path: root/Documentation/coccinelle.txt
2013-04-08Coccinelle: Add support to the SPFLAGS variableNicolas Palix
The SPFLAGS variable allows to pass additional options to spatch, e.g. -use_glimpse. Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22coccicheck: Allow the user to give a V= (verbose) argumentBernd Schubert
Do not run with verbosity on/off depending on the ONLINE variable, which gets set with C=1 or C=2, but allow the user to set the verbosity using kernel default make V= paramemter. Verbosity is off by default now. Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> CC: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14coccinelle.txt: update documentation to include M= optionGreg Dietsche
Adding documentation for the new M= option which limits Coccinelle to a specific set of directories. Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-03scripts/coccinelle: update for compatability with Coccinelle 0.2.4Julia Lawall
For doubleinit.cocci, Coccinelle 0.2.4 requires a comma after ... in a field list. Coccinelle also now behaves gracefully when a definition is provided for a virtual that doesn't exist, so there is no need for the semantic patch code to check for this case. Updated the documentation to reflect the fact that the best results will now be obtained with Coccinelle version 0.2.4 or later. Signed-off-by: Julia Lawall <julia@diku.dk>
2010-10-28Coccinelle: Fix documentationNicolas Palix
A file used as example has been moved elsewhere. Update the documentation accordingly Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Reported-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-13Coccinelle: Update documentationNicolas Palix
- Add information about use of the C={1,2} make flag - Add a description of the new chain mode mechanism - Add a link to the wiki Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-29Documentation: fix ubuntu distro nameKulikov Vasiliy
10.04 is Lucid, not Karmic. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-12Add Documentation/coccinelle.txtNicolas Palix
The purpose of this file is to document how to use Coccinelle and its spatch tool to check the Linux kernel. It gives information on where and how to retrieve Coccinelle, and how to use it with the Coccinelle scripts integrated in the Linux kernel. Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
