commit d86b5672b1adb98b4cdd6fbf0224bbfb03db6e2e upstream.
Unavoidable crashes in netfront_resume() and netback_changed() after a
previous fail in talk_to_netback() (e.g. when we fail to read MAC from
xenstore) were discovered. The failure path in talk_to_netback() does
unregister/free for netdev but we don't reset drvdata and we try accessing
it after resume.
Fix the bug by removing the whole xen device completely with
device_unregister(), this guarantees we won't have any calls into netfront
after a failure.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 1d5a31582ef046d3b233f0da1a68ae26519b2f0a upstream.
The variable temp is incorrectly being updated, instead it should
be offset otherwise the loop just reads the same capability value
and loops forever. Thanks to Alan Stern for pointing out the
correct fix to my original fix. Fix also cleans up clang warning:
drivers/usb/host/ehci-dbg.c:840:4: warning: Value stored to 'temp'
is never read
Fixes: d49d43174400 ("USB: misc ehci updates")
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 446f666da9f019ce2ffd03800995487e79a91462 upstream.
USBDEVFS_URB_ISO_ASAP must be accepted only for ISO endpoints.
Improve sanity checking.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Oliver Neukum <oneukum@suse.com>
commit 57999d1107c1e60c2ca7088f2ac0f819e2f554b3 upstream.
There used to be an integer overflow check in proc_do_submiturb() but
we removed it. It turns out that it's still required. The
uurb->buffer_length variable is a signed integer and it's controlled by
the user. It can lead to an integer overflow when we do:
num_sgs = DIV_ROUND_UP(uurb->buffer_length, USB_SG_SIZE);
If we strip away the macro then that line looks like this:
num_sgs = (uurb->buffer_length + USB_SG_SIZE - 1) / USB_SG_SIZE;
It's the first addition which can overflow.
Fixes: 1129d270cbfb ("USB: Increase usbfs transfer limit")
commit 1129d270cbfbb7e2b1ec3dede4a13930bdd10e41 upstream.
Promote a variable keeping track of USB transfer memory usage to a
wider data type and allow for higher bandwidth transfers from a large
number of USB devices connected to a single host.
Signed-off-by: Mateusz Berezecki <mateuszb@fastmail.fm>
commit 81cf4a45360f70528f1f64ba018d61cb5767249a upstream.
As most of BOS descriptors are longer in length than their header
'struct usb_dev_cap_header', comparing solely with it is not sufficient
to avoid out-of-bounds access to BOS descriptors.
This patch adds descriptor type specific length check in
usb_get_bos_descriptor() to fix the issue.
Signed-off-by: Masakazu Mokuno <masakazu.mokuno@gmail.com>
commit 80e457699a8dbdd70f2d26911e46f538645c55fc upstream.
Check vdev->real_port 0 to avoid panic
[ 9.261347] [<ffffff800884a390>] xhci_free_virt_devices_depth_first+0x58/0x108
[ 9.261352] [<ffffff800884a814>] xhci_mem_cleanup+0x1bc/0x570
[ 9.261355] [<ffffff8008842de8>] xhci_stop+0x140/0x1c8
[ 9.261365] [<ffffff80087ed304>] usb_remove_hcd+0xfc/0x1d0
[ 9.261369] [<ffffff80088551c4>] xhci_plat_remove+0x6c/0xa8
[ 9.261377] [<ffffff80086e928c>] platform_drv_remove+0x2c/0x70
[ 9.261384] [<ffffff80086e6ea0>] __device_release_driver+0x80/0x108
[ 9.261387] [<ffffff80086e7a1c>] device_release_driver+0x2c/0x40
[ 9.261392] [<ffffff80086e5f28>] bus_remove_device+0xe0/0x120
[ 9.261396] [<ffffff80086e2e34>] device_del+0x114/0x210
[ 9.261399] [<ffffff80086e9e00>] platform_device_del+0x30/0xa0
[ 9.261403] [<ffffff8008810bdc>] dwc3_otg_work+0x204/0x488
[ 9.261407] [<ffffff80088133fc>] event_work+0x304/0x5b8
[ 9.261414] [<ffffff80080e31b0>] process_one_work+0x148/0x490
[ 9.261417] [<ffffff80080e3548>] worker_thread+0x50/0x4a0
[ 9.261421] [<ffffff80080e9ea0>] kthread+0xe8/0x100
[ 9.261427] [<ffffff8008083680>] ret_from_fork+0x10/0x50
The problem can occur if xhci_plat_remove() is called shortly after
xhci_plat_probe(). While xhci_free_virt_devices_depth_first been
called before the device has been setup and get real_port initialized.
The problem occurred on Hikey960 and was reproduced by Guenter Roeck
on Kevin with chromeos-4.4.
Fixes: ee8665e28e8d ("xhci: free xhci virtual devices with leaf nodes first")
Cc: Guenter Roeck <groeck@google.com>
Reviewed-by: Guenter Roeck <groeck@chromium.org>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Fan Ning <fanning4@hisilicon.com>
Signed-off-by: Li Rui <lirui39@hisilicon.com>
Signed-off-by: yangdi <yangdi10@hisilicon.com>
Signed-off-by: Yu Chen <chenyu56@huawei.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 973593a960ddac0f14f0d8877d2d0abe0afda795 upstream.
Sometimes the USB device gets confused about the state of the initialization and
the connection fails. In particular, the device thinks that it's already set up
and running while the host thinks the device still needs to be configured. To
work around this issue, power-cycle the hub's output to issue a sort of "reset"
to the device. This makes the device restart its state machine and then the
initialization succeeds.
This fixes problems where the kernel reports a list of errors like this:
usb 1-1.3: device not accepting address 19, error -71
The end result is a non-functioning device. After this patch, the sequence
becomes like this:
usb 1-1.3: new high-speed USB device number 18 using ci_hdrc
usb 1-1.3: device not accepting address 18, error -71
usb 1-1.3: new high-speed USB device number 19 using ci_hdrc
usb 1-1-port3: attempt power cycle
usb 1-1.3: new high-speed USB device number 21 using ci_hdrc
usb-storage 1-1.3:1.2: USB Mass Storage device detected
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
commit 24a367348a017555f982a9ee137070a7a821fa97 upstream.
This was missed when adding a dma_fence_get call. While at it also
remove the kerneldoc for the static inline helper - no point
documenting internals down to every detail.
Fixes: 30cd85dd6edc ("dma-buf/sync_file: hold reference to fence when creating sync_file")
Cc: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Cc: Sean Paul <seanpaul@chromium.org>
Cc: linux-doc@vger.kernel.org
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Reviewed-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
Link: http://patchwork.freedesktop.org/patch/msgid/20161209185309.1682-3-daniel.vetter@ffwll.ch
commit 30cd85dd6edc86ea8d8589efb813f1fad41ef233 upstream.
fence referencing was out of balance. It was not taking any ref to the
fence at creating time, but it was putting a reference when freeing the
sync file.
This patch fixes the balancing issue by getting a reference for the fence
when creating the sync_file.
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1476899313-22241-1-git-send-email-gustavo@padovan.org
commit ea4d5a270b57fa8d4871f372ca9b97b7697fdfda upstream.
To avoid hanging userspace components that might have been waiting on the
active fences of the destroyed timeline we need to signal with error all
remaining fences on such timeline.
This restore the default behaviour of the Android sw_sync framework, which
Android still relies on. It was broken on the dma fence conversion a few
years ago and never fixed.
v2: Do not bother with cleanup do the list (Chris Wilson)
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Dominik Behr <dbehr@chromium.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20170907190246.16425-2-gustavo@padovan.org
[s/dma_fence/fence/g - gregkh]
Cc: Jisheng Zhang <Jisheng.Zhang@synaptics.com>
commit a009e975da5c7d42a7f5eaadc54946eb5f76c9af upstream.
The dma_fence.error field (formerly known as dma_fence.status) is an
optional field that may be set by drivers before calling
dma_fence_signal(). The field can be used to indicate that the fence was
completed in err rather than with success, and is visible to other
consumers of the fence and to userspace via sync_file.
This patch renames the field from status to error so that its meaning is
hopefully more clear (and distinct from dma_fence_get_status() which is
a composite between the error state and signal state) and adds a helper
that validates the preconditions of when it is suitable to adjust the
error field.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Sumit Semwal <sumit.semwal@linaro.org>
Link: http://patchwork.freedesktop.org/patch/msgid/20170104141222.6992-3-chris@chris-wilson.co.uk
commit d6c99f4bf093a58d3ab47caaec74b81f18bc4e3f upstream.
The fence->status is an optional field that is only valid once the fence
has been signaled. (Driver may fill the fence->status with an error code
prior to calling dma_fence_signal().) Given the restriction upon its
validity, wrap querying of the fence->status into a helper
dma_fence_get_status().
Link: http://patchwork.freedesktop.org/patch/msgid/20170104141222.6992-2-chris@chris-wilson.co.uk
commit 83dd1376fd92f33bdeca9e83d479534a4e7f870b upstream.
As the fence->status is an optional field that may be set before
dma_fence_signal() is called to convey that the fence completed with an
error, we have to ensure that it is always set to zero on initialisation
so that the typical use (i.e. unset) always flags a successful completion.
Reviewed-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170104141222.6992-1-chris@chris-wilson.co.uk
commit 3792b7c1a70815fe4e954221c096f9278638fd21 upstream.
If userspace already dropped its own reference by closing the sw_sync
fence fd we might end up in a deadlock where
dma_fence_is_signaled_locked() will trigger the release of the fence and
thus try to hold the lock to remove the fence from the list.
dma_fence_is_signaled_locked() tries to release/free the fence and hold
the lock in the process.
We fix that by changing the order operation and clean up the list and
rb-tree first.
v2: Drop fence get/put dance and manipulate the list first (Chris Wilson)
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Link: https://patchwork.freedesktop.org/patch/msgid/20170729152217.8362-2-gustavo@padovan.org
commit 150b6a9d7d6fffb95c0a5349960a10569e8218b5 upstream.
We are going to use timeline_fence_signaled() in a internal function in
the next commit.
Link: https://patchwork.freedesktop.org/patch/msgid/20170729152217.8362-1-gustavo@padovan.org
commit f1e8c67123cf171e2b0357e885e426328b241d7d upstream.
Reduce the list iteration when incrementing the timeline by storing the
fences in increasing order.
v2: Prevent spinlock recursion on free during create
v3: Fixup rebase conflict inside comments that escaped the compiler.
Cc: Gustavo Padovan <gustavo@padovan.org>
Reviewed-by: Sean Paul <seanpaul@chromium.org>
Link: http://patchwork.freedesktop.org/patch/msgid/20170629211253.22766-1-chris@chris-wilson.co.uk
commit d3862e44daa7a0c94d2f6193502a8c49379acfce upstream.
The sync_pt were not adding themselves atomically to the timeline lists,
corruption imminent. Only a single list is required to track the
unsignaled sync_pt, so reduce it and rename the lock more appropriately
along with using idiomatic names to distinguish a list from links along
it.
v2: Prevent spinlock recursion on free during create (next patch) and
fixup crossref in kerneldoc
Link: http://patchwork.freedesktop.org/patch/msgid/20170629210532.5617-1-chris@chris-wilson.co.uk
commit 3b52ce44e720c240afc4c4b03140d7b7811b23bd upstream.
Since sync_pt is only allocated from a single location and is no longer
the base class for fences (that is struct dma_fence) it no longer needs
a generic unsized allocator.
Link: http://patchwork.freedesktop.org/patch/msgid/20170629125930.821-5-chris@chris-wilson.co.uk
commit a6aa8fca4d792c72947e341d7842d2f700534335 upstream.
If we know the context under which we are called, then we can use the
simpler form of spin_lock_irq (saving the save/restore).
Link: http://patchwork.freedesktop.org/patch/msgid/20170629125930.821-4-chris@chris-wilson.co.uk
commit 8f66d3aa1735bc95ae58d846a157357e8d41abb8 upstream.
The timeline is u32, which limits any single advance to INT_MAX so that
we can detect all fences that need signaling.
Link: http://patchwork.freedesktop.org/patch/msgid/20170629125930.821-3-chris@chris-wilson.co.uk
commit 61894b02716f122dd7662d5d89f5b2245ca551e2 upstream.
Use the canonical __dma_fence_is_later() to compare the fence seqno
against the timeline seqno to check if the fence is signaled.
Link: http://patchwork.freedesktop.org/patch/msgid/20170629125930.821-2-chris@chris-wilson.co.uk
commit 8111477663813caa1a4469cfe6afaae36cd04513 upstream.
Often we have the task of comparing two seqno known to be on the same
context, so provide a common __dma_fence_is_later().
Link: http://patchwork.freedesktop.org/patch/msgid/20170629125930.821-1-chris@chris-wilson.co.uk
[renamed to __fence_is_later() - gregkh]
[ Upstream commit 01f8902bcf3ff124d0aeb88a774180ebcec20ace ]
Fix hardware setup of multicast address hash:
- Never clear the hardware hash (to avoid packet loss)
- Construct the hash register values in software and then write once
to hardware
Signed-off-by: Rui Sousa <rui.sousa@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
[ Upstream commit ebf692f85ff78092cd238166d8d7ec51419f9c02 ]
This patch fixes an issue where the type of counters in the queue(s)
and interface are not in sync (queue counters are int, interface
counters are long), causing incorrect reporting of tx/rx values
of the vif interface and unclear counter overflows.
This patch sets both counters to the u64 type.
Signed-off-by: Mart van Santen <mart@greenhost.nl>
Reviewed-by: Paul Durrant <paul.durrant@citrix.com>
[ Upstream commit 42980da2eb7eb9695d8efc0c0ef145cbbb993b2c ]
Poll messages that are used to allocate a logical address should
use the same initiator as the destination. Instead, it expected that
the initiator was 0xf which is not according to the standard.
This also had consequences for the message checks in cec_transmit_msg_fh
that incorrectly rejected poll messages with the same initiator and
destination.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit e2e004acc7cbe3c531e752a270a74e95cde3ea48 ]
This fixes a crash when running out of grant refs when creating many
queues across many netdevs.
* If creating queues fails (i.e. there are no grant refs available),
call xenbus_dev_fatal() to ensure that the xenbus device is set to the
closed state.
* If no queues are created, don't call xennet_disconnect_backend as
netdev->real_num_tx_queues will not have been set correctly.
* If setup_netfront() fails, ensure that all the queues created are
cleaned up, not just those that have been set up.
* If any queues were set up and an error occurs, call
xennet_destroy_queues() to clean up the napi context.
* If any fatal error occurs, unregister and destroy the netdev to avoid
leaving around a half setup network device.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit 0911d0041c22922228ca52a977d7b0b0159fee4b ]
Some ->page_mkwrite handlers may return VM_FAULT_RETRY as its return
code (GFS2 or Lustre can definitely do this). However VM_FAULT_RETRY
from ->page_mkwrite is completely unhandled by the mm code and results
in locking and writeably mapping the page which definitely is not what
the caller wanted.
Fix Lustre and block_page_mkwrite_ret() used by other filesystems
(notably GFS2) to return VM_FAULT_NOPAGE instead which results in
bailing out from the fault code, the CPU then retries the access, and we
fault again effectively doing what the handler wanted.
Link: http://lkml.kernel.org/r/20170203150729.15863-1-jack@suse.cz
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Reviewed-by: Jinshan Xiong <jinshan.xiong@intel.com>
Cc: Matthew Wilcox <willy@infradead.org>
[ Upstream commit 2da64d20a0b20046d688e44f4033efd09157e29d ]
Commit d9c728949ddc ("vfio/spapr: Postpone default window creation")
added an additional exit to the VFIO_IOMMU_SPAPR_TCE_CREATE case and
made it possible to return from tce_iommu_ioctl() without unlocking
container->lock; this fixes the issue.
Fixes: d9c728949ddc ("vfio/spapr: Postpone default window creation")
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit 4993b39ab04b083ff6ee1147e7e7f120feb6bf7f ]
Recent commit 34393529163a ("be2net: fix MAC addr setting on privileged
BE3 VFs") allows privileged BE3 VFs to set its MAC address during
initialization. Although the initial MAC for such VFs is already
programmed by parent PF the subsequent setting performed by VF is OK,
but in certain cases (after fresh boot) this command in VF can fail.
The MAC should be initialized only when:
1) no MAC is programmed (always except BE3 VFs during first init)
2) programmed MAC is different from requested (e.g. MAC is set when
interface is down). In this case the initial MAC programmed by PF
needs to be deleted.
The adapter->dev_mac contains MAC address currently programmed in HW so
it should be zeroed when the MAC is deleted from HW and should not be
filled when MAC is set when interface is down in be_mac_addr_set() as
no programming is performed in this case.
Example of failure without the fix (immediately after fresh boot):
# ip link set eth0 up <- eth0 is BE3 PF
be2net 0000:01:00.0 eth0: Link is Up
# echo 1 > /sys/class/net/eth0/device/sriov_numvfs <- Create 1 VF
be2net 0000:01:04.0: Emulex OneConnect(be3): VF port 0
# ip link set eth8 up <- eth8 is created privileged VF
be2net 0000:01:04.0: opcode 59-1 failed:status 1-76
RTNETLINK answers: Input/output error
# echo 0 > /sys/class/net/eth0/device/sriov_numvfs <- Delete VF
iommu: Removing device 0000:01:04.0 from group 33
# echo 1 > /sys/class/net/eth0/device/sriov_numvfs <- Create it again
be2net 0000:01:04.0 eth8: Link is Up
Initialization is now OK.
v2 - Corrected the comment and condition check suggested by Suresh & Harsha
Fixes: 34393529163a ("be2net: fix MAC addr setting on privileged BE3 VFs")
Cc: Sathya Perla <sathya.perla@broadcom.com>
Cc: Ajit Khaparde <ajit.khaparde@broadcom.com>
Cc: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com>
Cc: Somnath Kotur <somnath.kotur@broadcom.com>
Signed-off-by: Ivan Vecera <cera@cera.cz>
Acked-by: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com>
[ Upstream commit c73e44269369e936165f0f9b61f1f09a11dae01c ]
This fixes the following smatch and coccinelle warnings:
drivers/net/ethernet/cavium/thunder/thunder_xcv.c:119 xcv_setup_link() error: we previously assumed 'xcv' could be null (see line 118) [smatch]
drivers/net/ethernet/cavium/thunder/thunder_xcv.c:119:16-20: ERROR: xcv is NULL but dereferenced. [coccinelle]
Fixes: 6465859aba1e66a5 ("net: thunderx: Add RGMII interface type support")
Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net>
Cc: Sunil Goutham <sgoutham@cavium.com>
[ Upstream commit cf626c3b252b2c9d131be0dd66096ec3bf729e54 ]
As pr commit "net: phy: phy drivers should not set SUPPORTED_[Asym_]Pause"
this phy driver should not set these feature bits.
Signed-off-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk>
Fixes: 9d162ed69f51 ("net: phy: micrel: add support for KSZ8795")
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 3ab1b469e847ba425af3c5ad5068cc94b55b38d0 ]
The use of the passed through netlink src_net to check for a
cross netns operation was wrong. Using the GTP socket and the
GTP netdevice is always correct (even if the netdev has been
moved to new netns after link creation).
Remove the now obsolete net field from gtp_dev.
Signed-off-by: Andreas Schultz <aschultz@tpip.net>
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
[ Upstream commit c6ce1d08eede4c2968ed08aafa3165e8e183c5a1 ]
3GPP TS 29.281 and 3GPP TS 29.060 imply that GTP-U packets should be
sent with the DF bit cleared. For example 3GPP TS 29.060, Release 8,
Section 13.2.2:
> Backbone router: Any router in the backbone may fragment the GTP
> packet if needed, according to IPv4.
Acked-by: Harald Welte <laforge@netfilter.org>
[ Upstream commit 06406d81a2d7cfb8abcc4fa6cdfeb8e5897007c5 ]
Make sure they are not running and we can free the controller
safely.
Signed-off-by: Roy Shterman <roys@lightbitslabs.com>
Signed-off-by: Sagi Grimberg <sagi@grimberg.me>
[ Upstream commit 0e1929dedea36781e25902118c93edd8d8f09af1 ]
The cadence I2C driver calls cdns_i2c_writereg(..) to setup a workaround
in the controller, but did so after calling i2c_add_adapter() which starts
probing devices on the bus. Change the order so that the configuration is
completely finished before using the adapter.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit 56d806222ace4c3aeae516cd7a855340fb2839d8 ]
sock_reset_flag() maps to __clear_bit() not the atomic version clear_bit().
Thus, we need smp_mb(), smp_mb__after_atomic() is not sufficient.
Fixes: 3c7151275c0c ("tcp: add memory barriers to write space paths")
Signed-off-by: Jason Baron <jbaron@akamai.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
[ Upstream commit 91539eb1fda2d530d3b268eef542c5414e54bf1a ]
The static bug finder EBA (http://www.iagoabal.eu/eba/) reported the
following double-lock bug:
Double lock:
1. spin_lock_irqsave(pch->lock, flags) at pl330_free_chan_resources:2236;
2. call to function `pl330_release_channel' immediately after;
3. call to function `dma_pl330_rqcb' in line 1753;
4. spin_lock_irqsave(pch->lock, flags) at dma_pl330_rqcb:1505.
I have fixed it as suggested by Marek Szyprowski.
First, I have replaced `pch->lock' with `pl330->lock' in functions
`pl330_alloc_chan_resources' and `pl330_free_chan_resources'. This avoids
the double-lock by acquiring a different lock than `dma_pl330_rqcb'.
NOTE that, as a result, `pl330_free_chan_resources' executes
`list_splice_tail_init' on `pch->work_list' under lock `pl330->lock',
whereas in the rest of the code `pch->work_list' is protected by
`pch->lock'. I don't know if this may cause race conditions. Similarly
`pch->cyclic' is written by `pl330_alloc_chan_resources' under
`pl330->lock' but read by `pl330_tx_submit' under `pch->lock'.
Second, I have removed locking from `pl330_request_channel' and
`pl330_release_channel' functions. Function `pl330_request_channel' is
only called from `pl330_alloc_chan_resources', so the lock is already
held. Function `pl330_release_channel' is called from
`pl330_free_chan_resources', which already holds the lock, and from
`pl330_del'. Function `pl330_del' is called in an error path of
`pl330_probe' and at the end of `pl330_remove', but I assume that there
cannot be concurrent accesses to the protected data at those points.
Signed-off-by: Iago Abal <mail@iagoabal.eu>
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 35e22e49a5d6a741ebe7f2dd280b2052c3003ef7 ]
In tipc_server_stop(), we iterate over the connections with limiting
factor as server's idr_in_use. We ignore the fact that this variable
is decremented in tipc_close_conn(), leading to premature exit.
In this commit, we iterate until the we have no connections left.
Acked-by: Ying Xue <ying.xue@windriver.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
Tested-by: John Thompson <thompa.atl@gmail.com>
Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
[ Upstream commit 9dc3abdd1f7ea524e8552e0a3ef01219892ed1f4 ]
Commit 333f796235a527 ("tipc: fix a race condition leading to
subscriber refcnt bug") reveals a soft lockup while acquiring
nametbl_lock.
Before commit 333f796235a527, we call tipc_conn_shutdown() from
tipc_close_conn() in the context of tipc_topsrv_stop(). In that
context, we are allowed to grab the nametbl_lock.
Commit 333f796235a527, moved tipc_conn_release (renamed from
tipc_conn_shutdown) to the connection refcount cleanup. This allows
either tipc_nametbl_withdraw() or tipc_topsrv_stop() to the cleanup.
Since tipc_exit_net() first calls tipc_topsrv_stop() and then
tipc_nametble_withdraw() increases the chances for the later to
perform the connection cleanup.
The soft lockup occurs in the call chain of tipc_nametbl_withdraw(),
when it performs the tipc_conn_kref_release() as it tries to grab
nametbl_lock again while holding it already.
tipc_nametbl_withdraw() grabs nametbl_lock
tipc_nametbl_remove_publ()
tipc_subscrp_report_overlap()
tipc_subscrp_send_event()
tipc_conn_sendmsg()
<< if (con->flags != CF_CONNECTED) we do conn_put(),
triggering the cleanup as refcount=0. >>
tipc_sock_release
tipc_conn_release
tipc_subscrb_delete
tipc_subscrp_delete
tipc_nametbl_unsubscribe << Soft Lockup >>
The previous changes in this series fixes the race conditions fixed
by commit 333f796235a527. Hence we can now revert the commit.
Fixes: 333f796235a52727 ("tipc: fix a race condition leading to subscriber refcnt bug")
Reported-and-Tested-by: John Thompson <thompa.atl@gmail.com>
[ Upstream commit af2b14b8b8ae21b0047a52c767ac8b44f435a280 ]
The loopback logic in RDMA CM packets compares Ethernet addresses and
was accidently inverse.
Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com>
Signed-off-by: Ariel Elior <Ariel.Elior@cavium.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit 865cea40b69741c3da2574176876463233b2b67c ]
If the user is requesting us to change the QP state to the same state
that it is already in, return success instead of failure.
Signed-off-by: Michal Kalderon <Michal.Kalderon@cavium.com>
[ Upstream commit 115865fa0826ed18ca04717cf72d0fe874c0fe7f ]
In my previous patch, I missed that rate_control_rate_init() is
called from some places that cannot sleep, so it cannot call
ieee80211_recalc_min_chandef(). Remove that call for now to fix
the context bug, we'll have to find a different way to fix the
minimum channel width issue.
Fixes: 96aa2e7cf126 ("mac80211: calculate min channel width correctly")
Reported-by: Xiaolong Ye (via lkp-robot) <xiaolong.ye@intel.com>
[ Upstream commit 3a1d19a29670aa7eb58576a31883d0aa9fb77549 ]
Virtual display doesn't allocate amdgpu_encoder when initializing,
so will get invaild pointer if try to free amdgpu_encoder when
unloading driver.
Signed-off-by: Xiangliang Yu <Xiangliang.Yu@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 4c833368f0bf748d4147bf301b1f95bc8eccb3c0 ]
I got the following calltrace on a Apollo Lake SoC with 32-bit kernel:
WARNING: CPU: 2 PID: 261 at arch/x86/include/asm/fpu/internal.h:363 fpu__restore+0x1f5/0x260
Hardware name: Intel Corp. Broxton P/NOTEBOOK, BIOS APLIRVPA.X64.0138.B35.1608091058 08/09/2016
Call Trace:
dump_stack()
__warn()
? fpu__restore()
warn_slowpath_null()
fpu__restore()
__fpu__restore_sig()
fpu__restore_sig()
restore_sigcontext.isra.9()
sys_sigreturn()
do_int80_syscall_32()
entry_INT80_32()
The reason is that a #GP occurs when executing XRSTORS. The root cause
is that we forget to set the xcomp_bv when we fake up the XSAVES area
in the copyin_to_xsaves() function.
Signed-off-by: Kevin Hao <haokexin@gmail.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: Yu-cheng Yu <yu-cheng.yu@intel.com>
Link: http://lkml.kernel.org/r/1485075023-30161-1-git-send-email-haokexin@gmail.com
[ Upstream commit 0e73fc9a56f22f2eec4d2b2910c649f7af67b74d ]
The comparison on the timeout can lead to an array overrun
read on sctp_timer_tbl because of an off-by-one error. Fix
this by using < instead of <= and also compare to the array
size rather than SCTP_EVENT_TIMEOUT_MAX.
Fixes CoverityScan CID#1397639 ("Out-of-bounds read")
[ Upstream commit 11d8bcef7a0399e1d2519f207fd575fc404306b4 ]
DECON_TV requires STANDALONE_UPDATE after output enabling, otherwise it does
not start. This change is neutral for DECON.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
[ Upstream commit e05208ded1905e500cd5b369d624b071951c68b9 ]
Set the proper bits for clockgating setup.
Signed-off-by: Rex Zhu <Rex.Zhu@amd.com>
[ Upstream commit bb1181c9a8b46b6f10e749d9ed94480336445d7f ]
qlt_reset is called with Immedidate Notify IOCB only.
Current code wrongly cast it as ATIO IOCB.
Signed-off-by: Quinn Tran <quinn.tran@cavium.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
