path: root/Documentation/devicetree/bindings/leds/leds-ns2.txt
2015-08-28leds: leds-ns2: move LED modes mapping outside of the driverVincent Donnefort
On the board n090401 (Seagate NAS 4-Bay), the LED mode mapping (GPIO values to LED mode) is different from the one used on other boards supported by the leds-ns2 driver. With this patch the hardcoded mapping is removed from leds-ns2. Now, it must be defined either in the platform data (if an old-fashion board setup file is used) or in the DT node. In order to allow the later, this patch also introduces a modes-map property for the leds-ns2 DT binding. Signed-off-by: Vincent Donnefort <vdonnefort@gmail.com> Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
2013-02-07devicetree: Move NS2 LEDs binding into LEDs directoryGrant Likely
leds-ns2.txt is a binding for LEDs, not GPIOs. Move the documentation in with the rest of the LEDs bindings. Cc: Andrew Lunn <andrew@lunn.ch> Cc: Simon Guinot <simon.guinot@sequanux.org> Cc: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
