path: root/Documentation/CodingStyle
2008-07-25documentation: update CodingStyle tips for Emacs usersJohannes Weiner
Describe a setup that integrates better with Emacs' cc-mode and also fixes up the alignment of continuation lines to really only use tabs. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17CodingStyle: relax the 80-cole ruleAlan Cox
I would suggest this change to make CodingStyle properly reflect the style used by the kernel, rather than the current wording which is wishful thinking and misleading, and comes from the same school of thought that gets off on prescriptive grammar, latin and comp.std.c Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18dev_vdbg() documentationDavid Brownell
Update CodingStyle to talk about "-DDEBUG" message conventions and the new "-DVERBOSE_DEBUG" convention. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-16CodingStyle: add information about editor modelinesJosh Triplett
I recently received a patch including a file that had a vim modeline, and I realized that nothing specifically proscribed that practice. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16CodingStyle: add information about trailing whitespaceJosh Triplett
Signed-off-by: Josh Triplett <josh@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23Documentation: fix the explanation of Kconfig filesRobert P. J. Day
Fix the obvious errors in the explanation of Kconfig files. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix chapter reference in CodingStyleJesper Juhl
commit 226a6b84aaaf1fac7a5d41cf4e7387fd9ba895d5 renumbered Chapter 11 in Documentation/CodingStyle to Chapter 12, but it didn't update the reference to that chapter further down in the file. This patch corrects the chapter reference. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08CodingStyle: start flamewar about use of bracesOliver Neukum
Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] Add a new section to CodingStyle, promoting include/linux/kernel.hRobert P. J. Day
Add a new section to the CodingStyle file, encouraging people not to re-invent available kernel macros such as ARRAY_SIZE(), FIELD_SIZEOF(), min() and max(), among others. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] CodingStyle updatesRandy Dunlap
Add some kernel coding style comments, mostly pulled from emails by Andrew Morton, Jesper Juhl, and Randy Dunlap. - add paragraph on switch/case indentation (with fixes) - add paragraph on multiple-assignments - add more on Braces - add section on Spaces; add typeof, alignof, & __attribute__ with sizeof; add more on postfix/prefix increment/decrement operators - add paragraph on function breaks in source files; add info on function prototype parameter names - add paragraph on EXPORT_SYMBOL placement - add section on /*-comment style, long-comment style, and data declarations and comments - correct some chapter number references that were missed when chapters were renumbered Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Add section on function return values to CodingStyleAlan Stern
This patch (as776) adds a new chapter to Documentation/CodingStyle, explaining the circumstances under which a function should return 0 for failure and non-zero for success as opposed to a negative error code for failure and 0 for success. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] CodingStyle: add typedefs chapterRandy Dunlap
Add a chapter on typedefs, copied from an email from Linus to lkml on Feb. 3, 2006. (Subject: Re: [RFC][PATCH 1/5] Virtualization/containers: startup) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] CodingStyle correctionJesper Juhl
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Add a section about inlining to Documentation/CodingStyleArjan van de Ven
Adds a bit of text to Documentation/Codingstyle to state that inlining everything "just because" is a bad idea Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] docs: updated some code docsXose Vazquez Perez
2005-09-17[PATCH] CodingStyle: memory allocationPekka J Enberg
This patch adds a new chapter on memory allocation to Documentation/CodingStyle. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] Add kerneldoc reference to CodingStylePekka J Enberg
