path: root/Documentation/cpu-freq
2008-01-26[ARM] pxa: add cpufreq supportRussell King
There have been patches hanging around for ages to add support for cpufreq to PXA255 processors. It's about time we applied one. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09misc doc and kconfig typosMatt LaPlante
Fix various typos in kernel docs and Kconfigs, 2.6.21-rc4. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-12Merge ../linusDave Jones
Conflicts: drivers/cpufreq/cpufreq.c
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-15[CPUFREQ] Documentation fixDominik Brodowski
Fix reference to where the code actually is. Noted by Hero Wanders. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'F'-'G'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'F'-'G'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-07-31[CPUFREQ] return error when failing to set minfreqMattia Dongili
I just stumbled on this bug/feature, this is how to reproduce it: # echo 450000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq # echo 450000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq # echo powersave > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor # cpufreq-info -p 450000 450000 powersave # echo 1800000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq ; echo $? 0 # cpufreq-info -p 450000 450000 powersave Here it is. The kernel refuses to set a min_freq higher than the max_freq but it allows a max_freq lower than min_freq (lowering min_freq also). This behaviour is pretty straightforward (but undocumented) and it doesn't return an error altough failing to accomplish the requested action (set min_freq). The problem (IMO) is basically that userspace is not allowed to set a full policy atomically while the kernel always does that thus it must enforce an ordering on operations. The attached patch returns -EINVAL if trying to increase frequencies starting from scaling_min_freq and documents the correct ordering of writes. Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Dominik Brodowski <linux at dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com> --
2006-04-03[CPUFREQ] Update LART site URLErik Mouw
Update LART site URL. The LART website moved to http://www.lartmaker.nl/. This patch updates the URL in CpuFreq specific files. Signed-off-by: Erik Mouw <erik@bitwizard.nl> Signed-off-by: Dave Jones <davej@redhat.com>
2005-12-01[PATCH] cpufreq: documentation for 'ondemand' and 'conservative'Alexander Clouter
Added a more verbose entry for the 'ondemend' governor and an entry for the 'conservative' governor to the documentation. Signed-off-by: Alexander Clouter <alex-kernel@digriz.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-09-10[PATCH] Spelling fixes for Documentation/Tobias Klauser
The attached patch fixes the following spelling errors in Documentation/ - double "the" - Several misspellings of function/functionality - infomation - memeory - Recieved - wether and possibly others which I forgot ;-) Trailing whitespaces on the same line as the typo are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] cpufreq: governors documentation fixesNico Golde
I corrected a small error and enhanced the govenor.txt file with the ondemand daemon because the kernel configs link to the documentation but ondemand wasn't documentated. Feel free to include the patch in the attachment. Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-31[PATCH] cpufreq-stats driver documentationVenkatesh Pallipadi
Documentation for cpufreq stats. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
