path: root/Documentation/cpu-hotplug.txt
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-20[PATCH] doc: fixing cpu-hotplug documentationSatoru Takeuchi
Fixing cpu-hotplug documentation as follows: - moving confusing asterisk on additional_cpus descrition - fixing some typos - unifying indentation for source code and command line example Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] cpu hotplug: fix hotplug cpu documentation for proper usageChandra Seetharaman
Update hotplug cpu documentation to clearly state when to use register_cpu_notifier() and register_hotcpu_notifier. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] for_each_possible_cpu: documentaionKAMEZAWA Hiroyuki
Replace for_each_cpu with for_each_possible_cpu. Modifies occurences in documentaion. for_each_cpu in whatisRCU.txt should be for_each_online_cpu ??? (I'm not sure..) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] cpu hotplug documentation fixHeiko Carstens
Looks like there was a merge conflict when patches 8f8b1138fc9f65e3591aac83a4ee394fef34ac1d and 255acee706b333b79f593dd366f16e1f107cccc3 were applied which wasn't properly resolved. Fix this and add some additional description. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] s390: possible_cpus parameterHeiko Carstens
Introduce possible_cpus command line option. Hard sets the number of bits set in cpu_possible_map. Unlike the additional_cpus parameter this one guarantees that num_possible_cpus() will stay constant even if the system gets rebooted and a different number of cpus are present at startup. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] s390: additional_cpus parameterHeiko Carstens
Introduce additional_cpus command line option. By default no additional cpu can be attached to the system anymore. Only the cpus present at IPL time can be switched on/off. If it is desired that additional cpus can be attached to the system the maximum number of additional cpus needs to be specified with this option. This change is necessary in order to limit the waste of per_cpu data structures. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-16[IA64] Count disabled cpus as potential hot-pluggable CPUsAshok Raj
Minor updates to earlier patch. - Added to documentation to add ia64 as well. - Minor clarification on how to use disabled cpus - used plain max instead of max_t per Andew Morton. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-08[PATCH] Updated CPU hotplug documentationAshok Raj
Thanks to Nathan Lynch for the review and comments. Thanks to Joel Schopp for the pointer to add user space scipts. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
