commit 60f59ce0278557f7896d5158ae6d12a4855a72cc upstream.
These drivers need to be able to reference "struct ieee80211_hw" from
the driver's private data, and vice versa. The USB driver failed to
store the address of ieee80211_hw in the private data. Although this
bug has been present for a long time, it was not exposed until
commit ba9f93f82aba ("rtlwifi: Fix enter/exit power_save").
Fixes: ba9f93f82aba ("rtlwifi: Fix enter/exit power_save")
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit ba9f93f82abafe2552eac942ebb11c2df4f8dd7f upstream.
In commit a5ffbe0a1993 ("rtlwifi: Fix scheduling while atomic bug") and
commit a269913c52ad ("rtlwifi: Rework rtl_lps_leave() and rtl_lps_enter()
to use work queue"), an error was introduced in the power-save routines
due to the fact that leaving PS was delayed by the use of a work queue.
This problem is fixed by detecting if the enter or leave routines are
in interrupt mode. If so, the workqueue is used to place the request.
If in normal mode, the enter or leave routines are called directly.
Fixes: a269913c52ad ("rtlwifi: Rework rtl_lps_leave() and rtl_lps_enter() to use work queue")
Reported-by: Ping-Ke Shih <pkshih@realtek.com>
Cc: Stable <stable@vger.kernel.org>
commit 2c7d0602c815277f7cb7c932b091288710d8aba7 upstream.
commit 848496e5902833600f7992f4faa82dc1546051ba
Author: Ville Syrjälä <ville.syrjala@linux.intel.com>
Date: Wed Jul 13 16:32:03 2016 +0300
drm/i915: Wait up to 3ms for the pcu to ack the cdclk change request on SKL
increased the timeout to match the spec, but we still see a timeout on
at least one SKL. A CDCLK change request following the failed one will
succeed nevertheless.
I could reproduce this problem easily by running kms_pipe_crc_basic in a
loop. In all failure cases _wait_for() was pre-empted for >3ms and so in
the worst case - when the pre-emption happened right after calculating
timeout__ in _wait_for() - we called skl_cdclk_wait_for_pcu_ready() only
once which failed and so _wait_for() timed out. As opposed to this the
spec says to keep retrying the request for at most a 3ms period.
To fix this send the first request explicitly to guarantee that there is
3ms between the first and last request. Though this matches the spec, I
noticed that in rare cases this can still time out if we sent only a few
requests (in the worst case 2) _and_ PCODE is busy for some reason even
after a previous request and a 3ms delay. To work around this retry the
polling with pre-emption disabled to maximize the number of requests.
Also increase the timeout to 10ms to account for interrupts that could
reduce the number of requests. With this change I couldn't trigger
the problem.
v2:
- Use 1ms poll period instead of 10us. (Chris)
v3:
- Poll with pre-emption disabled to increase the number of request
attempts. (Ville, Chris)
- Factor out a helper to poll, it's also needed by the next patch.
v4:
- Pass reply_mask, reply to skl_pcode_request(), instead of assuming the
reply is generic. (Ville)
v5:
- List the request specific timeout values as code comment. (Ville)
v6:
- Try the poll first with preemption enabled.
- Add code comment about first request being queued by PCODE. (Art)
- Add timeout_base_ms argument. (Ville)
v7:
- Clarify code comment about first queued request. (Chris)
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Art Runyan <arthur.j.runyan@intel.com>
Cc: <stable@vger.kernel.org> # v4.2- : 3b2c171 : drm/i915: Wait up to 3ms
Fixes: 5d96d8afcfbb ("drm/i915/skl: Deinit/init the display at suspend/resume")
Reference: https://bugs.freedesktop.org/show_bug.cgi?id=97929
Testcase: igt/kms_pipe_crc_basic/suspend-read-crc-pipe-B
Signed-off-by: Imre Deak <imre.deak@intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Link: http://patchwork.freedesktop.org/patch/msgid/1480955258-26311-1-git-send-email-imre.deak@intel.com
(cherry picked from commit a0b8a1fe34430c3a82258e8cb45f5968bdf31afd)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 2e40795c3bf344cfb5220d94566205796e3ef19a upstream.
Plantronics BT600 does not support reading the sample rate which leads
to many lines of "cannot get freq at ep 0x1" and "cannot get freq at
ep 0x82". This patch adds the USB ID of the BT600 to quirks.c and
avoids those error messages.
Signed-off-by: Dennis Kadioglu <denk@post.com>
commit 7243e0b20729d372e97763617a7a9c89f29b33e1 upstream.
The calculation of SPR and SPPR doesn't round correctly at several
places which might result in baud rates that are too big. For example
with tclk_hz = 250000001 and target rate 25000000 it determined a
divider of 10 which is wrong.
Instead of fixing all the corner cases replace the calculation by an
algorithm without a loop which should even be quicker to execute apart
from being correct.
Fixes: df59fa7f4bca ("spi: orion: support armada extended baud rates")
Signed-off-by: Mark Brown <broonie@kernel.org>
commit f86a2c875fd146d9b82c8fdd86d31084507bcf4c upstream.
The commit 55ee7017ee31 ("arm: omap2: board-generic: use
omap4_local_timer_init for AM437x") unintentionally changes the
clocksource devices for AM437x from OMAP GP Timer to SyncTimer32K.
Unfortunately, the SyncTimer32K is starving from frequency deviation
as mentioned in commit 5b5c01359152 ("ARM: OMAP2+: AM43x: Use gptimer
as clocksource") and, as reported by Franklin [1], even its monotonic
nature is under question (most probably there is a HW issue, but it's
still under investigation).
Taking into account above facts It's reasonable to rollback to the use
of omap3_gptimer_timer_init().
[1] http://www.spinics.net/lists/linux-omap/msg127425.html
Fixes: 55ee7017ee31 ("arm: omap2: board-generic: use
Reported-by: Cooper Jr., Franklin <fcooper@ti.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Keerthy <j-keerthy@ti.com>
registration
commit 9388093db44356af911adf3d355b7544a13a63cd upstream.
Unlike clk_register_clkdev(), clk_hw_register_clkdev() doesn't check for
passed error objects from a previous registration call. Hence the caller
of clk_hw_register_*() has to check for errors before calling
clk_hw_register_clkdev*().
Make clk_hw_register_clkdev() more similar to clk_register_clkdev() by
adding this error check, removing the burden from callers that do mass
registration.
Fixes: e4f1b49bda6d6aa2 ("clkdev: Add clk_hw based registration APIs")
Fixes: 944b9a41e004534f ("clk: ls1x: Migrate to clk_hw based OF and registration APIs")
Fixes: 44ce9a9ae977736f ("MIPS: TXx9: Convert to Common Clock Framework")
Fixes: f48d947a162dfa9d ("clk: clps711x: Migrate to clk_hw based OF and registration APIs")
Fixes: b4626a7f489238a5 ("CLK: Add Loongson1C clock support")
commit cbf2642872333547b56b8c4d943f5ed04ac9a4ee upstream.
We don't want to fall through to a bunch of errors for retention
if PM_OMAP4_CPU_OSWR_DISABLE is not configured for a SoC.
Fixes: 6099dd37c669 ("ARM: OMAP5 / DRA7: Enable CPU RET on suspend")
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
commit da6d5993bf951846956903bee4f0eafd918250db upstream.
It's CONFIG_SOC_OMAP5, not CONFIG_ARCH_OMAP5. Looks like make randconfig
builds have not hit this one yet.
Fixes: b3bf289c1c45 ("ARM: OMAP2+: Fix build with CONFIG_SMP and CONFIG_PM is not set")
commit 8a8be46afeaa47aed1debe7e9b18152f9826a6b7 upstream.
We need to properly initialize mpuss also on omap5 like we do on omap4.
Otherwise we run into similar kexec problems like we had on omap4 when
trying to kexec from a kernel with PM initialized.
Fixes: 0573b957fc21 ("ARM: OMAP4+: Prevent CPU1 related hang with kexec")
commit 26242b330093fd14c2e94fb6cbdf0f482ab26576 upstream.
In case the driver registration fails, the hotplug callback is leaked.
Not fatal, because it's never invoked as there are no instances registered,
but wrong nevertheless.
Fixes: fdc15a36d84e ("bus/arm-ccn: Convert to hotplug statemachine")
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
commit 1b9f700b8cfc31089e2dfa5d0905c52fd4529b50 upstream.
Logic copied from xs_setup_bc_tcp().
Fixes: 39a9beab5acb ('rpc: share one xps between all backchannels')
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 206787737e308bb447d18adef7da7749188212f5 upstream.
Correct prefix is MDM instead of MSM.
Fixes: 8aa788d3e59a ("ARM: configs: qualcomm: Add MDM9615 missing defconfigs")
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
commit 7a3cc2a7b2c723aa552028f4e66841cec183756d upstream.
On Zynq, we haven't been reserving the correct amount of DMA-incapable
RAM to keep DMA away from it (per the Zynq TRM Section 4.1, it should be
the first 512k). In older kernels, this was masked by the
memblock_reserve call in arm_memblock_init(). Now, reserve the correct
amount excplicitly rather than relying on swapper_pg_dir, which is an
address and not a size anyway.
Fixes: 46f5b96 ("ARM: zynq: Reserve not DMAable space in front of the kernel")
Signed-off-by: Kyle Roeschley <kyle.roeschley@ni.com>
Tested-by: Nathan Rossi <nathan@nathanrossi.com>
commit e413bd33ac44b6d0bebc0ef2ac19cbe7558a7303 upstream.
In the device-tree case, the root interrupt controller cannot be
accessed through the 6th coprocessor, contrary to pxa27x and pxa3xx
architectures.
Fix it to behave as in non-devicetree builds.
Fixes: 32f17997c130 ("ARM: pxa: remove irq init from dt machines")
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 4f24450c6e580ac8591942c8bf65355a06b44635 upstream.
bcm2837-rpi-3-b.dts, its only in-tree user, was overriding it as
"brcm,bcm2837" already.
Fixes: 9d56c22a7861 ("ARM: bcm2835: Add devicetree for the Raspberry Pi 3.")
Cc: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Andreas Färber <afaerber@suse.de>
Signed-off-by: Eric Anholt <eric@anholt.net>
commit a44e87b47148c6ee6b78509f47e6a15c0fae890a upstream.
We are incorrectly defining the pwr LED, attaching it to a gpio line
that is wired to the Wi-Fi SDIO module (which fails due to this).
The actual power LED is connected to the GPIO expander, which we don't
expose currently.
Thanks-to: Eric Anholt <eric@anholt.net> [for clarifying we can't control the LED]
Signed-off-by: Andrea Merello <andrea.merello@gmail.com>
commit a3207d644fb89e5d7d5e01f00c04dcfc6d2d44d5 upstream.
The devicetree node for mt8173-auxadc lacks the clock and
io-channel-cells property. This leads to a non-working driver.
mt6577-auxadc 11001000.auxadc: failed to get auxadc clock
mt6577-auxadc: probe of 11001000.auxadc failed with error -2
Fix these fields to get the device up and running.
Fixes: 748c7d4de46a ("ARM64: dts: mt8173: Add thermal/auxadc device
nodes")
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
commit 5da889c795b1fbefc9d8f058b54717ab8ab17891 upstream.
The virtio tools implementation of READ_ONCE() has a single parameter called
'var', but erroneously refers to 'val' for its cast, and thus won't work unless
there's a variable of the correct type that happens to be called 'var'.
Fix this with s/var/val/, making READ_ONCE() work as expected regardless.
Fixes: a7c490333df3cff5 ("tools/virtio: use virt_xxx barriers")
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: virtualization@lists.linux-foundation.org
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Reviewed-by: Jason Wang <jasowang@redhat.com>
commit 8ae679c4bc2ea2d16d92620da8e3e9332fa4039f upstream.
I am getting the following warning when I build kernel 4.9-git on my
PowerBook G4 with a 32-bit PPC processor:
AS arch/powerpc/kernel/misc_32.o
arch/powerpc/kernel/misc_32.S:299:7: warning: "CONFIG_FSL_BOOKE" is not defined [-Wundef]
This problem is evident after commit 989cea5c14be ("kbuild: prevent
lib-ksyms.o rebuilds"); however, this change in kbuild only exposes an
error that has been in the code since 2005 when this source file was
created. That was with commit 9994a33865f4 ("powerpc: Introduce
entry_{32,64}.S, misc_{32,64}.S, systbl.S").
The offending line does not make a lot of sense. This error does not
seem to cause any errors in the executable, thus I am not recommending
that it be applied to any stable versions.
Thanks to Nicholas Piggin for suggesting this solution.
Fixes: 9994a33865f4 ("powerpc: Introduce entry_{32,64}.S, misc_{32,64}.S, systbl.S")
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
commit 6a2a2f45560a9cb7bc49820883b042e44f83726c upstream.
This module has a bug not to return error code in a case that data
structure for transmitted packets fails to be initialized.
This commit fixes the bug.
Fixes: 35efa5c489de ("ALSA: firewire-tascam: add streaming functionality")
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
commit 1ebb71143758f45dc0fa76e2f48429e13b16d110 upstream.
Make sure we have enough of a report structure to validate before
looking at it.
Reported-by: Benoit Camredon <benoit.camredon@airbus.com>
Tested-by: Benoit Camredon <benoit.camredon@airbus.com>
[ Upstream commit 24c63bbc18e25d5d8439422aa5fd2d66390b88eb ]
Frank reported that vrf devices can be created with a table id of 0.
This breaks many of the run time table id checks and should not be
allowed. Detect this condition at create time and fail with EINVAL.
Fixes: 193125dbd8eb ("net: Introduce VRF device driver")
Reported-by: Frank Kellermann <frank.kellermann@atos.net>
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
[ Upstream commit 7a18c5b9fb31a999afc62b0e60978aa896fc89e9 ]
fib_select_path does not call fib_select_multipath if oif is set in the
flow struct. For VRF use cases oif is always set, so multipath route
selection is bypassed. Use the FLOWI_FLAG_SKIP_NH_OIF to skip the oif
check similar to what is done in fib_table_lookup.
Add saddr and proto to the flow struct for the fib lookup done by the
VRF driver to better match hash computation for a flow.
Fixes: 613d09b30f8b ("net: Use VRF device index for lookups on TX")
[ Upstream commit 0bbcc0a8fc394d01988fe0263ccf7fddb77a12c3 ]
When trying to do interface down or changing interface configuration
under heavy traffic, some of the adaptive moderation corner cases can
occur and leave a WARN_ONCE call trace in the kernel log.
Those WARN_ONCE are meant for debug only, and should have been inserted
only under debug. We avoid such call traces by removing those WARN_ONCE.
Fixes: cb3c7fd4f839 ("net/mlx5e: Support adaptive RX coalescing")
Signed-off-by: Gil Rockah <gilr@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit 57ea52a865144aedbcd619ee0081155e658b6f7d ]
The GRO fast path caches the frag0 address. This address becomes
invalid if frag0 is modified by pskb_may_pull or its variants.
So whenever that happens we must disable the frag0 optimization.
This is usually done through the combination of gro_header_hard
and gro_header_slow, however, the IPv6 extension header path did
the pulling directly and would continue to use the GRO fast path
incorrectly.
This patch fixes it by disabling the fast path when we enter the
IPv6 extension header path.
Fixes: 78a478d0efd9 ("gro: Inline skb_gro_header and cache frag0 virtual address")
Reported-by: Slava Shwartsman <slavash@mellanox.com>
[ Upstream commit 7cfd5fd5a9813f1430290d20c0fead9b4582a307 ]
On 32bit arches, (skb->end - skb->data) is not 'unsigned int',
so we shall use min_t() instead of min() to avoid a compiler error.
Fixes: 1272ce87fa01 ("gro: Enter slow-path if there is no tailroom")
Reported-by: kernel test robot <fengguang.wu@intel.com>
[ Upstream commit 1272ce87fa017ca4cf32920764d879656b7a005a ]
The GRO path has a fast-path where we avoid calling pskb_may_pull
and pskb_expand by directly accessing frag0. However, this should
only be done if we have enough tailroom in the skb as otherwise
we'll have to expand it later anyway.
This patch adds the check by capping frag0_len with the skb tailroom.
Fixes: cb18978cbf45 ("gro: Open-code final pskb_may_pull")
[ Upstream commit 5d722b3024f6762addb8642ffddc9f275b5107ae ]
Commit bdabad3e363d ("net: Add Qualcomm IPC router") introduced a
new address family. Update the family name tables accordingly so
that the lockdep initialization can use the proper names for this
family.
Cc: Courtney Cavin <courtney.cavin@sonymobile.com>
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Suman Anna <s-anna@ti.com>
[ Upstream commit faf3a932fbeb77860226a8323eacb835edc98648 ]
It is perfectly possible to have non zero indexed switches being present
in a DSA switch tree, in such a case, we will be deferencing a NULL
pointer while dsa_cpu_port_ethtool_{setup,restore}. Be more defensive
and ensure that dst->ds[0] is valid before doing anything with it.
Fixes: 0c73c523cf73 ("net: dsa: Initialize CPU port ethtool ops per tree")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
[ Upstream commit 75dc692eda114cb234a46cb11893a9c3ea520934 ]
Pause the rx and make sure the rx fifo is empty when the autosuspend
occurs.
If the rx data comes when the driver is canceling the rx urb, the host
controller would stop getting the data from the device and continue
it after next rx urb is submitted. That is, one continuing data is
split into two different urb buffers. That let the driver take the
data as a rx descriptor, and unexpected behavior happens.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
[ Upstream commit 8fb280616878b81c0790a0c33acbeec59c5711f4 ]
Split rtl8152_suspend() into rtl8152_system_suspend() and
rtl8152_rumtime_suspend().
[ Upstream commit 2cfe8f8290bd28cf1ee67db914a6e76cf8e6437b ]
We are implementing a MDIO bus which is behind another one, so use the
nested version of the accessors to get lockdep annotations correct.
Fixes: 461cd1b03e32 ("net: dsa: bcm_sf2: Register our slave MDIO bus")
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit a4c61b92b3a4cbda35bb0251a5063a68f0861b2c ]
We make the bcm_sf2 driver override ds->ops which points to
b53_switch_ops since b53_switch_alloc() did the assignent. This is all
well and good until a second b53 switch comes in, and ends up using the
bcm_sf2 operations. Make a proper local copy, substitute the ds->ops
pointer and then override the operations.
Fixes: f458995b9ad8 ("net: dsa: bcm_sf2: Utilize core B53 driver when possible")
[ Upstream commit 9d5ecb09d525469abd1a10c096cb5a17206523f2 ]
If after too many passes still no image could be emitted, then
swap back to the original program as we do in all other cases
and don't use the one with blinding.
Fixes: 959a75791603 ("bpf, x86: add support for constant blinding")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 926d93a33e59b2729afdbad357233c17184de9d2 ]
The move from rx-handler to L3 receive handler inadvertantly dropped the
rx counters. Restore them.
Fixes: 74b20582ac38 ("net: l3mdev: Add hook in ip and ipv6")
Reported-by: Dinesh Dutt <ddutt@cumulusnetworks.com>
[ Upstream commit 5350d54f6cd12eaff623e890744c79b700bd3f17 ]
In the case of custom rules being present we need to handle the case of the
LOCAL table being intialized after the new rule has been added. To address
that I am adding a new check so that we can make certain we don't use an
alias of MAIN for LOCAL when allocating a new table.
Fixes: 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse")
Reported-by: Oliver Brunel <jjk@jjacky.com>
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit 7ababb782690e03b78657e27bd051e20163af2d6 ]
5.2. Action on Reception of a Query
When a system receives a Query, it does not respond immediately.
Instead, it delays its response by a random amount of time, bounded
by the Max Resp Time value derived from the Max Resp Code in the
received Query message. A system may receive a variety of Queries on
different interfaces and of different kinds (e.g., General Queries,
Group-Specific Queries, and Group-and-Source-Specific Queries), each
of which may require its own delayed response.
Before scheduling a response to a Query, the system must first
consider previously scheduled pending responses and in many cases
schedule a combined response. Therefore, the system must be able to
maintain the following state:
o A timer per interface for scheduling responses to General Queries.
o A per-group and interface timer for scheduling responses to Group-
Specific and Group-and-Source-Specific Queries.
o A per-group and interface list of sources to be reported in the
response to a Group-and-Source-Specific Query.
When a new Query with the Router-Alert option arrives on an
interface, provided the system has state to report, a delay for a
response is randomly selected in the range (0, [Max Resp Time]) where
Max Resp Time is derived from Max Resp Code in the received Query
message. The following rules are then used to determine if a Report
needs to be scheduled and the type of Report to schedule. The rules
are considered in order and only the first matching rule is applied.
1. If there is a pending response to a previous General Query
scheduled sooner than the selected delay, no additional response
needs to be scheduled.
2. If the received Query is a General Query, the interface timer is
used to schedule a response to the General Query after the
selected delay. Any previously pending response to a General
Query is canceled.
--8<--
Currently the timer is rearmed with new random expiration time for
every incoming query regardless of possibly already pending report.
Which is not aligned with the above RFE.
It also might happen that higher rate of incoming queries can
postpone the report after the expiration time of the first query
causing group membership loss.
Now the per interface general query timer is rearmed only
when there is no pending report already scheduled on that interface or
the newly selected expiration time is before the already pending
scheduled report.
Signed-off-by: Michal Tesar <mtesar@redhat.com>
[ Upstream commit d0af683407a26a4437d8fa6e283ea201f2ae8146 ]
__skb_flow_dissect can be called with a skb or a data packet, either
can be NULL. All calls seems to have been moved to __skb_header_pointer
except the pptp handling which is still calling skb_header_pointer.
skb_header_pointer will use skb->data and thus:
[ 109.556866] BUG: unable to handle kernel NULL pointer dereference at 0000000000000080
[ 109.557102] IP: [<ffffffff88dc02f8>] __skb_flow_dissect+0xa88/0xce0
[ 109.557263] PGD 0
[ 109.557338]
[ 109.557484] Oops: 0000 [#1] SMP
[ 109.557562] Modules linked in: chaoskey
[ 109.557783] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.9.0 #79
[ 109.557867] Hardware name: Supermicro A1SRM-LN7F/LN5F/A1SRM-LN7F-2758, BIOS 1.0c 11/04/2015
[ 109.557957] task: ffff94085c27bc00 task.stack: ffffb745c0068000
[ 109.558041] RIP: 0010:[<ffffffff88dc02f8>] [<ffffffff88dc02f8>] __skb_flow_dissect+0xa88/0xce0
[ 109.558203] RSP: 0018:ffff94087fc83d40 EFLAGS: 00010206
[ 109.558286] RAX: 0000000000000130 RBX: ffffffff8975bf80 RCX: ffff94084fab6800
[ 109.558373] RDX: 0000000000000010 RSI: 000000000000000c RDI: 0000000000000000
[ 109.558460] RBP: 0000000000000b88 R08: 0000000000000000 R09: 0000000000000022
[ 109.558547] R10: 0000000000000008 R11: ffff94087fc83e04 R12: 0000000000000000
[ 109.558763] R13: ffff94084fab6800 R14: ffff94087fc83e04 R15: 000000000000002f
[ 109.558979] FS: 0000000000000000(0000) GS:ffff94087fc80000(0000) knlGS:0000000000000000
[ 109.559326] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 109.559539] CR2: 0000000000000080 CR3: 0000000281809000 CR4: 00000000001026e0
[ 109.559753] Stack:
[ 109.559957] 000000000000000c ffff94084fab6822 0000000000000001 ffff94085c2b5fc0
[ 109.560578] 0000000000000001 0000000000002000 0000000000000000 0000000000000000
[ 109.561200] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 109.561820] Call Trace:
[ 109.562027] <IRQ>
[ 109.562108] [<ffffffff88dfb4fa>] ? eth_get_headlen+0x7a/0xf0
[ 109.562522] [<ffffffff88c5a35a>] ? igb_poll+0x96a/0xe80
[ 109.562737] [<ffffffff88dc912b>] ? net_rx_action+0x20b/0x350
[ 109.562953] [<ffffffff88546d68>] ? __do_softirq+0xe8/0x280
[ 109.563169] [<ffffffff8854704a>] ? irq_exit+0xaa/0xb0
[ 109.563382] [<ffffffff8847229b>] ? do_IRQ+0x4b/0xc0
[ 109.563597] [<ffffffff8902d4ff>] ? common_interrupt+0x7f/0x7f
[ 109.563810] <EOI>
[ 109.563890] [<ffffffff88d57530>] ? cpuidle_enter_state+0x130/0x2c0
[ 109.564304] [<ffffffff88d57520>] ? cpuidle_enter_state+0x120/0x2c0
[ 109.564520] [<ffffffff8857eacf>] ? cpu_startup_entry+0x19f/0x1f0
[ 109.564737] [<ffffffff8848d55a>] ? start_secondary+0x12a/0x140
[ 109.564950] Code: 83 e2 20 a8 80 0f 84 60 01 00 00 c7 04 24 08 00
00 00 66 85 d2 0f 84 be fe ff ff e9 69 fe ff ff 8b 34 24 89 f2 83 c2
04 66 85 c0 <41> 8b 84 24 80 00 00 00 0f 49 d6 41 8d 31 01 d6 41 2b 84
24 84
[ 109.569959] RIP [<ffffffff88dc02f8>] __skb_flow_dissect+0xa88/0xce0
[ 109.570245] RSP <ffff94087fc83d40>
[ 109.570453] CR2: 0000000000000080
Fixes: ab10dccb1160 ("rps: Inspect PPTP encapsulated by GRE to get flow hash")
Signed-off-by: Ian Kumlien <ian.kumlien@gmail.com>
[ Upstream commit 3b48ab2248e61408910e792fe84d6ec466084c1a ]
Final nlmsg_len field update must reflect inserted net_dm_drop_point
data.
This patch depends on previous patch:
"drop_monitor: add missing call to genlmsg_end"
Signed-off-by: Reiter Wolfgang <wr0112358@gmail.com>
[ Upstream commit 4200462d88f47f3759bdf4705f87e207b0f5b2e4 ]
Update nlmsg_len field with genlmsg_end to enable userspace processing
using nlmsg_next helper. Also adds error handling.
[ Upstream commit f5a0aab84b74de68523599817569c057c7ac1622 ]
IPv4 output routes already use l3mdev device instead of loopback for dst's
if it is applicable. Change local input routes to do the same.
This fixes icmp responses for unreachable UDP ports which are directed
to the wrong table after commit 9d1a6c4ea43e4 because local_input
routes use the loopback device. Moving from ingress device to loopback
loses the L3 domain causing responses based on the dst to get to lost.
Fixes: 9d1a6c4ea43e4 ("net: icmp_route_lookup should use rt dev to
determine L3 domain")
[ Upstream commit f0c16ba8933ed217c2688b277410b2a37ba81591 ]
When we send a packet for our own local address on a non-loopback
interface (e.g. eth0), due to the change had been introduced from
commit 0b922b7a829c ("net: original ingress device index in PKTINFO"), the
original ingress device index would be set as the loopback interface.
However, the packet should be considered as if it is being arrived via the
sending interface (eth0), otherwise it would break the expectation of the
userspace application (e.g. the DHCPRELEASE message from dhcp_release
binary would be ignored by the dnsmasq daemon, since it come from lo which
is not the interface dnsmasq bind to)
Fixes: 0b922b7a829c ("net: original ingress device index in PKTINFO")
Acked-by: David Ahern <dsa@cumulusnetworks.com>
Signed-off-by: Wei Zhang <asuka.com@163.com>
[ Upstream commit 4775cc1f2d5abca894ac32774eefc22c45347d1c ]
We miss to check if the netlink message is actually big enough to contain
a struct if_stats_msg.
Add a check to prevent userland from sending us short messages that would
make us access memory beyond the end of the message.
Fixes: 10c9ead9f3c6 ("rtnetlink: add new RTM_GETSTATS message to dump...")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Roopa Prabhu <roopa@cumulusnetworks.com>
[ Upstream commit 37f304d10030bb425c19099e7b955d9c3ec4cba3 ]
Disable netdev should come after it was closed, although no harm of doing it
before -hence the MLX5E_STATE_DESTROYING bit- but it is more natural this way.
Fixes: 26e59d8077a3 ("net/mlx5e: Implement mlx5e interface attach/detach callbacks")
Reviewed-by: Mohamad Haj Yahia <mohamad@mellanox.com>
[ Upstream commit 610e89e05c3f28a7394935aa6b91f99548c4fd3c ]
Skip setting netdev vxlan ports and netdev rx_mode on driver load
when netdev is not yet registered.
Synchronizing with netdev state is needed only on reset flow where the
netdev remains registered for the whole reset period.
This also fixes an access before initialization of net_device.addr_list_lock
- which for some reason initialized on register_netdev - where we queued
set_rx_mode work on driver load before netdev registration.
Reported-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
[ Upstream commit ccce1700263d8b5b219359d04180492a726cea16 ]
Need to check that VF mac address entered by the admin user is either
zero or unicast mac.
Multicast mac addresses are prohibited.
Fixes: 77256579c6b4 ('net/mlx5: E-Switch, Introduce Vport administration functions')
Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com>
[ Upstream commit 077b1e8069b9b74477b01d28f6b83774dc19a142 ]
We need to mask the destination mac value with the destination mac
mask when adding steering rule via ethtool.
Fixes: 1174fce8d1410 ('net/mlx5e: Support l3/l4 flow type specs in ethtool flow steering')
Signed-off-by: Maor Gottlieb <maorg@mellanox.com>
[ Upstream commit d151d73dcc99de87c63bdefebcc4cb69de1cdc40 ]
Avoid using a local variable named numa_node to avoid shadowing a public
one.
Fixes: db058a186f98 ('net/mlx5_core: Set irq affinity hints')
Signed-off-by: Eli Cohen <eli@mellanox.com>
