path: root/Documentation/fb/fbcon.txt
2013-07-25doc: Fix typo in doucmentationsMasanari Iida
Correct typo (double words) in documentations. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-26[PATCH] VT binding: Update documentationAntonino A. Daplas
Update Documentation/fb/fbcon.txt and Documentatin/console/console.txt to reflect the following changes: 1. sysfs attributes are relocated to /sys/class/vtconsole 2. feature is selectable in Kconfig 3. add sample scripts to fbcon.txt Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] VT binding: fbcon: Update documentationAntonino A. Daplas
Update Documentation/fb/fbcon.txt to reflect the following changes: 1. Simple illustration of the binding of the console down to individual framebuffer drivers 2. Usage of userspace tools to help with recovery of text console 3. How to use the attributes in /sys/class/tty/console to unload fbcon and the framebuffer drivers Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Detaching fbcon: update documentationAntonino A. Daplas
Update Documentation/fb/fbcon.txt on the following: 1. sysfs attributes are now located in class/graphics/fbcon 2. instructions on how to attach, detach and/or unload fbcon Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] fbcon: Console Rotation - Add framebuffer console documentationAntonino A. Daplas
Add documentation as Documentation/fb/fbcon.txt describing the framebuffer console and its boot options. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
