Applications can submit a set of commands in one packet to the kernel,
and in some cases it is required such as reading the temperature
sensor results. This adds an option W1_CN_BUNDLE to the flags of
cn_msg to request the kernel to reply in one packet for efficiency.
The cn_msg flags now check for unknown flag values and return an error
if one is seen. See "Proper handling of unknown flags in system
calls" http://lwn.net/Articles/588444/
This corrects the ack values returned as per the protocol standard,
namely the original ack for status messages and seq + 1 for all others
such as the data returned from a read.
Some of the common variable names have been standardized as follows.
struct cn_msg *cn
struct w1_netlink_msg *msg
struct w1_netlink_cmd *cmd
struct w1_master *dev
When an argument and a function scope variable would collide, add req_
to the argument.
Signed-off-by: David Fries <David@Fries.net>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
This increases the amount of bundling to reduce the number of packets
sent. For the one wire use there can be multiple struct
w1_netlink_cmd in a struct w1_netlink_msg and multiple of those in
struct cn_msg, and with this change multiple of those in a struct
nlmsghdr, and at each level the len identifies there being multiple of
the next.
Fix obvious cases of "it's" being used when "its" was meant.
Signed-off-by: Francis Galiegue <fgaliegue@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Acked-by: Lars Ellenberg <lars.ellenberg@linbit.com>
The grammar in most of this file is slightly off, and some sections are
hard to read due to lack of visual clues breaking up related material.
Return -ESRCH from cn_netlink_send() when there are not listeners,
just as it could be done by netlink_broadcast(). Propagate
netlink_broadcast() error back to the caller.
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Updated documentation to reflect 2.6.14 netlink changes
about socket options, multicasting and group number.
Please concider for 2.6.14.
Kernel connector - new userspace <-> kernel space easy to use
communication module which implements easy to use bidirectional
message bus using netlink as it's backend. Connector was created to
eliminate complex skb handling both in send and receive message bus
direction.
Connector driver adds possibility to connect various agents using as
one of it's backends netlink based network. One must register
callback and identifier. When driver receives special netlink message
with appropriate identifier, appropriate callback will be called.
From the userspace point of view it's quite straightforward:
socket();
bind();
send();
recv();
But if kernelspace want to use full power of such connections, driver
writer must create special sockets, must know about struct sk_buff
handling... Connector allows any kernelspace agents to use netlink
based networking for inter-process communication in a significantly
easier way:
int cn_add_callback(struct cb_id *id, char *name, void (*callback) (void *));
void cn_netlink_send(struct cn_msg *msg, u32 __groups, int gfp_mask);
struct cb_id
__u32 idx;
__u32 val;
idx and val are unique identifiers which must be registered in
connector.h for in-kernel usage. void (*callback) (void *) - is a
callback function which will be called when message with above idx.val
will be received by connector core.
Using connector completely hides low-level transport layer from it's
users.
Connector uses new netlink ability to have many groups in one socket.
[ Incorporating many cleanups and fixes by myself and
Andrew Morton -DaveM ]
