path: root/Documentation/filesystems/00-INDEX
2015-02-16dax: replace XIP documentation with DAX documentationMatthew Wilcox
Based on the original XIP documentation, this documents the current state of affairs, and includes instructions on how users can enable DAX if their devices and kernel support it. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Randy Dunlap <rdunlap@infradead.org> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-10Documentation/: update 00-INDEX filesHenrik Austad
Some of the 00-INDEX files are somewhat outdated and some folders does not contain 00-INDEX at all. Only outdated (with the notably exception of spi) indexes are touched here, the 169 folders without 00-INDEX has not been touched. New 00-INDEX - spi/* was added in a series of commits dating back to 2006 Added files (missing in (*/)00-INDEX) - dmatest.txt was added by commit 851b7e16a07d ("dmatest: run test via debugfs") - this_cpu_ops.txt was added by commit a1b2a555d637 ("percpu: add documentation on this_cpu operations") - ww-mutex-design.txt was added by commit 040a0a371005 ("mutex: Add support for wound/wait style locks") - bcache.txt was added by commit cafe56359144 ("bcache: A block layer cache") - kernel-per-CPU-kthreads.txt was added by commit 49717cb40410 ("kthread: Document ways of reducing OS jitter due to per-CPU kthreads") - phy.txt was added by commit ff764963479a ("drivers: phy: add generic PHY framework") - block/null_blk was added by commit 12f8f4fc0314 ("null_blk: documentation") - module-signing.txt was added by commit 3cafea307642 ("Add Documentation/module-signing.txt file") - assoc_array.txt was added by commit 3cb989501c26 ("Add a generic associative array implementation.") - arm/IXP4xx was part of the initial repo - arm/cluster-pm-race-avoidance.txt was added by commit 7fe31d28e839 ("ARM: mcpm: introduce helpers for platform coherency exit/setup") - arm/firmware.txt was added by commit 7366b92a77fc ("ARM: Add interface for registering and calling firmware-specific operations") - arm/kernel_mode_neon.txt was added by commit 2afd0a05241d ("ARM: 7825/1: document the use of NEON in kernel mode") - arm/tcm.txt was added by commit bc581770cfdd ("ARM: 5580/2: ARM TCM (Tightly-Coupled Memory) support v3") - arm/vlocks.txt was added by commit 9762f12d3e05 ("ARM: mcpm: Add baremetal voting mutexes") - blackfin/gptimers-example.c, Makefile was added by commit 4b60779d5ea7 ("Blackfin: add an example showing how to use the gptimers API") - devicetree/usage-model.txt was added by commit 31134efc681a ("dt: Linux DT usage model documentation") - fb/api.txt was added by commit fb21c2f42879 ("fbdev: Add FOURCC-based format configuration API") - fb/sm501.txt was added by commit e6a049807105 ("video, sm501: add edid and commandline support") - fb/udlfb.txt was added by commit 96f8d864afd6 ("fbdev: move udlfb out of staging.") - filesystems/Makefile was added by commit 1e0051ae48a2 ("Documentation/fs/: split txt and source files") - filesystems/nfs/nfsd-admin-interfaces.txt was added by commit 8a4c6e19cfed ("nfsd: document kernel interfaces for nfsd configuration") - ide/warm-plug-howto.txt was added by commit f74c91413ec6 ("ide: add warm-plug support for IDE devices (take 2)") - laptops/Makefile was added by commit d49129accc21 ("Documentation/laptop/: split txt and source files") - leds/leds-blinkm.txt was added by commit b54cf35a7f65 ("LEDS: add BlinkM RGB LED driver, documentation and update MAINTAINERS") - leds/ledtrig-oneshot.txt was added by commit 5e417281cde2 ("leds: add oneshot trigger") - leds/ledtrig-transient.txt was added by commit 44e1e9f8e705 ("leds: add new transient trigger for one shot timer activation") - m68k/README.buddha was part of the initial repo - networking/LICENSE.(qla3xxx|qlcnic|qlge) was added by commits 40839129f779, c4e84bde1d59, 5a4faa873782 - networking/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - networking/i40evf.txt was added by commit 105bf2fe6b32 ("i40evf: add driver to kernel build system") - networking/ipsec.txt was added by commit b3c6efbc36e2 ("xfrm: Add file to document IPsec corner case") - networking/mac80211-auth-assoc-deauth.txt was added by commit 3cd7920a2be8 ("mac80211: add auth/assoc/deauth flow diagram") - networking/netlink_mmap.txt was added by commit 5683264c3981 ("netlink: add documentation for memory mapped I/O") - networking/nf_conntrack-sysctl.txt was added by commit c9f9e0e1597f ("netfilter: doc: add nf_conntrack sysctl api documentation") lan) - networking/team.txt was added by commit 3d249d4ca7d0 ("net: introduce ethernet teaming device") - networking/vxlan.txt was added by commit d342894c5d2f ("vxlan: virtual extensible lan") - power/runtime_pm.txt was added by commit 5e928f77a09a ("PM: Introduce core framework for run-time PM of I/O devices (rev. 17)") - power/charger-manager.txt was added by commit 3bb3dbbd56ea ("power_supply: Add initial Charger-Manager driver") - RCU/lockdep-splat.txt was added by commit d7bd2d68aa2e ("rcu: Document interpretation of RCU-lockdep splats") - s390/kvm.txt was added by 5ecee4b (KVM: s390: API documentation) - s390/qeth.txt was added by commit b4d72c08b358 ("qeth: bridgeport support - basic control") - scheduler/sched-bwc.txt was added by commit 88ebc08ea9f7 ("sched: Add documentation for bandwidth control") - scsi/advansys.txt was added by commit 4bd6d7f35661 ("[SCSI] advansys: Move documentation to Documentation/scsi") - scsi/bfa.txt was added by commit 1ec90174bdb4 ("[SCSI] bfa: add readme file") - scsi/bnx2fc.txt was added by commit 12b8fc10eaf4 ("[SCSI] bnx2fc: Add driver documentation") - scsi/cxgb3i.txt was added by commit c3673464ebc0 ("[SCSI] cxgb3i: Add cxgb3i iSCSI driver.") - scsi/hpsa.txt was added by commit 992ebcf14f3c ("[SCSI] hpsa: Add hpsa.txt to Documentation/scsi") - scsi/link_power_management_policy.txt was added by commit ca77329fb713 ("[libata] Link power management infrastructure") - scsi/osd.txt was added by commit 78e0c621deca ("[SCSI] osd: Documentation for OSD library") - scsi/scsi-parameter.txt was created/moved by commit 163475fb111c ("Documentation: move SCSI parameters to their own text file") - serial/driver was part of the initial repo - serial/n_gsm.txt was added by commit 323e84122ec6 ("n_gsm: add a documentation") - timers/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - virt/kvm/s390.txt was added by commit d9101fca3d57 ("KVM: s390: diagnose call documentation") - vm/split_page_table_lock was added by commit 49076ec2ccaf ("mm: dynamically allocate page->ptl if it cannot be embedded to struct page") - w1/slaves/w1_ds28e04 was added by commit fbf7f7b4e2ae ("w1: Add 1-wire slave device driver for DS28E04-100") - w1/masters/omap-hdq was added by commit e0a29382c6f5 ("hdq: documentation for OMAP HDQ") - x86/early-microcode.txt was added by commit 0d91ea86a895 ("x86, doc: Documentation for early microcode loading") - x86/earlyprintk.txt was added by commit a1aade478862 ("x86/doc: mini-howto for using earlyprintk=dbgp") - x86/entry_64.txt was added by commit 8b4777a4b50c ("x86-64: Document some of entry_64.S") - x86/pat.txt was added by commit d27554d874c7 ("x86: PAT documentation") Moved files - arm/kernel_user_helpers.txt was moved out of arch/arm/kernel by commit 37b8304642c7 ("ARM: kuser: move interface documentation out of the source code") - efi-stub.txt was moved out of x86/ and down into Documentation/ in commit 4172fe2f8a47 ("EFI stub documentation updates") - laptops/hpfall.c was moved out of hwmon/ and into laptops/ in commit efcfed9bad88 ("Move hp_accel to drivers/platform/x86") - commit 5616c23ad9cd ("x86: doc: move x86-generic documentation from Doc/x86/i386"): * x86/usb-legacy-support.txt * x86/boot.txt * x86/zero_page.txt - power/video_extension.txt was moved to acpi in commit 70e66e4df191 ("ACPI / video: move video_extension.txt to Documentation/acpi") Removed files (left in 00-INDEX) - memory.txt was removed by commit 00ea8990aadf ("memory.txt: remove stray information") - gpio.txt was moved to gpio/ in commit fd8e198cfcaa ("Documentation: gpiolib: document new interface") - networking/DLINK.txt was removed by commit 168e06ae26dd ("drivers/net: delete old parallel port de600/de620 drivers") - serial/hayes-esp.txt was removed by commit f53a2ade0bb9 ("tty: esp: remove broken driver") - s390/TAPE was removed by commit 9e280f669308 ("[S390] remove tape block docu") - vm/locking was removed by commit 57ea8171d2bc ("mm: documentation: remove hopelessly out-of-date locking doc") - laptops/acer-wmi.txt was remvoed by commit 020036678e81 ("acer-wmi: Delete out-of-date documentation") Typos/misc issues - rpc-server-gss.txt was added as knfsd-rpcgss.txt in commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication.") - commit b88cf73d9278 ("net: add missing entries to Documentation/networking/00-INDEX") * generic-hdlc.txt was added as generic_hdlc.txt * spider_net.txt was added as spider-net.txt - w1/master/mxc-w1 was added as mxc_w1 by commit a5fd9139f74c ("w1: add 1-wire master driver for i.MX27 / i.MX31") - s390/zfcpdump.txt was added as zfcpdump by commit 6920c12a407e ("[S390] Add Documentation/s390/00-INDEX.") Signed-off-by: Henrik Austad <henrik@austad.us> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [rcu bits] Acked-by: Rob Landley <rob@landley.net> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <robh+dt@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Mark Brown <broonie@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Gleb Natapov <gleb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Len Brown <len.brown@intel.com> Cc: James Bottomley <JBottomley@parallels.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23Documentation/filesystems/00-INDEX: updatesFabian Frederick
Add the following documentation-files with description : -autofs4-mount-control.txt -btrfs.txt -debugfs.txt -devpts.txt -fiemap.txt -gfs2-glocks.txt -gfs2-uevents.txt -omfs.txt -path-lookup.txt -qnx6.txt -quota.txt -squashfs.txt -sysfs-tagging.txt -ubifs.txt -xfs-delayed-logging-design.txt -xfs-self-describing-metadata.txt Add the following documentation directories with description : -caching -cifs (replacing cifs.txt) -pohmelfs Remove the following documentation-files reference: -dentry-locking.txt -reiser4.txt Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-20Merge tag 'for-3.8-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull new F2FS filesystem from Jaegeuk Kim: "Introduce a new file system, Flash-Friendly File System (F2FS), to Linux 3.8. Highlights: - Add initial f2fs source codes - Fix an endian conversion bug - Fix build failures on random configs - Fix the power-off-recovery routine - Minor cleanup, coding style, and typos patches" From the Kconfig help text: F2FS is based on Log-structured File System (LFS), which supports versatile "flash-friendly" features. The design has been focused on addressing the fundamental issues in LFS, which are snowball effect of wandering tree and high cleaning overhead. Since flash-based storages show different characteristics according to the internal geometry or flash memory management schemes aka FTL, F2FS and tools support various parameters not only for configuring on-disk layout, but also for selecting allocation and cleaning algorithms. and there's an article by Neil Brown about it on lwn.net: http://lwn.net/Articles/518988/ * tag 'for-3.8-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (36 commits) f2fs: fix tracking parent inode number f2fs: cleanup the f2fs_bio_alloc routine f2fs: introduce accessor to retrieve number of dentry slots f2fs: remove redundant call to f2fs_put_page in delete entry f2fs: make use of GFP_F2FS_ZERO for setting gfp_mask f2fs: rewrite f2fs_bio_alloc to make it simpler f2fs: fix a typo in f2fs documentation f2fs: remove unused variable f2fs: move error condition for mkdir at proper place f2fs: remove unneeded initialization f2fs: check read only condition before beginning write out f2fs: remove unneeded memset from init_once f2fs: show error in case of invalid mount arguments f2fs: fix the compiler warning for uninitialized use of variable f2fs: resolve build failures f2fs: adjust kernel coding style f2fs: fix endian conversion bugs reported by sparse f2fs: remove unneeded version.h header file from f2fs.h f2fs: update the f2fs document f2fs: update Kconfig and Makefile ...
2012-12-11f2fs: add documentJaegeuk Kim
This adds a document describing the mount options, proc entries, usage, and design of Flash-Friendly File System, namely F2FS. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-10-30efivarfs: Add documentation for the EFI variable filesystemMatt Fleming
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2010-10-05smbfs: move to drivers/stagingArnd Bergmann
smbfs has been scheduled for removal in 2.6.27, so maybe we can now move it to drivers/staging on the way out. smbfs still uses the big kernel lock and nobody is going to fix that, so we should be getting rid of it soon. This removes the 32 bit compat mount and ioctl handling code, which is implemented in common fs code, and moves all smbfs related files into drivers/staging/smbfs. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-29ceph: some documentations fixesCheng Renquan
New documentation should have an entry in the 00-INDEX. Correct git urls. Signed-off-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-03-12Documentation/fs/: split txt and source filesRandy Dunlap
Make dnotify_test.c source file and add it to Makefile so that bitrot can be prevented. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Change magic number [LogFS] Remove h_version field [LogFS] Check feature flags [LogFS] Only write journal if dirty [LogFS] Fix bdev erases [LogFS] Silence gcc [LogFS] Prevent 64bit divisions in hash_index [LogFS] Plug memory leak on error paths [LogFS] Add MAINTAINERS entry [LogFS] add new flash file system Fixed up trivial conflict in lib/Kconfig, and a semantic conflict in fs/logfs/inode.c introduced by write_inode() being changed to use writeback_control' by commit a9185b41a4f84971b930c519f0c63bd450c4810d ("pass writeback_control to ->write_inode")
2009-12-16Merge branch 'for-2.6.33' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits) nfsd: remove pointless paths in file headers nfsd: move most of nfsfh.h to fs/nfsd nfsd: remove unused field rq_reffh nfsd: enable V4ROOT exports nfsd: make V4ROOT exports read-only nfsd: restrict filehandles accepted in V4ROOT case nfsd: allow exports of symlinks nfsd: filter readdir results in V4ROOT case nfsd: filter lookup results in V4ROOT case nfsd4: don't continue "under" mounts in V4ROOT case nfsd: introduce export flag for v4 pseudoroot nfsd: let "insecure" flag vary by pseudoflavor nfsd: new interface to advertise export features nfsd: Move private headers to source directory vfs: nfsctl.c un-used nfsd #includes lockd: Remove un-used nfsd headers #includes s390: remove un-used nfsd #includes sparc: remove un-used nfsd #includes parsic: remove un-used nfsd #includes compat.c: Remove dependence on nfsd private headers ...
2009-12-10trivial: some small fixes in exofs documentationThadeu Lima de Souza Cascardo
Add exofs.txt to filesystems Documentation index and fix some typos, identation and grammar. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2009-11-20[LogFS] add new flash file systemJoern Engel
This is a new flash file system. See Documentation/filesystems/logfs.txt Signed-off-by: Joern Engel <joern@logfs.org>
2009-11-06nfs: move more to Documentation/filesystems/nfsJ. Bruce Fields
Oops: I missed two files in the first commit that created this directory. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-27nfs: new subdir Documentation/filesystems/nfsJ. Bruce Fields
We're adding enough nfs documentation that it may as well have its own subdirectory. Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28update Documentation/filesystems/00-INDEX with new nfsd related docs.Benny Halevy
Signed-off-by: Benny Halevy <bhalevy@panasas.com> Cc: James Lentini <jlentini@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-07nilfs2: add documentRyusuke Konishi
This adds a document describing the features, mount options, userland tools, usage, disk format, and related URLs for the nilfs2 file system. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11Documentation: move rpc-cache.txt to filesystems/J. Bruce Fields
This file is nfs-related. (Maybe Documentation/filesystems/ would benefit from a separate nfs/ directory at some point.) Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-04-11Documentation: move nfsroot.txt to filesystems/J. Bruce Fields
Documentation/ is a little large, and filesystems/ seems an obvious place for this file. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-03-30Add the seq_file documentationJonathan Corbet
This is an updated version of the document describing the seq_file interface. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-02-07Documentation: move sharedsubtrees.txt to filesystems/J. Bruce Fields
This documentation is also vfs-related. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Documentation: move dnotify.txt to filesystems/J. Bruce Fields
I'm inclined to think dnotify belongs in filesystems/. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Documentation: add entries to filesystems/00-INDEX for several untracked filesDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Cc: Rob Landley <rob@landley.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09Documentation: move locks.txt in filesystems/J. Bruce Fields
This documentation (about file locking) belongs in filesystems/. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-10-09Documentation: move mandatory locking documentation to filesystems/J. Bruce Fields
Shouldn't this mandatory-locking documentation be in the Documentation/filesystems directory? Give it a more descriptive name while we're at it, and update 00-INDEX with a more inclusive description of Documentation/filesystems (which has already talked about more than just individual filesystems). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com>
2007-09-11Documentation/00-INDEX: notice ecryptfs.txt movedRob Landley
ecryptfs.txt moved into filesystems, make 00-INDEX follow. Signed-off-by: Rob Landley <rob@landley.net> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-189p: implement optional loose read cacheEric Van Hensbergen
While cacheing is generally frowned upon in the 9p world, it has its place -- particularly in situations where the remote file system is exclusive and/or read-only. The vacfs views of venti content addressable store are a real-world instance of such a situation. To facilitate higher performance for these workloads (and eventually use the fscache patches), we have enabled a "loose" cache mode which does not attempt to maintain any form of consistency on the page-cache or dcache. This results in over two orders of magnitude performance improvement for cacheable block reads in the Bonnie benchmark. The more aggressive use of the dcache also seems to improve metadata operational performance. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2006-10-11[PATCH] Documentation/filesystems/ext4.txtDave Kleikamp
This file, ext4.txt, was put together with information from Andrew Morton, Andreas Dilger, Suparna Bhattacharya, and Ted Ts'o. I copied the mount options, with the exception of "extents", from ext3.txt, so if anyone is aware of anything out-of-date, please let me know. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Suparna Bhattacharya <suparna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03remove mentionings of devfs in documentationAdrian Bunk
Now that devfs is removed, there's no longer any need to document how to do this or that with devfs. This patch includes some improvements by Joe Perches. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-27[PATCH] Documentation update for relay interfaceTom Zanussi
Here's updated documentation for the relay interface, rewritten to match the relayfs->relay changes. It also moves relayfs.txt to relay.txt in the process. It includes the changes to relayfs.txt previously posted by Randy Dunlap, thanks for those. The relay-apps examples have also been updated to match, and can be found on the sourceforge relayfs website. Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Docs update: missing files and descriptions for filesystems/00-INDEXJesper Juhl
Add missing files and descriptions to Documentation/filesystems/00-INDEX Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-05Merge http://oss.oracle.com/git/ocfs2Linus Torvalds
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
dlmfs: A minimal dlm userspace interface implemented via a virtual file system. Most of the OCFS2 tools make use of this to take cluster locks when doing operations on the file system. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
2006-01-03[PATCH] configfs: User-driven configuration filesystemJoel Becker
Configfs, a file system for userspace-driven kernel object configuration. The OCFS2 stack makes extensive use of this for propagation of cluster configuration information into kernel. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2006-01-03Documentation/filesystems/00-INDEX: remove entry for fat_cvf.txtPaolo 'Blaisorblade' Giarrusso
Remove non-existing entry for fat_cvf.txt (was it ever supported?). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
