-uninitialized warningArnd Bergmann
A bugfix introduced a harmless gcc warning in nfs4_slot_seqid_in_use if we enable -Wmaybe-uninitialized again: fs/nfs/nfs4session.c:203:54: error: 'cur_seq' may be used uninitialized in this function [-Werror=maybe-uninitialized] gcc is not smart enough to conclude that the IS_ERR/PTR_ERR pair results in a nonzero return value here. Using PTR_ERR_OR_ZERO() instead makes this clear to the compiler. Fixes: e09c978aae5b ("NFSv4.1: Fix Oopsable condition in server callback races") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11Kbuild: enable -Wmaybe-uninitialized warning for "make W=1"Arnd Bergmann
Traditionally, we have always had warnings about uninitialized variables enabled, as this is part of -Wall, and generally a good idea [1], but it also always produced false positives, mainly because this is a variation of the halting problem and provably impossible to get right in all cases [2]. Various people have identified cases that are particularly bad for false positives, and in commit e74fc973b6e5 ("Turn off -Wmaybe-uninitialized when building with -Os"), I turned off the warning for any build that was done with CC_OPTIMIZE_FOR_SIZE. This drastically reduced the number of false positive warnings in the default build but unfortunately had the side effect of turning the warning off completely in 'allmodconfig' builds, which in turn led to a lot of warnings (both actual bugs, and remaining false positives) to go in unnoticed. With commit 877417e6ffb9 ("Kbuild: change CC_OPTIMIZE_FOR_SIZE definition") enabled the warning again for allmodconfig builds in v4.7 and in v4.8-rc1, I had finally managed to address all warnings I get in an ARM allmodconfig build and most other maybe-uninitialized warnings for ARM randconfig builds. However, commit 6e8d666e9253 ("Disable "maybe-uninitialized" warning globally") was merged at the same time and disabled it completely for all configurations, because of false-positive warnings on x86 that I had not addressed until then. This caused a lot of actual bugs to get merged into mainline, and I sent several dozen patches for these during the v4.9 development cycle. Most of these are actual bugs, some are for correct code that is safe because it is only called under external constraints that make it impossible to run into the case that gcc sees, and in a few cases gcc is just stupid and finds something that can obviously never happen. I have now done a few thousand randconfig builds on x86 and collected all patches that I needed to address every single warning I got (I can provide the combined patch for the other warnings if anyone is interested), so I hope we can get the warning back and let people catch the actual bugs earlier. This reverts the change to disable the warning completely and for now brings it back at the "make W=1" level, so we can get it merged into mainline without introducing false positives. A follow-up patch enables it on all levels unless some configuration option turns it off because of false-positives. Link: https://rusty.ozlabs.org/?p=232 [1] Link: https://gcc.gnu.org/wiki/Better_Uninitialized_Warnings [2] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11lib/stackdepot: export save/fetch stack for driversChris Wilson
Some drivers would like to record stacktraces in order to aide leak tracing. As stackdepot already provides a facility for only storing the unique traces, thereby reducing the memory required, export that functionality for use by drivers. The code was originally created for KASAN and moved under lib in commit cd11016e5f521 ("mm, kasan: stackdepot implementation. Enable stackdepot for SLAB") so that it could be shared with mm/. In turn, we want to share it now with drivers. Link: http://lkml.kernel.org/r/20161108133209.22704-1-chris@chris-wilson.co.uk Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11mm: kmemleak: scan .data.ro_after_initJakub Kicinski
Limit the number of kmemleak false positives by including .data.ro_after_init in memory scanning. To achieve this we need to add symbols for start and end of the section to the linker scripts. The problem was been uncovered by commit 56989f6d8568 ("genetlink: mark families as __ro_after_init"). Link: http://lkml.kernel.org/r/1478274173-15218-1-git-send-email-jakub.kicinski@netronome.com Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11memcg: prevent memcg caches to be both OFF_SLAB & OBJFREELIST_SLABGreg Thelen
While testing OBJFREELIST_SLAB integration with pagealloc, we found a bug where kmem_cache(sys) would be created with both CFLGS_OFF_SLAB & CFLGS_OBJFREELIST_SLAB. When it happened, critical allocations needed for loading drivers or creating new caches will fail. The original kmem_cache is created early making OFF_SLAB not possible. When kmem_cache(sys) is created, OFF_SLAB is possible and if pagealloc is enabled it will try to enable it first under certain conditions. Given kmem_cache(sys) reuses the original flag, you can have both flags at the same time resulting in allocation failures and odd behaviors. This fix discards allocator specific flags from memcg before calling create_cache. The bug exists since 4.6-rc1 and affects testing debug pagealloc configurations. Fixes: b03a017bebc4 ("mm/slab: introduce new slab management type, OBJFREELIST_SLAB") Link: http://lkml.kernel.org/r/1478553075-120242-1-git-send-email-thgarnie@google.com Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Thomas Garnier <thgarnie@google.com> Tested-by: Thomas Garnier <thgarnie@google.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11coredump: fix unfreezable coredumping taskAndrey Ryabinin
It could be not possible to freeze coredumping task when it waits for 'core_state->startup' completion, because threads are frozen in get_signal() before they got a chance to complete 'core_state->startup'. Inability to freeze a task during suspend will cause suspend to fail. Also CRIU uses cgroup freezer during dump operation. So with an unfreezable task the CRIU dump will fail because it waits for a transition from 'FREEZING' to 'FROZEN' state which will never happen. Use freezer_do_not_count() to tell freezer to ignore coredumping task while it waits for core_state->startup completion. Link: http://lkml.kernel.org/r/1475225434-3753-1-git-send-email-aryabinin@virtuozzo.com Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Michal Hocko <mhocko@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11mm/filemap: don't allow partially uptodate page for pipesEryu Guan
Starting from 4.9-rc1 kernel, I started noticing some test failures of sendfile(2) and splice(2) (sendfile0N and splice01 from LTP) when testing on sub-page block size filesystems (tested both XFS and ext4), these syscalls start to return EIO in the tests. e.g. sendfile02 1 TFAIL : sendfile02.c:133: sendfile(2) failed to return expected value, expected: 26, got: -1 sendfile02 2 TFAIL : sendfile02.c:133: sendfile(2) failed to return expected value, expected: 24, got: -1 sendfile02 3 TFAIL : sendfile02.c:133: sendfile(2) failed to return expected value, expected: 22, got: -1 sendfile02 4 TFAIL : sendfile02.c:133: sendfile(2) failed to return expected value, expected: 20, got: -1 This is because that in sub-page block size cases, we don't need the whole page to be uptodate, only the part we care about is uptodate is OK (if fs has ->is_partially_uptodate defined). But page_cache_pipe_buf_confirm() doesn't have the ability to check the partially-uptodate case, it needs the whole page to be uptodate. So it returns EIO in this case. This is a regression introduced by commit 82c156f85384 ("switch generic_file_splice_read() to use of ->read_iter()"). Prior to the change, generic_file_splice_read() doesn't allow partially-uptodate page either, so it worked fine. Fix it by skipping the partially-uptodate check if we're working on a pipe in do_generic_file_read(), so we read the whole page from disk as long as the page is not uptodate. I think the other way to fix it is to add the ability to check & allow partially-uptodate page to page_cache_pipe_buf_confirm(), but that is much harder to do and seems gain little. Link: http://lkml.kernel.org/r/1477986187-12717-1-git-send-email-guaneryu@gmail.com Signed-off-by: Eryu Guan <guaneryu@gmail.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11mm/hugetlb: fix huge page reservation leak in private mapping error pathsMike Kravetz
Error paths in hugetlb_cow() and hugetlb_no_page() may free a newly allocated huge page. If a reservation was associated with the huge page, alloc_huge_page() consumed the reservation while allocating. When the newly allocated page is freed in free_huge_page(), it will increment the global reservation count. However, the reservation entry in the reserve map will remain. This is not an issue for shared mappings as the entry in the reserve map indicates a reservation exists. But, an entry in a private mapping reserve map indicates the reservation was consumed and no longer exists. This results in an inconsistency between the reserve map and the global reservation count. This 'leaks' a reserved huge page. Create a new routine restore_reserve_on_error() to restore the reserve entry in these specific error paths. This routine makes use of a new function vma_add_reservation() which will add a reserve entry for a specific address/page. In general, these error paths were rarely (if ever) taken on most architectures. However, powerpc contained arch specific code that that resulted in an extra fault and execution of these error paths on all private mappings. Fixes: 67961f9db8c4 ("mm/hugetlb: fix huge page reserve accounting for private mappings) Link: http://lkml.kernel.org/r/1476933077-23091-2-git-send-email-mike.kravetz@oracle.com Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Reported-by: Jan Stancek <jstancek@redhat.com> Tested-by: Jan Stancek <jstancek@redhat.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Kirill A . Shutemov <kirill.shutemov@linux.intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
