commit 749494b6bdbbaf0899aa1c62a1ad74cd747bce47 upstream.
Since commit: ba1582f22231 ("usb: gadget: f_hid: use alloc_ep_req()")
we cannot allocate any requests in bind() as we check if we should
align request buffer based on endpoint descriptor which is assigned
in set_alt().
Allocating request in bind() function causes a NULL pointer
dereference.
This commit moves allocation of IN request from bind() to set_alt()
to prevent this issue.
Fixes: ba1582f22231 ("usb: gadget: f_hid: use alloc_ep_req()")
Cc: stable@vger.kernel.org
Tested-by: David Lechner <david@lechnology.com>
Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Cc: Bin Liu <b-liu@ti.com>
commit 0c81ffc60d5280991773d17e84bda605387148b1 upstream.
Users can provide garbage while calling to ucma_join_ip_multicast(),
it will indirectly cause to rdma_addr_size() return 0, making the
call to ucma_process_join(), which had the right checks, but it is
better to check the input as early as possible.
The following crash from syzkaller revealed it.
kernel BUG at lib/string.c:1052!
invalid opcode: 0000 [#1] SMP KASAN Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 0 PID: 4113 Comm: syz-executor0 Not tainted 4.16.0-rc5+ #261
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:fortify_panic+0x13/0x20 lib/string.c:1051
RSP: 0018:ffff8801ca81f8f0 EFLAGS: 00010286
RAX: 0000000000000022 RBX: 1ffff10039503f23 RCX: 0000000000000000
RDX: 0000000000000022 RSI: 1ffff10039503ed3 RDI: ffffed0039503f12
RBP: ffff8801ca81f8f0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000006 R11: 0000000000000000 R12: ffff8801ca81f998
R13: ffff8801ca81f938 R14: ffff8801ca81fa58 R15: 000000000000fa00
FS: 0000000000000000(0000) GS:ffff8801db200000(0063) knlGS:000000000a12a900
CS: 0010 DS: 002b ES: 002b CR0: 0000000080050033
CR2: 0000000008138024 CR3: 00000001cbb58004 CR4: 00000000001606f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
memcpy include/linux/string.h:344 [inline]
ucma_join_ip_multicast+0x36b/0x3b0 drivers/infiniband/core/ucma.c:1421
ucma_write+0x2d6/0x3d0 drivers/infiniband/core/ucma.c:1633
__vfs_write+0xef/0x970 fs/read_write.c:480
vfs_write+0x189/0x510 fs/read_write.c:544
SYSC_write fs/read_write.c:589 [inline]
SyS_write+0xef/0x220 fs/read_write.c:581
do_syscall_32_irqs_on arch/x86/entry/common.c:330 [inline]
do_fast_syscall_32+0x3ec/0xf9f arch/x86/entry/common.c:392
entry_SYSENTER_compat+0x70/0x7f arch/x86/entry/entry_64_compat.S:139
RIP: 0023:0xf7f9ec99
RSP: 002b:00000000ff8172cc EFLAGS: 00000282 ORIG_RAX: 0000000000000004
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000020000100
RDX: 0000000000000063 RSI: 0000000000000000 RDI: 0000000000000000
RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
Code: 08 5b 41 5c 41 5d 41 5e 41 5f 5d c3 0f 0b 48 89 df e8 42 2c e3 fb eb de
55 48 89 fe 48 c7 c7 80 75 98 86 48 89 e5 e8 85 95 94 fb <0f> 0b 90 90 90 90
90 90 90 90 90 90 90 55 48 89 e5 41 57 41 56
RIP: fortify_panic+0x13/0x20 lib/string.c:1051 RSP: ffff8801ca81f8f0
Fixes: 5bc2b7b397b0 ("RDMA/ucma: Allow user space to specify AF_IB when joining multicast")
Reported-by: <syzbot+2287ac532caa81900a4e@syzkaller.appspotmail.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Sean Hefty <sean.hefty@intel.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 7688f2c3bbf55e52388e37ac5d63ca471a7712e1 upstream.
The attempt to join multicast group without ensuring that CMA device
exists will lead to the following crash reported by syzkaller.
[ 64.076794] BUG: KASAN: null-ptr-deref in rdma_join_multicast+0x26e/0x12c0
[ 64.076797] Read of size 8 at addr 00000000000000b0 by task join/691
[ 64.076797]
[ 64.076800] CPU: 1 PID: 691 Comm: join Not tainted 4.16.0-rc1-00219-gb97853b65b93 #23
[ 64.076802] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.11.0-0-g63451fca13-prebuilt.qemu-proj4
[ 64.076803] Call Trace:
[ 64.076809] dump_stack+0x5c/0x77
[ 64.076817] kasan_report+0x163/0x380
[ 64.085859] ? rdma_join_multicast+0x26e/0x12c0
[ 64.086634] rdma_join_multicast+0x26e/0x12c0
[ 64.087370] ? rdma_disconnect+0xf0/0xf0
[ 64.088579] ? __radix_tree_replace+0xc3/0x110
[ 64.089132] ? node_tag_clear+0x81/0xb0
[ 64.089606] ? idr_alloc_u32+0x12e/0x1a0
[ 64.090517] ? __fprop_inc_percpu_max+0x150/0x150
[ 64.091768] ? tracing_record_taskinfo+0x10/0xc0
[ 64.092340] ? idr_alloc+0x76/0xc0
[ 64.092951] ? idr_alloc_u32+0x1a0/0x1a0
[ 64.093632] ? ucma_process_join+0x23d/0x460
[ 64.094510] ucma_process_join+0x23d/0x460
[ 64.095199] ? ucma_migrate_id+0x440/0x440
[ 64.095696] ? futex_wake+0x10b/0x2a0
[ 64.096159] ucma_join_multicast+0x88/0xe0
[ 64.096660] ? ucma_process_join+0x460/0x460
[ 64.097540] ? _copy_from_user+0x5e/0x90
[ 64.098017] ucma_write+0x174/0x1f0
[ 64.098640] ? ucma_resolve_route+0xf0/0xf0
[ 64.099343] ? rb_erase_cached+0x6c7/0x7f0
[ 64.099839] __vfs_write+0xc4/0x350
[ 64.100622] ? perf_syscall_enter+0xe4/0x5f0
[ 64.101335] ? kernel_read+0xa0/0xa0
[ 64.103525] ? perf_sched_cb_inc+0xc0/0xc0
[ 64.105510] ? syscall_exit_register+0x2a0/0x2a0
[ 64.107359] ? __switch_to+0x351/0x640
[ 64.109285] ? fsnotify+0x899/0x8f0
[ 64.111610] ? fsnotify_unmount_inodes+0x170/0x170
[ 64.113876] ? __fsnotify_update_child_dentry_flags+0x30/0x30
[ 64.115813] ? ring_buffer_record_is_on+0xd/0x20
[ 64.117824] ? __fget+0xa8/0xf0
[ 64.119869] vfs_write+0xf7/0x280
[ 64.122001] SyS_write+0xa1/0x120
[ 64.124213] ? SyS_read+0x120/0x120
[ 64.126644] ? SyS_read+0x120/0x120
[ 64.128563] do_syscall_64+0xeb/0x250
[ 64.130732] entry_SYSCALL_64_after_hwframe+0x21/0x86
[ 64.132984] RIP: 0033:0x7f5c994ade99
[ 64.135699] RSP: 002b:00007f5c99b97d98 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 64.138740] RAX: ffffffffffffffda RBX: 00000000200001e4 RCX: 00007f5c994ade99
[ 64.141056] RDX: 00000000000000a0 RSI: 00000000200001c0 RDI: 0000000000000015
[ 64.143536] RBP: 00007f5c99b97ec0 R08: 0000000000000000 R09: 0000000000000000
[ 64.146017] R10: 0000000000000000 R11: 0000000000000246 R12: 00007f5c99b97fc0
[ 64.148608] R13: 0000000000000000 R14: 00007fff660e1c40 R15: 00007f5c99b989c0
[ 64.151060]
[ 64.153703] Disabling lock debugging due to kernel taint
[ 64.156032] BUG: unable to handle kernel NULL pointer dereference at 00000000000000b0
[ 64.159066] IP: rdma_join_multicast+0x26e/0x12c0
[ 64.161451] PGD 80000001d0298067 P4D 80000001d0298067 PUD 1dea39067 PMD 0
[ 64.164442] Oops: 0000 [#1] SMP KASAN PTI
[ 64.166817] CPU: 1 PID: 691 Comm: join Tainted: G B 4.16.0-rc1-00219-gb97853b65b93 #23
[ 64.170004] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.11.0-0-g63451fca13-prebuilt.qemu-proj4
[ 64.174985] RIP: 0010:rdma_join_multicast+0x26e/0x12c0
[ 64.177246] RSP: 0018:ffff8801c8207860 EFLAGS: 00010282
[ 64.179901] RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffffffff94789522
[ 64.183344] RDX: 1ffffffff2d50fa5 RSI: 0000000000000297 RDI: 0000000000000297
[ 64.186237] RBP: ffff8801c8207a50 R08: 0000000000000000 R09: ffffed0039040ea7
[ 64.189328] R10: 0000000000000001 R11: ffffed0039040ea6 R12: 0000000000000000
[ 64.192634] R13: 0000000000000000 R14: ffff8801e2022800 R15: ffff8801d4ac2400
[ 64.196105] FS: 00007f5c99b98700(0000) GS:ffff8801e5d00000(0000) knlGS:0000000000000000
[ 64.199211] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 64.202046] CR2: 00000000000000b0 CR3: 00000001d1c48004 CR4: 00000000003606a0
[ 64.205032] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 64.208221] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 64.211554] Call Trace:
[ 64.213464] ? rdma_disconnect+0xf0/0xf0
[ 64.216124] ? __radix_tree_replace+0xc3/0x110
[ 64.219337] ? node_tag_clear+0x81/0xb0
[ 64.222140] ? idr_alloc_u32+0x12e/0x1a0
[ 64.224422] ? __fprop_inc_percpu_max+0x150/0x150
[ 64.226588] ? tracing_record_taskinfo+0x10/0xc0
[ 64.229763] ? idr_alloc+0x76/0xc0
[ 64.232186] ? idr_alloc_u32+0x1a0/0x1a0
[ 64.234505] ? ucma_process_join+0x23d/0x460
[ 64.237024] ucma_process_join+0x23d/0x460
[ 64.240076] ? ucma_migrate_id+0x440/0x440
[ 64.243284] ? futex_wake+0x10b/0x2a0
[ 64.245302] ucma_join_multicast+0x88/0xe0
[ 64.247783] ? ucma_process_join+0x460/0x460
[ 64.250841] ? _copy_from_user+0x5e/0x90
[ 64.253878] ucma_write+0x174/0x1f0
[ 64.257008] ? ucma_resolve_route+0xf0/0xf0
[ 64.259877] ? rb_erase_cached+0x6c7/0x7f0
[ 64.262746] __vfs_write+0xc4/0x350
[ 64.265537] ? perf_syscall_enter+0xe4/0x5f0
[ 64.267792] ? kernel_read+0xa0/0xa0
[ 64.270358] ? perf_sched_cb_inc+0xc0/0xc0
[ 64.272575] ? syscall_exit_register+0x2a0/0x2a0
[ 64.275367] ? __switch_to+0x351/0x640
[ 64.277700] ? fsnotify+0x899/0x8f0
[ 64.280530] ? fsnotify_unmount_inodes+0x170/0x170
[ 64.283156] ? __fsnotify_update_child_dentry_flags+0x30/0x30
[ 64.286182] ? ring_buffer_record_is_on+0xd/0x20
[ 64.288749] ? __fget+0xa8/0xf0
[ 64.291136] vfs_write+0xf7/0x280
[ 64.292972] SyS_write+0xa1/0x120
[ 64.294965] ? SyS_read+0x120/0x120
[ 64.297474] ? SyS_read+0x120/0x120
[ 64.299751] do_syscall_64+0xeb/0x250
[ 64.301826] entry_SYSCALL_64_after_hwframe+0x21/0x86
[ 64.304352] RIP: 0033:0x7f5c994ade99
[ 64.306711] RSP: 002b:00007f5c99b97d98 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 64.309577] RAX: ffffffffffffffda RBX: 00000000200001e4 RCX: 00007f5c994ade99
[ 64.312334] RDX: 00000000000000a0 RSI: 00000000200001c0 RDI: 0000000000000015
[ 64.315783] RBP: 00007f5c99b97ec0 R08: 0000000000000000 R09: 0000000000000000
[ 64.318365] R10: 0000000000000000 R11: 0000000000000246 R12: 00007f5c99b97fc0
[ 64.320980] R13: 0000000000000000 R14: 00007fff660e1c40 R15: 00007f5c99b989c0
[ 64.323515] Code: e8 e8 79 08 ff 4c 89 ff 45 0f b6 a7 b8 01 00 00 e8 68 7c 08 ff 49 8b 1f 4d 89 e5 49 c1 e4 04 48 8
[ 64.330753] RIP: rdma_join_multicast+0x26e/0x12c0 RSP: ffff8801c8207860
[ 64.332979] CR2: 00000000000000b0
[ 64.335550] ---[ end trace 0c00c17a408849c1 ]---
Reported-by: <syzbot+e6aba77967bd72cbc9d6@syzkaller.appspotmail.com>
Fixes: c8f6a362bf3e ("RDMA/cma: Add multicast communication support")
commit 99652a469df19086d594e8e89757d4081a812789 upstream.
The orphan clocks reparents should migrate any existing count from the
orphan clock to its new acestor clocks, otherwise we may have
inconsistent counts in the tree and end-up with gated critical clocks
Assuming we have two clocks, A and B.
* Clock A has CLK_IS_CRITICAL flag set.
* Clock B is an ancestor of A which can gate. Clock B gate is left
enabled by the bootloader.
Step 1: Clock A is registered. Since it is a critical clock, it is
enabled. The clock being still an orphan, no parent are enabled.
Step 2: Clock B is registered and reparented to clock A (potentially
through several other clocks). We are now in situation where the enable
count of clock A is 1 while the enable count of its ancestors is 0, which
is not good.
Step 3: in lateinit, clk_disable_unused() is called, the enable_count of
clock B being 0, clock B is gated and and critical clock A actually gets
disabled.
This situation was found while adding fdiv_clk gates to the meson8b
platform. These clocks parent clk81 critical clock, which is the mother
of all peripheral clocks in this system. Because of the issue described
here, the system is crashing when clk_disable_unused() is called.
The situation is solved by reverting
commit f8f8f1d04494 ("clk: Don't touch hardware when reparenting during registration").
To avoid breaking again the situation described in this commit
description, enabling critical clock should be done before walking the
orphan list. This way, a parent critical clock may not be accidentally
disabled due to the CLK_OPS_PARENT_ENABLE mechanism.
Fixes: f8f8f1d04494 ("clk: Don't touch hardware when reparenting during registration")
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Dong Aisheng <aisheng.dong@nxp.com>
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Michael Turquette <mturquette@baylibre.com>
commit 2c292dbb398ee46fc1343daf6c3cf9715a75688e upstream.
Add a check for the length of the qpin structure to prevent out-of-bounds reads
BUG: KASAN: slab-out-of-bounds in create_raw_packet_qp+0x114c/0x15e2
Read of size 8192 at addr ffff880066b99290 by task syz-executor3/549
CPU: 3 PID: 549 Comm: syz-executor3 Not tainted 4.15.0-rc2+ #27 Hardware
name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5-0-ge51488c-20140602_164612-nilsson.home.kraxel.org 04/01/2014
Call Trace:
dump_stack+0x8d/0xd4
print_address_description+0x73/0x290
kasan_report+0x25c/0x370
? create_raw_packet_qp+0x114c/0x15e2
memcpy+0x1f/0x50
? create_raw_packet_qp_tis.isra.28+0x13d/0x13d
? lock_acquire+0x370/0x370
create_qp_common+0x2245/0x3b50
? destroy_qp_user.isra.47+0x100/0x100
? kasan_kmalloc+0x13d/0x170
? sched_clock_cpu+0x18/0x180
? fs_reclaim_acquire.part.15+0x5/0x30
? __lock_acquire+0xa11/0x1da0
? kmem_cache_alloc_trace+0x17e/0x310
? mlx5_ib_create_qp+0x30e/0x17b0
mlx5_ib_create_qp+0x33d/0x17b0
? create_qp_common+0x3b50/0x3b50
? __radix_tree_lookup+0x180/0x220
? uverbs_try_lock_object+0x68/0xc0
? rdma_lookup_get_uobject+0x114/0x240
create_qp.isra.5+0xce4/0x1e20
? ib_uverbs_ex_create_cq_cb+0xa0/0xa0
? copy_ah_attr_from_uverbs.isra.2+0xa00/0xa00
? ib_uverbs_cq_event_handler+0x160/0x160
? __might_fault+0x17c/0x1c0
ib_uverbs_create_qp+0x21b/0x2a0
? ib_uverbs_destroy_cq+0x2e0/0x2e0
ib_uverbs_write+0x55a/0xad0
? ib_uverbs_open+0x760/0x760
? futex_wake+0x147/0x410
? check_prev_add+0x1680/0x1680
? do_futex+0x3d3/0xa60
__vfs_write+0xf7/0x5c0
? kernel_read+0x110/0x110
? __fget+0x264/0x3b0
vfs_write+0x18a/0x460
SyS_write+0xc7/0x1a0
? SyS_read+0x1a0/0x1a0
? trace_hardirqs_on_thunk+0x1a/0x1c
entry_SYSCALL_64_fastpath+0x18/0x85
RIP: 0033:0x4477b9
RSP: 002b:00007f1822cadc18 EFLAGS: 00000292 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 00000000004477b9
RDX: 0000000000000070 RSI: 000000002000a000 RDI: 0000000000000005
RBP: 0000000000708000 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000292 R12: 00000000ffffffff
R13: 0000000000005d70 R14: 00000000006e6e30 R15: 0000000020010ff0
Allocated by task 549:
__kmalloc+0x15e/0x340
kvmalloc_node+0xa1/0xd0
create_user_qp.isra.46+0xd42/0x1610
create_qp_common+0x2e63/0x3b50
Freed by task 368:
kfree+0xeb/0x2f0
kernfs_fop_release+0x140/0x180
__fput+0x266/0x700
task_work_run+0x104/0x180
exit_to_usermode_loop+0xf7/0x110
syscall_return_slowpath+0x298/0x370
entry_SYSCALL_64_fastpath+0x83/0x85
The buggy address belongs to the object at ffff880066b99180 which
belongs to the cache kmalloc-512 of size 512 The buggy address is
located 272 bytes inside of 512-byte region [ffff880066b99180,
ffff880066b99380) The buggy address belongs to the page:
page:000000006040eedd count:1 mapcount:0 mapping: (null)
index:0x0 compound_mapcount: 0
flags: 0x4000000000008100(slab|head)
raw: 4000000000008100 0000000000000000 0000000000000000 0000000180190019
raw: ffffea00019a7500 0000000b0000000b ffff88006c403080 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff880066b99180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff880066b99200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffff880066b99280: 00 00 fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff880066b99300: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff880066b99380: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Cc: syzkaller <syzkaller@googlegroups.com>
Fixes: 0fb2ed66a14c ("IB/mlx5: Add create and destroy functionality for Raw Packet QP")
Signed-off-by: Boris Pismenny <borisp@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
commit c2b37f76485f073f020e60b5954b6dc4e55f693c upstream.
This patch validates user provided input to prevent integer overflow due
to integer manipulation in the mlx5_ib_create_srq function.
Fixes: e126ba97dba9 ("mlx5: Add driver for Mellanox Connect-IB adapters")
[ Upstream commit d087f15786021a9605b20f4c678312510be4cac1 ]
Register layout of a typical TPCC_EVT_MUX_M_N register is such that the
lowest numbered event is at the lowest byte address and highest numbered
event at highest byte address. But TPCC_EVT_MUX_60_63 register layout is
different, in that the lowest numbered event is at the highest address
and highest numbered event is at the lowest address. Therefore, modify
ti_am335x_xbar_write() to handle TPCC_EVT_MUX_60_63 register
accordingly.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit cdba9a4fb0b53703959ac861e415816cb61aded4 ]
This drivers probe fails due to a clock name collision if a clock named
'plla' or 'pllb' is already registered when registering this drivers
internal plls.
Fix it by renaming internal plls to avoid name collisions.
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Rabeeh Khoury <rabeeh@solid-run.com>
Signed-off-by: Sergej Sawazki <sergej@taudac.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[ Upstream commit 063578dc5f407f67d149133818efabe457daafda ]
If the nocount bit is set the divider is bypassed and the settings for the
divider count should be ignored and a divider value of 1 should be assumed.
Handle this correctly in the driver recalc_rate() callback.
While the driver sets up the part so that the read back dividers values
yield the correct result the power-on reset settings of the part might not
reflect this and hence calling e.g. clk_get_rate() without prior calls to
clk_set_rate() will yield the wrong result.
[ Upstream commit f8f8f1d04494d3a6546bee3f0618c4dba31d7b72 ]
The orphan clocks reparent operation shouldn't touch the hardware
if clocks are enabled, otherwise it may get a chance to disable a
newly registered critical clock which triggers the warning below.
Assuming we have two clocks: A and B, B is the parent of A.
Clock A has flag: CLK_OPS_PARENT_ENABLE
Clock B has flag: CLK_IS_CRITICAL
Step 1:
Clock A is registered, then it becomes orphan.
Step 2:
Clock B is registered. Before clock B reach the critical clock enable
operation, orphan A will find the newly registered parent B and do
reparent operation, then parent B will be finally disabled in
__clk_set_parent_after() due to CLK_OPS_PARENT_ENABLE flag as there's
still no users of B which will then trigger the following warning.
WARNING: CPU: 0 PID: 0 at drivers/clk/clk.c:597 clk_core_disable+0xb4/0xe0
Modules linked in:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.11.0-rc1-00056-gdff1f66-dirty #1373
Hardware name: Generic DT based system
Backtrace:
[<c010c4bc>] (dump_backtrace) from [<c010c764>] (show_stack+0x18/0x1c)
r6:600000d3 r5:00000000 r4:c0e26358 r3:00000000
[<c010c74c>] (show_stack) from [<c040599c>] (dump_stack+0xb4/0xe8)
[<c04058e8>] (dump_stack) from [<c0125c94>] (__warn+0xd8/0x104)
r10:c0c21cd0 r9:c048aa78 r8:00000255 r7:00000009 r6:c0c1cd90 r5:00000000
r4:00000000 r3:c0e01d34
[<c0125bbc>] (__warn) from [<c0125d74>] (warn_slowpath_null+0x28/0x30)
r9:00000000 r8:ef00bf80 r7:c165ac4c r6:ef00bf80 r5:ef00bf80 r4:ef00bf80
[<c0125d4c>] (warn_slowpath_null) from [<c048aa78>] (clk_core_disable+0xb4/0xe0)
[<c048a9c4>] (clk_core_disable) from [<c048be88>] (clk_core_disable_lock+0x20/0x2c)
r4:000000d3 r3:c0e0af00
[<c048be68>] (clk_core_disable_lock) from [<c048c224>] (clk_core_disable_unprepare+0x14/0x28)
r5:00000000 r4:ef00bf80
[<c048c210>] (clk_core_disable_unprepare) from [<c048c270>] (__clk_set_parent_after+0x38/0x54)
r4:ef00bd80 r3:000010a0
[<c048c238>] (__clk_set_parent_after) from [<c048daa8>] (clk_register+0x4d0/0x648)
r6:ef00d500 r5:ef00bf80 r4:ef00bd80 r3:ef00bfd4
[<c048d5d8>] (clk_register) from [<c048dc30>] (clk_hw_register+0x10/0x1c)
r9:00000000 r8:00000003 r7:00000000 r6:00000824 r5:00000001 r4:ef00d500
[<c048dc20>] (clk_hw_register) from [<c048e698>] (_register_divider+0xcc/0x120)
[<c048e5cc>] (_register_divider) from [<c048e730>] (clk_register_divider+0x44/0x54)
r10:00000004 r9:00000003 r8:00000001 r7:00000000 r6:00000003 r5:00000001
r4:f0810030
[<c048e6ec>] (clk_register_divider) from [<c0d3ff58>] (imx7ulp_clocks_init+0x558/0xe98)
r7:c0e296f8 r6:c165c808 r5:00000000 r4:c165c808
[<c0d3fa00>] (imx7ulp_clocks_init) from [<c0d24db0>] (of_clk_init+0x118/0x1e0)
r10:00000001 r9:c0e01f68 r8:00000000 r7:c0e01f60 r6:ef7f8974 r5:ef0035c0
r4:00000006
[<c0d24c98>] (of_clk_init) from [<c0d04a50>] (time_init+0x2c/0x38)
r10:efffed40 r9:c0d61a48 r8:c0e78000 r7:c0e07900 r6:ffffffff r5:c0e78000
r4:00000000
[<c0d04a24>] (time_init) from [<c0d00b8c>] (start_kernel+0x218/0x394)
[<c0d00974>] (start_kernel) from [<6000807c>] (0x6000807c)
r10:00000000 r9:410fc075 r8:6000406a r7:c0e0c930 r6:c0d61a44 r5:c0e07918
r4:c0e78294
We know that the clk isn't enabled with any sort of prepare_count
here so we don't need to enable anything to prevent a race. And
we're holding the prepare mutex so set_rate/set_parent can't race
here either. Based on an earlier patch by Dong Aisheng.
Fixes: fc8726a2c021 ("clk: core: support clocks which requires parents enable (part 2)")
Cc: Michael Turquette <mturquette@baylibre.com>
Reported-by: Dong Aisheng <aisheng.dong@nxp.com>
[ Upstream commit 66282ec1cf004c09083c29cb5e49019037937bbd ]
Clients must be able to read a file in order to execute it, and for pNFS
that means the client needs to be able to perform a LAYOUTGET on the file.
This behavior for executable-only files was added for OPEN in commit
a043226bc140 "nfsd4: permit read opens of executable-only files".
This fixes up xfstests generic/126 on block/scsi layouts.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[ Upstream commit e40ed274489a5f516da120186578eb379b452ac6 ]
Fixes a warning when building with W=1.
All of the ASPEED device trees build without warnings now.
Signed-off-by: Joel Stanley <joel@jms.id.au>
[ Upstream commit 744820869166c8c78be891240cf5f66e8a333694 ]
Debugfs file reset_stats is created with S_IRUSR permissions,
but ocrdma_dbgfs_ops_read() doesn't support OCRDMA_RESET_STATS,
whereas ocrdma_dbgfs_ops_write() supports only OCRDMA_RESET_STATS.
The patch fixes misstype with permissions.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru>
Acked-by: Selvin Xavier <selvin.xavier@broadcom.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit 53c81e95df1793933f87748d36070a721f6cb287 ]
LTP/udp6_ipsec_vti tests fail when sending large UDP datagrams over
ip6_vti that require fragmentation and the underlying device has an
MTU smaller than 1500 plus some extra space for headers. This happens
because ip6_vti, by default, sets MTU to ETH_DATA_LEN and not updating
it depending on a destination address or link parameter. Further
attempts to send UDP packets may succeed because pmtu gets updated on
ICMPV6_PKT_TOOBIG in vti6_err().
In case the lower device has larger MTU size, e.g. 9000, ip6_vti works
but not using the possible maximum size, output packets have 1500 limit.
The above cases require manual MTU setup after ip6_vti creation. However
ip_vti already updates MTU based on lower device with ip_tunnel_bind_dev().
Here is the example when the lower device MTU is set to 9000:
# ip a sh ltp_ns_veth2
ltp_ns_veth2@if7: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 ...
inet 10.0.0.2/24 scope global ltp_ns_veth2
inet6 fd00::2/64 scope global
# ip li add vti6 type vti6 local fd00::2 remote fd00::1
# ip li show vti6
vti6@NONE: <POINTOPOINT,NOARP> mtu 1500 ...
link/tunnel6 fd00::2 peer fd00::1
After the patch:
# ip li show vti6
vti6@NONE: <POINTOPOINT,NOARP> mtu 8832 ...
Reported-by: Petr Vorel <pvorel@suse.cz>
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
[ Upstream commit 72d548113881dd32bf7f0b221d031e6586468437 ]
It is unlikely request_threaded_irq will fail, but if it does for some
reason we should clear iommu->pr_irq in the error path. Also
intel_svm_finish_prq shouldn't try to clean up the page request
interrupt if pr_irq is 0. Without these, if request_threaded_irq were
to fail the following occurs:
fail with no fixes:
[ 0.683147] ------------[ cut here ]------------
[ 0.683148] NULL pointer, cannot free irq
[ 0.683158] WARNING: CPU: 1 PID: 1 at kernel/irq/irqdomain.c:1632 irq_domain_free_irqs+0x126/0x140
[ 0.683160] Modules linked in:
[ 0.683163] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.15.0-rc2 #3
[ 0.683165] Hardware name: /NUC7i3BNB, BIOS BNKBL357.86A.0036.2017.0105.1112 01/05/2017
[ 0.683168] RIP: 0010:irq_domain_free_irqs+0x126/0x140
[ 0.683169] RSP: 0000:ffffc90000037ce8 EFLAGS: 00010292
[ 0.683171] RAX: 000000000000001d RBX: ffff880276283c00 RCX: ffffffff81c5e5e8
[ 0.683172] RDX: 0000000000000001 RSI: 0000000000000096 RDI: 0000000000000246
[ 0.683174] RBP: ffff880276283c00 R08: 0000000000000000 R09: 000000000000023c
[ 0.683175] R10: 0000000000000007 R11: 0000000000000000 R12: 000000000000007a
[ 0.683176] R13: 0000000000000001 R14: 0000000000000000 R15: 0000010010000000
[ 0.683178] FS: 0000000000000000(0000) GS:ffff88027ec80000(0000) knlGS:0000000000000000
[ 0.683180] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 0.683181] CR2: 0000000000000000 CR3: 0000000001c09001 CR4: 00000000003606e0
[ 0.683182] Call Trace:
[ 0.683189] intel_svm_finish_prq+0x3c/0x60
[ 0.683191] free_dmar_iommu+0x1ac/0x1b0
[ 0.683195] init_dmars+0xaaa/0xaea
[ 0.683200] ? klist_next+0x19/0xc0
[ 0.683203] ? pci_do_find_bus+0x50/0x50
[ 0.683205] ? pci_get_dev_by_id+0x52/0x70
[ 0.683208] intel_iommu_init+0x498/0x5c7
[ 0.683211] pci_iommu_init+0x13/0x3c
[ 0.683214] ? e820__memblock_setup+0x61/0x61
[ 0.683217] do_one_initcall+0x4d/0x1a0
[ 0.683220] kernel_init_freeable+0x186/0x20e
[ 0.683222] ? set_debug_rodata+0x11/0x11
[ 0.683225] ? rest_init+0xb0/0xb0
[ 0.683226] kernel_init+0xa/0xff
[ 0.683229] ret_from_fork+0x1f/0x30
[ 0.683259] Code: 89 ee 44 89 e7 e8 3b e8 ff ff 5b 5d 44 89 e7 44 89 ee 41 5c 41 5d 41 5e e9 a8 84 ff ff 48 c7 c7 a8 71 a7 81 31 c0 e8 6a d3 f9 ff <0f> ff 5b 5d 41 5c 41 5d 41 5
e c3 0f 1f 44 00 00 66 2e 0f 1f 84
[ 0.683285] ---[ end trace f7650e42792627ca ]---
with iommu->pr_irq = 0, but no check in intel_svm_finish_prq:
[ 0.669561] ------------[ cut here ]------------
[ 0.669563] Trying to free already-free IRQ 0
[ 0.669573] WARNING: CPU: 3 PID: 1 at kernel/irq/manage.c:1546 __free_irq+0xa4/0x2c0
[ 0.669574] Modules linked in:
[ 0.669577] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.15.0-rc2 #4
[ 0.669579] Hardware name: /NUC7i3BNB, BIOS BNKBL357.86A.0036.2017.0105.1112 01/05/2017
[ 0.669581] RIP: 0010:__free_irq+0xa4/0x2c0
[ 0.669582] RSP: 0000:ffffc90000037cc0 EFLAGS: 00010082
[ 0.669584] RAX: 0000000000000021 RBX: 0000000000000000 RCX: ffffffff81c5e5e8
[ 0.669585] RDX: 0000000000000001 RSI: 0000000000000086 RDI: 0000000000000046
[ 0.669587] RBP: 0000000000000000 R08: 0000000000000000 R09: 000000000000023c
[ 0.669588] R10: 0000000000000007 R11: 0000000000000000 R12: ffff880276253960
[ 0.669589] R13: ffff8802762538a4 R14: ffff880276253800 R15: ffff880276283600
[ 0.669593] FS: 0000000000000000(0000) GS:ffff88027ed80000(0000) knlGS:0000000000000000
[ 0.669594] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 0.669596] CR2: 0000000000000000 CR3: 0000000001c09001 CR4: 00000000003606e0
[ 0.669602] Call Trace:
[ 0.669616] free_irq+0x30/0x60
[ 0.669620] intel_svm_finish_prq+0x34/0x60
[ 0.669623] free_dmar_iommu+0x1ac/0x1b0
[ 0.669627] init_dmars+0xaaa/0xaea
[ 0.669631] ? klist_next+0x19/0xc0
[ 0.669634] ? pci_do_find_bus+0x50/0x50
[ 0.669637] ? pci_get_dev_by_id+0x52/0x70
[ 0.669639] intel_iommu_init+0x498/0x5c7
[ 0.669642] pci_iommu_init+0x13/0x3c
[ 0.669645] ? e820__memblock_setup+0x61/0x61
[ 0.669648] do_one_initcall+0x4d/0x1a0
[ 0.669651] kernel_init_freeable+0x186/0x20e
[ 0.669653] ? set_debug_rodata+0x11/0x11
[ 0.669656] ? rest_init+0xb0/0xb0
[ 0.669658] kernel_init+0xa/0xff
[ 0.669661] ret_from_fork+0x1f/0x30
[ 0.669662] Code: 7a 08 75 0e e9 c3 01 00 00 4c 39 7b 08 74 57 48 89 da 48 8b 5a 18 48 85 db 75 ee 89 ee 48 c7 c7 78 67 a7 81 31 c0 e8 4c 37 fa ff <0f> ff 48 8b 34 24 4c 89 ef e
8 0e 4c 68 00 49 8b 46 40 48 8b 80
[ 0.669688] ---[ end trace 58a470248700f2fc ]---
Cc: Alex Williamson <alex.williamson@redhat.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Ashok Raj <ashok.raj@intel.com>
Signed-off-by: Jerry Snitselaar <jsnitsel@redhat.com>
Reviewed-by: Ashok Raj <ashok.raj@intel.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit 5c9d8c4f6b8168738a26bcf288516cc3a0886810 ]
We generally leave the GPIO clock disabled, unless an interrupt is
requested or we're accessing IO registers. We forgot to do this for the
->get_direction() callback, which means we can sometimes [1] get
incorrect results [2] from, e.g., /sys/kernel/debug/gpio.
Enable the clock, so we get the right results!
[1] Sometimes, because many systems have 1 or mor interrupt requested on
each GPIO bank, so they always leave their clock on.
[2] Incorrect, meaning the register returns 0, and so we interpret that
as "input".
Signed-off-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
[ Upstream commit 981ed1bfbc6c4660b2ddaa8392893e20a6255048 ]
In case a platform only defaults a "default" set of pins, but not a
"sleep" set of pins, and this particular platform suspends and resumes
in a way that the pin states are not preserved by the hardware, when we
resume, we would call pinctrl_single_resume() -> pinctrl_force_default()
-> pinctrl_select_state() and the first thing we do is check that the
pins state is the same as before, and do nothing.
In order to fix this, decouple the actual state change from
pinctrl_select_state() and move it pinctrl_commit_state(), while keeping
the p->state == state check in pinctrl_select_state() not to change the
caller assumptions. pinctrl_force_sleep() and pinctrl_force_default()
are updated to bypass the state check by calling pinctrl_commit_state().
[Linus Walleij]
The forced pin control states are currently only used in some pin
controller drivers that grab their own reference to their own pins.
This is equal to the pin control hogs: pins taken by pin control
devices since there are no corresponding device in the Linux device
hierarchy, such as memory controller lines or unused GPIO lines,
or GPIO lines that are used orthogonally from the GPIO subsystem
but pincontrol-wise managed as hogs (non-strict mode, allowing
simultaneous use by GPIO and pin control). For this case forcing
the state from the drivers' suspend()/resume() callbacks makes
sense and should semantically match the name of the function.
Fixes: 6e5e959dde0d ("pinctrl: API changes to support multiple states per device")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
[ Upstream commit 11595db8e17faaa05fadc25746c870e31276962f ]
The CoreSight TPIU should be disabled when tracing to other sinks to allow
them to operate at full bandwidth.
This patch fixes tpiu_disable_hw() to correctly disable the TPIU by
configuring the TPIU to stop on flush, initiating a manual flush, waiting
for the flush to complete and then waits for the TPIU to indicate it has
stopped.
Signed-off-by: Robert Walker <robert.walker@arm.com>
Tested-by: Mike Leach <mike.leach@linaro.org>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
[ Upstream commit 2b022ab7542df60021ab57854b3faaaf42552eaf ]
In case that CONFIG_SLUB_DEBUG is on and pty is used, races between
release_one_tty and flush_to_ldisc work threads may happen and lead
to use-after-free condition on tty->link->port. Because SLUB_DEBUG
is turned on, freed tty->link->port is filled with POISON_FREE value.
So far without SLUB_DEBUG, port was filled with zero and flush_to_ldisc
could return without a problem by checking if tty is NULL.
CPU 0 CPU 1
release_tty pty_write
cancel_work_sync(tty) to = tty->link
tty_kref_put(tty->link) tty_schedule_flip(to->port)
<< workqueue >> ...
release_one_tty ...
pty_cleanup ...
kfree(tty->link->port) << workqueue >>
flush_to_ldisc
tty = READ_ONCE(port->itty)
tty is 0x6b6b6b6b6b6b6b6b
!!PANIC!! access tty->ldisc
Unable to handle kernel paging request at virtual address 6b6b6b6b6b6b6b93
pgd = ffffffc0eb1c3000
[6b6b6b6b6b6b6b93] *pgd=0000000000000000, *pud=0000000000000000
Kernel BUG at ffffff800851154c [verbose debug info unavailable]
Internal error: Oops - BUG: 96000004 [#1] PREEMPT SMP
CPU: 3 PID: 265 Comm: kworker/u8:9 Tainted: G W 3.18.31-g0a58eeb #1
Hardware name: Qualcomm Technologies, Inc. MSM 8996pro v1.1 + PMI8996 Carbide (DT)
Workqueue: events_unbound flush_to_ldisc
task: ffffffc0ed610ec0 ti: ffffffc0ed624000 task.ti: ffffffc0ed624000
PC is at ldsem_down_read_trylock+0x0/0x4c
LR is at tty_ldisc_ref+0x24/0x4c
pc : [<ffffff800851154c>] lr : [<ffffff800850f6c0>] pstate: 80400145
sp : ffffffc0ed627cd0
x29: ffffffc0ed627cd0 x28: 0000000000000000
x27: ffffff8009e05000 x26: ffffffc0d382cfa0
x25: 0000000000000000 x24: ffffff800a012f08
x23: 0000000000000000 x22: ffffffc0703fbc88
x21: 6b6b6b6b6b6b6b6b x20: 6b6b6b6b6b6b6b93
x19: 0000000000000000 x18: 0000000000000001
x17: 00e80000f80d6f53 x16: 0000000000000001
x15: 0000007f7d826fff x14: 00000000000000a0
x13: 0000000000000000 x12: 0000000000000109
x11: 0000000000000000 x10: 0000000000000000
x9 : ffffffc0ed624000 x8 : ffffffc0ed611580
x7 : 0000000000000000 x6 : ffffff800a42e000
x5 : 00000000000003fc x4 : 0000000003bd1201
x3 : 0000000000000001 x2 : 0000000000000001
x1 : ffffff800851004c x0 : 6b6b6b6b6b6b6b93
Signed-off-by: Sahara <keun-o.park@darkmatter.ae>
[ Upstream commit b7ea6b286c4051e043f691781785e3c4672f014a ]
Check the status of the DMM engine after it is reported that the
transaction was completed as in rare cases the engine might not reached a
working state.
The wait_status() will print information in case the DMM is not reached the
expected state and the dmm_txn_commit() will return with an error code to
make sure that we are not continuing with a broken setup.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
[ Upstream commit c1b9d4c75cd549e08bd0596d7f9dcc20f7f6e8fa ]
The vendor name was "toppoly" but other panels and the vendor list
have defined it as "tpo". So let's fix it in driver and bindings.
We keep the old definition in parallel to stay compatible with
potential older DTB setup.
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
[ Upstream commit c82084117f79bcae085e40da526253736a247120 ]
Set the resource type when we reserve VGA-related I/O port resources.
The resource code doesn't actually look at the type, so it inserts
resources without a type in the tree correctly even without this change.
But if we ever print a resource without a type, it looks like this:
vga+ [??? 0x000003c0-0x000003df flags 0x0]
Setting the type means it will be printed correctly as:
vga+ [io 0x000003c0-0x000003df]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit 66f53e6f5400578bae58db0c06d85a8820831f40 ]
isert commands that failed during isert_rdma_rw_ctx_post() are queued to
Queue-Full(QF) queue and are scheduled to be reposted during queue-full
queue processing. During this reposting, the rdma contexts are initialised
again in isert_rdma_rw_ctx_post(), which is leaking significant memory.
unreferenced object 0xffff8830201d9640 (size 64):
comm "kworker/0:2", pid 195, jiffies 4295374851 (age 4528.436s)
hex dump (first 32 bytes):
00 60 8b cb 2e 00 00 00 00 10 00 00 00 00 00 00 .`..............
00 90 e3 cb 2e 00 00 00 00 10 00 00 00 00 00 00 ................
backtrace:
[<ffffffff8170711e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff811f8ba5>] __kmalloc+0x125/0x2b0
[<ffffffffa046b24f>] rdma_rw_ctx_init+0x15f/0x6f0 [ib_core]
[<ffffffffa07ab644>] isert_rdma_rw_ctx_post+0xc4/0x3c0 [ib_isert]
[<ffffffffa07ad972>] isert_put_datain+0x112/0x1c0 [ib_isert]
[<ffffffffa07dddce>] lio_queue_data_in+0x2e/0x30 [iscsi_target_mod]
[<ffffffffa076c322>] target_qf_do_work+0x2b2/0x4b0 [target_core_mod]
[<ffffffff81080c3b>] process_one_work+0x1db/0x5d0
[<ffffffff8108107d>] worker_thread+0x4d/0x3e0
[<ffffffff81088667>] kthread+0x117/0x150
[<ffffffff81713fa7>] ret_from_fork+0x27/0x40
[<ffffffffffffffff>] 0xffffffffffffffff
Here is patch to use the older rdma contexts while reposting
the isert commands intead of reinitialising them.
Signed-off-by: Potnuri Bharat Teja <bharat@chelsio.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
[ Upstream commit edf1a84fe37c51290e2c88154ecaf48dadff3d27 ]
In ib_umem structure npages holds original number of sg entries, while
nmap is number of DMA blocks returned by dma_map_sg.
Fixes: c5d76f130b28 ('IB/core: Add umem function to read data from user-space')
Signed-off-by: Artemy Kovalyov <artemyko@mellanox.com>
[ Upstream commit 7baaa49af3716fb31877c61f59b74d029ce15b75 ]
The code was using the src size when formatting the dst. They are almost
certainly the same value but it reads wrong.
Fixes: ce117ffac2e9 ("RDMA/cma: Export AF_IB statistics")
Signed-off-by: Parav Pandit <parav@mellanox.com>
Reviewed-by: Daniel Jurgens <danielj@mellanox.com>
[ Upstream commit 439000892ee17a9c92f1e4297818790ef8bb4ced ]
The ipoib path database is organized around DGIDs from the LLADDR, but the
SA is free to return a different GID when asked for path. This causes a
bug because the SA's modified DGID is copied into the database key, even
though it is no longer the correct lookup key, causing a memory leak and
other malfunctions.
Ensure the database key does not change after the SA query completes.
Demonstration of the bug is as follows
ipoib wants to send to GID fe80:0000:0000:0000:0002:c903:00ef:5ee2, it
creates new record in the DB with that gid as a key, and issues a new
request to the SM.
Now, the SM from some reason returns path-record with other SGID (for
example, 2001:0000:0000:0000:0002:c903:00ef:5ee2 that contains the local
subnet prefix) now ipoib will overwrite the current entry with the new
one, and if new request to the original GID arrives ipoib will not find
it in the DB (was overwritten) and will create new record that in its
turn will also be overwritten by the response from the SM, and so on
till the driver eats all the device memory.
Signed-off-by: Erez Shitrit <erezsh@mellanox.com>
[ Upstream commit de8dcc3d2c0e08e5068ee1e26fc46415c15e3637 ]
The Weibu F3C MiniPC has an onboard AP6255 module, presenting
two SDIO functions on a single MMC host (Bluetooth/btsdio and
WiFi/brcmfmac), and the mmc layer correctly detects this as
non-removable.
After suspend/resume, the wifi and bluetooth interfaces disappear
and do not get probed again.
The conditions here are:
1. During suspend, we reach mmc_pm_notify()
2. mmc_pm_notify() calls mmc_sdio_pre_suspend() to see if we can
suspend the SDIO host. However, mmc_sdio_pre_suspend() returns
-ENOSYS because btsdio_driver does not have a suspend method.
3. mmc_pm_notify() proceeds to remove the card
4. Upon resume, mmc_rescan() does nothing with this host, because of
the rescan_entered check which aims to only scan a non-removable
device a single time (i.e. during boot).
Fix the loss of functionality by detecting that we are unable to
suspend a non-removable host, so avoid the forced removal in that
case. The comment above this function already indicates that this
code was only intended for removable devices.
Signed-off-by: Daniel Drake <drake@endlessm.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit 4e5ca2d930aa8714400aedf4bf1dc959cb04280f ]
Add a check to ensure iowrite64 is only used if it is atomic.
It was decided in [1] that the tilcdc driver should not be using an
atomic operation (so it was left out of this patchset). However, it turns
out that through the drm code, a nonatomic header is actually included:
include/linux/io-64-nonatomic-lo-hi.h
is included from include/drm/drm_os_linux.h:9:0,
from include/drm/drmP.h:74,
from include/drm/drm_modeset_helper.h:26,
from include/drm/drm_atomic_helper.h:33,
from drivers/gpu/drm/tilcdc/tilcdc_crtc.c:19:
And thus, without this change, this patchset would inadvertantly
change the behaviour of the tilcdc driver.
[1] lkml.kernel.org/r/CAK8P3a2HhO_zCnsTzq7hmWSz5La5Thu19FWZpun16iMnyyNreQ@mail.gmail.com
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Cc: Jyri Sarha <jsarha@ti.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: David Airlie <airlied@linux.ie>
Signed-off-by: Jyri Sarha <jsarha@ti.com>
[ Upstream commit 5ba080aada5e739165e0f38d5cc3b04c82b323c8 ]
Incase of interrupt property is not present,
Driver is trying to free an invalid irq,
This patch fixes it by adding a check before freeing the irq.
Signed-off-by: Kedareswara rao Appana <appanad@xilinx.com>
[ Upstream commit d48b8c58c57f6edbe2965f0a5f62c5cf9593ca96 ]
pkt_xfer should be used for protocol v3, and cmd_xfer otherwise. We had
one instance of these functions correct, but not the second, fall-back
case. We use the fall-back only when the first command returns an
IN_PROGRESS status, which is only used on some EC firmwares where we
don't want to constantly poll the bus, but instead back off and
sleep/retry for a little while.
Fixes: 2c7589af3c4d ("mfd: cros_ec: add proto v3 skeleton")
Signed-off-by: Shawn Nematbakhsh <shawnn@chromium.org>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Benson Leung <bleung@chromium.org>
[ Upstream commit 4bcd615fad6adddc68b058d498b30a9e0e0db77a ]
If a watchdog driver's open function sets WDOG_HW_RUNNING with the
expectation that the watchdog can not be stopped, but then stops the
watchdog anyway in its stop function, kref_get() wil not be called in
watchdog_open(). If the watchdog then stops on close, WDOG_HW_RUNNING
will be cleared and kref_put() will be called, causing a kref imbalance.
As result the character device data structure will be released, which in
turn will cause the system to crash on the next call to watchdog_open().
Fixes: ee142889e32f5 ("watchdog: Introduce WDOG_HW_RUNNING flag")
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
[ Upstream commit 50a0d71a5d20e1d3eff1d974fdc8559ad6d74892 ]
As gcc-8 reports, we zero out the wrong byte:
drivers/platform/chrome/cros_ec_sysfs.c: In function 'show_ec_version':
drivers/platform/chrome/cros_ec_sysfs.c:190:12: error: array subscript 4294967295 is above array bounds of 'uint8_t[]' [-Werror=array-bounds]
This changes the code back to what it did before changing to a
zero-length array structure.
Fixes: a841178445bb ("mfd: cros_ec: Use a zero-length array for command data")
[ Upstream commit 8af016aa5a27c6a2505460eb4d83f1e70c38dc43 ]
If there is no clock rate for uartclk defined, disable the previously
enabled clock again.
Fixes: 23f5b3fdd04e serial: 8250_dw: only get the clock rate in one place
Signed-off-by: Stefan Potyra <Stefan.Potyra@elektrobit.com>
[ Upstream commit 245d21190aec547c0de64f70c0e6de871c185a24 ]
It has been reported that the dummy byte we add to avoid
ZLPs can be forwarded by the modem to the PGW/GGSN, and that
some operators will drop the connection if this happens.
In theory, QMI devices are based on CDC ECM and should as such
both support ZLPs and silently ignore the dummy byte. The latter
assumption failed. Let's test out the first.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit 380a6c86457573aa42d27ae11e025eb25941a0b7 ]
On faster CPUs a delay is required after the resume command and the restart command. Without the delay, the restart command often returns -EREMOTEIO and the Si2168 does not restart.
Note that this patch fixes the same issue as https://patchwork.linuxtv.org/patch/44304/, but I believe my udelay() fix addresses the actual problem.
Signed-off-by: Ron Economos <w6rz@comcast.net>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit 07ffb4497360ae8789f05555fec8171ee952304d ]
Data packets are not sent by STA in case of STA joined to
non QOS AP (WMM disabled AP). This is happening because of STA
is sending data packets to firmware from host with qos enabled
along with non qos queue value(TID = 16).
Due to qos enabled, firmware is discarding the packet.
This patch fixes this issue by updating the qos based on station
WME capability field if WMM is disabled in AP.
This patch is required by 10.4 family chipsets like
QCA4019/QCA9888/QCA9884/QCA99X0.
Firmware Versoin : 10.4-3.5.1-00018.
For 10.2.4 family chipsets QCA988X/QCA9887 and QCA6174 this patch
has no effect.
Signed-off-by: Balaji Pothunoori <bpothuno@qti.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
[ Upstream commit 45392ff6881dbe56d41ef0b17c2e576065f8ffa1 ]
This is odd to call 'pci_disable_device()' in an error path before a
coresponding successful 'pci_enable_device()'.
Return directly instead.
Fixes: 77e0be12100a ("V4L/DVB (4176): Bug-fix: Fix memory overflow")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit b7573a0a27bfa8270dea9b145448f6884b7cacc1 ]
Reset the driver current tx read/write index to zero when inactiveps
nic out of sync with HW state. Wrong driver tx read/write index will
cause Tx fail.
Signed-off-by: Tsang-Shian Lin <thlin@realtek.com>
Signed-off-by: Ping-Ke Shih <pkshih@realtek.com>
Cc: Yan-Hsuan Chuang <yhchuang@realtek.com>
Cc: Birming Chiu <birming@realtek.com>
Cc: Shaofu <shaofu@realtek.com>
Cc: Steven Ting <steventing@realtek.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
[ Upstream commit 302d6424e4a293a5761997e6c9fc3dfb1e4c355f ]
With gcc-4.1.2:
drivers/infiniband/core/iwpm_util.c: In function ‘iwpm_send_mapinfo’:
drivers/infiniband/core/iwpm_util.c:647: warning: ‘ret’ may be used uninitialized in this function
Indeed, if nl_client is not found in any of the scanned has buckets, ret
will be used uninitialized.
Preinitialize ret to -EINVAL to fix this.
Fixes: 30dc5e63d6a5ad24 ("RDMA/core: Add support for iWARP Port Mapper user space service")
Reviewed-by: Tatyana Nikolova <tatyana.e.nikolova@intel.com>
[ Upstream commit 62e3a3e342af3c313ab38603811ecdb1fcc79edb ]
get_pages doesn't keep a reference of the pages allocated
when it fails later in the code path. This can lead to
a memory leak. Keep reference of the allocated pages so
that it can be freed when msm_gem_free_object gets called
later during cleanup.
Signed-off-by: Prakash Kamliya <pkamliya@codeaurora.org>
Signed-off-by: Sharat Masetty <smasetty@codeaurora.org>
Signed-off-by: Rob Clark <robdclark@gmail.com>
c8sectpfe_timer_interrupt
[ Upstream commit baed3c4bc4c13de93e0dba0a26d601411ebcb389 ]
_channel_ is being dereferenced before it is null checked, hence there is a
potential null pointer dereference. Fix this by moving the pointer dereference
after _channel_ has been null checked.
This issue was detected with the help of Coccinelle.
Fixes: c5f5d0f99794 ("[media] c8sectpfe: STiH407/10 Linux DVB demux support")
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
[ Upstream commit 67b8fbead4685b36d290a0ef91c6ddffc4920ec9 ]
In case of hci send frame failure, skb is still owned
by the caller (hci_core) and then should not be freed.
This fixes crash on dragonboard-410c when sending SCO
packet. skb is freed by both btqcomsmd and hci_core.
Fixes: 1511cc750c3d ("Bluetooth: Introduce Qualcomm WCNSS SMD based HCI driver")
Signed-off-by: Loic Poulain <loic.poulain@linaro.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
[ Upstream commit ba8f3597900291a93604643017fff66a14546015 ]
Assuming that the original code idea was to enable in-band sleeping
only if the setup_rome method returns succes and run in 'standard'
mode otherwise, we should not return setup_rome return value which
makes qca_setup fail if no rampatch/nvm file found.
This fixes BT issue on the dragonboard-820C p4 which includes the
following QCA controller:
hci0: Product:0x00000008
hci0: Patch :0x00000111
hci0: ROM :0x00000302
hci0: SOC :0x00000044
Since there is no rampatch for this controller revision, just make
it work as is.
[ Upstream commit eabe06595d62cfa9278e2cd012df614bc68a7042 ]
By poking at /debug/sched_features I triggered the following splat:
[] WARNING: possible circular locking dependency detected
[] 4.11.0-00873-g964c8b7-dirty #694 Not tainted
[] bash/2109 is trying to acquire lock:
[] (cpu_hotplug_lock.rw_sem){++++++}, at: [<ffffffff8120cb8b>] static_key_slow_dec+0x1b/0x50
[] but task is already holding lock:
[] (&sb->s_type->i_mutex_key#4){+++++.}, at: [<ffffffff81140216>] sched_feat_write+0x86/0x170
[] which lock already depends on the new lock.
[] the existing dependency chain (in reverse order) is:
[] -> #2 (&sb->s_type->i_mutex_key#4){+++++.}:
[] lock_acquire+0x100/0x210
[] down_write+0x28/0x60
[] start_creating+0x5e/0xf0
[] debugfs_create_dir+0x13/0x110
[] blk_mq_debugfs_register+0x21/0x70
[] blk_mq_register_dev+0x64/0xd0
[] blk_register_queue+0x6a/0x170
[] device_add_disk+0x22d/0x440
[] loop_add+0x1f3/0x280
[] loop_init+0x104/0x142
[] do_one_initcall+0x43/0x180
[] kernel_init_freeable+0x1de/0x266
[] kernel_init+0xe/0x100
[] ret_from_fork+0x31/0x40
[] -> #1 (all_q_mutex){+.+.+.}:
[] __mutex_lock+0x6c/0x960
[] mutex_lock_nested+0x1b/0x20
[] blk_mq_init_allocated_queue+0x37c/0x4e0
[] blk_mq_init_queue+0x3a/0x60
[] loop_add+0xe5/0x280
[] *** DEADLOCK ***
[] 3 locks held by bash/2109:
[] #0: (sb_writers#11){.+.+.+}, at: [<ffffffff81292bcd>] vfs_write+0x17d/0x1a0
[] #1: (debugfs_srcu){......}, at: [<ffffffff8155a90d>] full_proxy_write+0x5d/0xd0
[] #2: (&sb->s_type->i_mutex_key#4){+++++.}, at: [<ffffffff81140216>] sched_feat_write+0x86/0x170
[] stack backtrace:
[] CPU: 9 PID: 2109 Comm: bash Not tainted 4.11.0-00873-g964c8b7-dirty #694
[] Hardware name: Intel Corporation S2600GZ/S2600GZ, BIOS SE5C600.86B.02.02.0002.122320131210 12/23/2013
[] Call Trace:
[] get_online_cpus+0x2a/0x90
[] static_key_slow_dec+0x1b/0x50
[] static_key_disable+0x20/0x30
[] sched_feat_write+0x131/0x170
[] full_proxy_write+0x97/0xd0
[] __vfs_write+0x28/0x120
[] vfs_write+0xb5/0x1a0
[] SyS_write+0x49/0xa0
[] entry_SYSCALL_64_fastpath+0x23/0xc2
This is because of the cpu hotplug lock rework. Break the chain at #1
by reversing the lock acquisition order. This way i_mutex_key#4 no
longer depends on cpu_hotplug_lock and things are good.
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 805b151a1afd24414706a7f6ae275fbb9649be74 ]
__kmod_path__parse() uses is_supported_compression() to determine and
parse out compressed module file extensions. On systems without zlib,
this test fails and __kmod_path__parse() continues to strcmp "ko" with
"gz". Don't do this on those systems.
Signed-off-by: Kim Phillips <kim.phillips@arm.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Fixes: 3c8a67f50a1e ("perf tools: Add kmod_path__parse function")
Link: http://lkml.kernel.org/r/20170503131402.c66e314460026c80cd787b34@arm.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit a16703aaeaedec7a8bee5be5522c7c3e75478951 ]
During write to debugfs file simulate_fw_crash, fixed-size local buffer
'buf' is accessed and modified at index 'count-1', where 'count' is the
size of the write (so potentially out of bounds).
This patch fixes this problem.
Signed-off-by: Michael Mera <dev@michaelmera.com>
[ Upstream commit 538c08f4c89580fc644e2bc64e0a4b86c925da4e ]
The WDIOC_SETOPTIONS case in the watchdog ioctl would alwayss falls
through to the -EINVAL case. This is wrong since thew watchdog does
actually get stopped or started correctly.
Fixes: 920f91e50c5b ("drivers/rtc/rtc-ds1374.c: add watchdog support")
Signed-off-by: Moritz Fischer <mdf@kernel.org>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
[ Upstream commit 453d0744f6c6ca3f9749b8c57c2e85b5b9f52514 ]
The issue is that the internal counter that triggers the watchdog reset
is actually running at 4096 Hz instead of 1Hz, therefore the value
given by userland (in sec) needs to be multiplied by 4096 to get the
correct behavior.
[ Upstream commit 286c469a988fbaf68e3a97ddf1e6c245c1446968 ]
Memory error handler calls try_to_unmap() for error pages in various
states. If the error page is a mlocked page, error handling could fail
with "still referenced by 1 users" message. This is because the page is
linked to and stays in lru cache after the following call chain.
try_to_unmap_one
page_remove_rmap
clear_page_mlock
putback_lru_page
lru_cache_add
memory_failure() calls shake_page() to hanlde the similar issue, but
current code doesn't cover because shake_page() is called only before
try_to_unmap(). So this patches adds shake_page().
Fixes: 23a003bfd23ea9ea0b7756b920e51f64b284b468 ("mm/madvise: pass return code of memory_failure() to userspace")
Link: http://lkml.kernel.org/r/20170417055948.GM31394@yexl-desktop
Link: http://lkml.kernel.org/r/1493197841-23986-3-git-send-email-n-horiguchi@ah.jp.nec.com
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reported-by: kernel test robot <lkp@intel.com>
Cc: Xiaolong Ye <xiaolong.ye@intel.com>
Cc: Chen Gong <gong.chen@linux.intel.com>
