path: root/Documentation/cpu-hotplug.txt
2010-08-11documentation: fix erroneous email address.Rusty Russell
Hey, at least it has both l's. Reported-by: Marin Mitov <mitov@issp.bas.bg> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-17cpumask: don't recommend set_cpus_allowed hack in Documentation/cpu-hotplug.txtRusty Russell
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com>
2009-11-24powerpc/pseries: Add hooks to put the CPU into an appropriate offline stateGautham R Shenoy
When a CPU is offlined on POWER currently, we call rtas_stop_self() and hand the CPU back to the resource pool. This path is used for DLPAR which will cause a change in the LPAR configuration which will be visible outside. This patch changes the default state a CPU is put into when it is offlined. On platforms which support ceding the processor to the hypervisor with latency hint specifier value, during a cpu offline operation, instead of calling rtas_stop_self(), we cede the vCPU to the hypervisor while passing a latency hint specifier value. The Hypervisor can use this hint to provide better energy savings. Also, during the offline operation, the control of the vCPU remains with the LPAR as oppposed to returning it to the resource pool. The patch achieves this by creating an infrastructure to set the preferred_offline_state() which can be either - CPU_STATE_OFFLINE: which is the current behaviour of calling rtas_stop_self() - CPU_STATE_INACTIVE: which cedes the vCPU to the hypervisor with the latency hint specifier. The codepath which wants to perform a DLPAR operation can set the preferred_offline_state() of a CPU to CPU_STATE_OFFLINE before invoking cpu_down(). The patch also provides a boot-time command line argument to disable/enable CPU_STATE_INACTIVE. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-18x86: use possible_cpus=NUM to extend the possible cpus allowedMike Travis
Impact: add new boot parameter Use possible_cpus=NUM kernel parameter to extend the number of possible cpus. The ability to HOTPLUG ON cpus that are "possible" but not "present" is dealt with in a later patch. Signed-off-by: Mike Travis <travis@sgi.com>
2008-08-12cpu hotplug: s390 doesn't support additional_cpus anymore.Heiko Carstens
s390 doesn't support the additional_cpus kernel parameter anymore since a long time. So we better update the code and documentation to reflect that. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-26[S390] Get rid of additional_cpus kernel parameter.Heiko Carstens
It caused only a lot of confusion. From now on cpu hotplug of up to NR_CPUS will work by default. If somebody wants to limit that then the possible_cpus parameter can be used. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-25cpu-hotplug: replace lock_cpu_hotplug() with get_online_cpus()Gautham R Shenoy
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use get_online_cpus and put_online_cpus instead as it highlights the refcount semantics in these operations. The new API guarantees protection against the cpu-hotplug operation, but it doesn't guarantee serialized access to any of the local data structures. Hence the changes needs to be reviewed. In case of pseries_add_processor/pseries_remove_processor, use cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the cpu_present_map there. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-19hotplug cpu: migrate a task within its cpusetCliff Wickman
When a cpu is disabled, move_task_off_dead_cpu() is called for tasks that have been running on that cpu. Currently, such a task is migrated: 1) to any cpu on the same node as the disabled cpu, which is both online and among that task's cpus_allowed 2) to any cpu which is both online and among that task's cpus_allowed It is typical of a multithreaded application running on a large NUMA system to have its tasks confined to a cpuset so as to cluster them near the memory that they share. Furthermore, it is typical to explicitly place such a task on a specific cpu in that cpuset. And in that case the task's cpus_allowed includes only a single cpu. This patch would insert a preference to migrate such a task to some cpu within its cpuset (and set its cpus_allowed to its entire cpuset). With this patch, migrate the task to: 1) to any cpu on the same node as the disabled cpu, which is both online and among that task's cpus_allowed 2) to any online cpu within the task's cpuset 3) to any cpu which is both online and among that task's cpus_allowed In order to do this, move_task_off_dead_cpu() must make a call to cpuset_cpus_allowed_locked(), a new subset of cpuset_cpus_allowed(), that will not block. (name change - per Oleg's suggestion) Calls are made to cpuset_lock() and cpuset_unlock() in migration_call() to set the cpuset mutex during the whole migrate_live_tasks() and migrate_dead_tasks() procedure. [akpm@linux-foundation.org: build fix] [pj@sgi.com: Fix indentation and spacing] Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Christoph Lameter <clameter@sgi.com> Cc: Paul Jackson <pj@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-20[PATCH] doc: fixing cpu-hotplug documentationSatoru Takeuchi
Fixing cpu-hotplug documentation as follows: - moving confusing asterisk on additional_cpus descrition - fixing some typos - unifying indentation for source code and command line example Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] cpu hotplug: fix hotplug cpu documentation for proper usageChandra Seetharaman
Update hotplug cpu documentation to clearly state when to use register_cpu_notifier() and register_hotcpu_notifier. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] for_each_possible_cpu: documentaionKAMEZAWA Hiroyuki
Replace for_each_cpu with for_each_possible_cpu. Modifies occurences in documentaion. for_each_cpu in whatisRCU.txt should be for_each_online_cpu ??? (I'm not sure..) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] cpu hotplug documentation fixHeiko Carstens
Looks like there was a merge conflict when patches 8f8b1138fc9f65e3591aac83a4ee394fef34ac1d and 255acee706b333b79f593dd366f16e1f107cccc3 were applied which wasn't properly resolved. Fix this and add some additional description. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] s390: possible_cpus parameterHeiko Carstens
Introduce possible_cpus command line option. Hard sets the number of bits set in cpu_possible_map. Unlike the additional_cpus parameter this one guarantees that num_possible_cpus() will stay constant even if the system gets rebooted and a different number of cpus are present at startup. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] s390: additional_cpus parameterHeiko Carstens
Introduce additional_cpus command line option. By default no additional cpu can be attached to the system anymore. Only the cpus present at IPL time can be switched on/off. If it is desired that additional cpus can be attached to the system the maximum number of additional cpus needs to be specified with this option. This change is necessary in order to limit the waste of per_cpu data structures. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-16[IA64] Count disabled cpus as potential hot-pluggable CPUsAshok Raj
Minor updates to earlier patch. - Added to documentation to add ia64 as well. - Minor clarification on how to use disabled cpus - used plain max instead of max_t per Andew Morton. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-08[PATCH] Updated CPU hotplug documentationAshok Raj
Thanks to Nathan Lynch for the review and comments. Thanks to Joel Schopp for the pointer to add user space scipts. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
