path: root/Documentation/RCU/rcu.txt
2010-01-16rcu: 1Q2010 update for RCU documentationPaul E. McKenney
Add expedited functions. Review documentation and update obsolete verbiage. Also fix the advice for the RCU CPU-stall kernel configuration parameter, and document RCU CPU-stall warnings. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12635142581866-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Remove CONFIG_PREEMPT_RCUPaul E. McKenney
Now that CONFIG_TREE_PREEMPT_RCU is in place, there is no further need for CONFIG_PREEMPT_RCU. Remove it, along with whatever subtle bugs it may (or may not) contain. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <125097461396-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02Doc: Fix missing whitespaces in RCU documentation.Jesper Dangaard Brouer
Trivial fix while reading through the RCU docs. Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-25Preempt-RCU: update RCU Documentation.Paul E. McKenney
This patch updates the RCU documentation to reflect preemptible RCU as well as recent publications. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Reviewed-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-10-04[PATCH] srcu-3: RCU variant permitting read-side blockingPaul E. McKenney
Updated patch adding a variant of RCU that permits sleeping in read-side critical sections. SRCU is as follows: o Each use of SRCU creates its own srcu_struct, and each srcu_struct has its own set of grace periods. This is critical, as it prevents one subsystem with a blocking reader from holding up SRCU grace periods for other subsystems. o The SRCU primitives (srcu_read_lock(), srcu_read_unlock(), and synchronize_srcu()) all take a pointer to a srcu_struct. o The SRCU primitives must be called from process context. o srcu_read_lock() returns an int that must be passed to the matching srcu_read_unlock(). Realtime RCU avoids the need for this by storing the state in the task struct, but SRCU needs to allow a given code path to pass through multiple SRCU domains -- storing state in the task struct would therefore require either arbitrary space in the task struct or arbitrary limits on SRCU nesting. So I kicked the state-storage problem up to the caller. Of course, it is not permitted to call synchronize_srcu() while in an SRCU read-side critical section. o There is no call_srcu(). It would not be hard to implement one, but it seems like too easy a way to OOM the system. (Hey, we have enough trouble with call_rcu(), which does -not- permit readers to sleep!!!) So, if you want it, please tell me why... [josht@us.ibm.com: sparse notation] Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] RCU documentation fixes (January 2006 update)Paul E. McKenney
Updates to in-tree RCU documentation based on comments over the past few months. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] Yet another RCU documentation updatePaul E. McKenney
Update RCU documentation based on discussions and review of RCU-based tree patches. Add an introductory whatisRCU.txt file. Signed-off-by: <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Update RCU documentationPaul E. McKenney
Update the RCU documentation to allow for the new synchronize_rcu() and synchronize_sched() primitives. Fix a few other nits as well. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
