Nilfs has "discard" mount option which issues discard/TRIM commands to
underlying block device, but it lacks a complementary option and has
no way to disable the feature through remount.
This adds "nodiscard" option to resolve this imbalance.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Nilfs enables write barriers by default and has "nobarrier" mount
option to disable this feature. But it lacks the complementary option
and has no way to re-enable the feature on remount.
This adds "barrier" option to resolve this imbalance.
Like ext3, nilfs has 'errors' mount option to allow specifying desired
behavior on severe errors.
Currently, the default action is 'errors=continue' and has potential
to advance filesystem corruption for severe errors.
This will change the action to 'errors=remount-ro' to avoid the issue.
This adds a function to send discard requests for given array of
segment numbers, and calls the function when garbage collection
succeeded.
Signed-off-by: Jiro SEKIBA <jir@unicus.jp>
This replaces the list address for nilfs discussion to linux-nilfs at
vger.kernel.org from users at nilfs.org.
This adds "norecovery" mount option which disables temporal write
access to read-only mounts or snapshots during mount/recovery.
Without this option, write access will be even performed for those
types of mounts; the temporal write access is needed to mount root
file system read-only after an unclean shutdown.
This option will be helpful when user wants to prevent any write
access to the device.
Cc: Eric Sandeen <sandeen@redhat.com>
Since most of fs using nofoobar style option,
modified barrier=off option as nobarrier.
This clarifies missing features of nilfs as a regular filesystem.
The sketch file is a file to mark checkpoints with user data. It was
experimentally introduced in the original implementation, and now
obsolete. The file was handled differently with regular files; the file
size got truncated when a checkpoint was created.
This stops the special treatment and will treat it as a regular file.
Most users are not affected because mkfs.nilfs2 no longer makes this file.
This adds a document describing the features, mount options, userland
tools, usage, disk format, and related URLs for the nilfs2 file system.
