2018-04-08Linux 4.9.93v4.9.93Greg Kroah-Hartman
2018-04-08spi: davinci: fix up dma_mapping_error() incorrect patchGreg Kroah-Hartman
commit aabb797b4c1204b2e8518538b2616e476f2bac92, which is commit c5a2a394835f473ae23931eda5066d3771d7b2f8 upstream had an error in it. Ben writes: The '!' needs to be deleted. This appears to have been fixed upstream by: commit 8aedbf580d21121d2a032e4c8ea12d8d2d85e275 Author: Fabien Parent <fparent@baylibre.com> Date: Thu Feb 23 19:01:56 2017 +0100 spi: davinci: Use SPI framework to handle DMA mapping which is not suitable for stable. So I'm just fixing this up directly. Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Cc: Kevin Hilman <khilman@baylibre.com> Cc: Mark Brown <broonie@kernel.org> Cc: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Revert "ip6_vti: adjust vti mtu according to mtu of lower device"Greg Kroah-Hartman
This reverts commit 1139d77d8a7f9aa6b6ae0a1c902f94775dad2f52 which is commit 53c81e95df1793933f87748d36070a721f6cb287 upstream. Ben writes that there are a number of follow-on patches needed to fix this up, but they get complex to backport, and some custom fixes are needed, so let's just revert this and wait for a "real" set of patches to resolve this to be submitted if it is really needed. Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Cc: Petr Vorel <pvorel@suse.cz> Cc: Alexey Kodanev <alexey.kodanev@oracle.com> Cc: David S. Miller <davem@davemloft.net> Cc: Stefano Brivio <sbrivio@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Revert "mtip32xx: use runtime tag to initialize command header"Greg Kroah-Hartman
This reverts commit db54facd56a40e7766bf7f7cda1ae138e72a691c which was commit a4e84aae8139aca9fbfbced1f45c51ca81b57488 upstream. Ben writes: MQ IO schedulers were introduced in 4.11, so this shouldn't be needed in older branches. It also causes a performance regression (fixed upstream). Please revert this for 4.4 and 4.9. So let's revert it! Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Cc: Ming Lei <ming.lei@redhat.com> Cc: Jens Axboe <axboe@fb.com> Cc: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Revert "spi: bcm-qspi: shut up warning about cfi header inclusion"Greg Kroah-Hartman
This reverts commit c30e6636ce101fd61331092c490b9d9c55b2d143. Florian writes: Sorry for noticing so late, but this appears to be bogus, there is no MTD_NORFLASH symbol being defined in 4.9, in fact I can't find this Kconfig symbol in any kernel version, so this effectively results in the driver no longer being selectable, so this sure does silence the warning. It's not good to just disable a whole driver :( So let's revert the patch for now, Arnd can work on a better build fix... Reported-by: Florian Fainelli <f.fainelli@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Revert "ARM: dts: omap3-n900: Fix the audio CODEC's reset pin"Greg Kroah-Hartman
This reverts commit e5ca83f556925b86133af12ef7f17c1a52c39d7e which was commit 7be4b5dc7ffa9499ac6ef33a5ffa9ff43f9b7057 upstream. It requires a driver that was not merged until 4.16, so remove it from this stable tree as it is pointless. Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Cc: Andrew F. Davis <afd@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Revert "ARM: dts: am335x-pepper: Fix the audio CODEC's reset pin"Greg Kroah-Hartman
This reverts commit 272b5eef085c23cd71eec30fe040fb1592682508 which was comit e153db03c6b7a035c797bcdf35262586f003ee93 upstream. It requires a driver that was not merged until 4.16, so remove it from this stable tree as it is pointless. Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Cc: Andrew F. Davis <afd@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Fix slab name "biovec-(1<<(21-12))"Mikulas Patocka
commit bd5c4facf59648581d2f1692dad7b107bf429954 upstream. I'm getting a slab named "biovec-(1<<(21-12))". It is caused by unintended expansion of the macro BIO_MAX_PAGES. This patch renames it to biovec-max. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org # v4.14+ Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08net: hns: Fix ethtool private flagsMatthias Brugger
commit d61d263c8d82db7c4404a29ebc29674b1c0c05c9 upstream. The driver implementation returns support for private flags, while no private flags are present. When asked for the number of private flags it returns the number of statistic flag names. Fix this by returning EOPNOTSUPP for not implemented ethtool flags. Signed-off-by: Matthias Brugger <mbrugger@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08md/raid10: reset the 'first' at the end of loopGuoqing Jiang
commit 6f287ca6046edd34ed83aafb7f9033c9c2e809e2 upstream. We need to set "first = 0' at the end of rdev_for_each loop, so we can get the array's min_offset_diff correctly otherwise min_offset_diff just means the last rdev's offset diff. [only the first chunk, due to b506335e5d2b ("md/raid10: skip spare disk as 'first' disk") being already applied - gregkh] Suggested-by: NeilBrown <neilb@suse.com> Signed-off-by: Guoqing Jiang <gqjiang@suse.com> Reviewed-by: NeilBrown <neilb@suse.com> Signed-off-by: Shaohua Li <shli@fb.com> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08ARM: dts: am57xx-idk-common: Add overide powerhold propertyKeerthy
commit 8804755bfb1f3cbc003e4ebe99eac491672f354c upstream. The PMICs have POWERHOLD set by default which prevents PMIC shutdown even on DEV_CTRL On bit set to 0 as the Powerhold has higher priority. So to enable pmic power off this property lets one over ride the default value and enable pmic power off. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08ARM: dts: am57xx-beagle-x15-common: Add overide powerhold propertyKeerthy
commit 1f166499ce006b3770a3166122eda64e160736ab upstream. The PMICs have POWERHOLD set by default which prevents PMIC shutdown even on DEV_CTRL On bit set to 0 as the Powerhold has higher priority. So to enable pmic power off this property lets one over ride the default value and enable pmic power off. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08ARM: dts: dra7: Add power hold and power controller properties to palmasKeerthy
commit 7c62de5f3fc92291decc0dac5f36949bdc3fb575 upstream. Add power hold and power controller properties to palmas node. This is needed to shutdown pmic correctly on boards with powerhold set. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Documentation: pinctrl: palmas: Add ti,palmas-powerhold-override property ↵Keerthy
definition commit 0ea66f76ba17a4b229caaadd77de694111b21769 upstream. GPIO7 is configured in POWERHOLD mode which has higher priority over DEV_ON bit and keeps the PMIC supplies on even after the DEV_ON bit is turned off. This property enables driver to over ride the POWERHOLD value to GPIO7 so as to turn off the PMIC in power off scenarios. Signed-off-by: Keerthy <j-keerthy@ti.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08vt: change SGR 21 to follow the standardsMike Frysinger
commit 65d9982d7e523a1a8e7c9af012da0d166f72fc56 upstream. ECMA-48 [1] (aka ISO 6429) has defined SGR 21 as "doubly underlined" since at least March 1984. The Linux kernel has treated it as SGR 22 "normal intensity" since it was added in Linux-0.96b in June 1992. Before that, it was simply ignored. Other terminal emulators have either ignored it, or treat it as double underline now. xterm for example added support in its 304 release (May 2014) [2] where it was previously ignoring it. Changing this behavior shouldn't be an issue: - It isn't a named capability in ncurses's terminfo database, so no script is using libtinfo/libcurses to look this up, or using tput to query & output the right sequence. - Any script assuming SGR 21 will reset intensity in all terminals already do not work correctly on non-Linux VTs (including running under screen/tmux/etc...). - If someone has written a script that only runs in the Linux VT, and they're using SGR 21 (instead of SGR 22), the output should still be readable. imo it's important to change this as the Linux VT's non-conformance is sometimes used as an argument for other terminal emulators to not implement SGR 21 at all, or do so incorrectly. [1]: https://www.ecma-international.org/publications/standards/Ecma-048.htm [2]: https://github.com/ThomasDickey/xterm-snapshots/commit/2fd29cb98d214cb536bcafbee00bc73b3f1eeb9d Signed-off-by: Mike Frysinger <vapier@chromium.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Input: i8042 - enable MUX on Sony VAIO VGN-CS series to fix touchpadOndrej Zary
commit 04bb1719c4de94700056241d4c0fe3c1413f5aff upstream. The touch sensor buttons on Sony VAIO VGN-CS series laptops (e.g. VGN-CS31S) are a separate PS/2 device. As the MUX is disabled for all VAIO machines by the nomux blacklist, the data from touch sensor buttons and touchpad are combined. The protocol used by the buttons is probably similar to the touchpad protocol (both are Synaptics) so both devices get enabled. The controller combines the data, creating a mess which results in random button clicks, touchpad stopping working and lost sync error messages: psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 4 psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1 psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1 psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1 psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1 psmouse serio1: issuing reconnect request Add a new i8042_dmi_forcemux_table whitelist with VGN-CS. With MUX enabled, touch sensor buttons are detected as separate device (and left disabled as there's currently no driver), fixing all touchpad problems. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Input: i8042 - add Lenovo ThinkPad L460 to i8042 reset listDennis Wassenberg
commit b56af54ac78c54a519d82813836f305d7f76ef27 upstream. Reset i8042 before probing because of insufficient BIOS initialisation of the i8042 serial controller. This makes Synaptics touchpad detection possible. Without resetting the Synaptics touchpad is not detected because there are always NACK messages from AUX port. Signed-off-by: Dennis Wassenberg <dennis.wassenberg@secunet.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Input: ALPS - fix TrackStick detection on Thinkpad L570 and Latitude 7370Masaki Ota
commit 567b9b549cfa1cbc202762ae97b5385c29ade1e3 upstream. The primary interface for the touchpad device in Thinkpad L570 is SMBus, so ALPS overlooked PS2 interface Firmware setting of TrackStick, and shipped with TrackStick otp bit is disabled. The address 0xD7 contains device number information, so we can identify the device by checking this value, but to access it we need to enable Command mode, and then re-enable the device. Devices shipped in Thinkpad L570 report either 0x0C or 0x1D as device numbers, if we see them we assume that the devices are DualPoints. The same issue exists on Dell Latitude 7370. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=196929 Fixes: 646580f793 ("Input: ALPS - fix multi-touch decoding on SS4 plus touchpads") Signed-off-by: Masaki Ota <masaki.ota@jp.alps.com> Tested-by: Aaron Ma <aaron.ma@canonical.com> Tested-by: Jonathan Liu <net147@gmail.com> Tested-by: Jaak Ristioja <jaak@ristioja.ee> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08staging: comedi: ni_mio_common: ack ai fifo error interrupts.Frank Mori Hess
commit e1d9fc04c41840a4688ef6ce90b6dcca157ea4d7 upstream. Ack ai fifo error interrupts in interrupt handler to clear interrupt after fifo overflow. It should prevent lock-ups after the ai fifo overflows. Cc: <stable@vger.kernel.org> # v4.2+ Signed-off-by: Frank Mori Hess <fmh6jj@gmail.com> Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08crypto: x86/cast5-avx - fix ECB encryption when long sg follows short oneEric Biggers
commit 8f461b1e02ed546fbd0f11611138da67fd85a30f upstream. With ecb-cast5-avx, if a 128+ byte scatterlist element followed a shorter one, then the algorithm accidentally encrypted/decrypted only 8 bytes instead of the expected 128 bytes. Fix it by setting the encryption/decryption 'fn' correctly. Fixes: c12ab20b162c ("crypto: cast5/avx - avoid using temporary stack buffers") Cc: <stable@vger.kernel.org> # v3.8+ Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08crypto: ahash - Fix early termination in hash walkHerbert Xu
commit 900a081f6912a8985dc15380ec912752cb66025a upstream. When we have an unaligned SG list entry where there is no leftover aligned data, the hash walk code will incorrectly return zero as if the entire SG list has been processed. This patch fixes it by moving onto the next page instead. Reported-by: Eli Cooper <elicooper@gmx.com> Cc: <stable@vger.kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08parport_pc: Add support for WCH CH382L PCI-E single parallel port card.Alexander Gerasiov
commit 823f7923833c6cc2b16e601546d607dcfb368004 upstream. WCH CH382L is a PCI-E adapter with 1 parallel port. It is similair to CH382 but serial ports are not soldered on board. Detected as Serial controller: Device 1c00:3050 (rev 10) (prog-if 05 [16850]) Signed-off-by: Alexander Gerasiov <gq@redlab-i.ru> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08media: usbtv: prevent double free in error caseOliver Neukum
commit 50e7044535537b2a54c7ab798cd34c7f6d900bd2 upstream. Quoting the original report: It looks like there is a double-free vulnerability in Linux usbtv driver on an error path of usbtv_probe function. When audio registration fails, usbtv_video_free function ends up freeing usbtv data structure, which gets freed the second time under usbtv_video_fail label. usbtv_audio_fail: usbtv_video_free(usbtv); => v4l2_device_put(&usbtv->v4l2_dev); => v4l2_device_put => kref_put => v4l2_device_release => usbtv_release (CALLBACK) => kfree(usbtv) (1st time) usbtv_video_fail: usb_set_intfdata(intf, NULL); usb_put_dev(usbtv->udev); kfree(usbtv); (2nd time) So, as we have refcounting, use it Reported-by: Yavuz, Tuba <tuba@ece.ufl.edu> Signed-off-by: Oliver Neukum <oneukum@suse.com> CC: stable@vger.kernel.org Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08mei: remove dev_err message on an unsupported ioctlColin Ian King
commit bb0829a741792b56c908d7745bc0b2b540293bcc upstream. Currently the driver spams the kernel log on unsupported ioctls which is unnecessary as the ioctl returns -ENOIOCTLCMD to indicate this anyway. I suspect this was originally for debugging purposes but it really is not required so remove it. Signed-off-by: Colin Ian King <colin.king@canonical.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08USB: serial: cp210x: add ELDAT Easywave RX09 idJohan Hovold
commit 1f1e82f74c0947e40144688c9e36abe4b3999f49 upstream. Add device id for ELDAT Easywave RX09 tranceiver. Reported-by: Jan Jansen <nattelip@hotmail.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08USB: serial: ftdi_sio: add support for Harman FirmwareHubEmulatorClemens Werther
commit 6555ad13a01952c16485c82a52ad1f3e07e34b3a upstream. Add device id for Harman FirmwareHubEmulator to make the device auto-detectable by the driver. Signed-off-by: Clemens Werther <clemens.werther@gmail.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08USB: serial: ftdi_sio: add RT Systems VX-8 cableMajor Hayden
commit 9608e5c0f079390473b484ef92334dfd3431bb89 upstream. This patch adds a device ID for the RT Systems cable used to program Yaesu VX-8R/VX-8DR handheld radios. It uses the main FTDI VID instead of the common RT Systems VID. Signed-off-by: Major Hayden <major@mhtx.net> Cc: stable <stable@vger.kernel.org> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: idmap: Use "awx" flags for .idmap.text .pushsection directivesWill Deacon
commit 439e70e27a51 upstream. The identity map is mapped as both writeable and executable by the SWAPPER_MM_MMUFLAGS and this is relied upon by the kpti code to manage a synchronisation flag. Update the .pushsection flags to reflect the actual mapping attributes. Reported-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: entry: Reword comment about post_ttbr_update_workaroundWill Deacon
commit f167211a93ac upstream. We don't fully understand the Cavium ThunderX erratum, but it appears that mapping the kernel as nG can lead to horrible consequences such as attempting to execute userspace from kernel context. Since kpti isn't enabled for these CPUs anyway, simplify the comment justifying the lack of post_ttbr_update_workaround in the exception trampoline. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: Force KPTI to be disabled on Cavium ThunderXMarc Zyngier
commit 6dc52b15c4a4 upstream. Cavium ThunderX's erratum 27456 results in a corruption of icache entries that are loaded from memory that is mapped as non-global (i.e. ASID-tagged). As KPTI is based on memory being mapped non-global, let's prevent it from kicking in if this erratum is detected. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> [will: Update comment] Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> [Alex: use cpus_have_cap as cpus_have_const_cap doesn't exist in v4.9] Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: kpti: Add ->enable callback to remap swapper using nG mappingsWill Deacon
commit f992b4dfd58b upstream. Defaulting to global mappings for kernel space is generally good for performance and appears to be necessary for Cavium ThunderX. If we subsequently decide that we need to enable kpti, then we need to rewrite our existing page table entries to be non-global. This is fiddly, and made worse by the possible use of contiguous mappings, which require a strict break-before-make sequence. Since the enable callback runs on each online CPU from stop_machine context, we can have all CPUs enter the idmap, where secondaries can wait for the primary CPU to rewrite swapper with its MMU off. It's all fairly horrible, but at least it only runs once. Nicolas Dechesne <nicolas.dechesne@linaro.org> found a bug on this commit which cause boot failure on db410c etc board. Ard Biesheuvel found it writting wrong contenct to ttbr1_el1 in __idmap_cpu_set_reserved_ttbr1 macro and fixed it by give it the right content. Tested-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> [Alex: avoid dependency on 52-bit PA patches and TTBR/MMU erratum patches] Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: kpti: Make use of nG dependent on arm64_kernel_unmapped_at_el0()Will Deacon
commit 41acec624087 upstream. To allow systems which do not require kpti to continue running with global kernel mappings (which appears to be a requirement for Cavium ThunderX due to a CPU erratum), make the use of nG in the kernel page tables dependent on arm64_kernel_unmapped_at_el0(), which is resolved at runtime. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: Turn on KPTI only on CPUs that need itJayachandran C
commit 0ba2e29c7fc1 upstream. Whitelist Broadcom Vulcan/Cavium ThunderX2 processors in unmap_kernel_at_el0(). These CPUs are not vulnerable to CVE-2017-5754 and do not need KPTI when KASLR is off. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Jayachandran C <jnair@caviumnetworks.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: cputype: Add MIDR values for Cavium ThunderX2 CPUsJayachandran C
commit 0d90718871fe upstream. Add the older Broadcom ID as well as the new Cavium ID for ThunderX2 CPUs. Signed-off-by: Jayachandran C <jnair@caviumnetworks.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: capabilities: Handle duplicate entries for a capabilitySuzuki K Poulose
commit 67948af41f2e upstream. Sometimes a single capability could be listed multiple times with differing matches(), e.g, CPU errata for different MIDR versions. This breaks verify_local_cpu_feature() and this_cpu_has_cap() as we stop checking for a capability on a CPU with the first entry in the given table, which is not sufficient. Make sure we run the checks for all entries of the same capability. We do this by fixing __this_cpu_has_cap() to run through all the entries in the given table for a match and reuse it for verify_local_cpu_feature(). Cc: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: Allow checking of a CPU-local erratumMarc Zyngier
commit 8f4137588261d7504f4aa022dc9d1a1fd1940e8e upstream. this_cpu_has_cap() only checks the feature array, and not the errata one. In order to be able to check for a CPU-local erratum, allow it to inspect the latter as well. This is consistent with cpus_have_cap()'s behaviour, which includes errata already. Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: Take into account ID_AA64PFR0_EL1.CSV3Will Deacon
commit 179a56f6f9fb upstream. For non-KASLR kernels where the KPTI behaviour has not been overridden on the command line we can use ID_AA64PFR0_EL1.CSV3 to determine whether or not we should unmap the kernel whilst running at EL0. Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> [Alex: s/read_sanitised_ftr_reg/read_system_reg/ to match v4.9 naming] Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] [Mark: correct zero bits in ftr_id_aa64pfr0 to account for CSV3] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: Kconfig: Reword UNMAP_KERNEL_AT_EL0 kconfig entryWill Deacon
commit 0617052ddde3 upstream. Although CONFIG_UNMAP_KERNEL_AT_EL0 does make KASLR more robust, it's actually more useful as a mitigation against speculation attacks that can leak arbitrary kernel data to userspace through speculation. Reword the Kconfig help message to reflect this, and make the option depend on EXPERT so that it is on by default for the majority of users. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: Kconfig: Add CONFIG_UNMAP_KERNEL_AT_EL0Will Deacon
commit 084eb77cd3a8 upstream. Add a Kconfig entry to control use of the entry trampoline, which allows us to unmap the kernel whilst running in userspace and improve the robustness of KASLR. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Laura Abbott <labbott@redhat.com> Tested-by: Shanker Donthineni <shankerd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: use RET instruction for exiting the trampolineWill Deacon
commit be04a6d1126b upstream. Speculation attacks against the entry trampoline can potentially resteer the speculative instruction stream through the indirect branch and into arbitrary gadgets within the kernel. This patch defends against these attacks by forcing a misprediction through the return stack: a dummy BL instruction loads an entry into the stack, so that the predicted program flow of the subsequent RET instruction is to a branch-to-self instruction which is finally resolved as a branch to the kernel vectors with speculation suppressed. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: kaslr: Put kernel vectors address in separate data pageWill Deacon
commit 6c27c4082f4f upstream. The literal pool entry for identifying the vectors base is the only piece of information in the trampoline page that identifies the true location of the kernel. This patch moves it into a page-aligned region of the .rodata section and maps this adjacent to the trampoline text via an additional fixmap entry, which protects against any accidental leakage of the trampoline contents. Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Tested-by: Laura Abbott <labbott@redhat.com> Tested-by: Shanker Donthineni <shankerd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com> [Alex: avoid ARM64_WORKAROUND_QCOM_FALKOR_E1003 dependency] Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: entry: Add fake CPU feature for unmapping the kernel at EL0Will Deacon
commit ea1e3de85e94 upstream. Allow explicit disabling of the entry trampoline on the kernel command line (kpti=off) by adding a fake CPU feature (ARM64_UNMAP_KERNEL_AT_EL0) that can be used to toggle the alternative sequences in our entry code and avoid use of the trampoline altogether if desired. This also allows us to make use of a static key in arm64_kernel_unmapped_at_el0(). Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Laura Abbott <labbott@redhat.com> Tested-by: Shanker Donthineni <shankerd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com> [Alex: use first free cpucap number, use cpus_have_cap] Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: tls: Avoid unconditional zeroing of tpidrro_el0 for native tasksWill Deacon
commit 18011eac28c7 upstream. When unmapping the kernel at EL0, we use tpidrro_el0 as a scratch register during exception entry from native tasks and subsequently zero it in the kernel_ventry macro. We can therefore avoid zeroing tpidrro_el0 in the context-switch path for native tasks using the entry trampoline. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Laura Abbott <labbott@redhat.com> Tested-by: Shanker Donthineni <shankerd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: entry: Hook up entry trampoline to exception vectorsWill Deacon
commit 4bf3286d29f3 upstream. Hook up the entry trampoline to our exception vectors so that all exceptions from and returns to EL0 go via the trampoline, which swizzles the vector base register accordingly. Transitioning to and from the kernel clobbers x30, so we use tpidrro_el0 and far_el1 as scratch registers for native tasks. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Laura Abbott <labbott@redhat.com> Tested-by: Shanker Donthineni <shankerd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: entry: Explicitly pass exception level to kernel_ventry macroWill Deacon
commit 5b1f7fe41909 upstream. We will need to treat exceptions from EL0 differently in kernel_ventry, so rework the macro to take the exception level as an argument and construct the branch target using that. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Laura Abbott <labbott@redhat.com> Tested-by: Shanker Donthineni <shankerd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] [Mark: avoid dependency on C error handler backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: mm: Map entry trampoline into trampoline and kernel page tablesWill Deacon
commit 51a0048beb44 upstream. The exception entry trampoline needs to be mapped at the same virtual address in both the trampoline page table (which maps nothing else) and also the kernel page table, so that we can swizzle TTBR1_EL1 on exceptions from and return to EL0. This patch maps the trampoline at a fixed virtual address in the fixmap area of the kernel virtual address space, which allows the kernel proper to be randomized with respect to the trampoline when KASLR is enabled. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Laura Abbott <labbott@redhat.com> Tested-by: Shanker Donthineni <shankerd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: entry: Add exception trampoline page for exceptions from EL0Will Deacon
commit c7b9adaf85f8 upstream. To allow unmapping of the kernel whilst running at EL0, we need to point the exception vectors at an entry trampoline that can map/unmap the kernel on entry/exit respectively. This patch adds the trampoline page, although it is not yet plugged into the vector table and is therefore unused. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Laura Abbott <labbott@redhat.com> Tested-by: Shanker Donthineni <shankerd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com> [Alex: avoid dependency on SW PAN patches] Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] [Mark: remove dummy SW PAN definitions] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08module: extend 'rodata=off' boot cmdline parameter to module mappingsAKASHI Takahiro
commit 39290b389ea upstream. The current "rodata=off" parameter disables read-only kernel mappings under CONFIG_DEBUG_RODATA: commit d2aa1acad22f ("mm/init: Add 'rodata=off' boot cmdline parameter to disable read-only kernel mappings") This patch is a logical extension to module mappings ie. read-only mappings at module loading can be disabled even if CONFIG_DEBUG_SET_MODULE_RONX (mainly for debug use). Please note, however, that it only affects RO/RW permissions, keeping NX set. This is the first step to make CONFIG_DEBUG_SET_MODULE_RONX mandatory (always-on) in the future as CONFIG_DEBUG_RODATA on x86 and arm64. Suggested-by: and Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Kees Cook <keescook@chromium.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Link: http://lkml.kernel.org/r/20161114061505.15238-1-takahiro.akashi@linaro.org Signed-off-by: Jessica Yu <jeyu@redhat.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: factor out entry stack manipulationMark Rutland
commit b11e5759bfac upstream. In subsequent patches, we will detect stack overflow in our exception entry code, by verifying the SP after it has been decremented to make space for the exception regs. This verification code is small, and we can minimize its impact by placing it directly in the vectors. To avoid redundant modification of the SP, we also need to move the initial decrement of the SP into the vectors. As a preparatory step, this patch introduces kernel_ventry, which performs this decrement, and updates the entry code accordingly. Subsequent patches will fold SP verification into kernel_ventry. There should be no functional change as a result of this patch. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> [Mark: turn into prep patch, expand commit msg] Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Tested-by: Laura Abbott <labbott@redhat.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: James Morse <james.morse@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08arm64: mm: Invalidate both kernel and user ASIDs when performing TLBIWill Deacon
commit 9b0de864b5bc upstream. Since an mm has both a kernel and a user ASID, we need to ensure that broadcast TLB maintenance targets both address spaces so that things like CoW continue to work with the uaccess primitives in the kernel. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Laura Abbott <labbott@redhat.com> Tested-by: Shanker Donthineni <shankerd@codeaurora.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport] Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
