path: root/Documentation/cachetlb.txt
2007-10-19remove unused flush_tlb_pgtablesBenjamin Herrenschmidt
Nobody uses flush_tlb_pgtables anymore, this patch removes all remaining traces of it from all archs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16flush icache before set_pte() on ia64: flush icache at set_pteKAMEZAWA Hiroyuki
Current ia64 kernel flushes icache by lazy_mmu_prot_update() *after* set_pte(). This is too late. This patch removes lazy_mmu_prot_update and add modfied set_pte() for flushing if necessary. This patch flush icache of a page when new pte has exec bit. && new pte has present bit && new pte is user's page. && (old *ptep is not present || new pte's pfn is not same to old *ptep's ptn) && new pte's page has no Pg_arch_1 bit. Pg_arch_1 is set when a page is cache consistent. I think this condition checks are much easier to understand than considering "Where sync_icache_dcache() should be inserted ?". pte_user() for ia64 was removed by http://lkml.org/lkml/2007/6/12/67 as clean-up. So, I added it again. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-14[POWERPC] unmap_vm_area becomes unmap_kernel_range for the publicBenjamin Herrenschmidt
This makes unmap_vm_area static and a wrapper around a new exported unmap_kernel_range that takes an explicit range instead of a vm_area struct. This makes it more versatile for code that wants to play with kernel page tables outside of the standard vmalloc area. (One example is some rework of the PowerPC PCI IO space mapping code that depends on that patch and removes some code duplication and horrible abuse of forged struct vm_struct). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-08[ARM] pass vma for flush_anon_page()Russell King
Since get_user_pages() may be used with processes other than the current process and calls flush_anon_page(), flush_anon_page() has to cope in some way with non-current processes. It may not be appropriate, or even desirable to flush a region of virtual memory cache in the current process when that is different to the process that we want the flush to occur for. Therefore, pass the vma into flush_anon_page() so that the architecture can work out whether the 'vmaddr' is for the current process or not. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-13[PATCH] Optimize D-cache alias handling on forkRalf Baechle
Virtually index, physically tagged cache architectures can get away without cache flushing when forking. This patch adds a new cache flushing function flush_cache_dup_mm(struct mm_struct *) which for the moment I've implemented to do the same thing on all architectures except on MIPS where it's a no-op. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Add flush_kernel_dcache_page() APIJames Bottomley
We have a problem in a lot of emulated storage in that it takes a page from get_user_pages() and does something like kmap_atomic(page) modify page kunmap_atomic(page) However, nothing has flushed the kernel cache view of the page before the kunmap. We need a lightweight API to do this, so this new API would specifically be for flushing the kernel cache view of a user page which the kernel has modified. The driver would need to add flush_kernel_dcache_page(page) before the final kunmap. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Add API for flushing Anon pagesJames Bottomley
Currently, get_user_pages() returns fully coherent pages to the kernel for anything other than anonymous pages. This is a problem for things like fuse and the SCSI generic ioctl SG_IO which can potentially wish to do DMA to anonymous pages passed in by users. The fix is to add a new memory management API: flush_anon_page() which is used in get_user_pages() to make anonymous pages coherent. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-15spelling: s/appropiate/appropriate/Adrian Bunk
2005-10-29[PATCH] mm: flush_tlb_range outside ptlockHugh Dickins
There was one small but very significant change in the previous patch: mprotect's flush_tlb_range fell outside the page_table_lock: as it is in 2.4, but that doesn't prove it safe in 2.6. On some architectures flush_tlb_range comes to the same as flush_tlb_mm, which has always been called from outside page_table_lock in dup_mmap, and is so proved safe. Others required a deeper audit: I could find no reliance on page_table_lock in any; but in ia64 and parisc found some code which looks a bit as if it might want preemption disabled. That won't do any actual harm, so pending a decision from the maintainers, disable preemption there. Remove comments on page_table_lock from flush_tlb_mm, flush_tlb_range and flush_tlb_page entries in cachetlb.txt: they were rather misleading (what generic code does is different from what usually happens), the rules are now changing, and it's not yet clear where we'll end up (will the generic tlb_flush_mmu happen always under lock? never under lock? or sometimes under and sometimes not?). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
