Rather than using explicit euid == 0 checks when trying to move
tasks into a cgroup via CFS, move permission checks into each
specific cgroup subsystem. If a subsystem does not specify a
'allow_attach' handler, then we fall back to doing our checks
the old way.
Use the 'allow_attach' handler for the 'cpu' cgroup to allow
non-root processes to add arbitrary processes to a 'cpu' cgroup
if it has the CAP_SYS_NICE capability set.
This version of the patch adds a 'allow_attach' handler instead
of reusing the 'can_attach' handler. If the 'can_attach' handler
is reused, a new cgroup that implements 'can_attach' but not
the permission checks could end up with no permission checks
at all.
Change-Id: Icfa950aa9321d1ceba362061d32dc7dfa2c64f0c
Original-Author: San Mehat <san@google.com>
Signed-off-by: Colin Cross <ccross@android.com>
This exports the amount of anonymous transparent hugepages for each
memcg via the new "rss_huge" stat in memory.stat. The units are in
bytes.
This is helpful to determine the hugepage utilization for individual
jobs on the system in comparison to rss and opportunities where
MADV_HUGEPAGE may be helpful.
The amount of anonymous transparent hugepages is also included in "rss"
for backwards compatibility.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
Pull trivial tree updates from Jiri Kosina:
"Usual stuff, mostly comment fixes, typo fixes, printk fixes and small
code cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits)
mm: Convert print_symbol to %pSR
gfs2: Convert print_symbol to %pSR
m32r: Convert print_symbol to %pSR
iostats.txt: add easy-to-find description for field 6
x86 cmpxchg.h: fix wrong comment
treewide: Fix typo in printk and comments
doc: devicetree: Fix various typos
docbook: fix 8250 naming in device-drivers
pata_pdc2027x: Fix compiler warning
treewide: Fix typo in printks
mei: Fix comments in drivers/misc/mei
treewide: Fix typos in kernel messages
pm44xx: Fix comment for "CONFIG_CPU_IDLE"
doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP"
mmzone: correct "pags" to "pages" in comment.
kernel-parameters: remove outdated 'noresidual' parameter
Remove spurious _H suffixes from ifdef comments
sound: Remove stray pluses from Kconfig file
radio-shark: Fix printk "CONFIG_LED_CLASS"
doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
- Fixes and a lot of cleanups. Locking cleanup is finally complete.
cgroup_mutex is no longer exposed to individual controlelrs which
used to cause nasty deadlock issues. Li fixed and cleaned up quite a
bit including long standing ones like racy cgroup_path().
- device cgroup now supports proper hierarchy thanks to Aristeu.
- perf_event cgroup now supports proper hierarchy.
- A new mount option "__DEVEL__sane_behavior" is added. As indicated
by the name, this option is to be used for development only at this
point and generates a warning message when used. Unfortunately,
cgroup interface currently has too many brekages and inconsistencies
to implement a consistent and unified hierarchy on top. The new flag
is used to collect the behavior changes which are necessary to
implement consistent unified hierarchy. It's likely that this flag
won't be used verbatim when it becomes ready but will be enabled
implicitly along with unified hierarchy.
The option currently disables some of broken behaviors in cgroup core
and also .use_hierarchy switch in memcg (will be routed through -mm),
which can be used to make very unusual hierarchy where nesting is
partially honored. It will also be used to implement hierarchy
support for blk-throttle which would be impossible otherwise without
introducing a full separate set of control knobs.
This is essentially versioning of interface which isn't very nice but
at this point I can't see any other options which would allow keeping
the interface the same while moving towards hierarchy behavior which
is at least somewhat sane. The planned unified hierarchy is likely
to require some level of adaptation from userland anyway, so I think
it'd be best to take the chance and update the interface such that
it's supportable in the long term.
Maintaining the existing interface does complicate cgroup core but
shouldn't put too much strain on individual controllers and I think
it'd be manageable for the foreseeable future. Maybe we'll be able
to drop it in a decade.
Fix up conflicts (including a semantic one adding a new #include to ppc
that was uncovered by header the file changes) as per Tejun.
* 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (45 commits)
cpuset: fix compile warning when CONFIG_SMP=n
cpuset: fix cpu hotplug vs rebuild_sched_domains() race
cpuset: use rebuild_sched_domains() in cpuset_hotplug_workfn()
cgroup: restore the call to eventfd->poll()
cgroup: fix use-after-free when umounting cgroupfs
cgroup: fix broken file xattrs
devcg: remove parent_cgroup.
memcg: force use_hierarchy if sane_behavior
cgroup: remove cgrp->top_cgroup
cgroup: introduce sane_behavior mount option
move cgroupfs_root to include/linux/cgroup.h
cgroup: convert cgroupfs_root flag bits to masks and add CGRP_ prefix
cgroup: make cgroup_path() not print double slashes
Revert "cgroup: remove bind() method from cgroup_subsys."
perf: make perf_event cgroup hierarchical
cgroup: implement cgroup_is_descendant()
cgroup: make sure parent won't be destroyed before its children
devcg: remove broken_hierarchy tag
cgroup: remove cgroup_lock_is_held()
With this patch userland applications that want to maintain the
interactivity/memory allocation cost can use the pressure level
notifications. The levels are defined like this:
The "low" level means that the system is reclaiming memory for new
allocations. Monitoring this reclaiming activity might be useful for
maintaining cache level. Upon notification, the program (typically
"Activity Manager") might analyze vmstat and act in advance (i.e.
prematurely shutdown unimportant services).
The "medium" level means that the system is experiencing medium memory
pressure, the system might be making swap, paging out active file
caches, etc. Upon this event applications may decide to further analyze
vmstat/zoneinfo/memcg or internal memory usage statistics and free any
resources that can be easily reconstructed or re-read from a disk.
The "critical" level means that the system is actively thrashing, it is
about to out of memory (OOM) or even the in-kernel OOM killer is on its
way to trigger. Applications should do whatever they can to help the
system. It might be too late to consult with vmstat or any other
statistics, so it's advisable to take an immediate action.
The events are propagated upward until the event is handled, i.e. the
events are not pass-through. Here is what this means: for example you
have three cgroups: A->B->C. Now you set up an event listener on
cgroups A, B and C, and suppose group C experiences some pressure. In
this situation, only group C will receive the notification, i.e. groups
A and B will not receive it. This is done to avoid excessive
"broadcasting" of messages, which disturbs the system and which is
especially bad if we are low on memory or thrashing. So, organize the
cgroups wisely, or propagate the events manually (or, ask us to
implement the pass-through events, explaining why would you need them.)
Performance wise, the memory pressure notifications feature itself is
lightweight and does not require much of bookkeeping, in contrast to the
rest of memcg features. Unfortunately, as of current memcg
implementation, pages accounting is an inseparable part and cannot be
turned off. The good news is that there are some efforts[1] to improve
the situation; plus, implementing the same, fully API-compatible[2]
interface for CONFIG_MEMCG=n case (e.g. embedded) is also a viable
option, so it will not require any changes on the userland side.
[1] http://permalink.gmane.org/gmane.linux.kernel.cgroups/6291
[2] http://lkml.org/lkml/2013/2/21/454
[akpm@linux-foundation.org: fix CONFIG_CGROPUPS=n warnings]
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Glauber Costa <glommer@parallels.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Leonid Moiseichuk <leonid.moiseichuk@nokia.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: John Stultz <john.stultz@linaro.org>
This reverts commit 84cfb6ab484b442d5115eb3baf9db7d74a3ea626. There
are scheduled changes which make use of the removed callback.
Cc: Rami Rosen <ramirose@gmail.com>
Cc: Li Zefan <lizefan@huawei.com>
The bind() method of cgroup_subsys is not used in any of the
controllers (cpuset, freezer, blkio, net_cls, memcg, net_prio,
devices, perf, hugetlb, cpu and cpuacct)
tj: Removed the entry on ->bind() from
Documentation/cgroups/cgroups.txt. Also updated a couple
paragraphs which were suggesting that dynamic re-binding may be
implemented. It's not gonna.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
This patch adds a new file, Documentation/cgroups/net_cls.txt, with info
about net_cls cgroups, and updates the 00-INDEX accordingly.
This trivial patch removes a word which appears twice in
Documentation/cgroup/cgroup.txt.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Rob Landley <rob@landley.net>
This patch makes exception changes to propagate down in hierarchy respecting
when possible local exceptions.
New exceptions allowing additional access to devices won't be propagated, but
it'll be possible to add an exception to access all of part of the newly
allowed device(s).
New exceptions disallowing access to devices will be propagated down and the
local group's exceptions will be revalidated for the new situation.
Example:
A
B
group behavior exceptions
A allow "b 8:* rwm", "c 116:1 rw"
B deny "c 1:3 rwm", "c 116:2 rwm", "b 3:* rwm"
If a new exception is added to group A:
# echo "c 116:* r" > A/devices.deny
it'll propagate down and after revalidating B's local exceptions, the exception
"c 116:2 rwm" will be removed.
In case parent's exceptions change and local exceptions are not allowed anymore,
they'll be deleted.
v7:
- do not allow behavior change when the cgroup has children
- update documentation
v6: fixed issues pointed by Serge Hallyn
- only copy parent's exceptions while propagating behavior if the local
behavior is different
- while propagating exceptions, do not clear and copy parent's: it'd be against
the premise we don't propagate access to more devices
v5: fixed issues pointed by Serge Hallyn
- updated documentation
- not propagating when an exception is written to devices.allow
- when propagating a new behavior, clean the local exceptions list if they're
for a different behavior
v4: fixed issues pointed by Tejun Heo
- separated function to walk the tree and collect valid propagation targets
v3: fixed issues pointed by Tejun Heo
- move css_online/css_offline changes to a new patch
- use cgroup_for_each_descendant_pre() instead of own descendant walk
- move exception_copy rework to a separared patch
- move exception_clean rework to a separated patch
v2: fixed issues pointed by Tejun Heo
- instead of keeping the local settings that won't apply anymore, remove them
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Signed-off-by: Aristeu Rozanski <aris@redhat.com>
cpuset no longer nests cgroup_mutex inside cpu_hotplug lock, so
we don't have to release cgroup_mutex before calling css_offline().
Signed-off-by: Li Zefan <lizefan@huawei.com>
Pull block IO core bits from Jens Axboe:
"Below are the core block IO bits for 3.9. It was delayed a few days
since my workstation kept crashing every 2-8h after pulling it into
current -git, but turns out it is a bug in the new pstate code (divide
by zero, will report separately). In any case, it contains:
- The big cfq/blkcg update from Tejun and and Vivek.
- Additional block and writeback tracepoints from Tejun.
- Improvement of the should sort (based on queues) logic in the plug
flushing.
- _io() variants of the wait_for_completion() interface, using
io_schedule() instead of schedule() to contribute to io wait
properly.
- Various little fixes.
You'll get two trivial merge conflicts, which should be easy enough to
fix up"
Fix up the trivial conflicts due to hlist traversal cleanups (commit
b67bfe0d42ca: "hlist: drop the node parameter from iterators").
* 'for-3.9/core' of git://git.kernel.dk/linux-block: (39 commits)
block: remove redundant check to bd_openers()
block: use i_size_write() in bd_set_size()
cfq: fix lock imbalance with failed allocations
drivers/block/swim3.c: fix null pointer dereference
block: don't select PERCPU_RWSEM
block: account iowait time when waiting for completion of IO request
sched: add wait_for_completion_io[_timeout]
writeback: add more tracepoints
block: add block_{touch|dirty}_buffer tracepoint
buffer: make touch_buffer() an exported function
block: add @req to bio_{front|back}_merge tracepoints
block: add missing block_bio_complete() tracepoint
block: Remove should_sort judgement when flush blk_plug
block,elevator: use new hashtable implementation
cfq-iosched: add hierarchical cfq_group statistics
cfq-iosched: collect stats from dead cfqgs
cfq-iosched: separate out cfqg_stats_reset() from cfq_pd_reset_stats()
blkcg: make blkcg_print_blkgs() grab q locks instead of blkcg lock
block: RCU free request_queue
blkcg: implement blkg_[rw]stat_recursive_sum() and blkg_[rw]stat_merge()
Signed-off-by: Warren Turkal <wt@ooyala.com>
With the previous two patches, all cfqg scheduling decisions are based
on vfraction and ready for hierarchy support. The only thing which
keeps the behavior flat is cfqg_flat_parent() which makes vfraction
calculation consider all non-root cfqgs children of the root cfqg.
Replace it with cfqg_parent() which returns the real parent. This
enables full blkcg hierarchy support for cfq-iosched. For example,
consider the following hierarchy.
root
A:500 B:250
AA:500 AB:1000
For simplicity, let's say all the leaf nodes have active tasks and are
on service tree. For each leaf node, vfraction would be
AA: (500 / 1500) * (500 / 750) =~ 0.2222
AB: (1000 / 1500) * (500 / 750) =~ 0.4444
B: (250 / 750) =~ 0.3333
and vdisktime will be distributed accordingly. For more detail,
please refer to Documentation/block/cfq-iosched.txt.
v2: cfq-iosched.txt updated to describe group scheduling as suggested
by Vivek.
v3: blkio-controller.txt updated.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Move the cgroup_event_listener.c tool from Documentation into the new
tools/cgroup directory.
This change involves wiring cgroup_event_listener.c into the tools/
make system so that is can be built with:
$ make tools/cgroup
Signed-off-by: Greg Thelen <gthelen@google.com>
Signed-off-by: Glauber Costa <glommer@parallels.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Frederic Weisbecker <fweisbec@redhat.com>
Cc: JoonSoo Kim <js1304@gmail.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Suleiman Souhlal <suleiman@google.com>
Acked-by: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
It is useful to know how many charges are still left after a call to
res_counter_uncharge. While it is possible to issue a res_counter_read
after uncharge, this can be racy.
If we need, for instance, to take some action when the counters drop down
to 0, only one of the callers should see it. This is the same semantics
as the atomic variables in the kernel.
Since the current return value is void, we don't need to worry about
anything breaking due to this change: nobody relied on that, and only
users appearing from now on will be checking this value.
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: David Rientjes <rientjes@google.com>
N_HIGH_MEMORY stands for the nodes that has normal or high memory.
N_MEMORY stands for the nodes that has any memory.
The code here need to handle with the nodes which have memory, we should
use N_MEMORY instead.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Hillf Danton <dhillf@gmail.com>
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Cc: Lin Feng <linfeng@cn.fujitsu.com>
Pull cgroup changes from Tejun Heo:
"A lot of activities on cgroup side. The big changes are focused on
making cgroup hierarchy handling saner.
- cgroup_rmdir() had peculiar semantics - it allowed cgroup
destruction to be vetoed by individual controllers and tried to
drain refcnt synchronously. The vetoing never worked properly and
caused good deal of contortions in cgroup. memcg was the last
reamining user. Michal Hocko removed the usage and cgroup_rmdir()
path has been simplified significantly. This was done in a
separate branch so that the memcg people can base further memcg
changes on top.
- The above allowed cleaning up cgroup lifecycle management and
implementation of generic cgroup iterators which are used to
improve hierarchy support.
- cgroup_freezer updated to allow migration in and out of a frozen
cgroup and handle hierarchy. If a cgroup is frozen, all descendant
cgroups are frozen.
- netcls_cgroup and netprio_cgroup updated to handle hierarchy
properly.
- Various fixes and cleanups.
- Two merge commits. One to pull in memcg and rmdir cleanups (needed
to build iterators). The other pulled in cgroup/for-3.7-fixes for
device_cgroup fixes so that further device_cgroup patches can be
stacked on top."
Fixed up a trivial conflict in mm/memcontrol.c as per Tejun (due to
commit bea8c150a7 ("memcg: fix hotplugged memory zone oops") in master
touching code close to commit 2ef37d3fe4 ("memcg: Simplify
mem_cgroup_force_empty_list error handling") in for-3.8)
* 'for-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (65 commits)
cgroup: update Documentation/cgroups/00-INDEX
cgroup_rm_file: don't delete the uncreated files
cgroup: remove subsystem files when remounting cgroup
cgroup: use cgroup_addrm_files() in cgroup_clear_directory()
cgroup: warn about broken hierarchies only after css_online
cgroup: list_del_init() on removed events
cgroup: fix lockdep warning for event_control
cgroup: move list add after list head initilization
netprio_cgroup: allow nesting and inherit config on cgroup creation
netprio_cgroup: implement netprio[_set]_prio() helpers
netprio_cgroup: use cgroup->id instead of cgroup_netprio_state->prioidx
netprio_cgroup: reimplement priomap expansion
netprio_cgroup: shorten variable names in extend_netdev_table()
netprio_cgroup: simplify write_priomap()
netcls_cgroup: move config inheritance to ->css_online() and remove .broken_hierarchy marking
cgroup: remove obsolete guarantee from cgroup_task_migrate.
cgroup: add cgroup->id
cgroup, cpuset: remove cgroup_subsys->post_clone()
cgroup: s/CGRP_CLONE_CHILDREN/CGRP_CPUSET_CLONE_CHILDREN/
cgroup: rename ->create/post_create/pre_destroy/destroy() to ->css_alloc/online/offline/free()
mem_cgroup_charge_common() is invoked as the entry point for cgroup limits
charge rather than mem_cgroup_charge(), as the later has been removed for
years. Update the cgroup/memory.txt to reflect this change.
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Cc: Ying Han <yinghan@google.com>
There are new files added to cgroup documentation. Let's update the
index file to include the new files.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com>
Inherit netprio configuration from ->css_online(), allow nesting and
remove .broken_hierarchy marking. This makes netprio_cgroup's
behavior match netcls_cgroup's.
Note that this patch changes userland-visible behavior. Nesting is
allowed and the first level cgroups below the root cgroup behave
differently - they inherit priorities from the root cgroup on creation
instead of starting with 0. This is unfortunate but not doing so is
much crazier.
Tested-and-Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Currently CGRP_CPUSET_CLONE_CHILDREN triggers ->post_clone(). Now
that clone_children is cpuset specific, there's no reason to have this
rather odd option activation mechanism in cgroup core. cpuset can
check the flag from its ->css_allocate() and take the necessary
action.
Move cpuset_post_clone() logic to the end of cpuset_css_alloc() and
remove cgroup_subsys->post_clone().
Loosely based on Glauber's "generalize post_clone into post_create"
patch.
Original-patch-by: Glauber Costa <glommer@parallels.com>
Original-patch: <1351686554-22592-2-git-send-email-glommer@parallels.com>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Acked-by: Li Zefan <lizefan@huawei.com>
clone_children is only meaningful for cpuset and will stay that way.
Rename the flag to reflect that and update documentation. Also, drop
clone_children() wrapper in cgroup.c. The thin wrapper is used only a
few times and one of them will go away soon.
Rename cgroup_subsys css lifetime related callbacks to better describe
what their roles are. Also, update documentation.
oom_badness() takes a totalpages argument which says how many pages are
available and it uses it as a base for the score calculation. The value
is calculated by mem_cgroup_get_limit which considers both limit and
total_swap_pages (resp. memsw portion of it).
This is usually correct but since fe35004fbf9e ("mm: avoid swapping out
with swappiness==0") we do not swap when swappiness is 0 which means
that we cannot really use up all the totalpages pages. This in turn
confuses oom score calculation if the memcg limit is much smaller than
the available swap because the used memory (capped by the limit) is
negligible comparing to totalpages so the resulting score is too small
if adj!=0 (typically task with CAP_SYS_ADMIN or non zero oom_score_adj).
A wrong process might be selected as result.
The problem can be worked around by checking mem_cgroup_swappiness==0
and not considering swap at all in such a case.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: <stable@vger.kernel.org>
Up until now, cgroup_freezer didn't implement hierarchy properly.
cgroups could be arranged in hierarchy but it didn't make any
difference in how each cgroup_freezer behaved. They all operated
separately.
This patch implements proper hierarchy support. If a cgroup is
frozen, all its descendants are frozen. A cgroup is thawed iff it and
all its ancestors are THAWED. freezer.self_freezing shows the current
freezing state for the cgroup itself. freezer.parent_freezing shows
whether the cgroup is freezing because any of its ancestors is
freezing.
freezer_post_create() locks the parent and new cgroup and inherits the
parent's state and freezer_change_state() applies new state top-down
using cgroup_for_each_descendant_pre() which guarantees that no child
can escape its parent's state. update_if_frozen() uses
cgroup_for_each_descendant_post() to propagate frozen states
bottom-up.
Synchronization could be coarser and easier by using a single mutex to
protect all hierarchy operations. Finer grained approach was used
because it wasn't too difficult for cgroup_freezer and I think it's
beneficial to have an example implementation and cgroup_freezer is
rather simple and can serve a good one.
As this makes cgroup_freezer properly hierarchical,
freezer_subsys.broken_hierarchy marking is removed.
Note that this patch changes userland visible behavior - freezing a
cgroup now freezes all its descendants too. This behavior change is
intended and has been warned via .broken_hierarchy.
v2: Michal spotted a bug in freezer_change_state() - descendants were
inheriting from the wrong ancestor. Fixed.
v3: Documentation/cgroups/freezer-subsystem.txt updated.
While reading through Documentation/cgroups/memory.txt, I found a number
of minor wordos and typos. The patch below is a conservative handling of
some of these: it provides just a number of "obviously correct" fixes to
the English that improve the readability of the document somewhat.
Obviously some more significant fixes need to be made to the document, but
some of those may not be in the "obvious correct" category.
Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com>
While reading through Documentation/cgroups/cgroups.txt, I found a
number of minor wordos and typos. The patch below is a conservative
handling of some of these: it provides just a number of "obviously
correct" fixes to the English that improve the readability
of the document somewhat. Obviously some more significant
fixes could be made to the document, but some of those
may not be in the "obviously correct" category.
v2: update cgroups.txt instead of creating a new file
Cc: Hillf Danton <dhillf@gmail.com>
Cc: Lennart Poettering <lpoetter@redhat.com>
Signed-off-by: Wanpeng Li <liwp.linux@gmail.com>
Sanity:
CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG
CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP
CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED
CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM
[mhocko@suse.cz: fix missed bits]
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Remounting support will be removed in the future (see
feature-removal-schedule.txt). Discourage users from using it.
Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Cc: Rob Landley <rob@landley.net>
Cc: Paul Menage <paul@paulmenage.org>
This function was removed by 86f82d561864e902c70282b6f17cf590c0f34691.
Cc: Li Zefan <lizf@cn.fujitsu.com>
It was introduced for memcg to iterate cgroup hierarchy without
holding cgroup_mutex, but soon after that it was replaced with
a lockless way in memcg.
No one used hierarchy_mutex since that, so remove it.
Presently, at removal of cgroup, ->pre_destroy() is called and moves
charges to the parent cgroup. A major reason for returning -EBUSY from
->pre_destroy() is that the 'moving' hits the parent's resource
limitation. It happens only when use_hierarchy=0.
Considering use_hierarchy=0, all cgroups should be flat. So, no one
cannot justify moving charges to parent...parent and children are in flat
configuration, not hierarchical.
This patch modifes the code to move charges to the root cgroup at
rmdir/force_empty if use_hierarchy==0. This will much simplify rmdir()
and reduce error in ->pre_destroy.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
When killing a res_counter which is a child of other counter, we need to
do
res_counter_uncharge(child, xxx)
res_counter_charge(parent, xxx)
This is not atomic and wastes CPU. This patch adds
res_counter_uncharge_until(). This function's uncharge propagates to
ancestors until specified res_counter.
res_counter_uncharge_until(child, parent, xxx)
Now the operation is atomic and efficient.
Signed-off-by: Frederic Weisbecker <fweisbec@redhat.com>
This patch changes memcg's behavior at task_move().
At task_move(), the kernel scans a task's page table and move the changes
for mapped pages from source cgroup to target cgroup. There has been a
bug at handling shared anonymous pages for a long time.
Before patch:
- The spec says 'shared anonymous pages are not moved.'
- The implementation was 'shared anonymoys pages may be moved'.
If page_mapcount <=2, shared anonymous pages's charge were moved.
After patch:
- The spec says 'all anonymous pages are moved'.
- The implementation is 'all anonymous pages are moved'.
Considering usage of memcg, this will not affect user's experience.
'shared anonymous' pages only exists between a tree of processes which
don't do exec(). Moving one of process without exec() seems not sane.
For example, libcgroup will not be affected by this change. (Anyway, no
one noticed the implementation for a long time...)
Below is a discussion log:
- current spec/implementation are complex
- Now, shared file caches are moved
- It adds unclear check as page_mapcount(). To do correct check,
we should check swap users, etc.
- No one notice this implementation behavior. So, no one get benefit
from the design.
- In general, once task is moved to a cgroup for running, it will not
be moved....
- Finally, we have control knob as memory.move_charge_at_immigrate.
Here is a patch to allow moving shared pages, completely. This makes
memcg simpler and fix current broken code.
Suggested-by: Hugh Dickins <hughd@google.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
The hierarchical versions of per-memcg counters in memory.stat are all
calculated the same way and are all named total_<counter>.
Documenting the pattern is easier for maintenance than listing each
counter twice.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Ying Han <yinghan@google.com>
Randy Dunlap <rdunlap@xenotime.net>
"cgroup file type addition / removal is updated so that file types are
added and removed instead of individual files so that dynamic file
type addition / removal can be implemented by cgroup and used by
controllers. blkio controller changes which will come through block
tree are dependent on this. Other changes include res_counter cleanup
and disallowing kthread / PF_THREAD_BOUND threads to be attached to
non-root cgroups.
There's a reported bug with the file type addition / removal handling
which can lead to oops on cgroup umount. The issue is being looked
into. It shouldn't cause problems for most setups and isn't a
security concern."
Fix up trivial conflict in Documentation/feature-removal-schedule.txt
* 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (21 commits)
res_counter: Account max_usage when calling res_counter_charge_nofail()
res_counter: Merge res_counter_charge and res_counter_charge_nofail
cgroups: disallow attaching kthreadd or PF_THREAD_BOUND threads
cgroup: remove cgroup_subsys->populate()
cgroup: get rid of populate for memcg
cgroup: pass struct mem_cgroup instead of struct cgroup to socket memcg
cgroup: make css->refcnt clearing on cgroup removal optional
cgroup: use negative bias on css->refcnt to block css_tryget()
cgroup: implement cgroup_rm_cftypes()
cgroup: introduce struct cfent
cgroup: relocate __d_cgrp() and __d_cft()
cgroup: remove cgroup_add_file[s]()
cgroup: convert memcg controller to the new cftype interface
memcg: always create memsw files if CONFIG_CGROUP_MEM_RES_CTLR_SWAP
cgroup: convert all non-memcg controllers to the new cftype interface
cgroup: relocate cftype and cgroup_subsys definitions in controllers
cgroup: merge cft_release_agent cftype array into the base files array
cgroup: implement cgroup_add_cftypes() and friends
cgroup: build list of all cgroups under a given cgroupfs_root
cgroup: move cgroup_clear_directory() call out of cgroup_populate_dir()
These two functions do almost the same thing and duplicate some code.
Merge their implementation into a single common function.
res_counter_charge_locked() takes one more parameter but it doesn't seem
to be used outside res_counter.c yet anyway.
There is no (intended) change in the behaviour.
Acked-by: Glauber Costa <glommer@parallels.com>
In v3.3-rc1, the global LRU was removed in commit 925b7673cce3 ("mm:
make per-memcg LRU lists exclusive"). The patch fixes up the memcg
docs.
I left the swap session to someone who has better understanding of
'memory+swap'.
Signed-off-by: Ying Han <yinghan@google.com>
This has been obsolescent for a while, fix documentation and
misc comments.
Pull trivial tree from Jiri Kosina:
"It's indeed trivial -- mostly documentation updates and a bunch of
typo fixes from Masanari.
There are also several linux/version.h include removals from Jesper."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits)
kcore: fix spelling in read_kcore() comment
constify struct pci_dev * in obvious cases
Revert "char: Fix typo in viotape.c"
init: fix wording error in mm_init comment
usb: gadget: Kconfig: fix typo for 'different'
Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c"
writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header
writeback: fix typo in the writeback_control comment
Documentation: Fix multiple typo in Documentation
tpm_tis: fix tis_lock with respect to RCU
Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c"
Doc: Update numastat.txt
qla4xxx: Add missing spaces to error messages
compiler.h: Fix typo
security: struct security_operations kerneldoc fix
Documentation: broken URL in libata.tmpl
Documentation: broken URL in filesystems.tmpl
mtd: simplify return logic in do_map_probe()
mm: fix comment typo of truncate_inode_pages_range
power: bq27x00: Fix typos in comment
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
The argument is not used at all, and it's not necessary, because
a specific callback handler of course knows which subsys it
belongs to.
Now only ->pupulate() takes this argument, because the handlers of
this callback always call cgroup_add_file()/cgroup_add_files().
So we reduce a few lines of code, though the shrinking of object size
is minimal.
16 files changed, 113 insertions(+), 162 deletions(-)
5486240 656987 7039960 13183187 c928d3 vmlinux.o.orig
5486170 656987 7039960 13183117 c9288d vmlinux.o
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
