path: root/Documentation/arm
2014-06-05Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm into nextLinus Torvalds
Pull ARM updates from Russell King: - Major clean-up of the L2 cache support code. The existing mess was becoming rather unmaintainable through all the additions that others have done over time. This turns it into a much nicer structure, and implements a few performance improvements as well. - Clean up some of the CP15 control register tweaks for alignment support, moving some code and data into alignment.c - DMA properties for ARM, from Santosh and reviewed by DT people. This adds DT properties to specify bus translations we can't discover automatically, and to indicate whether devices are coherent. - Hibernation support for ARM - Make ftrace work with read-only text in modules - add suspend support for PJ4B CPUs - rework interrupt masking for undefined instruction handling, which allows us to enable interrupts earlier in the handling of these exceptions. - support for big endian page tables - fix stacktrace support to exclude stacktrace functions from the trace, and add save_stack_trace_regs() implementation so that kprobes can record stack traces. - Add support for the Cortex-A17 CPU. - Remove last vestiges of ARM710 support. - Removal of ARM "meminfo" structure, finally converting us solely to memblock to handle the early memory initialisation. * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits) ARM: ensure C page table setup code follows assembly code (part II) ARM: ensure C page table setup code follows assembly code ARM: consolidate last remaining open-coded alignment trap enable ARM: remove global cr_no_alignment ARM: remove CPU_CP15 conditional from alignment.c ARM: remove unused adjust_cr() function ARM: move "noalign" command line option to alignment.c ARM: provide common method to clear bits in CPU control register ARM: 8025/1: Get rid of meminfo ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type ARM: 8066/1: correction for ARM patch 8031/2 ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation ARM: 8065/1: remove last use of CONFIG_CPU_ARM710 ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction ARM: 8047/1: rwsem: use asm-generic rwsem implementation ARM: l2c: trial at enabling some Cortex-A9 optimisations ARM: l2c: add warnings for stuff modifying aux_ctrl register values ARM: l2c: print a warning with L2C-310 caches if the cache size is modified ARM: l2c: remove old .set_debug method ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this ...
2014-06-05Merge branch 'arm64-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull ARM64 EFI update from Peter Anvin: "By agreement with the ARM64 EFI maintainers, we have agreed to make -tip the upstream for all EFI patches. That is why this patchset comes from me :) This patchset enables EFI stub support for ARM64, like we already have on x86" * 'arm64-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: arm64: efi: only attempt efi map setup if booting via EFI efi/arm64: ignore dtb= when UEFI SecureBoot is enabled doc: arm64: add description of EFI stub support arm64: efi: add EFI stub doc: arm: add UEFI support documentation arm64: add EFI runtime services efi: Add shared FDT related functions for ARM/ARM64 arm64: Add function to create identity mappings efi: add helper function to get UEFI params from FDT doc: efi-stub.txt updates for ARM lib: add fdt_empty_tree.c
2014-06-01ARM: 8066/1: correction for ARM patch 8031/2Nicolas Pitre
A small mistake slipped through in memory.txt. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-26Merge tag 'berlin-soc-3.16' of https://github.com/shesselba/linux-berlin ↵Olof Johansson
into next/soc Merge "ARM: berlin: SoC changes for v3.16" from Sebastian Hesselbart: Despite relatively young Berlin SoC support, we already have support for a BG2Q SoC provided by Alexandre Belloni and Antoine Tenart. Also, we gained support for DW gpio and a pinctrl driver. * tag 'berlin-soc-3.16' of https://github.com/shesselba/linux-berlin: ARM: berlin: add the pinctrl dependency for the Marvell Berlin SoCs ARM: berlin: add the LIBGPIO as a dependency for the BG2Q ARM: berlin: add MACH_BERLIN_BG2Q symbol ARM: berlin: add Marvell Armada 1500 pro to Marvell doc Signed-off-by: Olof Johansson <olof@lixom.net>
2014-05-19ARM: berlin: add Marvell Armada 1500 pro to Marvell docAntoine Tenart
This adds Marvell Berlin Armada 1500 Pro (BG2Q) to Marvell SoC documentation. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2014-05-17ARM: STi: Add STiH407 SoC supportMaxime Coquelin
This patch adds support to STiH407 SoC. Acked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
2014-04-30doc: arm: add UEFI support documentationLeif Lindholm
This patch provides documentation of the [U]EFI runtime service and configuration features for the arm architecture. Cc: Rob Landley <rob@landley.net> Cc: linux-doc@vger.kernel.org Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org> Acked-by: Grant Likely <grant.likely@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-04-23ARM: 8031/2: change fixmap mapping region to support 32 CPUsLiu Hua
In 32-bit ARM systems, the fixmap mapping region can support no more than 14 CPUs(total: 896k; one CPU: 64K). And we can configure NR_CPUS up to 32. So there is a mismatch. This patch moves fixmapping region downwards to region 0xffc00000- 0xffe00000. Then the fixmap mapping region can support up to 32 CPUs. Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Liu Hua <sdu.liu@huawei.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-23ARM: 8023/1: remove remnants of the static DMA mappingNicolas Pitre
It looks like the static mapping area for DMA was replaced by dynamic allocation into the vmalloc area by commit e9da6e9905e6 but the information in Documentation/arm/memory.txt was not removed accordingly. CONSISTENT_END in arch/arm/include/asm/memory.h has no more users and can be removed as well. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-02-25Merge tag 'mvebu-soc-3xx-3.15' of git://git.infradead.org/linux-mvebu into ↵Arnd Bergmann
next/soc Merge "mvebu new SoCs for v3.15" from Jason Cooper: - mvebu - initial support for Armada 375, 380, and 385 Depends: - tags/mvebu-soc-3.15 (resolves delete/rename hidden conflict) * tag 'mvebu-soc-3xx-3.15' of git://git.infradead.org/linux-mvebu: Documentation: arm: update Marvell documentation about Armada 375/38x ARM: mvebu: add initial support for the Armada 380/385 SOCs ARM: mvebu: add workaround for data abort issue on Armada 375 ARM: mvebu: add initial support for the Armada 375 SOCs ARM: mvebu: add Armada 375 support to the system-controller driver ARM: mvebu: make CPU_PJ4B selection a per-SoC choice ARM: mvebu: rename DT machine structure for Armada 370/XP ARM: mvebu: rename armada-370-xp.c to board-v7.c Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-02-22Documentation: arm: update Marvell documentation about Armada 375/38xThomas Petazzoni
This commit updates the documentation that describes the various families of SOCs produced by Marvell, together with the corresponding available technical documents. It adds Armada 375 and Armada 38x, and adds a link to the product brief for the already supported Armada 370. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-02-10Documentation/: update 00-INDEX filesHenrik Austad
Some of the 00-INDEX files are somewhat outdated and some folders does not contain 00-INDEX at all. Only outdated (with the notably exception of spi) indexes are touched here, the 169 folders without 00-INDEX has not been touched. New 00-INDEX - spi/* was added in a series of commits dating back to 2006 Added files (missing in (*/)00-INDEX) - dmatest.txt was added by commit 851b7e16a07d ("dmatest: run test via debugfs") - this_cpu_ops.txt was added by commit a1b2a555d637 ("percpu: add documentation on this_cpu operations") - ww-mutex-design.txt was added by commit 040a0a371005 ("mutex: Add support for wound/wait style locks") - bcache.txt was added by commit cafe56359144 ("bcache: A block layer cache") - kernel-per-CPU-kthreads.txt was added by commit 49717cb40410 ("kthread: Document ways of reducing OS jitter due to per-CPU kthreads") - phy.txt was added by commit ff764963479a ("drivers: phy: add generic PHY framework") - block/null_blk was added by commit 12f8f4fc0314 ("null_blk: documentation") - module-signing.txt was added by commit 3cafea307642 ("Add Documentation/module-signing.txt file") - assoc_array.txt was added by commit 3cb989501c26 ("Add a generic associative array implementation.") - arm/IXP4xx was part of the initial repo - arm/cluster-pm-race-avoidance.txt was added by commit 7fe31d28e839 ("ARM: mcpm: introduce helpers for platform coherency exit/setup") - arm/firmware.txt was added by commit 7366b92a77fc ("ARM: Add interface for registering and calling firmware-specific operations") - arm/kernel_mode_neon.txt was added by commit 2afd0a05241d ("ARM: 7825/1: document the use of NEON in kernel mode") - arm/tcm.txt was added by commit bc581770cfdd ("ARM: 5580/2: ARM TCM (Tightly-Coupled Memory) support v3") - arm/vlocks.txt was added by commit 9762f12d3e05 ("ARM: mcpm: Add baremetal voting mutexes") - blackfin/gptimers-example.c, Makefile was added by commit 4b60779d5ea7 ("Blackfin: add an example showing how to use the gptimers API") - devicetree/usage-model.txt was added by commit 31134efc681a ("dt: Linux DT usage model documentation") - fb/api.txt was added by commit fb21c2f42879 ("fbdev: Add FOURCC-based format configuration API") - fb/sm501.txt was added by commit e6a049807105 ("video, sm501: add edid and commandline support") - fb/udlfb.txt was added by commit 96f8d864afd6 ("fbdev: move udlfb out of staging.") - filesystems/Makefile was added by commit 1e0051ae48a2 ("Documentation/fs/: split txt and source files") - filesystems/nfs/nfsd-admin-interfaces.txt was added by commit 8a4c6e19cfed ("nfsd: document kernel interfaces for nfsd configuration") - ide/warm-plug-howto.txt was added by commit f74c91413ec6 ("ide: add warm-plug support for IDE devices (take 2)") - laptops/Makefile was added by commit d49129accc21 ("Documentation/laptop/: split txt and source files") - leds/leds-blinkm.txt was added by commit b54cf35a7f65 ("LEDS: add BlinkM RGB LED driver, documentation and update MAINTAINERS") - leds/ledtrig-oneshot.txt was added by commit 5e417281cde2 ("leds: add oneshot trigger") - leds/ledtrig-transient.txt was added by commit 44e1e9f8e705 ("leds: add new transient trigger for one shot timer activation") - m68k/README.buddha was part of the initial repo - networking/LICENSE.(qla3xxx|qlcnic|qlge) was added by commits 40839129f779, c4e84bde1d59, 5a4faa873782 - networking/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - networking/i40evf.txt was added by commit 105bf2fe6b32 ("i40evf: add driver to kernel build system") - networking/ipsec.txt was added by commit b3c6efbc36e2 ("xfrm: Add file to document IPsec corner case") - networking/mac80211-auth-assoc-deauth.txt was added by commit 3cd7920a2be8 ("mac80211: add auth/assoc/deauth flow diagram") - networking/netlink_mmap.txt was added by commit 5683264c3981 ("netlink: add documentation for memory mapped I/O") - networking/nf_conntrack-sysctl.txt was added by commit c9f9e0e1597f ("netfilter: doc: add nf_conntrack sysctl api documentation") lan) - networking/team.txt was added by commit 3d249d4ca7d0 ("net: introduce ethernet teaming device") - networking/vxlan.txt was added by commit d342894c5d2f ("vxlan: virtual extensible lan") - power/runtime_pm.txt was added by commit 5e928f77a09a ("PM: Introduce core framework for run-time PM of I/O devices (rev. 17)") - power/charger-manager.txt was added by commit 3bb3dbbd56ea ("power_supply: Add initial Charger-Manager driver") - RCU/lockdep-splat.txt was added by commit d7bd2d68aa2e ("rcu: Document interpretation of RCU-lockdep splats") - s390/kvm.txt was added by 5ecee4b (KVM: s390: API documentation) - s390/qeth.txt was added by commit b4d72c08b358 ("qeth: bridgeport support - basic control") - scheduler/sched-bwc.txt was added by commit 88ebc08ea9f7 ("sched: Add documentation for bandwidth control") - scsi/advansys.txt was added by commit 4bd6d7f35661 ("[SCSI] advansys: Move documentation to Documentation/scsi") - scsi/bfa.txt was added by commit 1ec90174bdb4 ("[SCSI] bfa: add readme file") - scsi/bnx2fc.txt was added by commit 12b8fc10eaf4 ("[SCSI] bnx2fc: Add driver documentation") - scsi/cxgb3i.txt was added by commit c3673464ebc0 ("[SCSI] cxgb3i: Add cxgb3i iSCSI driver.") - scsi/hpsa.txt was added by commit 992ebcf14f3c ("[SCSI] hpsa: Add hpsa.txt to Documentation/scsi") - scsi/link_power_management_policy.txt was added by commit ca77329fb713 ("[libata] Link power management infrastructure") - scsi/osd.txt was added by commit 78e0c621deca ("[SCSI] osd: Documentation for OSD library") - scsi/scsi-parameter.txt was created/moved by commit 163475fb111c ("Documentation: move SCSI parameters to their own text file") - serial/driver was part of the initial repo - serial/n_gsm.txt was added by commit 323e84122ec6 ("n_gsm: add a documentation") - timers/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - virt/kvm/s390.txt was added by commit d9101fca3d57 ("KVM: s390: diagnose call documentation") - vm/split_page_table_lock was added by commit 49076ec2ccaf ("mm: dynamically allocate page->ptl if it cannot be embedded to struct page") - w1/slaves/w1_ds28e04 was added by commit fbf7f7b4e2ae ("w1: Add 1-wire slave device driver for DS28E04-100") - w1/masters/omap-hdq was added by commit e0a29382c6f5 ("hdq: documentation for OMAP HDQ") - x86/early-microcode.txt was added by commit 0d91ea86a895 ("x86, doc: Documentation for early microcode loading") - x86/earlyprintk.txt was added by commit a1aade478862 ("x86/doc: mini-howto for using earlyprintk=dbgp") - x86/entry_64.txt was added by commit 8b4777a4b50c ("x86-64: Document some of entry_64.S") - x86/pat.txt was added by commit d27554d874c7 ("x86: PAT documentation") Moved files - arm/kernel_user_helpers.txt was moved out of arch/arm/kernel by commit 37b8304642c7 ("ARM: kuser: move interface documentation out of the source code") - efi-stub.txt was moved out of x86/ and down into Documentation/ in commit 4172fe2f8a47 ("EFI stub documentation updates") - laptops/hpfall.c was moved out of hwmon/ and into laptops/ in commit efcfed9bad88 ("Move hp_accel to drivers/platform/x86") - commit 5616c23ad9cd ("x86: doc: move x86-generic documentation from Doc/x86/i386"): * x86/usb-legacy-support.txt * x86/boot.txt * x86/zero_page.txt - power/video_extension.txt was moved to acpi in commit 70e66e4df191 ("ACPI / video: move video_extension.txt to Documentation/acpi") Removed files (left in 00-INDEX) - memory.txt was removed by commit 00ea8990aadf ("memory.txt: remove stray information") - gpio.txt was moved to gpio/ in commit fd8e198cfcaa ("Documentation: gpiolib: document new interface") - networking/DLINK.txt was removed by commit 168e06ae26dd ("drivers/net: delete old parallel port de600/de620 drivers") - serial/hayes-esp.txt was removed by commit f53a2ade0bb9 ("tty: esp: remove broken driver") - s390/TAPE was removed by commit 9e280f669308 ("[S390] remove tape block docu") - vm/locking was removed by commit 57ea8171d2bc ("mm: documentation: remove hopelessly out-of-date locking doc") - laptops/acer-wmi.txt was remvoed by commit 020036678e81 ("acer-wmi: Delete out-of-date documentation") Typos/misc issues - rpc-server-gss.txt was added as knfsd-rpcgss.txt in commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication.") - commit b88cf73d9278 ("net: add missing entries to Documentation/networking/00-INDEX") * generic-hdlc.txt was added as generic_hdlc.txt * spider_net.txt was added as spider-net.txt - w1/master/mxc-w1 was added as mxc_w1 by commit a5fd9139f74c ("w1: add 1-wire master driver for i.MX27 / i.MX31") - s390/zfcpdump.txt was added as zfcpdump by commit 6920c12a407e ("[S390] Add Documentation/s390/00-INDEX.") Signed-off-by: Henrik Austad <henrik@austad.us> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [rcu bits] Acked-by: Rob Landley <rob@landley.net> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <robh+dt@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Mark Brown <broonie@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Gleb Natapov <gleb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Len Brown <len.brown@intel.com> Cc: James Bottomley <JBottomley@parallels.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New core SoC-specific changes. New platforms: * Introduction of a vendor, Hisilicon, and one of their SoCs with some random numerical product name. * Introduction of EFM32, embedded platform from Silicon Labs (ARMv7m, i.e. !MMU). * Marvell Berlin series of SoCs, which include the one in Chromecast. * MOXA platform support, ARM9-based platform used mostly in industrial products * Support for Freescale's i.MX50 SoC. Other work: * Renesas work for new platforms and drivers, and conversion over to more multiplatform-friendly device registration schemes. * SMP support for Allwinner sunxi platforms. * ... plus a bunch of other stuff across various platforms" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (201 commits) ARM: tegra: fix tegra_powergate_sequence_power_up() inline ARM: msm_defconfig: Update for multi-platform ARM: msm: Move MSM's DT based hardware to multi-platform support ARM: msm: Only build timer.c if required ARM: msm: Only build clock.c on proc_comm based platforms ARM: ux500: Enable system suspend with WFI support ARM: ux500: turn on PRINTK_TIME in u8500_defconfig ARM: shmobile: r8a7790: Fix I2C controller names ARM: msm: Simplify ARCH_MSM_DT config ARM: msm: Add support for MSM8974 SoC ARM: sunxi: select ARM_PSCI MAINTAINERS: Update Allwinner sunXi maintainer files ARM: sunxi: Select RESET_CONTROLLER ARM: imx: improve the comment of CCM lpm SW workaround ARM: imx: improve status check of clock gate ARM: imx: add necessary interface for pfd ARM: imx_v6_v7_defconfig: Select CONFIG_REGULATOR_PFUZE100 ARM: imx_v6_v7_defconfig: Select MX35 and MX50 device tree support ARM: imx: Add cpu frequency scaling support ARM i.MX35: Add devicetree support. ...
2014-01-07gpio: samsung: Update documentationSachin Kamat
hardware.h inclusion is no longer needed. Update the documentation section related to it and fix a file path. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-13ARM: add Marvell Berlin SoC familiy to Marvell docSebastian Hesselbarth
This adds known facts and rumors about the Marvell Berlin (88DE3xxx) SoC family to the Marvell SoC documentation. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Reviewed-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2013-10-28Merge tag 'sunxi-core-for-3.13' of https://github.com/mripard/linux into ↵Olof Johansson
next/soc From Maxime Ripard: Allwinner sunXi SoCs machine additions for 3.13 Nothing outstanding here, mostly some documentation cleanup, and the split of the previous generic machine declaration into three different machines to handle the sun4i/sun5i, sun6i and sun7i separately. * tag 'sunxi-core-for-3.13' of https://github.com/mripard/linux: Documentation: dt: Remove clock gates IDs list for Allwinner SoCs Documentation: dt: Remove interrupt sources list for Allwinner SoCs Documentation: sunxi: Update Allwinner SoC documentation Documentation: sunxi: Update A13 user manual dead link ARM: sunxi: Order Kconfig options alphabetically ARM: sunxi: Simplify restart setup code ARM: sunxi: Split out the DT machines for sun6i and sun7i Signed-off-by: Olof Johansson <olof@lixom.net>
2013-10-11Documentation: sunxi: Update Allwinner SoC documentationMaxime Ripard
Since that document was first submitted, some new SoCs have been announced/released by Allwinner. Update the documentation to mention those and the related documents. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-10-11Documentation: sunxi: Update A13 user manual dead linkMaxime Ripard
2013-10-08Documentation: arm/Marvell: clarify Armada SoCs that match 78xx0 patternKevin Hilman
New users of Marvell SoCs will potentially be confused by the MVEBU SoCs that match the 78xx0 pattern and thus which defconfig and mach-* directory to be looking at. Add a bit of clarification to README for this. Signed-off-by: Kevin Hilman <khilman@linaro.org> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
2013-08-25ARM: 7825/1: document the use of NEON in kernel modeArd Biesheuvel
Add a file to Documentation/arm explaining how kernel mode NEON is supposed to be used. Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: 7824/1: update advice on kernel, initramfs and FDT load address.Ian Campbell
- Recommend that the kernel be placed under 128MiB, this is required if CONFIG_AUTO_ZRELADDR=y and good (or at least not bad) advice even if CONFIG_AUTO_ZRELADDR=n. - Recommend that a zImage kernel be placed above 32MiB, this avoids the need to relocate prior to decompression, which can speed up boot. - Add basic info on the requirements when loading a raw (non-zImage) kernel which are stricter than the zImage requirements. - Recommend that the DTB be placed after the 128MiB boundary, avoiding any potential conflict with the kernel decompressor, and within the lowmem region. In practice it could follow the kernel loaded after 32MiB, assuming the kernel decompesses to less than 32MiB, but the 128MiB recommendation is simple and unambiguous. - Add similar recommendation regarding initramfs. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Dave Martin <dave.martin@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Roy Franz <roy.franz@linaro.org> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-07-25doc: Fix typo in doucmentationsMasanari Iida
Correct typo (double words) in documentations. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-02Merge tag 'late-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late changes from Arnd Bergmann: "These are changes that arrived a little late before the merge window or that have multiple dependencies on previous branches so they did not fit into one of the earlier ones. There are 10 branches merged here, a total of 39 non-merge commits. Contents are a mixed bag for the above reasons: * Two new SoC platforms: ST microelectronics stixxxx and the TI 'Nspire' graphing calculator. These should have been in the 'soc' branch but were a little late * Support for the Exynos 5420 variant in mach-exynos, which is based on the other exynos branches to avoid conflicts. * Various small changes for sh-mobile, ux500 and davinci * Common clk support for MSM" * tag 'late-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits) ARM: ux500: bail out on alien cpus ARM: davinci: da850: adopt to pinctrl-single change for configuring multiple pins serial: sh-sci: Initialise variables before access in sci_set_termios() ARM: stih41x: Add B2020 board support ARM: stih41x: Add B2000 board support ARM: sti: Add DEBUG_LL console support ARM: sti: Add STiH416 SOC support ARM: sti: Add STiH415 SOC support ARM: msm: Migrate to common clock framework ARM: msm: Make proc_comm clock control into a platform driver ARM: msm: Prepare clk_get() users in mach-msm for clock-pcom driver ARM: msm: Remove clock-7x30.h include file ARM: msm: Remove custom clk_set_{max,min}_rate() API ARM: msm: Remove custom clk_set_flags() API msm: iommu: Use clk_set_rate() instead of clk_set_min_rate() msm: iommu: Convert to clk_prepare/unprepare msm_sdcc: Convert to clk_prepare/unprepare usb: otg: msm: Convert to clk_prepare/unprepare msm_serial: Use devm_clk_get() and properly return errors msm_serial: Convert to clk_prepare/unprepare ...
2013-06-25ARM: sti: Add STiH416 SOC supportSrinivas Kandagatla
The STiH416 is advanced HD AVC processor with 3D graphics acceleration and 1.2-GHz ARM Cortex-A9 SMP CPU. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> CC: Stephen Gallimore <stephen.gallimore@st.com> CC: Stuart Menefy <stuart.menefy@st.com> CC: Arnd Bergmann <arnd@arndb.de> CC: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-25ARM: sti: Add STiH415 SOC supportSrinivas Kandagatla
The STiH415 is the next generation of HD, AVC set-top box processors for satellite, cable, terrestrial and IP-STB markets. It is an ARM Cortex-A9 1.0 GHz, dual-core CPU. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> CC: Stephen Gallimore <stephen.gallimore@st.com> CC: Stuart Menefy <stuart.menefy@st.com> CC: Arnd Bergmann <arnd@arndb.de> CC: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-16ARM: sunxi: Add Allwinner A10s machine compatibleMaxime Ripard
The A10s is a SoC member of the Allwinner sun5i family. It is basically an A13 with an EMAC and an HDMI controller. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-06-05Documentation/arm/IXP4xx fix a typoStefan Huber
Corrected the word softare to software. Signed-off-by: Stefan Huber <steffhip@googlemail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-05-29ARM: sunxi: Update datasheet documentationMaxime Ripard
We have access to more documentation now, especially the user manuals, so add the links to them, and do so minor comestic changes while we're at it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-05-04Merge tag 'firmware-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM platform specific firmware interfaces from Olof Johansson: "Two platforms, bcm and exynos have their own firmware interfaces using the "secure monitor call", this adds support for those. We had originally planned to have a third set of patches in here, which would extend support for the existing generic "psci" call that is used on multiple platforms as well as Xen and KVM guests, but that ended up getting dropped because the patches were not ready in time." * tag 'firmware-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: bcm: mark bcm_kona_smc_init as __init ARM: bcm281xx: Add DT support for SMC handler ARM: bcm281xx: Add L2 cache enable code ARM: EXYNOS: Add secure firmware support to secondary CPU bring-up ARM: EXYNOS: Add IO mapping for non-secure SYSRAM. ARM: EXYNOS: Add support for Exynos secure firmware ARM: EXYNOS: Add support for secure monitor calls ARM: Add interface for registering and calling firmware-specific operations
2013-05-03Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "The major items included in here are: - MCPM, multi-cluster power management, part of the infrastructure required for ARMs big.LITTLE support. - A rework of the ARM KVM code to allow re-use by ARM64. - Error handling cleanups of the IS_ERR_OR_NULL() madness and fixes of that stuff for arch/arm - Preparatory patches for Cortex-M3 support from Uwe Kleine-König. There is also a set of three patches in here from Hugh/Catalin to address freeing of inappropriate page tables on LPAE. You already have these from akpm, but they were already part of my tree at the time he sent them, so unfortunately they'll end up with duplicate commits" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (77 commits) ARM: EXYNOS: remove unnecessary use of IS_ERR_VALUE() ARM: IMX: remove unnecessary use of IS_ERR_VALUE() ARM: OMAP: use consistent error checking ARM: cleanup: OMAP hwmod error checking ARM: 7709/1: mcpm: Add explicit AFLAGS to support v6/v7 multiplatform kernels ARM: 7700/2: Make cpu_init() notrace ARM: 7702/1: Set the page table freeing ceiling to TASK_SIZE ARM: 7701/1: mm: Allow arch code to control the user page table ceiling ARM: 7703/1: Disable preemption in broadcast_tlb*_a15_erratum() ARM: mcpm: provide an interface to set the SMP ops at run time ARM: mcpm: generic SMP secondary bringup and hotplug support ARM: mcpm_head.S: vlock-based first man election ARM: mcpm: Add baremetal voting mutexes ARM: mcpm: introduce helpers for platform coherency exit/setup ARM: mcpm: introduce the CPU/cluster power API ARM: multi-cluster PM: secondary kernel entry code ARM: cacheflush: add synchronization helpers for mixed cache state accesses ARM: cpu hotplug: remove majority of cache flushing from platforms ARM: smp: flush L1 cache in cpu_die() ARM: tegra: remove tegra specific cpu_disable() ...
2013-04-24ARM: mcpm: Add baremetal voting mutexesDave Martin
This patch adds a simple low-level voting mutex implementation to be used to arbitrate during first man selection when no load/store exclusive instructions are usable. For want of a better name, these are called "vlocks". (I was tempted to call them ballot locks, but "block" is way too confusing an abbreviation...) There is no function to wait for the lock to be released, and no vlock_lock() function since we don't need these at the moment. These could straightforwardly be added if vlocks get used for other purposes. For architectural correctness even Strongly-Ordered memory accesses require barriers in order to guarantee that multiple CPUs have a coherent view of the ordering of memory accesses. Whether or not this matters depends on hardware implementation details of the memory system. Since the purpose of this code is to provide a clean, generic locking mechanism with no platform-specific dependencies the barriers should be present to avoid unpleasant surprises on future platforms. Note: * When taking the lock, we don't care about implicit background memory operations and other signalling which may be pending, because those are not part of the critical section anyway. A DMB is sufficient to ensure correctly observed ordering if the explicit memory accesses in vlock_trylock. * No barrier is required after checking the election result, because the result is determined by the store to VLOCK_OWNER_OFFSET and is already globally observed due to the barriers in voting_end. This means that global agreement on the winner is guaranteed, even before the winner is known locally. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Will Deacon <will.deacon@arm.com>
2013-04-24ARM: mcpm: introduce helpers for platform coherency exit/setupDave Martin
This provides helper methods to coordinate between CPUs coming down and CPUs going up, as well as documentation on the used algorithms, so that cluster teardown and setup operations are not done for a cluster simultaneously. For use in the power_down() implementation: * __mcpm_cpu_going_down(unsigned int cluster, unsigned int cpu) * __mcpm_outbound_enter_critical(unsigned int cluster) * __mcpm_outbound_leave_critical(unsigned int cluster) * __mcpm_cpu_down(unsigned int cluster, unsigned int cpu) The power_up_setup() helper should do platform-specific setup in preparation for turning the CPU on, such as invalidating local caches or entering coherency. It must be assembler for now, since it must run before the MMU can be switched on. It is passed the affinity level for which initialization should be performed. Because the mcpm_sync_struct content is looked-up and modified with the cache enabled or disabled depending on the code path, it is crucial to always ensure proper cache maintenance to update main memory right away. The sync_cache_*() helpers are used to that end. Also, in order to prevent a cached writer from interfering with an adjacent non-cached writer, we ensure each state variable is located to a separate cache line. Thanks to Nicolas Pitre and Achin Gupta for the help with this patch. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Will Deacon <will.deacon@arm.com>
2013-04-09ARM: Add interface for registering and calling firmware-specific operationsTomasz Figa
Some boards are running with secure firmware running in TrustZone secure world, which changes the way some things have to be initialized. This patch adds an interface for platforms to specify available firmware operations and call them. A wrapper macro, call_firmware_op(), checks if the operation is provided and calls it if so, otherwise returns -ENOSYS to allow fallback to legacy operation.. By default no operations are provided. Example of use: In code using firmware ops: __raw_writel(virt_to_phys(exynos4_secondary_startup), CPU1_BOOT_REG); /* Call Exynos specific smc call */ if (call_firmware_op(cpu_boot, cpu) == -ENOSYS) cpu_boot_legacy(...); /* Try legacy way */ gic_raise_softirq(cpumask_of(cpu), 1); In board-/platform-specific code: static int platformX_do_idle(void) { /* tell platformX firmware to enter idle */ return 0; } static int platformX_cpu_boot(int i) { /* tell platformX firmware to boot CPU i */ return 0; } static const struct firmware_ops platformX_firmware_ops = { .do_idle = exynos_do_idle, .cpu_boot = exynos_cpu_boot, /* other operations not available on platformX */ }; static void __init board_init_early(void) { register_firmware_ops(&platformX_firmware_ops); } Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-03-27arm: sunxi: Add useful information about sunxi clocksEmilio López
This patch contains useful bits of information about the sunxi clocks that may help and/or be interesting for current and future developers. Signed-off-by: Emilio López <emilio@elopez.com.ar> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-12-15Merge tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
Pull fbdev changes from Tomi Valkeinen: "OMAPDSS changes, including: - use dynanic debug prints - OMAP platform dependency removals - Creation of compat-layer, helping us to improve omapdrm - Misc cleanups, aiming to make omadss more in line with the upcoming common display framework Exynos DP changes for the 3.8 merge window: - Device Tree support for Samsung Exynos DP - SW Link training is cleaned up. - HPD interrupt is supported. Samsung Framebuffer changes for the 3.8 merge window: - The bit definitions of header file are updated. - Some minor typos are fixed. - Some minor bugs of s3c_fb_check_var() are fixed. FB related changes for SH Mobile, Freescale DIU Add support for the Solomon SSD1307 OLED Controller" * tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linux: (191 commits) OMAPDSS: fix TV-out issue with DSI PLL Revert "OMAPFB: simplify locking" OMAPFB: remove silly loop in fb2display() OMAPFB: fix error handling in omapfb_find_best_mode() OMAPFB: use devm_kzalloc to allocate omapfb2_device OMAPDSS: DISPC: remove dispc fck uses OMAPDSS: DISPC: get dss clock rate from dss driver drivers/video/console/softcursor.c: remove redundant NULL check before kfree() drivers/video: add support for the Solomon SSD1307 OLED Controller OMAPDSS: use omapdss_compat_init() in other drivers OMAPDSS: export dispc functions OMAPDSS: export dss_feat functions OMAPDSS: export dss_mgr_ops functions OMAPDSS: separate compat files in the Makefile OMAPDSS: move display sysfs init to compat layer OMAPDSS: DPI: use dispc's check_timings OMAPDSS: DISPC: add dispc_ovl_check() OMAPDSS: move irq handling to dispc-compat OMAPDSS: move omap_dispc_wait_for_irq_interruptible_timeout to dispc-compat.c OMAPDSS: move blocking mgr enable/disable to compat layer ... Conflicts: arch/arm/mach-davinci/devices-da8xx.c arch/arm/plat-omap/common.c drivers/media/platform/omap/omap_vout.c
2012-11-16ARM: sunxi: Add basic support for Allwinner A1x SoCsMaxime Ripard
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de>
2012-11-13OMAPFB: use dma_alloc_attrs to allocate memoryTomi Valkeinen
Use dma_alloc_attrs to allocate memory instead of omap specific vram allocator. After this we can remove the omap vram allocator. There are some downsides to this change: 1) dma_alloc_attrs doesn't let us allocate at certain physical address. However, this should not be a problem as this feature of vram allocator is only used when reserving the framebuffer that was initialized by the bootloader, and we don't currently support "passing" a framebuffer from the bootloader to the kernel anyway. 2) dma_alloc_attrs, as of now, always ioremaps the allocated area, and we don't need the ioremap when using VRFB. This patch uses DMA_ATTR_NO_KERNEL_MAPPING for the allocation, but the flag is currently not operational. 3) OMAPFB_GET_VRAM_INFO ioctl cannot return real values anymore. I changed the ioctl to return 64M for all the values, which, I hope, the applications will interpret as "there's enough vram". 4) "vram" kernel parameter to define how much ram to reserve for video use no longer works. The user needs to enable CMA and use "cma" parameter. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-10-11Merge branch 'fixes' into for-linusRussell King
Conflicts: arch/arm/kernel/smp.c
2012-10-01Merge tag 'docs' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc documentation updates from Olof Johansson: "Documentation update for Marvell SoCs, the secret decoder ring to all their crazy product names and numbers." * tag 'docs' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arm: add documentation describing Marvell families of SoC
2012-09-20Merge branch 'samsung/cleanup' into next/cleanupOlof Johansson
From Kukjin Kim: Here, there are cleanup patches for Samsung v3.7 and most of them are related to cleanup Samsung specific gpio API. * samsung/cleanup: gpio: samsung: Update documentation ARM: S3C24XX: Use module_platform_driver macro in mach-osiris-dvs.c ARM: S3C24XX: Use module_platform_driver macro in h1940-bluetooth.c gpio-samsung: Remove now unused s3c2410_gpio* API ARM: S3C24XX: Remove obsolete GPIO API declarations ARM: S3C24XX: Convert users of s3c2410_gpio_setpin to gpiolib API ARM: EXYNOS: cleanup unused code related to GPS
2012-09-19ARM: virt: Update documentation for hyp mode entry supportDave Martin
Document the possibility of the kernel being entered in HYP mode. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2012-09-07gpio: samsung: Update documentationSylwester Nawrocki
Update Samsung GPIO API documentation to reflect removal of the s3c24xx specific gpio API. While at it, fix some typos. The notes on conversion from s3c2410_* functions to the gpiolib API are left here just in case there is any out of tree code that still needs to be converted. Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-08-13Merge branch 'cleanup/io-pci' into next/cleanupsArnd Bergmann
From Rob Herring <robherring2@gmail.com>: This is the 2nd part of mach/io.h removals. This series removes io.h on platforms with PCI by creating a fixed virtual I/O mapping and a common __io() macro. This version has changed a bit to accommodate Tegra converting its PCIe host to a platform driver. Now the virtual space is only reserved during early boot before .map_io() is called. The mapping is not created until calling pci_ioremap_io which can be done at any point after vmalloc is initialized. I've gone back to fixed 64K windows for each PCI bus. This allows removing all the i/o resource setup from the individually platforms and placing it within the common ARM PCI code. I've only tested versatilepb under qemu (with the model hacked up to actually enable i/o space), so any testing is appreciated. iop3xx and mv78xx0 have some risk of breaking as the PCI bus addresses are moved to 0 from matching the cpu host bus addesss. * cleanup/io-pci: ARM: iop3xx: use fixed PCI i/o mapping ARM: mv78xx0: use fixed pci i/o mapping ARM: iop13xx: use fixed PCI i/o mapping iop13xx: use more regular PCI I/O space handling ARM: orion5x: use fixed PCI i/o mapping ARM: kirkwood: use fixed PCI i/o mapping ARM: dove: use fixed PCI i/o mapping ARM: footbridge: use fixed PCI i/o mapping ARM: shark: use fixed PCI i/o mapping ARM: integrator: remove trailing whitespace on pci_v3.c ARM: integrator: use fixed PCI i/o mapping ARM: tegra: use fixed PCI i/o mapping ARM: versatile: use fixed PCI i/o mapping ARM: move PCI i/o resource setup into common code ARM: Add fixed PCI i/o mapping i2c: iop3xx: use standard gpiolib functions i2c: iop3xx: clean-up trailing whitespace Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-11arm: add documentation describing Marvell families of SoCThomas Petazzoni
As stated in the introduction of the document, the families of ARM SoCs at Marvell are very complicated, and it is difficult for newcomers to understand the organization of this SoC family and how it relates to the Linux kernel support for those hardware platforms. This document is only at RFC stage for now, it requires reviews and comments from the Marvell maintainers, the PXA maintainers and the MMP maintainers. For correctness of course, but also to add any other information that would be useful. For example, one of the thing that wasn't clear how to detail in the documentation is how the SoCs relate to each other in terms of hardware IP blocks. For example, most of the Kirkwood/Dove/Armada 370-XP/etc. hardware IPs (I2C, SPI, USB, SATA, etc.) are identical, while the PXA and MMP families are completely separate. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Gregory Clement <gregory.clement@free-electrons.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Nicolas Pitre <nico@fluxnic.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Olof Johansson <olof@lixom.net> Cc: Lior Amsalem <alior@marvell.com> Cc: Maen Suleiman <maen@marvell.com> Cc: Tawfik Bayouk <tawfik@marvell.com> Cc: Shadi Ammouri <shadi@marvell.com> Cc: Eran Ben-Avi <benavi@marvell.com> Acked-by: Arnd Bergmann <arnd@arndb.de> --- Changes from v3: * Add Arnd Bergmann Acked-by. Changes from v2: * Mention the plat-<foo> directory that each SoC family is using. * Take into account Eric Miao's comments on the PXA/MMP families: add PXA21x/PXA25x/PXA26x to the list, mention which processors are AP+CP or AP only. Clarify the comments on which SoCs were designed by Intel, which ones were designed by Marvell after the acquisition of the XScale family. * Mention long-term plans regarding the support of those SoC families. Changes from v1: * Added publicly available datasheet for the 88F5182 pointed by Andrew Lunn. * Added publicly available datasheet for the 88F5281 found with Google searches * Mentionned the Feroceon core name where appropriate, and Sheeva where appropriate * Fixed the core names for PXA930, PXA935 and PXA955 after comments from Arnd Bergmann. Wikipedia is mistakenly suggesting that PXA93x are Sheeva-based, and there isn't much information available on the web about the 955.
2012-07-25ARM: Add fixed PCI i/o mappingRob Herring
This adds a fixed virtual mapping for PCI i/o addresses. The mapping is located at the last 2MB of vmalloc region (0xfee00000-0xff000000). 2MB is used to align with PMD size, but IO_SPACE_LIMIT is 1MB. The space is reserved after .map_io and can be mapped at any time later with pci_ioremap_io. Platforms which need early i/o mapping (e.g. for vga console) can call pci_map_io_early in their .map_io function. This has changed completely from the 1st implementation which only supported creating the static mapping at .map_io. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-07-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Trivial updates all over the place as usual." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits) Fix typo in include/linux/clk.h . pci: hotplug: Fix typo in pci iommu: Fix typo in iommu video: Fix typo in drivers/video Documentation: Add newline at end-of-file to files lacking one arm,unicore32: Remove obsolete "select MISC_DEVICES" module.c: spelling s/postition/position/g cpufreq: Fix typo in cpufreq driver trivial: typo in comment in mksysmap mach-omap2: Fix typo in debug message and comment scsi: aha152x: Fix sparse warning and make printing pointer address more portable. Change email address for Steve Glendinning Btrfs: fix typo in convert_extent_bit via: Remove bogus if check netprio_cgroup.c: fix comment typo backlight: fix memory leak on obscure error path Documentation: asus-laptop.txt references an obsolete Kconfig item Documentation: ManagementStyle: fixed typo mm/vmscan: cleanup comment error in balance_pgdat mm: cleanup on the comments of zone_reclaim_stat ...
2012-07-20Documentation: Add newline at end-of-file to files lacking oneJesper Juhl
This patch simply adds a newline character at end-of-file to those files in Documentation/ that currently lack one. This is done for a few different reasons: A) It's rather annoying when you do "cat some_file.txt" that your prompt/cursor ends up at the end of the last line of output rather than on a new line. B) Some tools that process files line-by-line may get confused by the lack of a newline on the last line. C) The "\ No newline at end of file" line in diffs annoys me for some reason. So, let's just add the missing newline once and for all. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-06-20Viresh has movedViresh Kumar
viresh.kumar@st.com email-id doesn't exist anymore as I have left the company. Replace ST's id with viresh.linux@gmail.com. It also updates .mailmap file to fix address for 'git shortlog' Signed-off-by: Viresh Kumar <viresh.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
