path: root/Documentation/feature-removal-schedule.txt
2012-10-01Get rid of Documentation/feature-removal.txtLinus Torvalds
This file has turned out to be a pure write-only file that causes merge conflicts and has no actual redeeming features. There is never any reason to add stuff to this idiotic file. Either something isn't getting used, and you should just remove it, or there is no excuse for removing it in the first place. Just stop the idiocy. It has also been the excuse for just plain bad behavior ("Hey, I don't like xyz, so let's mark it for removal" followed by "Hey, look, it been in feature-removal.txt for six months now, so we should remove it"). The recent bogus setitimer() ABI change request was just the most recent example of pointless and incorrect mental masturbation involving this file, and I'm tired of the silly and pointless conflicts in the file. This removal was discussed during the recent kernel summit, and while Steven Rostedt suggested we should just enter the file itself in the feature-removal schedule (to see if anybody who edits the file actually looks at it), that's cute but non-productive. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-01Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: "New drivers for: MCP3221, ADT7410, MAX197 Chip support added to existing drivers: LM71, LM74, MAX1110, MAX1112, MAX1113, INA220, INA230, MCP3221 Cleanup: Use devm_ functions, fixed build warnings, removed deprecated sysfs attributes, code simplifications, dropped dependencies on EXPERIMENTAL" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: (64 commits) hwmon: (mcp3021) Add MCP3221 support hwmon: (mcp3021) Prepare MCP3021 driver to support other chips hwmon: (w83791d) Drop unnecessary compare statements hwmon: (lm93) Drop unnecessary compare statement hwmon: (lm70) Simplify show_name function hwmon: (adcxx) Simplify show_name function hwmon: Drop dependencies on EXPERIMENTAL hwmon: (it87) Fix Kconfig for IT87 driver hwmon: (sht15) move header to linux/platform_data/ hwmon: (asus_atk0110) Remove useless kfree hwmon: (ina2xx) Add support for INA220 and INA230 hwmon: (ina2xx) Use structure array to distinguish chip types hwmon: (max1111) Add support for MAX1110, MAX1112, and MAX1113 hwmon: (lm70) Add support for LM71 and LM74 hwmon: (Documentation) Update feature-removal-schedule.txt hwmon: (w83793) Remove legacy chassis intrusion detection sysfs attributes hwmon: (w83792d) Remove legacy chassis intrusion detection attributes hwmon: (adm9240) Remove legacy chassis intrusion detection sysfs attribute hwmon: (lm70) Allow 4wire SPI bus with LM70 hwmon: (sht15) remove multiple driver registration ...
2012-10-01Merge tag 'usb-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usbLinus Torvalds
Pull USB changes from Greg Kroah-Hartman: "Here is the big USB pull request for 3.7-rc1 There are lots of gadget driver changes (including copying a bunch of files into the drivers/staging/ccg/ directory so that the other gadget drivers can be fixed up properly without breaking that driver), and we remove the old obsolete ub.c driver from the tree. There are also the usual XHCI set of updates, and other various driver changes and updates. We also are trying hard to remove the old dbg() macro, but the final bits of that removal will be coming in through the networking tree before we can delete it for good. All of these patches have been in the linux-next tree. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up several annoying - but fairly mindless - conflicts due to the termios structure having moved into the tty device, and often clashing with dbg -> dev_dbg conversion. * tag 'usb-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (339 commits) USB: ezusb: move ezusb.c from drivers/usb/serial to drivers/usb/misc USB: uas: fix gcc warning USB: uas: fix locking USB: Fix race condition when removing host controllers USB: uas: add locking USB: uas: fix abort USB: uas: remove aborted field, replace with status bit. USB: uas: fix task management USB: uas: keep track of command urbs xhci: Intel Panther Point BEI quirk. powerpc/usb: remove checking PHY_CLK_VALID for UTMI PHY USB: ftdi_sio: add TIAO USB Multi-Protocol Adapter (TUMPA) support Revert "usb : Add sysfs files to control port power." USB: serial: remove vizzini driver usb: host: xhci: Fix Null pointer dereferencing with 71c731a for non-x86 systems Increase XHCI suspend timeout to 16ms USB: ohci-at91: fix null pointer in ohci_hcd_at91_overcurrent_irq USB: sierra_ms: don't keep unused variable fsl/usb: Add support for USB controller version 2.4 USB: qcaux: add Pantech vendor class match ...
2012-09-23hwmon: (Documentation) Update feature-removal-schedule.txtGuenter Roeck
Legacy sysfs attributes for chassis intrusion detection have been removed. Update feature-removal-schedule.txt to reflect it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-09-16Merge 3.6-rc6 into usb-nextGreg Kroah-Hartman
This resolves the merge problems with: drivers/usb/dwc3/gadget.c drivers/usb/musb/tusb6010.c that had been seen in linux-next. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-13Merge commit 'v3.6-rc5' into nextBjorn Helgaas
* commit 'v3.6-rc5': (1098 commits) Linux 3.6-rc5 HID: tpkbd: work even if the new Lenovo Keyboard driver is not configured Remove user-triggerable BUG from mpol_to_str xen/pciback: Fix proper FLR steps. uml: fix compile error in deliver_alarm() dj: memory scribble in logi_dj Fix order of arguments to compat_put_time[spec|val] xen: Use correct masking in xen_swiotlb_alloc_coherent. xen: fix logical error in tlb flushing xen/p2m: Fix one-off error in checking the P2M tree directory. powerpc: Don't use __put_user() in patch_instruction powerpc: Make sure IPI handlers see data written by IPI senders powerpc: Restore correct DSCR in context switch powerpc: Fix DSCR inheritance in copy_thread() powerpc: Keep thread.dscr and thread.dscr_inherit in sync powerpc: Update DSCR on all CPUs when writing sysfs dscr_default powerpc/powernv: Always go into nap mode when CPU is offline powerpc: Give hypervisor decrementer interrupts their own handler powerpc/vphn: Fix arch_update_cpu_topology() return value ARM: gemini: fix the gemini build ... Conflicts: drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c drivers/rapidio/devices/tsi721.c
2012-09-05block: remove the deprecated ub driverCong Wang
It was scheduled to be removed in 3.6. Acked-by: Pete Zaitcev <zaitcev@redhat.com> Cc: Jens Axboe <jaxboe@fusionio.com> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-27ARM: at91/feature-removal-schedule: delay at91_mci removalLudovic Desroches
Delay sd/mmc driver at91_mci.c removal because of tight schedule to move platform data to new driver atmel-mci. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-08-24PCI: Remove the fakephp driverBjorn Helgaas
The fakephp driver was scheduled for removal in 2011. Fakephp presented /sys/bus/pci/slots/.../power files for every PCI function. Writing "0" to one of these files logically removed the device from the system. The PCI core now provides the same functionality with /sys/bus/pci/devices/.../remove. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-08-01Merge branch 'dmaengine' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM DMA engine updates from Russell King: "This looks scary at first glance, but what it is is: - a rework of the sa11x0 DMA engine driver merged during the previous cycle, to extract a common set of helper functions for DMA engine implementations. - conversion of amba-pl08x.c to use these helper functions. - addition of OMAP DMA engine driver (using these helper functions), and conversion of some of the OMAP DMA users to use DMA engine. Nothing in the helper functions is ARM specific, so I hope that other implementations can consolidate some of their code by making use of these helpers. This has been sitting in linux-next most of the merge cycle, and has been tested by several OMAP folk. I've tested it on sa11x0 platforms, and given it my best shot on my broken platforms which have the amba-pl08x controller. The last point is the addition to feature-removal-schedule.txt, which will have a merge conflict. Between myself and TI, we're planning to remove the old TI DMA implementation next year." Fix up trivial add/add conflicts in Documentation/feature-removal-schedule.txt and drivers/dma/{Kconfig,Makefile} * 'dmaengine' of git://git.linaro.org/people/rmk/linux-arm: (53 commits) ARM: 7481/1: OMAP2+: omap2plus_defconfig: enable OMAP DMA engine ARM: 7464/1: mmc: omap_hsmmc: ensure probe returns error if DMA channel request fails Add feature removal of old OMAP private DMA implementation mtd: omap2: remove private DMA API implementation mtd: omap2: add DMA engine support spi: omap2-mcspi: remove private DMA API implementation spi: omap2-mcspi: add DMA engine support ARM: omap: remove mmc platform data dma_mask and initialization mmc: omap: remove private DMA API implementation mmc: omap: add DMA engine support mmc: omap_hsmmc: remove private DMA API implementation mmc: omap_hsmmc: add DMA engine support dmaengine: omap: add support for cyclic DMA dmaengine: omap: add support for setting fi dmaengine: omap: add support for returning residue in tx_state method dmaengine: add OMAP DMA engine driver dmaengine: sa11x0-dma: add cyclic DMA support dmaengine: sa11x0-dma: fix DMA residue support dmaengine: PL08x: ensure all descriptors are freed when channel is released dmaengine: PL08x: get rid of write only pool_ctr and free_txd locking ...
2012-07-31Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's second set of patches: - MM - a few random fixes - a couple of RTC leftovers * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits) rtc/rtc-88pm80x: remove unneed devm_kfree rtc/rtc-88pm80x: assign ret only when rtc_register_driver fails mm: hugetlbfs: close race during teardown of hugetlbfs shared page tables tmpfs: distribute interleave better across nodes mm: remove redundant initialization mm: warn if pg_data_t isn't initialized with zero mips: zero out pg_data_t when it's allocated memcg: gix memory accounting scalability in shrink_page_list mm/sparse: remove index_init_lock mm/sparse: more checks on mem_section number mm/sparse: optimize sparse_index_alloc memcg: add mem_cgroup_from_css() helper memcg: further prevent OOM with too many dirty pages memcg: prevent OOM with too many dirty pages mm: mmu_notifier: fix freed page still mapped in secondary MMU mm: memcg: only check anon swapin page charges for swap cache mm: memcg: only check swap cache pages for repeated charging mm: memcg: split swapin charge function into private and public part mm: memcg: remove needless !mm fixup to init_mm when charging mm: memcg: remove unneeded shmem charge type ...
2012-07-31Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull random subsystem patches from Ted Ts'o: "This patch series contains a major revamp of how we collect entropy from interrupts for /dev/random and /dev/urandom. The goal is to addresses weaknesses discussed in the paper "Mining your Ps and Qs: Detection of Widespread Weak Keys in Network Devices", by Nadia Heninger, Zakir Durumeric, Eric Wustrow, J. Alex Halderman, which will be published in the Proceedings of the 21st Usenix Security Symposium, August 2012. (See https://factorable.net for more information and an extended version of the paper.)" Fix up trivial conflicts due to nearby changes in drivers/{mfd/ab3100-core.c, usb/gadget/omap_udc.c} * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: (33 commits) random: mix in architectural randomness in extract_buf() dmi: Feed DMI table to /dev/random driver random: Add comment to random_initialize() random: final removal of IRQF_SAMPLE_RANDOM um: remove IRQF_SAMPLE_RANDOM which is now a no-op sparc/ldc: remove IRQF_SAMPLE_RANDOM which is now a no-op [ARM] pxa: remove IRQF_SAMPLE_RANDOM which is now a no-op board-palmz71: remove IRQF_SAMPLE_RANDOM which is now a no-op isp1301_omap: remove IRQF_SAMPLE_RANDOM which is now a no-op pxa25x_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op omap_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op goku_udc: remove IRQF_SAMPLE_RANDOM which was commented out uartlite: remove IRQF_SAMPLE_RANDOM which is now a no-op drivers: hv: remove IRQF_SAMPLE_RANDOM which is now a no-op xen-blkfront: remove IRQF_SAMPLE_RANDOM which is now a no-op n2_crypto: remove IRQF_SAMPLE_RANDOM which is now a no-op pda_power: remove IRQF_SAMPLE_RANDOM which is now a no-op i2c-pmcmsp: remove IRQF_SAMPLE_RANDOM which is now a no-op input/serio/hp_sdc.c: remove IRQF_SAMPLE_RANDOM which is now a no-op mfd: remove IRQF_SAMPLE_RANDOM which is now a no-op ...
2012-07-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull second set of media updates from Mauro Carvalho Chehab: - radio API: add support to work with radio frequency bands - new AM/FM radio drivers: radio-shark, radio-shark2 - new Remote Controller USB driver: iguanair - conversion of several drivers to the v4l2 core control framework - new board additions at existing drivers - the remaining (and vast majority of the patches) are due to drivers/DocBook fixes/cleanups. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (154 commits) [media] radio-tea5777: use library for 64bits div [media] tlg2300: Declare MODULE_FIRMWARE usage [media] lgs8gxx: Declare MODULE_FIRMWARE usage [media] xc5000: Add MODULE_FIRMWARE statements [media] s2255drv: Add MODULE_FIRMWARE statement [media] dib8000: move dereference after check for NULL [media] Documentation: Update cardlists [media] bttv: add support for Aposonic W-DVR [media] cx25821: Remove bad strcpy to read-only char* [media] pms.c: remove duplicated include [media] smiapp-core.c: remove duplicated include [media] via-camera: pass correct format settings to sensor [media] rtl2832.c: minor cleanup [media] Add support for the IguanaWorks USB IR Transceiver [media] Minor cleanups for MCE USB [media] drivers/media/dvb/siano/smscoreapi.c: use list_for_each_entry [media] Use a named union in struct v4l2_ioctl_info [media] mceusb: Add Twisted Melon USB IDs [media] staging/media/solo6x10: use module_pci_driver macro [media] staging/media/dt3155v4l: use module_pci_driver macro ... Conflicts: Documentation/feature-removal-schedule.txt
2012-07-31mm: prepare for removal of obsolete /proc/sys/vm/nr_pdflush_threadsWanpeng Li
Since per-BDI flusher threads were introduced in 2.6, the pdflush mechanism is not used any more. But the old interface exported through /proc/sys/vm/nr_pdflush_threads still exists and is obviously useless. For back-compatibility, printk warning information and return 2 to notify the users that the interface is removed. Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31Add feature removal of old OMAP private DMA implementationRussell King
Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-30Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This is the first part of the media patches for v3.6. This patch series contain: - new DVB frontend: rtl2832 - new video drivers: adv7393 - some unused files got removed - a selection API cleanup between V4L2 and V4L2 subdev API's - a major redesign at v4l-ioctl2, in order to clean it up - several driver fixes and improvements." * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (174 commits) v4l: Export v4l2-common.h in include/linux/Kbuild media: Revert "[media] Terratec Cinergy S2 USB HD Rev.2" [media] media: Use pr_info not homegrown pr_reg macro [media] Terratec Cinergy S2 USB HD Rev.2 [media] v4l: Correct conflicting V4L2 subdev selection API documentation [media] Feature removal: V4L2 selections API target and flag definitions [media] v4l: Unify selection flags documentation [media] v4l: Unify selection flags [media] v4l: Common documentation for selection targets [media] v4l: Unify selection targets across V4L2 and V4L2 subdev interfaces [media] v4l: Remove "_ACTUAL" from subdev selection API target definition names [media] V4L: Remove "_ACTIVE" from the selection target name definitions [media] media: dvb-usb: print mac address via native %pM [media] s5p-tv: Use module_i2c_driver in sii9234_drv.c file [media] media: gpio-ir-recv: add allowed_protos for platform data [media] s5p-jpeg: Use module_platform_driver in jpeg-core.c file [media] saa7134: fix spelling of detach in label [media] cx88-blackbird: replace ioctl by unlocked_ioctl [media] cx88: don't use current_norm [media] cx88: fix a number of v4l2-compliance violations ...
2012-07-30[media] Feature removal: using capture and output capabilities for m2m devicesSylwester Nawrocki
Identifying a memory-to-memory video device through an ORed output and capture capability flags is not reliable. Schedule this for removal. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-27Merge branch 'kmap_atomic' of git://github.com/congwang/linuxLinus Torvalds
Pull final kmap_atomic cleanups from Cong Wang: "This should be the final round of cleanup, as the definitions of enum km_type finally get removed from the whole tree. The patches have been in linux-next for a long time." * 'kmap_atomic' of git://github.com/congwang/linux: pipe: remove KM_USER0 from comments vmalloc: remove KM_USER0 from comments feature-removal-schedule.txt: remove kmap_atomic(page, km_type) tile: remove km_type definitions um: remove km_type definitions asm-generic: remove km_type definitions avr32: remove km_type definitions frv: remove km_type definitions powerpc: remove km_type definitions arm: remove km_type definitions highmem: remove the deprecated form of kmap_atomic tile: remove usage of enum km_type frv: remove the second parameter of kmap_atomic_primary() jbd2: remove the second argument of kmap_atomic
2012-07-24feature-removal-schedule.txt: remove kmap_atomic(page, km_type)Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-07-19random: final removal of IRQF_SAMPLE_RANDOMTheodore Ts'o
The IRQF_SAMPLE_RANDOM flag is finally gone from the kernel tree, only three years late. :-) Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-07-06[media] Feature removal: V4L2 selections API target and flag definitionsSylwester Nawrocki
After unification of the V4L2 and V4L2 subdev selection targets and flags the old flags are no longer required. Thus they can be removed. However, as the API is present in a kernel release, this must go through the feature removal process. Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-12Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2012-06-07netfilter: xt_recent: add address masking optionDenys Fedoryshchenko
The mask option allows you put all address belonging that mask into the same recent slot. This can be useful in case that recent is used to detect attacks from the same network segment. Tested for backward compatibility. Signed-off-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-06-07netfilter: xt_connlimit: remove revision 0Cong Wang
It was scheduled to be removed. Cc: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-06-07netfilter: remove include/linux/netfilter_ipv4/ipt_addrtype.hCong Wang
It was scheduled to be removed. Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-06-05cfg80211: deprecate CFG80211_WEXTJohannes Berg
Almost all wireless tools have transitioned to or at least added compatibility with nl80211 so there's no real need for CONFIG_CFG80211_WEXT any more. Mark it for removal, and also change the default to not be enabled. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05wireless: remove wext sysfsJohannes Berg
The only user of this was hal prior to its 0.5.12 release which happened over two years ago, so I'm sure this can be removed without issues. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking changes from David S. Miller: 1) Fix IPSEC header length calculation for transport mode in ESP. The issue is whether to do the calculation before or after alignment. Fix from Benjamin Poirier. 2) Fix regression in IPV6 IPSEC fragment length calculations, from Gao Feng. This is another transport vs tunnel mode issue. 3) Handle AF_UNSPEC connect()s properly in L2TP to avoid OOPSes. Fix from James Chapman. 4) Fix USB ASIX driver's reception of full sized VLAN packets, from Eric Dumazet. 5) Allow drop monitor (and, more generically, all generic netlink protocols) to be automatically loaded as a module. From Neil Horman. Fix up trivial conflict in Documentation/feature-removal-schedule.txt due to new entries added next to each other at the end. As usual. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits) net/smsc911x: Repair broken failure paths virtio-net: remove useless disable on freeze netdevice: Update netif_dbg for CONFIG_DYNAMIC_DEBUG drop_monitor: Add module alias to enable automatic module loading genetlink: Build a generic netlink family module alias net: add MODULE_ALIAS_NET_PF_PROTO_NAME r6040: Do a Proper deinit at errorpath and also when driver unloads (calling r6040_remove_one) r6040: disable pci device if the subsequent calls (after pci_enable_device) fails skb: avoid unnecessary reallocations in __skb_cow net: sh_eth: fix the rxdesc pointer when rx descriptor empty happens asix: allow full size 8021Q frames to be received rds_rdma: don't assume infiniband device is PCI l2tp: fix oops in L2TP IP sockets for connect() AF_UNSPEC case mac80211: fix ADDBA declined after suspend with wowlan wlcore: fix undefined symbols when CONFIG_PM is not defined mac80211: fix flag check for QoS NOACK frames ath9k_hw: apply internal regulator settings on AR933x ath9k_hw: update AR933x initvals to fix issues with high power devices ath9k: fix a use-after-free-bug when ath_tx_setup_buffer() fails ath9k: stop rx dma before stopping tx ...
2012-05-25Merge tag 'mmc-merge-for-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC changes from Chris Ball - at91-mci: This driver will be replaced by atmel-mci in 3.7. - atmel-mci: Add support for old at91-mci hardware. - dw_mmc: Allow multiple controllers; this previously caused corruption. - imxmmc: Remove this driver, replaced by mxcmmc. - mmci: Add device tree support. - omap: Allow multiple controllers. - omap_hsmmc: Auto CMD12, DDR support. - tegra: Support SD 3.0 spec. Fix up the usual trivial conflicts in feature-removal-schedule.txt * tag 'mmc-merge-for-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (38 commits) mmc: at91-mci: this driver is now deprecated mmc: omap_hsmmc: pass IRQF_ONESHOT to request_threaded_irq mmc: block: Allow disabling 512B sector size emulation mmc: atmel-mci: add debug logs mmc: atmel-mci: add support for version lower than v2xx mmc: atmel-mci: change the state machine for compatibility with old IP mmc: atmel-mci: the r/w proof capability lack was not well managed mmc: dw_mmc: Fixed sdio interrupt mask bit setting bug mmc: omap: convert to module_platform_driver mmc: omap: make it behave well as a module mmc: omap: convert to per instance workqueue mmc: core: Remove dead code mmc: card: Avoid null pointer dereference mmc: core: Prevent eMMC VCC supply to be cut from late init mmc: dw_mmc: make multiple instances of dw_mci_card_workqueue mmc: queue: remove redundant memsets mmc: queue: rename mmc_request function mmc: core: skip card initialization if power class selection fails mmc: core: fix the signaling 1.8V for HS200 mmc: core: fix the decision of HS200/DDR card-type ...
2012-05-24Merge branch 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Avi Kivity: "Changes include additional instruction emulation, page-crossing MMIO, faster dirty logging, preventing the watchdog from killing a stopped guest, module autoload, a new MSI ABI, and some minor optimizations and fixes. Outside x86 we have a small s390 and a very large ppc update. Regarding the new (for kvm) rebaseless workflow, some of the patches that were merged before we switch trees had to be rebased, while others are true pulls. In either case the signoffs should be correct now." Fix up trivial conflicts in Documentation/feature-removal-schedule.txt arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h. I suspect the kvm_para.h resolution ends up doing the "do I have cpuid" check effectively twice (it was done differently in two different commits), but better safe than sorry ;) * 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits) KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block KVM: s390: onereg for timer related registers KVM: s390: epoch difference and TOD programmable field KVM: s390: KVM_GET/SET_ONEREG for s390 KVM: s390: add capability indicating COW support KVM: Fix mmu_reload() clash with nested vmx event injection KVM: MMU: Don't use RCU for lockless shadow walking KVM: VMX: Optimize %ds, %es reload KVM: VMX: Fix %ds/%es clobber KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte() KVM: VMX: unlike vmcs on fail path KVM: PPC: Emulator: clean up SPR reads and writes KVM: PPC: Emulator: clean up instruction parsing kvm/powerpc: Add new ioctl to retreive server MMU infos kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler KVM: PPC: Book3S: Enable IRQs during exit handling KVM: PPC: Fix PR KVM on POWER7 bare metal KVM: PPC: Fix stbux emulation KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields ...
2012-05-24net/wanrouter: Deprecate and schedule for removalJoe Perches
No one uses this on current kernels anymore. Let it be known it's going to be removed eventually. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull more networking updates from David Miller: "Ok, everything from here on out will be bug fixes." 1) One final sync of wireless and bluetooth stuff from John Linville. These changes have all been in his tree for more than a week, and therefore have had the necessary -next exposure. John was just away on a trip and didn't have a change to send the pull request until a day or two ago. 2) Put back some defines in user exposed header file areas that were removed during the tokenring purge. From Stephen Hemminger and Paul Gortmaker. 3) A bug fix for UDP hash table allocation got lost in the pile due to one of those "you got it.. no I've got it.." situations. :-) From Tim Bird. 4) SKB coalescing in TCP needs to have stricter checks, otherwise we'll try to coalesce overlapping frags and crash. Fix from Eric Dumazet. 5) RCU routing table lookups can race with free_fib_info(), causing crashes when we deref the device pointers in the route. Fix by releasing the net device in the RCU callback. From Yanmin Zhang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (293 commits) tcp: take care of overlaps in tcp_try_coalesce() ipv4: fix the rcu race between free_fib_info and ip_route_output_slow mm: add a low limit to alloc_large_system_hash ipx: restore token ring define to include/linux/ipx.h if: restore token ring ARP type to header xen: do not disable netfront in dom0 phy/micrel: Fix ID of KSZ9021 mISDN: Add X-Tensions USB ISDN TA XC-525 gianfar:don't add FCB length to hard_header_len Bluetooth: Report proper error number in disconnection Bluetooth: Create flags for bt_sk() Bluetooth: report the right security level in getsockopt Bluetooth: Lock the L2CAP channel when sending Bluetooth: Restore locking semantics when looking up L2CAP channels Bluetooth: Fix a redundant and problematic incoming MTU check Bluetooth: Add support for Foxconn/Hon Hai AR5BBU22 0489:E03C Bluetooth: Fix EIR data generation for mgmt_device_found Bluetooth: Fix Inquiry with RSSI event mask Bluetooth: improve readability of l2cap_seq_list code Bluetooth: Fix skb length calculation ...
2012-05-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - some V4L2 API updates needed by embedded devices - DVB API extensions for ATSC-MH delivery system, used in US for mobile TV - new tuners for fc0011/0012/0013 and tua9001 - a new dvb driver for af9033/9035 - a new ATSC-MH frontend (lg2160) - new remote controller keymaps - Removal of a few legacy webcam driver that got replaced by gspca on several kernel versions ago - a new driver for Exynos 4/5 webcams(s5pp fimc-lite) - a new webcam sensor driver (smiapp) - a new video input driver for embedded (sta2x1xx) - several improvements, fixes, cleanups, etc inside the drivers. Manually fix up conflicts due to err() -> dev_err() conversion in drivers/staging/media/easycap/easycap_main.c * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (484 commits) [media] saa7134-cards: Remove a PCI entry added by mistake [media] radio-sf16fmi: add support for SF16-FMD [media] rc-loopback: remove duplicate line [media] patch for Asus My Cinema PS3-100 (1043:48cd) [media] au0828: Move the Kconfig knob under V4L_USB_DRIVERS [media] em28xx: simple comment fix [media] [resend] radio-sf16fmr2: add PnP support for SF16-FMD2 [media] smiapp: Use v4l2_ctrl_new_int_menu() instead of v4l2_ctrl_new_custom() [media] smiapp: Add support for 8-bit uncompressed formats [media] smiapp: Allow generic quirk registers [media] smiapp: Use non-binning limits if the binning limit is zero [media] smiapp: Initialise rval in smiapp_read_nvm() [media] smiapp: Round minimum pre_pll up rather than down in ip_clk_freq check [media] smiapp: Use 8-bit reads only before identifying the sensor [media] smiapp: Quirk for sensors that only do 8-bit reads [media] smiapp: Pass struct sensor to register writing commands instead of i2c_client [media] smiapp: Allow using external clock from the clock framework [media] zl10353: change .read_snr() to report SNR as a 0.1 dB [media] media: add support to gspca/pac7302.c for 093a:2627 (Genius FaceCam 300) [media] m88rs2000 - only flip bit 2 on reg 0x70 on 16th try ...
2012-05-22Merge branch 'for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "cgroup file type addition / removal is updated so that file types are added and removed instead of individual files so that dynamic file type addition / removal can be implemented by cgroup and used by controllers. blkio controller changes which will come through block tree are dependent on this. Other changes include res_counter cleanup and disallowing kthread / PF_THREAD_BOUND threads to be attached to non-root cgroups. There's a reported bug with the file type addition / removal handling which can lead to oops on cgroup umount. The issue is being looked into. It shouldn't cause problems for most setups and isn't a security concern." Fix up trivial conflict in Documentation/feature-removal-schedule.txt * 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (21 commits) res_counter: Account max_usage when calling res_counter_charge_nofail() res_counter: Merge res_counter_charge and res_counter_charge_nofail cgroups: disallow attaching kthreadd or PF_THREAD_BOUND threads cgroup: remove cgroup_subsys->populate() cgroup: get rid of populate for memcg cgroup: pass struct mem_cgroup instead of struct cgroup to socket memcg cgroup: make css->refcnt clearing on cgroup removal optional cgroup: use negative bias on css->refcnt to block css_tryget() cgroup: implement cgroup_rm_cftypes() cgroup: introduce struct cfent cgroup: relocate __d_cgrp() and __d_cft() cgroup: remove cgroup_add_file[s]() cgroup: convert memcg controller to the new cftype interface memcg: always create memsw files if CONFIG_CGROUP_MEM_RES_CTLR_SWAP cgroup: convert all non-memcg controllers to the new cftype interface cgroup: relocate cftype and cgroup_subsys definitions in controllers cgroup: merge cft_release_agent cftype array into the base files array cgroup: implement cgroup_add_cftypes() and friends cgroup: build list of all cgroups under a given cgroupfs_root cgroup: move cgroup_clear_directory() call out of cgroup_populate_dir() ...
2012-05-22Merge tag 'driver-core-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the driver core, and other driver subsystems, pull request for the 3.5-rc1 merge window. Outside of a few minor driver core changes, we ended up with the following different subsystem and core changes as well, due to interdependancies on the driver core: - hyperv driver updates - drivers/memory being created and some drivers moved into it - extcon driver subsystem created out of the old Android staging switch driver code - dynamic debug updates - printk rework, and /dev/kmsg changes All of this has been tested in the linux-next releases for a few weeks with no reported problems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up conflicts in drivers/extcon/extcon-max8997.c where git noticed that a patch to the deleted drivers/misc/max8997-muic.c driver needs to be applied to this one. * tag 'driver-core-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (90 commits) uio_pdrv_genirq: get irq through platform resource if not set otherwise memory: tegra{20,30}-mc: Remove empty *_remove() printk() - isolate KERN_CONT users from ordinary complete lines sysfs: get rid of some lockdep false positives Drivers: hv: util: Properly handle version negotiations. Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp() memory: tegra{20,30}-mc: Use dev_err_ratelimited() driver core: Add dev_*_ratelimited() family Driver Core: don't oops with unregistered driver in driver_find_device() printk() - restore prefix/timestamp printing for multi-newline strings printk: add stub for prepend_timestamp() ARM: tegra30: Make MC optional in Kconfig ARM: tegra20: Make MC optional in Kconfig ARM: tegra30: MC: Remove unnecessary BUG*() ARM: tegra20: MC: Remove unnecessary BUG*() printk: correctly align __log_buf ARM: tegra30: Add Tegra Memory Controller(MC) driver ARM: tegra20: Add Tegra Memory Controller(MC) driver printk() - restore timestamp printing at console output printk() - do not merge continuation lines of different threads ...
2012-05-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-nextJohn W. Linville
2012-05-20[media] Feature removal: remove invalid DV presetsHans Verkuil
Formats V4L2_DV_1080I25, V4L2_DV_1080I30 and V4L2_DV_1080I29_97 do not exist, so these presets are bogus. Remove them in 3.6. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-17mmc: at91-mci: this driver is now deprecatedLudovic Desroches
at91-mci is deprecated since atmel-mci can deal with all chips. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-05-15feature-removal: Remove pn544 raw driverSamuel Ortiz
The pn544_hci driver uses the kernel NFC APIs while pn544 does not. Moreover pn544 is outdated and not maintained. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-14Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "For a some fix patches for v3.4, including a regression fix at DVB core" Fix up trivial conflicts in Documentation/feature-removal-schedule.txt * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] gspca - sonixj: Fix a zero divide in isoc interrupt [media] media: videobuf2-dma-contig: include header for exported symbols [media] media: videobuf2-dma-contig: quiet sparse noise about plain integer as NULL pointer [media] media: vb2-memops: Export vb2_get_vma symbol [media] s5p-fimc: Correct memory allocation for VIDIOC_CREATE_BUFS [media] s5p-fimc: Fix locking in subdev set_crop op [media] dvb_frontend: fix a regression with DVB-S zig-zag [media] fintek-cir: change || to && [media] V4L: Schedule V4L2_CID_HCENTER, V4L2_CID_VCENTER controls for removal [media] rc: Postpone ISR registration [media] marvell-cam: fix an ARM build error [media] V4L: soc-camera: protect hosts during probing from overzealous user-space
2012-05-02Merge 3.4-rc5 into driver-core-nextGreg Kroah-Hartman
This was done to resolve a merge issue with the init/main.c file. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: deprecate ddebug_query, suggest dyndbg insteadJim Cromie
With ddebug_dyndbg_boot_params_cb() handling bare dyndbg params, we dont need ddebug_query param anymore. Add a warning when processing ddebug_query= param that it is deprecated, and to change it to dyndbg= Add a deprecation notice for v3.8 to feature-removal-schedule.txt, and add a suggested deprecation period of 3 releases to the header. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-26[media] V4L: Schedule V4L2_CID_HCENTER, V4L2_CID_VCENTER controls for removalSylwester Nawrocki
These controls have been marked for long time as V4L2_CID_HCENTER_DEPRECATED, V4L2_CID_VCENTER_DEPRECATED in the DocBook and are going to be removed from include/linux/videodev2.h. Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-19Merge branch 'linus' into queueMarcelo Tosatti
Merge reason: development work has dependency on kvm patches merged upstream. Conflicts: Documentation/feature-removal-schedule.txt Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-12Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "The itimer removal one is not strictly a fix, but I really wanted to avoid a rebase of the urgent ones." * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Revert "clocksource: Load the ACPI PM clocksource asynchronously" clockevents: tTack broadcast device mode change in tick_broadcast_switch_to_oneshot() itimer: Use printk_once instead of WARN_ONCE nohz: Fix stale jiffies update in tick_nohz_restart() tick: Document TICK_ONESHOT config option proc: stats: Use arch_idle_time for idle and iowait times if available itimer: Schedule silent NULL pointer fixup in setitimer() for removal
2012-04-08KVM: schedule debugfs statistics for removalAvi Kivity
Deprecated in favour of tracepoints. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-04Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar. * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, kvm: Call restore_sched_clock_state() only after %gs is initialized x86: Use -mno-avx when available x86: Remove the ancient and deprecated disable_hlt() and enable_hlt() facility x86: Preserve lazy irq disable semantics in fixup_irqs()
2012-04-01cgroup: deprecate remount option changesTejun Heo
This patch marks the following features for deprecation. * Rebinding subsys by remount: Never reached useful state - only works on empty hierarchies. * release_agent update by remount: release_agent itself will be replaced with conventional fsnotify notification. v2: Lennart pointed out that "name=" is necessary for mounts w/o any controller attached. Drop "name=" deprecation. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Lennart Poettering <mzxreary@0pointer.de>
2012-03-30itimer: Schedule silent NULL pointer fixup in setitimer() for removalSasikantha babu
setitimer() should return -EFAULT if called with an invalid pointer for value. The current code excludes a NULL pointer from this rule and silently uses it to stop the timer. This violates the spec. Warn about user space apps which rely on that feature and schedule it for removal. [ tglx: Massaged changelog, warn message and Doc entry ] Signed-off-by: Sasikantha babu <sasikanth.v19@gmail.com> Link: http://lkml.kernel.org/r/1332340854-26053-1-git-send-email-sasikanth.v19@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-30x86: Remove the ancient and deprecated disable_hlt() and enable_hlt() facilityLen Brown
The X86_32-only disable_hlt/enable_hlt mechanism was used by the 32-bit floppy driver. Its effect was to replace the use of the HLT instruction inside default_idle() with cpu_relax() - essentially it turned off the use of HLT. This workaround was commented in the code as: "disable hlt during certain critical i/o operations" "This halt magic was a workaround for ancient floppy DMA wreckage. It should be safe to remove." H. Peter Anvin additionally adds: "To the best of my knowledge, no-hlt only existed because of flaky power distributions on 386/486 systems which were sold to run DOS. Since DOS did no power management of any kind, including HLT, the power draw was fairly uniform; when exposed to the much hhigher noise levels you got when Linux used HLT caused some of these systems to fail. They were by far in the minority even back then." Alan Cox further says: "Also for the Cyrix 5510 which tended to go castors up if a HLT occurred during a DMA cycle and on a few other boxes HLT during DMA tended to go astray. Do we care ? I doubt it. The 5510 was pretty obscure, the 5520 fixed it, the 5530 is probably the oldest still in any kind of use." So, let's finally drop this. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Stephen Hemminger <shemminger@vyatta.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/n/tip-3rhk9bzf0x9rljkv488tloib@git.kernel.org [ If anyone cares then alternative instruction patching could be used to replace HLT with a one-byte NOP instruction. Much simpler. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
