Signed-off-by: Wojciech Slenska <wojciech.slenska@gmail.com>
This commit adds two properties to control the RX DLL and TX DLL
2ns delay on RXC/TXC RGMII clock lines. This is especially needed
if the MAC does not provide TXC delay by itself.
Related-to: ELB-1299
Add support for Microchip Technology KSZ9131 10/100/1000 Ethernet PHY
Signed-off-by: Yuiko Oshino <yuiko.oshino@microchip.com>
(cherry picked from commit bff5b4b3737219195ca0caef4ff7884303cb5dc1)
toradex_4.14-2.0.x-imx-next
sound/soc/codecs/sgtl5000.c
This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
[ Upstream commit 73852e56827f5cb5db9d6e8dd8191fc2f2e8f424 ]
The abracon,tc-resistor property value is in kOhm.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
This allows to have a clock on clko even if the controller is
disabled.
Add device-tree bindings for Microcip CanFD Controller mcp2517fd
Changelog:
V1 -> V2: new more generic name based on feedback from microchip
cleanup of dt custom properties removing (most) gpio functions
V2 -> V3: added vendor-prefix for gpio-opendrain
s/_/-/
added gpio-controller
V3 -> V4: resend
added: Reviewed-by: Rob Herring <robh@kernel.org>
V7 -> V8: added support for mcp2518fd
added microchip,gpio0-xstandby
removed Reviewed-by because of changes
Signed-off-by: Martin Sperl <kernel@martin.sperl.org>
(cherry picked from commit ca3c427d353bafffa51d38da57e49f61ba16dbbf)
[ Upstream commit b78ac6ecd1b6b46f8767cbafa95a7b0b51b87ad8 ]
Allow the configuration of the MDIO clock divider when the Device Tree
contains 'clock-frequency' property (similar to I2C and SPI buses).
Because the hardware may have lost its state during suspend/resume,
re-apply the MDIO clock divider upon resumption.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 27582f0ea97fe3e4a38beb98ab36cce4b6f029d5 ]
With recent dtc and W=1:
Warning (graph_port): video-receiver@70/port@10: graph node unit address error, expected "a"
Warning (graph_port): video-receiver@70/port@11: graph node unit address error, expected "b"
Unit addresses are always hexadecimal (without prefix), while the bases
of reg property values depend on their prefixes.
Fixes: e69595170b1cad85 ("media: adv748x: Add adv7481, adv7482 bindings")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
commit 42bf02ec6e420e541af9a47437d0bdf961ca2972 upstream
Some platforms (e.g. TI's DRA7 USB2 instance) have more trouble
with the metastability workaround as it supports only
a High-Speed PHY and the PHY can enter into an Erratic state [1]
when the controller is set in SuperSpeed mode as part of
the metastability workaround.
This causes upto 2 seconds delay in enumeration on DRA7's USB2
instance in gadget mode.
If these platforms can be better off without the workaround,
provide a device tree property to suggest that so the workaround
is avoided.
[1] Device mode enumeration trace showing PHY Erratic Error.
irq/90-dwc3-969 [000] d... 52.323145: dwc3_event: event (00000901): Erratic Error [U0]
irq/90-dwc3-969 [000] d... 52.560646: dwc3_event: event (00000901): Erratic Error [U0]
irq/90-dwc3-969 [000] d... 52.798144: dwc3_event: event (00000901): Erratic Error [U0]
Signed-off-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
The NXP PCA6416 is a variant of the PCA GPIO expander, with 16 GPIOs.
(cherry picked from commit 15e384c446d93d00ab96d34bf2a5c308e3b3d16b)
Property "force-mode" tells the driver to replace previously
initialized power-off kernel hook and allows gpio-poweroff to
probe and operate successfully in any case.
Related-to: #42589
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
The driver got converted to a I2C device, DDC/EDID and HPD handling is added.
commit c737abc193d16e62e23e2fb585b8b7398ab380d8 upstream.
Armada-37xx UART0 registers are 0x200 bytes wide. Right next to them are
the UART1 registers that should not be declared in this node.
Update the example in DT bindings document accordingly.
Signed-off-by: allen yan <yanwei@marvell.com>
Signed-off-by: Miquel Raynal <miquel.raynal@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 80785f5a22e9073e2ded5958feb7f220e066d17b upstream.
Armada 8040 needs four clocks to be enabled for MDIO accesses to work.
Update the binding to allow the extra clock to be specified.
Cc: stable@vger.kernel.org
Fixes: 6d6a331f44a1 ("dt-bindings: allow up to three clocks for orion-mdio")
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Josua Mayer <josua@solid-run.com>
[ Upstream commit 0df82dcd55832a99363ab7f9fab954fcacdac3ae ]
Fully compatible with mcp2515, the mcp25625 have integrated transceiver.
This patch add the mcp25625 to the device tree bindings documentation.
Signed-off-by: Sean Nyekjaer <sean@geanix.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Clarify properties.
Drop unused pinctrl-2 state 'gpio'.
The Lontium LT8912 MIPI-DSI to LVDS and HDMI/MHL bridge features a
single-channel MIPI D-PHY receiver front-end configuration with 4 data
lanes per channel operating at 1.5Gbps per data lane and a maximum
input bandwidth of 6Gbps.
Change-Id: I7733ea5f33094151bb62e62406561cc0025cf900
Signed-off-by: Wyon Bi <bivvy.bi@rock-chips.com>
Import and forward port to 4.9 (API change of_get_drm_display_mode() )
from https://github.com/rockchip-linux/kernel/commit/230f7f061036a99fc02d2cd7d20f66f7f0efae99
drop drm_atomic_helper_connector_dpms, see 7d902c05b drm: Nuke drm_atomic_helper_connector_dpms
(cherry picked from commit 265fac62bf9defe0de5c1ce088013b61c9b46fb7)
(cherry picked from commit 7d2bdcf5aa35191aa0810884ea8eef944059269c)
This allows to configure the NRD register from device tree or platform data.
(cherry picked from commit 92ed1faf672e46e3e54b1f41f0b38f533b53b1aa)
(cherry picked from commit 6b5280f4e71770600d5b89638d849896158f2ec3)
While the usb3503 variant uses a HSIC connection to upstream,
the usb3803 uses a regular USB connection and provides a
bypass mode which connects the upstream port with downstream
port 3.
This adds an additional control gpio to the configuration which
allows moving away from the bypass mode to either standby or hub
mode once the driver is instantiated.
(cherry picked from commit e7812f55781bd9453a231d104a2c6c520491e2e4)
(cherry picked from commit 8662817b83bee3c30336f104608752fcb652f5c4)
This adds the devicetree bindings for the STMPE ADC. This also corrects
a typo in st,sample-time it is rather "6 -> 124 clocks" according
to the datasheet and not 144.
We need to use the naming stmpe_adc in devicetree because this is given
by the mfd device.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
(cherry picked from commit 81cdab79818988d27d8aeb162b7988c9e6dde936)
This patch reformats the parameter list for stmpe device in a
table-style so it is more clear to read.
(cherry picked from commit 270a60bcc8f23254d749987f3d2acb79ea5c599e)
From the i.MX 7 reference manual the drive strenght field
is defined as follows:
00 DSE_0_X1
01 DSE_1_X4
10 DSE_2_X2
11 DSE_3_X6
(cherry picked from commit 38524d73583e8f7fc61c8acd57b77c0a29889616)
The current imx-sgtl5000 driver always attaches the cpu-dai to ssi while
in fact it could be attached to other cpu-dais like SAI. Thus this patch
use a general code to support another cpu-dai. And meanwhile update the
devicetree for i.MX6 Series.
Acked-by: Wang Shengjiu <b02247@freescale.com>
Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com>
(cherry picked from commit f9302eb42ad8f597b46e681b5ad402af3fb7dd9d)
Add a new property 'pref-rate' support which can be used to
assign a different clock frequency for the DPHY PLL reference
clock in the dtb file. And if this property does not exist,
the default clock frequency for the reference clock will be
used. And according to the spec, the DPHY PLL reference clk
frequency should be in [6MHz, 300MHz] range.
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
(cherry picked from commit a9fafe8108505f8a1580af898ff5fa9c26d03680)
Add virtual i2c driver to send SRTM i2c messages to M4.
Each virtual I2C bus has a specal bus id, which is abstracted by M4.
Each SRTM message include a bus id for the bus which the device is on.
Virtual i2c rpmsg bus will bind rpbus nodes with compatible string
"fsl,i2c-rpbus". And "rpmsg-i2c-channel" will probe only one rpmsg
channel for all rpbuses.
This virtual i2c driver depends on CONFIG_I2C and CONFIG_RPMSG.
Signed-off-by: Clark Wang <xiaoning.wang@nxp.com>
commit 6c0c5dc33ff42af49243e94842d0ebdb153189ea upstream.
Add new compatible to the device tree bindings.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl>
Implement mode_valid and check functions from
drm_simple_display_pipe_funcs such that we can filter-out modes that
cannot be driven by this controller.
Add 3 new clocks:
- video_pll: this is the PLL that provides the pixel clock; it's rate
needs to be set such that the pixel clock can be achieved
- osc_25: this is an oscillater that can be used as source clock for the
video_pll; default freq is 25MHz
- osc_27: same as above, but with freq of 27MHz
Depending on the display mode used, the video_pll needs to have it's
clock source a 25MHz or 27MHz oscillator. Also, the video_pll rate needs
to be set to a rate that can be evenly divided to obtain the required
pixel clock. All these settings (clock source and video_pll rate) are
saved in mode_valid, then applied before mode needs to be set in the
check function.
Signed-off-by: Robert Chiras <robert.chiras@nxp.com>
Reviewed-by: Laurentiu Palcu <laurentiu.palcu@nxp.com>
Add new partition reset interrupt group to know M4 reset and restore
back at rpmsg level later.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Acked-by: Richard Zhu <hongxing.zhu@nxp.com>
The description of dmas pointed to the common description of dma,
and the introduction of dmas was unclear. Add a doc link to sdma
introduction.
In order to support 44kHz and 48kHz sample rate together, we need to
reconfigure the parent clock of mclk.
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
Add "fsl,imx8mm-usb" compatible string.
Acked-by: Peter Chen <peter.chen@nxp.com>
Signed-off-by: Li Jun <jun.li@nxp.com>
Some platforms may want to use USB PHY charger detection function
when VBUS is there, add one flag for it. The user can enable it
at firmware.
Reviewed-by: Jun Li <jun.li@nxp.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
This is an adapter card made for the 4.3", 800x480, LCD panel Seiko
43WVFIG. The LCD panel is a 24bit DPI bus, while the adapter card has
two ports: 18-bit and 24-bit data input. For the 18-bit data input, the
adapter card is demuxing some of the data lines, in order to feed all of
the 24 lines needed by the LCD.
This driver handles both this use-cases.
Add driver for Seiko Instruments Inc. 4.3" WVGA (800 x RGB x 480)
TFT with Touch-Panel.
Datasheet available at:
http://www.glyn.de/data/glyn/media/doc/43wvf1g-0.pdf
Seiko 43WVF1G panel has two power supplies: avdd and dvdd and they
require a specific power on/down sequence.
For this reason the simple panel driver cannot be used to drive this
panel, so create a new one heavily based on simple panel.
Based on initial patch submission from Breno Lima.
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1500567179-6967-1-git-send-email-marco.franchi@nxp.com
This patch is to add CAN wakeup function on MX8 platforms and update the
binding file fsl-flexcan.txt.
For MX8, the function "flexcan_irq()" should not call "flexcan_exit_stop_mode()"
due to firmware(SCU) cannot make SC IPC calls from an interrupt context.
If not exit stop mode in ISR, it will continuously enter wakeup ISR for the reason
that system will respond IRQ before call CAN system resume.
To fix the issue, we can exit stop mode during noirq resume stage.
For wakeup case, it should not set pinctrl to sleep state by
pinctrl_pm_select_sleep_state.
Reviewed-by: Dong Aisheng <aisheng.dong@nxp.com>
Reviewed-by: Andy Duan <fugang.duan@nxp.com>
Signed-off-by: Joakim Zhang <qiangqing.zhang@nxp.com>
Add xen,i2c bindings
Signed-off-by: Peng Fan <peng.fan@nxp.com>
FLEXCAN has supported selecting the clock source to the CAN Protocol Engine (PE).
It's SoC Implementation dependent. Refer to RM for detailed definition of each SoC.
tree
Normally CAN FD capable device must work on FD mode as it has different
statically claimed bittiming capability.
This patch provides users to disable CAN FD capability if users want
to only work at normal mode.
Add "spi-slave" attribute for recognizing slave mode.
If it is not in slave mode, please delete this attribute.
Usage can be found at spi-fsl-lpspi.txt.
Modify "Makefile" to build "imx7ulp-evk-spi-slave.dtb".
Signed-off-by: Xiaoning Wang <xiaoning.wang@nxp.com>
On imx8qm mek, the cs42888 is connected with i2c in cm41 domain,
but wm8960 is connected with i2c1, which is not in m4 domain.
So we only need to eable rpmsg for cs42888.
(cherry picked from commit 9d2368aef40e4d107e4deee1a2c7e191c1afe644)
According to AK5558 MCLK frequence must not exceed 36.864 MHz.
Limit maximum supported rate as function of max MCLK frequency,
sample bits and number of slots.
Signed-off-by: Viorel Suman <viorel.suman@nxp.com>
Reviewed-by: Shengjiu Wang <shengjiu.wang@nxp.com>
(cherry picked from commit 236796cad225daa39d5b77d763a1d964dd4de4c9)
Pixel combiner found in i.MX8 SoCs may combine two display
streams(one master and the other slave) to drive a high
pixel rate display. This patch adds DT property descriptions
in imx-drm DT documentation for pixel combiner.
Signed-off-by: Liu Ying <victor.liu@nxp.com>
Add two parameters which are used to tune USB signal for picophy,
picophy is used at imx7d and imx845.
The existing implementation calculates mclk rate as function
of audio sample rate multiplied to multiplier taken from Table 5.
However this is not accurate for Manual Setting Mode - tables 3 & 4 from
AK4458 RM defines rate (LRCK/FS) and frame width (MCLK/16fs..1152fs) ranges
as parameters to calculate mclk frequency. Aside of this - adjust
bclk:mclk ratio from machine driver as function of "compatible" id.
(cherry picked from commit 527b8b7032dcb75c14bb2790330ab96743d83b16)
Add output IOs defalut voltage set in device tree by add property like:
out-default = /bits/ 16 <mask val>;
Reviewed-by: Haibo Chen <haibo.chen@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
support more codecs, codec is specified by compatible string
(cherry picked from commit 7c92a75fcf83ec0aa3fe6773e4cb5f5e88a1ff09)
Add two new message command I2S_TX_POINTER and I2S_RX_POINTER,
which are used to get the hw pointer in m4 side. For in low
power audio mode, m4 won't send notification every period, the
notification only be sent when hw pointer reach end of buffer,
so we need these command to get the position of hw pointer,
user can use it to calculate the timestamp.
Restructure send message and recv message together for i2s_rpmsg,
that every send message has a recv message. so the
i2s_send_message can store the recv message indepedently. one
reason is that the receive message is async withe send message.
The low power audio is disabled in default, user need to enabled
it by add "fsl,enable-lpa" in dts.
Reviewed-by: Viorel Suman <viorel.suman@nxp.com>
(cherry picked from commit 753e7b819609ad4791e32069a124d4411c720947)
