path: root/Documentation/filesystems/ramfs-rootfs-initramfs.txt
2008-11-30Trivial Documentation/filesystems/ramfs-rootfs-initramfs.txt fixfrans
A very minor patch on ramfs-rootfs-initramfs.txt: update the location where CONFIG_INITRAMFS_SOURCE lives in menuconfig Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Fix Documentation/filesystems/ramfs-rootfs-initramfs.txtfrans
First a file hello.c is created, then the file hello2.c is compiled. Change this to hello.c Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03Documentation: fix type errorDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17docs: ramdisk/initrd/initramfs correctionsRandy Dunlap
initrd/initramfs/ramdisk docs: - fix typos/spellos/grammar - clarify RAM disk config location - correct cpio option Acked-by: Bryan O'Sullivan <bos@serpentine.com> Acked-by: Rob Landley <rob@landley.net> Cc: Werner Almesberger <werner@almesberger.net> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-25[PATCH] Initramfs docs updateRob Landley
New section on creating an external initramfs image using cpio (with script), a warning about bad advice in the cpio man page, a bit of debugging advice (hello world and rdinit=/bin/sh), and a few minor tweaks to other parts of it. Signed-off-by: Rob Landley <rob@landley.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] update to the initramfs docsRob Landley
Based on questions people have asked me. Repeatedly. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] ramfs, rootfs, and initramfs docsRob Landley
Docs for ramfs, rootfs, and initramfs. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
