path: root/Documentation/devicetree
2011-08-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: ad7879 - fix deficient device disable Input: gpio_keys - fix two typos in devicetree documentation Input: mma8450 - add device tree probe support Input: gpio_keys - return proper error code if memory allocation fails Input: lm8323 - add missing device_remove_file for dev_attr_time Input: tegra-kbc - fix computation of polling time Input: kxtj9 - explicitly include module.h Input: psmouse - hgpk.c needs module.h
2011-08-02Input: gpio_keys - fix two typos in devicetree documentationTobias Klauser
Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-07-31Input: mma8450 - add device tree probe supportShawn Guo
It adds device tree probe support for mma8450 driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Eric Miao <eric.miao@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-07-29Merge branch 'next/dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (21 commits) arm/dt: tegra devicetree support arm/versatile: Add device tree support dt/irq: add irq_domain_generate_simple() helper irq: add irq_domain translation infrastructure dmaengine: imx-sdma: add device tree probe support dmaengine: imx-sdma: sdma_get_firmware does not need to copy fw_name dmaengine: imx-sdma: use platform_device_id to identify sdma version mmc: sdhci-esdhc-imx: add device tree probe support mmc: sdhci-pltfm: dt device does not pass parent to sdhci_alloc_host mmc: sdhci-esdhc-imx: get rid of the uses of cpu_is_mx() mmc: sdhci-esdhc-imx: do not reference platform data after probe mmc: sdhci-esdhc-imx: extend card_detect and write_protect support for mx5 net/fec: add device tree probe support net: ibm_newemac: convert it to use of_get_phy_mode dt/net: add helper function of_get_phy_mode net/fec: gasket needs to be enabled for some i.mx serial/imx: add device tree probe support serial/imx: get rid of the uses of cpu_is_mx1() arm/dt: Add dtb make rule arm/dt: Add skeleton dtsi file ...
2011-07-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdog: (25 commits) watchdog: WatchDog Timer Driver Core - Add minimum and max timeout watchdog: WatchDog Timer Driver Core - Add ioctl call watchdog: WatchDog Timer Driver Core - Add nowayout feature watchdog: WatchDog Timer Driver Core - Add Magic Close feature watchdog: WatchDog Timer Driver Core - Add WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl watchdog: WatchDog Timer Driver Core - Add WDIOC_SETOPTIONS ioctl watchdog: WatchDog Timer Driver Core - Add WDIOC_KEEPALIVE ioctl watchdog: WatchDog Timer Driver Core - Add basic ioctl functionality watchdog: WatchDog Timer Driver Core - Add basic framework watchdog: hpwdt: add next gen HP servers watchdog: it8712f_wdt.c: improve includes watchdog: at91sam9/wdt: move register header to drivers watchdog: Add Xilinx watchdog timer driver watchdog: remove empty pm-functions watchdog: sp805: Flush posted writes in enable/disable. watchdog: sp805: Don't write 0 to the load value register. watchdog: imx2_wdt: add device tree probe support watchdog: s3c2410: Add support for device tree based probe watchdog: mpcore_wdt: Add suspend/resume support. watchdog: mtx1-wdt: use dev_{err,info} instead of printk() ...
2011-07-28Merge branch 'imx/dt' into next/dtArnd Bergmann
2011-07-28arm/versatile: Add device tree supportGrant Likely
For testing the dt work, define a dt-enabled versatile platform. This patch adds a new versatile platform for when using the device tree. Add platform and amba devices are discovered and registered by parsing the device tree. Clocks and initial io mappings are still configured statically. This patch still depends on some static platform_data for a few devices which is passed via the auxdata structure to of_platform_populate(), but it is a viable starting point until the drivers can get all configuration data out of the device tree. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (53 commits) Input: synaptics - fix reporting of min coordinates Input: tegra-kbc - enable key autorepeat Input: kxtj9 - fix locking typo in kxtj9_set_poll() Input: kxtj9 - fix bug in probe() Input: intel-mid-touch - remove pointless checking for variable 'found' Input: hp_sdc - staticize hp_sdc_kicker() Input: pmic8xxx-keypad - fix a leak of the IRQ during init failure Input: cy8ctmg110_ts - set reset_pin and irq_pin from platform data Input: cy8ctmg110_ts - constify i2c_device_id table Input: cy8ctmg110_ts - fix checking return value of i2c_master_send Input: lifebook - make dmi callback functions return 1 Input: atkbd - make dmi callback functions return 1 Input: gpio_keys - switch to using SIMPLE_DEV_PM_OPS Input: gpio_keys - add support for device-tree platform data Input: aiptek - remove double define Input: synaptics - set minimum coordinates as reported by firmware Input: synaptics - process button bits in AGM packets Input: synaptics - rename set_slot to be more descriptive Input: synaptics - fuzz position for touchpad with reduced filtering Input: synaptics - set resolution for MT_POSITION_X/Y axes ...
2011-07-27dmaengine: imx-sdma: add device tree probe supportShawn Guo
It adds device tree probe support for imx-sdma driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Vinod Koul <vinod.koul@intel.com>
2011-07-27mmc: sdhci-esdhc-imx: add device tree probe supportShawn Guo
The patch adds device tree probe support for sdhci-esdhc-imx driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Wolfram Sang <w.sang@pengutronix.de> Cc: Chris Ball <cjb@laptop.org> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Chris Ball <cjb@laptop.org>
2011-07-27net/fec: add device tree probe supportShawn Guo
It adds device tree probe support for fec driver. Signed-off-by: Jason Liu <jason.hui@linaro.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: David S. Miller <davem@davemloft.net> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2011-07-27serial/imx: add device tree probe supportShawn Guo
It adds device tree probe support for imx tty/serial driver. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Jason Liu <jason.hui@linaro.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Alan Cox <alan@linux.intel.com> Cc: Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-26Merge branch 'next/soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: MAINTAINERS: add maintainer of CSR SiRFprimaII machine ARM: CSR: initializing L2 cache ARM: CSR: mapping early DEBUG_LL uart ARM: CSR: Adding CSR SiRFprimaII board support OMAP4: clocks: Update the clock tree with 4460 clock nodes OMAP4: PRCM: OMAP4460 specific PRM and CM register bitshifts OMAP4: ID: add omap_has_feature for max freq supported OMAP: ID: introduce chip detection for OMAP4460 ARM: Xilinx: merge board file into main platform code ARM: Xilinx: Adding Xilinx board support Fix up conflicts in arch/arm/mach-omap2/cm-regbits-44xx.h
2011-07-26watchdog: imx2_wdt: add device tree probe supportShawn Guo
Adds device tree probe support for imx2_wdt driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26Merge branch 'x86-olpc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-olpc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, olpc-xo15-sci: Enable EC wakeup capability x86, olpc: Fix dependency on POWER_SUPPLY x86, olpc: Add XO-1.5 SCI driver x86, olpc: Add XO-1 RTC driver x86, olpc-xo1-sci: Propagate power supply/battery events x86, olpc-xo1-sci: Add lid switch functionality x86, olpc-xo1-sci: Add GPE handler and ebook switch functionality x86, olpc: EC SCI wakeup mask functionality x86, olpc: Add XO-1 SCI driver and power button control x86, olpc: Add XO-1 suspend/resume support x86, olpc: Rename olpc-xo1 to olpc-xo1-pm x86, olpc: Move CS5536-related constants to cs5535.h x86, olpc: Add missing elements to device tree
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (237 commits) ARM: 7004/1: fix traps.h compile warnings ARM: 6998/2: kernel: use proper memory barriers for bitops ARM: 6997/1: ep93xx: increase NR_BANKS to 16 for support of 128MB RAM ARM: Fix build errors caused by adding generic macros ARM: CPU hotplug: ensure we migrate all IRQs off a downed CPU ARM: CPU hotplug: pass in proper affinity mask on IRQ migration ARM: GIC: avoid routing interrupts to offline CPUs ARM: CPU hotplug: fix abuse of irqdesc->node ARM: 6981/2: mmci: adjust calculation of f_min ARM: 7000/1: LPAE: Use long long printk format for displaying the pud ARM: 6999/1: head, zImage: Always Enter the kernel in ARM state ARM: btc: avoid invalidating the branch target cache on kernel TLB maintanence ARM: ARM_DMA_ZONE_SIZE is no more ARM: mach-shark: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-sa1100: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-realview: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-pxa: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-ixp4xx: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-h720x: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-davinci: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ...
2011-07-22Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: dt: include linux/errno.h in linux/of_address.h of/address: Add of_find_matching_node_by_address helper dt: remove extra xsysace platform_driver registration tty/serial: Add devicetree support for nVidia Tegra serial ports dt: add empty of_property_read_u32[_array] for non-dt dt: bindings: move SEC node under new crypto/ dt: add helper function to read u32 arrays tty/serial: change of_serial to use new of_property_read_u32() api dt: add 'const' for of_property_read_string parameter **out_string dt: add helper functions to read u32 and string property values tty: of_serial: support for 32 bit accesses dt: document the of_serial bindings dt/platform: allow device name to be overridden drivers/amba: create devices from device tree dt: add of_platform_populate() for creating device from the device tree dt: Add default match table for bus ids
2011-07-22Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/imx: add device tree probe support spi/imx: copy gpio number passed by platform data into driver private data spi/imx: use soc name in spi device type naming scheme spi/imx: merge type SPI_IMX_VER_0_7 into SPI_IMX_VER_0_4 spi/imx: do not use spi_imx2_3 to name SPI_IMX_VER_2_3 function and macro spi/imx: use mx21 to name SPI_IMX_VER_0_0 function and macro spi/imx: do not make copy of spi_imx_devtype_data spi/dw: Add spi number into spi irq desc spi/tegra: Use engineering names in DT compatible property spi/fsl_spi: fix CPM spi driver mach-s3c2410: remove unused spi-gpio.h file spi: remove obsolete spi-s3c24xx-gpio driver mach-gta2: remove unused spi-gpio.h include mach-qt2410: convert to spi_gpio mach-jive: convert to spi_gpio spi/pxa2xx: Remove unavailable ssp_type from documentation spi/bfin_spi: uninline fat queue funcs spi/bfin_spi: constify pin array spi/bfin_spi: use structs for accessing hardware regs spi/topcliff-pch: Support new device ML7223 IOH ... Fix up trivial conflict in arch/arm/mach-ep93xx/Makefile
2011-07-22watchdog: s3c2410: Add support for device tree based probeThomas Abraham
This patch adds the of_match_table to enable s3c2410-wdt driver to be probed when watchdog device node is found in the device tree. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-17Merge branch 'zynq/master' of ↵Arnd Bergmann
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc into next/soc Conflicts: arch/arm/Kconfig arch/arm/mm/Kconfig
2011-07-15gpio/tegra: dt: add binding for gpio polarityOlof Johansson
Allocate one bit in the available extra cell to indicate if the gpio should be considered logically inverted. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-14spi/imx: add device tree probe supportShawn Guo
It adds device tree probe support for spi-imx driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-10Input: gpio_keys - add support for device-tree platform dataDavid Jander
This patch enables fetching configuration data, which is normally provided via platform_data, from the device-tree instead. If the device is configured from device-tree data, the platform_data struct is not used, and button data needs to be allocated dynamically. Big part of this patch deals with confining pdata usage to the probe function, to make this possible. Signed-off-by: David Jander <david@protonic.nl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-07-10tty/serial: Add devicetree support for nVidia Tegra serial portsGrant Likely
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-09ARM: CSR: Adding CSR SiRFprimaII board supportBinghua Duan
SiRFprimaII is the latest generation application processor from CSR’s Multifunction SoC product family. Designed around an ARM cortex A9 core, high-speed memory bus, advanced 3D accelerator and full-HD multi-format video decoder, SiRFprimaII is able to meet the needs of complicated applications for modern multifunction devices that require heavy concurrent applications and fluid user experience. Integrated with GPS baseband, analog and PMU, this new platform is designed to provide a cost effective solution for Automotive and Consumer markets. This patch adds the basic support for this SoC and EVB board based on device tree. It is following the ZYNQ of Xilinx in some degree. Signed-off-by: Binghua Duan <Binghua.Duan@csr.com> Signed-off-by: Rongjun Ying <Rongjun.Ying@csr.com> Signed-off-by: Zhiwu Song <Zhiwu.Song@csr.com> Signed-off-by: Yuping Luo <Yuping.Luo@csr.com> Signed-off-by: Bin Shi <Bin.Shi@csr.com> Signed-off-by: Huayi Li <Huayi.Li@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-08gpio/mxc: add device tree probe supportShawn Guo
The patch adds device tree probe support for gpio-mxc driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-07dt: bindings: move SEC node under new crypto/Kim Phillips
Since technically it's not powerpc arch-specific. Also rename it sec2 to differentiate it from its incompatible successor, the SEC 4. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-06x86, olpc: Add XO-1 RTC driverDaniel Drake
Add a driver to configure the XO-1 RTC via CS5536 MSRs, to be used as a system wakeup source via olpc-xo1-pm. Device detection is based on finding the relevant device tree node. Signed-off-by: Daniel Drake <dsd@laptop.org> Link: http://lkml.kernel.org/r/1309019658-1712-11-git-send-email-dsd@laptop.org Acked-by: Andres Salomon <dilinger@queued.net> Acked-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: devicetree-discuss@lists.ozlabs.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-05spi/tegra: Use engineering names in DT compatible propertyStephen Warren
Engineering names are more stable than marketing names. Hence, use them for Device Tree compatible properties instead. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-05gpio/tegra: Use engineering names in DT compatible propertyStephen Warren
2011-06-30tty: of_serial: support for 32 bit accessesJamie Iles
Some platforms e.g. TI Davinci require 32-bit accesses to the UARTs. The of_serial driver currently registers all UARTs as UPIO_MEM. Add a new attribute "reg-io-width" to allow the port to be registered with different IO width requirements. Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-29ARM: 6976/1: pmu: add OF probing supportMark Rutland
This is based on an earlier patch from Rob Herring <rob.herring@calxeda.com> > Add OF match table to enable OF style driver binding. The dts entry is like > this: > > pmu { > compatible = "arm,cortex-a9-pmu"; > interrupts = <100 101>; > }; > > The use of pdev->id as an index breaks with OF device binding, so set the type > based on the OF compatible string. This modification sets the PMU hardware type based on data embedded in the binding, allowing easy addition of new PMU types in future. Support for new PMU types not provided by devicetree can be added later using platform_device_id tables in a similar fashion. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-28gpio/dt: Refine GPIO device tree bindingGrant Likely
Allow for multiple named gpio properties Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-27dt: document the of_serial bindingsJamie Iles
The of_serial bindings can be used to register a number of serial devices. Document this binding with all of the others. v3: remove device-type and clarify used-by-rtas Signed-off-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-27doc: powerpc: drop +x perms on text fileMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-21drivers/amba: create devices from device treeGrant Likely
Add a function to create amba_devices (i.e. primecell peripherals) from device tree nodes. The device tree scanning is done by the of_platform_populate() function which can call of_amba_device_create based on a match table entry. Nodes with a "arm,primecell-periphid" property can override the h/w peripheral id value. Based on the original work by Jeremy Kerr. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> [grant.likely: add Jeremy's original s-o-b line, changes from review comments, and moved all code to drivers/of/platform.c] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-20ARM: Xilinx: Adding Xilinx board supportJohn Linn
The 1st board support is minimal to get a system up and running on the Xilinx platform. This platform reuses the clock implementation from plat-versatile, and it depends entirely on CONFIG_OF support. There is only one board support file which obtains all device information from a device tree dtb file which is passed to the kernel at boot time. Signed-off-by: John Linn <john.linn@xilinx.com>
2011-06-15gpio/tegra: add devicetree supportGrant Likely
Add support for decoding gpios from the device tree Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Olof Johansson <olof@lixom.net>
2011-06-15gpio/tegra: Move Tegra gpio driver to drivers/gpioGrant Likely
As part of the gpio driver consolidation, this patch moves the Tegra driver into drivers/gpio Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-27Merge branches 'devel', 'devel-stable' and 'fixes' into for-linusRussell King
2011-05-25Merge branch 'timers-ptp-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-ptp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ptp: Fix dp83640 build warning when building statically ptp: Added a clock driver for the National Semiconductor PHYTER. ptp: Added a clock driver for the IXP46x. ptp: Added a clock that uses the eTSEC found on the MPC85xx. ptp: Added a brand new class driver for ptp clocks.
2011-05-25Merge branch 'devicetree/arm-next' of git://git.secretlab.ca/git/linux-2.6 ↵Russell King
into devel-stable
2011-05-23ptp: Added a clock that uses the eTSEC found on the MPC85xx.Richard Cochran
The eTSEC includes a PTP clock with quite a few features. This patch adds support for the basic clock adjustment functions, plus two external time stamps, one alarm, and the PPS callback. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: John Stultz <john.stultz@linaro.org> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-23dt: add documentation of ARM dt boot interfaceGrant Likely
v6: typo fixes v5: clarified that dtb should be aligned on a 64 bit boundary in RAM. v3: added details to Documentation/arm/Booting Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (45 commits) crypto: caam - add support for sha512 variants of existing AEAD algorithms crypto: caam - remove unused authkeylen from caam_ctx crypto: caam - fix decryption shared vs. non-shared key setting crypto: caam - platform_bus_type migration crypto: aesni-intel - fix aesni build on i386 crypto: aesni-intel - Merge with fpu.ko crypto: mv_cesa - make count_sgs() null-pointer proof crypto: mv_cesa - copy remaining bytes to SRAM only when needed crypto: mv_cesa - move digest state initialisation to a better place crypto: mv_cesa - fill inner/outer IV fields only in HMAC case crypto: mv_cesa - refactor copy_src_to_buf() crypto: mv_cesa - no need to save digest state after the last chunk crypto: mv_cesa - print a warning when registration of AES algos fail crypto: mv_cesa - drop this call to mv_hash_final from mv_hash_finup crypto: mv_cesa - the descriptor pointer register needs to be set just once crypto: mv_cesa - use ablkcipher_request_cast instead of the manual container_of crypto: caam - fix printk recursion for long error texts crypto: caam - remove unused keylen from session context hwrng: amd - enable AMD hw rnd driver for Maple PPC boards hwrng: amd - manage resource allocation ...
2011-05-19powerpc: Integrated Flash controller device tree bindingsDipen Dudhat
Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com> Acked-By: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-19powerpc: Adding bindings for flexcan controllerBhaskar Upadhaya
Signed-off-by: Bhaskar Upadhaya <bhaskar.upadhaya@freescale.com> Acked-By: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-19powerpc: Add fsl mpic timer bindingScott Wood
Update the existing example in the general mpic binding to have a separate TCRx region. Currently the example doesn't describe TCRx at all. The one upstream device tree with an mpic timer node (p1022ds) uses one large reg region to describe both, even though there are other unrelated registers in between. That device tree also contains a bogus interrupt specifier, and there's no upstream software that uses this yet, so changing this shouldn't be a problem. Add a full binding for the MPIC timer node, not just an example of 4-cell interrupts in the MPIC binding. Add fsl,available-ranges, similar to msi-available-ranges. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
