path: root/Documentation/SubmitChecklist
2008-02-13Documentation: prune redundant SubmitChecklist itemsJ. Bruce Fields
Kernel style is mentioned twice, and the git apply trick is a bit redundant given the checkpatch.pl recommendation (which also checks for bad whitespace). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20Documentation: Fix typo in SubmitChecklist.James Bowes
Signed-off-by: James Bowes <jbowes@dangerouslyinc.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-16SubmitChecklist update, fix spelling errorJesper Juhl
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01add a trivial patch style checkerAndy Whitcroft
We are seeing increasing levels of minor patch style violations in submissions to the mailing lists as well as making it into the tree. These detract from the quality of the submission and cause unnessary work for reviewers. As a first step package up the current state of the patch style checker and include it in the kernel tree. Add instructions suggesting running it on submissions. This adds version v0.01 of the checkpatch.pl script. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Joel Schopp <jschopp@austin.ibm.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11SubmitChecklist: add -W helpAndrew Morton
Help people to work out how to use `gcc -W'. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Add info about whitespace to SubmitChecklistRoland Dreier
Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] add -mm testing in SubmitChecklistRandy Dunlap
Add -mm testing to SubmitChecklist. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] SubmitChecklist updateAndrew Morton
Sing the praises of `gcc -W'. Would have prevented that blockdev direct-IO bug. Cc: "Chen, Kenneth W" <kenneth.w.chen@intel.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] submit checklist updateAndrew Morton
Mention the new fault-injection test framework. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] submit checklist: mention headers_checkAndrew Morton
Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Mention Documenation/ABI/ requirements in Documentation/SubmitChecklistRandy Dunlap
Mention Documenation/ABI/ requirements in Documentation/SubmitChecklist. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] checklist updateAndrew Morton
Update Documentation/SubmitChecklist. - Mention lockdep coverage - Describe documentation requirements - Number the various items to simplify the composition of caustic emails. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] add Doc/SubmitChecklistRandy Dunlap
Provide a checklist of techniques to aid kernel patch submitters in producing healthy patches and in lessening a burden on maintainers. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
