Put the parameters at the sequencial order as they appear inside
the frontend.h header.
TODO: fix the per-standard section, to reflect the parameters
that should actually be used for each transmission system type.
Instead of adding a program listing, just add there all parameters.
There were lots of DVB S2API parameters that were never documented.
Let's add a definition for all of them, based on what's currently
used inside the core and the drivers.
The description here is not complete nor perfect, so patches
improving it are welcome.
Update the DVB parameter structs to reflect VSB modulation and
improve a few descriptions.
The frontend.h.xml now references to the main document. However,
several references are missed.
Links the trivial ones with the corresponding API descriptions.
While here, updates the main API to reflect the API improvements.
As the DVB API provides two ways to specify the delivery
systems, correlate both ways into a table.
Associate the frontend.h DVB S2API parmeters to the corresponding
documentation at the spec.
The fe_type_t documentation was incomplete and not linked to the
dvb/frontend.h.xml. Properly document it.
Also, drop a note that newer formats are only supported via
FE_GET_PROPERTY/FE_GET_SET_PROPERTY ioctls.
With this change, it is now possible to discover the gap between
the API defined inside include/dvb/frontend.h and the one documented
into the specs.
The JPG-Light, AKA Pegasus Lossless JPEG, is used in Divio webcams based
on NW 800/801/802 chips.
Signed-off-by: Jean-François Moine <moinejf@free.fr>
TRY}_EXT_CTRLS
VIDIOC_S_CTRL and VIDIOC_S_EXT_CTRLS return EACCES when setting a read-only
control VIDIOC_TRY_EXT_CTRLS when trying a read-only control and
VIDIOC_G_CTRL and VIDIOC_G_EXT_CTRLS when getting a write-only control.
Document this.
Signed-off-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
This patch addresses several issues pointed by Randy Dunlap
<rdunlap@xenotime.net> at changeset ece722c:
- In the generated index.html file, "media" is listed first, but it
should be listed in alphabetical order, not first.
- The generated files are (hidden) in .tmpmedia/
- The link from the top-level index.html file to "media" is to
media/index.html, but the file is actually in .tmpmedia/media/index.html
- Please build docs with and without using "O=builddir" and test that.
- Would it be possible for media to have its own Makefile instead of
merging into this one?
Due to the way cleandocs target works, I had to rename the media DocBook
to media_api, otherwise cleandocs would remove the /media directory.
Thanks-to: Randy Dunlap <rdunlap@xenotime.net>
Auto-generate the videodev2.h.xml,frontend.h.xml and the indexes.
Some logic at the Makefile helps us to identify when a symbol is missing,
like for example:
Error: no ID for constraint linkend: V4L2-PIX-FMT-JPGL.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (297 commits)
ALSA: asihpi - Replace with snd_ctl_boolean_mono_info()
ALSA: asihpi - HPI version 4.08
ALSA: asihpi - Add volume mute controls
ALSA: asihpi - Control name updates
ALSA: asihpi - Use size_t for sizeof result
ALSA: asihpi - Explicitly include mutex.h
ALSA: asihpi - Add new node and message defines
ALSA: asihpi - Make local function static
ALSA: asihpi - Fix minor typos and spelling
ALSA: asihpi - Remove unused structures, macros and functions
ALSA: asihpi - Remove spurious adapter index check
ALSA: asihpi - Revise snd_pcm_debug_name, get rid of DEBUG_NAME macro
ALSA: asihpi - DSP code loader API now independent of OS
ALSA: asihpi - Remove controlex structs and associated special data transfer code
ALSA: asihpi - Increase request and response buffer sizes
ALSA: asihpi - Give more meaningful name to hpi request message type
ALSA: usb-audio - Add quirk for Roland / BOSS BR-800
ALSA: hda - Remove a superfluous argument of via_auto_init_output()
ALSA: hda - Fix indep-HP path (de-)activation for VT1708* codecs
ALSA: hda - Add documentation for codec-specific mixer controls
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits)
sched: Cleanup duplicate local variable in [enqueue|dequeue]_task_fair
sched: Replace use of entity_key()
sched: Separate group-scheduling code more clearly
sched: Reorder root_domain to remove 64 bit alignment padding
sched: Do not attempt to destroy uninitialized rt_bandwidth
sched: Remove unused function cpu_cfs_rq()
sched: Fix (harmless) typo 'CONFG_FAIR_GROUP_SCHED'
sched, cgroup: Optimize load_balance_fair()
sched: Don't update shares twice on on_rq parent
sched: update correct entity's runtime in check_preempt_wakeup()
xtensa: Use generic config PREEMPT definition
h8300: Use generic config PREEMPT definition
m32r: Use generic PREEMPT config
sched: Skip autogroup when looking for all rt sched groups
sched: Simplify mutex_spin_on_owner()
sched: Remove rcu_read_lock() from wake_affine()
sched: Generalize sleep inside spinlock detection
sched: Make sleeping inside spinlock detection working in !CONFIG_PREEMPT
sched: Isolate preempt counting in its own config option
sched: Remove pointless in_atomic() definition check
All these are instances of
#define NAME value;
or
#define NAME(params_opt) value;
These of course fail to build when used in contexts like
if(foo $OP NAME)
while(bar $OP NAME)
and may silently generate the wrong code in contexts such as
foo = NAME + 1; /* foo = value; + 1; */
bar = NAME - 1; /* bar = value; - 1; */
baz = NAME & quux; /* baz = value; & quux; */
Reported on comp.lang.c,
Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com>
Initial analysis of the dangers provided by Keith Thompson in that thread.
There are many more instances of more complicated macros having unnecessary
trailing semicolons, but this pile seems to be all of the cases of simple
values suffering from the problem. (Thus things that are likely to be found
in one of the contexts above, more complicated ones aren't.)
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
net/bluetooth/l2cap_core.c
I changed the TKIP key functions, but forgot to
update the documentation includes, fix that.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into sched/core
The sleeping inside spinlock detection is actually used
for more general sleeping inside atomic sections
debugging: preemption disabled, rcu read side critical
sections, interrupts, interrupt disabled, etc...
Change the name of the config and its help section to
reflect its more general role.
* git://git.infradead.org/mtd-2.6: (97 commits)
mtd: kill CONFIG_MTD_PARTITIONS
mtd: remove add_mtd_partitions, add_mtd_device and friends
mtd: convert remaining users to mtd_device_register()
mtd: samsung onenand: convert to mtd_device_register()
mtd: omap2 onenand: convert to mtd_device_register()
mtd: txx9ndfmc: convert to mtd_device_register()
mtd: tmio_nand: convert to mtd_device_register()
mtd: socrates_nand: convert to mtd_device_register()
mtd: sharpsl: convert to mtd_device_register()
mtd: s3c2410 nand: convert to mtd_device_register()
mtd: ppchameleonevb: convert to mtd_device_register()
mtd: orion_nand: convert to mtd_device_register()
mtd: omap2: convert to mtd_device_register()
mtd: nomadik_nand: convert to mtd_device_register()
mtd: ndfc: convert to mtd_device_register()
mtd: mxc_nand: convert to mtd_device_register()
mtd: mpc5121_nfc: convert to mtd_device_register()
mtd: jz4740_nand: convert to mtd_device_register()
mtd: h1910: convert to mtd_device_register()
mtd: fsmc_nand: convert to mtd_device_register()
Fixed up trivial conflicts in
- drivers/mtd/maps/integrator-flash.c: removed in ARM tree
- drivers/mtd/maps/physmap.c: addition of afs partition probe type
clashing with removal of CONFIG_MTD_PARTITIONS
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
[media] v1.88 DM04/QQBOX Move remote to use rc_core dvb-usb-remote
[media] Add missing include guard to header file
[media] Inlined functions should be static
[media] Remove invalid parameter description
[media] cpia2: fix warning about invalid trigraph sequence
[media] s5p-csis: Add missing dependency on PLAT_S5P
[media] gspca/kinect: wrap gspca_debug with GSPCA_DEBUG
[media] fintek-cir: new driver for Fintek LPC SuperIO CIR function
[media] uvcvideo: Connect video devices to media entities
[media] uvcvideo: Register subdevices for each entity
[media] uvcvideo: Register a v4l2_device
[media] add V4L2-PIX-FMT-SRGGB12 & friends to docbook
[media] Documentation/DocBook: Rename media fops xml files
[media] Media DocBook: fix validation errors
[media] wl12xx: g_volatile_ctrl fix: wrong field set
[media] fix kconfig dependency warning for VIDEO_TIMBERDALE
[media] dm1105: GPIO handling added, I2C on GPIO added, LNB control through GPIO reworked
[media] Add support for M-5MOLS 8 Mega Pixel camera ISP
The xml with those guys are there, but they weren't included
on the docbook.
By convention, the name of the XML file should match the references
declared at media-entities.tmpl, as, otherwise, some validation
scripts break.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Now that none of the drivers use CONFIG_MTD_PARTITIONS we can remove
it from Kconfig and the last remaining uses.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: make KBUILD_NOCMDDEP=1 handle empty built-in.o
scripts/kallsyms.c: fix potential segfault
scripts/gen_initramfs_list.sh: Convert to a /bin/sh script
kbuild: Fix GNU make v3.80 compatibility
kbuild: Fix passing -Wno-* options to gcc 4.4+
kbuild: move scripts/basic/docproc.c to scripts/docproc.c
kbuild: Fix Makefile.asm-generic for um
kbuild: Allow to combine multiple W= levels
kbuild: Disable -Wunused-but-set-variable for gcc 4.6.0
Fix handling of backlash character in LINUX_COMPILE_BY name
kbuild: asm-generic support
kbuild: implement several W= levels
kbuild: Fix build with binutils <= 2.19
initramfs: Use KBUILD_BUILD_TIMESTAMP for generated entries
kbuild: Allow to override LINUX_COMPILE_BY and LINUX_COMPILE_HOST macros
kbuild: Drop unused LINUX_COMPILE_TIME and LINUX_COMPILE_DOMAIN macros
kbuild: Use the deterministic mode of ar
kbuild: Call gzip with -n
kbuild: move KALLSYMS_EXTRA_PASS from Kconfig to Makefile
Kconfig: improve KALLSYMS_ALL documentation
Fix up trivial conflict in Makefile
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (247 commits)
[media] gspca - sunplus: Fix some warnings and simplify code
[media] gspca: Fix some warnings tied to 'no debug'
[media] gspca: Unset debug by default
[media] gspca - cpia1: Remove a bad conditional compilation instruction
[media] gspca - main: Remove USB traces
[media] gspca - main: Version change to 2.13
[media] gspca - stk014 / t613: Accept the index 0 in querymenu
[media] gspca - kinect: Remove __devinitdata
[media] gspca - cpia1: Fix some warnings
[media] video/Kconfig: Fix mis-classified devices
[media] support for medion dvb stick 1660:1921
[media] tm6000: fix uninitialized field, change prink to dprintk
[media] cx231xx: Add support for Iconbit U100
[media] saa7134 add new TV cards
[media] Use a more consistent value for RC repeat period
[media] cx18: Move spinlock and vb_type initialisation into stream_init
[media] tm6000: remove tm6010 sif audio start and stop
[media] tm6000: remove unused exports
[media] tm6000: add pts logging
[media] tm6000: change from ioctl to unlocked_ioctl
A few new capabilities added to frontend.h for DVB-T2. Added these
to the documentation plus some notes explaining that they are
used by the T2 delivery system.
Signed-off-by: Steve Kerrison <steve@stevekerrison.com>
M420 is a hybrid YUV 4:2:0 packet/planar format. Two Y lines are
followed by an interleaved U/V line.
[laurent.pinchart@ideasonboard.com: split into v4l/uvcvideo patches]
[laurent.pinchart@ideasonboard.com: add documentation]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add V4L2_MBUS_FMT_JPEG_1X8 format and the corresponding Docbook
documentation.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
It only contains generated files
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Add a 10 bits per pixel greyscale format in a bit-packed array representation,
naming it Y10B. Such pixel format is supplied for instance by the Kinect
sensor device.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (44 commits)
debugfs: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warning
sysfs: remove "last sysfs file:" line from the oops messages
drivers/base/memory.c: fix warning due to "memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION"
SYSFS: Fix erroneous comments for sysfs_update_group().
driver core: remove the driver-model structures from the documentation
driver core: Add the device driver-model structures to kerneldoc
Translated Documentation/email-clients.txt
RAW driver: Remove call to kobject_put().
reboot: disable usermodehelper to prevent fs access
efivars: prevent oops on unload when efi is not enabled
Allow setting of number of raw devices as a module parameter
Introduce CONFIG_GOOGLE_FIRMWARE
driver: Google Memory Console
driver: Google EFI SMI
x86: Better comments for get_bios_ebda()
x86: get_bios_ebda_length()
misc: fix ti-st build issues
params.c: Use new strtobool function to process boolean inputs
debugfs: move to new strtobool
Fix up trivial conflicts in fs/debugfs/file.c due to the same patch
being applied twice, and an unrelated cleanup nearby.
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
irq: Export functions to allow modular irq drivers
genirq: Uninline and sanity check generic_handle_irq()
genirq: Remove pointless ifdefs
genirq: Make generic irq chip depend on CONFIG_GENERIC_IRQ_CHIP
genirq: Add chip suspend and resume callbacks
genirq: Implement a generic interrupt chip
genirq: Support per-IRQ thread disabling.
genirq: irq_desc: Document preflow_handler and affinity_hint
genirq: Update DocBook comments
genirq: Forgotten updates/deletions after removal of compat code
Add the comments to the structure bus_type, device_driver, device,
class to device.h for generating the driver-model kerneldoc. With another patch
these all removed from the files in Documentation/driver-model/ since
they are out of date. That will keep things up to date and provide a better way
to document this stuff.
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
Acked-by: Harry Wei <harryxiyou@gmail.com>
Move docproc from scripts/basic to scripts so it is only built for *doc
targets instead of every time the kernel is built.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (42 commits)
[media] media: vb2: correct queue initialization order
[media] media: vb2: fix incorrect v4l2_buffer->flags handling
[media] s5p-fimc: Add support for the buffer timestamps and sequence
[media] s5p-fimc: Fix bytesperline and plane payload setup
[media] s5p-fimc: Do not allow changing format after REQBUFS
[media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4
[media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheet
[media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheet
[media] tda18271: fix bad calculation of main post divider byte
[media] tda18271: prog_cal and prog_tab variables should be s32, not u8
[media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_init
[media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() fails
[media] v4l: Don't register media entities for subdev device nodes
[media] omap3isp: Don't increment node entity use count when poweron fails
[media] omap3isp: lane shifter support
[media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmts
[media] media: add missing 8-bit bayer formats and Y12
[media] v4l: add V4L2_PIX_FMT_Y12 format
cx23885: Fix stv0367 Kconfig dependency
[media] omap3isp: Use isp xclk defines
Fix up trivial conflict (spelink errurs) in drivers/media/video/omap3isp/isp.c
Fix some parts to match the actual code.
[ tglx: Resolved the FIXMEs Gerd put in ]
Link: http://lkml.kernel.org/r/%3C1302426113-13808-3-git-send-email-geert%40linux-m68k.org%3E
Cc: linux-doc@vger.kernel.org
8-bit SGBRG and SRGGB media bus formats are missing, as well as the
12-bit grey format. Add them.
Y12 is a grey-scale format with a depth of 12 bits per pixel stored in
16-bit words.
The documentation incorrectly refers to MEDIA_IOC_ENUM_LINKS, fix it.
Fix fsl_rio.c kernel-doc warning: no exported symbols as
requested by !E are found:
Warning(arch/powerpc/sysdev/fsl_rio.c): no structured comments found
DocBook/v4l/ no longer has any *.png files, so the 'cp' command fails,
breaking the build. Drop the *.png cp.
cp: cannot stat `linux-2.6.38-git18/Documentation/DocBook/v4l/*.png': No such file or directory
Reported-by: Daniel Burr <dburr@topcon.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Multi-planar API was added to 2.6.39 version of Video for Linux 2 API.
Signed-off-by: Pawel Osciak <pawel@osciak.com>
