This reverts commit 1e9e71782f3462d5aecb0720d26298253bdbeca7 which is
commit 661ccdc1a95f18ab6c1373322fde09afd5b90a1f upstream.
It's not needed in 4.9, and it breaks the build.
Reported-by: Guenter Roeck <linux@roeck-us.net>
Cc: Milo Kim <woogyom.kim@gmail.com>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Sasha Levin <alexander.levin@verizon.com>
commit 7e5a672289c9754d07e1c3b33649786d3d70f5e4 upstream.
The mmu_notifier_release() callback of KVM triggers cleaning up
the stage2 page table on kvm-arm. However there could be other
notifier callbacks in parallel with the mmu_notifier_release(),
which could cause the call backs ending up in an empty stage2
page table. Make sure we check it for all the notifier callbacks.
Fixes: commit 293f29363 ("kvm-arm: Unmap shadow pagetables properly")
Reported-by: Alex Graf <agraf@suse.de>
Reviewed-by: Christoffer Dall <cdall@linaro.org>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
commit fc290a114fc6034b0f6a5a46e2fb7d54976cf87a upstream.
This fixes another cause of random segfaults and bus errors that may
occur while running perf with the callgraph option.
Critical sections beginning with spin_lock_irqsave() raise the interrupt
level to PIL_NORMAL_MAX (14) and intentionally do not block performance
counter interrupts, which arrive at PIL_NMI (15).
But some sections of code are "super critical" with respect to perf
because the perf_callchain_user() path accesses user space and may cause
TLB activity as well as faults as it unwinds the user stack.
One particular critical section occurs in switch_mm:
spin_lock_irqsave(&mm->context.lock, flags);
load_secondary_context(mm);
tsb_context_switch(mm);
spin_unlock_irqrestore(&mm->context.lock, flags);
If a perf interrupt arrives in between load_secondary_context() and
tsb_context_switch(), then perf_callchain_user() could execute with
the context ID of one process, but with an active TSB for a different
process. When the user stack is accessed, it is very likely to
incur a TLB miss, since the h/w context ID has been changed. The TLB
will then be reloaded with a translation from the TSB for one process,
but using a context ID for another process. This exposes memory from
one process to another, and since it is a mapping for stack memory,
this usually causes the new process to crash quickly.
This super critical section needs more protection than is provided
by spin_lock_irqsave() since perf interrupts must not be allowed in.
Since __tsb_context_switch already goes through the trouble of
disabling interrupts completely, we fix this by moving the secondary
context load down into this better protected region.
Orabug: 25577560
Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com>
Signed-off-by: Rob Gardner <rob.gardner@oracle.com>
[ Upstream commit 85f1bd9a7b5a79d5baa8bf44af19658f7bf77bfa ]
When iteratively building a UDP datagram with MSG_MORE and that
datagram exceeds MTU, consistently choose UFO or fragmentation.
Once skb_is_gso, always apply ufo. Conversely, once a datagram is
split across multiple skbs, do not consider ufo.
Sendpage already maintains the first invariant, only add the second.
IPv6 does not have a sendpage implementation to modify.
A gso skb must have a partial checksum, do not follow sk_no_check_tx
in udp_send_skb.
Found by syzkaller.
Fixes: e89e9cf539a2 ("[IPv4/IPv6]: UFO Scatter-gather approach")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
__ip_append_data and ip_finish_output"
This reverts commit f102bb7164c9020e12662998f0fd99c3be72d4f6 which is
commit 0a28cfd51e17f4f0a056bcf66bfbe492c3b99f38 upstream as there is
another patch that needs to be applied instead of this one.
Cc: Zheng Li <james.z.li@ericsson.com>
This reverts commit ef09c9ff343122a0b245416066992d096416ff19 which is
commit a5cb659bbc1c8644efa0c3138a757a1e432a4880 upstream as it causes
merge issues with later patches that are much more important...
Cc: Michal Kubecek <mkubecek@suse.cz>
Cc: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit c27927e372f0785f3303e8fad94b85945e2c97b7 ]
Updates to tp_reserve can race with reads of the field in
packet_set_ring. Avoid this by holding the socket lock during
updates in setsockopt PACKET_RESERVE.
This bug was discovered by syzkaller.
Fixes: 8913336a7e8d ("packet: add PACKET_RESERVE sockopt")
[ Upstream commit 1714020e42b17135032c8606f7185b3fb2ba5d78 ]
Commit dcd87999d415 ("igmp: net: Move igmp namespace init to correct file")
moved the igmp sysctls initialization from tcp_sk_init to igmp_net_init. This
function is only called as part of per-namespace initialization, only if
CONFIG_IP_MULTICAST is defined, otherwise igmp_mc_init() call in ip_init is
compiled out, casuing the igmp pernet ops to not be registerd and those sysctl
being left initialized with 0. However, there are certain functions, such as
ip_mc_join_group which are always compiled and make use of some of those
sysctls. Let's do a partial revert of the aforementioned commit and move the
sysctl initialization into inet_init_net, that way they will always have
sane values.
Fixes: dcd87999d415 ("igmp: net: Move igmp namespace init to correct file")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196595
Reported-by: Gerardo Exequiel Pozzi <vmlinuz386@gmail.com>
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
[ Upstream commit 8d63bee643f1fb53e472f0e135cae4eb99d62d19 ]
skb_warn_bad_offload triggers a warning when an skb enters the GSO
stack at __skb_gso_segment that does not have CHECKSUM_PARTIAL
checksum offload set.
Commit b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise")
observed that SKB_GSO_DODGY producers can trigger the check and
that passing those packets through the GSO handlers will fix it
up. But, the software UFO handler will set ip_summed to
CHECKSUM_NONE.
When __skb_gso_segment is called from the receive path, this
triggers the warning again.
Make UFO set CHECKSUM_UNNECESSARY instead of CHECKSUM_NONE. On
Tx these two are equivalent. On Rx, this better matches the
skb state (checksum computed), as CHECKSUM_NONE here means no
checksum computed.
See also this thread for context:
http://patchwork.ozlabs.org/patch/799015/
Fixes: b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise")
[ Upstream commit 8ba60924710cde564a3905588b6219741d6356d0 ]
With new TCP_FASTOPEN_CONNECT socket option, there is a possibility
to call tcp_connect() while socket sk_dst_cache is either NULL
or invalid.
+0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 4
+0 fcntl(4, F_SETFL, O_RDWR|O_NONBLOCK) = 0
+0 setsockopt(4, SOL_TCP, TCP_FASTOPEN_CONNECT, [1], 4) = 0
+0 connect(4, ..., ...) = 0
<< sk->sk_dst_cache becomes obsolete, or even set to NULL >>
+1 sendto(4, ..., 1000, MSG_FASTOPEN, ..., ...) = 1000
We need to refresh the route otherwise bad things can happen,
especially when syzkaller is running on the host :/
Fixes: 19f6d3f3c8422 ("net/tcp-fastopen: Add new API support")
Cc: Wei Wang <weiwan@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Wei Wang <weiwan@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 96d9703050a0036a3360ec98bb41e107c90664fe ]
Commit 55917a21d0cc ("netfilter: x_tables: add context to know if
extension runs from nft_compat") introduced a member nft_compat to
xt_tgchk_param structure.
But it didn't set it's value for ipt_init_target. With unexpected
value in par.nft_compat, it may return unexpected result in some
target's checkentry.
This patch is to set all it's fields as 0 and only initialize the
non-zero fields in ipt_init_target.
v1->v2:
As Wang Cong's suggestion, fix it by setting all it's fields as
0 and only initializing the non-zero fields.
Fixes: 55917a21d0cc ("netfilter: x_tables: add context to know if extension runs from nft_compat")
Suggested-by: Cong Wang <xiyou.wangcong@gmail.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit e718fe450e616227b74d27a233cdf37b4df0c82b ]
if the NIC fails to validate the checksum on TCP/UDP, and validation of IP
checksum is successful, the driver subtracts the pseudo-header checksum
from the value obtained by the hardware and sets CHECKSUM_COMPLETE. Don't
do that if protocol is IPPROTO_SCTP, otherwise CRC32c validation fails.
V2: don't test MLX4_CQE_STATUS_IPV6 if MLX4_CQE_STATUS_IPV4 is set
Reported-by: Shuang Li <shuali@redhat.com>
Fixes: f8c6455bb04b ("net/mlx4_en: Extend checksum offloading by CHECKSUM COMPLETE")
Signed-off-by: Davide Caratti <dcaratti@redhat.com>
Acked-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit b0a0c2566f28e71e5e32121992ac8060cec75510 ]
While testing some other work that required JIT modifications, I
run into test_bpf causing a hang when JIT enabled on s390. The
problematic test case was the one from ddc665a4bb4b (bpf, arm64:
fix jit branch offset related to ldimm64), and turns out that we
do have a similar issue on s390 as well. In bpf_jit_prog() we
update next instruction address after returning from bpf_jit_insn()
with an insn_count. bpf_jit_insn() returns either -1 in case of
error (e.g. unsupported insn), 1 or 2. The latter is only the
case for ldimm64 due to spanning 2 insns, however, next address
is only set to i + 1 not taking actual insn_count into account,
thus fix is to use insn_count instead of 1. bpf_jit_enable in
mode 2 provides also disasm on s390:
Before fix:
000003ff800349b6: a7f40003 brc 15,3ff800349bc ; target
000003ff800349ba: 0000 unknown
000003ff800349bc: e3b0f0700024 stg %r11,112(%r15)
000003ff800349c2: e3e0f0880024 stg %r14,136(%r15)
000003ff800349c8: 0db0 basr %r11,%r0
000003ff800349ca: c0ef00000000 llilf %r14,0
000003ff800349d0: e320b0360004 lg %r2,54(%r11)
000003ff800349d6: e330b03e0004 lg %r3,62(%r11)
000003ff800349dc: ec23ffeda065 clgrj %r2,%r3,10,3ff800349b6 ; jmp
000003ff800349e2: e3e0b0460004 lg %r14,70(%r11)
000003ff800349e8: e3e0b04e0004 lg %r14,78(%r11)
000003ff800349ee: b904002e lgr %r2,%r14
000003ff800349f2: e3b0f0700004 lg %r11,112(%r15)
000003ff800349f8: e3e0f0880004 lg %r14,136(%r15)
000003ff800349fe: 07fe bcr 15,%r14
After fix:
000003ff80ef3db4: a7f40003 brc 15,3ff80ef3dba
000003ff80ef3db8: 0000 unknown
000003ff80ef3dba: e3b0f0700024 stg %r11,112(%r15)
000003ff80ef3dc0: e3e0f0880024 stg %r14,136(%r15)
000003ff80ef3dc6: 0db0 basr %r11,%r0
000003ff80ef3dc8: c0ef00000000 llilf %r14,0
000003ff80ef3dce: e320b0360004 lg %r2,54(%r11)
000003ff80ef3dd4: e330b03e0004 lg %r3,62(%r11)
000003ff80ef3dda: ec230006a065 clgrj %r2,%r3,10,3ff80ef3de6 ; jmp
000003ff80ef3de0: e3e0b0460004 lg %r14,70(%r11)
000003ff80ef3de6: e3e0b04e0004 lg %r14,78(%r11) ; target
000003ff80ef3dec: b904002e lgr %r2,%r14
000003ff80ef3df0: e3b0f0700004 lg %r11,112(%r15)
000003ff80ef3df6: e3e0f0880004 lg %r14,136(%r15)
000003ff80ef3dfc: 07fe bcr 15,%r14
test_bpf.ko suite runs fine after the fix.
Fixes: 054623105728 ("s390/bpf: Add s390x eBPF JIT compiler backend")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Tested-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
[ Upstream commit 2dda640040876cd8ae646408b69eea40c24f9ae9 ]
syzkaller was able to trigger a divide by 0 in TCP stack [1]
Issue here is that keepalive timer needs to be updated to not attempt
to send a probe if the connection setup was deferred using
TCP_FASTOPEN_CONNECT socket option added in linux-4.11
[1]
divide error: 0000 [#1] SMP
CPU: 18 PID: 0 Comm: swapper/18 Not tainted
task: ffff986f62f4b040 ti: ffff986f62fa2000 task.ti: ffff986f62fa2000
RIP: 0010:[<ffffffff8409cc0d>] [<ffffffff8409cc0d>] __tcp_select_window+0x8d/0x160
Call Trace:
<IRQ>
[<ffffffff8409d951>] tcp_transmit_skb+0x11/0x20
[<ffffffff8409da21>] tcp_xmit_probe_skb+0xc1/0xe0
[<ffffffff840a0ee8>] tcp_write_wakeup+0x68/0x160
[<ffffffff840a151b>] tcp_keepalive_timer+0x17b/0x230
[<ffffffff83b3f799>] call_timer_fn+0x39/0xf0
[<ffffffff83b40797>] run_timer_softirq+0x1d7/0x280
[<ffffffff83a04ddb>] __do_softirq+0xcb/0x257
[<ffffffff83ae03ac>] irq_exit+0x9c/0xb0
[<ffffffff83a04c1a>] smp_apic_timer_interrupt+0x6a/0x80
[<ffffffff83a03eaf>] apic_timer_interrupt+0x7f/0x90
<EOI>
[<ffffffff83fed2ea>] ? cpuidle_enter_state+0x13a/0x3b0
[<ffffffff83fed2cd>] ? cpuidle_enter_state+0x11d/0x3b0
Tested:
Following packetdrill no longer crashes the kernel
`echo 0 >/proc/sys/net/ipv4/tcp_timestamps`
// Cache warmup: send a Fast Open cookie request
0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 fcntl(3, F_SETFL, O_RDWR|O_NONBLOCK) = 0
+0 setsockopt(3, SOL_TCP, TCP_FASTOPEN_CONNECT, [1], 4) = 0
+0 connect(3, ..., ...) = -1 EINPROGRESS (Operation is now in progress)
+0 > S 0:0(0) <mss 1460,nop,nop,sackOK,nop,wscale 8,FO,nop,nop>
+.01 < S. 123:123(0) ack 1 win 14600 <mss 1460,nop,nop,sackOK,nop,wscale 6,FO abcd1234,nop,nop>
+0 > . 1:1(0) ack 1
+0 close(3) = 0
+0 > F. 1:1(0) ack 1
+0 < F. 1:1(0) ack 2 win 92
+0 > . 2:2(0) ack 2
+0 setsockopt(4, SOL_SOCKET, SO_KEEPALIVE, [1], 4) = 0
+.01 connect(4, ..., ...) = 0
+0 setsockopt(4, SOL_TCP, TCP_KEEPIDLE, [5], 4) = 0
+10 close(4) = 0
`echo 1 >/proc/sys/net/ipv4/tcp_timestamps`
Fixes: 19f6d3f3c842 ("net/tcp-fastopen: Add new API support")
[ Upstream commit ed254971edea92c3ac5c67c6a05247a92aa6075e ]
If the sender switches the congestion control during ECN-triggered
cwnd-reduction state (CA_CWR), upon exiting recovery cwnd is set to
the ssthresh value calculated by the previous congestion control. If
the previous congestion control is BBR that always keep ssthresh
to TCP_INIFINITE_SSTHRESH, cwnd ends up being infinite. The safe
step is to avoid assigning invalid ssthresh value when recovery ends.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 0a0e1a85c83775a648041be2b15de6d0a2f2b8eb ]
Commit e5dadc65f9e0 ("ppp: Fix false xmit recursion detect with two ppp
devices") dropped the xmit_recursion counter incrementation in
ppp_channel_push() and relied on ppp_xmit_process() for this task.
But __ppp_channel_push() can also send packets directly (using the
.start_xmit() channel callback), in which case the xmit_recursion
counter isn't incremented anymore. If such packets get routed back to
the parent ppp unit, ppp_xmit_process() won't notice the recursion and
will call ppp_channel_push() on the same channel, effectively creating
the deadlock situation that the xmit_recursion mechanism was supposed
to prevent.
This patch re-introduces the xmit_recursion counter incrementation in
ppp_channel_push(). Since the xmit_recursion variable is now part of
the parent ppp unit, incrementation is skipped if the channel doesn't
have any. This is fine because only packets routed through the parent
unit may enter the channel recursively.
Finally, we have to ensure that pch->ppp is not going to be modified
while executing ppp_channel_push(). Instead of taking this lock only
while calling ppp_xmit_process(), we now have to hold it for the full
ppp_channel_push() execution. This respects the ppp locks ordering
which requires locking ->upl before ->downl.
Fixes: e5dadc65f9e0 ("ppp: Fix false xmit recursion detect with two ppp devices")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit e5dadc65f9e0177eb649bcd9d333f1ebf871223e ]
The global percpu variable ppp_xmit_recursion is used to detect the ppp
xmit recursion to avoid the deadlock, which is caused by one CPU tries to
lock the xmit lock twice. But it would report false recursion when one CPU
wants to send the skb from two different PPP devices, like one L2TP on the
PPPoE. It is a normal case actually.
Now use one percpu member of struct ppp instead of the gloable variable to
detect the xmit recursion of one ppp device.
Fixes: 55454a565836 ("ppp: avoid dealock on recursive xmit")
Signed-off-by: Gao Feng <gfree.wind@vip.163.com>
Signed-off-by: Liu Jianying <jianying.liu@ikuai8.com>
commit 0a94efb5acbb6980d7c9ab604372d93cd507e4d8 upstream.
5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be
ordered") automatically enabled ordered attribute for unbound
workqueues w/ max_active == 1. Because ordered workqueues reject
max_active and some attribute changes, this implicit ordered mode
broke cases where the user creates an unbound workqueue w/ max_active
== 1 and later explicitly changes the related attributes.
This patch distinguishes explicit and implicit ordered setting and
overrides from attribute changes if implict.
Fixes: 5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be ordered")
Cc: Holger Hoffstätte <holger@applied-asynchrony.com>
commit 7b9a88a390dacb37b051a7b09b9a08f546edf5eb upstream.
The PHY library does not deal very well with bind and unbind events. The first
thing we would see is that we were not properly canceling the PHY state machine
workqueue, so we would be crashing while dereferencing phydev->drv since there
is no driver attached anymore.
Suggested-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit a5cb659bbc1c8644efa0c3138a757a1e432a4880 ]
Our customer encountered stuck NFS writes for blocks starting at specific
offsets w.r.t. page boundary caused by networking stack sending packets via
UFO enabled device with wrong checksum. The problem can be reproduced by
composing a long UDP datagram from multiple parts using MSG_MORE flag:
sendto(sd, buff, 1000, MSG_MORE, ...);
sendto(sd, buff, 3000, 0, ...);
Assume this packet is to be routed via a device with MTU 1500 and
NETIF_F_UFO enabled. When second sendto() gets into __ip_append_data(),
this condition is tested (among others) to decide whether to call
ip_ufo_append_data():
((length + fragheaderlen) > mtu) || (skb && skb_is_gso(skb))
At the moment, we already have skb with 1028 bytes of data which is not
marked for GSO so that the test is false (fragheaderlen is usually 20).
Thus we append second 1000 bytes to this skb without invoking UFO. Third
sendto(), however, has sufficient length to trigger the UFO path so that we
end up with non-UFO skb followed by a UFO one. Later on, udp_send_skb()
uses udp_csum() to calculate the checksum but that assumes all fragments
have correct checksum in skb->csum which is not true for UFO fragments.
When checking against MTU, we need to add skb->len to length of new segment
if we already have a partially filled skb and fragheaderlen only if there
isn't one.
In the IPv6 case, skb can only be null if this is the first segment so that
we have to use headersize (length of the first IPv6 header) rather than
fragheaderlen (length of IPv6 header of further fragments) for skb == NULL.
Fixes: e4c5e13aa45c ("ipv6: Should use consistent conditional judgement for
ip6 fragment between __ip6_append_data and ip6_finish_output")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 0a28cfd51e17f4f0a056bcf66bfbe492c3b99f38 ]
There is an inconsistent conditional judgement in __ip_append_data and
ip_finish_output functions, the variable length in __ip_append_data just
include the length of application's payload and udp header, don't include
the length of ip header, but in ip_finish_output use
(skb->len > ip_skb_dst_mtu(skb)) as judgement, and skb->len include the
length of ip header.
That causes some particular application's udp payload whose length is
between (MTU - IP Header) and MTU were fragmented by ip_fragment even
though the rst->dev support UFO feature.
Add the length of ip header to length in __ip_append_data to keep
consistent conditional judgement as ip_finish_output for ip fragment.
Signed-off-by: Zheng Li <james.z.li@ericsson.com>
[ Upstream commit 5bae8c031053c69b4aa74b7f1ba15d4ec8426208 ]
We must re-enable RoCE on the e-switch management port (PF) only after destroying
the FDB in its switchdev/offloaded mode. Otherwise, when encapsulation is supported,
this re-enablement will fail.
Also, it's more natural and symmetric to disable RoCE on the PF before we create
the FDB under switchdev mode, so do that as well and revert if getting into error
during the mode change later.
Fixes: 9da34cd34e85 ('net/mlx5: Disable RoCE on the e-switch management [..]')
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Reviewed-by: Hadar Hen Zion <hadarh@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit f073bdc51771f5a5c7a8d1191bfc3ae371d44de7 ]
The VM_BUG_ON() check in move_freepages() checks whether the node id of
a page matches the node id of its zone. However, it does this before
having checked whether the struct page pointer refers to a valid struct
page to begin with. This is guaranteed in most cases, but may not be
the case if CONFIG_HOLES_IN_ZONE=y.
So reorder the VM_BUG_ON() with the pfn_valid_within() check.
Link: http://lkml.kernel.org/r/1481706707-6211-2-git-send-email-ard.biesheuvel@linaro.org
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Robert Richter <rrichter@cavium.com>
Cc: James Morse <james.morse@arm.com>
[ Upstream commit 2d39b3cd34e6d323720d4c61bd714f5ae202c022 ]
Since commit 00cd5c37afd5 ("ptrace: permit ptracing of /sbin/init") we
can now trace init processes. init is initially protected with
SIGNAL_UNKILLABLE which will prevent fatal signals such as SIGSTOP, but
there are a number of paths during tracing where SIGNAL_UNKILLABLE can
be implicitly cleared.
This can result in init becoming stoppable/killable after tracing. For
example, running:
while true; do kill -STOP 1; done &
strace -p 1
and then stopping strace and the kill loop will result in init being
left in state TASK_STOPPED. Sending SIGCONT to init will resume it, but
init will now respond to future SIGSTOP signals rather than ignoring
them.
Make sure that when setting SIGNAL_STOP_CONTINUED/SIGNAL_STOP_STOPPED
that we don't clear SIGNAL_UNKILLABLE.
Link: http://lkml.kernel.org/r/20170104122017.25047-1-jamie.iles@oracle.com
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
[ Upstream commit da0510c47519fe0999cffe316e1d370e29f952be ]
The build of frv allmodconfig was failing with the errors like:
/tmp/cc0JSPc3.s: Assembler messages:
/tmp/cc0JSPc3.s:1839: Error: symbol `.LSLT0' is already defined
/tmp/cc0JSPc3.s:1842: Error: symbol `.LASLTP0' is already defined
/tmp/cc0JSPc3.s:1969: Error: symbol `.LELTP0' is already defined
/tmp/cc0JSPc3.s:1970: Error: symbol `.LELT0' is already defined
Commit 866ced950bcd ("kbuild: Support split debug info v4") introduced
splitting the debug info and keeping that in a separate file. Somehow,
the frv-linux gcc did not like that and I am guessing that instead of
splitting it started copying. The first report about this is at:
https://lists.01.org/pipermail/kbuild-all/2015-July/010527.html.
I will try and see if this can work with frv and if still fails I will
open a bug report with gcc. But meanwhile this is the easiest option to
solve build failure of frv.
Fixes: 866ced950bcd ("kbuild: Support split debug info v4")
Link: http://lkml.kernel.org/r/1482062348-5352-1-git-send-email-sudipm.mukherjee@gmail.com
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit bb1107f7c6052c863692a41f78c000db792334bf ]
Andrey Konovalov has reported the following warning triggered by the
syzkaller fuzzer.
WARNING: CPU: 1 PID: 9935 at mm/page_alloc.c:3511 __alloc_pages_nodemask+0x159c/0x1e20
Kernel panic - not syncing: panic_on_warn set ...
CPU: 1 PID: 9935 Comm: syz-executor0 Not tainted 4.9.0-rc7+ #34
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__alloc_pages_slowpath mm/page_alloc.c:3511
__alloc_pages_nodemask+0x159c/0x1e20 mm/page_alloc.c:3781
alloc_pages_current+0x1c7/0x6b0 mm/mempolicy.c:2072
alloc_pages include/linux/gfp.h:469
kmalloc_order+0x1f/0x70 mm/slab_common.c:1015
kmalloc_order_trace+0x1f/0x160 mm/slab_common.c:1026
kmalloc_large include/linux/slab.h:422
__kmalloc+0x210/0x2d0 mm/slub.c:3723
kmalloc include/linux/slab.h:495
ep_write_iter+0x167/0xb50 drivers/usb/gadget/legacy/inode.c:664
new_sync_write fs/read_write.c:499
__vfs_write+0x483/0x760 fs/read_write.c:512
vfs_write+0x170/0x4e0 fs/read_write.c:560
SYSC_write fs/read_write.c:607
SyS_write+0xfb/0x230 fs/read_write.c:599
entry_SYSCALL_64_fastpath+0x1f/0xc2
The issue is caused by a lack of size check for the request size in
ep_write_iter which should be fixed. It, however, points to another
problem, that SLUB defines KMALLOC_MAX_SIZE too large because the its
KMALLOC_SHIFT_MAX is (MAX_ORDER + PAGE_SHIFT) which means that the
resulting page allocator request might be MAX_ORDER which is too large
(see __alloc_pages_slowpath).
The same applies to the SLOB allocator which allows even larger sizes.
Make sure that they are capped properly and never request more than
MAX_ORDER order.
Link: http://lkml.kernel.org/r/20161220130659.16461-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 270c8cf1cacc69cb8d99dea812f06067a45e4609 ]
ARM has a few system calls (most notably mmap) for which the names of
the functions which are referenced in the syscall table do not match the
names of the syscall tracepoints. As a consequence of this, these
tracepoints are not made available. Implement
arch_syscall_match_sym_name to fix this and allow tracing even these
system calls.
Signed-off-by: Rabin Vincent <rabinv@axis.com>
[ Upstream commit 6bf6b0aa3da84a3d9126919a94c49c0fb7ee2fb3 ]
If blk_mq_init_queue() returns an error, it gets assigned to
vblk->disk->queue. Then, when we call put_disk(), we end up calling
blk_put_queue() with the ERR_PTR, causing a bad dereference. Fix it by
only assigning to vblk->disk->queue on success.
Signed-off-by: Omar Sandoval <osandov@fb.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 25b4acfc7de0fc4da3bfea3a316f7282c6fbde81 ]
Additionally, don't assign directly to disk->queue, otherwise
blk_put_queue (called via put_disk) will choke (panic) on the errno
stored there.
Bug found by code inspection after Omar found a similar issue in
virtio_blk. Compile-tested only.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Reviewed-by: Omar Sandoval <osandov@fb.com>
Reviewed-by: Josef Bacik <jbacik@fb.com>
[ Upstream commit 3bcf96e0183f5c863657cb6ae9adad307a0f6071 ]
Function rx_data(), which handles ingress CPL_RX_DATA messages, was
always sending an RX_DATA_ACK with the goal of updating the credits.
However, if the RDMA connection is moved out of FPDU mode abruptly,
then it is possible for iw_cxgb4 to process queued RX_DATA CPLs after HW
has aborted the connection. These CPLs should not trigger RX_DATA_ACKS.
If they do, HW can see a READ after DELETE of the DB_LE hash entry for
the tid and post a LE_DB HashTblMemCrcError.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit 3116d37651d77125bf50f81f859b1278e02ccce6 ]
The node name for the power seq pin is mmc2@0 like the mmc2_pins_a one.
This makes the original node (mmc2_pins_a) scrapped out of the dtb and
result in a unusable eMMC if U-Boot didn't configured the pins to the
correct functions.
Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[ Upstream commit 661ccdc1a95f18ab6c1373322fde09afd5b90a1f ]
The commit 10efbf5f1633 ("ARM: dts: sun8i: Add dts file for NanoPi M1 SBC")
introduced NanoPi M1 board but it's missing in Allwinner H3 DTB build.
Signed-off-by: Milo Kim <woogyom.kim@gmail.com>
[ Upstream commit 71d3f6ef7f5af38dea2975ec5715c88bae92e92d ]
virtio uses normal ram as backing storage for the framebuffer, so we
should assign the address to new screen_buffer (added by commit
17a7b0b4d9749f80d365d7baff5dec2f54b0e992) instead of screen_base.
Reported-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
[ Upstream commit c7702b8c22712a06080e10f1d2dee1a133ec8809 ]
There is a race condition with qla2xxx optrom functions where one thread
might modify optrom buffer, optrom_state while other thread is still
reading from it.
In couple of crashes, it was found that we had successfully passed the
following 'if' check where we confirm optrom_state to be
QLA_SREADING. But by the time we acquired mutex lock to proceed with
memory_read_from_buffer function, some other thread/process had already
modified that option rom buffer and optrom_state from QLA_SREADING to
QLA_SWAITING. Then we got ha->optrom_buffer 0x0 and crashed the system:
if (ha->optrom_state != QLA_SREADING)
return 0;
mutex_lock(&ha->optrom_mutex);
rval = memory_read_from_buffer(buf, count, &off, ha->optrom_buffer,
ha->optrom_region_size);
mutex_unlock(&ha->optrom_mutex);
With current optrom function we get following crash due to a race
condition:
[ 1479.466679] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1479.466707] IP: [<ffffffff81326756>] memcpy+0x6/0x110
[ 1479.473673] Call Trace:
[ 1479.474296] [<ffffffff81225cbc>] ? memory_read_from_buffer+0x3c/0x60
[ 1479.474941] [<ffffffffa01574dc>] qla2x00_sysfs_read_optrom+0x9c/0xc0 [qla2xxx]
[ 1479.475571] [<ffffffff8127e76b>] read+0xdb/0x1f0
[ 1479.476206] [<ffffffff811fdf9e>] vfs_read+0x9e/0x170
[ 1479.476839] [<ffffffff811feb6f>] SyS_read+0x7f/0xe0
[ 1479.477466] [<ffffffff816964c9>] system_call_fastpath+0x16/0x1b
Below patch modifies qla2x00_sysfs_read_optrom,
qla2x00_sysfs_write_optrom functions to get the mutex_lock before
checking ha->optrom_state to avoid similar crashes.
The patch was applied and tested and same crashes were no longer
observed again.
Tested-by: Milan P. Gandhi <mgandhi@redhat.com>
Signed-off-by: Milan P. Gandhi <mgandhi@redhat.com>
Reviewed-by: Laurence Oberman <loberman@redhat.com>
Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com>
[ Upstream commit 318fa46cc60d37fec1e87dbf03a82aca0f5ce695 ]
Some parent clocks of the Exynos542x clock blocks, which have separate
power domains (like DISP, MFC, MSC, GSC, FSYS and G2D) must be always
enabled to access any register related to power management unit or devices
connected to it. For the time being, until a proper solution based on
runtime PM is applied, mark those clocks as critical (instead of ignore
unused or even no flags) to prevent disabling them.
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com> [Exynos5800 Peach Pi Chromebook]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[ Upstream commit b007f09072ca8afa118ade333e717ba443e8d807 ]
> cat /proc/sys/net/ipv4/tcp_notsent_lowat
-1
> echo 4294967295 > /proc/sys/net/ipv4/tcp_notsent_lowat
-bash: echo: write error: Invalid argument
> echo -2147483648 > /proc/sys/net/ipv4/tcp_notsent_lowat
-2147483648
but in documentation we have "tcp_notsent_lowat - UNSIGNED INTEGER"
v2: simplify to just proc_douintvec
Signed-off-by: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
[ Upstream commit 811a919135b980bac8009d042acdccf10dc1ef5e ]
While in RUNNING state, phy_state_machine() checks for link changes by
comparing phydev->link before and after calling phy_read_status().
This works as long as it is guaranteed that phydev->link is never
changed outside the phy_state_machine().
If in some setups this happens, it causes the state machine to miss
a link loss and remain RUNNING despite phydev->link being 0.
This has been observed running a dsa setup with a process continuously
polling the link states over ethtool each second (SNMPD RFC-1213
agent). Disconnecting the link on a phy followed by a ETHTOOL_GSET
causes dsa_slave_get_settings() / dsa_slave_get_link_ksettings() to
call phy_read_status() and with that modify the link status - and
with that bricking the phy state machine.
This patch adds a fail-safe check while in RUNNING, which causes to
move to CHANGELINK when the link is gone and we are still RUNNING.
Signed-off-by: Zefir Kurtisi <zefir.kurtisi@neratec.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit cc31d43b4154ad5a7d8aa5543255a93b7e89edc2 ]
Otherwise, RST packets generated by ipt_REJECT always have mark 0 when
the routing is checked later in the same code path.
Fixes: e110861f8609 ("net: add a sysctl to reflect the fwmark on replies")
Cc: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Pau Espin Pedrol <pau.espin@tessares.net>
[ Upstream commit 02c5c03283c52157d336abf5e44ffcda10579fbf ]
The i2s clock pre-divider 1 is used for both i2s1 and sysclk.
The i2s1 is usually used for the main i2s and the pre-divider
will be set in hw_params function.
However, if i2s2 is used, the pre-divider is not set in the hw_params
function and the default value of i2s clock pre-divider 1 is too high
for sysclk and DMIC usage. Fix by overriding default divider value to 2.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=95681
Tested-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Signed-off-by: Bard Liao <bardliao@realtek.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 9620ca90115d4bd700f05862d3b210a266a66efe ]
We should go to 'err_put_master' here instead of returning directly.
Otherwise a call to 'spi_master_put' is missing.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
[ Upstream commit fac69d0efad08fc15e4dbfc116830782acc0dc9a ]
Add the missing declarations of basic string functions to string.h to allow
a clean build.
Fixes: 5be865661516 ("String-handling functions for the new x86 setup code.")
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Link: http://lkml.kernel.org/r/1483781911-21399-1-git-send-email-hofrat@osadl.org
[ Upstream commit f5992b72ebe0dde488fa8f706b887194020c66fc ]
The driver's ndo_get_stats64() method is not always called under RTNL.
So it can race with driver close or ethtool reconfigurations. Fix the
race condition by taking tp->lock spinlock in tg3_free_consistent()
when freeing the tp->hw_stats memory block. tg3_get_stats64() is
already taking tp->lock.
Reported-by: Wang Yufen <wangyufen@huawei.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 5ca7d1ca77dc23934504b95a96d2660d345f83c2 ]
For proper IRQ generation by DP83867 phy the INT/PWDN pin has to be
programmed as an interrupt output instead of a Powerdown input in
Configuration Register 3 (CFG3), Address 0x001E, bit 7 INT_OE = 1. The
current driver doesn't do this and as result IRQs will not be generated by
DP83867 phy even if they are properly configured in DT.
Hence, fix IRQ generation by properly configuring CFG3.INT_OE bit and
ensure that Link Status Change (LINK_STATUS_CHNG_INT) and Auto-Negotiation
Complete (AUTONEG_COMP_INT) interrupt are enabled. After this the DP83867
driver will work properly in interrupt enabled mode.
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
[ Upstream commit 0f1f9cbc04dbb3cc310f70a11cba0cf1f2109d9c ]
The R8A7740 GEther controller supports the packet checksum offloading
but the 'hw_crc' (bad name, I'll fix it) flag isn't set in the R8A7740
data, thus CSMR isn't cleared...
Fixes: 73a0d907301e ("net: sh_eth: add support R8A7740")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 978d3639fd13d987950e4ce85c8737ae92154b2c ]
As the SH77{34|63} manuals are freely available, I've checked the EESIPR
values written against the manuals, and they appeared to set the reserved
bits 11-15 (which should be 0 on write). Fix those EESIPR values.
Fixes: 380af9e390ec ("net: sh_eth: CPU dependency code collect to "struct sh_eth_cpu_data"")
Fixes: f5d12767c8fd ("sh_eth: get SH77{34|63} support out of #ifdef")
commit 93be2b74279c15c2844684b1a027fdc71dd5d9bf upstream.
gcc-7 complains that wl3501_cs passes NULL into a function that
then uses the argument as the input for memcpy:
drivers/net/wireless/wl3501_cs.c: In function 'wl3501_get_scan':
include/net/iw_handler.h:559:3: error: argument 2 null where non-null expected [-Werror=nonnull]
memcpy(stream + point_len, extra, iwe->u.data.length);
This works fine here because iwe->u.data.length is guaranteed to be 0
and the memcpy doesn't actually have an effect.
Making the length check explicit avoids the warning and should have
no other effect here.
Also check the pointer itself, since otherwise we get warnings
elsewhere in the code.
[ Upstream commit 0ede1c401332173ab0693121dc6cde04a4dbf131 ]
Mikael Pettersson reported that some test programs in the strace-4.18
testsuite cause an OOPS.
After some debugging it turns out that garbage values are returned
when an exception occurs, causing the fixup memset() to be run with
bogus arguments.
The problem is that two of the exception handler stubs write the
successfully copied length into the wrong register.
Fixes: ee841d0aff64 ("sparc64: Convert U3copy_{from,to}_user to accurate exception reporting.")
Reported-by: Mikael Pettersson <mikpelinux@gmail.com>
Tested-by: Mikael Pettersson <mikpelinux@gmail.com>
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
[ Upstream commit 9d53caec84c7c5700e7c1ed744ea584fff55f9ac ]
A large sun4v SPARC system may have moments of intensive xcall activities,
usually caused by unmapping many pages on many CPUs concurrently. This can
flood receivers with CPU mondo interrupts for an extended period, causing
some unlucky senders to hit send-mondo timeout. This problem gets worse
as cpu count increases because sometimes mappings must be invalidated on
all CPUs, and sometimes all CPUs may gang up on a single CPU.
But a busy system is not a broken system. In the above scenario, as long
as the receiver is making forward progress processing mondo interrupts,
the sender should continue to retry.
This patch implements the receiver's forward progress meter by introducing
a per cpu counter 'cpu_mondo_counter[cpu]' where 'cpu' is in the range
of 0..NR_CPUS. The receiver increments its counter as soon as it receives
a mondo and the sender tracks the receiver's counter. If the receiver has
stopped making forward progress when the retry limit is reached, the sender
declares send-mondo-timeout and panic; otherwise, the receiver is allowed
to keep making forward progress.
In addition, it's been observed that PCIe hotplug events generate Correctable
Errors that are handled by hypervisor and then OS. Hypervisor 'borrows'
a guest cpu strand briefly to provide the service. If the cpu strand is
simultaneously the only cpu targeted by a mondo, it may not be available
for the mondo in 20msec, causing SUN4V mondo timeout. It appears that 1 second
is the agreed wait time between hypervisor and guest OS, this patch makes
the adjustment.
Orabug: 25476541
Orabug: 26417466
Signed-off-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Steve Sistare <steven.sistare@oracle.com>
Reviewed-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
Reviewed-by: Thomas Tai <thomas.tai@oracle.com>
