commit bafb2f7d4755bf1571bd5e9a03b97f3fc4fe69ae upstream.
There is a disparity in the context image saved to disk and our own
bookkeeping - that is we presume the RING_HEAD and RING_TAIL match our
stored ce->ring->tail value. However, as we emit WA_TAIL_DWORDS into the
ring but may not tell the GPU about them, the GPU may be lagging behind
our bookkeeping. Upon hibernation we do not save stolen pages, presuming
that their contents are volatile. This means that although we start
writing into the ring at tail, the GPU starts executing from its HEAD
and there may be some garbage in between and so the GPU promptly hangs
upon resume.
Testcase: igt/gem_exec_suspend/basic-S4
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96526
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20160921135108.29574-3-chris@chris-wilson.co.uk
Cc: Eric Blau <eblau1@gmail.com>
commit d1908f52557b3230fbd63c0429f3b4b748bf2b6d upstream.
Tetsuo has noticed that an OOM stress test which performs large write
requests can cause the full memory reserves depletion. He has tracked
this down to the following path
__alloc_pages_nodemask+0x436/0x4d0
alloc_pages_current+0x97/0x1b0
__page_cache_alloc+0x15d/0x1a0 mm/filemap.c:728
pagecache_get_page+0x5a/0x2b0 mm/filemap.c:1331
grab_cache_page_write_begin+0x23/0x40 mm/filemap.c:2773
iomap_write_begin+0x50/0xd0 fs/iomap.c:118
iomap_write_actor+0xb5/0x1a0 fs/iomap.c:190
? iomap_write_end+0x80/0x80 fs/iomap.c:150
iomap_apply+0xb3/0x130 fs/iomap.c:79
iomap_file_buffered_write+0x68/0xa0 fs/iomap.c:243
xfs_file_buffered_aio_write+0x132/0x390 [xfs]
? remove_wait_queue+0x59/0x60
xfs_file_write_iter+0x90/0x130 [xfs]
__vfs_write+0xe5/0x140
vfs_write+0xc7/0x1f0
? syscall_trace_enter+0x1d0/0x380
SyS_write+0x58/0xc0
do_syscall_64+0x6c/0x200
entry_SYSCALL64_slow_path+0x25/0x25
the oom victim has access to all memory reserves to make a forward
progress to exit easier. But iomap_file_buffered_write and other
callers of iomap_apply loop to complete the full request. We need to
check for fatal signals and back off with a short write instead.
As the iomap_apply delegates all the work down to the actor we have to
hook into those. All callers that work with the page cache are calling
iomap_write_begin so we will check for signals there. dax_iomap_actor
has to handle the situation explicitly because it copies data to the
userspace directly. Other callers like iomap_page_mkwrite work on a
single page or iomap_fiemap_actor do not allocate memory based on the
given len.
Fixes: 68a9f5e7007c ("xfs: implement iomap based buffered write path")
Link: http://lkml.kernel.org/r/20170201092706.9966-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
commit b414fa01c31318383ae29d9d23cb9ca4184bbd86 upstream.
The current QP FetchBurstMax value is 256B, which
is incorrect since a WR can exceed that value. The
result being a partial WR fetched by hardware, and
a fatal "bad WR" error posted by the SGE.
So bump the FetchBurstMax to 512B.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit aaaec6fc755447a1d056765b11b24d8ff2b81366 upstream.
The recent commit which prevents double activation of interrupts unearthed
interesting code in x86. The code (ab)uses irq_domain_activate_irq() to
reconfigure an already activated interrupt. That trips over the prevention
code now.
Fix it by deactivating the interrupt before activating the new configuration.
Fixes: 08d85f3ea99f1 "irqdomain: Avoid activating interrupts more than once"
Reported-and-tested-by: Mike Galbraith <efault@gmx.de>
Reported-and-tested-by: Borislav Petkov <bp@alien8.de>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1701311901580.3457@nanos
commit 08d85f3ea99f1eeafc4e8507936190e86a16ee8c upstream.
Since commit f3b0946d629c ("genirq/msi: Make sure PCI MSIs are
activated early"), we can end-up activating a PCI/MSI twice (once
at allocation time, and once at startup time).
This is normally of no consequences, except that there is some
HW out there that may misbehave if activate is used more than once
(the GICv3 ITS, for example, uses the activate callback
to issue the MAPVI command, and the architecture spec says that
"If there is an existing mapping for the EventID-DeviceID
combination, behavior is UNPREDICTABLE").
While this could be worked around in each individual driver, it may
make more sense to tackle the issue at the core level. In order to
avoid getting in that situation, let's have a per-interrupt flag
to remember if we have already activated that interrupt or not.
Fixes: f3b0946d629c ("genirq/msi: Make sure PCI MSIs are activated early")
Reported-and-tested-by: Andre Przywara <andre.przywara@arm.com>
Link: http://lkml.kernel.org/r/1484668848-24361-1-git-send-email-marc.zyngier@arm.com
commit 828f84ee8f84710ea1818b3565add268bcb824c8 upstream.
FIFO was being read every sample after the "almost full" state was
reached. This was due to an incorrect placement of the parenthesis
in the while condition check.
Note - the fixes tag is not actually correct, but the fix in this patch
would also be needed for it to function correctly so we'll go with that
one. Backports should pick up both.
Signed-off-by: Matt Ranostay <matt@ranostay.consulting>
Fixes: b74fccad7 ("iio: health: max30100: correct FIFO check condition")
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 5c113b5e0082e90d2e1c7b12e96a7b8cf0623e27 upstream.
The DHT22 (AM2302) datasheet specifies that the LOW start pulse should not
exceed 20ms. However, observations with an oscilloscope of an RPi Model 2B
(rev 1.1) communicating with a DHT22 sensor showed that the driver was
consistently sending start pulses longer than 20ms:
Kernel 4.7.10-v7+ (n=132):
Minimum pulse length: 20.20ms
Maximum: 29.84ms
Mean: 24.96ms
StDev: 2.82ms
Sensor response rate: 100%
Read success rate: 76%
On kernel 4.8, the start pulse was so long that the sensor would not even
respond 97% of the time:
Kernel 4.8.16-v7+ (n=100):
Minimum pulse length: 30.4ms
Maximum: 74.4ms
Mean: 39.3ms
StDev: 10.2ms
Sensor response rate: 3%
Read success rate: 3%
The driver would return ETIMEDOUT and write log messages like this:
[ 51.430987] dht11 dht11@0: Only 1 signal edges detected
[ 66.311019] dht11 dht11@0: Only 0 signal edges detected
Replacing msleep(18) with usleep_range(18000, 20000) made the pulse length
sane again and restored responsiveness:
Kernel 4.8.16-v7+ with usleep_range (n=123):
Minimum pulse length: 18.16ms
Maximum: 20.20ms
Mean: 19.85ms
StDev: 0.51ms
Read success rate: 84%
Signed-off-by: John Brooks <john@fastquake.com>
Reviewed-by: Harald Geyer <harald@ccbib.org>
commit a5badd1e97e6caeca78ad74191f12fc923c403a8 upstream.
The suspend/resume functions were using dev_to_iio_dev() to get
the iio_dev. That only works on IIO dev's. Replace it with spi
functions to get the correct iio_dev.
Signed-off-by: Alison Schofield <amsfield22@gmail.com>
Acked-by: Andrew F. Davis <afd@ti.com>
commit 802ecfc113df1e15af1d028427cbbe785ae9cc4a upstream.
the iio_dev. That only works on IIO dev's. Replace it with i2c
commit d1aaf20ee655888c227d5137b7a63551f8d15416 upstream.
the iio_dev. That only works on IIO dev's. Use dev_get_drvdata()
for a platform device to get the correct iio_dev.
commit b17c1bba9cec1727451b906d9a0c209774624873 upstream.
When tearingdown timesync, and not in arche platform, the state platform
callback is not initialized. That will trigger the following NULL
dereferencing.
CallTrace:
? gb_timesync_platform_unlock_bus+0x11/0x20 [greybus]
gb_timesync_teardown+0x85/0xc0 [greybus]
gb_timesync_svc_remove+0xab/0x190 [greybus]
gb_svc_del+0x29/0x110 [greybus]
gb_hd_del+0x14/0x20 [greybus]
ap_disconnect+0x24/0x60 [gb_es2]
usb_unbind_interface+0x7a/0x2c0
__device_release_driver+0x96/0x150
device_release_driver+0x1e/0x30
bus_remove_device+0xe7/0x130
device_del+0x116/0x230
usb_disable_device+0x97/0x1f0
usb_disconnect+0x80/0x260
hub_event+0x5ca/0x10e0
process_one_work+0x126/0x3b0
worker_thread+0x55/0x4c0
? process_one_work+0x3b0/0x3b0
kthread+0xc4/0xe0
? kthread_park+0xb0/0xb0
ret_from_fork+0x22/0x30
So, fix that by adding checks before use the callback.
Fixes: 970dc85bd95d ("greybus: timesync: Add timesync core driver")
Signed-off-by: Rui Miguel Silva <rmfrfs@gmail.com>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Johan Hovold <johan@kernel.org>
commit 5d03a2fd2292e71936c4235885c35ccc3c94695b upstream.
Yet another laptop vendor rebranded Novatel E371.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 83e526f2a2fa4b2e82b6bd3ddbb26b70acfa8947 upstream.
OS descriptor head, when flagged as provided, is accessed without
checking if it fits in provided buffer. Verify length before access.
Also, there are other places where buffer length it checked
after accessing offsets which are potentially past the end. Check
buffer length before as well to fail cleanly.
Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com>
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit 407788b51db6f6aab499d02420082f436abf3238 upstream.
Commit 467d5c980709 ("usb: musb: Implement session bit based runtime PM for
musb-core") started implementing musb generic runtime PM support by
introducing devctl register session bit based state control.
This caused a regression where if a USB mass storage device is connected
to a USB hub, we can get:
usb 1-1: reset high-speed USB device number 2 using musb-hdrc
usb 1-1: device descriptor read/64, error -71
usb 1-1.1: new high-speed USB device number 4 using musb-hdrc
This is because before the USB storage device is connected, musb is
in OTG_STATE_A_SUSPEND. And we currently only set need_finish_resume
in musb_stage0_irq() and the related code calling finish_resume_work
in musb_resume() and musb_runtime_resume() never gets called.
To fix the issue, we can call schedule_delayed_work() directly in
musb_stage0_irq() to have finish_resume_work run.
And we should no longer never get interrupts when when suspended.
We have changed musb to no longer need pm_runtime_irqsafe().
The need_finish_resume flag was added in commit 9298b4aad37e ("usb:
musb: fix device hotplug behind hub") and no longer applies as far
as I can tell. So let's just remove the earlier code that no longer
is needed.
Fixes: 467d5c980709 ("usb: musb: Implement session bit based runtime PM for musb-core")
Reported-by: Bin Liu <b-liu@ti.com>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit d9b2997e4a0a874e452df7cdd7de5a54502bd0aa upstream.
Add a quirk for WORLDE easykey.25 MIDI keyboard (idVendor=0218,
idProduct=0401). The device reports that it has config string
descriptor at index 3, but when the system selects the configuration
and tries to get the description, it returns a -EPROTO error,
the communication restarts and this keeps repeating over and over again.
Not requesting the string descriptor makes the device work correctly.
Relevant info from Wireshark:
CONFIGURATION DESCRIPTOR
bLength: 9
bDescriptorType: 0x02 (CONFIGURATION)
wTotalLength: 101
bNumInterfaces: 2
bConfigurationValue: 1
iConfiguration: 3
Configuration bmAttributes: 0xc0 SELF-POWERED NO REMOTE-WAKEUP
1... .... = Must be 1: Must be 1 for USB 1.1 and higher
.1.. .... = Self-Powered: This device is SELF-POWERED
..0. .... = Remote Wakeup: This device does NOT support remote wakeup
bMaxPower: 50 (100mA)
45 0.369104 host 2.38.0 USB 64 GET DESCRIPTOR Request STRING
URB setup
bmRequestType: 0x80
1... .... = Direction: Device-to-host
.00. .... = Type: Standard (0x00)
...0 0000 = Recipient: Device (0x00)
bRequest: GET DESCRIPTOR (6)
Descriptor Index: 0x03
bDescriptorType: 0x03
Language Id: English (United States) (0x0409)
wLength: 255
46 0.369255 2.38.0 host USB 64 GET DESCRIPTOR Response STRING[Malformed Packet]
Frame 46: 64 bytes on wire (512 bits), 64 bytes captured (512 bits) on interface 0
USB URB
[Source: 2.38.0]
[Destination: host]
URB id: 0xffff88021f62d480
URB type: URB_COMPLETE ('C')
URB transfer type: URB_CONTROL (0x02)
Endpoint: 0x80, Direction: IN
Device: 38
URB bus id: 2
Device setup request: not relevant ('-')
Data: present (0)
URB sec: 1484896277
URB usec: 455031
URB status: Protocol error (-EPROTO) (-71)
URB length [bytes]: 0
Data length [bytes]: 0
[Request in: 45]
[Time from request: 0.000151000 seconds]
Unused Setup Header
Interval: 0
Start frame: 0
Copy of Transfer Flags: 0x00000200
Number of ISO descriptors: 0
[Malformed Packet: USB]
[Expert Info (Error/Malformed): Malformed Packet (Exception occurred)]
[Malformed Packet (Exception occurred)]
[Severity level: Error]
[Group: Malformed]
Signed-off-by: Lukáš Lalinský <lukas@oxygene.sk>
commit d07830db1bdb254e4b50d366010b219286b8c937 upstream.
Seems that ATEN serial-to-usb devices using pl2303 exist with
different device ids. This patch adds a missing device ID so it
is recognised by the driver.
Signed-off-by: Marcel J.E. Mol <marcel@mesa.nl>
commit 24d615a694d649aa2e167c3f97f62bdad07e3f84 upstream.
The Dell DW5570 is a re-branded Sierra Wireless MC8805 which will by
default boot with vid 0x413c and pid 0x81a3. When triggered QDL download
mode, the device switches to pid 0x81a6 and provides the standard TTY
used for firmware upgrade.
Signed-off-by: Aleksander Morgado <aleksander@aleksander.es>
commit 00c87e9a70a17b355b81c36adedf05e84f54e10d upstream.
Saving unsupported state prevents migration when the new host does not
support a XSAVE feature of the original host, even if the feature is not
exposed to the guest.
We've masked host features with guest-visible features before, with
4344ee981e21 ("KVM: x86: only copy XSAVE state for the supported
features") and dropped it when implementing XSAVES. Do it again.
Fixes: df1daba7d1cb ("KVM: x86: support XSAVES usage in the host")
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 362f4562466c3b9490e733e06999025638310d4a upstream.
Commit fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support")
together with recent MUSB changes allowed USB and DMA on BeagleBone to idle
when no cable is connected. But looks like few corner case issues still
remain.
Looks like just by re-plugging USB cable about ten or so times on BeagleBone
when configured in USB peripheral mode we can get warnings and eventually
trigger an oops in cppi41 DMA:
WARNING: CPU: 0 PID: 14 at drivers/dma/cppi41.c:1154 cppi41_runtime_suspend+
x28/0x38 [cppi41]
WARNING: CPU: 0 PID: 14 at drivers/dma/cppi41.c:452
push_desc_queue+0x94/0x9c [cppi41]
Unable to handle kernel NULL pointer dereference at virtual
address 00000104
pgd = c0004000
[00000104] *pgd=00000000
Internal error: Oops: 805 [#1] SMP ARM
[<bf0d92cc>] (cppi41_runtime_resume [cppi41]) from [<c0589838>]
(__rpm_callback+0xc0/0x214)
[<c0589838>] (__rpm_callback) from [<c05899ac>] (rpm_callback+0x20/0x80)
[<c05899ac>] (rpm_callback) from [<c0589460>] (rpm_resume+0x504/0x78c)
[<c0589460>] (rpm_resume) from [<c058a1a0>] (pm_runtime_work+0x60/0xa8)
[<c058a1a0>] (pm_runtime_work) from [<c0156120>] (process_one_work+0x2b4/0x808)
This is because of a race with runtime PM and cppi41_dma_issue_pending()
as reported by Alexandre Bailon <abailon@baylibre.com> in earlier
set of patches. Based on mailing list discussions we however came to the
conclusion that a different fix from Alexandre's fix is needed in order
to guarantee that DMA is really active when we try to use it.
To fix the issue, we need to add a driver specific flag as we otherwise
can have -EINPROGRESS state set by runtime PM and can't rely on
pm_runtime_active() to tell us when we can use the DMA.
And we need to make sure the DMA transfers get triggered in the queued
order. So let's always queue the transfers, then flush the queue
from both cppi41_dma_issue_pending() and cppi41_runtime_resume()
as suggested by Grygorii Strashko <grygorii.strashko@ti.com> in an
earlier example patch.
For reference, this is also documented in Documentation/power/runtime_pm.txt
in the example at the end of the file as pointed out by Grygorii Strashko
<grygorii.strashko@ti.com>.
Based on earlier patches from Alexandre Bailon <abailon@baylibre.com>
and Grygorii Strashko <grygorii.strashko@ti.com> modified based on
testing and what was discussed on the mailing lists.
Fixes: fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support")
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Bin Liu <b-liu@ti.com>
Cc: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Kevin Hilman <khilman@baylibre.com>
Cc: Patrick Titiano <ptitiano@baylibre.com>
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Reported-by: Alexandre Bailon <abailon@baylibre.com>
Tested-by: Bin Liu <b-liu@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit ae4a3e028bb8b59e7cfeb0cc9ef03d885182ce8b upstream.
added runtime PM support for cppi41, but had corner case issues. Some of
the issues were fixed with commit 098de42ad670 ("dmaengine: cppi41: Fix
unpaired pm runtime when only a USB hub is connected"). That fix however
caused a new regression where we can get error -115 messages with USB on
BeagleBone when connecting a USB mass storage device to a hub.
This is because when connecting a USB mass storage device to a hub, the
initial DMA transfers can take over 200ms to complete and cppi41
autosuspend delay times out.
To fix the issue, we want to implement refcounting for chan_busy array
that contains the active dma transfers. Increasing the autosuspend delay
won't help as that the delay could be potentially seconds, and it's best
to let the USB subsystem to deal with the timeouts on errors.
The earlier attempt for runtime PM was buggy as the pm_runtime_get/put()
calls could get unpaired easily as they did not follow the state of
the chan_busy array as described in commit 098de42ad670 ("dmaengine:
cppi41: Fix unpaired pm runtime when only a USB hub is connected".
Let's fix the issue by adding pm_runtime_get() to where a new transfer
is added to the chan_busy array, and calls to pm_runtime_put() where
chan_busy array entry is cleared. This prevents any autosuspend timeouts
from happening while dma transfers are active.
Fixes: 098de42ad670 ("dmaengine: cppi41: Fix unpaired pm runtime when
commit 1aa6cfd33df492939b0be15ebdbcff1f8ae5ddb6 upstream.
The recent conversion to the hotplug state machine kept two mechanisms from
the original code:
1) The first_init logic which adds the number of online CPUs in a package
to the refcount. That's wrong because the callbacks are executed for
all online CPUs.
Remove it so the refcounting is correct.
2) The on_each_cpu() call to undo box->init() in the error handling
path. That's bogus because when the prepare callback fails no box has
been initialized yet.
Remove it.
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: Yasuaki Ishimatsu <yasu.isimatu@gmail.com>
Fixes: 1a246b9f58c6 ("perf/x86/intel/uncore: Convert to hotplug state machine")
Link: http://lkml.kernel.org/r/20170131230141.298032324@linutronix.de
commit 282e4637bc1c0b338708bcebd09d31c69abec070 upstream.
Commit 025bcc1 performed cleanup work on the 'wacom_pl_irq' function, making
it follow the standards used in the rest of the codebase. The change
unintiontionally allowed the function to send input events from reports
that are not marked as being in prox. This can cause problems as the
report values for X, Y, etc. are not guaranteed to be correct. In
particular, occasionally the tablet will send a report with these values
set to zero. If such a report is received it can caus an unexpected jump
in the XY position.
This patch surrounds more of the processing code with a proximity check,
preventing these zeroed reports from overwriting the current state. To
be safe, only the tool type and ABS_MISC events should be reported when
the pen is marked as being out of prox.
Fixes: 025bcc1540 ("HID: wacom: Simplify 'wacom_pl_irq'")
Signed-off-by: Jason Gerecke <jason.gerecke@wacom.com>
Reviewed-by: Ping Cheng <pingc@wacom.com>
commit 877a021e08ccb6434718c0cc781fdf943c884cc0 upstream.
With NOGET quirk Logitech F510 is now fully workable in dinput mode including
rumble effects (according to fftest).
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=117091
[jkosina@suse.cz: fix patch format]
Signed-off-by: Ardinartsev Nikita <ardinar23@gmail.com>
Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit ed9ab4287f96e66340e0390e2c583f2f9110cba0 upstream.
Quirking the following AMI USB device with ALWAYS_POLL fixes an AMI
virtual keyboard and mouse from not responding and timing out when
it is attached to a ppc64el Power 8 system and when we have some
rapid open/closes on the mouse device.
usb 1-3: new high-speed USB device number 2 using xhci_hcd
usb 1-3: New USB device found, idVendor=046b, idProduct=ff01
usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-3: Product: Virtual Hub
usb 1-3: Manufacturer: American Megatrends Inc.
usb 1-3: SerialNumber: serial
usb 1-3.3: new high-speed USB device number 3 using xhci_hcd
usb 1-3.3: New USB device found, idVendor=046b, idProduct=ff31
usb 1-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-3.3: Product: Virtual HardDisk Device
usb 1-3.3: Manufacturer: American Megatrends Inc.
usb 1-3.4: new low-speed USB device number 4 using xhci_hcd
usb 1-3.4: New USB device found, idVendor=046b, idProduct=ff10
usb 1-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-3.4: Product: Virtual Keyboard and Mouse
usb 1-3.4: Manufacturer: American Megatrends Inc.
With the quirk I have not been able to trigger the issue with
half an hour of saturation soak testing.
commit 03c902bff524e0cf664737a33f2365f7837040bf upstream.
When the firmware restarts in a situation in which any station
has no queue reserved anymore because that queue was used, the
code will crash trying to access the queue_info array at the
offset 255, which is far too big. Fix this by checking that a
queue is actually reserved before writing its status.
Fixes: 8d98ae6eb0d5 ("iwlwifi: mvm: re-assign old queues after hw restart in dqa mode")
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
commit 7941c59e45f3b6d30e07375e9b6713427e0a9f98 upstream.
Mistakenly, the driver is trying to load the 8000C firmware with an
incorrect name (i.e. with two hyphens where there should be only one)
and that fails. Fix that by removing the hyphen from the format
macro.
Fixes: e1ba684f762b ("iwlwifi: 8000: fix MODULE_FIRMWARE input")
Signed-off-by: Jürg Billeter <j@bitron.ch>
commit 19b26d92dfb70f56440c187a20c49102ab648b97 upstream.
Not every pin can be configured. Add missed check to prevent access
violation.
Fixes: 4e80c8f50574 ("pinctrl: intel: Add Intel Merrifield pin controller support")
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit 1b89970d81bbd52720fc64a3fe9572ee33588363 upstream.
Debounce value is set globally per community. Otherwise user will easily
get a kernel crash when they start using the feature:
BUG: unable to handle kernel paging request at ffffc900003be000
IP: byt_gpio_dbg_show+0xa9/0x430
Make it clear in byt_gpio_reg().
Note that this fix just prevents kernel to crash, but doesn't make any
difference to the existing logic. It means the last caller will win the
trade and debounce value will be configured accordingly. The actual
logic fix needs to be thought about and it's not as important as crash
fix. That's why the latter goes separately and right now.
Fixes: 658b476c742f ("pinctrl: baytrail: Add debounce configuration")
Cc: Cristina Ciocan <cristina.ciocan@intel.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
commit 0d5415b489f68b58e1983a53793d25d53098ed4b upstream.
This reverts commit c7070619f3408d9a0dffbed9149e6f00479cf43b.
This has been shown to regress on some ARM systems:
by forcing on DMA API usage for ARM systems, we have inadvertently
kicked open a hornets' nest in terms of cache-coherency. Namely that
unless the virtio device is explicitly described as capable of coherent
DMA by firmware, the DMA APIs on ARM and other DT-based platforms will
assume it is non-coherent. This turns out to cause a big problem for the
likes of QEMU and kvmtool, which generate virtio-mmio devices in their
guest DTs but neglect to add the often-overlooked "dma-coherent"
property; as a result, we end up with the guest making non-cacheable
accesses to the vring, the host doing so cacheably, both talking past
each other and things going horribly wrong.
We are working on a safer work-around.
Fixes: c7070619f340 ("vring: Force use of DMA API for ARM-based systems with legacy devices")
Reported-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
commit 7195439d1d71bc4a6c33cfb57bc669a7cd041041 upstream.
This reverts commit 4c81acab3816 ("bcma: init serial console directly
from ChipCommon code") as it broke IRQ assignment. Getting IRQ with
bcma_core_irq helper on SoC requires MIPS core to be set. It happens
*after* ChipCommon initialization so we can't do this so early.
This fixes a user reported regression. It wasn't critical as serial was
still somehow working but lack of IRQs was making in unreliable.
Fixes: 4c81acab3816 ("bcma: init serial console directly from ChipCommon code")
Reported-by: Felix Fietkau <nbd@nbd.name>
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 966d2b04e070bc040319aaebfec09e0144dc3341 upstream.
percpu_ref_tryget() and percpu_ref_tryget_live() should return
"true" IFF they acquire a reference. But the return value from
atomic_long_inc_not_zero() is a long and may have high bits set,
e.g. PERCPU_COUNT_BIAS, and the return value of the tryget routines
is bool so the reference may actually be acquired but the routines
return "false" which results in a reference leak since the caller
assumes it does not need to do a corresponding percpu_ref_put().
This was seen when performing CPU hotplug during I/O, as hangs in
blk_mq_freeze_queue_wait where percpu_ref_kill (blk_mq_freeze_queue_start)
raced with percpu_ref_tryget (blk_mq_timeout_work).
Sample stack trace:
__switch_to+0x2c0/0x450
__schedule+0x2f8/0x970
schedule+0x48/0xc0
blk_mq_freeze_queue_wait+0x94/0x120
blk_mq_queue_reinit_work+0xb8/0x180
blk_mq_queue_reinit_prepare+0x84/0xa0
cpuhp_invoke_callback+0x17c/0x600
cpuhp_up_callbacks+0x58/0x150
_cpu_up+0xf0/0x1c0
do_cpu_up+0x120/0x150
cpu_subsys_online+0x64/0xe0
device_online+0xb4/0x120
online_store+0xb4/0xc0
dev_attr_store+0x68/0xa0
sysfs_kf_write+0x80/0xb0
kernfs_fop_write+0x17c/0x250
__vfs_write+0x6c/0x1e0
vfs_write+0xd0/0x270
SyS_write+0x6c/0x110
system_call+0x38/0xe0
Examination of the queue showed a single reference (no PERCPU_COUNT_BIAS,
and __PERCPU_REF_DEAD, __PERCPU_REF_ATOMIC set) and no requests.
However, conditions at the time of the race are count of PERCPU_COUNT_BIAS + 0
and __PERCPU_REF_DEAD and __PERCPU_REF_ATOMIC set.
The fix is to make the tryget routines use an actual boolean internally instead
of the atomic long result truncated to a int.
Fixes: e625305b3907 percpu-refcount: make percpu_ref based on longs instead of ints
Link: https://bugzilla.kernel.org/show_bug.cgi?id=190751
Signed-off-by: Douglas Miller <dougmill@linux.vnet.ibm.com>
Reviewed-by: Jens Axboe <axboe@fb.com>
Fixes: e625305b3907 ("percpu-refcount: make percpu_ref based on longs instead of ints")
commit d0e287a401d9acf67b75180b26e2d62b7d482652 upstream.
A typo or copy-paste bug means that the register access intended for
regulator dcdce goes to dcdcb instead. This patch corrects it.
Fixes: 2ca342d391e3 (regulator: axp20x: Support AXP806 variant)
Signed-off-by: Rask Ingemann Lambertsen <rask@formelder.dk>
Acked-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit cda8bba0f99d25d2061c531113c14fa41effc3ae upstream.
Currently, under certain circumstances vhost_init_is_le does just a part
of the initialization job, and depends on vhost_reset_is_le being called
too. For this reason vhost_vq_init_access used to call vhost_reset_is_le
when vq->private_data is NULL. This is not only counter intuitive, but
also real a problem because it breaks vhost_net. The bug was introduced to
vhost_net with commit 2751c9882b94 ("vhost: cross-endian support for
legacy devices"). The symptom is corruption of the vq's used.idx field
(virtio) after VHOST_NET_SET_BACKEND was issued as a part of the vhost
shutdown on a vq with pending descriptors.
Let us make sure the outcome of vhost_init_is_le never depend on the state
it is actually supposed to initialize, and fix virtio_net by removing the
reset from vhost_vq_init_access.
With the above, there is no reason for vhost_reset_is_le to do just half
of the job. Let us make vhost_reset_is_le reinitialize is_le.
Signed-off-by: Halil Pasic <pasic@linux.vnet.ibm.com>
Reported-by: Michael A. Tebolt <miket@us.ibm.com>
Reported-by: Dr. David Alan Gilbert <dgilbert@redhat.com>
Fixes: commit 2751c9882b94 ("vhost: cross-endian support for legacy devices")
Reviewed-by: Greg Kurz <groug@kaod.org>
Tested-by: Michael A. Tebolt <miket@us.ibm.com>
commit 161e6d44a5e2d3f85365cb717d60e363171b39e6 upstream.
One of our kernelCI boxes hanged at boot because a faulty eSDHC device
was triggering spurious CARD_INT interrupts for SD cards, causing CMD52
reads, which are not allowed for SD devices. This adds a sanity check
to the interruption path, preventing that illegal command from getting
sent if the CARD_INT interruption should be disabled.
This quirk allows that particular machine to resume boot despite the
faulty hardware, instead of getting hung dealing with thousands of
mishandled interrupts.
Suggested-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Gabriel Krisman Bertazi <krisman@collabora.co.uk>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 07cd12945551b63ecb1a349d50a6d69d1d6feb4a upstream.
While refactoring cgroup creation, a5bca2152036 ("cgroup: factor out
cgroup_create() out of cgroup_mkdir()") incorrectly onlined subsystems
before the new cgroup is associated with it kernfs_node. This is fine
for cgroup proper but cgroup_name/path() depend on the associated
kernfs_node and if a subsystem makes the new cgroup_subsys_state
visible, which they're allowed to after onlining, it can lead to NULL
dereference.
The current code performs cgroup creation and subsystem onlining in
cgroup_create() and cgroup_mkdir() makes the cgroup and subsystems
visible afterwards. There's no reason to online the subsystems early
and we can simply drop cgroup_apply_control_enable() call from
cgroup_create() so that the subsystems are onlined and made visible at
the same time.
Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Fixes: a5bca2152036 ("cgroup: factor out cgroup_create() out of cgroup_mkdir()")
commit a06393ed03167771246c4c43192d9c264bc48412 upstream.
When removing a bcm tx operation either a hrtimer or a tasklet might run.
As the hrtimer triggers its associated tasklet and vice versa we need to
take care to mutually terminate both handlers.
Reported-by: Michael Josenhans <michael.josenhans@web.de>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Tested-by: Michael Josenhans <michael.josenhans@web.de>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 79c6f448c8b79c321e4a1f31f98194e4f6b6cae7 upstream.
The hwlat tracer creates a kernel thread at start of the tracer. It is
pinned to a single CPU and will move to the next CPU after each period of
running. If the user modifies the migration thread's affinity, it will not
change after that happens.
The original code created the thread at the first instance it was called,
but later was changed to destroy the thread after the tracer was finished,
and would not be created until the next instance of the tracer was
established. The code that initialized the affinity was only called on the
initial instantiation of the tracer. After that, it was not initialized, and
the previous affinity did not match the current newly created one, making
it appear that the user modified the thread's affinity when it did not, and
the thread failed to migrate again.
Fixes: 0330f7aa8ee6 ("tracing: Have hwlat trace migrate across tracing_cpumask CPUs")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 5abf186a30a89d5b9c18a6bf93a2c192c9fd52f6 upstream.
do_generic_file_read() can be told to perform a large request from
userspace. If the system is under OOM and the reading task is the OOM
victim then it has an access to memory reserves and finishing the full
request can lead to the full memory depletion which is dangerous. Make
sure we rather go with a short read and allow the killed task to
terminate.
Link: http://lkml.kernel.org/r/20170201092706.9966-3-mhocko@kernel.org
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: <stable@vger.kernel.org>
commit a96dfddbcc04336bbed50dc2b24823e45e09e80c upstream.
Reading a sysfs "memoryN/valid_zones" file leads to the following oops
when the first page of a range is not backed by struct page.
show_valid_zones() assumes that 'start_pfn' is always valid for
page_zone().
BUG: unable to handle kernel paging request at ffffea017a000000
IP: show_valid_zones+0x6f/0x160
This issue may happen on x86-64 systems with 64GiB or more memory since
their memory block size is bumped up to 2GiB. [1] An example of such
systems is desribed below. 0x3240000000 is only aligned by 1GiB and
this memory block starts from 0x3200000000, which is not backed by
struct page.
BIOS-e820: [mem 0x0000003240000000-0x000000603fffffff] usable
Since test_pages_in_a_zone() already checks holes, fix this issue by
extending this function to return 'valid_start' and 'valid_end' for a
given range. show_valid_zones() then proceeds with the valid range.
[1] 'Commit bdee237c0343 ("x86: mm: Use 2GB memory block size on
large-memory x86-64 systems")'
Link: http://lkml.kernel.org/r/20170127222149.30893-3-toshi.kani@hpe.com
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: Reza Arbab <arbab@linux.vnet.ibm.com>
Cc: Dan Williams <dan.j.williams@intel.com>
commit deb88a2a19e85842d79ba96b05031739ec327ff4 upstream.
Patch series "fix a kernel oops when reading sysfs valid_zones", v2.
A sysfs memory file is created for each 2GiB memory block on x86-64 when
the system has 64GiB or more memory. [1] When the start address of a
memory block is not backed by struct page, i.e. a memory range is not
aligned by 2GiB, reading its 'valid_zones' attribute file leads to a
kernel oops. This issue was observed on multiple x86-64 systems with
more than 64GiB of memory. This patch-set fixes this issue.
Patch 1 first fixes an issue in test_pages_in_a_zone(), which does not
test the start section.
Patch 2 then fixes the kernel oops by extending test_pages_in_a_zone()
to return valid [start, end).
Note for stable kernels: The memory block size change was made by commit
bdee237c0343 ("x86: mm: Use 2GB memory block size on large-memory x86-64
systems"), which was accepted to 3.9. However, this patch-set depends
on (and fixes) the change to test_pages_in_a_zone() made by commit
5f0f2887f4de ("mm/memory_hotplug.c: check for missing sections in
test_pages_in_a_zone()"), which was accepted to 4.4.
So, I recommend that we backport it up to 4.4.
This patch (of 2):
test_pages_in_a_zone() does not check 'start_pfn' when it is aligned by
section since 'sec_end_pfn' is set equal to 'pfn'. Since this function
is called for testing the range of a sysfs memory file, 'start_pfn' is
always aligned by section.
Fix it by properly setting 'sec_end_pfn' to the next section pfn.
Also make sure that this function returns 1 only when the range belongs
to a zone.
Link: http://lkml.kernel.org/r/20170127222149.30893-2-toshi.kani@hpe.com
Cc: Andrew Banman <abanman@sgi.com>
Cc: Greg KH <greg@kroah.com>
commit 81ddd8c0c5e1cb41184d66567140cb48c53eb3d1 upstream.
Reviewed-by: Jeff Layton <jlayton@redhat.com>
file_info_lock is not initalized in initiate_cifs_search(), leading to the
following splat after a simple "mount.cifs ... dir && ls dir/":
BUG: spinlock bad magic on CPU#0, ls/486
lock: 0xffff880009301110, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
CPU: 0 PID: 486 Comm: ls Not tainted 4.9.0 #27
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996)
ffffc900042f3db0 ffffffff81327533 0000000000000000 ffff880009301110
ffffc900042f3dd0 ffffffff810baf75 ffff880009301110 ffffffff817ae077
ffffc900042f3df0 ffffffff810baff6 ffff880009301110 ffff880008d69900
Call Trace:
[<ffffffff81327533>] dump_stack+0x65/0x92
[<ffffffff810baf75>] spin_dump+0x85/0xe0
[<ffffffff810baff6>] spin_bug+0x26/0x30
[<ffffffff810bb159>] do_raw_spin_lock+0xe9/0x130
[<ffffffff8159ad2f>] _raw_spin_lock+0x1f/0x30
[<ffffffff8127e50d>] cifs_closedir+0x4d/0x100
[<ffffffff81181cfd>] __fput+0x5d/0x160
[<ffffffff81181e3e>] ____fput+0xe/0x10
[<ffffffff8109410e>] task_work_run+0x7e/0xa0
[<ffffffff81002512>] exit_to_usermode_loop+0x92/0xa0
[<ffffffff810026f9>] syscall_return_slowpath+0x49/0x50
[<ffffffff8159b484>] entry_SYSCALL_64_fastpath+0xa7/0xa9
Fixes: 3afca265b5f53a0 ("Clarify locking of cifs file and tcon structures and make more granular")
Signed-off-by: Rabin Vincent <rabinv@axis.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit d7b028f56a971a2e4d8d7887540a144eeefcd4ab upstream.
Add zswap_init_failed bool that prevents changing any of the module
params, if init_zswap() fails, and set zswap_enabled to false. Change
'enabled' param to a callback, and check zswap_init_failed before
allowing any change to 'enabled', 'zpool', or 'compressor' params.
Any driver that is built-in to the kernel will not be unloaded if its
init function returns error, and its module params remain accessible for
users to change via sysfs. Since zswap uses param callbacks, which
assume that zswap has been initialized, changing the zswap params after
a failed initialization will result in WARNING due to the param
callbacks expecting a pool to already exist. This prevents that by
immediately exiting any of the param callbacks if initialization failed.
This was reported here:
https://marc.info/?l=linux-mm&m=147004228125528&w=4
And fixes this WARNING:
[ 429.723476] WARNING: CPU: 0 PID: 5140 at mm/zswap.c:503 __zswap_pool_current+0x56/0x60
The warning is just noise, and not serious. However, when init fails,
zswap frees all its percpu dstmem pages and its kmem cache. The kmem
cache might be serious, if kmem_cache_alloc(NULL, gfp) has problems; but
the percpu dstmem pages are definitely a problem, as they're used as
temporary buffer for compressed pages before copying into place in the
zpool.
If the user does get zswap enabled after an init failure, then zswap
will likely Oops on the first page it tries to compress (or worse, start
corrupting memory).
Fixes: 90b0fc26d5db ("zswap: change zpool/compressor at runtime")
Link: http://lkml.kernel.org/r/20170124200259.16191-2-ddstreet@ieee.org
Signed-off-by: Dan Streetman <dan.streetman@canonical.com>
Reported-by: Marcin Miroslaw <marcin@mejor.pl>
Cc: Seth Jennings <sjenning@redhat.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
commit 034dd34ff4916ec1f8f74e39ca3efb04eab2f791 upstream.
Olga Kornievskaia says: "I ran into this oops in the nfsd (below)
(4.10-rc3 kernel). To trigger this I had a client (unsuccessfully) try
to mount the server with krb5 where the server doesn't have the
rpcsec_gss_krb5 module built."
The problem is that rsci.cred is copied from a svc_cred structure that
gss_proxy didn't properly initialize. Fix that.
[120408.542387] general protection fault: 0000 [#1] SMP
[120408.565724] CPU: 0 PID: 3601 Comm: nfsd Not tainted 4.10.0-rc3+ #16
[120408.567037] Hardware name: VMware, Inc. VMware Virtual =
Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015
[120408.569225] task: ffff8800776f95c0 task.stack: ffffc90003d58000
[120408.570483] RIP: 0010:gss_mech_put+0xb/0x20 [auth_rpcgss]
[120408.584946] ? rsc_free+0x55/0x90 [auth_rpcgss]
[120408.585901] gss_proxy_save_rsc+0xb2/0x2a0 [auth_rpcgss]
[120408.587017] svcauth_gss_proxy_init+0x3cc/0x520 [auth_rpcgss]
[120408.588257] ? __enqueue_entity+0x6c/0x70
[120408.589101] svcauth_gss_accept+0x391/0xb90 [auth_rpcgss]
[120408.590212] ? try_to_wake_up+0x4a/0x360
[120408.591036] ? wake_up_process+0x15/0x20
[120408.592093] ? svc_xprt_do_enqueue+0x12e/0x2d0 [sunrpc]
[120408.593177] svc_authenticate+0xe1/0x100 [sunrpc]
[120408.594168] svc_process_common+0x203/0x710 [sunrpc]
[120408.595220] svc_process+0x105/0x1c0 [sunrpc]
[120408.596278] nfsd+0xe9/0x160 [nfsd]
[120408.597060] kthread+0x101/0x140
[120408.597734] ? nfsd_destroy+0x60/0x60 [nfsd]
[120408.598626] ? kthread_park+0x90/0x90
[120408.599448] ret_from_fork+0x22/0x30
Fixes: 1d658336b05f "SUNRPC: Add RPC based upcall mechanism for RPCGSS auth"
Cc: Simo Sorce <simo@redhat.com>
Reported-by: Olga Kornievskaia <kolga@netapp.com>
Tested-by: Olga Kornievskaia <kolga@netapp.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit d19fb70dd68c4e960e2ac09b0b9c79dfdeefa726 upstream.
nfsd assigns the nfs4_free_lock_stateid to .sc_free in init_lock_stateid().
If nfsd doesn't go through init_lock_stateid() and put stateid at end,
there is a NULL reference to .sc_free when calling nfs4_put_stid(ns).
This patch let the nfs4_stid.sc_free assignment to nfs4_alloc_stid().
Fixes: 356a95ece7aa "nfsd: clean up races in lock stateid searching..."
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
commit a0615a16f7d0ceb5804d295203c302d496d8ee91 upstream.
When setting a 2MB pte, radix__map_kernel_page() is using the address
ptep = (pte_t *)pudp;
Fix this conversion to use pmdp instead. Use pmdp_ptep() to do this
instead of casting the pointer.
Fixes: 2bfd65e45e87 ("powerpc/mm/radix: Add radix callbacks for early init routines")
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Reza Arbab <arbab@linux.vnet.ibm.com>
commit b5fa0f7f88edcde37df1807fdf9ff10ec787a60e upstream.
Anton says: In commit 4db7327194db ("powerpc: Add option to use jump
label for cpu_has_feature()") and commit c12e6f24d413 ("powerpc: Add
option to use jump label for mmu_has_feature()") we added:
BUILD_BUG_ON(!__builtin_constant_p(feature))
to cpu_has_feature() and mmu_has_feature() in order to catch usage
issues (such as cpu_has_feature(cpu_has_feature(X), which has happened
once in the past). Unfortunately LLVM isn't smart enough to resolve
this, and it errors out.
I work around it in my clang/LLVM builds of the kernel, but I have just
discovered that it causes a lot of issues for the bcc (eBPF) trace tool
(which uses LLVM).
For now just #ifdef it away for clang builds.
Fixes: 4db7327194db ("powerpc: Add option to use jump label for cpu_has_feature()")
Fixes: c12e6f24d413 ("powerpc: Add option to use jump label for mmu_has_feature()")
Reported-by: Anton Blanchard <anton@samba.org>
Tested-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
commit af2b7fa17eb92e52b65f96604448ff7a2a89ee99 upstream.
prom_init.c calls 'instance-to-package' twice, but the return
is not checked during prom_find_boot_cpu(). The result is then
passed to prom_getprop(), which could be PROM_ERROR. Add a return check
to prevent this.
This was found on a pasemi system, where CFE doesn't have a working
'instance-to package' prom call.
Before Commit 5c0484e25ec0 ('powerpc: Endian safe trampoline') the area
around addr 0 was mostly 0's and this doesn't cause a problem. Once the
macro 'FIXUP_ENDIAN' has been added to head_64.S, the low memory area
now has non-zero values, which cause the prom_getprop() call
to hang.
mpe: Also confirmed that under SLOF if 'instance-to-package' did fail
with PROM_ERROR we would crash in SLOF. So the bug is not specific to
CFE, it's just that other open firmwares don't trigger it because they
have a working 'instance-to-package'.
Fixes: 5c0484e25ec0 ("powerpc: Endian safe trampoline")
Signed-off-by: Darren Stevens <darren@stevens-zone.net>
commit f05fea5b3574a5926c53865eea27139bb40b2f2b upstream.
In __eeh_clear_pe_frozen_state(), we should pass the flag's value
instead of its address to eeh_unfreeze_pe(). The isolated flag is
cleared if no error returned from __eeh_clear_pe_frozen_state(). We
never observed the error from the function. So the isolated flag should
have been always cleared, no real issue is caused because of the misused
@flag.
This fixes the code by passing the value of @flag to eeh_unfreeze_pe().
Fixes: 5cfb20b96f6 ("powerpc/eeh: Emulate EEH recovery for VFIO devices")
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit 2dae99558e86894e9e5dbf097477baaa5eb70134 upstream.
For an ATA device supporting the sense data reporting feature set, a
failed command will trigger the execution of ata_eh_request_sense if
the result task file of the failed command has the ATA_SENSE bit set
(sense data available bit). ata_eh_request_sense executes the REQUEST
SENSE DATA EXT command to retrieve the sense data of the failed
command. On success of REQUEST SENSE DATA EXT, the ATA_SENSE bit will
NOT be set (the command succeeded) but ata_eh_request_sense
nevertheless tests the availability of sense data by testing that bit
presence in the result tf of the REQUEST SENSE DATA EXT command. This
leads us to falsely assume that request sense data failed and to the
warning message:
atax.xx: request sense failed stat 50 emask 0
Upon success of REQUEST SENSE DATA EXT, set the ATA_SENSE bit in the
result task file command so that sense data can be returned by
ata_eh_request_sense.
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
