path: root/Documentation/cgroups
2015-06-26Merge branch 'for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - threadgroup_lock got reorganized so that its users can pick the actual locking mechanism to use. Its only user - cgroups - is updated to use a percpu_rwsem instead of per-process rwsem. This makes things a bit lighter on hot paths and allows cgroups to perform and fail multi-task (a process) migrations atomically. Multi-task migrations are used in several places including the unified hierarchy. - Delegation rule and documentation added to unified hierarchy. This will likely be the last interface update from the cgroup core side for unified hierarchy before lifting the devel mask. - Some groundwork for the pids controller which is scheduled to be merged in the coming devel cycle. * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: add delegation section to unified hierarchy documentation cgroup: require write perm on common ancestor when moving processes on the default hierarchy cgroup: separate out cgroup_procs_write_permission() from __cgroup_procs_write() kernfs: make kernfs_get_inode() public MAINTAINERS: add a cgroup core co-maintainer cgroup: fix uninitialised iterator in for_each_subsys_which cgroup: replace explicit ss_mask checking with for_each_subsys_which cgroup: use bitmask to filter for_each_subsys cgroup: add seq_file forward declaration for struct cftype cgroup: simplify threadgroup locking sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem sched, cgroup: reorganize threadgroup locking cgroup: switch to unsigned long for bitmasks cgroup: reorganize include/linux/cgroup.h cgroup: separate out include/linux/cgroup-defs.h cgroup: fix some comment typos
2015-06-18cgroup: add delegation section to unified hierarchy documentationTejun Heo
v2: Rearranged paragraphs as suggested by Johannes Weiner. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org>
2015-06-17writeback, blkio: add documentation for cgroup writeback supportTejun Heo
Update Documentation/cgroups/blkio-controller.txt to reflect the recently added cgroup writeback support. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: cgroups@vger.kernel.org Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02memcg: add per cgroup dirty page accountingGreg Thelen
When modifying PG_Dirty on cached file pages, update the new MEM_CGROUP_STAT_DIRTY counter. This is done in the same places where global NR_FILE_DIRTY is managed. The new memcg stat is visible in the per memcg memory.stat cgroupfs file. The most recent past attempt at this was http://thread.gmane.org/gmane.linux.kernel.cgroups/8632 The new accounting supports future efforts to add per cgroup dirty page throttling and writeback. It also helps an administrator break down a container's memory usage and provides evidence to understand memcg oom kills (the new dirty count is included in memcg oom kill messages). The ability to move page accounting between memcg (memory.move_charge_at_immigrate) makes this accounting more complicated than the global counter. The existing mem_cgroup_{begin,end}_page_stat() lock is used to serialize move accounting with stat updates. Typical update operation: memcg = mem_cgroup_begin_page_stat(page) if (TestSetPageDirty()) { [...] mem_cgroup_update_page_stat(memcg) } mem_cgroup_end_page_stat(memcg) Summary of mem_cgroup_end_page_stat() overhead: - Without CONFIG_MEMCG it's a no-op - With CONFIG_MEMCG and no inter memcg task movement, it's just rcu_read_lock() - With CONFIG_MEMCG and inter memcg task movement, it's rcu_read_lock() + spin_lock_irqsave() A memcg parameter is added to several routines because their callers now grab mem_cgroup_begin_page_stat() which returns the memcg later needed by for mem_cgroup_update_page_stat(). Because mem_cgroup_begin_page_stat() may disable interrupts, some adjustments are needed: - move __mark_inode_dirty() from __set_page_dirty() to its caller. __mark_inode_dirty() locking does not want interrupts disabled. - use spin_lock_irqsave(tree_lock) rather than spin_lock_irq() in __delete_from_page_cache(), replace_page_cache_page(), invalidate_complete_page2(), and __remove_mapping(). text data bss dec hex filename 8925147 1774832 1785856 12485835 be84cb vmlinux-!CONFIG_MEMCG-before 8925339 1774832 1785856 12486027 be858b vmlinux-!CONFIG_MEMCG-after +192 text bytes 8965977 1784992 1785856 12536825 bf4bf9 vmlinux-CONFIG_MEMCG-before 8966750 1784992 1785856 12537598 bf4efe vmlinux-CONFIG_MEMCG-after +773 text bytes Performance tests run on v4.0-rc1-36-g4f671fe2f952. Lower is better for all metrics, they're all wall clock or cycle counts. The read and write fault benchmarks just measure fault time, they do not include I/O time. * CONFIG_MEMCG not set: baseline patched kbuild 1m25.030000(+-0.088% 3 samples) 1m25.426667(+-0.120% 3 samples) dd write 100 MiB 0.859211561 +-15.10% 0.874162885 +-15.03% dd write 200 MiB 1.670653105 +-17.87% 1.669384764 +-11.99% dd write 1000 MiB 8.434691190 +-14.15% 8.474733215 +-14.77% read fault cycles 254.0(+-0.000% 10 samples) 253.0(+-0.000% 10 samples) write fault cycles 2021.2(+-3.070% 10 samples) 1984.5(+-1.036% 10 samples) * CONFIG_MEMCG=y root_memcg: baseline patched kbuild 1m25.716667(+-0.105% 3 samples) 1m25.686667(+-0.153% 3 samples) dd write 100 MiB 0.855650830 +-14.90% 0.887557919 +-14.90% dd write 200 MiB 1.688322953 +-12.72% 1.667682724 +-13.33% dd write 1000 MiB 8.418601605 +-14.30% 8.673532299 +-15.00% read fault cycles 266.0(+-0.000% 10 samples) 266.0(+-0.000% 10 samples) write fault cycles 2051.7(+-1.349% 10 samples) 2049.6(+-1.686% 10 samples) * CONFIG_MEMCG=y non-root_memcg: baseline patched kbuild 1m26.120000(+-0.273% 3 samples) 1m25.763333(+-0.127% 3 samples) dd write 100 MiB 0.861723964 +-15.25% 0.818129350 +-14.82% dd write 200 MiB 1.669887569 +-13.30% 1.698645885 +-13.27% dd write 1000 MiB 8.383191730 +-14.65% 8.351742280 +-14.52% read fault cycles 265.7(+-0.172% 10 samples) 267.0(+-0.000% 10 samples) write fault cycles 2070.6(+-1.512% 10 samples) 2084.4(+-2.148% 10 samples) As expected anon page faults are not affected by this patch. tj: Updated to apply on top of the recent cancel_dirty_page() changes. Signed-off-by: Sha Zhengju <handai.szj@gmail.com> Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-04-18Merge tag 'docs-for-linus' of git://git.lwn.net/linux-2.6Linus Torvalds
Pull documentation updates from Jonathan Corbet: "Numerous fixes, the overdue removal of the i2o docs, some new Chinese translations, and, hopefully, the README fix that will end the flow of identical patches to that file" * tag 'docs-for-linus' of git://git.lwn.net/linux-2.6: (34 commits) Documentation/memcg: update memcg/kmem status Documentation: blackfin: Makefile: Typo building issue Documentation/vm/pagemap.txt: correct location of page-types tool Documentation/memory-barriers.txt: typo fix doc: Add guest_nice column to example output of `cat /proc/stat' Documentation/kernel-parameters: Move "eagerfpu" to its right place Documentation: gpio: Update ACPI part of the document to mention _DSD docs/completion.txt: Various tweaks and corrections doc: completion: context, scope and language fixes Documentation:Update Documentation/zh_CN/arm64/memory.txt Documentation:Update Documentation/zh_CN/arm64/booting.txt Documentation: Chinese translation of arm64/legacy_instructions.txt DocBook media: fix broken EIA hyperlink Documentation: tweak the maintainers entry README: Change gzip/bzip2 to xz compression format README: Update version number reference doc:pci: Fix typo in Documentation/PCI Documentation: drm: Use '->' when describing access through pointers. Documentation: Remove mentioning of block barriers Documentation/email-clients.txt: Fix one grammar mistake, add extra info about TB ...
2015-04-13Merge branch 'for-4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "Nothing too interesting. Rik made cpuset cooperate better with isolcpus and there are several other cleanup patches" * 'for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cpuset, isolcpus: document relationship between cpusets & isolcpus cpusets, isolcpus: exclude isolcpus from load balancing in cpusets sched, isolcpu: make cpu_isolated_map visible outside scheduler cpuset: initialize cpuset a bit early cgroup: Use kvfree in pidlist_free() cgroup: call cgroup_subsys->bind on cgroup subsys initialization
2015-04-11Documentation/memcg: update memcg/kmem statusVladimir Davydov
Memcg/kmem reclaim support has been finally merged. Reflect this in the documentation. Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-03-19cpuset, isolcpus: document relationship between cpusets & isolcpusRik van Riel
Document the subtly changed relationship between cpusets and isolcpus. Turns out the old documentation did not match the code... Signed-off-by: Rik van Riel <riel@redhat.com> Suggested-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-02-28mm: memcontrol: use "max" instead of "infinity" in control knobsJohannes Weiner
The memcg control knobs indicate the highest possible value using the symbolic name "infinity", which is long and awkward to type. Switch to the string "max", which is just as descriptive but shorter and sweeter. This changes a user interface, so do it before the release and before the development flag is dropped from the default hierarchy. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: memcontrol: default hierarchy interface for memoryJohannes Weiner
Introduce the basic control files to account, partition, and limit memory using cgroups in default hierarchy mode. This interface versioning allows us to address fundamental design issues in the existing memory cgroup interface, further explained below. The old interface will be maintained indefinitely, but a clearer model and improved workload performance should encourage existing users to switch over to the new one eventually. The control files are thus: - memory.current shows the current consumption of the cgroup and its descendants, in bytes. - memory.low configures the lower end of the cgroup's expected memory consumption range. The kernel considers memory below that boundary to be a reserve - the minimum that the workload needs in order to make forward progress - and generally avoids reclaiming it, unless there is an imminent risk of entering an OOM situation. - memory.high configures the upper end of the cgroup's expected memory consumption range. A cgroup whose consumption grows beyond this threshold is forced into direct reclaim, to work off the excess and to throttle new allocations heavily, but is generally allowed to continue and the OOM killer is not invoked. - memory.max configures the hard maximum amount of memory that the cgroup is allowed to consume before the OOM killer is invoked. - memory.events shows event counters that indicate how often the cgroup was reclaimed while below memory.low, how often it was forced to reclaim excess beyond memory.high, how often it hit memory.max, and how often it entered OOM due to memory.max. This allows users to identify configuration problems when observing a degradation in workload performance. An overcommitted system will have an increased rate of low boundary breaches, whereas increased rates of high limit breaches, maximum hits, or even OOM situations will indicate internally overcommitted cgroups. For existing users of memory cgroups, the following deviations from the current interface are worth pointing out and explaining: - The original lower boundary, the soft limit, is defined as a limit that is per default unset. As a result, the set of cgroups that global reclaim prefers is opt-in, rather than opt-out. The costs for optimizing these mostly negative lookups are so high that the implementation, despite its enormous size, does not even provide the basic desirable behavior. First off, the soft limit has no hierarchical meaning. All configured groups are organized in a global rbtree and treated like equal peers, regardless where they are located in the hierarchy. This makes subtree delegation impossible. Second, the soft limit reclaim pass is so aggressive that it not just introduces high allocation latencies into the system, but also impacts system performance due to overreclaim, to the point where the feature becomes self-defeating. The memory.low boundary on the other hand is a top-down allocated reserve. A cgroup enjoys reclaim protection when it and all its ancestors are below their low boundaries, which makes delegation of subtrees possible. Secondly, new cgroups have no reserve per default and in the common case most cgroups are eligible for the preferred reclaim pass. This allows the new low boundary to be efficiently implemented with just a minor addition to the generic reclaim code, without the need for out-of-band data structures and reclaim passes. Because the generic reclaim code considers all cgroups except for the ones running low in the preferred first reclaim pass, overreclaim of individual groups is eliminated as well, resulting in much better overall workload performance. - The original high boundary, the hard limit, is defined as a strict limit that can not budge, even if the OOM killer has to be called. But this generally goes against the goal of making the most out of the available memory. The memory consumption of workloads varies during runtime, and that requires users to overcommit. But doing that with a strict upper limit requires either a fairly accurate prediction of the working set size or adding slack to the limit. Since working set size estimation is hard and error prone, and getting it wrong results in OOM kills, most users tend to err on the side of a looser limit and end up wasting precious resources. The memory.high boundary on the other hand can be set much more conservatively. When hit, it throttles allocations by forcing them into direct reclaim to work off the excess, but it never invokes the OOM killer. As a result, a high boundary that is chosen too aggressively will not terminate the processes, but instead it will lead to gradual performance degradation. The user can monitor this and make corrections until the minimal memory footprint that still gives acceptable performance is found. In extreme cases, with many concurrent allocations and a complete breakdown of reclaim progress within the group, the high boundary can be exceeded. But even then it's mostly better to satisfy the allocation from the slack available in other groups or the rest of the system than killing the group. Otherwise, memory.max is there to limit this type of spillover and ultimately contain buggy or even malicious applications. - The original control file names are unwieldy and inconsistent in many different ways. For example, the upper boundary hit count is exported in the memory.failcnt file, but an OOM event count has to be manually counted by listening to memory.oom_control events, and lower boundary / soft limit events have to be counted by first setting a threshold for that value and then counting those events. Also, usage and limit files encode their units in the filename. That makes the filenames very long, even though this is not information that a user needs to be reminded of every time they type out those names. To address these naming issues, as well as to signal clearly that the new interface carries a new configuration model, the naming conventions in it necessarily differ from the old interface. - The original limit files indicate the state of an unset limit with a very high number, and a configured limit can be unset by echoing -1 into those files. But that very high number is implementation and architecture dependent and not very descriptive. And while -1 can be understood as an underflow into the highest possible value, -2 or -10M etc. do not work, so it's not inconsistent. memory.low, memory.high, and memory.max will use the string "infinity" to indicate and set the highest possible value. [akpm@linux-foundation.org: use seq_puts() for basic strings] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Greg Thelen <gthelen@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-05Update of Documentation/cgroups/00-INDEXHenrik Austad
unified-hierarchy.txt was added by 65731578 (cgroup: add documentation about unified hierarchy) Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: cgroups@vger.kernel.org Cc: linux-doc@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Henrik Austad <henrik@austad.us> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-12-13Merge branch 'akpm' (second patch-bomb from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - the rest of MM - misc fs fixes - add execveat() syscall - new ratelimit feature for fault-injection - decompressor updates - ipc/ updates - fallocate feature creep - fsnotify cleanups - a few other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (99 commits) cgroups: Documentation: fix trivial typos and wrong paragraph numberings parisc: percpu: update comments referring to __get_cpu_var percpu: update local_ops.txt to reflect this_cpu operations percpu: remove __get_cpu_var and __raw_get_cpu_var macros fsnotify: remove destroy_list from fsnotify_mark fsnotify: unify inode and mount marks handling fallocate: create FAN_MODIFY and IN_MODIFY events mm/cma: make kmemleak ignore CMA regions slub: fix cpuset check in get_any_partial slab: fix cpuset check in fallback_alloc shmdt: use i_size_read() instead of ->i_size ipc/shm.c: fix overly aggressive shmdt() when calls span multiple segments ipc/msg: increase MSGMNI, remove scaling ipc/sem.c: increase SEMMSL, SEMMNI, SEMOPM ipc/sem.c: change memory barrier in sem_lock() to smp_rmb() lib/decompress.c: consistency of compress formats for kernel image decompress_bunzip2: off by one in get_next_block() usr/Kconfig: make initrd compression algorithm selection not expert fault-inject: add ratelimit option ratelimit: add initialization macro ...
2014-12-13cgroups: Documentation: fix trivial typos and wrong paragraph numberingsSeongJae Park
Signed-off-by: SeongJae Park <sj38.park@gmail.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-12Merge tag 'docs-for-linus' of git://git.lwn.net/linux-2.6Linus Torvalds
Pull documentation update from Jonathan Corbet: "Here's my set of accumulated documentation changes for 3.19. It includes a couple of additions to the coding style document, some fixes for minor build problems within the documentation tree, the relocation of the kselftest docs, and various tweaks and additions. A couple of changes reach outside of Documentation/; they only make trivial comment changes and I did my best to get the required acks. Complete with a shiny signed tag this time around" * tag 'docs-for-linus' of git://git.lwn.net/linux-2.6: kobject: grammar fix Input: xpad - update docs to reflect current state Documentation: Build mic/mpssd only for x86_64 cgroups: Documentation: fix wrong cgroupfs paths Documentation/email-clients.txt: add info about Claws Mail CodingStyle: add some more error handling guidelines kselftest: Move the docs to the Documentation dir Documentation: fix formatting to make 's' happy Documentation: power: Fix typo in Documentation/power Documentation: vm: Add 1GB large page support information ipv4: add kernel parameter tcpmhash_entries Documentation: Fix a typo in mailbox.txt treewide: Fix typo in Documentation/DocBook/device-drivers CodingStyle: Add a chapter on conditional compilation
2014-12-10mm: embed the memcg pointer directly into struct pageJohannes Weiner
Memory cgroups used to have 5 per-page pointers. To allow users to disable that amount of overhead during runtime, those pointers were allocated in a separate array, with a translation layer between them and struct page. There is now only one page pointer remaining: the memcg pointer, that indicates which cgroup the page is associated with when charged. The complexity of runtime allocation and the runtime translation overhead is no longer justified to save that *potential* 0.19% of memory. With CONFIG_SLUB, page->mem_cgroup actually sits in the doubleword padding after the page->private member and doesn't even increase struct page, and then this patch actually saves space. Remaining users that care can still compile their kernels without CONFIG_MEMCG. text data bss dec hex filename 8828345 1725264 983040 11536649 b00909 vmlinux.old 8827425 1725264 966656 11519345 afc571 vmlinux.new [mhocko@suse.cz: update Documentation/cgroups/memory.txt] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vladimir Davydov <vdavydov@parallels.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10kernel: res_counter: remove the unused APIJohannes Weiner
All memory accounting and limiting has been switched over to the lockless page counters. Bye, res_counter! [akpm@linux-foundation.org: update Documentation/cgroups/memory.txt] [mhocko@suse.cz: ditch the last remainings of res_counter] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vladimir Davydov <vdavydov@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10mm: hugetlb_cgroup: convert to lockless page countersJohannes Weiner
Abandon the spinlock-protected byte counters in favor of the unlocked page counters in the hugetlb controller as well. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Vladimir Davydov <vdavydov@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10mm: memcontrol: lockless page countersJohannes Weiner
Memory is internally accounted in bytes, using spinlock-protected 64-bit counters, even though the smallest accounting delta is a page. The counter interface is also convoluted and does too many things. Introduce a new lockless word-sized page counter API, then change all memory accounting over to it. The translation from and to bytes then only happens when interfacing with userspace. The removed locking overhead is noticable when scaling beyond the per-cpu charge caches - on a 4-socket machine with 144-threads, the following test shows the performance differences of 288 memcgs concurrently running a page fault benchmark: vanilla: 18631648.500498 task-clock (msec) # 140.643 CPUs utilized ( +- 0.33% ) 1,380,638 context-switches # 0.074 K/sec ( +- 0.75% ) 24,390 cpu-migrations # 0.001 K/sec ( +- 8.44% ) 1,843,305,768 page-faults # 0.099 M/sec ( +- 0.00% ) 50,134,994,088,218 cycles # 2.691 GHz ( +- 0.33% ) <not supported> stalled-cycles-frontend <not supported> stalled-cycles-backend 8,049,712,224,651 instructions # 0.16 insns per cycle ( +- 0.04% ) 1,586,970,584,979 branches # 85.176 M/sec ( +- 0.05% ) 1,724,989,949 branch-misses # 0.11% of all branches ( +- 0.48% ) 132.474343877 seconds time elapsed ( +- 0.21% ) lockless: 12195979.037525 task-clock (msec) # 133.480 CPUs utilized ( +- 0.18% ) 832,850 context-switches # 0.068 K/sec ( +- 0.54% ) 15,624 cpu-migrations # 0.001 K/sec ( +- 10.17% ) 1,843,304,774 page-faults # 0.151 M/sec ( +- 0.00% ) 32,811,216,801,141 cycles # 2.690 GHz ( +- 0.18% ) <not supported> stalled-cycles-frontend <not supported> stalled-cycles-backend 9,999,265,091,727 instructions # 0.30 insns per cycle ( +- 0.10% ) 2,076,759,325,203 branches # 170.282 M/sec ( +- 0.12% ) 1,656,917,214 branch-misses # 0.08% of all branches ( +- 0.55% ) 91.369330729 seconds time elapsed ( +- 0.45% ) On top of improved scalability, this also gets rid of the icky long long types in the very heart of memcg, which is great for 32 bit and also makes the code a lot more readable. Notable differences between the old and new API: - res_counter_charge() and res_counter_charge_nofail() become page_counter_try_charge() and page_counter_charge() resp. to match the more common kernel naming scheme of try_do()/do() - res_counter_uncharge_until() is only ever used to cancel a local counter and never to uncharge bigger segments of a hierarchy, so it's replaced by the simpler page_counter_cancel() - res_counter_set_limit() is replaced by page_counter_limit(), which expects its callers to serialize against themselves - res_counter_memparse_write_strategy() is replaced by page_counter_limit(), which rounds down to the nearest page size - rather than up. This is more reasonable for explicitely requested hard upper limits. - to keep charging light-weight, page_counter_try_charge() charges speculatively, only to roll back if the result exceeds the limit. Because of this, a failing bigger charge can temporarily lock out smaller charges that would otherwise succeed. The error is bounded to the difference between the smallest and the biggest possible charge size, so for memcg, this means that a failing THP charge can send base page charges into reclaim upto 2MB (4MB) before the limit would have been reached. This should be acceptable. [akpm@linux-foundation.org: add includes for WARN_ON_ONCE and memparse] [akpm@linux-foundation.org: add includes for WARN_ON_ONCE, memparse, strncmp, and PAGE_SIZE] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03cgroups: Documentation: fix wrong cgroupfs pathsSeongJae Park
Few paths used as example to describe cgroupfs usage have been wrong from f6e07d38078e ("Documentation: update cgroupfs mount point") by mistake. This patch fix those trivial wrong paths. Signed-off-by: SeongJae Park <sj38.park@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2014-09-24cpuset: PF_SPREAD_PAGE and PF_SPREAD_SLAB should be atomic flagsZefan Li
When we change cpuset.memory_spread_{page,slab}, cpuset will flip PF_SPREAD_{PAGE,SLAB} bit of tsk->flags for each task in that cpuset. This should be done using atomic bitops, but currently we don't, which is broken. Tetsuo reported a hard-to-reproduce kernel crash on RHEL6, which happened when one thread tried to clear PF_USED_MATH while at the same time another thread tried to flip PF_SPREAD_PAGE/PF_SPREAD_SLAB. They both operate on the same task. Here's the full report: https://lkml.org/lkml/2014/9/19/230 To fix this, we make PF_SPREAD_PAGE and PF_SPREAD_SLAB atomic flags. v4: - updated mm/slab.c. (Fengguang Wu) - updated Documentation. Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: Kees Cook <keescook@chromium.org> Fixes: 950592f7b991 ("cpusets: update tasks' page/slab spread flags in time") Cc: <stable@vger.kernel.org> # 2.6.31+ Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-08-08mm: memcontrol: rewrite uncharge APIJohannes Weiner
The memcg uncharging code that is involved towards the end of a page's lifetime - truncation, reclaim, swapout, migration - is impressively complicated and fragile. Because anonymous and file pages were always charged before they had their page->mapping established, uncharges had to happen when the page type could still be known from the context; as in unmap for anonymous, page cache removal for file and shmem pages, and swap cache truncation for swap pages. However, these operations happen well before the page is actually freed, and so a lot of synchronization is necessary: - Charging, uncharging, page migration, and charge migration all need to take a per-page bit spinlock as they could race with uncharging. - Swap cache truncation happens during both swap-in and swap-out, and possibly repeatedly before the page is actually freed. This means that the memcg swapout code is called from many contexts that make no sense and it has to figure out the direction from page state to make sure memory and memory+swap are always correctly charged. - On page migration, the old page might be unmapped but then reused, so memcg code has to prevent untimely uncharging in that case. Because this code - which should be a simple charge transfer - is so special-cased, it is not reusable for replace_page_cache(). But now that charged pages always have a page->mapping, introduce mem_cgroup_uncharge(), which is called after the final put_page(), when we know for sure that nobody is looking at the page anymore. For page migration, introduce mem_cgroup_migrate(), which is called after the migration is successful and the new page is fully rmapped. Because the old page is no longer uncharged after migration, prevent double charges by decoupling the page's memcg association (PCG_USED and pc->mem_cgroup) from the page holding an actual charge. The new bits PCG_MEM and PCG_MEMSW represent the respective charges and are transferred to the new page during migration. mem_cgroup_migrate() is suitable for replace_page_cache() as well, which gets rid of mem_cgroup_replace_page_cache(). However, care needs to be taken because both the source and the target page can already be charged and on the LRU when fuse is splicing: grab the page lock on the charge moving side to prevent changing pc->mem_cgroup of a page under migration. Also, the lruvecs of both pages change as we uncharge the old and charge the new during migration, and putback may race with us, so grab the lru lock and isolate the pages iff on LRU to prevent races and ensure the pages are on the right lruvec afterward. Swap accounting is massively simplified: because the page is no longer uncharged as early as swap cache deletion, a new mem_cgroup_swapout() can transfer the page's memory+swap charge (PCG_MEMSW) to the swap entry before the final put_page() in page reclaim. Finally, page_cgroup changes are now protected by whatever protection the page itself offers: anonymous pages are charged under the page table lock, whereas page cache insertions, swapin, and migration hold the page lock. Uncharging happens under full exclusion with no outstanding references. Charging and uncharging also ensure that the page is off-LRU, which serializes against charge migration. Remove the very costly page_cgroup lock and set pc->flags non-atomically. [mhocko@suse.cz: mem_cgroup_charge_statistics needs preempt_disable] [vdavydov@parallels.com: fix flags definition] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Tested-by: Jet Chen <jet.chen@intel.com> Acked-by: Michal Hocko <mhocko@suse.cz> Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08mm: memcontrol: rewrite charge APIJohannes Weiner
These patches rework memcg charge lifetime to integrate more naturally with the lifetime of user pages. This drastically simplifies the code and reduces charging and uncharging overhead. The most expensive part of charging and uncharging is the page_cgroup bit spinlock, which is removed entirely after this series. Here are the top-10 profile entries of a stress test that reads a 128G sparse file on a freshly booted box, without even a dedicated cgroup (i.e. executing in the root memcg). Before: 15.36% cat [kernel.kallsyms] [k] copy_user_generic_string 13.31% cat [kernel.kallsyms] [k] memset 11.48% cat [kernel.kallsyms] [k] do_mpage_readpage 4.23% cat [kernel.kallsyms] [k] get_page_from_freelist 2.38% cat [kernel.kallsyms] [k] put_page 2.32% cat [kernel.kallsyms] [k] __mem_cgroup_commit_charge 2.18% kswapd0 [kernel.kallsyms] [k] __mem_cgroup_uncharge_common 1.92% kswapd0 [kernel.kallsyms] [k] shrink_page_list 1.86% cat [kernel.kallsyms] [k] __radix_tree_lookup 1.62% cat [kernel.kallsyms] [k] __pagevec_lru_add_fn After: 15.67% cat [kernel.kallsyms] [k] copy_user_generic_string 13.48% cat [kernel.kallsyms] [k] memset 11.42% cat [kernel.kallsyms] [k] do_mpage_readpage 3.98% cat [kernel.kallsyms] [k] get_page_from_freelist 2.46% cat [kernel.kallsyms] [k] put_page 2.13% kswapd0 [kernel.kallsyms] [k] shrink_page_list 1.88% cat [kernel.kallsyms] [k] __radix_tree_lookup 1.67% cat [kernel.kallsyms] [k] __pagevec_lru_add_fn 1.39% kswapd0 [kernel.kallsyms] [k] free_pcppages_bulk 1.30% cat [kernel.kallsyms] [k] kfree As you can see, the memcg footprint has shrunk quite a bit. text data bss dec hex filename 37970 9892 400 48262 bc86 mm/memcontrol.o.old 35239 9892 400 45531 b1db mm/memcontrol.o This patch (of 4): The memcg charge API charges pages before they are rmapped - i.e. have an actual "type" - and so every callsite needs its own set of charge and uncharge functions to know what type is being operated on. Worse, uncharge has to happen from a context that is still type-specific, rather than at the end of the page's lifetime with exclusive access, and so requires a lot of synchronization. Rewrite the charge API to provide a generic set of try_charge(), commit_charge() and cancel_charge() transaction operations, much like what's currently done for swap-in: mem_cgroup_try_charge() attempts to reserve a charge, reclaiming pages from the memcg if necessary. mem_cgroup_commit_charge() commits the page to the charge once it has a valid page->mapping and PageAnon() reliably tells the type. mem_cgroup_cancel_charge() aborts the transaction. This reduces the charge API and enables subsequent patches to drastically simplify uncharging. As pages need to be committed after rmap is established but before they are added to the LRU, page_add_new_anon_rmap() must stop doing LRU additions again. Revive lru_cache_add_active_or_unevictable(). [hughd@google.com: fix shmem_unuse] [hughd@google.com: Add comments on the private use of -EAGAIN] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-15cgroup: distinguish the default and legacy hierarchies when handling cftypesTejun Heo
Until now, cftype arrays carried files for both the default and legacy hierarchies and the files which needed to be used on only one of them were flagged with either CFTYPE_ONLY_ON_DFL or CFTYPE_INSANE. This gets confusing very quickly and we may end up exposing interface files to the default hierarchy without thinking it through. This patch makes cgroup core provide separate sets of interfaces for cftype handling so that the cftypes for the default and legacy hierarchies are clearly distinguished. The previous two patches renamed the existing ones so that they clearly indicate that they're for the legacy hierarchies. This patch adds the interface for the default hierarchy and apply them selectively depending on the hierarchy type. * cftypes added through cgroup_subsys->dfl_cftypes and cgroup_add_dfl_cftypes() only show up on the default hierarchy. * cftypes added through cgroup_subsys->legacy_cftypes and cgroup_add_legacy_cftypes() only show up on the legacy hierarchies. * cgroup_subsys->dfl_cftypes and ->legacy_cftypes can point to the same array for the cases where the interface files are identical on both types of hierarchies. * This makes all the existing subsystem interface files legacy-only by default and all subsystems will have no interface file created when enabled on the default hierarchy. Each subsystem should explicitly review and compose the interface for the default hierarchy. * A boot param "cgroup__DEVEL__legacy_files_on_dfl" is added which makes subsystems which haven't decided the interface files for the default hierarchy to present the legacy files on the default hierarchy so that its behavior on the default hierarchy can be tested. As the awkward name suggests, this is for development only. * memcg's CFTYPE_INSANE on "use_hierarchy" is noop now as the whole array isn't used on the default hierarchy. The flag is removed. v2: Updated documentation for cgroup__DEVEL__legacy_files_on_dfl. v3: Clear CFTYPE_ONLY_ON_DFL and CFTYPE_INSANE when cfts are removed as suggested by Li. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Aristeu Rozanski <aris@redhat.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2014-07-08cgroup: implement cgroup_subsys->depends_onTejun Heo
Currently, the blkio subsystem attributes all of writeback IOs to the root. One of the issues is that there's no way to tell who originated a writeback IO from block layer. Those IOs are usually issued asynchronously from a task which didn't have anything to do with actually generating the dirty pages. The memory subsystem, when enabled, already keeps track of the ownership of each dirty page and it's desirable for blkio to piggyback instead of adding its own per-page tag. blkio piggybacking on memory is an implementation detail which preferably should be handled automatically without requiring explicit userland action. To achieve that, this patch implements cgroup_subsys->depends_on which contains the mask of subsystems which should be enabled together when the subsystem is enabled. The previous patches already implemented the support for enabled but invisible subsystems and cgroup_subsys->depends_on can be easily implemented by updating cgroup_refresh_child_subsys_mask() so that it calculates cgroup->child_subsys_mask considering cgroup_subsys->depends_on of the explicitly enabled subsystems. Documentation/cgroups/unified-hierarchy.txt is updated to explain that subsystems may not become immediately available after being unused from userland and that dependency could be a factor in it. As subsystems may already keep residual references, this doesn't significantly change how subsystem rebinding can be used. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org>
2014-07-08cgroup: implement cgroup_subsys->css_reset()Tejun Heo
cgroup is implementing support for subsystem dependency which would require a way to enable a subsystem even when it's not directly configured through "cgroup.subtree_control". The previous patches added support for explicitly and implicitly enabled subsystems and showing/hiding their interface files. An explicitly enabled subsystem may become implicitly enabled if it's turned off through "cgroup.subtree_control" but there are subsystems depending on it. In such cases, the subsystem, as it's turned off when seen from userland, shouldn't enforce any resource control. Also, the subsystem may be explicitly turned on later again and its interface files should be as close to the intial state as possible. This patch adds cgroup_subsys->css_reset() which is invoked when a css is hidden. The callback should disable resource control and reset the state to the vanilla state. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org>
2014-06-09Merge branch 'for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot of activities on cgroup side. Heavy restructuring including locking simplification took place to improve the code base and enable implementation of the unified hierarchy, which currently exists behind a __DEVEL__ mount option. The core support is mostly complete but individual controllers need further work. To explain the design and rationales of the the unified hierarchy Documentation/cgroups/unified-hierarchy.txt is added. Another notable change is css (cgroup_subsys_state - what each controller uses to identify and interact with a cgroup) iteration update. This is part of continuing updates on css object lifetime and visibility. cgroup started with reference count draining on removal way back and is now reaching a point where csses behave and are iterated like normal refcnted objects albeit with some complexities to allow distinguishing the state where they're being deleted. The css iteration update isn't taken advantage of yet but is planned to be used to simplify memcg significantly" * 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (77 commits) cgroup: disallow disabled controllers on the default hierarchy cgroup: don't destroy the default root cgroup: disallow debug controller on the default hierarchy cgroup: clean up MAINTAINERS entries cgroup: implement css_tryget() device_cgroup: use css_has_online_children() instead of has_children() cgroup: convert cgroup_has_live_children() into css_has_online_children() cgroup: use CSS_ONLINE instead of CGRP_DEAD cgroup: iterate cgroup_subsys_states directly cgroup: introduce CSS_RELEASED and reduce css iteration fallback window cgroup: move cgroup->serial_nr into cgroup_subsys_state cgroup: link all cgroup_subsys_states in their sibling lists cgroup: move cgroup->sibling and ->children into cgroup_subsys_state cgroup: remove cgroup->parent device_cgroup: remove direct access to cgroup->children memcg: update memcg_has_children() to use css_next_child() memcg: remove tasks/children test from mem_cgroup_force_empty() cgroup: remove css_parent() cgroup: skip refcnting on normal root csses and cgrp_dfl_root self css cgroup: use cgroup->self.refcnt for cgroup refcnting ...
2014-06-06vmscan: memcg: always use swappiness of the reclaimed memcgMichal Hocko
Memory reclaim always uses swappiness of the reclaim target memcg (origin of the memory pressure) or vm_swappiness for global memory reclaim. This behavior was consistent (except for difference between global and hard limit reclaim) because swappiness was enforced to be consistent within each memcg hierarchy. After "mm: memcontrol: remove hierarchy restrictions for swappiness and oom_control" each memcg can have its own swappiness independent of hierarchical parents, though, so the consistency guarantee is gone. This can lead to an unexpected behavior. Say that a group is explicitly configured to not swapout by memory.swappiness=0 but its memory gets swapped out anyway when the memory pressure comes from its parent with a It is also unexpected that the knob is meaningless without setting the hard limit which would trigger the reclaim and enforce the swappiness. There are setups where the hard limit is configured higher in the hierarchy by an administrator and children groups are under control of somebody else who is interested in the swapout behavior but not necessarily about the memory limit. From a semantic point of view swappiness is an attribute defining anon vs. file proportional scanning of LRU which is memcg specific (unlike charges which are propagated up the hierarchy) so it should be applied to the particular memcg's LRU regardless where the memory pressure comes from. This patch removes vmscan_swappiness() and stores the swappiness into the scan_control structure. mem_cgroup_swappiness is then used to provide the correct value before shrink_lruvec is called. The global vm_swappiness is used for the root memcg. [hughd@google.com: oopses immediately when booted with cgroup_disable=memory] Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04Documentation/memcg: warn about incomplete kmemcg stateVladimir Davydov
Kmemcg is currently under development and lacks some important features. In particular, it does not have support of kmem reclaim on memory pressure inside cgroup, which practically makes it unusable in real life. Let's warn about it in both Kconfig and Documentation to prevent complaints arising. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm: memcontrol: remove hierarchy restrictions for swappiness and oom_controlJohannes Weiner
Per-memcg swappiness and oom killing can currently not be tweaked on a memcg that is part of a hierarchy, but not the root of that hierarchy. Users have complained that they can't configure this when they turned on hierarchy mode. In fact, with hierarchy mode becoming the default, this restriction disables the tunables entirely. But there is no good reason for this restriction. The settings for swappiness and OOM killing are taken from whatever memcg whose limit triggered reclaim and OOM invocation, regardless of its position in the hierarchy tree. Allow setting swappiness on any group. The knob on the root memcg already reads the global VM swappiness, make it writable as well. Allow disabling the OOM killer on any non-root memcg. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-16memcg: remove tasks/children test from mem_cgroup_force_empty()Michal Hocko
Tejun has correctly pointed out that tasks/children test in mem_cgroup_force_empty is not correct because there is no other locking which preserves this state throughout the rest of the function so both new tasks can join the group or new children groups can be added while somebody is writing to memory.force_empty. A new task would break mem_cgroup_reparent_charges expectation that all failures as described by mem_cgroup_force_empty_list are temporal and there is no way out. The main use case for the knob as described by Documentation/cgroups/memory.txt is to: " The typical use case for this interface is before calling rmdir(). Because rmdir() moves all pages to parent, some out-of-use page caches can be moved to the parent. If you want to avoid that, force_empty will be useful. " This means that reparenting is not really required as rmdir will reparent pages implicitly from the safe context. If we remove it from mem_cgroup_force_empty then we are safe even with existing tasks because the number of reclaim attempts is bounded. Moreover the knob still does what the documentation claims (modulo reparenting which doesn't make any difference) and users might expect. Longterm we want to deprecate the whole knob and put the reparented pages to the tail of parent LRU during cgroup removal. tj: Removed unused variable @cgrp from mem_cgroup_force_empty() Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-04-25cgroup: add documentation about unified hierarchyTejun Heo
Unified hierarchy will be the new version of cgroup interface. This patch adds Documentation/cgroups/unified-hierarchy.txt which describes the design and rationales of unified hierarchy. v2: Grammatical updates as per Randy Dunlap's review. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Randy Dunlap <rdunlap@infradead.org>
2014-04-07memcg: rename high level charging functionsMichal Hocko
mem_cgroup_newpage_charge is used only for charging anonymous memory so it is better to rename it to mem_cgroup_charge_anon. mem_cgroup_cache_charge is used for file backed memory so rename it to mem_cgroup_charge_file. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07res_counter: remove interface for locked charging and unchargingDavid Rientjes
The res_counter_{charge,uncharge}_locked() variants are not used in the kernel outside of the resource counter code itself, so remove the interface. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Tejun Heo <tj@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Tim Hockin <thockin@google.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - a new jpeg codec driver for Samsung Exynos (jpeg-hw-exynos4) - a new dvb frontend for ds2103 chipset (m88ds2103) - a new sensor driver for Samsung S5K5BAF UXGA (s5k5baf) - new drivers for R-Car VSP1 - a new radio driver: radio-raremono - a new tuner driver for ts2022 chipset (m88ts2022) - the analog part of em28xx is now a separate module that only load/runs if the device is not a pure digital TV device - added a staging driver for bcm2048 radio devices - the omap 2 video driver (omap24xx) was moved to staging. This driver is for an old hardware and uses a deprecated Kernel internal API. If nobody cares enough to fix it, it would be removed on a couple Kernel releases - the sn9c102 driver was moved to staging. This driver was replaced by gspca, and disabled on some distros, as almost all devices are known to work properly with gspca. It should be removed from kernel on a couple Kernel releases - lots of driver fixes, improvements and cleanups * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (421 commits) [media] media: v4l2-dev: fix video device index assignment [media] rc-core: reuse device numbers [media] em28xx-cards: properly initialize the device bitmap [media] Staging: media: Fix line length exceeding 80 characters in as102_drv.c [media] Staging: media: Fix line length exceeding 80 characters in as102_fe.c [media] Staging: media: Fix quoted string split across line in as102_fe.c [media] media: st-rc: Add reset support [media] m2m-deinterlace: fix allocated struct type [media] radio-usb-si4713: fix sparse non static symbol warnings [media] em28xx-audio: remove needless check before usb_free_coherent() [media] au0828: Fix sparse non static symbol warning Revert "[media] go7007-usb: only use go->dev after allocated" [media] em28xx-audio: provide an error code when URB submit fails [media] em28xx: fix check for audio only usb interfaces when changing the usb alternate setting [media] em28xx: fix usb alternate setting for analog and digital video endpoints > 0 [media] em28xx: make 'em28xx_ctrl_ops' static em28xx-alsa: Fix error patch for init/fini [media] em28xx-audio: flush work at .fini [media] drxk: remove the option to load firmware asynchronously [media] em28xx: adjust period size at runtime ...
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-03netfilter: x_tables: lightweight process control group matchingDaniel Borkmann
It would be useful e.g. in a server or desktop environment to have a facility in the notion of fine-grained "per application" or "per application group" firewall policies. Probably, users in the mobile, embedded area (e.g. Android based) with different security policy requirements for application groups could have great benefit from that as well. For example, with a little bit of configuration effort, an admin could whitelist well-known applications, and thus block otherwise unwanted "hard-to-track" applications like [1] from a user's machine. Blocking is just one example, but it is not limited to that, meaning we can have much different scenarios/policies that netfilter allows us than just blocking, e.g. fine grained settings where applications are allowed to connect/send traffic to, application traffic marking/conntracking, application-specific packet mangling, and so on. Implementation of PID-based matching would not be appropriate as they frequently change, and child tracking would make that even more complex and ugly. Cgroups would be a perfect candidate for accomplishing that as they associate a set of tasks with a set of parameters for one or more subsystems, in our case the netfilter subsystem, which, of course, can be combined with other cgroup subsystems into something more complex if needed. As mentioned, to overcome this constraint, such processes could be placed into one or multiple cgroups where different fine-grained rules can be defined depending on the application scenario, while e.g. everything else that is not part of that could be dropped (or vice versa), thus making life harder for unwanted processes to communicate to the outside world. So, we make use of cgroups here to track jobs and limit their resources in terms of iptables policies; in other words, limiting, tracking, etc what they are allowed to communicate. In our case we're working on outgoing traffic based on which local socket that originated from. Also, one doesn't even need to have an a-prio knowledge of the application internals regarding their particular use of ports or protocols. Matching is *extremly* lightweight as we just test for the sk_classid marker of sockets, originating from net_cls. net_cls and netfilter do not contradict each other; in fact, each construct can live as standalone or they can be used in combination with each other, which is perfectly fine, plus it serves Tejun's requirement to not introduce a new cgroups subsystem. Through this, we result in a very minimal and efficient module, and don't add anything except netfilter code. One possible, minimal usage example (many other iptables options can be applied obviously): 1) Configuring cgroups if not already done, e.g.: mkdir /sys/fs/cgroup/net_cls mount -t cgroup -o net_cls net_cls /sys/fs/cgroup/net_cls mkdir /sys/fs/cgroup/net_cls/0 echo 1 > /sys/fs/cgroup/net_cls/0/net_cls.classid (resp. a real flow handle id for tc) 2) Configuring netfilter (iptables-nftables), e.g.: iptables -A OUTPUT -m cgroup ! --cgroup 1 -j DROP 3) Running applications, e.g.: ping 208.67.222.222 <pid:1799> echo 1799 > /sys/fs/cgroup/net_cls/0/tasks 64 bytes from 208.67.222.222: icmp_seq=44 ttl=49 time=11.9 ms [...] ping 208.67.220.220 <pid:1804> ping: sendmsg: Operation not permitted [...] echo 1804 > /sys/fs/cgroup/net_cls/0/tasks 64 bytes from 208.67.220.220: icmp_seq=89 ttl=56 time=19.0 ms [...] Of course, real-world deployments would make use of cgroups user space toolsuite, or own custom policy daemons dynamically moving applications from/to various cgroups. [1] http://www.blackhat.com/presentations/bh-europe-06/bh-eu-06-biondi/bh-eu-06-biondi-up.pdf Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: cgroups@vger.kernel.org Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-12-31doc: cgroups: Fix typo in doc/cgroupsMasanari Iida
Correct spelling typo in memory.txt and resource_counter.txt Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-12-10[media] doc: no singingKees Cook
Stop that, stop that! You're not going to do a song while I'm here. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-22cgroup: Merge branch 'memcg_event' into for-3.14Tejun Heo
Merge v3.12 based patch series to move cgroup_event implementation to memcg into for-3.14. The following two commits cause a conflict in kernel/cgroup.c 2ff2a7d03bbe4 ("cgroup: kill css_id") 79bd9814e5ec9 ("cgroup, memcg: move cgroup_event implementation to memcg") Each patch removes a struct definition from kernel/cgroup.c. As the two are adjacent, they cause a context conflict. Easily resolved by removing both structs. Signed-off-by: Tejun Heo <tj@kernel.org>
2013-11-22memcg: rename cgroup_event to mem_cgroup_eventTejun Heo
cgroup_event is only available in memcg now. Let's brand it that way. While at it, add a comment encouraging deprecation of the feature and remove the respective section from cgroup documentation. This patch is cosmetic. v3: Typo update as per Li Zefan. v2: Index in cgroups.txt updated accordingly as suggested by Li Zefan. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.cz>
2013-11-13memcg: support hierarchical memory.numa_statsYing Han
The memory.numa_stat file was not hierarchical. Memory charged to the children was not shown in parent's numa_stat. This change adds the "hierarchical_" stats to the existing stats. The new hierarchical stats include the sum of all children's values in addition to the value of the memcg. Tested: Create cgroup a, a/b and run workload under b. The values of b are included in the "hierarchical_*" under a. $ cd /sys/fs/cgroup $ echo 1 > memory.use_hierarchy $ mkdir a a/b Run workload in a/b: $ (echo $BASHPID >> a/b/cgroup.procs && cat /some/file && bash) & The hierarchical_ fields in parent (a) show use of workload in a/b: $ cat a/memory.numa_stat total=0 N0=0 N1=0 N2=0 N3=0 file=0 N0=0 N1=0 N2=0 N3=0 anon=0 N0=0 N1=0 N2=0 N3=0 unevictable=0 N0=0 N1=0 N2=0 N3=0 hierarchical_total=908 N0=552 N1=317 N2=39 N3=0 hierarchical_file=850 N0=549 N1=301 N2=0 N3=0 hierarchical_anon=58 N0=3 N1=16 N2=39 N3=0 hierarchical_unevictable=0 N0=0 N1=0 N2=0 N3=0 $ cat a/b/memory.numa_stat total=908 N0=552 N1=317 N2=39 N3=0 file=850 N0=549 N1=301 N2=0 N3=0 anon=58 N0=3 N1=16 N2=39 N3=0 unevictable=0 N0=0 N1=0 N2=0 N3=0 hierarchical_total=908 N0=552 N1=317 N2=39 N3=0 hierarchical_file=850 N0=549 N1=301 N2=0 N3=0 hierarchical_anon=58 N0=3 N1=16 N2=39 N3=0 hierarchical_unevictable=0 N0=0 N1=0 N2=0 N3=0 Signed-off-by: Ying Han <yinghan@google.com> Signed-off-by: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12memcg: document cgroup dirty/writeback memory statisticsSha Zhengju
Signed-off-by: Sha Zhengju <handai.szj@taobao.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Greg Thelen <gthelen@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-11Merge branch 'for-3.11/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO updates from Jens Axboe: "Here are the core IO block bits for 3.11. It contains: - A tweak to the reserved tag logic from Jan, for weirdo devices with just 3 free tags. But for those it improves things substantially for random writes. - Periodic writeback fix from Jan. Marked for stable as well. - Fix for a race condition in IO scheduler switching from Jianpeng. - The hierarchical blk-cgroup support from Tejun. This is the grunt of the series. - blk-throttle fix from Vivek. Just a note that I'm in the middle of a relocation, whole family is flying out tomorrow. Hence I will be awal the remainder of this week, but back at work again on Monday the 15th. CC'ing Tejun, since any potential "surprises" will most likely be from the blk-cgroup work. But it's been brewing for a while and sitting in my tree and linux-next for a long time, so should be solid." * 'for-3.11/core' of git://git.kernel.dk/linux-block: (36 commits) elevator: Fix a race in elevator switching block: Reserve only one queue tag for sync IO if only 3 tags are available writeback: Fix periodic writeback after fs mount blk-throttle: implement proper hierarchy support blk-throttle: implement throtl_grp->has_rules[] blk-throttle: Account for child group's start time in parent while bio climbs up blk-throttle: add throtl_qnode for dispatch fairness blk-throttle: make throtl_pending_timer_fn() ready for hierarchy blk-throttle: make tg_dispatch_one_bio() ready for hierarchy blk-throttle: make blk_throtl_bio() ready for hierarchy blk-throttle: make blk_throtl_drain() ready for hierarchy blk-throttle: dispatch from throtl_pending_timer_fn() blk-throttle: implement dispatch looping blk-throttle: separate out throtl_service_queue->pending_timer from throtl_data->dispatch_work blk-throttle: set REQ_THROTTLED from throtl_charge_bio() and gate stats update with it blk-throttle: implement sq_to_tg(), sq_to_td() and throtl_log() blk-throttle: add throtl_service_queue->parent_sq blk-throttle: generalize update_disptime optimization in blk_throtl_bio() blk-throttle: dispatch to throtl_data->service_queue.bio_lists[] blk-throttle: move bio_lists[] and friends to throtl_service_queue ...
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-03memcg: update TODO list in DocumentationLi Zefan
hugetlb cgroup has already been implemented. Signed-off-by: Li Zefan <lizefan@huawei.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rob Landley <rob@landley.net> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-24Documentation/cgroups/memory.txt: fix stat file documentationAaro Koskinen
Documentation for inactive_anon / active_anon was mixed up. Fix that. Signed-off-by: Aaro Koskinen <aaro.koskinen@nsn.com> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-06-19sched: Rename sched.c as sched/core.c in comments and DocumentationViresh Kumar
Most of the stuff from kernel/sched.c was moved to kernel/sched/core.c long time back and the comments/Documentation never got updated. I figured it out when I was going through sched-domains.txt and so thought of fixing it globally. I haven't crossed check if the stuff that is referenced in sched/core.c by all these files is still present and hasn't changed as that wasn't the motive behind this patch. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/cdff76a265326ab8d71922a1db5be599f20aad45.1370329560.git.viresh.kumar@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-05-28doc: fix misspellings with 'codespell' toolAnatol Pomozov
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-05-14blk-throttle: implement proper hierarchy supportTejun Heo
With the recent updates, blk-throttle is finally ready for proper hierarchy support. Dispatching now honors service_queue->parent_sq and propagates correctly. The only thing missing is setting ->parent_sq correctly so that throtl_grp hierarchy matches the cgroup hierarchy. This patch updates throtl_pd_init() such that service_queues form the same hierarchy as the cgroup hierarchy if sane_behavior is enabled. As this concludes proper hierarchy support for blkcg, the shameful .broken_hierarchy tag is removed from blkio_subsys. v2: Updated blkio-controller.txt as suggested by Vivek. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Li Zefan <lizefan@huawei.com>
2013-05-07mm, memcg: add rss_huge stat to memory.statDavid Rientjes
This exports the amount of anonymous transparent hugepages for each memcg via the new "rss_huge" stat in memory.stat. The units are in bytes. This is helpful to determine the hugepage utilization for individual jobs on the system in comparison to rss and opportunities where MADV_HUGEPAGE may be helpful. The amount of anonymous transparent hugepages is also included in "rss" for backwards compatibility. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
