path: root/Documentation/aoe
2008-02-08aoe: user can ask driver to forget previously detected devicesEd L. Cashin
When an AoE device is detected, the kernel is informed, and a new block device is created. If the device is unused, the block device corresponding to remote device that is no longer available may be removed from the system by telling the aoe driver to "flush" its list of devices. Without this patch, software like GPFS and LVM may attempt to read from AoE devices that were discovered earlier but are no longer present, blocking until the I/O attempt times out. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aoe: clean up udev configuration exampleEd L. Cashin
This patch adds a known default location for the udev configuration file and uses the more recent "==" syntax for SUBSYSTEM and KERNEL. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-23[PATCH] aoe [2/8]: support dynamic resizing of AoE devicesEd L. Cashin
Allow the driver to recognize AoE devices that have changed size. Devices not in use are updated automatically, and devices that are in use are updated at user request. Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-09[PATCH] aoe [1/2]: support 16 AoE slot addresses per AoE shelfEd L Cashin
Change the number of supported AoE slot addresses per AoE shelf address to 16. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-03[PATCH] aoe: update the documentation to mention aoetoolsEd L Cashin
update the documentation to mention aoetools Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-03[PATCH] aoe: aoe-stat should work for built-in as well as moduleEd L Cashin
aoe-stat should work for built-in as well as module Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -uprN a/Documentation/aoe/status.sh b/Documentation/aoe/status.sh
2005-05-03[PATCH] aoe: improve allowed interfaces configurationEd L Cashin
improve allowed interfaces configuration Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -uprN a/Documentation/aoe/aoe.txt b/Documentation/aoe/aoe.txt
2005-04-18[PATCH] aoe 9/12: add note about the need for deadlock-free sk_buff allocationecashin@coraid.com
add note about the need for deadlock-free sk_buff allocation Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] aoe 8/12: document env var for specifying numberecashin@coraid.com
document env var for specifying number of partitions per dev Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] aoe 4/12: handle distros that have a udev rulesecashin@coraid.com
handle distros that have a udev rules file instead of dir Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
