path: root/Documentation/DocBook
2008-10-26docbooks: fix fatal filename errorsRandy Dunlap
Fix docbook fatal errors (file location changed): docproc: lin2628-rc1/include/asm-x86/io_32.h: No such file or directory make[1]: *** [Documentation/DocBook/deviceiobook.xml] Error 1 docproc: lin2628-rc1/include/asm-x86/atomic_32.h: No such file or directory make[1]: *** [Documentation/DocBook/kernel-api.xml] Error 1 docproc: lin2628-rc1/include/asm-x86/mca_dma.h: No such file or directory make[1]: *** [Documentation/DocBook/mcabook.xml] Error 1 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20misc: replace remaining __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-17usb gadget: cdc obex glueFelipe Balbi
The following patch introduces a new f_obex.c function driver. It allows userspace obex servers to use usb as transport layer for their messages. [ dbrownell@users.sourceforge.net: various fixes and cleanups ] Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16Merge branch 'docs' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'docs' of git://git.lwn.net/linux-2.6: Document panic_on_unrecovered_nmi sysctl Add a reference to paper to SubmittingPatches Add kerneldoc documentation for new printk format extensions Remove videobook.tmpl doc: Test-by? Add the development process document Documentation/block/data-integrity.txt: Fix section numbers
2008-10-16docbook: update procfs creditsRandy Dunlap
Update Erik Mouw's email address & affiliation in DocBook. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Erik Mouw <mouw@nl.linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove videobook.tmplJonathan Corbet
This document describes the long-deprecated V4L1 interface. In-tree, it can only serve to encourage developers to write drivers to the wrong API. Remove it in favor of the V4L2 documentation which must surely show up someday. Acked-by: Alan Cox <alan@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1075 commits) myri10ge: update driver version number to 1.4.3-1.369 r8169: add shutdown handler r8169: preliminary 8168d support r8169: support additional 8168cp chipset r8169: change default behavior for mildly identified 8168c chipsets r8169: add a new 8168cp flavor r8169: add a new 8168c flavor (bis) r8169: add a new 8168c flavor r8169: sync existing 8168 device hardware start sequences with vendor driver r8169: 8168b Tx performance tweak r8169: make room for more specific 8168 hardware start procedure r8169: shuffle some registers handling around (8168 operation only) r8169: new phy init parameters for the 8168b r8169: update phy init parameters r8169: wake up the PHY of the 8168 af_key: fix SADB_X_SPDDELETE response ath9k: Fix return code when ath9k_hw_setpower() fails on reset ath9k: remove nasty FAIL macro from ath9k_hw_reset() gre: minor cleanups in netlink interface gre: fix copy and paste error ...
2008-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: selinux: Fix an uninitialized variable BUG/panic in selinux_secattr_to_sid() selinux: use default proc sid on symlinks file capabilities: uninline cap_safe_nice Update selinux info in MAINTAINERS and Kconfig help text SELinux: add gitignore file for mdp script SELinux: add boundary support and thread context assignment securityfs: do not depend on CONFIG_SECURITY selinux: add support for installing a dummy policy (v2) security: add/fix security kernel-doc selinux: Unify for- and while-loop style selinux: conditional expression type validation was off-by-one smack: limit privilege by label SELinux: Fix a potentially uninitialised variable in SELinux hooks SELinux: trivial, remove unneeded local variable SELinux: Trivial minor fixes that change C null character style make selinux_write_opts() static
2008-10-09Add some block/ source files to the kernel-api docbook. Fix kernel-doc ↵Randy Dunlap
notation in them as needed. Fix changed function parameter names. Fix typos/spellos. In comments, change REQ_SPECIAL to REQ_TYPE_SPECIAL and REQ_BLOCK_PC to REQ_TYPE_BLOCK_PC. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-09-15mac80211: clean up kdocJohannes Berg
A few errors sneaked in over time, some functions no longer exist, for some alternatives exist. This changes the docbook template to include the right things. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-28Merge branch 'master' into nextJames Morris
2008-08-20security: add/fix security kernel-docRandy Dunlap
Add security/inode.c functions to the kernel-api docbook. Use '%' on constants in kernel-doc notation. Fix several typos/spellos in security function descriptions. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-08-12docsrc: fix procfs exampleRandy Dunlap
Add MODULE_LICENSE() to DocBook/procfs_example.c since modpost complained about a missing license there. Remove tty procfs removal since the creation was deleted long ago (http://git.kernel.org/?p=linux/kernel/git/tglx/history.git;a=commitdiff;h=5ad9cb65e9b15e5b83e2dd1c10a4bcaccc4ec644). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <J.A.K.Mouw@its.tudelft.nl> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: build Documentation/ sourcesRandy Dunlap
Currently source files in the Documentation/ sub-dir can easily bit-rot since they are not generally buildable, either because they are hidden in text files or because there are no Makefile rules for them. This needs to be fixed so that the source files remain usable and good examples of code instead of bad examples. Add the ability to build source files that are in the Documentation/ dir. Add to Kconfig as "BUILD_DOCSRC" config symbol. Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the Documentation/ sources. Or enable BUILD_DOCSRC in the *config system. However, this symbol depends on HEADERS_CHECK since the header files need to be installed (for userspace builds). Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32, sparc64, powerpc, sh, m68k, & mips. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (99 commits) pkt_sched: Fix actions referencing bnx2x: fix logical op tcp: (whitespace only) fix confusing indentation pkt_sched: Fix qdisc config when link is down. [Bluetooth] Add full quirk implementation for btusb driver [Bluetooth] Removal of unnecessary ignore module parameter [Bluetooth] Add parameters to control BNEP header compression ath9k: Revamp wireless mode usage ath9k: More unused macros ath9k: Remove a few unused macros and fix indentation ath9k: Use mac80211's band macros and remove enum hal_freq_band ath9k: Remove redundant data structure ath9k_txq_info ath9k: Cleanup data structures related to HW capabilities ath9k: work around gcc ICEs ath9k: Add new Atheros IEEE 802.11n driver ath5k: remove Atheros 11n devices from supported list list.h: add list_cut_position() list.h: Add list_splice_tail() and list_splice_tail_init() p54: swap short slot time dcf values rt2x00: Block all unsupported modes ...
2008-08-07Merge branch 'for-jeff' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6 into tmp
2008-08-06docbook: fix v4l fatal filename errorRandy Dunlap
docproc: /var/linsrc/lin2627-rc2/drivers/media/video/videodev.c: No such file or directory make[1]: *** [Documentation/DocBook/videobook.xml] Error 1 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: mchehab@infradead.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-05docbook: fix s390 fatal error after header files movedRandy Dunlap
Fix (fatal error) s390 docbook file to handle renamed header files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (29 commits) sh: enable maple_keyb in dreamcast_defconfig. SH2(A) cache update nommu: Provide vmalloc_exec(). add addrespace definition for sh2a. sh: Kill off ARCH_SUPPORTS_AOUT and remnants of a.out support. sh: define GENERIC_HARDIRQS_NO__DO_IRQ. sh: define GENERIC_LOCKBREAK. sh: Save NUMA node data in vmcore for crash dumps. sh: module_alloc() should be using vmalloc_exec(). sh: Fix up __bug_table handling in module loader. sh: Add documentation and integrate into docbook build. sh: Fix up broken kerneldoc comments. maple: Kill useless private_data pointer. maple: Clean up maple_driver_register/unregister routines. input: Clean up maple keyboard driver maple: allow removal and reinsertion of keyboard driver module sh: /proc/asids depends on MMU. arch/sh/boards/mach-se/7343/irq.c: removed duplicated #include arch/sh/boards/board-ap325rxa.c: removed duplicated #include sh/boards/Makefile typo fix ...
2008-08-04sh: Add documentation and integrate into docbook build.Paul Mundt
This adds some preliminary docbook bits for SH, tying in to the few interfaces that are exposed and that have adequate kerneldoc comments. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-08-01kgdb: fix kgdb_validate_break_address to perform a mem writeJason Wessel
A regression to the kgdb core was found in the case of using the CONFIG_DEBUG_RODATA kernel option. When this option is on, a breakpoint cannot be written into any readonly memory page. When an external debugger requests a breakpoint to get set, the kgdb_validate_break_address() was only checking to see if the address to place the breakpoint was readable and lacked a write check. This patch changes the validate routine to try reading (via the breakpoint set request) and also to try immediately writing the break point. If either fails, an error is correctly returned and the debugger behaves correctly. Then an end user can make the descision to use hardware breakpoints. Also update the documentation to reflect that using CONFIG_DEBUG_RODATA will inhibit the use of software breakpoints. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-08-01kgdb: remove the requirement for CONFIG_FRAME_POINTERJason Wessel
There is no technical reason that the kgdb core requires frame pointers. It is up to the end user of KGDB to decide if they need them or not. [ anemo@mba.ocn.ne.jp: removed frame pointers on mips ] Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-07-25procfs-guide: drop pointless &nbsp; entitiesMike Frysinger
Having trailing &nbsp; entities in a revision numer seems pretty pointless to me. More so, it's causing me pains, so just drop them since no other guide is doing this. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Remove mention of semaphores from kernel-lockingMatthew Wilcox
Since the consensus seems to be to eliminate semaphores where possible, we shouldn't be educating people about how to use them as locks. Use mutexes instead. Semaphores should be described in a separate document if we end up keeping them. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-23WAN: don't mention syncppp in z8530 DocBook.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2008-07-21uio-howto.tmpl: use unique output namesMike Frysinger
The Userspace I/O HOWTO template sets two different sections with the same html output name (about.html). This clearly won't work, so change the first one to a unique "aboutthis.html" to prevent clobbering. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Hans J. Koch <hjk@linutronix.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21uio-howto.tmpl: use standard copyright/legal markingsMike Frysinger
The Userspace I/O HOWTO document uses straight <sect1> tags and plain text to describe copyright/legal information. It should instead use the <copyright> and <legalnotice> tags like all other documents in the kernel. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Hans J. Koch <hjk@linutronix.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21UIO: Add write function to allow irq maskingHans J. Koch
Sometimes it is necessary to enable/disable the interrupt of a UIO device from the userspace part of the driver. With this patch, the UIO kernel driver can implement an "irqcontrol()" function that does this. Userspace can write an s32 value to /dev/uioX (usually 0 or 1 to turn the irq off or on). The UIO core will then call the driver's irqcontrol function. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Acked-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget serial: split out generic serial functionDavid Brownell
Split out the generic serial support into a "function driver". This closely mimics the ACM support, but with a MUCH simpler control model. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget serial: split out CDC ACM functionDavid Brownell
Split out CDC ACM parts of "gadget serial" to a "function driver". Some key structural differences from the previous ACM support, shared with with the generic serial function (next patch): - As a function driver, it can be combined with other functions. One gadget configuration could offer both serial and network links, as an example. - One serial port can be exposed in multiple configurations; the /dev/ttyGS0 node could be exposed regardless of which config the host selected. - One configuration can expose multiple serial ports, such as ttyGS0, ttyGS1, ttyGS2, and ttyGS3. This code should be a lot easier to understand than the previous all-in-one-big-file version of the driver. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget: composite gadget coreDavid Brownell
Add <linux/usb/composite.h> interfaces for composite gadget drivers, and basic implementation support behind it: - struct usb_function ... groups one or more interfaces into a function managed as one unit within a configuration, to which it's added by usb_add_function(). - struct usb_configuration ... groups one or more such functions into a configuration managed as one unit by a driver, to which it's added by usb_add_config(). These operate at either high or full/low speeds and at a given bMaxPower. - struct usb_composite_driver ... groups one or more such configurations into a gadget driver, which may be registered or unregistered. - struct usb_composite_dev ... a usb_composite_driver manages this; it wraps the usb_gadget exposed by the controller driver. This also includes some basic kerneldoc. How to use it (the short version): provide a usb_composite_driver with a bind() that calls usb_add_config() for each of the needed configurations. The configurations in turn have bind() calls, which will usb_add_function() for each function required. Each function's bind() allocates resources needed to perform its tasks, like endpoints; sometimes configurations will allocate resources too. Separate patches will convert most gadget drivers to this infrastructure. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-24kgdb: documentation update - remove kgdboeJason Wessel
kgdboe is not presently included kgdb, and there should be no references to it. Also fix the tcp port terminal connection example. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-05-23doc: add a chapter about trylock functions [Bug 9011]Matti Linnanvuori
Add a chapter about trylock functions. http://bugzilla.kernel.org/show_bug.cgi?id=9011 Signed-off-by: Matti Linnanvuori <mattilinnanvuori@yahoo.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed down_trylock)
2008-05-05kgdb: minor documentation fixesgrzegorz.chwesewicz@chilan.com
Two minor fixes to the kgdb documentation. Signed-off-by: Grzegorz Chwesewicz, Chilan <grzegorz.chwesewicz@chilan.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-04-30debugobjects: add documentationThomas Gleixner
Add a DocBook for debugobjects. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29docbook: fix fatal rapidio yet again (and more to come)Randy Dunlap
Don't refer to file that no longer exists: docproc: linux-2.6.25-git14/arch/powerpc/kernel/rio.c: No such file or directory Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28docbook: fix bitops fatal filename errorRandy Dunlap
bitops source file was renamed, so fix docbook for that. docproc: linux-2.6.25-git11/include/asm-x86/bitops_32.h: No such file or directory Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kerneldoc for <linux/clk.h>David Brownell
Add <linux/clk.h> to the generated kerneldoc, with some overview to go along with those per-function descriptions. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25kbuild: silence documentation GEN xml messages according to $(quiet)Mike Frysinger
Add rules for gen_xml and its quiet & silent variants. This causes "make -s" to be silent for gen_xml. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits) DOC: A couple corrections and clarifications in USB doc. Generate a slightly more informative error msg for bad HZ fix typo "is" -> "if" in Makefile ext*: spelling fix prefered -> preferred DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs. KEYS: Fix the comment to match the file name in rxrpc-type.h. RAID: remove trailing space from printk line DMA engine: typo fixes Remove unused MAX_NODES_SHIFT MAINTAINERS: Clarify access to OCFS2 development mailing list. V4L: Storage class should be before const qualifier (sn9c102) V4L: Storage class should be before const qualifier sonypi: Storage class should be before const qualifier intel_menlow: Storage class should be before const qualifier DVB: Storage class should be before const qualifier arm: Storage class should be before const qualifier ALSA: Storage class should be before const qualifier acpi: Storage class should be before const qualifier firmware_sample_driver.c: fix coding style MAINTAINERS: Add ati_remote2 driver ... Fixed up trivial conflicts in firmware_sample_driver.c
2008-04-21DOC: A couple corrections and clarifications in USB doc.Robert P. J. Day
A couple of corrections and clarifications in USB documentation. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits) SCSI: convert struct class_device to struct device DRM: remove unused dev_class IB: rename "dev" to "srp_dev" in srp_host structure IB: convert struct class_device to struct device memstick: convert struct class_device to struct device driver core: replace remaining __FUNCTION__ occurrences sysfs: refill attribute buffer when reading from offset 0 PM: Remove destroy_suspended_device() Firmware: add iSCSI iBFT Support PM: Remove legacy PM (fix) Kobject: Replace list_for_each() with list_for_each_entry(). SYSFS: Explicitly include required header file slab.h. Driver core: make device_is_registered() work for class devices PM: Convert wakeup flag accessors to inline functions PM: Make wakeup flags available whenever CONFIG_PM is set PM: Fix misuse of wakeup flag accessors in serial core Driver core: Call device_pm_add() after bus_add_device() in device_add() PM: Handle device registrations during suspend/resume block: send disk "change" event for rescan_partitions() sysdev: detect multiple driver registrations ... Fixed trivial conflict in include/linux/memory.h due to semaphore header file change (made irrelevant by the change to mutex).
2008-04-21DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs.Robert P. J. Day
2008-04-19PM: Remove legacy PM (fix)Randy Dunlap
Source file was removed. Need to remove docbook reference also. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Pavel Machek <pavel@suse.cz> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits) [NET]: Fix and allocate less memory for ->priv'less netdevices [IPV6]: Fix dangling references on error in fib6_add(). [NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found [PKT_SCHED]: Fix datalen check in tcf_simp_init(). [INET]: Uninline the __inet_inherit_port call. [INET]: Drop the inet_inherit_port() call. SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked. [netdrvr] forcedeth: internal simplifications; changelog removal phylib: factor out get_phy_id from within get_phy_device PHY: add BCM5464 support to broadcom PHY driver cxgb3: Fix __must_check warning with dev_dbg. tc35815: Statistics cleanup natsemi: fix MMIO for PPC 44x platforms [TIPC]: Cleanup of TIPC reference table code [TIPC]: Optimized initialization of TIPC reference table [TIPC]: Remove inlining of reference table locking routines e1000: convert uint16_t style integers to u16 ixgb: convert uint16_t style integers to u16 sb1000.c: make const arrays static sb1000.c: stop inlining largish static functions ...
2008-04-17kgdb: documentation fixesJason Wessel
Minor cleanups to kgdb docs. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: add documentationJason Wessel
Add in the kgdb documentation for kgdb. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/rt2x00dev.c net/8021q/vlan_dev.c
2008-03-06mac80211: add documentation bookJohannes Berg
Quite a while ago I started this book. The required kernel-doc patches have since gone into the tree so it is now possible to build the book in mainline. The actual documentation is still rather incomplete and not all things are linked into the book, but this enables us to edit the documentation collaboratively, hopefully driver authors can add documentation based on their experience with mac80211. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
