path: root/Documentation/ABI
2009-08-01block: Update topology documentationMartin K. Petersen
Update topology comments and sysfs documentation based upon discussions with Neil Brown. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-22Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (63 commits) mtd: OneNAND: Allow setting of boundary information when built as module jffs2: leaking jffs2_summary in function jffs2_scan_medium mtd: nand: Fix memory leak on txx9ndfmc probe failure. mtd: orion_nand: use burst reads with double word accesses mtd/nand: s3c6400 support for s3c2410 driver [MTD] [NAND] S3C2410: Use DIV_ROUND_UP [MTD] [NAND] S3C2410: Deal with unaligned lengths in S3C2440 buffer read/write [MTD] [NAND] S3C2410: Allow the machine code to get the BBT table from NAND [MTD] [NAND] S3C2410: Added a kerneldoc for s3c2410_nand_set mtd: physmap_of: Add multiple regions and concatenation support mtd: nand: max_retries off by one in mxc_nand mtd: nand: s3c2410_nand_setrate(): use correct macros for 2412/2440 mtd: onenand: add bbt_wait & unlock_all as replaceable for some platform mtd: Flex-OneNAND support mtd: nand: add OMAP2/OMAP3 NAND driver mtd: maps: Blackfin async: fix memory leaks in probe/remove funcs mtd: uclinux: mark local stuff static mtd: uclinux: do not allow to be built as a module mtd: uclinux: allow systems to override map addr/size mtd: blackfin NFC: fix hang when using NAND on BF527-EZKITs ...
2009-06-22Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (74 commits) PCI: make msi_free_irqs() to use msix_mask_irq() instead of open coded write PCI: Fix the NIU MSI-X problem in a better way PCI ASPM: remove get_root_port_link PCI ASPM: cleanup pcie_aspm_sanity_check PCI ASPM: remove has_switch field PCI ASPM: cleanup calc_Lx_latency PCI ASPM: cleanup pcie_aspm_get_cap_device PCI ASPM: cleanup clkpm checks PCI ASPM: cleanup __pcie_aspm_check_state_one PCI ASPM: cleanup initialization PCI ASPM: cleanup change input argument of aspm functions PCI ASPM: cleanup misc in struct pcie_link_state PCI ASPM: cleanup clkpm state in struct pcie_link_state PCI ASPM: cleanup latency field in struct pcie_link_state PCI ASPM: cleanup aspm state field in struct pcie_link_state PCI ASPM: fix typo in struct pcie_link_state PCI: drivers/pci/slot.c should depend on CONFIG_SYSFS PCI: remove redundant __msi_set_enable() PCI PM: consistently use type bool for wake enable variable x86/ACPI: Correct maximum allowed _CRS returned resources and warn if exceeded ...
2009-06-18Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: jbd2: clean up jbd2_journal_try_to_free_buffers() ext4: Don't update ctime for non-extent-mapped inodes ext4: Fix up whitespace issues in fs/ext4/inode.c ext4: Fix 64-bit block type problem on 32-bit platforms ext4: teach the inode allocator to use a goal inode number ext4: Use a hash of the topdir directory name for the Orlov parent group ext4: document the "abort" mount option ext4: move the abort flag from s_mount_opts to s_mount_flags ext4: update the s_last_mounted field in the superblock ext4: change s_mount_opt to be an unsigned int ext4: online defrag -- Add EXT4_IOC_MOVE_EXT ioctl ext4: avoid unnecessary spinlock in critical POSIX ACL path ext3: avoid unnecessary spinlock in critical POSIX ACL path ext4: convert instrumentation from markers to tracepoints jbd2: convert instrumentation from markers to tracepoints
2009-06-18LinuxPPS: core supportRodolfo Giometti
This patch adds the kernel side of the PPS support currently named "LinuxPPS". PPS means "pulse per second" and a PPS source is just a device which provides a high precision signal each second so that an application can use it to adjust system clock time. Common use is the combination of the NTPD as userland program with a GPS receiver as PPS source to obtain a wallclock-time with sub-millisecond synchronisation to UTC. To obtain this goal the userland programs shoud use the PPS API specification (RFC 2783 - Pulse-Per-Second API for UNIX-like Operating Systems, Version 1.0) which in part is implemented by this patch. It provides a set of chars devices, one per PPS source, which can be used to get the time signal. The RFC's functions can be implemented by accessing to these char devices. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16PCI hotplug: create symlink to hotplug driver moduleKenji Kaneshige
Create symbolic link to hotplug driver module in the PCI slot directory (/sys/bus/pci/slots/<SLOT#>). In the past, we need to load hotplug drivers one by one to identify the hotplug driver that handles the slot, and it was very inconvenient especially for trouble shooting. With this change, we can easily identify the hotplug driver. Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com> Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-13ext4: teach the inode allocator to use a goal inode numberAndreas Dilger
Enhance the inode allocator to take a goal inode number as a paremeter; if it is specified, it takes precedence over Orlov or parent directory inode allocation algorithms. The extents migration function uses the goal inode number so that the extent trees allocated the migration function use the correct flex_bg. In the future, the goal inode functionality will also be used to allocate an adjacent inode for the extended attributes. Also, for testing purposes the goal inode number can be specified via /sys/fs/{dev}/inode_goal. This can be useful for testing inode allocation beyond 2^32 blocks on very large filesystems. Signed-off-by: Andreas Dilger <adilger@sun.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-08Merge branch 'next-mtd' of git://aeryn.fluff.org.uk/bjdooks/linuxDavid Woodhouse
2009-06-07Merge branch 'linus' into x86/cpuIngo Molnar
2009-06-02cciss: add cciss driver sysfs entriesAndrew Patterson
Add sysfs entries to the cciss driver needed for the dm/multipath tools. A file for vendor, model, rev, and unique_id is added for each logical drive under directory /sys/bus/pci/devices/<dev>/ccissX/cXdY. Where X = the controller (or host) number and Y is the logical drive number. A link from /sys/bus/pci/devices/<dev>/ccissX/cXdY/block:cciss!cXdY to /sys/block/cciss!cXdY/device is also created. A bus is created in /sys/bus/cciss. A link is created from the pci ccissX entry to /sys/bus/cciss/devices/ccissX. Please consider this for inclusion. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Stephen M. Cameron <scameron@beardog.cca.cpqcorp.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-29Documentation: add MTD sysfs docsKevin Cernekee
Signed-off-by: Kevin Cernekee <kpc.mtd@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-22block: Export I/O topology for block devices and partitionsMartin K. Petersen
To support devices with physical block sizes bigger than 512 bytes we need to ensure proper alignment. This patch adds support for exposing I/O topology characteristics as devices are stacked. logical_block_size is the smallest unit the device can address. physical_block_size indicates the smallest I/O the device can write without incurring a read-modify-write penalty. The io_min parameter is the smallest preferred I/O size reported by the device. In many cases this is the same as the physical block size. However, the io_min parameter can be scaled up when stacking (RAID5 chunk size > physical block size). The io_opt characteristic indicates the optimal I/O size reported by the device. This is usually the stripe width for arrays. The alignment_offset parameter indicates the number of bytes the start of the device/partition is offset from the device's natural alignment. Partition tools and MD/DM utilities can use this to pad their offsets so filesystems start on proper boundaries. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28slub: add Documentation/ABI/testing/sysfs-kernel-slabDavid Rientjes
Adds documentation for the slub ABI. This is placed in the `testing' directory since the meanings of these files are still subject to change as slub is developed. Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-04-21ACPI: add /sys/firmware/acpi/interrupts/sci_not counterLen Brown
This counter may prove useful in debugging some spurious interrupt issues seen in the field. Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-13doc: use correct debugfs mountpointShen Feng
Use the default mountpoint of debugfs in the pktcdvd ABI. Signed-off-by: Shen Feng <shen@cn.fujitsu.com> Cc: <balagi@justmail.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-10x86/docs: add description for cache_disable sysfs interfaceMark Langsdorf
Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com> Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <20090409133153.GL31527@alberich.amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: (32 commits) regulator: twl4030 VAUX3 supports 3.0V regulator: Support disabling of unused regulators by machines regulator: Don't increment use_count for boot_on regulators twl4030-regulator: expose VPLL2 regulator: refcount fixes regulator: Don't warn if we failed to get a regulator regulator: Allow boot_on regulators to be disabled by clients regulator: Implement list_voltage for WM835x LDOs and DCDCs twl4030-regulator: list more VAUX4 voltages regulator: Don't warn on omitted voltage constraints regulator: Implement list_voltage() for WM8400 DCDCs and LDOs MMC: regulator utilities regulator: twl4030 voltage enumeration (v2) regulator: twl4030 regulators regulator: get_status() grows kerneldoc regulator: enumerate voltages (v2) regulator: Fix get_mode() for WM835x DCDCs regulator: Allow regulators to set the initial operating mode regulator: Suggest use of datasheet supply or pin names for consumers regulator: email - update email address and regulator webpage. ...
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-04-01Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (33 commits) ext4: Regularize mount options ext4: fix locking typo in mballoc which could cause soft lockup hangs ext4: fix typo which causes a memory leak on error path jbd2: Update locking coments ext4: Rename pa_linear to pa_type ext4: add checks of block references for non-extent inodes ext4: Check for an valid i_mode when reading the inode from disk ext4: Use WRITE_SYNC for commits which are caused by fsync() ext4: Add auto_da_alloc mount option ext4: Use struct flex_groups to calculate get_orlov_stats() ext4: Use atomic_t's in struct flex_groups ext4: remove /proc tuning knobs ext4: Add sysfs support ext4: Track lifetime disk writes ext4: Fix discard of inode prealloc space with delayed allocation. ext4: Automatically allocate delay allocated blocks on rename ext4: Automatically allocate delay allocated blocks on close ext4: add EXT4_IOC_ALLOC_DA_BLKS ioctl ext4: Simplify delalloc code by removing mpage_da_writepages() ext4: Save stack space by removing fake buffer heads ...
2009-04-01Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (88 commits) PCI: fix HT MSI mapping fix PCI: don't enable too much HT MSI mapping x86/PCI: make pci=lastbus=255 work when acpi is on PCI: save and restore PCIe 2.0 registers PCI: update fakephp for bus_id removal PCI: fix kernel oops on bridge removal PCI: fix conflict between SR-IOV and config space sizing powerpc/PCI: include pci.h in powerpc MSI implementation PCI Hotplug: schedule fakephp for feature removal PCI Hotplug: rename legacy_fakephp to fakephp PCI Hotplug: restore fakephp interface with complete reimplementation PCI: Introduce /sys/bus/pci/devices/.../rescan PCI: Introduce /sys/bus/pci/devices/.../remove PCI: Introduce /sys/bus/pci/rescan PCI: Introduce pci_rescan_bus() PCI: do not enable bridges more than once PCI: do not initialize bridges more than once PCI: always scan child buses PCI: pci_scan_slot() returns newly found devices PCI: don't scan existing devices ... Fix trivial append-only conflict in Documentation/feature-removal-schedule.txt
2009-03-31regulator: add get_status()David Brownell
Based on previous LKML discussions: * Update docs for regulator sysfs class attributes to highlight the fact that all current attributes are intended to be control inputs, including notably "state" and "opmode" which previously implied otherwise. * Define a new regulator driver get_status() method, which is the first method reporting regulator outputs instead of inputs. It can report on/off and error status; or instead of simply "on", report the actual operating mode. For the moment, this is a sysfs-only interface, not accessible to regulator clients. Such clients can use the current notification interfaces to detect errors, if the regulator reports them. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-03-24Merge branch 'master' into nextJames Morris
2009-03-20PCI: Introduce /sys/bus/pci/devices/.../rescanAlex Chiang
This interface allows the user to force a rescan of the device's parent bus and all subordinate buses, and rediscover devices removed earlier from this part of the device tree. Cc: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Introduce /sys/bus/pci/devices/.../removeAlex Chiang
This patch adds an attribute named "remove" to a PCI device's sysfs directory. Writing a non-zero value to this attribute will remove the PCI device and any children of it. Trent Piepho wrote the original implementation and documentation. Thanks to Vegard Nossum for testing under kmemcheck and finding locking issues with the sysfs interface. Cc: Trent Piepho <xyzzy@speakeasy.org> Tested-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Introduce /sys/bus/pci/rescanAlex Chiang
This interface allows the user to force a rescan of all PCI buses in system, and rediscover devices that have been removed earlier. pci_bus_attrs implementation from Trent Piepho. Thanks to Vegard Nossum for discovering locking issues with the sysfs interface. Cc: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: document SR-IOV sysfs entriesYu Zhao
Reviewed-by: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: add remove_id sysfs entryChris Wright
This adds a remove_id sysfs entry to allow users of new_id to later remove the added dynid. One use case is management tools that want to dynamically bind/unbind devices to pci-stub driver while devices are assigned to KVM guests. Rather than having to track which driver was originally bound to the driver, a mangement tool can simply: Guest uses device Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-31ext4: Add sysfs supportTheodore Ts'o
Add basic sysfs support so that information about the mounted filesystem and various tuning parameters can be accessed via /sys/fs/ext4/<dev>/*. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-02Merge branches 'tracing/ftrace', 'tracing/mmiotrace' and 'linus' into ↵Ingo Molnar
tracing/core
2009-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: AMD 813x B2 devices do not need boot interrupt quirk PCI: Enable PCIe AER only after checking firmware support PCI: pciehp: Handle interrupts that happen during initialization. PCI: don't enable too many HT MSI mappings PCI: add some sysfs ABI docs PCI quirk: enable MSI on 8132
2009-02-24PCI: add some sysfs ABI docsChris Wright
Add sysfs ABI docs for driver entries bind, unbind and new_id. These entries are pretty old, from 2.6.0 onwards AFAIK, so this documents current behaviour. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
2009-02-19Merge branch 'linus' into tracing/blktraceIngo Molnar
Conflicts: block/blktrace.c Semantic merge: kernel/trace/blktrace.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-18Bernhard has movedBernhard Walle
Since I don't work for SUSE any more and the bwalle@suse.de address is invalid, correct it in the copyright headers and documentation. Signed-off-by: Bernhard Walle <bernhard.walle@gmx.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-06Merge branch 'master' into nextJames Morris
Conflicts: fs/namei.c Manually merged per: diff --cc fs/namei.c index 734f2b5,bbc15c2..0000000 --- a/fs/namei.c +++ b/fs/namei.c @@@ -860,9 -848,8 +849,10 @@@ static int __link_path_walk(const char nd->flags |= LOOKUP_CONTINUE; err = exec_permission_lite(inode); if (err == -EAGAIN) - err = vfs_permission(nd, MAY_EXEC); + err = inode_permission(nd->path.dentry->d_inode, + MAY_EXEC); + if (!err) + err = ima_path_check(&nd->path, MAY_EXEC); if (err) break; @@@ -1525,14 -1506,9 +1509,14 @@@ int may_open(struct path *path, int acc flag &= ~O_TRUNC; } - error = vfs_permission(nd, acc_mode); + error = inode_permission(inode, acc_mode); if (error) return error; + - error = ima_path_check(&nd->path, ++ error = ima_path_check(path, + acc_mode & (MAY_READ | MAY_WRITE | MAY_EXEC)); + if (error) + return error; /* * An append-only file must be opened in append mode for writing. */ Signed-off-by: James Morris <jmorris@namei.org>
2009-02-06integrity: IMA policyMimi Zohar
Support for a user loadable policy through securityfs with support for LSM specific policy data. - free invalid rule in ima_parse_add_rule() Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-01-11Merge commit 'v2.6.29-rc1' into tracing/urgentIngo Molnar
2009-01-08regulator: sysfs attribute reduction (v2)David Brownell
Clean up the sysfs interface to regulators by only exposing the attributes that can be properly displayed. For example: when a particular regulator method is needed to display the value, only create that attribute when that method exists. This cleaned-up interface is much more comprehensible. Most regulators only support a subset of the possible methods, so often more than half the attributes would be meaningless. Many "not defined" values are no longer necessary. (But handling of out-of-range values still looks a bit iffy.) Documentation is updated to reflect that few of the attributes are *always* present, and to briefly explain why a regulator may not have a given attribute. This adds object code, about a dozen bytes more than was removed by the preceding patch, but saves a bunch of per-regulator data associated with the now-removed attributes. So there's a net reduction in memory footprint. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-01-06mm: show node to memory section relationship with symlinks in sysfsGary Hade
Show node to memory section relationship with symlinks in sysfs Add /sys/devices/system/node/nodeX/memoryY symlinks for all the memory sections located on nodeX. For example: /sys/devices/system/node/node1/memory135 -> ../../memory/memory135 indicates that memory section 135 resides on node1. Also revises documentation to cover this change as well as updating Documentation/ABI/testing/sysfs-devices-memory to include descriptions of memory hotremove files 'phys_device', 'phys_index', and 'state' that were previously not described there. In addition to it always being a good policy to provide users with the maximum possible amount of physical location information for resources that can be hot-added and/or hot-removed, the following are some (but likely not all) of the user benefits provided by this change. Immediate: - Provides information needed to determine the specific node on which a defective DIMM is located. This will reduce system downtime when the node or defective DIMM is swapped out. - Prevents unintended onlining of a memory section that was previously offlined due to a defective DIMM. This could happen during node hot-add when the user or node hot-add assist script onlines _all_ offlined sections due to user or script inability to identify the specific memory sections located on the hot-added node. The consequences of reintroducing the defective memory could be ugly. - Provides information needed to vary the amount and distribution of memory on specific nodes for testing or debugging purposes. Future: - Will provide information needed to identify the memory sections that need to be offlined prior to physical removal of a specific node. Symlink creation during boot was tested on 2-node x86_64, 2-node ppc64, and 2-node ia64 systems. Symlink creation during physical memory hot-add tested on a 2-node x86_64 system. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06Merge branch 'linus' into tracing/kmemtrace2Ingo Molnar
2008-12-29kmemtrace: Fix typos in documentation.Eduard - Gabriel Munteanu
Corrected the ABI description and the kmemtrace usage guide. Thanks to Randy Dunlap for noticing these errors. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29kmemtrace: Additional documentation.Eduard - Gabriel Munteanu
Documented kmemtrace's ABI, purpose and design. Also includes a short usage guide, FAQ, as well as a link to the userspace application's Git repository, which is currently hosted at repo.or.cz. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-11-19Merge branch 'master' of ↵David Vrabel
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-upstream
2008-11-19uwb: add basic radio managerDavid Vrabel
The UWB radio manager coordinates the use of the radio between the PALs that may be using it. PALs request use of the radio with uwb_radio_start() and the radio manager will start beaconing if its not already doing so. When the last PAL has called uwb_radio_stop() beaconing will be stopped. In the future, the radio manager will have a more sophisticated channel selection algorithm, probably following the Channel Selection Policy from the WiMedia Alliance when it is finalized. For now, channel 9 (BG1, TFC1) is selected. The user may override the channel selected by the radio manager and may force the radio to stop beaconing. The WUSB Host Controller PAL makes use of this and there are two new debug PAL commands that can be used for testing. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-11-12Add c2 port supportRodolfo Giometti
C2port implements a two wire serial communication protocol (bit banging) designed to enable in-system programming, debugging, and boundary-scan testing on low pin-count Silicon Labs devices. Currently this code supports only flash programming through sysfs interface but extensions shoud be easy to add. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-28ACPI: bugfix reporting of event handler statusZhang Rui
Introduce a new flag showing whether the event has an event handler/method. For all the GPEs and Fixed Events, 1. ACPI_EVENT_FLAG_HANDLE is cleared, it's an "invalid" ACPI event. 2. Both ACPI_EVENT_FLAG_HANDLE and ACPI_EVENT_FLAG_DISABLE are set, it's "disabled". 3. Both ACPI_EVENT_FLAG_HANDLE and ACPI_EVENT_FLAG_ENABLE are set, it's "enabled". 4. Both ACPI_EVENT_FLAG_HANDLE and ACPI_EVENT_FLAG_WAKE_ENABLE are set, it's "wake_enabled". Among other things, this prevents incorrect reporting of ACPI events as being "invalid" when it's really just (temporarily) "disabled". Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-20Merge branch 'master' into for-upstreamDavid Vrabel
Conflicts: Documentation/ABI/testing/sysfs-bus-usb drivers/Makefile
2008-10-17USB: Export if an interface driver supports autosuspend.Sarah Sharp
Create a new sysfs file per interface named supports_autosuspend. This file returns true if an interface driver's .supports_autosuspend flag is set. It also returns true if the interface is unclaimed (since the USB core will autosuspend a device if an interface is not claimed). This new sysfs file will be useful for user space scripts to test whether a USB device correctly auto-suspends. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: add USB test and measurement class driverGreg Kroah-Hartman
This driver was originaly written by Stefan Kopp, but massively reworked by Greg for submission. Thanks to Felipe Balbi <me@felipebalbi.com> for lots of work in cleaning up this driver. Thanks to Oliver Neukum <oliver@neukum.org> for reviewing previous versions and pointing out problems. Cc: Stefan Kopp <stefan_kopp@agilent.com> Cc: Marcel Janssen <korgull@home.nl> Cc: Felipe Balbi <me@felipebalbi.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
