path: root/Documentation/aoe
2012-12-17aoe: allow user to disable target failure timeoutEd Cashin
With this change, the aoe driver treats the value zero as special for the aoe_deadsecs module parameter. Normally, this value specifies the number of seconds during which the driver will continue to attempt retransmits to an unresponsive AoE target. After aoe_deadsecs has elapsed, the aoe driver marks the aoe device as "down" and fails all I/O. The new meaning of an aoe_deadsecs of zero is for the driver to retransmit commands indefinitely. Signed-off-by: Ed Cashin <ecashin@coraid.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06aoe: update documentation to better reflect aoe-plus-udev usageEd Cashin
Signed-off-by: Ed Cashin <ecashin@coraid.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06aoe: update documentation with new URL and VM settings referenceEd Cashin
The old area has a new URL. Also, now that the driver can perform better, it is worth mentioning the VM settings that help aoe to sink dirty pages out early, avoiding unecessary memory pressure when much I/O is going on. Signed-off-by: Ed Cashin <ecashin@coraid.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-02-08aoe: user can ask driver to forget previously detected devicesEd L. Cashin
When an AoE device is detected, the kernel is informed, and a new block device is created. If the device is unused, the block device corresponding to remote device that is no longer available may be removed from the system by telling the aoe driver to "flush" its list of devices. Without this patch, software like GPFS and LVM may attempt to read from AoE devices that were discovered earlier but are no longer present, blocking until the I/O attempt times out. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aoe: clean up udev configuration exampleEd L. Cashin
This patch adds a known default location for the udev configuration file and uses the more recent "==" syntax for SUBSYSTEM and KERNEL. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-23[PATCH] aoe [2/8]: support dynamic resizing of AoE devicesEd L. Cashin
Allow the driver to recognize AoE devices that have changed size. Devices not in use are updated automatically, and devices that are in use are updated at user request. Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-09[PATCH] aoe [1/2]: support 16 AoE slot addresses per AoE shelfEd L Cashin
Change the number of supported AoE slot addresses per AoE shelf address to 16. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-03[PATCH] aoe: update the documentation to mention aoetoolsEd L Cashin
update the documentation to mention aoetools Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-03[PATCH] aoe: aoe-stat should work for built-in as well as moduleEd L Cashin
aoe-stat should work for built-in as well as module Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -uprN a/Documentation/aoe/status.sh b/Documentation/aoe/status.sh
2005-05-03[PATCH] aoe: improve allowed interfaces configurationEd L Cashin
improve allowed interfaces configuration Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -uprN a/Documentation/aoe/aoe.txt b/Documentation/aoe/aoe.txt
2005-04-18[PATCH] aoe 9/12: add note about the need for deadlock-free sk_buff allocationecashin@coraid.com
add note about the need for deadlock-free sk_buff allocation Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] aoe 8/12: document env var for specifying numberecashin@coraid.com
document env var for specifying number of partitions per dev Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] aoe 4/12: handle distros that have a udev rulesecashin@coraid.com
handle distros that have a udev rules file instead of dir Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
