path: root/Documentation/cgroups
2011-04-28memcg: update documentation to describe usage_in_bytesDaisuke Nishimura
Since 569b846d ("memcg: coalesce uncharge during unmap/truncate"), we do batched (delayed) uncharge at truncation/unmap. And since cdec2e42(memcg: coalesce charging via percpu storage), we have percpu cache for res_counter. These changes improved performance of memory cgroup very much, but made res_counter->usage usually have a bigger value than the actual value of memory usage. So, *.usage_in_bytes, which show res_counter->usage, are not desirable for precise values of memory(and swap) usage anymore. Instead of removing these files completely(because we cannot know res_counter->usage without them), this patch updates the meaning of those files. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-04Documentation: update cgroups info user groups namesGeunsik Lim
Update suitable words to explain / understand cgroups contents. Signed-off-by: Geunsik Lim <geunsik.lim@samsung.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-16Documentation: update cgroup pid and cpuset informationEric B Munson
The cgroup documentation does not specify how a process can be removed from a particular group. This patch adds a note at the end of the simple example about how this is done. Also, some cgroups (like cpusets) require user input before a new group can be used. This is noted in the patch as well. Signed-off-by: Eric B Munson <emunson@mgebm.net> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-08Update cpuset info & webiste for cgroupsGeunSik Lim
cpuset related websited is changed. and, update list of cpuset using cgroup(controller group). Signed-off-by: Geunsik Lim <geunsik.lim@samsung.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-08blk-cgroup: Lower minimum weight from 100 to 10.Justin TerAvest
We've found that we still get good, useful isolation at weights this low. I'd like to adjust the minimum so that any other changes can take these values into account. Signed-off-by: Justin TerAvest <teravest@google.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-01cfq-iosched: Always provide group isolation.Justin TerAvest
Effectively, make group_isolation=1 the default and remove the tunable. The setting group_isolation=0 was because by default we idle on sync-noidle tree and on fast devices, this can be very harmful for throughput. However, this problem can also be addressed by tuning slice_idle and possibly group_idle on faster storage devices. This change simplifies the CFQ code by removing the feature entirely. Signed-off-by: Justin TerAvest <teravest@google.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-17memcg: clarify use_hierarchy documentationGreg Thelen
The memcg code does not allow changing memory.use_hierarchy if the parent cgroup has enabled use_hierarchy. Update documentation to match the code. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-14revert documentaion update for memcg's dirty ratio.KAMEZAWA Hiroyuki
Subjct: Revert memory cgroup dirty_ratio Documentation. The commit ece72400c2a27a3d726cb0854449f991d9fcd2da adds documentation for memcg's dirty ratio. But the function is not implemented yet. Remove the documentation for avoiding confusing users. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Greg Thelen <gthelen@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13memcg: document cgroup dirty memory interfacesGreg Thelen
Document cgroup dirty memory interfaces and statistics. [akpm@linux-foundation.org: fix use_hierarchy description] Signed-off-by: Andrea Righi <arighi@develer.com> Signed-off-by: Greg Thelen <gthelen@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-13cgroups: remove deprecated subsystem from examples.Trevor Woerner
The 'ns' cgroup is considered deprecated. Change the cgroup subsystem used in the examples of the cgroup documentation from 'ns' to 'blkio'. Signed-off-by: Trevor Woerner <twoerner@gmail.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-15blk-cgroup: Allow creation of hierarchical cgroupsVivek Goyal
o Allow hierarchical cgroup creation for blkio controller o Currently we disallow it as both the io controller policies (throttling as well as proportion bandwidth) do not support hierarhical accounting and control. But the flip side is that blkio controller can not be used with libvirt as libvirt creates a cgroup hierarchy deeper than 1 level. <top-level-cgroup-dir>/<controller>/libvirt/qemu/<virtual-machine-groups> o So this patch will allow creation of cgroup hierarhcy but at the backend everything will be treated as flat. So if somebody created a an hierarchy like as follows. root / \ test1 test2 | test3 CFQ and throttling will practically treat all groups at same level. pivot / | \ \ root test1 test2 test3 o Once we have actual support for hierarchical accounting and control then we can introduce another cgroup tunable file "blkio.use_hierarchy" which will be 0 by default but if user wants to enforce hierarhical control then it can be set to 1. This way there should not be any ABI problems down the line. o The only not so pretty part is introduction of extra file "use_hierarchy" down the line. Kame-san had mentioned that hierarhical accounting is expensive in memory controller hence they keep it off by default. I suspect same will be the case for IO controller also as for each IO completion we shall have to account IO through hierarchy up to the root. if yes, then it probably is not a very bad idea to introduce this extra file so that it will be used only when somebody needs it and some people might enable hierarchy only in part of the hierarchy. o This is how basically memory controller also uses "use_hierarhcy" and they also allowed creation of hierarchies when actual backend support was not available. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Reviewed-by: Ciju Rajan K <ciju@linux.vnet.ibm.com> Tested-by: Ciju Rajan K <ciju@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-27cgroup: add clone_children control fileDaniel Lezcano
The ns_cgroup is a control group interacting with the namespaces. When a new namespace is created, a corresponding cgroup is automatically created too. The cgroup name is the pid of the process who did 'unshare' or the child of 'clone'. This cgroup is tied with the namespace because it prevents a process to escape the control group and use the post_clone callback, so the child cgroup inherits the values of the parent cgroup. Unfortunately, the more we use this cgroup and the more we are facing problems with it: (1) when a process unshares, the cgroup name may conflict with a previous cgroup with the same pid, so unshare or clone return -EEXIST (2) the cgroup creation is out of control because there may have an application creating several namespaces where the system will automatically create several cgroups in his back and let them on the cgroupfs (eg. a vrf based on the network namespace). (3) the mix of (1) and (2) force an administrator to regularly check and clean these cgroups. This patchset removes the ns_cgroup by adding a new flag to the cgroup and the cgroupfs mount option. It enables the copy of the parent cgroup when a child cgroup is created. We can then safely remove the ns_cgroup as this flag brings a compatibility. We have now to manually create and add the task to a cgroup, which is consistent with the cgroup framework. This patch: Sent as an answer to a previous thread around the ns_cgroup. https://lists.linux-foundation.org/pipermail/containers/2009-June/018627.html It adds a control file 'clone_children' for a cgroup. This control file is a boolean specifying if the child cgroup should be a clone of the parent cgroup or not. The default value is 'false'. This flag makes the child cgroup to call the post_clone callback of all the subsystem, if it is available. At present, the cpuset is the only one which had implemented the post_clone callback. The option can be set at mount time by specifying the 'clone_children' mount option. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Jamal Hadi Salim <hadi@cyberus.ca> Cc: Matt Helsley <matthltc@us.ibm.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-22Merge branch 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits) cfq-iosched: Fix a gcc 4.5 warning and put some comments block: Turn bvec_k{un,}map_irq() into static inline functions block: fix accounting bug on cross partition merges block: Make the integrity mapped property a bio flag block: Fix double free in blk_integrity_unregister block: Ensure physical block size is unsigned int blkio-throttle: Fix possible multiplication overflow in iops calculations blkio-throttle: limit max iops value to UINT_MAX blkio-throttle: There is no need to convert jiffies to milli seconds blkio-throttle: Fix link failure failure on i386 blkio: Recalculate the throttled bio dispatch time upon throttle limit change blkio: Add root group to td->tg_list blkio: deletion of a cgroup was causes oops blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n block: set the bounce_pfn to the actual DMA limit rather than to max memory block: revert bad fix for memory hotplug causing bounces Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK block: set the bounce_pfn to the actual DMA limit rather than to max memory block: Prevent hang_check firing during long I/O cfq: improve fsync performance for small files ... Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
2010-09-16blkio: Documentation UpdateVivek Goyal
o Documentation update Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-23cfq-iosched: Documentation help for new tunablesVivek Goyal
Some documentation to provide help with tunables. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-27memcg: update documentationKAMEZAWA Hiroyuki
Some information are old, and I think current document doesn't work as "a guide for users". We need summary of all of our controls, at least. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: move charge of file pagesDaisuke Nishimura
This patch adds support for moving charge of file pages, which include normal file, tmpfs file and swaps of tmpfs file. It's enabled by setting bit 1 of <target cgroup>/memory.move_charge_at_immigrate. Unlike the case of anonymous pages, file pages(and swaps) in the range mmapped by the task will be moved even if the task hasn't done page fault, i.e. they might not be the task's "RSS", but other task's "RSS" that maps the same file. And mapcount of the page is ignored(the page can be moved even if page_mapcount(page) > 1). So, conditions that the page/swap should be met to be moved is that it must be in the range mmapped by the target task and it must be charged to the old cgroup. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix warning] Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: oom kill disable and oom statusKAMEZAWA Hiroyuki
This adds a feature to disable oom-killer for memcg, if disabled, of course, tasks under memcg will stop. But now, we have oom-notifier for memcg. And the world around memcg is not under out-of-memory. memcg's out-of-memory just shows memcg hits limit. Then, administrator or management daemon can recover the situation by - kill some process - enlarge limit, add more swap. - migrate some tasks - remove file cache on tmps (difficult ?) Unlike oom-killer, you can take enough information before killing tasks. (by gcore, or, ps etc.) [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: oom notifierKAMEZAWA Hiroyuki
Considering containers or other resource management softwares in userland, event notification of OOM in memcg should be implemented. Now, memcg has "threshold" notifier which uses eventfd, we can make use of it for oom notification. This patch adds oom notification eventfd callback for memcg. The usage is very similar to threshold notifier, but control file is memory.oom_control and no arguments other than eventfd is required. % cgroup_event_notifier /cgroup/A/memory.oom_control dummy (About cgroup_event_notifier, see Documentation/cgroup/) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: David Rientjes <rientjes@google.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27Documentation/cgroups/cgroups.txt: fix reference to "numtasks"Trevor Woerner
Signed-off-by: Trevor Woerner <twoerner@gmail.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/ext3/fsync.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-04-29Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/block_dev.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-26blk-cgroup: config options re-arrangementVivek Goyal
This patch fixes few usability and configurability issues. o All the cgroup based controller options are configurable from "Genral Setup/Control Group Support/" menu. blkio is the only exception. Hence make this option visible in above menu and make it configurable from there to bring it inline with rest of the cgroup based controllers. o Get rid of CONFIG_DEBUG_CFQ_IOSCHED. This option currently does two things. - Enable printing of cgroup paths in blktrace - Enables CONFIG_DEBUG_BLK_CGROUP, which in turn displays additional stat files in cgroup. If we are using group scheduling, blktrace data is of not really much use if cgroup information is not present. To get this data, currently one has to also enable CONFIG_DEBUG_CFQ_IOSCHED, which in turn brings the overhead of all the additional debug stat files which is not desired. Hence, this patch moves printing of cgroup paths under CONFIG_CFQ_GROUP_IOSCHED. This allows us to get rid of CONFIG_DEBUG_CFQ_IOSCHED completely. Now all the debug stat files are controlled only by CONFIG_DEBUG_BLK_CGROUP which can be enabled through config menu. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Divyesh Shah <dpshah@google.com> Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-24cgroups: fix procs documentationKAMEZAWA Hiroyuki
Writing to cgroup.procs is not supported now. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Ben Blum <bblum@andrew.cmu.edu> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-13io-controller: Document for blkio.weight_deviceGui Jianfeng
Here is the document for blkio.weight_device Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Add more debug-only per-cgroup statsDivyesh Shah
1) group_wait_time - This is the amount of time the cgroup had to wait to get a timeslice for one of its queues from when it became busy, i.e., went from 0 to 1 request queued. This is different from the io_wait_time which is the cumulative total of the amount of time spent by each IO in that cgroup waiting in the scheduler queue. This stat is a great way to find out any jobs in the fleet that are being starved or waiting for longer than what is expected (due to an IO controller bug or any other issue). 2) empty_time - This is the amount of time a cgroup spends w/o any pending requests. This stat is useful when a job does not seem to be able to use its assigned disk share by helping check if that is happening due to an IO controller bug or because the job is not submitting enough IOs. 3) idle_time - This is the amount of time spent by the IO scheduler idling for a given cgroup in anticipation of a better request than the exising ones from other queues/cgroups. All these stats are recorded using start and stop events. When reading these stats, we do not add the delta between the current time and the last start time if we're between the start and stop events. We avoid doing this to make sure that these numbers are always monotonically increasing when read. Since we're using sched_clock() which may use the tsc as its source, it may induce some inconsistency (due to tsc resync across cpus) if we included the current delta. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Add io_queued and avg_queue_size statsDivyesh Shah
These stats are useful for getting a feel for the queue depth of the cgroup, i.e., how filled up its queues are at a given instant and over the existence of the cgroup. This ability is useful when debugging problems in the wild as it helps understand the application's IO pattern w/o having to read through the userspace code (coz its tedious or just not available) or w/o the ability to run blktrace (since you may not have root access and/or not want to disturb performance). Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Add io_merged statDivyesh Shah
This includes both the number of bios merged into requests belonging to this cgroup as well as the number of requests merged together. In the past, we've observed different merging behavior across upstream kernels, some by design some actual bugs. This stat helps a lot in debugging such problems when applications report decreased throughput with a new kernel version. This needed adding an extra elevator function to capture bios being merged as I did not want to pollute elevator code with blkiocg knowledge and hence needed the accounting invocation to come from CFQ. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Changes to IO controller additional stats patchesDivyesh Shah
that include some minor fixes and addresses all comments. Changelog: (most based on Vivek Goyal's comments) o renamed blkiocg_reset_write to blkiocg_reset_stats o more clarification in the documentation on io_service_time and io_wait_time o Initialize blkg->stats_lock o rename io_add_stat to blkio_add_stat and declare it static o use bool for direction and sync o derive direction and sync info from existing rq methods o use 12 for major:minor string length o define io_service_time better to cover the NCQ case o add a separate reset_stats interface o make the indexed stats a 2d array to simplify macro and function pointer code o blkio.time now exports in jiffies as before o Added stats description in patch description and Documentation/cgroup/blkio-controller.txt o Prefix all stats functions with blkio and make them static as applicable o replace IO_TYPE_MAX with IO_TYPE_TOTAL o Moved #define constant to top of blk-cgroup.c o Pass dev_t around instead of char * o Add note to documentation file about resetting stats o use BLK_CGROUP_MODULE in addition to BLK_CGROUP config option in #ifdef statements o Avoid struct request specific knowledge in blk-cgroup. blk-cgroup.h now has rq_direction() and rq_sync() functions which are used by CFQ and when using io-controller at a higher level, bio_* functions can be added. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-25cpuset: Fix documentation punctuationGreg Thelen
Fix cpusets.txt documentation punctuation. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-24memcg: fix typo in memcg documentationGreg Thelen
Update memory.txt to be more consistent: s/swapiness/swappiness/ Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-19memcg: fix typo in memcg documentationGreg Thelen
Updated memory.txt to be more consistent: s/swapiness/swappiness/ Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-16Fix typos in commentsThomas Weber
[Ss]ytem => [Ss]ystem udpate => update paramters => parameters orginal => original Signed-off-by: Thomas Weber <swirl@gmx.li> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12memcg: fix typos in memcg_test.txtKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: update memcg_test.txt to describe memory thresholdsKirill A. Shutemov
Decription of sanity check for memory thresholds. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: add simple listener of cgroup events to documentationKirill A. Shutemov
An example of cgroup notification API usage. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: handle panic_on_oom=always caseKAMEZAWA Hiroyuki
Presently, if panic_on_oom=2, the whole system panics even if the oom happend in some special situation (as cpuset, mempolicy....). Then, panic_on_oom=2 means painc_on_oom_always. Now, memcg doesn't check panic_on_oom flag. This patch adds a check. BTW, how it's useful ? kdump+panic_on_oom=2 is the last tool to investigate what happens in oom-ed system. When a task is killed, the sysytem recovers and there will be few hint to know what happnes. In mission critical system, oom should never happen. Then, panic_on_oom=2+kdump is useful to avoid next OOM by knowing precise information via snapshot. TODO: - For memcg, it's for isolate system's memory usage, oom-notiifer and freeze_at_oom (or rest_at_oom) should be implemented. Then, management daemon can do similar jobs (as kdump) or taking snapshot per cgroup. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Nick Piggin <npiggin@suse.de> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: update memcg_test.txtDaisuke Nishimura
Update memcg_test.txt to describe how to test the move-charge feature. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: implement memory thresholdsKirill A. Shutemov
It allows to register multiple memory and memsw thresholds and gets notifications when it crosses. To register a threshold application need: - create an eventfd; - open memory.usage_in_bytes or memory.memsw.usage_in_bytes; - write string like "<event_fd> <memory.usage_in_bytes> <threshold>" to cgroup.event_control. Application will be notified through eventfd when memory usage crosses threshold in any direction. It's applicable for root and non-root cgroup. It uses stats to track memory usage, simmilar to soft limits. It checks if we need to send event to userspace on every 100 page in/out. I guess it's good compromise between performance and accuracy of thresholds. [akpm@linux-foundation.org: coding-style fixes] [nishimura@mxp.nes.nec.co.jp: fix documentation merge issue] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Vladislav Buzov <vbuzov@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Alexander Shishkin <virtuoso@slind.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroup: implement eventfd-based generic API for notificationsKirill A. Shutemov
This patchset introduces eventfd-based API for notifications in cgroups and implements memory notifications on top of it. It uses statistics in memory controler to track memory usage. Output of time(1) on building kernel on tmpfs: Root cgroup before changes: make -j2 506.37 user 60.93s system 193% cpu 4:52.77 total Non-root cgroup before changes: make -j2 507.14 user 62.66s system 193% cpu 4:54.74 total Root cgroup after changes (0 thresholds): make -j2 507.13 user 62.20s system 193% cpu 4:53.55 total Non-root cgroup after changes (0 thresholds): make -j2 507.70 user 64.20s system 193% cpu 4:55.70 total Root cgroup after changes (1 thresholds, never crossed): make -j2 506.97 user 62.20s system 193% cpu 4:53.90 total Non-root cgroup after changes (1 thresholds, never crossed): make -j2 507.55 user 64.08s system 193% cpu 4:55.63 total This patch: Introduce the write-only file "cgroup.event_control" in every cgroup. To register new notification handler you need: - create an eventfd; - open a control file to be monitored. Callbacks register_event() and unregister_event() must be defined for the control file; - write "<event_fd> <control_fd> <args>" to cgroup.event_control. Interpretation of args is defined by control file implementation; eventfd will be woken up by control file implementation or when the cgroup is removed. To unregister notification handler just close eventfd. If you need notification functionality for a control file you have to implement callbacks register_event() and unregister_event() in the struct cftype. [kamezawa.hiroyu@jp.fujitsu.com: Kconfig fix] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Vladislav Buzov <vbuzov@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Alexander Shishkin <virtuoso@slind.org> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: move charges of anonymous swapDaisuke Nishimura
This patch is another core part of this move-charge-at-task-migration feature. It enables moving charges of anonymous swaps. To move the charge of swap, we need to exchange swap_cgroup's record. In current implementation, swap_cgroup's record is protected by: - page lock: if the entry is on swap cache. - swap_lock: if the entry is not on swap cache. This works well in usual swap-in/out activity. But this behavior make the feature of moving swap charge check many conditions to exchange swap_cgroup's record safely. So I changed modification of swap_cgroup's recored(swap_cgroup_record()) to use xchg, and define a new function to cmpxchg swap_cgroup's record. This patch also enables moving charge of non pte_present but not uncharged swap caches, which can be exist on swap-out path, by getting the target pages via find_get_page() as do_mincore() does. [kosaki.motohiro@jp.fujitsu.com: fix ia64 build] [akpm@linux-foundation.org: fix typos] Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
