commit a13f085d111e90469faf2d9965eb39b11c114d7e upstream.
This fixes the following issues:
- When a buffer size is supplied to reiserfs_listxattr() such that each
individual name fits, but the concatenation of all names doesn't fit,
reiserfs_listxattr() overflows the supplied buffer. This leads to a
kernel heap overflow (verified using KASAN) followed by an out-of-bounds
usercopy and is therefore a security bug.
- When a buffer size is supplied to reiserfs_listxattr() such that a
name doesn't fit, -ERANGE should be returned. But reiserfs instead just
truncates the list of names; I have verified that if the only xattr on a
file has a longer name than the supplied buffer length, listxattr()
incorrectly returns zero.
With my patch applied, -ERANGE is returned in both cases and the memory
corruption doesn't happen anymore.
Credit for making me clean this code up a bit goes to Al Viro, who pointed
out that the ->actor calling convention is suboptimal and should be
changed.
Link: http://lkml.kernel.org/r/20180802151539.5373-1-jannh@google.com
Fixes: 48b32a3553a5 ("reiserfs: use generic xattr handlers")
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Jeff Mahoney <jeffm@suse.com>
Cc: Eric Biggers <ebiggers@google.com>
Cc: <stable@vger.kernel.org>
commit bed4ff1ed4d8f2ef5007c5c6ae1b29c5677a3632 upstream.
This fixes a race condition, where the DMAEN bit ends up being set after
I2C slave has transmitted a byte following the dummy read. When that
happens, an interrupt is generated instead, and no DMA request is generated
to kickstart the DMA read, and a timeout happens after DMA_TIMEOUT (1 sec).
Fixed by setting the DMAEN bit before the dummy read.
Signed-off-by: Esben Haabendal <eha@deif.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: stable@kernel.org
commit 1204e35bedf4e5015cda559ed8c84789a6dae24e upstream.
Commit b440bde74f04 ("PCI: Add pci_ignore_hotplug() to ignore hotplug
events for a device") iterates over the devices on a hotplug port's
subordinate bus in pciehp's IRQ handler without acquiring pci_bus_sem.
It is thus possible for a user to cause a crash by concurrently
manipulating the device list, e.g. by disabling slot power via sysfs
on a different CPU or by initiating a remove/rescan via sysfs.
This can't be fixed by acquiring pci_bus_sem because it may sleep.
The simplest fix is to avoid the list iteration altogether and just
check the ignore_hotplug flag on the port itself. This works because
pci_ignore_hotplug() sets the flag both on the device as well as on its
parent bridge.
We do lose the ability to print the name of the device blocking hotplug
in the debug message, but that's probably bearable.
Fixes: b440bde74f04 ("PCI: Add pci_ignore_hotplug() to ignore hotplug events for a device")
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: stable@vger.kernel.org
commit 281e878eab191cce4259abbbf1a0322e3adae02c upstream.
When pciehp is unbound (e.g. on unplug of a Thunderbolt device), the
hotplug_slot struct is deregistered and thus freed before freeing the
IRQ. The IRQ handler and the work items it schedules print the slot
name referenced from the freed structure in various informational and
debug log messages, each time resulting in a quadruple dereference of
freed pointers (hotplug_slot -> pci_slot -> kobject -> name).
At best the slot name is logged as "(null)", at worst kernel memory is
exposed in logs or the driver crashes:
pciehp 0000:10:00.0:pcie204: Slot((null)): Card not present
An attacker may provoke the bug by unplugging multiple devices on a
Thunderbolt daisy chain at once. Unplugging can also be simulated by
powering down slots via sysfs. The bug is particularly easy to trigger
in poll mode.
It has been present since the driver's introduction in 2004:
https://git.kernel.org/tglx/history/c/c16b4b14d980
Fix by rearranging teardown such that the IRQ is freed first. Run the
work items queued by the IRQ handler to completion before freeing the
hotplug_slot struct by draining the work queue from the ->release_slot
callback which is invoked by pci_hp_deregister().
Cc: stable@vger.kernel.org # v2.6.4
commit 3dbe97efe8bf450b183d6dee2305cbc032e6b8a4 upstream.
PCIe r4.0, sec 9.3.5.4, "Device Control Register", shows both
Max_Payload_Size (MPS) and Max_Read_request_Size (MRRS) to be 'RsvdP' for
VFs. Just prior to the table it states:
"PF and VF functionality is defined in Section 7.5.3.4 except where
noted in Table 9-16. For VF fields marked 'RsvdP', the PF setting
applies to the VF."
All of which implies that with respect to Max_Payload_Size Supported
(MPSS), MPS, and MRRS values, we should not be paying any attention to the
VF's fields, but rather only to the PF's. Only looking at the PF's fields
also logically makes sense as it's the sole physical interface to the PCIe
bus.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=200527
Fixes: 27d868b5e6cf ("PCI: Set MPS to match upstream bridge")
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
Cc: stable@vger.kernel.org # 4.3+
Cc: Keith Busch <keith.busch@intel.com>
Cc: Sinan Kaya <okaya@kernel.org>
Cc: Dongdong Liu <liudongdong3@huawei.com>
Cc: Jon Mason <jdmason@kudzu.us>
commit 4ce6435820d1f1cc2c2788e232735eb244bcc8a3 upstream.
If addition of sysfs files fails on registration of a hotplug slot, the
struct pci_slot as well as the entry in the slot_list is leaked. The
issue has been present since the hotplug core was introduced in 2002:
https://git.kernel.org/tglx/history/c/a8a2069f432c
Perhaps the idea was that even though sysfs addition fails, the slot
should still be usable. But that's not how drivers use the interface,
they abort probe if a non-zero value is returned.
Cc: stable@vger.kernel.org # v2.4.15+
Cc: Greg Kroah-Hartman <greg@kroah.com>
commit 3b885ac1dc35b87a39ee176a6c7e2af9c789d8b8 upstream.
Now that mb() is an instruction barrier, it will slow performance if we issue
unnecessary barriers.
The spinlock defines have a number of unnecessary barriers. The __ldcw()
define is both a hardware and compiler barrier. The mb() barriers in the
routines using __ldcw() serve no purpose.
The only barrier needed is the one in arch_spin_unlock(). We need to ensure
all accesses are complete prior to releasing the lock.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # 4.0+
Signed-off-by: Helge Deller <deller@gmx.de>
commit 4576cd469d980317c4edd9173f8b694aa71ea3a3 upstream.
TPACKET_V3 stores variable length frames in fixed length blocks.
Blocks must be able to store a block header, optional private space
and at least one minimum sized frame.
Frames, even for a zero snaplen packet, store metadata headers and
optional reserved space.
In the block size bounds check, ensure that the frame of the
chosen configuration fits. This includes sockaddr_ll and optional
tp_reserve.
Syzbot was able to construct a ring with insuffient room for the
sockaddr_ll in the header of a zero-length frame, triggering an
out-of-bounds write in dev_parse_header.
Convert the comparison to less than, as zero is a valid snap len.
This matches the test for minimum tp_frame_size immediately below.
Fixes: f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation.")
Fixes: eb73190f4fbe ("net/packet: refine check for priv area size")
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
commit 6613b6173dee098997229caf1f3b961c49da75e6 upstream.
When first DCCP packet is SYNC or SYNCACK, we insert a new conntrack
that has an un-initialized timeout value, i.e. such entry could be
reaped at any time.
Mark them as INVALID and only ignore SYNC/SYNCACK when connection had
an old state.
Reported-by: syzbot+6f18401420df260e37ed@syzkaller.appspotmail.com
commit 45c180bc29babbedd6b8c01b975780ef44d9d09c upstream.
struct xfrm_userpolicy_type has two holes, so we should not
use C99 style initializer.
KMSAN report:
BUG: KMSAN: kernel-infoleak in copyout lib/iov_iter.c:140 [inline]
BUG: KMSAN: kernel-infoleak in _copy_to_iter+0x1b14/0x2800 lib/iov_iter.c:571
CPU: 1 PID: 4520 Comm: syz-executor841 Not tainted 4.17.0+ #5
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:113
kmsan_report+0x188/0x2a0 mm/kmsan/kmsan.c:1117
kmsan_internal_check_memory+0x138/0x1f0 mm/kmsan/kmsan.c:1211
kmsan_copy_to_user+0x7a/0x160 mm/kmsan/kmsan.c:1253
copy_to_iter include/linux/uio.h:106 [inline]
skb_copy_datagram_iter+0x422/0xfa0 net/core/datagram.c:431
skb_copy_datagram_msg include/linux/skbuff.h:3268 [inline]
netlink_recvmsg+0x6f1/0x1900 net/netlink/af_netlink.c:1959
sock_recvmsg_nosec net/socket.c:802 [inline]
sock_recvmsg+0x1d6/0x230 net/socket.c:809
___sys_recvmsg+0x3fe/0x810 net/socket.c:2279
__sys_recvmmsg+0x58e/0xe30 net/socket.c:2391
do_sys_recvmmsg+0x2a6/0x3e0 net/socket.c:2472
__do_sys_recvmmsg net/socket.c:2485 [inline]
__se_sys_recvmmsg net/socket.c:2481 [inline]
__x64_sys_recvmmsg+0x15d/0x1c0 net/socket.c:2481
do_syscall_64+0x15b/0x230 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x446ce9
RSP: 002b:00007fc307918db8 EFLAGS: 00000293 ORIG_RAX: 000000000000012b
RAX: ffffffffffffffda RBX: 00000000006dbc24 RCX: 0000000000446ce9
RDX: 000000000000000a RSI: 0000000020005040 RDI: 0000000000000003
RBP: 00000000006dbc20 R08: 0000000020004e40 R09: 0000000000000000
R10: 0000000040000000 R11: 0000000000000293 R12: 0000000000000000
R13: 00007ffc8d2df32f R14: 00007fc3079199c0 R15: 0000000000000001
Uninit was stored to memory at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:279 [inline]
kmsan_save_stack mm/kmsan/kmsan.c:294 [inline]
kmsan_internal_chain_origin+0x12b/0x210 mm/kmsan/kmsan.c:685
kmsan_memcpy_origins+0x11d/0x170 mm/kmsan/kmsan.c:527
__msan_memcpy+0x109/0x160 mm/kmsan/kmsan_instr.c:413
__nla_put lib/nlattr.c:569 [inline]
nla_put+0x276/0x340 lib/nlattr.c:627
copy_to_user_policy_type net/xfrm/xfrm_user.c:1678 [inline]
dump_one_policy+0xbe1/0x1090 net/xfrm/xfrm_user.c:1708
xfrm_policy_walk+0x45a/0xd00 net/xfrm/xfrm_policy.c:1013
xfrm_dump_policy+0x1c0/0x2a0 net/xfrm/xfrm_user.c:1749
netlink_dump+0x9b5/0x1550 net/netlink/af_netlink.c:2226
__netlink_dump_start+0x1131/0x1270 net/netlink/af_netlink.c:2323
netlink_dump_start include/linux/netlink.h:214 [inline]
xfrm_user_rcv_msg+0x8a3/0x9b0 net/xfrm/xfrm_user.c:2577
netlink_rcv_skb+0x37e/0x600 net/netlink/af_netlink.c:2448
xfrm_netlink_rcv+0xb2/0xf0 net/xfrm/xfrm_user.c:2598
netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
netlink_unicast+0x1680/0x1750 net/netlink/af_netlink.c:1336
netlink_sendmsg+0x104f/0x1350 net/netlink/af_netlink.c:1901
sock_sendmsg_nosec net/socket.c:629 [inline]
sock_sendmsg net/socket.c:639 [inline]
___sys_sendmsg+0xec8/0x1320 net/socket.c:2117
__sys_sendmsg net/socket.c:2155 [inline]
__do_sys_sendmsg net/socket.c:2164 [inline]
__se_sys_sendmsg net/socket.c:2162 [inline]
__x64_sys_sendmsg+0x331/0x460 net/socket.c:2162
Local variable description: ----upt.i@dump_one_policy
Variable was created at:
dump_one_policy+0x78/0x1090 net/xfrm/xfrm_user.c:1689
Byte 130 of 137 is uninitialized
Memory access starts at ffff88019550407f
Fixes: c0144beaeca42 ("[XFRM] netlink: Use nla_put()/NLA_PUT() variantes")
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
commit 7797167ffde1f00446301cb22b37b7c03194cfaf upstream.
Now that we use a sync prior to releasing the locks in syscall.S, we don't need
the PA 2.0 ordered stores used to release some locks. Using an ordered store,
potentially slows the release and subsequent code.
There are a number of other ordered stores and loads that serve no purpose. I
have converted these to normal stores.
commit 1a5d5e5d51e75a5bca67dadbcea8c841934b7b85 upstream.
'ac->ac_g_ex.fe_len' is a user-controlled value which is used in the
derivation of 'ac->ac_2order'. 'ac->ac_2order', in turn, is used to
index arrays which makes it a potential spectre gadget. Fix this by
sanitizing the value assigned to 'ac->ac2_order'. This covers the
following accesses found with the help of smatch:
* fs/ext4/mballoc.c:1896 ext4_mb_simple_scan_group() warn: potential
spectre issue 'grp->bb_counters' [w] (local cap)
* fs/ext4/mballoc.c:445 mb_find_buddy() warn: potential spectre issue
'EXT4_SB(e4b->bd_sb)->s_mb_offsets' [r] (local cap)
* fs/ext4/mballoc.c:446 mb_find_buddy() warn: potential spectre issue
'EXT4_SB(e4b->bd_sb)->s_mb_maxs' [r] (local cap)
Suggested-by: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: Jeremy Cline <jcline@redhat.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 9432a3175770e06cb83eada2d91fac90c977cb99 upstream.
A comment warning against this bug is there, but the code is not doing what
the comment says. Therefore it is possible that an EPOLLHUP races against
irq_bypass_register_consumer. The EPOLLHUP handler schedules irqfd_shutdown,
and if that runs soon enough, you get a use-after-free.
Reviewed-by: David Hildenbrand <david@redhat.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit e56b8ce363a36fb7b74b80aaa5cc9084f2c908b4 ]
Attempt to make cryptic TCP seq number error messages clearer by
(1) identifying the source of the message as "TCP", (2) identifying the
errors as "seq # bug", and (3) grouping the field identifiers and values
by separating them with commas.
E.g., the following message is changed from:
recvmsg bug 2: copied 73BCB6CD seq 70F17CBE rcvnxt 73BCB9AA fl 0
WARNING: CPU: 2 PID: 1501 at /linux/net/ipv4/tcp.c:1881 tcp_recvmsg+0x649/0xb90
to:
TCP recvmsg seq # bug 2: copied 73BCB6CD, seq 70F17CBE, rcvnxt 73BCB9AA, fl 0
WARNING: CPU: 2 PID: 1501 at /linux/net/ipv4/tcp.c:2011 tcp_recvmsg+0x694/0xba0
Suggested-by: 積丹尼 Dan Jacobson <jidanni@jidanni.org>
[ Upstream commit 50973993260a6934f0a00da53d9b746cfbea89ab ]
In cases the probing fails the log level of the messages should
be an error.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
[ Upstream commit 711c62dfa6bdb4326ca6c587f295ea5c4f7269de ]
In case the SPI thread is not running, a simple reset of sync
state won't fix the transmit timeout. We also need to wake up the kernel
thread.
Fixes: ed7d42e24eff ("net: qca_spi: fix transmit queue timeout handling")
[ Upstream commit b2bab426dc715de147f8039a3fccff27d795f4eb ]
As long as the synchronization with the QCA7000 isn't finished, we
cannot accept packets from the upper layers. So let the SPI thread
enable the TX queue after sync and avoid unwanted packet drop.
Fixes: 291ab06ecf67 ("net: qualcomm: new Ethernet over SPI driver for QCA7000")
[ Upstream commit 0018b265adf7e251f90d3ca1c7c0e32e2a0ad262 ]
When testing the R-Car PCIe driver on the Condor board, if the PCIe PHY
driver was left disabled, the kernel crashed with this BUG:
kernel BUG at lib/ioremap.c:72!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 39 Comm: kworker/0:1 Not tainted 4.17.0-dirty #1092
Hardware name: Renesas Condor board based on r8a77980 (DT)
Workqueue: events deferred_probe_work_func
pstate: 80000005 (Nzcv daif -PAN -UAO)
pc : ioremap_page_range+0x370/0x3c8
lr : ioremap_page_range+0x40/0x3c8
sp : ffff000008da39e0
x29: ffff000008da39e0 x28: 00e8000000000f07
x27: ffff7dfffee00000 x26: 0140000000000000
x25: ffff7dfffef00000 x24: 00000000000fe100
x23: ffff80007b906000 x22: ffff000008ab8000
x21: ffff000008bb1d58 x20: ffff7dfffef00000
x19: ffff800009c30fb8 x18: 0000000000000001
x17: 00000000000152d0 x16: 00000000014012d0
x15: 0000000000000000 x14: 0720072007200720
x13: 0720072007200720 x12: 0720072007200720
x11: 0720072007300730 x10: 00000000000000ae
x9 : 0000000000000000 x8 : ffff7dffff000000
x7 : 0000000000000000 x6 : 0000000000000100
x5 : 0000000000000000 x4 : 000000007b906000
x3 : ffff80007c61a880 x2 : ffff7dfffeefffff
x1 : 0000000040000000 x0 : 00e80000fe100f07
Process kworker/0:1 (pid: 39, stack limit = 0x (ptrval))
Call trace:
pci_remap_iospace+0x7c/0xac
pci_parse_request_of_pci_ranges+0x13c/0x190
rcar_pcie_probe+0x4c/0xb04
platform_drv_probe+0x50/0xbc
driver_probe_device+0x21c/0x308
__device_attach_driver+0x98/0xc8
bus_for_each_drv+0x54/0x94
__device_attach+0xc4/0x12c
device_initial_probe+0x10/0x18
bus_probe_device+0x90/0x98
deferred_probe_work_func+0xb0/0x150
process_one_work+0x12c/0x29c
worker_thread+0x200/0x3fc
kthread+0x108/0x134
ret_from_fork+0x10/0x18
Code: f9004ba2 54000080 aa0003fb 17ffff48 (d4210000)
It turned out that pci_remap_iospace() wasn't undone when the driver's
probe failed, and since devm_phy_optional_get() returned -EPROBE_DEFER,
the probe was retried, finally causing the BUG due to trying to remap
already remapped pages.
The Versatile PCI controller driver has the same issue.
Replace pci_remap_iospace() with the devm_ managed version to fix the bug.
Fixes: b7e78170efd4 ("PCI: versatile: Add DT-based ARM Versatile PB PCIe host driver")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[lorenzo.pieralisi@arm.com: updated the commit log]
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
commit a5fb9fb023a1435f2b42bccd7f547560f3a21dc3 upstream.
Modules linked in:
Call trace:
kthread+0x108/0x134
Introduce the devm_pci_remap_iospace() managed API and replace the
pci_remap_iospace() call with it to fix the bug.
Fixes: dbf9826d5797 ("PCI: generic: Convert to DT resource parsing API")
[lorenzo.pieralisi@arm.com: split commit/updated the commit log]
[ Upstream commit 3a9b0455062ffb9d2f6cd4473a76e3456f318c9f ]
This driver can spam the kernel log with multiple messages of:
net eth0: eth0: allmulti set
Usually 4 or 8 at a time (probably because of using ConnMan).
This message doesn't seem useful, so let's demote it from dev_info()
to dev_dbg().
Signed-off-by: David Lechner <david@lechnology.com>
[ Upstream commit c133459765fae249ba482f62e12f987aec4376f0 ]
CC [M] drivers/net/ethernet/freescale/fman/fman.o
In file included from ../drivers/net/ethernet/freescale/fman/fman.c:35:
../include/linux/fsl/guts.h: In function 'guts_set_dmacr':
../include/linux/fsl/guts.h:165:2: error: implicit declaration of function 'clrsetbits_be32' [-Werror=implicit-function-declaration]
clrsetbits_be32(&guts->dmacr, 3 << shift, device << shift);
Cc: Madalin Bucur <madalin.bucur@nxp.com>
Cc: netdev@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
[ Upstream commit 7f073d011f93e92d4d225526b9ab6b8b0bbd6613 ]
The bo array has req->nr_buffers elements so the > should be >= so we
don't read beyond the end of the array.
Fixes: a1606a9596e5 ("drm/nouveau: new gem pushbuf interface, bump to 0.0.16")
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
[ Upstream commit c29e9da56bebb4c2c794e871b0dc0298bbf08142 ]
platform_get_resource() may fail and return NULL, so we should
better check it's return value to avoid a NULL pointer dereference
a bit later in the code.
This is detected by Coccinelle semantic patch.
expression pdev, res, n, t, e, e1, e2;
res = platform_get_resource(pdev, t, n);
+ if (!res)
+ return -EINVAL;
... when != res == NULL
e = devm_ioremap_nocache(e1, res->start, e2);
Fixes: cc4fa83f66e9 ("pinctrl: nsp: add pinmux driver support for Broadcom NSP SoC")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
[ Upstream commit f90a21c898db58eaea14b8ad7e9af3b9e15e5f8a ]
The > comparisons should be >= or else we read beyond the end of the
pinctrl->functions[] array.
[ Upstream commit a69258f7aa2623e0930212f09c586fd06674ad79 ]
After fixing the way DCTCP tracking delayed ACKs, the delayed-ACK
related callbacks are no longer needed
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Lawrence Brakmo <brakmo@fb.com>
[ Upstream commit 5fc853cc01c68f84984ecc2d5fd777ecad78240f ]
We accidentally left out the error handling for kstrtoul().
Fixes: a520030e326a ("qlcnic: Implement flash sysfs callback for 83xx adapter")
[ Upstream commit 993675a3100b16a4c80dfd70cbcde8ea7127b31d ]
If variable length link layer headers result in a packet shorter
than dev->hard_header_len, reset the network header offset. Else
skb->mac_len may exceed skb->len after skb_mac_reset_len.
packet_sendmsg_spkt already has similar logic.
Fixes: b84bbaf7a6c8 ("packet: in packet_snd start writing at link layer allocation")
[ Upstream commit 8b247a92ebd0cda7dec49a6f771d9c4950f3d3ad ]
The final link of fixdep uses LDFLAGS but not the existing HOSTLDFLAGS.
Fix this.
Signed-off-by: Laura Abbott <labbott@redhat.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
[ Upstream commit d14c780c11fbc10f66c43e7b64eefe87ca442bd3 ]
This change makes it so that we are much more explicit about the ordering
of updates to the receive address register (RAR) table. Prior to this patch
I believe we may have been updating the table while entries were still
active, or possibly allowing for reordering of things since we weren't
explicitly flushing writes to either the lower or upper portion of the
register prior to accessing the other half.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Reviewed-by: Shannon Nelson <shannon.nelson@oracle.com>
Tested-by: Andrew Bowers <andrewx.bowers@intel.com>
[ Upstream commit 923847413f7316b5ced3491769b3fefa6c56a79a ]
The AM3517 has a different OTG controller location than the OMAP3,
which is included from omap3.dtsi. This results in a hwmod error.
Since the AM3517 has a different OTG controller address, this patch
disabes one that is isn't available.
[ Upstream commit 2f8b5b21830aea95989a6e67d8a971297272a086 ]
Call secure services to enable ACTLR[0] (Enable invalidates of BTB with
ICIALLU) when branch hardening is enabled for kernel.
On GP devices OMAP5/DRA7, there is no possibility to update secure
side since "secure world" is ROM and there are no override mechanisms
possible. On HS devices, appropriate PPA should do the workarounds as
well.
However, the configuration is only done for secondary core, since it is
expected that firmware/bootloader will have enabled the required
configuration for the primary boot core (note: bootloaders typically
will NOT enable secondary processors, since it has no need to do so).
Signed-off-by: Nishanth Menon <nm@ti.com>
[ Upstream commit b4c7e2bd2eb4764afe3af9409ff3b1b87116fa30 ]
Dynamic ftrace requires modifying the code segments that are usually
set to read-only. To do this, a per arch function is called both before
and after the ftrace modifications are performed. The "before" function
will set kernel code text to read-write to allow for ftrace to make the
modifications, and the "after" function will set the kernel code text
back to "read-only" to keep the kernel code text protected.
The issue happens when dynamic ftrace is tested at boot up. The test is
done before the kernel code text has been set to read-only. But the
"before" and "after" calls are still performed. The "after" call will
change the kernel code text to read-only prematurely, and other boot
code that expects this code to be read-write will fail.
The solution is to add a variable that is set when the kernel code text
is expected to be converted to read-only, and make the ftrace "before"
and "after" calls do nothing if that variable is not yet set. This is
similar to the x86 solution from commit 162396309745 ("ftrace, x86:
make kernel text writable only for conversions").
Link: http://lkml.kernel.org/r/20180620212906.24b7b66e@vmware.local.home
Reported-by: Stefan Agner <stefan@agner.ch>
Tested-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit d63c46734c545ad0488761059004a65c46efdde3 ]
Fix memory leak in the error path of mlx5_ib_create_srq() by making sure
to free the allocated srq.
Fixes: c2b37f76485f ("IB/mlx5: Fix integer overflows in mlx5_ib_create_srq")
Signed-off-by: Kamal Heib <kamalheib1@gmail.com>
Acked-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit ee6581ceba7f8314b81b2f2a81f1cf3f67c679e2 ]
Incremental patch to fix the unchecked dereference in acpi_nfit_ctl.
Reported by Dan Carpenter:
"acpi/nfit: fix cmd_rc for acpi_nfit_ctl to
always return a value" from Jun 28, 2018, leads to the following
Smatch complaint:
drivers/acpi/nfit/core.c:578 acpi_nfit_ctl()
warn: variable dereferenced before check 'cmd_rc' (see line 411)
410
411 *cmd_rc = -EINVAL;
Patch adds unchecked dereference.
Fixes: c1985cefd844 ("acpi/nfit: fix cmd_rc for acpi_nfit_ctl to always return a value")
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
[ Upstream commit f6432b9f65001651412dbc3589d251534822d4ab ]
Like system(), popen() calls /bin/sh, which may/may not be bash.
Script when run on dash and encounters the line, yields:
exit: Illegal number: -1
checkbashisms report on script content:
possible bashism (exit|return with negative status code):
exit -1
Remove the bashism and use the more portable non-zero failure
status code 1.
Signed-off-by: Kim Phillips <kim.phillips@arm.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Michael Petlan <mpetlan@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Sandipan Das <sandipan@linux.vnet.ibm.com>
Cc: Thomas Richter <tmricht@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20180629124652.8d0af7e2281fd3fd8262cacc@arm.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit c58387ab1614f6d7fb9e244f214b61e7631421fc ]
Fix bug in the error code path when bnxt_request_irq() returns failure.
bnxt_disable_napi() should not be called in this error path because
NAPI has not been enabled yet.
Fixes: c0c050c58d84 ("bnxt_en: New Broadcom ethernet driver.")
Signed-off-by: Vikas Gupta <vikas.gupta@broadcom.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 78f058a4aa0f2280dc4d45d2c4a95728398ef857 ]
The current code returns -ENOMEM and does not bother to set the output
parameters to 0 when no rings are available. Some callers, such as
bnxt_get_channels() will display garbage ring numbers when that happens.
Fix it by always setting the output parameters.
Fixes: 6e6c5a57fbe1 ("bnxt_en: Modify bnxt_get_max_rings() to support shared or non shared rings.")
[ Upstream commit e8708786d4fe21c043d38d760f768949a3d71185 ]
This is used in configs lacking hardware atomics to emulate atomic r-m-w
for user space, implemented by disabling preemption in kernel.
However there are issues in current implementation:
1. Process not terminated if invalid user pointer passed:
i.e. __get_user() failed.
2. The reason for this patch was __put_user() failure not being handled
either, specifically for the COW break scenario.
The zero page is initially wired up and read from __get_user()
succeeds. A subsequent write by __put_user() induces a
Protection Violation, but COW can't finish as Linux page fault
handler is disabled due to preempt disable.
And what's worse is we silently return the stale value to user space.
Fix this specific case by re-enabling preemption and explicitly
fixing up the fault and retrying the whole sequence over.
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
[vgupta: rewrote the changelog]
[ Upstream commit 2045cdfa1b40d66f126f3fd05604fc7c754f0022 ]
Loading the nf_conntrack module with doubled hashsize parameter, i.e.
modprobe nf_conntrack hashsize=12345 hashsize=12345
causes NULL-ptr deref.
If 'hashsize' specified twice, the nf_conntrack_set_hashsize() function
will be called also twice.
The first nf_conntrack_set_hashsize() call will set the
'nf_conntrack_htable_size' variable:
/* On boot, we can set this without any fancy locking. */
if (!nf_conntrack_htable_size)
return param_set_uint(val, kp);
But on the second invocation, the nf_conntrack_htable_size is already set,
so the nf_conntrack_set_hashsize() will take a different path and call
the nf_conntrack_hash_resize() function. Which will crash on the attempt
to dereference 'nf_conntrack_hash' pointer:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
RIP: 0010:nf_conntrack_hash_resize+0x255/0x490 [nf_conntrack]
Call Trace:
nf_conntrack_set_hashsize+0xcd/0x100 [nf_conntrack]
parse_args+0x1f9/0x5a0
load_module+0x1281/0x1a50
__se_sys_finit_module+0xbe/0xf0
do_syscall_64+0x7c/0x390
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fix this, by checking !nf_conntrack_hash instead of
!nf_conntrack_htable_size. nf_conntrack_hash will be initialized only
after the module loaded, so the second invocation of the
nf_conntrack_set_hashsize() won't crash, it will just reinitialize
nf_conntrack_htable_size again.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
[ Upstream commit d378859a667edc99e3473704847698cae97ca2b1 ]
The colorkey mode property was not correctly disabling the colorkeying
when "disabled" mode was selected. Arrange for this to work as one
would expect.
[ Upstream commit 8f2fbc6c60ff213369e06a73610fc882a42fdf20 ]
The check is valid but it does not warrant to crash the kernel. A
WARN_ON() is good enough here.
Found by checkpatch.
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
[ Upstream commit 8a81388ec27c4c0adbdecd20e67bb5f411ab46b2 ]
Instead of having the function name hard-coded (it might change and we
forgot to update them in the debug output) we can use __func__ instead
and also shorter the line so we do not need to break it. Also fix an
extra blank line while being here.
[ Upstream commit 20f330452ad8814f2289a589baf65e21270879a7 ]
[ Upstream commit 38230a3e0e0933bbcf5df6fa469ba0667f667568 ]
the control action in the common member of struct tcf_tunnel_key must be a
valid value, as it can contain the chain index when 'goto chain' is used.
Ensure that the control action can be read as x->tcfa_action, when x is a
pointer to struct tc_action and x->ops->type is TCA_ACT_TUNNEL_KEY, to
prevent the following command:
# tc filter add dev $h2 ingress protocol ip pref 1 handle 101 flower \
> $tcflags dst_mac $h2mac action tunnel_key unset goto chain 1
from causing a NULL dereference when a matching packet is received:
PGD 80000001097ac067 P4D 80000001097ac067 PUD 103b0a067 PMD 0
Oops: 0000 [#1] SMP PTI
CPU: 0 PID: 3491 Comm: mausezahn Tainted: G E 4.18.0-rc2.auguri+ #421
Hardware name: Hewlett-Packard HP Z220 CMT Workstation/1790, BIOS K51 v01.58 02/07/2013
RIP: 0010:tcf_action_exec+0xb8/0x100
Code: 00 00 00 20 74 1d 83 f8 03 75 09 49 83 c4 08 4d 39 ec 75 bc 48 83 c4 10 5b 5d 41 5c 41 5d 41 5e 41 5f c3 49 8b 97 a8 00 00 00 <48> 8b 12 48 89 55 00 48 83 c4 10 5b 5d 41 5c 41 5d 41 5e 41 5f c3
RSP: 0018:ffff95145ea03c40 EFLAGS: 00010246
RAX: 0000000020000001 RBX: ffff9514499e5800 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000002 RDI: 0000000000000000
RBP: ffff95145ea03e60 R08: 0000000000000000 R09: ffff95145ea03c9c
R10: ffff95145ea03c78 R11: 0000000000000008 R12: ffff951456a69800
R13: ffff951456a69808 R14: 0000000000000001 R15: ffff95144965ee40
FS: 00007fd67ee11740(0000) GS:ffff95145ea00000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 00000001038a2006 CR4: 00000000001606f0
Call Trace:
<IRQ>
fl_classify+0x1ad/0x1c0 [cls_flower]
? __update_load_avg_se.isra.47+0x1ca/0x1d0
? update_load_avg+0x665/0x690
? kmem_cache_alloc+0x38/0x1c0
tcf_classify+0x89/0x140
__netif_receive_skb_core+0x5ea/0xb70
? enqueue_entity+0xd0/0x270
? process_backlog+0x97/0x150
net_rx_action+0x14b/0x3e0
__do_softirq+0xde/0x2b4
do_softirq_own_stack+0x2a/0x40
</IRQ>
do_softirq.part.18+0x49/0x50
__local_bh_enable_ip+0x49/0x50
__dev_queue_xmit+0x4ab/0x8a0
? wait_woken+0x80/0x80
? packet_sendmsg+0x38f/0x810
? __dev_queue_xmit+0x8a0/0x8a0
sock_sendmsg+0x36/0x40
__sys_sendto+0x10e/0x140
? do_vfs_ioctl+0xa4/0x630
? syscall_trace_enter+0x1df/0x2e0
? __audit_syscall_exit+0x22a/0x290
__x64_sys_sendto+0x24/0x30
do_syscall_64+0x5b/0x180
RIP: 0033:0x7fd67e18dc93
Code: 48 8b 0d 18 83 20 00 f7 d8 64 89 01 48 83 c8 ff c3 66 0f 1f 44 00 00 83 3d 59 c7 20 00 00 75 13 49 89 ca b8 2c 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 34 c3 48 83 ec 08 e8 2b f7 ff ff 48 89 04 24
RSP: 002b:00007ffe0189b748 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000020ca010 RCX: 00007fd67e18dc93
RDX: 0000000000000062 RSI: 00000000020ca322 RDI: 0000000000000003
RBP: 00007ffe0189b780 R08: 00007ffe0189b760 R09: 0000000000000014
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000062
R13: 00000000020ca322 R14: 00007ffe0189b760 R15: 0000000000000003
Modules linked in: act_tunnel_key act_gact cls_flower sch_ingress vrf veth act_csum(E) xt_CHECKSUM iptable_mangle ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ipt_REJECT nf_reject_ipv4 tun bridge stp llc ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter intel_rapl snd_hda_codec_hdmi x86_pkg_temp_thermal intel_powerclamp snd_hda_codec_realtek coretemp snd_hda_codec_generic kvm_intel kvm irqbypass snd_hda_intel crct10dif_pclmul crc32_pclmul hp_wmi ghash_clmulni_intel pcbc snd_hda_codec aesni_intel sparse_keymap rfkill snd_hda_core snd_hwdep snd_seq crypto_simd iTCO_wdt gpio_ich iTCO_vendor_support wmi_bmof cryptd mei_wdt glue_helper snd_seq_device snd_pcm pcspkr snd_timer snd i2c_i801 lpc_ich sg soundcore wmi mei_me
mei ie31200_edac nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c sd_mod sr_mod cdrom i915 video i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci crc32c_intel libahci serio_raw sfc libata mtd drm ixgbe mdio i2c_core e1000e dca
---[ end trace 1ab8b5b5d4639dfc ]---
Kernel panic - not syncing: Fatal exception in interrupt
Kernel Offset: 0x11400000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff)
---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
Fixes: d0f6dd8a914f ("net/sched: Introduce act_tunnel_key")
Signed-off-by: Davide Caratti <dcaratti@redhat.com>
[ Upstream commit 0c1049dcb4ceec640d8bd797335bcbebdcab44d2 ]
PXA3xx platforms have 56 interrupts that are stored in two ICMR
registers. The code in pxa_irq_suspend() and pxa_irq_resume() however
does a simple division by 32 which only leads to one register being
saved at suspend and restored at resume time. The NAND interrupt
setting, for instance, is lost.
Fix this by using DIV_ROUND_UP() instead.
Signed-off-by: Daniel Mack <daniel@zonque.org>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
[ Upstream commit 05925e52a7d379192a5fdff2c33710f573190ead ]
The change fixes sleep in atomic context bug, which is encountered
every time when link settings are changed by ethtool.
Since commit 35b5f6b1a82b ("PHYLIB: Locking fixes for PHY I/O
potentially sleeping") phy_start_aneg() function utilizes a mutex
to serialize changes to phy state, however that helper function is
called in atomic context under a grabbed spinlock, because
phy_start_aneg() is called by phy_ethtool_ksettings_set() and by
replaced phy_ethtool_sset() helpers from phylib.
Now duplex mode setting is enforced in ravb_adjust_link() only, also
now RX/TX is disabled when link is put down or modifications to E-MAC
registers ECMR and GECMR are expected for both cases of checked and
ignored link status pin state from E-MAC interrupt handler.
Fixes: c156633f1353 ("Renesas Ethernet AVB driver proper")
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Reviewed-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 0973a4dd79fe56a3beecfcff675ba4c01df0b0c1 ]
to serialize changes to phy state, however the helper function is
called in atomic context.
The bug can be reproduced by running "ethtool -r" command, the bug
is reported if CONFIG_DEBUG_ATOMIC_SLEEP build option is enabled.
[ Upstream commit 5cb3f52a11e18628fc4bee76dd14b1f0b76349de ]
Now duplex mode setting is enforced in sh_eth_adjust_link() only,
also now RX/TX is disabled when link is put down or modifications
to E-MAC registers ECMR and GECMR are expected for both cases of
checked and ignored link status pin state from E-MAC interrupt handler.
For reference the change is a partial rework of commit 1e1b812bbe10
("sh_eth: fix handling of no LINK signal").
Fixes: dc19e4e5e02f ("sh: sh_eth: Add support ethtool")
[ Upstream commit 53a710b5044d8475faa6813000b6dd659400ef7b ]
