path: root/Documentation/devicetree/bindings/serial/serial.txt
2017-09-05dt-bindings: Remove "status" from examplesRob Herring
Pretty much any node can have a status property, so it doesn't need to be in examples. Converted with the following command and removed examples with SoC and board specific splits: git grep -l -E 'status.*=.*' Documentation/devicetree/ | xargs sed -i -E '/\sstatus.*=.*"(disabled|ok|okay)/d' Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Rob Herring <robh@kernel.org>
2017-02-06dt-bindings: serial: Update 'uart-has-rtscts' descriptionLee Jones
'uart-has-rtscts' property and 'rts-gpios|cts-gpios' are normally mutually exclusive, however it is possible for some drivers to have a dynamic approach, meaning that both properties can be relevant. Acked-by: Peter Griffin <peter.griffin@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-30doc: DT: Add Generic Serial Device Tree BindingsGeert Uytterhoeven
Document a set of generic properties for describing UARTs in a device tree: 1. The GPIO modem control properties are currently duplicated across hardware-specific binding documentation, 2. The property for dedicated RTS/CTS hardware flow control lines is already supported by several drivers, albeit with a vendor-specific prefix, hence make it generic. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Rob Herring <rob@kernel.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
