path: root/Documentation/DocBook/usb.tmpl
2007-05-22USB: remove usb DocBook warningsDavid Brownell
This just removes some warnings generated by the Docbook tools when turning USB (host and peripheral side) kerneldoc into HTML; they're all about missing ID attributes. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-11[PATCH] fix DocBook buildDon Mullis
Fix DocBook build. Regression was introduced by gregkh-usb-usb-linux-usb_ch9h-becomes-linux-usb-ch9h.patch Tested by `make htmldocs`. Signed-off-by: Don Mullis <dwm@meer.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03remove mentionings of devfs in documentationAdrian Bunk
Now that devfs is removed, there's no longer any need to document how to do this or that with devfs. This patch includes some improvements by Joe Perches. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-27USB doc patch 2Sam Bishop
A little more detail on how and when to poll() /proc/bus/usb/devices. Signed-off-by: Sam Bishop <sam@bishop.dhs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: doc patch 1Sam Bishop
Grammar, spelling, and stylistic edits. Signed-off-by: Sam Bishop <sam@bishop.dhs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: reorg some functions out of the main usb.c fileGreg Kroah-Hartman
This will make the dynamic-id stuff easier to do, as it will be self-contained. No logic was changed at all. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] usb doc: fix kernel-doc warningRandy Dunlap
usb/core/buffer.c doesn't export any symbols, so it should use !I instead of !E to eliminate this warning message: Warning(/var/linsrc/linux-2614-rc4//drivers/usb/core/buffer.c): no structured comments found Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-10[PATCH] Spelling fixes for Documentation/Tobias Klauser
The attached patch fixes the following spelling errors in Documentation/ - double "the" - Several misspellings of function/functionality - infomation - memeory - Recieved - wether and possibly others which I forgot ;-) Trailing whitespaces on the same line as the typo are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
