path: root/Documentation/Makefile.sphinx
2016-09-01doc-rst: generic way to build PDF of sub-foldersMarkus Heiser
This extends the method to build only sub-folders to the targets "latexdocs" and "pdfdocs". To do so, a conf.py in the sub-folder is required, where the latex_documents of the sub-folder are defined. E.g. to build only gpu's PDF add the following to the Documentation/gpu/conf.py:: +latex_documents = [ + ("index", "gpu.tex", "Linux GPU Driver Developer's Guide", + "The kernel development community", "manual"), +] and run: make SPHINXDIRS=gpu pdfdocs Signed-off-by: Markus Heiser <markus.heiser@darmarIT.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-22docs-rst: add support for LaTeX outputMauro Carvalho Chehab
Sphinx supports LaTeX output. Sometimes, it is interesting to call it directly, instead of also generating a PDF. As it comes for free, add a target for it. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-18docs-rst: Don't go to interactive mode on errorsMauro Carvalho Chehab
When building for LaTeX, it stops and enters into interactive mode on errors. Don't do that, as there are some non-fatal errors on media books when using Sphinx 1.4.x that we don't know how fix yet. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-18docs-rst: Don't mangle with UTF-8 chars on LaTeX/PDF outputMauro Carvalho Chehab
pdflatex doesn't accept using some UTF-8 chars, like "equal or less than" or "equal or greater than" chars. However, the media documents use them. So, we need to use XeLaTeX for conversion, and a font that accepts such characters. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-18docs-rst: fix a breakage when building PDF documentsMauro Carvalho Chehab
changeset 606b9ac81a63 ("doc-rst: generic way to build only sphinx sub-folders") accidentally broke PDF generation by adding an extra ")". Remove it. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-14doc-rst: generic way to build only sphinx sub-foldersMarkus Heiser
Add a generic way to build only a reST sub-folder with or without a individual *build-theme*. * control *sub-folders* by environment SPHINXDIRS * control *build-theme* by environment SPHINX_CONF Folders with a conf.py file, matching $(srctree)/Documentation/*/conf.py can be build and distributed *stand-alone*. E.g. to compile only the html of 'media' and 'gpu' folder use:: make SPHINXDIRS="media gpu" htmldocs To use an additional sphinx-build configuration (*build-theme*) set the name of the configuration file to SPHINX_CONF. E.g. to compile only the html of 'media' with the *nit-picking* build use:: make SPHINXDIRS=media SPHINX_CONF=conf_nitpick.py htmldocs With this, the Documentation/conf.py is read first and updated with the configuration values from the Documentation/media/conf_nitpick.py. Signed-off-by: Markus Heiser <markus.heiser@darmarIT.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-12Documentation: switch to pdflatex for pdf generationJani Nikula
Looks like rst2pdf is not robust enough, especially for large documents. Use recursive make on the Sphinx generated makefile to convert latex to pdf. The ugly detail is that pdf is generated into Documentation/output/latex. Unfortunately, the pdflatex build generates huge amounts of build log noise, and also fails in the end. We'll fix that next. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Acked-by: Markus Heiser <markus.heiser@darmarit.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-12Documentation/sphinx: build the media intermediate rst files for all outputsJani Nikula
This is a stopgap measure to allow building outputs other than html. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Acked-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Acked-by: Markus Heiser <markus.heiser@darmarit.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-07Merge tag 'doc-4.8-fixes' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation fixes from Jonathan Corbet: "Three fixes for the docs build, including removing an annoying warning on 'make help' if sphinx isn't present" * tag 'doc-4.8-fixes' of git://git.lwn.net/linux: DocBook: use DOCBOOKS="" to ignore DocBooks instead of IGNORE_DOCBOOKS=1 Documenation: update cgroup's document path Documentation/sphinx: do not warn about missing tools in 'make help'
2016-08-03Documentation/sphinx: do not warn about missing tools in 'make help'Jani Nikula
Simply move the dochelp rule outside of the HAVE_SPHINX check, overriding the .DEFAULT rule for HAVE_SPHINX=0. Cc: Jonathan Corbet <corbet@lwn.net> Cc: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-07-28doc-rst: Remove the media docbookMauro Carvalho Chehab
Now that all media documentation was converted to Sphinx, we should get rid of the old DocBook one, as we don't want people to submit patches against the old stuff. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-07-15Merge branch 'docs-next' of git://git.lwn.net/linux into devel/docs-nextMauro Carvalho Chehab
* 'docs-next' of git://git.lwn.net/linux: doc-rst: add an option to ignore DocBooks when generating docs workqueue: Fix a typo in workqueue.txt Doc: ocfs: Fix typo in filesystems/ocfs2-online-filecheck.txt Documentation/sphinx: skip build if user requested specific DOCBOOKS Documentation: add cleanmediadocs to the documentation targets
2016-07-08doc_rst: rename the media Sphinx suff to Documentation/mediaMauro Carvalho Chehab
The name of the subsystem is "media", and not "linux_tv". Also, as we plan to add other stuff there in the future, let's rename also the media uAPI book to media_uapi, to make it clearer. No functional changes. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-07-08doc-rst: linux_tv/Makefile: Honor quiet make O=dirMarkus Heiser
To honor the: make O=dir [targets] Locate all output files in "dir" * activate kernel-include directive * export BUILDDIR=$(BUILDDIR) * linux_tv: replace '.. include::' with '.. kernel-include:: $BUILDDIR/<foo.h.rst>' Signed-off-by: Markus Heiser <markus.heiser@darmarIT.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-07-08doc-rst: linux_tv/Makefile: Honor quiet modeMauro Carvalho Chehab
Cleanup the Makefile and handle the V=1 flag and make it to work when specifying an output directory with O=dir Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-07-07doc-rst: auto-build the frontend.h.rstMauro Carvalho Chehab
This file is auto-generated with DocBook, from the uapi header. Do the same with Sphinx. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-07-01Documentation/sphinx: skip build if user requested specific DOCBOOKSJani Nikula
If the user requested specific DocBooks to be built using 'make DOCBOOKS=foo.xml htmldocs', assume no Sphinx build is desired. This check is transitional, and can be removed once we drop the DocBook build. Cc: Markus Heiser <markus.heiser@darmarit.de> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Fixes: 22cba31bae9d ("Documentation/sphinx: add basic working Sphinx configuration and build") Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-07-01Documentation: add cleanmediadocs to the documentation targetsJani Nikula
This was broken when updating the documentation targets for the Sphinx build, and moving from %docs target pattern to explicitly listed targets. Cc: Markus Heiser <markus.heiser@darmarit.de> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Fixes: 22cba31bae9d ("Documentation/sphinx: add basic working Sphinx configuration and build") Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-06-23Documentation: add top level 'make help' output for SphinxJani Nikula
While there's slight overlap with the DocBook help now, this can stay intact when the DocBook help goes away. Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2016-05-30Documentation/sphinx: set version and release properlyJani Nikula
Read the version and release from the top level Makefile (for use when Sphinx is invoked directly, by e.g. Read the Docs), but override them via Sphinx command line arguments in a normal documentation build. Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2016-05-30Documentation/sphinx: configure the kernel-doc extensionJani Nikula
Tell Sphinx where to find the extension, and pass on the kernel src tree and kernel-doc paths to the extension. With this, any .rst files under Documentation may contain the kernel-doc rst directive to include kernel-doc documentation from any source file. While building, it may be handy to pass kernel-doc extension configuration on the command line. For example, 'make SPHINXOPTS="-D kerneldoc_verbosity=0" htmldocs' silences all stderr output from kernel-doc when the kernel-doc exit code is 0. (The stderr will be logged unconditionally when the exit code is non-zero.) Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2016-05-30Documentation/sphinx: add basic working Sphinx configuration and buildJani Nikula
Add basic configuration and makefile to build documentation from any .rst files under Documentation using Sphinx. For starters, there's just the placeholder index.rst. At the top level Makefile, hook Sphinx documentation targets alongside (but independent of) the DocBook toolchain, having both be run on the various 'make *docs' targets. All Sphinx processing is placed into Documentation/Makefile.sphinx. Both that and the Documentation/DocBook/Makefile are now expected to handle all the documentation targets, explicitly ignoring them if they're not relevant for that particular toolchain. The changes to the existing DocBook Makefile are kept minimal. There is graceful handling of missing Sphinx and rst2pdf (which is needed for pdf output) by checking for the tool and python module, respectively, with informative messages to the user. If the Read the Docs theme (sphinx_rtd_theme) is available, use it, but otherwise gracefully fall back to the Sphinx default theme, with an informative message to the user, and slightly less pretty HTML output. Sphinx can now handle htmldocs, pdfdocs (if rst2pdf is available), epubdocs and xmldocs targets. The output documents are written into per output type subdirectories under Documentation/output. Finally, you can pass options to sphinx-build using the SPHINXBUILD make variable. For example, 'make SPHINXOPTS=-v htmldocs' for more verbose output from Sphinx. This is based on the original work by Jonathan Corbet, but he probably wouldn't recognize this as his own anymore. Signed-off-by: Jani Nikula <jani.nikula@intel.com>
