path: root/Documentation/arm
2019-08-12Documentation/arm/samsung-s3c24xx: Remove stray U+FEFF character to fix titleJonathan Neuschäfer
It seems a UTF-8 byte order mark (the least useful kind of BOM...) snuck into the file and broke Sphinx's detection of the title line. Besides making arm/samsung-s3c24xx/index.html look a little better, this patch also confines the non-index pages in arm/samsung-s3c24xx to their own table of contents. Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-08-12Documentation/arm/sa1100/assabet: Fix 'make assabet_defconfig' commandJonathan Neuschäfer
"make assabet_config" doesn't work. Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-08-12Documentation/arm/sa1100: Remove some obsolete documentationJonathan Neuschäfer
The support for the following boards, among others, was removed in 2004 with commit "[ARM] Remove broken SA1100 machine support.": - ADS Bitsy - Brutus - Freebird - ADS GraphicsClient Plus - ADS GraphicsMaster - Höft & Wessel Webpanel - Compaq Itsy - nanoEngine - Pangolin - PLEB - Yopy Tifon support has been removed in 2.4.3.3. Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-07-31docs: arm: Remove orphan sh-mobile directoryGeert Uytterhoeven
This directory is empty, except for a .gitignore file, listing an executable file that can no longer be built since commit c6535e1e0361157e ("Documentation: Remove ZBOOT MMC/SDHI utility and docs"). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-07-15docs: arm: fix a breakage with pdf outputMauro Carvalho Chehab
Add an extra blank line, as otherwise XeLaTex will complain with: ! LaTeX Error: Too deeply nested. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-07-15docs: add SPDX tags to new index filesMauro Carvalho Chehab
All those new files I added are under GPL v2.0 license. Add the corresponding SPDX headers to them. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-07-15docs: add arch doc directories to the indexMauro Carvalho Chehab
Now that several arch documents were converted to ReST, add their indexes to Documentation/index.rst and remove the :orphan: from them. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-07-15docs: arm: convert docs to ReST and rename to *.rstMauro Carvalho Chehab
Converts ARM the text files to ReST, preparing them to be an architecture book. The conversion is actually: - add blank lines and identation in order to identify paragraphs; - fix tables markups; - add some lists markups; - mark literal blocks; - adjust title markups. At its new index.rst, let's add a :orphan: while this is not linked to the main index.rst file, in order to avoid build warnings. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Reviewed-by Corentin Labbe <clabbe.montjoie@gmail.com> # For sun4i-ss
2019-06-08docs: mark orphan documents as suchMauro Carvalho Chehab
Sphinx doesn't like orphan documents: Documentation/accelerators/ocxl.rst: WARNING: document isn't included in any toctree Documentation/arm/stm32/overview.rst: WARNING: document isn't included in any toctree Documentation/arm/stm32/stm32f429-overview.rst: WARNING: document isn't included in any toctree Documentation/arm/stm32/stm32f746-overview.rst: WARNING: document isn't included in any toctree Documentation/arm/stm32/stm32f769-overview.rst: WARNING: document isn't included in any toctree Documentation/arm/stm32/stm32h743-overview.rst: WARNING: document isn't included in any toctree Documentation/arm/stm32/stm32mp157-overview.rst: WARNING: document isn't included in any toctree Documentation/gpu/msm-crash-dump.rst: WARNING: document isn't included in any toctree Documentation/interconnect/interconnect.rst: WARNING: document isn't included in any toctree Documentation/laptops/lg-laptop.rst: WARNING: document isn't included in any toctree Documentation/powerpc/isa-versions.rst: WARNING: document isn't included in any toctree Documentation/virtual/kvm/amd-memory-encryption.rst: WARNING: document isn't included in any toctree Documentation/virtual/kvm/vcpu-requests.rst: WARNING: document isn't included in any toctree So, while they aren't on any toctree, add :orphan: to them, in order to silent this warning. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Andrew Donnellan <ajd@linux.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-06-07treewide: trivial: fix s/poped/popped/ typoGeorge G. Davis
Fix a couple of s/poped/popped/ typos. Signed-off-by: George G. Davis <george_davis@mentor.com> Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-02-12ARM: 8833/1: Ensure that NEON code always compiles with ClangNathan Chancellor
While building arm32 allyesconfig, I ran into the following errors: arch/arm/lib/xor-neon.c:17:2: error: You should compile this file with '-mfloat-abi=softfp -mfpu=neon' In file included from lib/raid6/neon1.c:27: /home/nathan/cbl/prebuilt/lib/clang/8.0.0/include/arm_neon.h:28:2: error: "NEON support not enabled" Building V=1 showed NEON_FLAGS getting passed along to Clang but __ARM_NEON__ was not getting defined. Ultimately, it boils down to Clang only defining __ARM_NEON__ when targeting armv7, rather than armv6k, which is the '-march' value for allyesconfig. >From lib/Basic/Targets/ARM.cpp in the Clang source: // This only gets set when Neon instructions are actually available, unlike // the VFP define, hence the soft float and arch check. This is subtly // different from gcc, we follow the intent which was that it should be set // when Neon instructions are actually available. if ((FPU & NeonFPU) && !SoftFloat && ArchVersion >= 7) { Builder.defineMacro("__ARM_NEON", "1"); Builder.defineMacro("__ARM_NEON__"); // current AArch32 NEON implementations do not support double-precision // floating-point even when it is present in VFP. Builder.defineMacro("__ARM_NEON_FP", "0x" + Twine::utohexstr(HW_FP & ~HW_FP_DP)); } Ard Biesheuvel recommended explicitly adding '-march=armv7-a' at the beginning of the NEON_FLAGS definitions so that __ARM_NEON__ always gets definined by Clang. This doesn't functionally change anything because that code will only run where NEON is supported, which is implicitly armv7. Link: https://github.com/ClangBuiltLinux/linux/issues/287 Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Acked-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Nick Desaulniers <ndesaulniers@google.com> Reviewed-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-11-20Documentation: Use "while" instead of "whilst"Will Deacon
Whilst making an unrelated change to some Documentation, Linus sayeth: | Afaik, even in Britain, "whilst" is unusual and considered more | formal, and "while" is the common word. | | [...] | | Can we just admit that we work with computers, and we don't need to | use þe eald Englisc spelling of words that most of the world never | uses? dictionary.com refers to the word as "Chiefly British", which is probably an undesirable attribute for technical documentation. Replace all occurrences under Documentation/ with "while". Cc: David Howells <dhowells@redhat.com> Cc: Liam Girdwood <lgirdwood@gmail.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Jonathan Corbet <corbet@lwn.net> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-10-29Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree updates from Arnd Bergmann: "There are close to 800 indivudal changesets in this branch again, which feels like a lot. There are particularly many changes for the NVIDIA Tegra platform this time, in fact more than it has seen in the two years since the v4.9 merge window. Aside from this, it's been fairly normal, with lots of changes going into Renesas R-CAR, NXP i.MX, Allwinner Sunxi, Samsung Exynos, and TI OMAP. Most of the changes are for adding new features into existing boards, for brevity I'm only mentioning completely new machines and SoCs here. For the first time I think we have (slightly) more new 64-bit hardware than 32-bit: Two boards get added for TI OMAP: Moxa UC-2101 is an industrial computer, see https://www.moxa.com/product/UC-2100.htm; GTA04A5 is a minor variation of the motherboards of the GTA04 phone, see https://shop.goldelico.com/wiki.php?page=GTA04A5 Clearfog is a nice little board for quad-core Marvell Armada 8040 network processor, see https://www.solid-run.com/marvell-armada-family/clearfog-gt-8k/ Two additional server boards come with the Aspeed baseboard management controllers: Stardragon4800 is an arm64 reference platform made by HXT (based on Qualcomm's server chips), and TiogaPass is an Open Compute mainboard with x86 CPUs. Both use the ARM11 based AST2500 chips in the BMC. NXP i.MX usually sees a lot of new boards each release. This time there we only add one minor variant: ConnectCore 6UL SBC Pro uses the same SoM design as the ConnectCore 6UL SBC Express added later. However, there is a new chip, the i.MX6ULZ, which is an even smaller variant of the i.MX6ULL, with features removed. There is also support for the reference board design, the i.MX6ULZ 14x14 EVK. A new Raspberry Pi variant gets added, this one is the CM3 compute module based on bcm2837, it was launched in early 2017 but only now added to the kernel, both as 32-bit and as 64-bit files, as we tend to do for Raspberry Pi. On the Allwinner side, everything is again about cheap development boards, usually of the "Fruit Pi" variety. The new ones this time are: - Orange Pi Zero Plus2: http://www.orangepi.org/OrangePiZeroPlus2/ - Orange Pi One Plus: http://www.orangepi.org/OrangePiOneplus/ - Pine64 LTS: https://www.pine64.org/?product=pine-a64-lts - Banana Pi M2+ H5: http://www.banana-pi.org/m2plus.html The last one of these is now a 64-bit version of the earlier Banana Pi M2+ H3, with the same board layout. Similarly, for Rockchips, get get another variant of the 32-bit Asus Tinker board, the model 'S' based on rk3288, and three now boards based on the popular RK3399 chip: - ROC-RK3399-PC: https://libre.computer/products/boards/roc-rk3399-pc/ - Rock960: https://www.96boards.org/product/rock960/ - RockPro64: https://www.pine64.org/?page_id=61454 These are all quite powerful boards with lots of RAM and I/O, and the RK3399 is the same chip used in several Chromebooks. Finally, we get support for the PX30 (aka rk3326) chip, which is based on the low-end 64-bit Cortex-A35 CPU core. So far, only the evaluation board is supported. One more Banana Pi is added with a Mediatek chip: Banana Pi R64 is based on the MT7622 WiFi router platform, and the first product I've seen with a 64-bit Mediatek chip in that market: http://www.banana-pi.org/r64.html For HiSilicon, we gain support for the Hi3670 SoC and HiKey 370 development board, which are similar to the Hi3660 and Hikey 360 respectively, but add support for an NPU. Amlogic gets initial support for the Meson-G12A chip (S905D2), another quad-core Cortex-A53 SoC, and its evaluation platform. On the 32-bit side, we gain support for an actual end-user product, the Endless Computers Endless Mini based on Meson8b (S805), see https://endlessos.com/computers/ Qualcomm adds support for their MSM8998 SoC and evaluation platform. This chip is commonly known as the Snapdragon 835, and is used in high-end phones as well as low-end laptops. For Renesas, a very bare support for the r8a774a1 (RZ/G2M) is added, but no boards for this one. However, we do add boards for the previously added r8a77965 (R-Car M3-N): the M3NULCB Kingfisher and the M3NULCB Starter Kit Pro. While we have lots of DT changes for NVIDIA to update the existing files, the only board that gets added is the Toradex Colibri T20 on Colibri Evaluation Board for the old Tegra2. Synaptics add support for their AS370 SoC, which is part of the (formerly Marvell) Berlin line of set-top-box chips used e.g. in the various Google Chromecast. Only the .dtsi gets added at this point, no actual machines" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (721 commits) ARM: dts: socfgpa: remove ethernet aliases from dtsi arm64: dts: stratix10: add ethernet aliases dt-bindings: mediatek: Add bindig for MT7623 IOMMU and SMI dt-bindings: mediatek: Add JPEG Decoder binding for MT7623 dt-bindings: iommu: mediatek: Add binding for MT7623 dt-bindings: clock: mediatek: add support for MT7623 ARM: dts: mvebu: armada-385-db-88f6820-amc: auto-detect nand ECC properites ARM: dts: da850-lego-ev3: slow down A/DC as much as possible ARM: dts: da850-evm: Enable tca6416 on baseboard arm64: dts: uniphier: Add USB2 PHY nodes arm64: dts: uniphier: Add USB3 controller nodes ARM: dts: uniphier: Add USB2 PHY nodes ARM: dts: uniphier: Add USB3 controller nodes arm64: dts: meson-axg: s400: disable emmc arm64: dts: meson-axg: s400: add missing emmc pwrseq arm64: dts: clearfog-gt-8k: add PCIe slot description ARM: dts: at91: sama5d4_xplained: even nand memory partitions ARM: dts: at91: sama5d3_xplained: even nand memory partitions ARM: dts: at91: at91sam9x5cm: even nand memory partitions ARM: dts: at91: sama5d2_ptc_ek: fix bootloader env offsets ...
2018-09-09Drop all 00-INDEX files from Documentation/Henrik Austad
This is a respin with a wider audience (all that get_maintainer returned) and I know this spams a *lot* of people. Not sure what would be the correct way, so my apologies for ruining your inbox. The 00-INDEX files are supposed to give a summary of all files present in a directory, but these files are horribly out of date and their usefulness is brought into question. Often a simple "ls" would reveal the same information as the filenames are generally quite descriptive as a short introduction to what the file covers (it should not surprise anyone what Documentation/sched/sched-design-CFS.txt covers) A few years back it was mentioned that these files were no longer really needed, and they have since then grown further out of date, so perhaps it is time to just throw them out. A short status yields the following _outdated_ 00-INDEX files, first counter is files listed in 00-INDEX but missing in the directory, last is files present but not listed in 00-INDEX. List of outdated 00-INDEX: Documentation: (4/10) Documentation/sysctl: (0/1) Documentation/timers: (1/0) Documentation/blockdev: (3/1) Documentation/w1/slaves: (0/1) Documentation/locking: (0/1) Documentation/devicetree: (0/5) Documentation/power: (1/1) Documentation/powerpc: (0/5) Documentation/arm: (1/0) Documentation/x86: (0/9) Documentation/x86/x86_64: (1/1) Documentation/scsi: (4/4) Documentation/filesystems: (2/9) Documentation/filesystems/nfs: (0/2) Documentation/cgroup-v1: (0/2) Documentation/kbuild: (0/4) Documentation/spi: (1/0) Documentation/virtual/kvm: (1/0) Documentation/scheduler: (0/2) Documentation/fb: (0/1) Documentation/block: (0/1) Documentation/networking: (6/37) Documentation/vm: (1/3) Then there are 364 subdirectories in Documentation/ with several files that are missing 00-INDEX alltogether (and another 120 with a single file and no 00-INDEX). I don't really have an opinion to whether or not we /should/ have 00-INDEX, but the above 00-INDEX should either be removed or be kept up to date. If we should keep the files, I can try to keep them updated, but I rather not if we just want to delete them anyway. As a starting point, remove all index-files and references to 00-INDEX and see where the discussion is going. Signed-off-by: Henrik Austad <henrik@austad.us> Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Just-do-it-by: Steven Rostedt <rostedt@goodmis.org> Reviewed-by: Jens Axboe <axboe@kernel.dk> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Mark Brown <broonie@kernel.org> Acked-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: [Almost everybody else] Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-08-30ARM: exynos: Fix imprecise abort during Exynos5422 suspend to RAMKrzysztof Kozlowski
Suspend to RAM on Odroid XU3/XU4/HC1 family (Exynos5422) causes imprecise abort: PM: Syncing filesystems ... done. Freezing user space processes ... (elapsed 0.003 seconds) done. OOM killer disabled. Freezing remaining freezable tasks ... (elapsed 0.003 seconds) done. wake enabled for irq 139 Disabling non-boot CPUs ... IRQ51 no longer affine to CPU1 IRQ52 no longer affine to CPU2 IRQ53 no longer affine to CPU3 IRQ54 no longer affine to CPU4 IRQ55 no longer affine to CPU5 IRQ56 no longer affine to CPU6 cpu cpu4: Dropping the link to regulator.40 IRQ57 no longer affine to CPU7 Unhandled fault: external abort on non-linefetch (0x1008) at 0xf081a028 Internal error: : 1008 [#1] PREEMPT SMP ARM with last call trace in exynos_suspend_enter(). The abort is caused by writing to register in secure part of sysram. Boards booted under secure firmware (e.g. Hardkernel Odroid boards) should access non-secure sysram. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
2018-06-11Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree updates from Olof Johansson: "As always, a large number of DT updates. Too many to enumerate them all, but at a glance: New SoCs introduced in this release: - Amlogic: + Meson 8M2 SoC, a.k.a. S812. A quad Cortex-A9 SoC used in some set top boxes and other products. - Mediatek: + MT7623A, which is a flavor of the MT7623 family with other on-chip ethernet options. - Qualcomm: + SDM845, a.k.a Snapdragon 845, an 4+4-core Kryo 385/845 (Cortex-A75/A55 derivative) SoC that's one of the current high-end mobile SoCs. It's great to see mainline support for it. So far, you can't do much with it, since a lot of peripherals are not yet in the DTs but driver support for USB, GPU and other pieces are starting to trickle in. This might end up being a well-supported SoC upstream if the momentum keeps up. - Renesas: + R8A77990, a.k.a R-Car E3, a new automotive entertainment-targeted SoC. Currently only one Cortex-A53 CPU is enabled, we are eagerly awaiting more. So far, basic drivers such as serial, gpios, PMU and ethernet are enabled. + R8A77470, a.k.a. RZ/G1C, a new dual Cortex-A7 SoC with PowerVR GPU. Same here, basic set of drivers such as serial, gpios and ethernet enabled, and SMP support is also forthcoming. - STMicroelectronics: + STM32F469, very similar tih STM32F429 but with display support Enhancements to SoCs/platforms (DTS contents, some driver portions might not be in yet): - Allwinner sun8i (h3/a33/a83t) SMP, DVFS tweaks, misc - Amlogic Meson: I2C, UFS, TDM, GPIO external interrupts, MMC resets - Hisilicon hi3660: Thermal cooling, CPU frequency scaling, mailbox interfaces - Marvell Berlin2CD: SMP support, thermal sensors - Mediatek MT7623: Highspeed DMA, audio support - Qualcomm IPQ8074 PCIe support, MSM8996 UFS support - Renesas: Watchdog and PMU support across many platforms - Rockchip RK3399: USB3 OTG support - Samsung Exynos: Audio-over-HDMI on Odroid X/X2/U3 - STMicro STM32: Lots of peripherals added to STM32MP175C - Uniphier: Ethernet support New boards: - Allwinner A20: Olimex A20-SOM-EVB-eMMC variant - Allwinner H2+: Libre Computer ALL-H3-CC (h2+ version) - Allwinner A33: Nintendo NES/SuperNES Classic Edition - Aspeed: S2600WF, Inventec Lanyang BMC, Portwell Neptune - Berlin2CD: Valve Steam Link - Broadcom BCM5301X: Luxul XAP-1610 and XWR-3150 V1 - Broadcom: Raspberry Pi 3 B+ - Mediatek MT7623N and MT7623A: reference boards - Meson 8M2: Tronsmart MXIII Plus - NXP i.MX: Engicam i.CoreM6, DHCOM iMX6 SOM, BTicino i.MX6DL Mamoj - Qualcomm MSM8974: Sony Xperia Z1 Compact support - Qualcomm SDM845: MTP development board - Renesas: Ebisu R8A77990 board - Renesas RZ/G1C: iwg23s: iWave G235-SDB - TI am335x: Pocketbeagle support" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (448 commits) ARM: dts: aspeed: Fix hwrng register address arm64: dts: sprd: whale2: Add the rtc enable clock for watchdog arm64: dts: sprd: Add GPIO and GPIO keys device nodes arm64: dts: sprd: fix typo in 'remote-endpoint' arm64: dts: apq8096-db820c: Removed bt-en-1-8v regulator arm64: dts: fix regulator property name for wlan pcie endpoint arm64: dts: qcom: msm8996: Use UFS_GDSC for UFS ARM: dts: pxa3xx: fix MMC clocks ARM: pxa: dts: add pin definitions for extended GPIOs ARM: pxa: dts: add gpio-ranges to gpio controller ARM: dts: ipq8074: Enable few peripherals for hk01 board ARM: dts: ipq8074: Add pcie nodes ARM: dts: ipq8074: Add peripheral nodes ARM: dts: ipq4019: Add qcom-ipq4019-ap.dk07.1-c2 board file ARM: dts: ipq4019: Add qcom-ipq4019-ap.dk07.1-c1 board file ARM: dts: ipq4019: Add ipq4019-ap.dk07.1 common data ARM: dts: ipq4019: Add qcom-ipq4019-ap.dk04.1-c3 board file ARM: dts: ipq4019: Add ipq4019-ap.dk04.1-c1 board file ARM: dts: ipq4019: Add ipq4019-ap.dk04.dtsi ARM: dts: ipq4019: Change the max opp frequency ...
2018-05-16Documentation: arm: clean up Marvell Berlin family infoThomas Hebb
Remove dead links, make spacing consistent, and note that the family was acquired by Synaptics in 2017. Signed-off-by: Thomas Hebb <tommyhebb@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-05-03Documentation: ARM: Add new MMC requirements for DRA7/K2GKishon Vijay Abraham I
From 4.18 kernel, all the MMC controller instances in DRA7 are programmed using sdhci based driver (sdhci-omap.c). Document this new requirement here. Both omap2plus_defconfig and multi_v7_defconfig has CONFIG_MMC_SDHCI_OMAP enabled. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-04-06Merge tag 'mtd/for-4.17' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Boris Brezillon: "MTD Core: - Remove support for asynchronous erase (not implemented by any of the existing drivers anyway) - Remove Cyrille from the list of SPI NOR and MTD maintainers - Fix kernel doc headers - Allow users to define the partitions parsers they want to test through a DT property (compatible of the partitions subnode) - Remove the bfin-async-flash driver (the only architecture using it has been removed) - Fix pagetest test - Add extra checks in mtd_erase() - Simplify the MTD partition creation logic and get rid of mtd_add_device_partitions() MTD Drivers: - Add endianness information to the physmap DT binding - Add Eon EN29LV400A IDs to JEDEC probe logic - Use %*ph where appropriate SPI NOR Drivers: - Make fsl-quaspi assign different names to MTD devices connected to the same QSPI controller - Remove an unneeded driver.bus assigned in the fsl-qspi driver NAND Core: - Prepare arrival of the SPI NAND subsystem by implementing a generic (interface-agnostic) layer to ease manipulation of NAND devices - Move onenand code base to the drivers/mtd/nand/ dir - Rework timing mode selection - Provide a generic way for NAND chip drivers to flag a specific GET/SET FEATURE operation as supported/unsupported - Stop embedding ONFI/JEDEC param page in nand_chip NAND Drivers: - Rework/cleanup of the mxc driver - Various cleanups in the vf610 driver - Migrate the fsmc and vf610 to ->exec_op() - Get rid of the pxa driver (replaced by marvell_nand) - Support ->setup_data_interface() in the GPMI driver - Fix probe error path in several drivers - Remove support for unused hw_syndrome mode in sunxi_nand - Various minor improvements" * tag 'mtd/for-4.17' of git://git.infradead.org/linux-mtd: (89 commits) dt-bindings: fsl-quadspi: Add the example of two SPI NOR mtd: fsl-quadspi: Distinguish the mtd device names mtd: nand: Fix some function description mismatches in core.c mtd: fsl-quadspi: Remove unneeded driver.bus assignment mtd: rawnand: marvell: Rename ->ecc_clk into ->core_clk mtd: rawnand: s3c2410: enhance the probe function error path mtd: rawnand: tango: fix probe function error path mtd: rawnand: sh_flctl: fix the probe function error path mtd: rawnand: omap2: fix the probe function error path mtd: rawnand: mxc: fix probe function error path mtd: rawnand: denali: fix probe function error path mtd: rawnand: davinci: fix probe function error path mtd: rawnand: cafe: fix probe function error path mtd: rawnand: brcmnand: fix probe function error path mtd: rawnand: sunxi: Stop supporting ECC_HW_SYNDROME mode mtd: rawnand: marvell: Fix clock resource by adding a register clock mtd: ftl: Use DIV_ROUND_UP() mtd: Fix some function description mismatches in mtdcore.c mtd: physmap_of: update struct map_info's swap as per map requirement dt-bindings: mtd-physmap: Add endianness supports ...
2018-04-05Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "The main addition this time around is the new ARM "SCMI" framework, which is the latest in a series of standards coming from ARM to do power management in a platform independent way. This has been through many review cycles, and it relies on a rather interesting way of using the mailbox subsystem, but in the end I agreed that Sudeep's version was the best we could do after all. Other changes include: - the ARM CCN driver is moved out of drivers/bus into drivers/perf, which makes more sense. Similarly, the performance monitoring portion of the CCI driver are moved the same way and cleaned up a little more. - a series of updates to the SCPI framework - support for the Mediatek mt7623a SoC in drivers/soc - support for additional NVIDIA Tegra hardware in drivers/soc - a new reset driver for Socionext Uniphier - lesser bug fixes in drivers/soc, drivers/tee, drivers/memory, and drivers/firmware and drivers/reset across platforms" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (87 commits) reset: uniphier: add ethernet reset control support for PXs3 reset: stm32mp1: Enable stm32mp1 reset driver dt-bindings: reset: add STM32MP1 resets reset: uniphier: add Pro4/Pro5/PXs2 audio systems reset control reset: imx7: add 'depends on HAS_IOMEM' to fix unmet dependency reset: modify the way reset lookup works for board files reset: add support for non-DT systems clk: scmi: use devm_of_clk_add_hw_provider() API and drop scmi_clocks_remove firmware: arm_scmi: prevent accessing rate_discrete uninitialized hwmon: (scmi) return -EINVAL when sensor information is unavailable amlogic: meson-gx-socinfo: Update soc ids soc/tegra: pmc: Use the new reset APIs to manage reset controllers soc: mediatek: update power domain data of MT2712 dt-bindings: soc: update MT2712 power dt-bindings cpufreq: scmi: add thermal dependency soc: mediatek: fix the mistaken pointer accessed when subdomains are added soc: mediatek: add SCPSYS power domain driver for MediaTek MT7623A SoC soc: mediatek: avoid hardcoded value with bus_prot_mask dt-bindings: soc: add header files required for MT7623A SCPSYS dt-binding dt-bindings: soc: add SCPSYS binding for MT7623 and MT7623A SoC ...
2018-03-12Merge tag 'at91-ab-4.17-soc' of ↵Arnd Bergmann
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/abelloni/linux into next/soc Pull "AT91 SoC for 4.17: from Alexandre Belloni: - Rename Atmel to Microhip in MAINTAINERS, Documentation and Kconfig * tag 'at91-ab-4.17-soc' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: ARM: at91: Kconfig: Update company to Microchip Documentation: at91: Update Microchip SoC documentation MAINTAINERS: ARM: at91: update entry for ARM/Microchip
2018-03-06drivers/bus: Move Arm CCN PMU driverRobin Murphy
The arm-ccn driver is purely a perf driver for the CCN PMU, not a bus driver in the sense of the other residents of drivers/bus/, so let's move it to the appropriate place for SoC PMU drivers. Not to mention moving the documentation accordingly as well. Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Robin Murphy <robin.murphy@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-03-05ARM: stm32: add initial support for STM32MP157Ludovic Barre
This patch adds initial support of STM32MP157 microprocessor (MPU) based on Arm Cortex-A7. New Cortex-A infrastructure (gic, timer,...) are selected if ARCH_MULTI_V7 is defined. Signed-off-by: Ludovic Barre <ludovic.barre@st.com> Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com>
2018-03-05ARM: stm32: prepare stm32 family to welcome armv7 architectureLudovic Barre
This patch prepares the STM32 machine for the integration of Cortex-A based microprocessor (MPU), on top of the existing Cortex-M microcontroller family (MCU). Since both MCUs and MPUs are sharing common hardware blocks we can keep using ARCH_STM32 flag for most of them. If a hardware block is specific to one family we can use either ARM_SINGLE_ARMV7M or ARCH_MULTI_V7 flag. Signed-off-by: Ludovic Barre <ludovic.barre@st.com> Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com>
2018-03-05Documentation: arm: stm32: move to rst formatLudovic Barre
This patch rewrites stm32 documentation to rst (ReStructuredText) format. Signed-off-by: Ludovic Barre <ludovic.barre@st.com> Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com>
2018-03-05ARM: stm32: add new STM32F769 MCUAlexandre Torgue
Add new st,stm32f769 compatible machine name for STM32F769 MCU and update documentation. Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com>
2018-02-28Documentation: at91: Update Microchip SoC documentationNicolas Ferre
We move the former Atmel wording to the the new Microchip name for this SoC family. With the name of the directory we also change the content in relation with the update of the MAINTAINERS file. The Datasheet links now point to real documents instead of 404s. Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
2018-02-16mtd: nand: move raw NAND related code to the raw/ subdirBoris Brezillon
As part of the process of sharing more code between different NAND based devices, we need to move all raw NAND related code to the raw/ subdirectory. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
2017-09-22ARM: sunxi: add support for R40 SoCIcenowy Zheng
Allwinner R40 is a new SoC, with Quad Core Cortex-A7 and peripherals like A20. Add support for it. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-22ARM: sunxi: fix the core number of V3s in sunxi READMEIcenowy Zheng
The Allwinner V3s SoC is not quad-core, but single-core. Fix this in the README file. Fixes: b074fede01c0 ("arm: sunxi: add support for V3s SoC") Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-07-17Documentation: arm: Replace use of virt_to_phys with __pa_symbolGeert Uytterhoeven
All low-level PM/SMP code using virt_to_phys() should actually use __pa_symbol() against kernel symbols. Update the documentation to move away from virt_to_phys(). Cfr. commit 6996cbb2372189f7 ("ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbol") Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2017-06-02ARM: at91: Documentation: add armv7m familiesAlexandre Belloni
The Atmel sams70, samv70 and samv71 are Cortex-M7 based MCUs that can run Linux (without MMU). Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2017-05-09Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "SoC platform changes (arch/arm/mach-*). This merge window, the bulk is for a few platforms: Gemini: - Legacy platform that Linus Walleij has converted to multiplatform and DT, so a handful of various tweaks there, removal of some old stale support, etc. Atmel AT91: - Fixup of various power management related pieces - Move of SoC detection to a drivers/soc driver instead ST Micro STM32: - New SoC support: STM32H743 TI platforms: - More driver support for Davinci (SATA in particular) - Removal of some old stale hwmod files (linkspace platform) Misc: - A couple of smaller patches for i.MX, sunxi, hisi" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits) ARM: davinci: Add clock for CPPI 4.1 DMA engine ARM: mxs: add support for I2SE Duckbill 2 boards MAINTAINERS: Update the Allwinner sunXi entry ARM: i.MX25: globally disable supervisor protect ARM: at91: move SoC detection to its own driver ARM: at91: pm: correct typo ARM: at91: pm: Remove at91_pm_set_standby ARM: at91: pm: Merge all at91sam9*_pm_init ARM: at91: pm: Tie the USB clock mask to the pmc ARM: at91: pm: Tie the memory controller type to the ramc id ARM: at91: pm: Workaround DDRSDRC self-refresh bug with LPDDR1 memories. ARM: at91: pm: Simplify at91rm9200_standby ARM: at91: pm: Use struct at91_pm_data in pm_suspend.S ARM: at91: pm: Move global variables into at91_pm_data ARM: at91: pm: Move at91_ramc_read/write to pm.c ARM: at91: pm: Cleanup headers MAINTAINERS: Add memory drivers to AT91 entry MAINTAINERS: Update AT91 entry ARM: davinci: add pata_bk3710 libata driver support ARM: OMAP2+: mark omap_init_rng as __init ...
2017-04-20arm: Documentation: update a path namePerr Zhang
the path in the example cmd is out of date, and the path for now is also mentioned in the same file Signed-off-by: Perr Zhang <strongbox8@zoho.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2017-03-24ARM: stm32: Add a new SOC - STM32H743Alexandre TORGUE
The STM32H743 is a Cortex-M7 MCU running at 400MHz and containing 1MBytes internal RAM. Signed-off-by: Alexandre TORGUE <alexandre.torgue@st.com>
2017-01-20arm: sunxi: add support for V3s SoCIcenowy Zheng
Allwinner V3s is a low-end single-core Cortex-A7 SoC, with 64MB integrated DRAM, and several peripherals. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-01-02ARM: sunxi: add support for H2+ SoCIcenowy Zheng
Allwinner H2+ is a quad-core Cortex-A7 SoC. It is very like H3, that they share the same SoC ID (0x1680), and H3 memory maps as well as drivers works well on the SoC. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-12-15Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "These are updates for platform specific code on 32-bit ARM machines, essentially anything that can not (yet) be expressed using DT files. Noteworthy changes include: - Added support for the TI DRA71x family of SoCs in mach-omap2, this is an new variant of the the DRA72x/DRA74x automotive infotainment chips we already supported for a while. - Added support for the ST STM32F746 SoC, the first Cortex-M7 based microcontroller we support, related to the smaller STM32F4 family. - Renesas adds support for r8a7743 and r8a7745 in mach-shmobile, see http://elinux.org/RZ-G - SMP is now supported on the OX820 platform - A lot of code in mach-omap2 gets removed as a follow-up to removing support for board files in the previous release - Davinci has some new work to improve USB support - For i.MX, the performance monitor now supports profiling the memory controller using 'perf'" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (95 commits) ARM: davinci: da830-evm: use gpio descriptor for mmc pins ARM: davinci: da850-evm: use gpio descriptor for mmc pins ARM: davinci: hawk: use gpio descriptor for mmc pins ARM: ARTPEC-6: add select MFD_SYSCON to MACH_ARTPEC6 ARM: davinci: da8xx: Fix ohci device name ARM: oxnas: Add OX820 config and makefile entry ARM: oxnas: Add OX820 SMP support ARM: davinci: PM: fix build when da850 not compiled in ARM: orion5x: remove legacy support of ls-chl ARM: integrator: drop EBI access use syscon ARM: BCM5301X: Add back handler ignoring external imprecise aborts ARM: davinci: PM: support da8xx DT platforms ARM: davinci: PM: cleanup: remove references to pdata ARM: davinci: PM: rework init, remove platform device ARM: Kconfig: Introduce MACH_STM32F746 flag ARM: mach-stm32: Add a new SOC - STM32F746 ARM: shmobile: document SK-RZG1E board ARM: shmobile: r8a7745: basic SoC support ARM: imx: mach-imx6ul: add imx6ull support ARM: zynq: Reserve correct amount of non-DMA RAM ...
2016-11-15ARM: mach-stm32: Add a new SOC - STM32F746Alexandre TORGUE
2016-10-24docs: fix locations of several documents that got movedMauro Carvalho Chehab
The previous patch renamed several files that are cross-referenced along the Kernel documentation. Adjust the links to point to the right places. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-10-14Merge tag 'linux-kselftest-4.9-rc1-update' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest updates from Shuah Khan: "This update consists of: - Fixes and improvements to existing tests - Moving code from Documentation to selftests, samples, and tools: * Moves dnotify_test, prctl, ptp, vDSO, ia64, watchdog, and networking tests from Documentation to selftests. * Moves mic/mpssd, misc-devices/mei, timers, watchdog, auxdisplay, and blackfin examples from Documentation to samples. * Moves accounting, laptops/dslm, and pcmcia/crc32hash tools from Documentation to tools. * Deletes BUILD_DOCSRC and its dependencies" * tag 'linux-kselftest-4.9-rc1-update' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: (21 commits) selftests/futex: Check ANSI terminal color support Doc: update 00-INDEX files to reflect the runnable code move samples: move blackfin gptimers-example from Documentation tools: move pcmcia crc32hash tool from Documentation tools: move laptops dslm tool from Documentation tools: move accounting tool from Documentation samples: move auxdisplay example code from Documentation samples: move watchdog example code from Documentation samples: move timers example code from Documentation samples: move misc-devices/mei example code from Documentation samples: move mic/mpssd example code from Documentation selftests: Move networking/timestamping from Documentation selftests: move watchdog tests from Documentation/watchdog selftests: move ia64 tests from Documentation/ia64 selftests: move vDSO tests from Documentation/vDSO selftests: move ptp tests from Documentation/ptp selftests: move prctl tests from Documentation/prctl selftests: move dnotify_test from Documentation/filesystems selftests/timers: Add missing error code assignment before test selftests/zram: replace ZRAM_LZ4_COMPRESS ...
2016-10-10Doc: update 00-INDEX files to reflect the runnable code moveShuah Khan
Update 00-INDEX files with the current file list to reflect the runnable code move. Acked-by: Michal Marek <mmarek@suse.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-10-07Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "These are updates for platform specific code on 32-bit ARM machines, essentially anything that can not (yet) be expressed using DT files. Noteworthy changes include: - We get support for running in big-endian mode on two platforms: sunxi (Allwinner) and s3c24xx (old Samsung). - The recently added Uniphier platform now uses standard PSCI methods for SMP booting and we remove support for old bootloader versions that did not support it yet. - In sunxi, we gain support for the "Nextthing GR8" SoC, which is a close relative of the Allwinner A13 and R8 chips. - PXA completes its move over to the generic dmaengine framework and removes its old private API - mach-bcm gains support for BCM47189/BCM53573, their first ARM SoC with integrated 802.11ac wireless networking" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: imx legacy: pca100: move peripheral initialization to .init_late ARM: imx legacy: mx27ads: move peripheral initialization to .init_late ARM: imx legacy: mx21ads: move peripheral initialization to .init_late ARM: imx legacy: pcm043: move peripheral initialization to .init_late ARM: imx legacy: mx35-3ds: move peripheral initialization to .init_late ARM: imx legacy: mx27-3ds: move peripheral initialization to .init_late ARM: imx legacy: imx27-visstrim-m10: move peripheral initialization to .init_late ARM: imx legacy: vpr200: move peripheral initialization to .init_late ARM: imx legacy: mx31moboard: move peripheral initialization to .init_late ARM: imx legacy: armadillo5x0: move peripheral initialization to .init_late ARM: imx legacy: qong: move peripheral initialization to .init_late ARM: imx legacy: mx31-3ds: move peripheral initialization to .init_late ARM: imx legacy: pcm037: move peripheral initialization to .init_late ARM: imx legacy: mx31lilly: move peripheral initialization to .init_late ARM: imx legacy: mx31ads: move peripheral initialization to .init_late ARM: imx legacy: mx31lite: move peripheral initialization to .init_late ARM: imx legacy: kzm: move peripheral initialization to .init_late MAINTAINERS: update list of Oxnas maintainers ARM: orion5x: remove extraneous NO_IRQ ARM: orion: simplify orion_ge00_switch_init ...
2016-10-04Merge tag 'docs-4.9' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation updates from Jonathan Corbet: "This is the documentation update pull for the 4.9 merge window. The Sphinx transition is still creating a fair amount of work. Here we have a number of fixes and, importantly, a proper PDF output solution, thanks to Jani Nikula, Mauro Carvalho Chehab and Markus Heiser. I've started a couple of new books: a driver API book (based on the old device-drivers.tmpl) and a development tools book. Both are meant to show how we can integrate together our existing documentation into a more coherent and accessible whole. It involves moving some stuff around and formatting changes, but, I think, the results are worth it. The good news is that most of our existing Documentation/*.txt files are *almost* in RST format already; the amount of messing around required is minimal. And, of course, there's the usual set of updates, typo fixes, and more" * tag 'docs-4.9' of git://git.lwn.net/linux: (120 commits) URL changed for Linux Foundation TAB dax : Fix documentation with respect to struct pages iio: Documentation: Correct the path used to create triggers. docs: Remove space-before-label guidance from CodingStyle docs-rst: add inter-document cross references Documentation/email-clients.txt: convert it to ReST markup Documentation/kernel-docs.txt: reorder based on timestamp Documentation/kernel-docs.txt: Add dates for online docs Documentation/kernel-docs.txt: get rid of broken docs Documentation/kernel-docs.txt: move in-kernel docs Documentation/kernel-docs.txt: remove more legacy references Documentation/kernel-docs.txt: add two published books Documentation/kernel-docs.txt: sort books per publication date Documentation/kernel-docs.txt: adjust LDD references Documentation/kernel-docs.txt: some improvements on the ReST output Documentation/kernel-docs.txt: Consistent indenting: 4 spaces Documentation/kernel-docs.txt: Add 4 paper/book references Documentation/kernel-docs.txt: Improve layouting of book list Documentation/kernel-docs.txt: Remove offline or outdated entries docs: Clean up bare :: lines ...
2016-09-08ARM: sunxi: Support the Nextthing GR8Maxime Ripard
The GR8 is an SoC made by Nextthing Co, loosely based on the sun5i family. It has a number of new controllers compared to the A10s and A13 (SPDIF, I2S), but some controllers missing too (Ethernet, less I2C, less UARTs). Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-08-18Documentation: sunxi: Update Allwinner SoC documentationIcenowy Zheng
Now, the A83T and A64 SoC user manuals are available. Update the documentation to add the links. An updated version of A83T datasheet is also included now. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-17bus: arm-ccn: Correct required arguments for XP PMU eventsPawel Moll
XP can provide events from two sources: watchpoints, observing traffic on device ports and PMU looking at internal buses. Unfortunately the sysfs definition of the PMU events was requiring port number (instead of bus number) and direction (the buses are unidirectional), as these fields were shared with the watchpoint event. Although it does not introduce a major problem (port can be used as bus alias and direction is simply ignored for XP PMU events), it's better to fix it now, before external tools start depending on this behaviour. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2016-06-21ARM: at91: Documentation: update the sama5d2 entryNicolas Ferre
Update the Atmel SoC entry for SAMA5D2 with all the product variants. Add the datasheet web link, now that it's available, for instant access to full product documentation. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-04-28Documentation: fix common spelling mistakesKees Cook
This fixes several spelling mistakes in the Documentation/ tree, which are caught by checkpatch.pl's spell checking. Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-03-20Merge tag 'armsoc-arm64' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC 64-bit changes from Arnd Bergmann: "Here's our branch of ARM64 contents for this merge window, now containing all ARM64 changes other than device tree files. - Various new platforms get added: * Allwinner A64 SoC * Annapurna Labs Alpine SoCs * Broadcom Vulcan * Marvell Armada 3700 SoCs * Amlogic S905 - Various defconfig changes to enable platform specific drivers This branch includes the clk git tree to resolve a build-time dependency" * tag 'armsoc-arm64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) arm64: defconfig: Increase MMC_BLOCK_MINORS to 16 arm64: defconfig: Add Qualcomm sdhci and restart functionality ARM64: Enable Amlogic Meson GXBaby platform arm64: defconfig: Enable Samsung MFD and related configs arm64: alpine: select the Alpine MSI controller driver arm64: defconfig: enable the Alpine family arm64: add Alpine SoC family arm64: defconfig: Enable exynos thermal config arm64: add defconfig options for Allwinner SoCs arm64: defconfig: Enable DesignWare APB GPIO controller arm64: defconfig: Add Renesas R-Car Gen3 USB 2.0 phy driver support arm64: EXYNOS: Consolidate ARCH_EXYNOS7 symbol into ARCH_EXYNOS clk: samsung: Don't build ARMv8 clock drivers on ARMv7 MAINTAINERS: Add entry for Broadcom Vulcan SoC arm64: cputype info for Broadcom Vulcan arm64: Broadcom Vulcan support arm64: defconfig: Add Broadcom Vulcan to defconfig arm64: update ARCH_MVEBU for Marvell Armada 7K/8K support Documentation: arm: add Marvell Armada 7K and 8K families Documentation: arm: add link to Armada 38x Functional Spec ...
