commit 89affbf5d9ebb15c6460596822e8857ea2f9e735 upstream.
In codepaths that use the begin/retry interface for reading
mems_allowed_seq with irqs disabled, there exists a race condition that
stalls the patch process after only modifying a subset of the
static_branch call sites.
This problem manifested itself as a deadlock in the slub allocator,
inside get_any_partial. The loop reads mems_allowed_seq value (via
read_mems_allowed_begin), performs the defrag operation, and then
verifies the consistency of mem_allowed via the read_mems_allowed_retry
and the cookie returned by xxx_begin.
The issue here is that both begin and retry first check if cpusets are
enabled via cpusets_enabled() static branch. This branch can be
rewritted dynamically (via cpuset_inc) if a new cpuset is created. The
x86 jump label code fully synchronizes across all CPUs for every entry
it rewrites. If it rewrites only one of the callsites (specifically the
one in read_mems_allowed_retry) and then waits for the
smp_call_function(do_sync_core) to complete while a CPU is inside the
begin/retry section with IRQs off and the mems_allowed value is changed,
we can hang.
This is because begin() will always return 0 (since it wasn't patched
yet) while retry() will test the 0 against the actual value of the seq
counter.
The fix is to use two different static keys: one for begin
(pre_enable_key) and one for retry (enable_key). In cpuset_inc(), we
first bump the pre_enable key to ensure that cpuset_mems_allowed_begin()
always return a valid seqcount if are enabling cpusets. Similarly, when
disabling cpusets via cpuset_dec(), we first ensure that callers of
cpuset_mems_allowed_retry() will start ignoring the seqcount value
before we let cpuset_mems_allowed_begin() return 0.
The relevant stack traces of the two stuck threads:
CPU: 1 PID: 1415 Comm: mkdir Tainted: G L 4.9.36-00104-g540c51286237 #4
Hardware name: Default string Default string/Hardware, BIOS 4.29.1-20170526215256 05/26/2017
task: ffff8817f9c28000 task.stack: ffffc9000ffa4000
RIP: smp_call_function_many+0x1f9/0x260
Call Trace:
smp_call_function+0x3b/0x70
on_each_cpu+0x2f/0x90
text_poke_bp+0x87/0xd0
arch_jump_label_transform+0x93/0x100
__jump_label_update+0x77/0x90
jump_label_update+0xaa/0xc0
static_key_slow_inc+0x9e/0xb0
cpuset_css_online+0x70/0x2e0
online_css+0x2c/0xa0
cgroup_apply_control_enable+0x27f/0x3d0
cgroup_mkdir+0x2b7/0x420
kernfs_iop_mkdir+0x5a/0x80
vfs_mkdir+0xf6/0x1a0
SyS_mkdir+0xb7/0xe0
entry_SYSCALL_64_fastpath+0x18/0xad
CPU: 2 PID: 1 Comm: init Tainted: G L 4.9.36-00104-g540c51286237 #4
task: ffff8818087c0000 task.stack: ffffc90000030000
RIP: int3+0x39/0x70
Call Trace:
<#DB> ? ___slab_alloc+0x28b/0x5a0
<EOE> ? copy_process.part.40+0xf7/0x1de0
__slab_alloc.isra.80+0x54/0x90
kmem_cache_alloc_node+0x8a/0x280
_do_fork+0xe7/0x6c0
_raw_spin_unlock_irq+0x2d/0x60
trace_hardirqs_on_caller+0x136/0x1d0
entry_SYSCALL_64_fastpath+0x5/0xad
do_syscall_64+0x27/0x350
SyS_clone+0x19/0x20
do_syscall_64+0x60/0x350
entry_SYSCALL64_slow_path+0x25/0x25
Link: http://lkml.kernel.org/r/20170731040113.14197-1-dmitriyz@waymo.com
Fixes: 46e700abc44c ("mm, page_alloc: remove unnecessary taking of a seqlock when cpusets are disabled")
Signed-off-by: Dima Zavin <dmitriyz@waymo.com>
Reported-by: Cliff Spradlin <cspradlin@waymo.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christopher Lameter <cl@linux.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
leaving stale TLB entries
commit 3ea277194daaeaa84ce75180ec7c7a2075027a68 upstream.
Nadav Amit identified a theoritical race between page reclaim and
mprotect due to TLB flushes being batched outside of the PTL being held.
He described the race as follows:
CPU0 CPU1
user accesses memory using RW PTE
[PTE now cached in TLB]
try_to_unmap_one()
==> ptep_get_and_clear()
==> set_tlb_ubc_flush_pending()
mprotect(addr, PROT_READ)
==> change_pte_range()
==> [ PTE non-present - no flush ]
user writes using cached RW PTE
try_to_unmap_flush()
The same type of race exists for reads when protecting for PROT_NONE and
also exists for operations that can leave an old TLB entry behind such
as munmap, mremap and madvise.
For some operations like mprotect, it's not necessarily a data integrity
issue but it is a correctness issue as there is a window where an
mprotect that limits access still allows access. For munmap, it's
potentially a data integrity issue although the race is massive as an
munmap, mmap and return to userspace must all complete between the
window when reclaim drops the PTL and flushes the TLB. However, it's
theoritically possible so handle this issue by flushing the mm if
reclaim is potentially currently batching TLB flushes.
Other instances where a flush is required for a present pte should be ok
as either the page lock is held preventing parallel reclaim or a page
reference count is elevated preventing a parallel free leading to
corruption. In the case of page_mkclean there isn't an obvious path
that userspace could take advantage of without using the operations that
are guarded by this patch. Other users such as gup as a race with
reclaim looks just at PTEs. huge page variants should be ok as they
don't race with reclaim. mincore only looks at PTEs. userfault also
should be ok as if a parallel reclaim takes place, it will either fault
the page back in or read some of the data before the flush occurs
triggering a fault.
Note that a variant of this patch was acked by Andy Lutomirski but this
was for the x86 parts on top of his PCID work which didn't make the 4.13
merge window as expected. His ack is dropped from this version and
there will be a follow-on patch on top of PCID that will include his
ack.
[akpm@linux-foundation.org: tweak comments]
[akpm@linux-foundation.org: fix spello]
Link: http://lkml.kernel.org/r/20170717155523.emckq2esjro6hf3z@suse.de
Reported-by: Nadav Amit <nadav.amit@gmail.com>
commit 773dc118756b1f38766063e90e582016be868f09 upstream.
HS400-ES devices fail to initialize with the following error messages.
mmc1: power class selection to bus width 8 ddr 0 failed
mmc1: error -110 whilst initialising MMC card
This was seen on Samsung Chromebook Plus. Code analysis points to
commit 3d4ef329757c ("mmc: core: fix multi-bit bus width without
high-speed mode"), which attempts to set the bus width for all but
HS200 devices unconditionally. However, for HS400-ES, the bus width
is already selected.
Cc: Anssi Hannula <anssi.hannula@bitwise.fi>
Cc: Douglas Anderson <dianders@chromium.org>
Cc: Brian Norris <briannorris@chromium.org>
Fixes: 3d4ef329757c ("mmc: core: fix multi-bit bus width ...")
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Shawn Lin <shawn.lin@rock-chip.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit e44bb0cbdc88686c21e2175a990b40bf6db5d005 upstream.
The function to obtain a fwnode related to a struct device is useful for
drivers that use the fwnode property API: it allows not being aware of the
underlying firmware implementation.
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
commit 7a1e3f143176e8ebdb2f5a9b3b47abc18b879d90 upstream.
When the device is non removable, the card detect signal is often used
for another purpose i.e. muxed to another SoC peripheral or used as a
GPIO. It could lead to wrong behaviors depending the default value of
this signal if not muxed to the SDHCI controller.
Fixes: bb5f8ea4d514 ("mmc: sdhci-of-at91: introduce driver for the Atmel SDMMC")
Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
commit fd40559c8657418385e42f797e0b04bfc0add748 upstream.
The verifier is allocated on the stack, but the EXCHANGE_ID RPC call was
changed to be asynchronous by commit 8d89bd70bc939. If we interrrupt
the call to rpc_wait_for_completion_task(), we can therefore end up
transmitting random stack contents in lieu of the verifier.
Fixes: 8d89bd70bc939 ("NFS setup async exchange_id")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 5f5d03143de5e0c593da4ab18fc6393c2815e108 upstream.
Due to a bugfix in wireless tree and the commit mentioned below a merge
was needed which went haywire. So the submitted change resulted in the
function brcmf_sdiod_sgtable_alloc() being called twice during the probe
thus leaking the memory of the first call.
Fixes: 4d7928959832 ("brcmfmac: switch to new platform data")
Reported-by: Stefan Wahren <stefan.wahren@i2se.com>
Tested-by: Stefan Wahren <stefan.wahren@i2se.com>
Reviewed-by: Hante Meuleman <hante.meuleman@broadcom.com>
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 0b0f934e92a8eaed2e6c48a50eae6f84661f74f3 upstream.
iwlagn_check_ratid_empty takes the tid as a parameter, but
it doesn't check that it is not IWL_TID_NON_QOS.
Since IWL_TID_NON_QOS = 8 and iwl_priv::tid_data is an array
with 8 entries, accessing iwl_priv::tid_data[IWL_TID_NON_QOS]
is a bad idea.
This happened in iwlagn_rx_reply_tx. Since
iwlagn_check_ratid_empty is relevant only to check whether
we can open A-MPDU, this flow is irrelevant if tid is
IWL_TID_NON_QOS. Call iwlagn_check_ratid_empty only inside
the
if (tid != IWL_TID_NON_QOS)
a few lines earlier in the function.
Reported-by: Seraphime Kirkovski <kirkseraph@gmail.com>
Tested-by: Seraphime Kirkovski <kirkseraph@gmail.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
commit 5c0338c68706be53b3dc472e4308961c36e4ece1 upstream.
The combination of WQ_UNBOUND and max_active == 1 used to imply
ordered execution. After NUMA affinity 4c16bd327c74 ("workqueue:
implement NUMA affinity for unbound workqueues"), this is no longer
true due to per-node worker pools.
While the right way to create an ordered workqueue is
alloc_ordered_workqueue(), the documentation has been misleading for a
long time and people do use WQ_UNBOUND and max_active == 1 for ordered
workqueues which can lead to subtle bugs which are very difficult to
trigger.
It's unlikely that we'd see noticeable performance impact by enforcing
ordering on WQ_UNBOUND / max_active == 1 workqueues. Let's
automatically set __WQ_ORDERED for those workqueues.
Reported-by: Christoph Hellwig <hch@infradead.org>
Reported-by: Alexei Potashnik <alexei@purestorage.com>
Fixes: 4c16bd327c74 ("workqueue: implement NUMA affinity for unbound workqueues")
commit 59a5e266c3f5c1567508888dd61a45b86daed0fa upstream.
My static checker complains that "devno" can be negative, meaning that
we read before the start of the loop. I've looked at the code, and I
think the warning is right. This come from /proc so it's root only or
it would be quite a quite a serious bug. The call tree looks like this:
proc_scsi_write() <- gets id and channel from simple_strtoul()
-> scsi_add_single_device() <- calls shost->transportt->user_scan()
-> ata_scsi_user_scan()
-> ata_find_dev()
commit 3c74541777302eec43a0d1327c4d58b8659a776b upstream.
While refactoring, f7b2814bb9b6 ("cgroup: factor out
cgroup_{apply|finalize}_control() from
cgroup_subtree_control_write()") broke error return value from the
function. The return value from the last operation is always
overridden to zero. Fix it.
commit 7af608e4f9530372aec6e940552bf76595f2e265 upstream.
On subsystem registration, css_populate_dir() is not called on the new
root css, so the interface files for the subsystem on cgrp_dfl_root
aren't created on registration. This is a residue from the days when
cgrp_dfl_root was used only as the parking spot for unused subsystems,
which no longer is true as it's used as the root for cgroup2.
This is often fine as later operations tend to create them as a part
of mount (cgroup1) or subtree_control operations (cgroup2); however,
it's not difficult to mount cgroup2 with the controller interface
files missing as Waiman found out.
Fix it by invoking css_populate_dir() on the root css on subsys
registration.
Reported-and-tested-by: Waiman Long <longman@redhat.com>
commit 13d57093c141db2036364d6be35e394fc5b64728 upstream.
In testing James' patch to drivers/parisc/pdc_stable.c, I hit the BUG
statement in flush_cache_range() during a system shutdown:
kernel BUG at arch/parisc/kernel/cache.c:595!
CPU: 2 PID: 6532 Comm: kworker/2:0 Not tainted 4.13.0-rc2+ #1
Workqueue: events free_ioctx
IAOQ[0]: flush_cache_range+0x144/0x148
IAOQ[1]: flush_cache_page+0x0/0x1a8
RP(r2): flush_cache_range+0xec/0x148
Backtrace:
[<00000000402910ac>] unmap_page_range+0x84/0x880
[<00000000402918f4>] unmap_single_vma+0x4c/0x60
[<0000000040291a18>] zap_page_range_single+0x110/0x160
[<0000000040291c34>] unmap_mapping_range+0x174/0x1a8
[<000000004026ccd8>] truncate_pagecache+0x50/0xa8
[<000000004026cd84>] truncate_setsize+0x54/0x70
[<000000004033d534>] put_aio_ring_file+0x44/0xb0
[<000000004033d5d8>] aio_free_ring+0x38/0x140
[<000000004033d714>] free_ioctx+0x34/0xa8
[<00000000401b0028>] process_one_work+0x1b8/0x4d0
[<00000000401b04f4>] worker_thread+0x1b4/0x648
[<00000000401b9128>] kthread+0x1b0/0x208
[<0000000040150020>] end_fault_vector+0x20/0x28
[<0000000040639518>] nf_ip_reroute+0x50/0xa8
[<0000000040638ed0>] nf_ip_route+0x10/0x78
[<0000000040638c90>] xfrm4_mode_tunnel_input+0x180/0x1f8
Backtrace:
[<0000000040163bf0>] show_stack+0x20/0x38
[<0000000040688480>] dump_stack+0xa8/0x120
[<0000000040163dc4>] die_if_kernel+0x19c/0x2b0
[<0000000040164d0c>] handle_interruption+0xa24/0xa48
This patch modifies flush_cache_range() to handle non current contexts.
In as much as this occurs infrequently, the simplest approach is to
flush the entire cache when this happens.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: Helge Deller <deller@gmx.de>
[ Upstream commit 9f169b9f52a4afccdab7a7d2311b0c53a78a1e6b ]
When multiple front-ends are using the same back-end, putting state of a
front-end to STOP state upon receiving pause command will result in backend
stream getting released by DPCM framework unintentionally. In order to
avoid backend to be released when another active front-end stream is
present, put the stream state to PAUSED state instead of STOP state.
Signed-off-by: Patrick Lai <plai@codeaurora.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit bc65a326c579e93a5c2120a65ede72f11369ee5a ]
Saved firmware ctx was not never released, so release Firmware
ctx in cleanup routine.
Signed-off-by: Jeeja KP <jeeja.kp@intel.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 2d1148f0f45079d25a0fa0d67e4fdb2a656d12fb ]
bna & bfa firmware version 3.2.5.1 was submitted to linux-firmware on
Feb 17 19:10:20 2015 -0500 in 0ab54ff1dc ("linux-firmware: Add QLogic BR
Series Adapter Firmware").
bna was updated to use the newer firmware on Feb 19 16:02:32 2015 -0500 in
3f307c3d70 ("bna: Update the Driver and Firmware Version")
bfa was not updated. I presume this was an oversight but it broke support
for bfa+bna cards such as the following
04:00.0 Fibre Channel [0c04]: Brocade Communications Systems, Inc.
1010/1020/1007/1741 10Gbps CNA [1657:0014] (rev 01)
04:00.1 Fibre Channel [0c04]: Brocade Communications Systems, Inc.
04:00.2 Ethernet controller [0200]: Brocade Communications Systems,
Inc. 1010/1020/1007/1741 10Gbps CNA [1657:0014] (rev 01)
04:00.3 Ethernet controller [0200]: Brocade Communications Systems,
Currently, if the bfa module is loaded first, bna fails to probe the
respective devices with
[ 215.026787] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[ 215.043707] bna 0000:04:00.2: bar0 mapped to ffffc90001fc0000, len 262144
[ 215.060656] bna 0000:04:00.2: initialization failed err=1
[ 215.073893] bna 0000:04:00.3: bar0 mapped to ffffc90002040000, len 262144
[ 215.090644] bna 0000:04:00.3: initialization failed err=1
Whereas if bna is loaded first, bfa fails with
[ 249.592109] QLogic BR-series BFA FC/FCOE SCSI driver - version: 3.2.25.0
[ 249.610738] bfa 0000:04:00.0: Running firmware version is incompatible with the driver version
[ 249.833513] bfa 0000:04:00.0: bfa init failed
[ 249.833919] scsi host6: QLogic BR-series FC/FCOE Adapter, hwpath: 0000:04:00.0 driver: 3.2.25.0
[ 249.841446] bfa 0000:04:00.1: Running firmware version is incompatible with the driver version
[ 250.045449] bfa 0000:04:00.1: bfa init failed
[ 250.045962] scsi host7: QLogic BR-series FC/FCOE Adapter, hwpath: 0000:04:00.1 driver: 3.2.25.0
Increase bfa's requested firmware version. Also increase the driver
version. I only tested that all of the devices probe without error.
Reported-by: Tim Ehlers <tehlers@gwdg.de>
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
Acked-by: Rasesh Mody <rasesh.mody@cavium.com>
[ Upstream commit 0371adcdaca92912baaa3256ed13e058a016e62d ]
If a call to mempool_create_slab_pool() in snic_probe() returns NULL,
return -ENOMEM to indicate failure. mempool_creat_slab_pool() only fails
if it cannot allocate memory.
https://bugzilla.kernel.org/show_bug.cgi?id=189061
Reported-by: bianpan2010@ruc.edu.cn
Signed-off-by: Burak Ok <burak-kernel@bur0k.de>
Signed-off-by: Andreas Schaertl <andreas.schaertl@fau.de>
Acked-by: Narsimhulu Musini <nmusini@cisco.com>
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
[ Upstream commit 9698b6f473555a722bf81a3371998427d5d27bde ]
This fix is to avoid calling fnic_fw_reset_handler through
fnic_host_reset when a finc reset is alreay in progress.
Signed-off-by: Satish Kharat <satishkh@cisco.com>
Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com>
[ Upstream commit 08f9572671c8047e7234cbf150869aa3c3d59a97 ]
This headlamp contains a dummy HID descriptor which pretends to be
a mouse-like device, but can't be used as a mouse at all.
Reported-by: Lukas Ocilka <lukas.ocilka@suse.com>
[ Upstream commit 60448b077ed93d227e6c117a9e87db76ff0c1911 ]
Frequency value of zero did not make sense, use same 24.576MHz
setting and only change the clock source in idle mode
Suggested-by: Bard Liao <bardliao@realtek.com>
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
[ Upstream commit 74545f63890e38520eb4d1dbedcadaa9c0dbc824 ]
The conversion of Intel PMU drivers into modules did not include reference
counting. The machine will crash when attempting to access deleted code
if an event from a module PMU is started and the module removed before the
event is destroyed.
i.e. this crashes the machine:
$ insmod intel-rapl-perf.ko
$ perf stat -e power/energy-cores/ -C 0 &
$ rmmod intel-rapl-perf.ko
Set THIS_MODULE to pmu->module in Intel module PMUs so that generic code
can handle reference counting and deny rmmod while an event still exists.
Signed-off-by: David Carrillo-Cisneros <davidcc@google.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Kan Liang <kan.liang@intel.com>
Cc: Paul Turner <pjt@google.com>
Cc: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1482455860-116269-1-git-send-email-davidcc@google.com
[ Upstream commit 159d3726db12b3476bc59ea0ab0a702103d466b5 ]
The current implementation supports only Intel Merrifield platforms. Don't mess
with the rest of the Intel MID family by not registering device with wrong
properties.
Link: http://lkml.kernel.org/r/20170102092450.87229-1-andriy.shevchenko@linux.intel.com
[ Upstream commit 13a6c8328e6056932dc680e447d4c5e8ad9add17 ]
Testing EP_FLAG_RUNNING in snd_complete_urb() before running the completion
logic allows us to save a few cpu cycles by returning early, skipping the
pending urb in case the stream was stopped; the stop logic handles the urb
and sets the completion callbacks to NULL.
Signed-off-by: Ioan-Adrian Ratiu <adi@adirat.com>
[ Upstream commit e51d5d02f688c45b6f644f472f0c80fdfa73f0cb ]
It is necessary to call entry/exit functions for parent interrupt
controllers for proper masking/unmasking of interrupt lines.
Signed-off-by: Yuriy Kolerov <yuriy.kolerov@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
[ Upstream commit 71eae1ca77fd6be218d8a952d97bba827e56516d ]
The RX descriptor word 0 on SH7734 has the RFS[9:0] field in bits 16-25
(bits 0-15 usually used for that are occupied by the packet checksum).
Thus we need to set the 'shift_rd0' field in the SH7734 SoC data...
Fixes: f0e81fecd4f8 ("net: sh_eth: Add support SH7734")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 4ee437fbf626b5ad756889d8bc0fcead3d66dde7 ]
The fsl_ssi fifo watermark is by default set to 2 free spaces (i.e.
activate DMA on FIFO when only 2 spaces are left.) This means the
DMA must service the fifo within 2 audio samples, which is just not
enough time for many use cases with high data rate. In many
configurations the audio channel slips (causing l/r swap in stereo
configurations, or channel slipping in multi-channel configurations).
This patch gives more breathing room and allows the SSI to operate
reliably by changing the fifio refill watermark to 8.
There is no change in behavior for older chips (with an 8-deep fifo).
Only the newer chips with a 15-deep fifo get the new behavior. I
suspect a new fifo depth setting could be optimized on the older
chips too, but I have not tested.
Signed-off-by: Caleb Crome <caleb@crome.org>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
[ Upstream commit 63dfb0dac9055145db85ce764355aef2f563739a ]
The USB core may call reset_resume when it fails to resume asix device.
And USB core can recovery this abnormal resume at low level driver,
the same .resume at asix driver can work too. Add .reset_resume can
avoid disconnecting after backing from system resume, and NFS can
still be mounted after this commit.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
[ Upstream commit 14ba972842f9e84e6d3264bc0302101b8a792288 ]
All i.MX6 SoCs have an OCOTP Controller with 4kbit fuses. The i.MX6SL is
an exception and has only 2kbit fuses.
In the TRM for the i.MX6DQ (IMX6QDRM - Rev 2, 06/2014) the fuses size is
described in chapter 46.1.1 with:
"32-bit word restricted program and read to 4Kbits of eFuse OTP(512x8)."
In the TRM for the i.MX6SL (IMX6SLRM - Rev 2, 06/2015) the fuses size is
described in chapter 34.1.1 with:
"32-bit word restricted program and read to 2 kbit of eFuse OTP(128x8)."
Since the Freescale Linux kernel OCOTP driver works with a fuses size of
2 kbit for the i.MX6SL, it looks like the TRM is wrong and the formula
to calculate the correct fuses size has to be 256x8.
Signed-off-by: Daniel Schultz <d.schultz@phytec.de>
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
[ Upstream commit 6ef4fb387d50fa8f3bffdffc868b57e981cdd709 ]
Recent changes made KERN_CONT mandatory for continued lines. In the
absence of KERN_CONT, a newline may be implicit inserted by the core
printk code.
In show_pte, we (erroneously) use printk without KERN_CONT for continued
prints, resulting in output being split across a number of lines, and
not matching the intended output, e.g.
[ff000000000000] *pgd=00000009f511b003
, *pud=00000009f4a80003
, *pmd=0000000000000000
Fix this by using pr_cont() for all the continuations.
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
[ Upstream commit e19f32da5ded958238eac1bbe001192acef191a2 ]
Here, pci_iomap can fail, handle this case release selected
pci regions and return -ENOMEM.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit 4dcd19bfabaee8f9f4bcf203afba09b98ccbaf76 ]
Here, If devm_ioremap will fail. It will return NULL.
Kernel can run into a NULL-pointer dereference.
This error check will avoid NULL pointer dereference.
Acked-by: Yoichi Yuasa <yuasa@linux-mips.org>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ]
Markus reported that perf segfaults when reading /sys/kernel/notes from
a kernel linked with GNU gold, due to what looks like a gold bug, so do
some bounds checking to avoid crashing in that case.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 30a9c6444810429aa2b7cbfbd453ce339baaadbf ]
Those are binaries as well, so should be installed by:
make -C tools/perf install-bin'
too.
Cc: Daniel Bristot de Oliveira <bristot@redhat.com>
Link: http://lkml.kernel.org/n/tip-3841b37u05evxrs1igkyu6ks@git.kernel.org
commit 4c86d77743a54fb2d8a4d18a037a074c892bb3be upstream.
On IPv4-mapped IPv6 addresses sk_family is AF_INET6,
but the flow informations are created based on AF_INET.
So the routing set up 'struct flowi4' but we try to
access 'struct flowi6' what leads to an out of bounds
access. Fix this by using the family we get with the
dst_entry, like we do it for the standard policy lookup.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 074859184d770824f4437dca716bdeb625ae8b1c ]
Currently, the sched:sched_switch tracepoint reports deadline tasks with
priority -1. But when reading the trace via perf script I've got the
following output:
# ./d & # (d is a deadline task, see [1])
# perf record -e sched:sched_switch -a sleep 1
# perf script
swapper 0 [000] 2146.962441: sched:sched_switch: swapper/0:0 [120] R ==> d:2593 [4294967295]
d 2593 [000] 2146.972472: sched:sched_switch: d:2593 [4294967295] R ==> g:2590 [4294967295]
The task d reports the wrong priority [4294967295]. This happens because
the "int prio" is stored in an unsigned long long val. Although it is
set as a %lld, as int is shorter than unsigned long long,
trace_seq_printf prints it as a positive number.
The fix is just to cast the val as an int, and print it as a %d,
as in the sched:sched_switch tracepoint's "format".
The output with the fix is:
# ./d &
# perf script
swapper 0 [000] 4306.374037: sched:sched_switch: swapper/0:0 [120] R ==> d:10941 [-1]
d 10941 [000] 4306.383823: sched:sched_switch: d:10941 [-1] R ==> swapper/0:0 [120]
[1] d.c
#include <stdio.h>
#include <unistd.h>
#include <sys/syscall.h>
#include <linux/types.h>
#include <linux/sched.h>
struct sched_attr {
__u32 size, sched_policy;
__u64 sched_flags;
__s32 sched_nice;
__u32 sched_priority;
__u64 sched_runtime, sched_deadline, sched_period;
int sched_setattr(pid_t pid, const struct sched_attr *attr, unsigned int flags)
return syscall(__NR_sched_setattr, pid, attr, flags);
int main(void)
struct sched_attr attr = {
.size = sizeof(attr),
.sched_policy = SCHED_DEADLINE, /* This creates a 10ms/30ms reservation */
.sched_runtime = 10 * 1000 * 1000,
.sched_period = attr.sched_deadline = 30 * 1000 * 1000,
if (sched_setattr(0, &attr, 0) < 0) {
perror("sched_setattr");
return -1;
for(;;);
Committer notes:
Got the program from the provided URL, http://bristot.me/lkml/d.c,
trimmed it and included in the cset log above, so that we have
everything needed to test it in one place.
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/866ef75bcebf670ae91c6a96daa63597ba981f0d.1483443552.git.bristot@redhat.com
[ Upstream commit 0b47a6bd1150f4846b1d61925a4cc5a96593a541 ]
Ensure all reserved fields of xatp are zero before making
hypervisor call to XEN in xen_map_device_mmio().
xenmem_add_to_physmap_one() in XEN fails the mapping request if
extra.res reserved field in xatp is not zero for XENMAPSPACE_dev_mmio
request.
Signed-off-by: Jiandi An <anjiandi@codeaurora.org>
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
[ Upstream commit c2931667c83ded6504b3857e99cc45b21fa496fb ]
Currently how btrfs dio deals with split dio write is not good
enough if dio write is split into several segments due to the
lack of contiguous space, a large dio write like 'dd bs=1G count=1'
can end up with incorrect outstanding_extents counter and endio
would complain loudly with an assertion.
This fixes the problem by compensating the outstanding_extents
counter in inode if a large dio write gets split.
Reported-by: Anand Jain <anand.jain@oracle.com>
Tested-by: Anand Jain <anand.jain@oracle.com>
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
Signed-off-by: David Sterba <dsterba@suse.com>
[ Upstream commit 096de2f83ebc8e0404c5b7e847a4abd27b9739da ]
When VXLAN offloading is enabled, be_features_check() tries to check if
an encapsulated packet is indeed a VXLAN packet. The check is not strict
enough, and considers any UDP-encapsulated ethernet frame with a 8-byte
tunnel header as being VXLAN. Unfortunately, both GENEVE and VXLAN-GPE
have a 8-byte header, so they get through this check.
Force the UDP destination port to be the one that has been offloaded to
hardware.
Without this, GENEVE-encapsulated packets can end up having an incorrect
checksum when both a GENEVE and a VXLAN (offloaded) tunnel are
configured.
This is similar to commit a547224dceed ("mlx4e: Do not attempt to
offload VXLAN ports that are unrecognized").
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
[ Upstream commit 781feef7e6befafd4d9787d1f7ada1f9ccd504e4 ]
While checking INODE_REF/INODE_EXTREF for a corner case, we may acquire a
different inode's log_mutex with holding the current inode's log_mutex, and
lockdep has complained this with a possilble deadlock warning.
Fix this by using mutex_lock_nested() when processing the other inode's
log_mutex.
Reviewed-by: Filipe Manana <fdmanana@suse.com>
[ Upstream commit e321f8a801d7b4c40da8005257b05b9c2b51b072 ]
If @block_group is not @used_bg, it'll try to get @used_bg's lock without
droping @block_group 's lock and lockdep has throwed a scary deadlock warning
about it.
Fix it by using down_read_nested.
Reviewed-by: David Sterba <dsterba@suse.com>
[ Upstream commit 43aef5c2ca90535b3227e97e71604291875444ed ]
This fixes an error message that was probably copied and pasted. The same
message is used for both the in and out endpoints, so it makes it impossible
to know which one actually failed because both cases say "IN".
Make the out endpoint error message say "OUT".
Signed-off-by: David Lechner <david@lechnology.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit c2a6bbaf0c5f90463a7011a295bbdb7e33c80b51 ]
The way acpi_find_child_device() works currently is that, if there
are two (or more) devices with the same _ADR value in the same
namespace scope (which is not specifically allowed by the spec and
the OS behavior in that case is not defined), the first one of them
found to be present (with the help of _STA) will be returned.
This covers the majority of cases, but is not sufficient if some of
the devices in question have a _HID (or _CID) returning some valid
ACPI/PNP device IDs (which is disallowed by the spec) and the
ASL writers' expectation appears to be that the OS will match
devices without a valid ACPI/PNP device ID against a given bus
address first.
To cover this special case as well, modify find_child_checks()
to prefer devices without ACPI/PNP device IDs over devices that
have them.
Suggested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
[ Upstream commit 3ef01c968fbfb21c2f16281445d30a865ee4412c ]
NF_CT_PROTO_DCCP/SCTP/UDPLITE were switched from tristate to boolean so
defconfig needs to be adjusted to silence warnings:
warning: symbol value 'm' invalid for NF_CT_PROTO_DCCP
warning: symbol value 'm' invalid for NF_CT_PROTO_SCTP
warning: symbol value 'm' invalid for NF_CT_PROTO_UDPLITE
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 1f2ed153b916c95a49a1ca9d7107738664224b7f ]
Since 'perf probe' supports cross-arch probes, it is possible to analyze
different arch kernel image which has different bits-per-long.
In that case, it fails to get the module name because it uses the
MOD_NAME_OFFSET macro based on the host machine bits-per-long, instead
of the target arch bits-per-long.
This fixes above issue by changing modname-offset based on the target
archs bit width. This is ok because linux kernel uses LP64 model on
64bit arch.
E.g. without this (on x86_64, and target module is arm32):
$ perf probe -m build-arm/fs/configfs/configfs.ko -D configfs_lookup
p:probe/configfs_lookup :configfs_lookup+0
^-Here is an empty module name.
With this fix, you can see correct module name:
p:probe/configfs_lookup configfs:configfs_lookup+0
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Link: http://lkml.kernel.org/r/148337043836.6752.383495516397005695.stgit@devbox
[ Upstream commit c415f9e8304a1d235ef118d912f374ee2e46c45d ]
The Zynq Ultrascale MP uses version 1.4 of the Cadence IP core
which fixes some silicon bugs that needed software workarounds
in Version 1.0 that was used on Zynq systems.
Signed-off-by: Moritz Fischer <mdf@kernel.org>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Sören Brinkmann <soren.brinkmann@xilinx.com>
Cc: Rob Herring <robh+dt@kernel.org>
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
[ Upstream commit 4ea2a6be9565455f152c12f80222af1582ede0c7 ]
The patch removes these warnings reported by dtc 1.4:
Warning (unit_address_vs_reg): Node /amba_apu has a reg or ranges
property, but no unit name
Warning (unit_address_vs_reg): Node /memory has a reg or ranges
[ Upstream commit 12a7f17fac5b370bec87259e4c718faf563ce900 ]
Now races can happen between interrupt handler execution and PM runtime in
error handling code path in probe and in dwc3_omap_remove() which will lead
to system crash:
in probe:
err1:
pm_runtime_put_sync(dev);
^^ PM runtime can race with IRQ handler when deferred probing happening
due to extcon
pm_runtime_disable(dev);
return ret;
in dwc3_omap_remove:
dwc3_omap_disable_irqs(omap);
^^ IRQs are disabled in HW, but handler may still run
of_platform_depopulate(omap->dev);
pm_runtime_put_sync(&pdev->dev);
pm_runtime_disable(&pdev->dev);
return 0;
So, OMAP DWC3 IRQ need to be disabled before calling
pm_runtime_put() in probe and in dwc3_omap_remove().
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
[ Upstream commit 75bdc7f31a3a6e9a12e218b31a44a1f54a91554c ]
Add some missing 'of_node_put()' in early exit error path.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 97b84fd6d91766ea57dcc350d78f42639e011c30 ]
An L2TP socket bound to the unspecified address should match with any
address. If not, it can't receive any packet and __l2tp_ip6_bind_lookup()
can't prevent another socket from binding on the same device/tunnel ID.
While there, rename the 'addr' variable to 'sk_laddr' (local addr), to
make following patch clearer.
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
